Евтин читав цветен лазерен принтер?
    От: Евтин читав цветен лазерен принтер?
    Първоначално публикуван от DBRS Преглед на мнение
    Glow:
    Brother
    DCP-9020CDW ? и имаш ли го при тебе
    ми 600лв. бря - евтинИя,
    навремето 3000usd продавах черно бели баси
    Това което си избрал е супер. Даже спокойно може да си работи в малък офис. 2500 копия правят касетите, а зареждането им е към 65 лв.
    За съжаление го нямам при мене, киорав Brother не е останал...
      Лазерно многофункционално устройство, Brother DCP-9020CDW Colour Laser Multifunctional
      Print, Copy, Scan
      Up to 2400 (2400 x 600), 600 x 600 dpi
      Up to 18 ppm; FPOT: Less than 16 s
      Color scanner
      Optical: 1200 x 2400 dpi (Scancer glass), 1200 x 600dpi (ADF); Scan resolution (enhanced): Up to 19200 x 19200 dpi
      48bit internal / 24bit external
      256
      Scan to: E-mail, Image, OCR, File
      Up to 600x600 dpi
      Up to 18 ppm
      Up to 18 ppm
      from 25% to 400% in 1% increments
      Hi-Speed USB 2.0
      Ethernet 10Base-T/100Base-TX
      IEEE 802.11b/g/n (Infrastructure Mode / Adhoc Mode)
      Standard Paper Tray: Plain & recycled paper; Manual Slot: Plain, recycled, bond & glossy paper
      Standard Paper Tray: A4, Letter, B5(JIS), A5, A5(Long Edge), A6, Executive, Legal, Folio; Manual Slot: 76.2mm to 215.9mm x Length: 116mm to 355.6mm; ADF: A4
      Standard Paper Tray: between 60 - 105 g/m2; Manual Slot: between 60 - 163g/m2
      Standard Paper Tray: Up to 250 sheets; Manual Slot: 1 Sheet
      Up to (face down)100 sheets
      35 sheet ADF
      yes (3.5 sheets per minute) colour & mono)
      Standard toners : TN-241BK (2500 pages), TN-241C/TN-241M/TN-241Y (1400 pages per each color); High yield toners: TN-245C/TN-245M/TN-245Y (2200 pages in accordance with ISO/IEC1979
      30 000 pages; Recommended monthly: 300-1500 pages
      Windows 8® 7/Vista/XP, Windows Server® 2003/2003 R2/2008/2008 R2 (Windows Server® print only; Mac OS X 10.6.8, 10.7.x, 10.8.x; Linux (free download from http://solutions.brother.com)
      410 x 483 x 410 mm
      White-Grey
      Direct USB Printing & Scanning; 9.3cm TFT Display; Emulation: PCL6, BR-Script3 (Postscript®3TM Language Emulation)
      24 месеца
      Цена при мен - в Пловдив - 732.00 лв
        Ъ-ъ, последното десетилетие предпочитам самнсунзите. От наблюдение на няколко колеги с ниско потребление - също.
        Тая фирма, пък - ХП не ща да я чуя, камо ли пък да я видя. Беше добра - преди няколко десетилетия.
          Първоначално публикуван от chris_vicom Преглед на мнение
          Последния самсунг които зареждах беше "прекрасен". Само - Чип 25 лв. Касета 1500 копия... Отделно, че касетата е е направена за еднократна употреба. Като я отвориш да я заредиш после трябва да я лепиш...
            Гласувам за Брадър.
            И един тънък намек:
            повечето плювалници се запушват като не ги ползваш. Брадъра не (ако го държиш включен де).
            Софтуерът на абсолютно всичките е бъгавиня. Ама се научава човек да заобикаля мотиките.
            Значи наклоняваме към Брадъра, емулира ли добре стандартни HP, ъъъ PCL6 ?
            пп
            пълнене на цветни касети съществува ли
            Суперспам - спама на суперите
              Съществува. Ако ти го прави читава фирма става добре.
                HP LaserJet Pro 200 color printer M251nw (CF147A)
                Купих за офиса почти същия, ама без "w" накрая. Мястото му е на 50 см. от компютъра и реших да спестя некой лев. Ся, Добри... зависи кво печаташ, де... ама тая работа с XXXXL касети за 2000...амнайсе копия не е баш тъй. Въпросните тиражи се спрягат при десетина процента (ако се лъжа, знаещите да ме поправят) запълване на страницата. Демек, текст, шарена диаграмка или нещо от рода. Тръгнеш ли на печатане на картинки с фонове, и ала- бали, тия капацитети ги забравяш.
                И-и-и-и, да имат пълнене касетите, за тоя модел е към 30-35 лева, а "Not OEM" касети, сравнително читави са около 50- 60 лв. за XL- капацитета.
                Последно редактирано от Тропчо; 04-02-14, 23:42.
                  ...при десетина процента....
                  При 5%.
                  ...и общо взето при нормално ползване (текст + крайно рядко нещо по-наситено) отговарят на действителността, с леко оптимистичен привкус от страна на производителя.
                    3405, нали?
                    не се лепи, заварява се.
                    за да не се слага чип от 25 лева, се правят едни други неща..
                      3405, нали?
                      d101 е касетата/чипа с 2 -та "процесора" - Другите неща са ясни, но не всеки иска да му се "бърка" новото гаранционнно принтерче...
                        Така,
                        при тез цени се спираме на комбайни
                        финалисти:
                        Brother
                        DCP-9020CDW, CANON i-SENSYS MF8280Cw
                        HP Color LaserJet Pro MFP M176n
                        Hp-to най-евтино, но като цена е подобна на канона,
                        значи решаващи ще са разходите консумативи, които какви са, разчитам на вас
                          Така,
                          финалисти:
                          Brother
                          HP Color LaserJet Pro MFP M176n -
                          CANON i-SENSYS MF8280Cw - 1500 копия цветни касети - 55 лв с чипа, 2500 копия черна 65 лв с чипа
                          HP Color LaserJet Pro MFP M176n - цветни по 1000 копия, черна 1200 копия - 45 с смяна на чипа
                          BrotherDCP-9020CDW - 2500 копия черна, и по 1400 копия за цветните - 65 лв е зареждането
                            Явно бира ще пиеш
                            това "с чипа" имаш предвид при пълнене или съвсем нова касета?
                              Явно бира ще пиеш
                              При пълнене. Освен че се зарежда с тонер, сменя се и чип в касетата, за да знае принтера че е пълен. Педерастия велика. Просто още едно звено по веригата, което взима едни пари.
                                Ясно, като на захранванията по лаптопите напоследък.
                                Благодаря на всички,
                                трябва да измислим къде да се нашморцаме с бири за моя сметка
