OBDII_NEW
P0001Fuel Volume Regulator Control Circuit Open
P0002Fuel Volume Regulator Control CKT Range/Perf
P0003Fuel Volume Regulator Control Circuit Low
P0004Fuel Volume Regulator Control Circuit High
P0005Fuel Shutoff Vlv. A Control Circuit Open
P0006Fuel Shutoff Vlv. A Control Circuit Low
P0007Fuel Shutoff Vlv. A Control Circuit High
P0008Engine Position System Performance (Bank 1)
P0009Engine Position System Performance (Bank 2)
P0010Camshaft Position Actuator A - Bank 1 Circuit Malfunction
P0011Camshaft Position Actuator A -Bank 1 Timing Over-Advan.
P0012Camshaft Position Actuator A - Bank 1 Timing Over-Retard
P0013Camshaft Position Actuator B - Bank 1 Circuit Malfunction
P0014Camshaft Position Actuator B - Bank 1 Timing Over-Advan.
P0015Camshaft Position Actuator B - Bank 1 Timing Over-Retard
P0016Cam/Crankshaft Pos. Correlation Sensor A - Bank 1
P0017Cam/Crankshaft Pos. Correlation Sensor B - Bank 1
P0018Cam/Crankshaft Pos. Correlation Sensor A - Bank 2
P0019Cam/Crankshaft Pos. Correlation Sensor B - Bank 2
P0020Camshaft Position Actuator A - Bank 2 Circuit Malfunction
P0021Camshaft Position Actuator A - Bank 2 Timing Over-Advan.
P0022Camshaft Position Actuator A - Bank 2 Timing Over-Retard
P0023Camshaft Position Actuator B - Bank 2 Circuit Malfunction
P0024Camshaft Position Actuator B - Bank 2 Timing Over-Advan.
P0025Camshaft Position Actuator B - Bank 2 Timing Over-Retard
P0026Intake Valve-Bank 1 Control Solenoid CKT Range/Perf
P0027Exhaust Valve-Bank1 Control Solenoid CKT Range/Perf
P0028Intake Valve-Bank 2 Control Solenoid CKT Range/Perf
P0029Exhaust Valve-Bank2 Control Solenoid CKT Range/Perf
P0030HO2S Bank 1 Sen 1 Heater Circuit
P0031HO2S Bank 1 Sen 1 Heater Circuit Low
P0032HO2S Bank 1 Sen 1 Heater Circuit High
P0033Turbo/Sup Wastegate Control Circuit
P0034Turbo/Sup Wastegate Control Circuit Low
P0035Turbo/Sup Wastegate Control Circuit High
P0036HO2S Bank 1 Sen 2 Heater Circuit
P0037HO2S Bank 1 Sen 2 Heater Circuit Low
P0038HO2S Bank 1 Sen 2 Heater Circuit High
P0039Turbo/Super Charger Bypass Cntrl CKT Performance
P0040O2 Bank 1 Sensor 1 Signals Swapped w/ O2 Bank 2 Sensor 1
P0041O2 Bank 1 Sensor 2 Signals Swapped w/ O2 Bank 2 Sensor 2
P0042HO2S Bank 1 Sen 3 Heater Circuit
P0043HO2S Bank 1 Sen 3 Heater Circuit Low
P0044HO2S Bank 1 Sen 3 Heater Circuit High
P0045Turbo/Super Charger Boost Control Solenoid A Circuit Open
P0046Turbo/Super Charger Boost Control Solenoid A Circuit Range/ Perform ance
P0047Turbo/Super Charger Boost Control Solenoid A Circuit Low
P0048Turbo/Super Charger Boost Control Solenoid A Circuit High
P0049Turbo/Super Charger Boost Input/Turbine Speed Overspeed
P0050HO2S Bank 2 Sen 1 Heater Circuit
P0051HO2S Bank 2 Sen 1 Heater Circuit Low
P0052HO2S Bank 2 Sen 1 Heater Circuit High
P0053HO2S Bank 1 Sen 1 Heater Resistance
P0054HO2S Bank 1 Sen 2 Heater Resistance
P0055HO2S Bank 1 Sen 3 Heater Resistance
P0056HO2S Bank 2 Sen 2 Heater Circuit
P0057HO2S Bank 2 Sen 2 Heater Circuit Low
P0058HO2S Bank 2 Sen 2 Heater Circuit High
P0059HO2S Bank 2 Sen 1 Heater Resistance
P0060HO2S Bank 2 Sen 2 Heater Resistance
P0061HO2S Bank 2 Sen 3 Heater Resistance
P0062HO2S Bank 2 Sen 3 Heater Circuit
P0063HO2S Bank 2 Sen 3 Heater Circuit Low
P0064HO2S Bank 2 Sen 3 Heater Circuit High
P0065Air Assisted Injec. Control Range/Performance
P0066Air Assisted Injec. Control Circuit Low
P0067Air Assisted Injec. Control Circuit High
P0068MAF/MAP Sensor Throttle Position Correlation
P0069MAP/BARO Correlation
P0070Ambient Air Temp. Sensor Circuit
P0071Ambient Air Temp. Sensor Range/Performance
P0072Ambient Air Temp. Sensor Circuit Low
P0073Ambient Air Temp. Sensor Circuit High
P0074Ambient Air Temp. Sensor CKT Intermittent
P0075Intake Valve-Bank 1 Control Circuit
P0076Intake Valve-Bank 1 Control Circuit Low
P0077Intake Valve-Bank 1 Control Circuit High
P0078Exhaust Valve-Bank1 Control Circuit
P0079Exhaust Valve-Bank1 Control Circuit Low
P0080Exhaust Valve-Bank1 Control Circuit High
P0081Intake Valve-Bank 2 Control Circuit
P0082Intake Valve-Bank 2 Control Circuit Low
P0083Intake Valve-Bank 2 Control Circuit High
P0084Exhaust Valve-Bank2 Control Circuit
P0085Exhaust Valve-Bank2 Control Circuit Low
P0086Exhaust Valve-Bank2 Control Circuit High
P0087Fuel Rail Pressure Too Low
P0088Fuel Rail Pressure Too High
P0089Fuel Pressure Reg 1 Performance
P0090Fuel Pressure Reg 1 Control Circuit
P0091Fuel Pressure Reg 1 Control Circuit Low
P0092Fuel Pressure Reg 1 Control Circuit High
P0093Fuel System Leak (Large)
P0094Fuel System Leak (Small)
P0095IAT Sensor 2 Circuit
P0096IAT Sensor 2 CKT Range/Perf
P0097IAT Sensor 2 Circuit Low
P0098IAT Sensor 2 Circuit High
P0099IAT Sensor 2 CKT Intermittent
P0100MAF or VAF A Circuit Malfunction
P0101MAF or VAF A Circuit Range/Perf
P0102MAF or VAF A Circuit Low Input
P0103MAF or VAF A Circuit High Input
P0104MAF or VAF A Circuit Intermittent
P0105MAP/BARO Circuit Malfunction
P0106MAP/BARO CKT Range/Perf
P0107MAP/BARO Circuit Low Input
P0108MAP/BARO Circuit High Input
P0109MAP/BARO CKT Intermittent
P0110IAT Sensor Circuit Malfunction
P0111IAT Sensor 1 CKT Range/Perf
P0112IAT Sensor 1 Circuit Low Input
P0113IAT Sensor 1 Circuit High Input
P0114IAT Sensor 1 CKT Intermittent
P0115Engine Coolant Temp Circuit Malfunction
P0116Engine Coolant Temp CKT Range/Perf
P0117Engine Coolant Temp Circuit Low Input
P0118Engine Coolant Temp Circuit High Input
P0119Engine Coolant Temp CKT Intermittent
P0120TPS/Pedal Position Sensor A Circuit Malfunction
P0121TPS/Pedal Position Sensor A CKT Range/Perf
P0122TPS/Pedal Position Sensor A Circuit Low Input
P0123TPS/Pedal Position Sensor A Circuit High Input
P0124TPS/Pedal Position Sensor A CKT Intermittent
P0125Clsd Loop Fuel Ctrl Insufficient Coolant Temp
P0126Coolant Temp Insufficient Stable Operation
P0127IAT Sensor Too High
P0128Coolant Temp Below Thermostat Regulating Temp
P0129Barometric Pressure Too Low
P0130O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131O2 Sensor Circuit Low Volts (Bank 1 Sensor 1)
P0132O2 Sensor Circuit High Volts (Bank 1 Sensor 1)
P0133O2 Sensor CKT Slow Response (Bank 1 Sensor 1)
P0134O2 Sensor CKT No Activity (Bank 1 Sensor 1)
P0135O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137O2 Sensor Circuit Low Volts (Bank 1 Sensor 2)
P0138O2 Sensor Circuit High Volts (Bank 1 Sensor 2)
P0139O2 Sensor CKT Slow Response (Bank 1 Sensor 2)
P0140O2 Sensor CKT No Activity (Bank 1 Sensor 2)
P0141O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143O2 Sensor Circuit Low Volts (Bank 1 Sensor 3)
P0144O2 Sensor Circuit High Volts (Bank 1 Sensor 3)
P0145O2 Sensor CKT Slow Response (Bank 1 Sensor 3)
P0146O2 Sensor CKT No Activity (Bank 1 Sensor 3)
P0147O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0148Fuel Delivery Malfunction
P0149Fuel Timing Malfunction
P0150O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151O2 Sensor Circuit Low Volts (Bank 2 Sensor 1)
P0152O2 Sensor Circuit High Volts (Bank 2 Sensor 1)
P0153O2 Sensor CKT Slow Response (Bank 2 Sensor 1)
P0154O2 Sensor CKT No Activity (Bank 2 Sensor 1)
P0155O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157O2 Sensor Circuit Low Volts (Bank 2 Sensor 2)
P0158O2 Sensor Circuit High Volts (Bank 2 Sensor 2)
P0159O2 Sensor CKT Slow Response (Bank 2 Sensor 2)
P0160O2 Sensor CKT No Activity (Bank 2 Sensor 2)
P0161O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163O2 Sensor Circuit Low Volts (Bank 2 Sensor 3)
P0164O2 Sensor Circuit High Volts (Bank 2 Sensor 3)
P0165O2 Sensor CKT Slow Response (Bank 2 Sensor 3)
P0166O2 Sensor CKT No Activity (Bank 2 Sensor 3)
P0167O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0168Engine Fuel Temperature Too High
P0169Fuel Composition Incorrect
P0170Fuel Trim Malfunction (Bank 1)
P0171System Too Lean (Bank 1)
P0172System Too Rich (Bank 1)
P0173Fuel Trim Malfunction (Bank 2)
P0174System Too Lean (Bank 2)
P0175System Too Rich (Bank 2)
P0176Fuel Compensation Sensor Circuit Malfunction
P0177Fuel Compensation Sensor CKT Range/Perf
P0178Fuel Compensation Sensor Circuit Low Input
P0179Fuel Compensation Sensor Circuit High Input
P0180Fuel Temperature Sensor A Circuit Malfunction
P0181Fuel Temperature Sensor A CKT Range/Perf
P0182Fuel Temperature Sensor A Circuit Low Input
P0183Fuel Temperature Sensor A Circuit High Input
P0184Fuel Temperature Sensor A CKT Intermittent
P0185Fuel Temperature Sensor B Circuit Malfunction
P0186Fuel Temperature Sensor B CKT Range/Perf
P0187Fuel Temperature Sensor B Circuit Low Input
P0188Fuel Temperature Sensor B Circuit High Input
P0189Fuel Temperature Sensor B CKT Intermittent
P0190Fuel Rail Pressure Sensor Circuit Malfunction
P0191Fuel Rail Pressure Sensor CKT Range/Perf
P0192Fuel Rail Pressure Sensor Circuit Low Input
P0193Fuel Rail Pressure Sensor Circuit High Input
P0194Fuel Rail Pressure Sensor CKT Intermittent
P0195Engine Oil Temp Sensor Circuit Malfunction
P0196Engine Oil Temp Sensor CKT Range/Perf
P0197Engine Oil Temp Sensor Circuit Low Input
P0198Engine Oil Temp Sensor Circuit High Input
P0199Engine Oil Temp Sensor CKT Intermittent
P0200Injector Circuit Open
P0201Injector Circuit Open Cylinder 1
P0202Injector Circuit Open Cylinder 2
P0203Injector Circuit Open Cylinder 3
P0204Injector Circuit Open Cylinder 4
P0205Injector Circuit Open Cylinder 5
P0206Injector Circuit Open Cylinder 6
P0207Injector Circuit Open Cylinder 7
P0208Injector Circuit Open Cylinder 8
P0209Injector Circuit Open Cylinder 9
P0210Injector Circuit Open Cylinder 10
P0211Injector Circuit Open Cylinder 11
P0212Injector Circuit Open Cylinder 12
P0213Cold Start Injector 1 Malfunction
P0214Cold Start Injector 2 Malfunction
P0215Engine Shutoff Solenoid Malfunction
P0216Injection Timing Control Circuit Malfunction
P0217Engine Overtemp Condition
P0218Trans Overtemp Condition
P0219Engine Overspeed Condition
P0220TPS/Pedal Position Sensor/Switch B Circuit Malfunction
P0221TPS/Pedal Position Sensor/Switch B CKT Range/Perf
P0222TPS/Pedal Position Sensor/Switch B Circuit Low Input
P0223TPS/Pedal Position Sensor/Switch B Circuit High Input
P0224TPS/Pedal Position Sensor/Switch B CKT Intermittent
P0225TPS/Pedal Position Sensor/Switch C Circuit Malfunction
P0226TPS/Pedal Position Sensor/Switch C CKT Range/Perf
P0227TPS/Pedal Position Sensor/Switch C Circuit Low Input
P0228TPS/Pedal Position Sensor/Switch C Circuit High Input
P0229TPS/Pedal Position Sensor/Switch C CKT Intermittent
P0230Fuel Pump Primary Circuit Malfunction
P0231Fuel Pump Secondary Circuit Low
P0232Fuel Pump Secondary Circuit High
P0233Fuel Pump Secondary Circuit Intermittent Ckt
P0234Engine Overboost Condition
P0235Turbo/Super Boost Sensor A Circuit Malfunction
P0236Turbo/Super Boost Sensor A CKT Range/Perf
P0237Turbo/Super Boost Sensor A Circuit Low Input
P0238Turbo/Super Boost Sensor A Circuit High Input
P0239Turbo/Super Boost Sensor B Circuit Malfunction
P0240Turbo/Super Boost Sensor B CKT Range/Perf
P0241Turbo/Super Boost Sensor B Circuit Low Input
P0242Turbo/Super Boost Sensor B Circuit High Input
P0243Turbo/Sup Wastegate Solenoid A Malfunction
P0244Turbo/Sup Wastegate Solenoid A Range/Performance
P0245Turbo/Sup Wastegate Solenoid A Low
P0246Turbo/Sup Wastegate Solenoid A High
P0247Turbo/Sup Wastegate Solenoid B Malfunction
P0248Turbo /Sup Wastegate Solenoid B Range/Performance
P0249Turbo/Sup Wastegate Solenoid B Low
P0250Turbo/Sup Wastegate Solenoid B High
P0251Injection Pump Metering Control A
P0252Injection Pump Metering Control A Range/Performance
P0253Injection Pump Metering Control A Low
P0254Injection Pump Metering Control A High
P0255Injection Pump Metering Control A Intermittent Ckt
P0256Injection Pump Metering Control B Malfunction
P0257Injection Pump Metering Control B Range/Performance
P0258Injection Pump Metering Control B Low
P0259Injection Pump Metering Control B High
P0260Injection Pump Metering Control B Intermittent Ckt
P0261Cylinder 1 Injector Control Circuit Low
P0262Cylinder 1 Injector Control Circuit High
P0263Cylinder 1 Contribution Balance Fault
P0264Cylinder 2 Injector Control Circuit Low
P0265Cylinder 2 Injector Control Circuit High
P0266Cylinder 2 Contribution Balance Fault
P0267Cylinder 3 Injector Control Circuit Low
P0268Cylinder 3 Injector Control Circuit High
P0269Cylinder 3 Contribution Balance Fault
P0270Cylinder 4 Injector Control Circuit Low
P0271Cylinder 4 Injector Control Circuit High
P0272Cylinder 4 Contribution Balance Fault
P0273Cylinder 5 Injector Control Circuit Low
P0274Cylinder 5 Injector Control Circuit High
P0275Cylinder 5 Contribution Balance Fault
P0276Cylinder 6 Injector Control Circuit Low
P0277Cylinder 6 Injector Control Circuit High
P0278Cylinder 6 Contribution Balance Fault
P0279Cylinder 7 Injector Control Circuit Low
P0280Cylinder 7 Injector Control Circuit High
P0281Cylinder 7 Contribution Balance Fault
P0282Cylinder 8 Injector Control Circuit Low
P0283Cylinder 8 Injector Control Circuit High
P0284Cylinder 8 Contribution Balance Fault
P0285Cylinder 9 Injector Control Circuit Low
P0286Cylinder 9 Injector Control Circuit High
P0287Cylinder 9 Contribution Balance Fault
P0288Cylinder 10 Injector Control Circuit Low
P0289Cylinder 10 Injector Control Circuit High
P0290Cylinder 10 Contribution Balance Fault
P0291Cylinder 11 Injector Control Circuit Low
P0292Cylinder 11 Injector Control Circuit High
P0293Cylinder 11 Contribution Balance Fault
P0294Cylinder 12 Injector Control Circuit Low
P0295Cylinder 12 Injector Control Circuit High
P0296Cylinder 12 Contribution Balance Fault
P0297Vehicle Overspeed Error
P0298Engine Oil Temperature Too High
P0299Turbo/Super Charger UnderBoost
P0300Random/Multiple Cylinder Misfire Detected
P0301Cylinder 1 Misfire Detected
P0302Cylinder 2 Misfire Detected
P0303Cylinder 3 Misfire Detected
P0304Cylinder 4 Misfire Detected
P0305Cylinder 5 Misfire Detected
P0306Cylinder 6 Misfire Detected
P0307Cylinder 7 Misfire Detected
P0308Cylinder 8 Misfire Detected
P0309Cylinder 9 Misfire Detected
P0310Cylinder 10 Misfire Detected
P0311Cylinder 11 Misfire Detected
P0312Cylinder 12 Misfire Detected
P0313Misfire Detected Low Fuel Level
P0314Misfire Detected Cyl. not Specific
P0315Crankshaft Position System Variation Not Learned
P0316Misfire Detected 1st 1000 Revs.
P0317Rough Road Hardware Not Present
P0318Rough Road Sensor A Signal Circuit
P0319Rough Road Sensor B
P0320Ignition/Dist Engine Speed Input Circuit Malfunction
P0321Ignition/Dist Engine Speed Input CKT Range/Perf
P0322Ignition/Dist Engine Speed Input Circuit No Signal
P0323Ignition/Dist Engine Speed Input CKT Intermittent
P0324Knock Control System Malfunction
P0325Knock Sensor 1 Circuit Malfunction Bank 1 or 1 Sensor
P0326Knock Sensor 1 CKT Range/Perf Bank 1 or 1 Sensor
P0327Knock Sensor 1 Circuit Low Input Bank 1 or 1 Sensor
P0328Knock Sensor 1 Circuit High Input Bank 1 or 1 Sensor
P0329Knock Sensor 1 CKT Intermittent Bank 1 or 1 Sensor
P0330Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331Knock Sensor 2 CKT Range/Perf (Bank 2)
P0332Knock Sensor 2 Circuit Low Input (Bank 2)
P0333Knock Sensor 2 Circuit High Input (Bank 2)
P0334Knock Sensor 2 CKT Intermittent (Bank 2)
P0335Crankshaft Position Sensor A Circuit Malfunction
P0336Crankshaft Position Sensor A CKT Range/Perf
P0337Crankshaft Position Sensor A Circuit Low Input
P0338Crankshaft Position Sensor A Circuit High Input
P0339Crankshaft Position Sensor A CKT Intermittent
P0340Camshaft Position Sensor A - Bank 1 Circuit Malfunction
P0341Camshaft Position Sensor A - Bank 1 CKT Range/Perf
P0342Camshaft Position Sensor A - Bank 1 Circuit Low Input
P0343Camshaft Position Sensor A - Bank 1 Circuit High Input
P0344Camshaft Position Sensor A - Bank 1 CKT Intermittent
P0345Camshaft Position Sensor A - Bank 2 Circuit Malfunction
P0346Camshaft Position Sensor A - Bank 2 CKT Range/Perf
P0347Camshaft Position Sensor A - Bank 2 Circuit Low Input
P0348Camshaft Position Sensor A - Bank 2 Circuit High Input
P0349Camshaft Position Sensor A - Bank 2 CKT Intermittent
P0350Ignition Coil Primary/Secondary Circuit Malfunction
P0351Ignition Coil A Primary/Secondary Circuit Malfunction
P0352Ignition Coil B Primary/Secondary Circuit Malfunction
P0353Ignition Coil C Primary/Secondary Circuit Malfunction
P0354Ignition Coil D Primary/Secondary Circuit Malfunction
P0355Ignition Coil E Primary/Secondary Circuit Malfunction
P0356Ignition Coil F Primary/Secondary Circuit Malfunction
P0357Ignition Coil G Primary/Secondary Circuit Malfunction
P0358Ignition Coil H Primary/Secondary Circuit Malfunction
P0359Ignition Coil I Primary/Secondary Circuit Malfunction
P0360Ignition Coil J Primary/Secondary Circuit Malfunction
P0361Ignition Coil K Primary/Secondary Circuit Malfunction
P0362Ignition Coil L Primary/Secondary Circuit Malfunction
P0363Misfire Detected Fueling Disabled
P0365Camshaft Position Sensor B - Bank 1 Circuit Malfunction
P0366Camshaft Position Sensor B - Bank 1 CKT Range/Perf
P0367Camshaft Position Sensor B - Bank 1 Circuit Low Input
P0368Camshaft Position Sensor B - Bank 1 Circuit High Input
P0369Camshaft Position Sensor B - Bank 1 CKT Intermittent
P0370Timing Reference High Res Signal A Malfunction
P0371Timing Reference High Res Signal A Too Many Pulses
P0372Timing Reference High Res Signal A Too Few Pulses
P0373Timing Reference High Res Signal A Erratic Pulses
P0374Timing Reference High Res Signal A No Pulses
P0375Timing Reference High Res Signal B Malfunction
P0376Timing Reference High Res Signal B Too Many Pulses
P0377Timing Reference High Res Signal B Too Few Pulses
P0378Timing Reference High Res Signal B Erratic Pulses
P0379Timing Reference High Res Signal B No Pulses
P0380Glow Plug/Heater CKT A Malfunction
P0381Glow Plug/Heater Indicator Circuit Malfunction
P0382Glow Plug/Heater CKT B Malfunction
P0383Glow Plug Module Control Circuit Low
P0384Glow Plug Module Control Circuit High
P0385Crankshaft Position Sensor B Circuit Malfunction
P0386Crankshaft Position Sensor B CKT Range/Perf
P0387Crankshaft Position Sensor B Circuit Low Input
P0388Crankshaft Position Sensor B Circuit High Input
P0389Crankshaft Position Sensor B CKT Intermittent
P0390Camshaft Position Sensor B - Bank 2 Circuit Malfunction
P0391Camshaft Position Sensor B - Bank 2 CKT Range/Perf
P0392Camshaft Position Sensor B - Bank 2 Circuit Low Input
P0393Camshaft Position Sensor B - Bank 2 Circuit High Input
P0394Camshaft Position Sensor B - Bank 2 CKT Intermittent
P0400EGR Flow Malfunction
P0401EGR Flow Insufficient
P0402EGR Flow Excessive
P0403EGR Flow Circuit Malfunction
P0404EGR Flow CKT Range/Perf
P0405EGR Flow Sensor A Circuit Low Input
P0406EGR Flow Sensor A Circuit High Input
P0407EGR Flow Sensor B Circuit Low Input
P0408EGR Flow Sensor B Circuit High Input
P0409EGR Flow Sensor A Circuit
P0410Secondary Air Injection System Malfunction
P0411Secondary Air Injection System Incorrect Flow
P0412Secondary Air Injection System Valve A Malfunction
P0413Secondary Air Injection System Valve A CKT Open
P0414Secondary Air Injection System Valve A CKT Short
P0415Secondary Air Injection System Valve B Malfunction
P0416Secondary Air Injection System Valve B CKT Open
P0417Secondary Air Injection System Valve B CKT Short
P0418Secondary Air Injection System Relay A Malfunction
P0419Secondary Air Injection System Relay B Malfunction
P0420Catalyst Efficiency Below Threshold (Bank 1)
P0421Warm Up Catalyst Below Threshold (Bank 1)
P0422Main Catalyst Below Threshold (Bank 1)
P0423Heated Catalyst Below Threshold (Bank 1)
P0424Htd Catalyst Temp Below Threshold (Bank 1)
P0425Catalyst Temp. Sensor (Bank 1 Sensor 1)
P0426Catalyst Temp. Sensor Performance (Bank 1 Sensor 1)
P0427Catalyst Temp. Sensor Circuit Low (Bank 1 Sensor 1)
P0428Catalyst Temp. Sensor Circuit High (Bank 1 Sensor 1)
P0429Catalyst Heater Control (Bank 1)
P0430Catalyst Efficiency Below Threshold (Bank 2)
P0431Warm Up Catalyst Below Threshold (Bank 2)
P0432Main Catalyst Below Threshold (Bank 2)
P0433Heated Catalyst Below Threshold (Bank 2)
P0434Htd Catalyst Temp Below Threshold (Bank 2)
P0435Catalyst Temp. Sensor (Bank 2 Sensor 1)
P0436Catalyst Temp. Sensor Performance (Bank 2 Sensor 1)
P0437Catalyst Temp. Sensor Circuit Low (Bank 2 Sensor 1)
P0438Catalyst Temp. Sensor Circuit High (Bank 2 Sensor 1)
P0439Catalyst Heater Control (Bank 2)
P0440EVAP Emission Control System Malfunction
P0441EVAP Emission Control System Purge Flow Fault
P0442EVAP Emission Control System Leak (Small)
P0443EVAP Emission Control System Purge Valve C Fault
P0444EVAP Emission Control System Purge Valve C Open
P0445EVAP Emission Control System Purge Valve C Short
P0446EVAP Emission Control System Vent Circuit Malf
P0447EVAP Emission Control System Vent Circuit Open
P0448EVAP Emission Control System Vent Circuit Short
P0449EVAP Emission Control System Vent Vlv/Sol Malf
P0450EVAP Emission Control System Pres Sensor Fault
P0451EVAP Emission Control System Pres Sensor Range
P0452EVAP Emission Control System Pres Sensor Low
P0453EVAP Emission Control System Pres Sensor High
P0454EVAP Emission Control System Pres Sensor Erratic
P0455EVAP Emission Control System Leak (Large)
P0456EVAP Emission Control System Leak Very Small
P0457EVAP Emission Control System Leak Cap Loose/Off
P0458EVAP System Canister Purge Sol Circuit Low
P0459EVAP System Canister Purge Sol Circuit High
P0460Fuel Level Sensor A Circuit Malfunction
P0461Fuel Level Sensor A CKT Range/Perf
P0462Fuel Level Sensor A Circuit Low Input
P0463Fuel Level Sensor A Circuit High Input
P0464Fuel Level Sensor A CKT Intermittent
P0465EVAP Emission Purge Flow Sensor Circuit Malfunction
P0466EVAP Emission Purge Flow Sensor CKT Range/Perf
P0467EVAP Emission Purge Flow Sensor Circuit Low Input
P0468EVAP Emission Purge Flow Sensor Circuit High Input
P0469EVAP Emission Purge Flow Sensor CKT Intermittent
P0470Exhaust Pressure Sensor Circuit Malfunction
P0471Exhaust Pressure Sensor CKT Range/Perf
P0472Exhaust Pressure Sensor Circuit Low Input
P0473Exhaust Pressure Sensor Circuit High Input
P0474Exhaust Pressure Sensor CKT Intermittent
P0475Exhaust Pressure Control Valve Circuit Malfunction
P0476Exhaust Pressure Control Valve CKT Range/Perf
P0477Exhaust Pressure Control Valve Circuit Low Input
P0478Exhaust Pressure Control Valve Circuit High Input
P0479Exhaust Pressure Control Valve CKT Intermittent
P0480Cooling Fan 1 Control Circuit
P0481Cooling Fan 2 Control Circuit
P0482Cooling Fan 3 Control Circuit
P0483Control Fan Rationality Check Malfunction
P0484Control Fan CKT Over Current
P0485Control Fan Power/Ground Circuit Malfunction
P0486EGR System Sensor B Circuit
P0487EGR TPS Control Circuit
P0488EGR TPS Control CKT Range/Perf
P0489EGR Control Circuit Low
P0490EGR Control Circuit High
P0491Secondary Air System (Bank 1)
P0492Secondary Air System (Bank 2)
P0493Fan Speed Overspeed
P0494Fan Speed Low
P0495Fan Speed High
P0496EVAP Emission High Purge Flow Fault
P0497EVAP Emission Low Purge Flow Fault
P0498EVAP Emission Vent Vlv/Sol Malf Circuit Low
P0499EVAP Emission Vent Vlv/Sol Malf Circuit High
P0500Veh Speed Sensor A Malfunction
P0501Veh Speed Sensor A Range/Performance
P0502Veh Speed Sensor A Circuit Low Input
P0503Veh Speed Sensor A Erratic/High
P0504Brake Switch A Brake Switch B Correlation
P0505Idle Control System Malfunction
P0506Idle Control System RPM Low
P0507Idle Control System RPM High
P0508Idle Control System Circuit Low
P0509Idle Control System Circuit High
P0510Closed Throttle Position Switch
P0511Idle Air Control Circuit
P0512Starter Signal Circuit
P0513Immobilizer Incorrect
P0514Battery Temperature Sensor CKT Range/Perf
P0515Battery Temperature Sensor Circuit
P0516Battery Temperature Circuit Low
P0517Battery Temperature Circuit High
P0518Idle Air Control CKT Intermittent
P0519Idle Air Control System Performance
P0520Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521Engine Oil Pressure Sensor/Switch Range/Performance
P0522Engine Oil Pressure Sensor/Switch Low Voltage
P0523Engine Oil Pressure Sensor/Switch High Voltage
P0524Engine Oil Pressure Too Low
P0525Cruise Servo CKT Range/Perf
P0526Fan Speed Sensor Circuit
P0527Fan Speed Sensor CKT Range/Perf
P0528Fan Speed Sensor Circuit No Signal
P0529Fan Speed Sensor CKT Intermittent
P0530A/C Refrigerant Pressure Sensor A Circuit Malfunction
P0531A/C Refrigerant Pressure Sensor A CKT Range/Perf
P0532A/C Refrigerant Pressure Sensor A Circuit Low Input
P0533A/C Refrigerant Pressure Sensor A Circuit High Input
P0534A/C Refrigerant Charge Loss
P0535A/C Evaporator Temperature Sensor Circuit
P0536A/C Evaporator Temperature Sensor CKT Range/Perf
P0537A/C Evaporator Temperature Sensor Circuit Low
P0538A/C Evaporator Temperature Sensor Circuit High
P0539A/C Evaporator Temperature Sensor CKT Intermittent
P0540Intake Air Heater A Circuit
P0541Intake Air Heater A Circuit Low
P0542Intake Air Heater A Circuit High
P0543Intake Air Heater A Circuit Open
P0544Exhaust Gas Temp. Sensor Circuit (Bank 1 Sensor 1)
P0545Exhaust Gas Temp. Sensor Circuit Low (Bank 1 Sensor 1)
P0546Exhaust Gas Temp. Sensor Circuit High (Bank 1 Sensor 1)
P0547Exhaust Gas Temp. Sensor Circuit (Bank 2 Sensor 1)
P0548Exhaust Gas Temp. Sensor Circuit Low (Bank 2 Sensor 1)
P0549Exhaust Gas Temp. Sensor Circuit High (Bank 2 Sensor 1)
P0550Power Steering Pres Sensor Circuit Malfunction
P0551Power Steering Pres Sensor CKT Range/Perf
P0552Power Steering Pres Sensor Circuit Low Input
P0553Power Steering Pres Sensor Circuit High Input
P0554Power Steering Pres Sensor CKT Intermittent
P0555Brake Booster Pressure Sensor Circuit
P0556Brake Booster Pressure Sensor CKT Range/Perf
P0557Brake Booster Pressure Sensor Circuit Low Input
P0558Brake Booster Pressure Sensor Circuit High Input
P0559Brake Booster Pressure Sensor CKT Intermittent
P0560System Voltage Malfunction
P0561System Voltage Unstable
P0562System Voltage Low
P0563System Voltage High
P0564Cruise Control Multi Func. Input A Signal Error
P0565Cruise Control On Signal Malfunction
P0566Cruise Control Off Signal Malfunction
P0567Cruise Control Resume Signal Malfunction
P0568Cruise Control Set Signal Malfunction
P0569Cruise Control Coast Signal Malfunction
P0570Cruise Control Acceleration Signal Error
P0571Brake Switch A Circuit Malfunction
P0572Brake Switch A Circuit Low Input
P0573Brake Switch A Circuit High Input
P0574Cruise Control Vehicle Speed Too High
P0575Cruise Control Circuit Malfunction
P0576Cruise Control Circuit Low Input
P0577Cruise Control Circuit High Input
P0578Cruise Control Multi-Func. Input A Circuit Stuck
P0579Cruise Control Multi-Func. Input A CKT Range/Perf
P0580Cruise Control Multi-Func. Input A Circuit Low
P0581Cruise Control Multi-Func. Input A Circuit High
P0582Cruise Control Vacuum Control Circuit Open
P0583Cruise Control Vacuum Control Circuit Low
P0584Cruise Control Vacuum Control Circuit High
P0585Cruise Control Multi-Func. Input Correlation
P0586Cruise Control Vent Control Circuit Open
P0587Cruise Control Vent Control Circuit Low
P0588Cruise Control Vent Control Circuit High
P0589Cruise Control Multi-Func. Input B Circuit
P0590Cruise Control Multi-Func. Input B Circuit Stuck
P0591Cruise Control Multi-Func. Input B CKT Range/Perf
P0592Cruise Control Multi-Func. Input B Circuit Low
P0593Cruise Control Multi-Func. Input B Circuit High
P0594Cruise Control Servo Control Circuit Open
P0595Cruise Control Servo Control Circuit Low
P0596Cruise Control Servo Control Circuit High
P0597Cruise Control Control Circuit Open
P0598Cruise Control Control Circuit Low
P0599Cruise Control Control Circuit High
P0600Serial Comm Link Malfunction
P0601Int Control Module Memory Check Sum Error
P0602Control Module Programming Error
P0603PCM Keep Alive Memory (KAM) Error
P0604PCM Random Access Mem (RAM) Error
P0605PCM Read Only Memory (ROM) Error
P0606PCM Processor Fault
P0607Control Module Performance
P0608Control Module VSS Output A Malfunction
P0609Control Module VSS Output B Malfunction
P0610Control Module Vehicle Options Malfunction
P0611Injector Control Module Performance
P0612Injector Control Module Relay Control
P0613TCM Processor Fault
P0614ECM/TCM Incompatible
P0615Starter Relay Circuit
P0616Starter Relay Circuit Low
P0617Starter Relay Circuit High
P0618Alternative Fuel Module (KAM) Error
P0619Alternative Fuel Module Memory
P0620Generator Control Malfunction
P0621Generator L-Term. Lamp Control
P0622Generator F-Term. Field F Control
P0623Generator Lamp Control Circuit
P0624Fuel Cap Lamp Circuit
P0625Generator F-Term. Circuit Low
P0626Generator F-Term. Circuit High
P0627Fuel Pump A Control Circuit Open
P0628Fuel Pump A Control Circuit Low
P0629Fuel Pump A Control Circuit High
P0630PCM VIN Not Program. Or Missmatch
P0631TCM VIN Not Program. Or Missmatch
P0632Odometer Code Not Programmed ECM/PCM
P0633Immobilizer Code Not Programmed ECM/PCM
P0634PCM/ECM/TCM Internal Temp. Too High
P0635Power Steering Control Circuit
P0636Power Steering Control Circuit Low
P0637Power Steering Control Circuit High
P0638Throttle Actuator Range/Performance (Bank 1)
P0639Throttle Actuator Range/Performance (Bank 2)
P0640Intake Air Heater Control Circuit
P0641Sensor A Reference Voltage Circuit Open
P0642Sensor A Reference Voltage Circuit Low
P0643Sensor A Reference Voltage Circuit High
P0644Driver Display Serial Comm Link
P0645A/C Clutch Relay Control Circuit
P0646A/C Clutch Relay Control Circuit Low
P0647A/C Clutch Relay Control Circuit High
P0648Immobilizer Lamp Circuit
P0649Cruise Control Lamp Circuit
P0650MIL Control Circuit Malfunction
P0651Sensor B Reference Voltage Circuit Open
P0652Sensor B Reference Voltage Circuit Low
P0653Sensor B Reference Voltage Circuit High
P0654Engine RPM Circuit Malfunction
P0655Engine Hot Lamp Output Circuit Malfunction
P0656Fuel Level Output Circuit Malfunction
P0657Actuator Supply Voltage A Circuit Open
P0658Actuator Supply Voltage A Circuit Low
P0659Actuator Supply Voltage A Circuit High
P0660Intake Man Tuning Control CKT Open (Bank 1)
P0661Intake Man Tuning Control CKT Low (Bank 1)
P0662Intake Man Tuning Control CKT High (Bank 1)
P0663Intake Man Tuning Control CKT Open (Bank 2)
P0664Intake Man Tuning Control CKT Low (Bank 2)
P0665Intake Man Tuning Control CKT High (Bank 2)
P0666PCM/ECM/TCM Internal Temp. Sensor Circuit
P0667PCM/ECM/TCM Internal Temp. Sensor Range/Perf.
P0668PCM/ECM/TCM Internal Temp. Sensor Circuit Low
P0669PCM/ECM/TCM Internal Temp. Sensor Circuit High
P0670Glow Plug/Heater Module Control
P0671Glow Plug/Heater Cylinder 1
P0672Glow Plug/Heater Cylinder 2
P0673Glow Plug/Heater Cylinder 3
P0674Glow Plug/Heater Cylinder 4
P0675Glow Plug/Heater Cylinder 5
P0676Glow Plug/Heater Cylinder 6
P0677Glow Plug/Heater Cylinder 7
P0678Glow Plug/Heater Cylinder 8
P0679Glow Plug/Heater Cylinder 9
P0680Glow Plug/Heater Cylinder 10
P0681Glow Plug/Heater Cylinder 11
P0682Glow Plug/Heater Cylinder 12
P0683Glow Plug/Heater Module Comm Problem
P0684Glow Plug/Heater Comm Problem CKT Range/Perf
P0685ECM/PCM Power Relay Control Circuit Open
P0686ECM/PCM Power Relay Control Circuit Low
P0687ECM/PCM Power Relay Control Circuit High
P0688ECM/PCM Power Relay Sense Circuit Open
P0689ECM/PCM Power Relay Sense Circuit Low
P0690ECM/PCM Power Relay Sense Circuit High
P0691Fan 1 Control Circuit Low
P0692Fan 1 Control Circuit High
P0693Fan 2 Control Circuit Low
P0694Fan 2 Control Circuit High
P0695Fan 3 Control Circuit Low
P0696Fan 3 Control Circuit High
P0697Sensor C Reference Voltage Circuit Open
P0698Sensor C Reference Voltage Circuit Low
P0699Sensor C Reference Voltage Circuit High
P0700Trans Control Sys Malfunction
P0701Trans Control Sys Range/Performance
P0702Trans Control Sys Electrical
P0703Brake Switch B Circuit Malfunction
P0704Clutch Switch Input Circuit Malfunction
P0705Trans Range Sensor Circuit Malfunction (PRNDL Input)
P0706Trans Range Sensor CKT Range/Perf
P0707Trans Range Sensor Circuit Low Input
P0708Trans Range Sensor Circuit High Input
P0709Trans Range Sensor CKT Intermittent
P0710Transmission Fluid Temperature Sensor Circuit Malfunction
P0711Trans Fluid Temp Sensor A CKT Range/Perf
P0712Trans Fluid Temp Sensor A Circuit Low Input
P0713Trans Fluid Temp Sensor A Circuit High Input
P0714Trans Fluid Temp Sensor A CKT Intermittent
P0715Input/Turbine Speed Sensor A Circuit Malfunction
P0716Input/Turbine Speed Sensor A CKT Range/Perf
P0717Input/Turbine Speed Sensor A Circuit No Signal
P0718Input/Turbine Speed Sensor A CKT Intermittent
P0719Brake Switch B Circuit Low Input
P0720Output Speed Sensor Circuit Malfunction
P0721Output Speed Sensor Circuit Range/Perf
P0722Output Speed Sensor Circuit No Signal
P0723Output Speed Sensor CKT Intermittent
P0724Brake Switch B Circuit High Input
P0725Engine Speed Sensor Circuit Malfunction
P0726Engine Speed Sensor CKT Range/Perf
P0727Engine Speed Sensor Circuit No Signal
P0728Engine Speed Sensor CKT Intermittent
P0729Gear 6 Ratio Incorrect
P0730Gear Ratio Incorrect
P0731Gear 1 Ratio Incorrect
P0732Gear 2 Ratio Incorrect
P0733Gear 3 Ratio Incorrect
P0734Gear 4 Ratio Incorrect
P0735Gear 5 Ratio Incorrect
P0736Reverse Ratio Incorrect
P0737TCM Engine Speed Output Circuit
P0738TCM Engine Speed Output Circuit Low
P0739TCM Engine Speed Output Circuit High
P0740TCC Circuit Malfunction
P0741Torque Converter CKT Performance Or Stuck Off
P0742Torque Converter Circuit Stuck On
P0743Torque Converter Circuit Electrical
P0744Torque Converter CKT Intermittent
P0745Pres Cntrl Sol. A Circuit Malfunction
P0746Pres Cntrl Sol. A CKT Performance Or Stuck Off
P0747Pres Cntrl Sol. A Circuit Stuck On
P0748Pres Cntrl Sol. A Circuit Electrical
P0749Pres Cntrl Sol. A CKT Intermittent
P0750Shift Solenoid A Malfunction
P0751Shift Solenoid A CKT Performance Or Stuck Off
P0752Shift Solenoid A Circuit Stuck On
P0753Shift Solenoid A Circuit Electrical
P0754Shift Solenoid A CKT Intermittent
P0755Shift Solenoid B Malfunction
P0756Shift Solenoid B CKT Performance Or Stuck Off
P0757Shift Solenoid B Circuit Stuck On
P0758Shift Solenoid B Circuit Electrical
P0759Shift Solenoid B CKT Intermittent
P0760Shift Solenoid C Malfunction
P0761Shift Solenoid C CKT Performance Or Stuck Off
P0762Shift Solenoid C Circuit Stuck On
P0763Shift Solenoid C Circuit Electrical
P0764Shift Solenoid C CKT Intermittent
P0765Shift Solenoid D Malfunction
P0766Shift Solenoid D CKT Performance Or Stuck Off
P0767Shift Solenoid D Circuit Stuck On
P0768Shift Solenoid D Circuit Electrical
P0769Shift Solenoid D CKT Intermittent
P0770Shift Solenoid E Malfunction
P0771Shift Solenoid E CKT Performance Or Stuck Off
P0772Shift Solenoid E Circuit Stuck On
P0773Shift Solenoid E Circuit Electrical
P0774Shift Solenoid E CKT Intermittent
P0775Pres Ctrl Sol. B Circuit Malfunction
P0776Pres Ctrl Sol. B CKT Performance Or Stuck Off
P0777Pres Ctrl Sol. B Circuit Stuck On
P0778Pres Ctrl Sol. B Circuit Electrical
P0779Pres Ctrl Sol. B CKT Intermittent
P0780Shift Malfunction
P07811-2 Shift Malfunction
P07822-3 Shift Malfunction
P07833-4 Shift Malfunction
P07844-5 Shift Malfunction
P0785Shift/Timing Solenoid Malfunction
P0786Shift/Timing Solenoid Range/Performance
P0787Shift/Timing Solenoid Low
P0788Shift/Timing Solenoid High
P0789Shift/Timing Solenoid Intermittent Ckt
P0790Normal/Performance Switch Circuit Malfunction
P0791Intermediate Shaft Speed Sensor A Circuit
P0792Intermediate Shaft Speed Sensor A Circuit Range/Perf
P0793Intermediate Shaft Speed Sensor A Circuit No Signal
P0794Intermediate Shaft Speed Sensor A CKT Intermittent
P0795Pres Ctrl Sol. C Malfunction
P0796Pres Ctrl Sol. C CKT Performance Or Stuck Off
P0797Pres Ctrl Sol. C Circuit Stuck On
P0798Pres Ctrl Sol. C Circuit Electrical
P0799Pres Ctrl Sol. C CKT Intermittent
P0800Transfer Case Control System MIL Request
P0801Reverse Inhibit Control Circuit Malfunction
P0802Trans Control Sys MIL Request Circuit Open
P08031-4 Upshift Solenoid Circuit Malfunction
P08041-4 Upshift Lamp Circuit Malfunction
P0805Clutch Position Sensor Circuit Malfunction
P0806Clutch Position Sensor Circuit Range/Performance
P0807Clutch Position Sensor Circuit Low
P0808Clutch Position Sensor Circuit High
P0809Clutch Position Sensor Circuit Intermittent Ckt
P0810Clutch Position Control Malfunction
P0811Clutch Slippage Excessive
P0812Reverse Input Circuit Malfunction
P0813Reverse Output Circuit Malfunction
P0814Trans Range Display Circuit Malfunction
P0815Upshift Switch Circuit Malfunction
P0816Downshift Switch Circuit Malfunction
P0817Starter Disable Circuit
P0818Driveline Disconn. Switch Input
P0819Up/Down Shift SW Transmission Range Correlation
P0820Gear Lever X-Y Sensor Circuit
P0821Gear Lever X Sensor Circuit
P0822Gear Lever Y Sensor Circuit
P0823Gear Lever X Sensor Circuit Intermittent Ckt
P0824Gear Lever Y Sensor Circuit Intermittent Ckt
P0825Gear Lever Push/Pull Switch (Shift Anticipate)
P0826Upshift Switch Downshift Switch Circuit
P0827Upshift Switch Downshift Switch Circuit Low
P0828Upshift Switch Downshift Switch Circuit High
P08295-6 Shift
P0830Clutch Position Switch A Circuit Malfunction
P0831Clutch Position Switch A Circuit Low
P0832Clutch Position Switch A Circuit Highb
P0833Clutch Position Switch B Circuit Malfunction
P0834Clutch Position Switch B Circuit Low
P0835Clutch Position Switch B Circuit High
P08364 Wheel Drive Switch Circuit Malfunction
P08374 Wheel Drive Switch CKT Range/Perf
P08384 Wheel Drive Switch Circuit Low
P08394 Wheel Drive Switch Circuit High
P0840Trans Fluid Press Sensor/Switch A Circuit Malfunction
P0841Trans Fluid Press Sensor/Switch A CKT Range/Perf
P0842Trans Fluid Press Sensor/Switch A Circuit Low
P0843Trans Fluid Press Sensor/Switch A Circuit High
P0844Trans Fluid Press Sensor/Switch A CKT Intermittent
P0845Trans Fluid Press Sensor/Switch B Circuit Malfunction
P0846Trans Fluid Press Sensor/Switch B CKT Range/Perf
P0847Trans Fluid Press Sensor/Switch B Circuit Low
P0848Trans Fluid Press Sensor/Switch B Circuit High
P0849Trans Fluid Press Sensor/Switch B CKT Intermittent
P0850Park/Neutral Switch Input Circuit
P0851Park/Neutral Switch Circuit Low Input
P0852Park/Neutral Switch Circuit High Input
P0853Drive Switch Input Circuit
P0854Drive Switch Circuit Low Input
P0855Drive Switch Circuit High Input
P0856Traction Control Input Signal
P0857Traction Control Input Signal Range/Performance
P0858Traction Control Input Signal Low
P0859Traction Control Input Signal High
P0860Gear Shift Module Communications Circuit
P0861Gear Shift Module Communications Circuit Low
P0862Gear Shift Module Communications Circuit High
P0863TCM Communications Circuit
P0864TCM Communications CKT Range/Perf
P0865TCM Communications Circuit Low
P0866TCM Communications Circuit High
P0867Trans Fluid Press
P0868Trans Fluid Press Low
P0869Trans Fluid Press High
P0870Trans Fluid Press Sensor/Switch C Circuit
P0871Trans Fluid Press Sensor/Switch C CKT Range/Perf
P0872Trans Fluid Press Sensor/Switch C Circuit Low
P0873Trans Fluid Press Sensor/Switch C Circuit High
P0874Trans Fluid Press Sensor/Switch C CKT Intermittent
P0875Trans Fluid Press Sensor/Switch D Circuit
P0876Trans Fluid Press Sensor/Switch D CKT Range/Perf
P0877Trans Fluid Press Sensor/Switch D Circuit Low
P0878Trans Fluid Press Sensor/Switch D Circuit High
P0879Trans Fluid Press Sensor/Switch D CKT Intermittent
P0880TCM Power Input Signal
P0881TCM Power Input Signal Range/Performance
P0882TCM Power Input Signal Low
P0883TCM Power Input Signal High
P0884TCM Power Input Signal CKT Intermittent
P0885TCM Power Relay Control Circuit Open
P0886TCM Power Relay Control Circuit Low
P0887TCM Power Relay Control Circuit High
P0888TCM Power Relay Sense Circuit
P0889TCM Power Relay Sense CKT Range/Perf
P0890TCM Power Relay Sense Circuit Low
P0891TCM Power Relay Sense Circuit High
P0892TCM Power Relay Sense CKT Intermittent
P0893Multiple Gears Engaged
P0894Transmission Comp. Slipping
P0895Shift Time Too Short
P0896Shift Time Too Long
P0897Transmission Fluid Deteriorated
P0898Transmission Ctrl. MIL Request Circuit Low
P0899Transmission Ctrl. MIL Request Circuit High
P0900Clutch Actuator Circuit Open
P0901Clutch Actuator CKT Range/Perf
P0902Clutch Actuator Circuit Low
P0903Clutch Actuator Circuit High
P0904Gate Select Position Circuit
P0905Gate Select Position CKT Range/Perf
P0906Gate Select Position Circuit Low
P0907Gate Select Position Circuit High
P0908Gate Select Position CKT Intermittent
P0909Gate Select Control Error
P0910Gate Select Actuator Circuit Open
P0911Gate Select Actuator CKT Range/Perf
P0912Gate Select Actuator Circuit Low
P0913Gate Select Actuator Circuit High
P0914Gear Shift Position Circuit
P0915Gear Shift Position CKT Range/Perf
P0916Gear Shift Position Circuit Low
P0917Gear Shift Position Circuit High
P0918Gear Shift Position CKT Intermittent
P0919Gear Shift Position Control Error
P0920Gear Shift Forward Actuator Circuit Open
P0921Gear Shift Forward Actuator CKT Range/Perf
P0922Gear Shift Forward Actuator Circuit Low
P0923Gear Shift Forward Actuator Circuit High
P0924Gear Shift Reverse Actuator Circuit Open
P0925Gear Shift Reverse Actuator CKT Range/Perf
P0926Gear Shift Reverse Actuator Circuit Low
P0927Gear Shift Reverse Actuator Circuit High
P0928Gear Shift Lock Solenoid Ctrl Circuit Open
P0929Gear Shift Lock Solenoid Ctrl CKT Range/Perf
P0930Gear Shift Lock Solenoid Ctrl Circuit Low
P0931Gear Shift Lock Solenoid Ctrl Circuit High
P0932Hydraulic Pressure Sensor Circuit
P0933Hydraulic Pressure Sensor CKT Range/Perf
P0934Hydraulic Pressure Sensor Circuit Low
P0935Hydraulic Pressure Sensor Circuit High
P0936Hydraulic Pressure Sensor CKT Intermittent
P0937Hydraulic Oil Temp Sensor Circuit
P0938Hydraulic Oil Temp Sensor CKT Range/Perf
P0939Hydraulic Oil Temp Sensor Circuit Low
P0940Hydraulic Oil Temp Sensor Circuit High
P0941Hydraulic Oil Temp Sensor CKT Intermittent
P0942Hyd. Pressure Unit
P0943Hyd. Pressure Unit Unit Cycling Too Short
P0944Hyd. Pressure Unit Loss of Pressure
P0945Hyd. Pump Relay Circuit Open
P0946Hyd. Pump Relay CKT Range/Perf
P0947Hyd. Pump Relay Circuit Low
P0948Hyd. Pump Relay Circuit High
P0949Auto Shift Adaptive Learning Not Complete
P0950Auto Shift Manual Control Circuit
P0951Auto Shift Manual Control CKT Range/Perf
P0952Auto Shift Manual Control Circuit Low
P0953Auto Shift Manual Control Circuit High
P0954Auto Shift Manual Control CKT Intermittent
P0955Auto Shift Manual Mode Circuit
P0956Auto Shift Manual Mode CKT Range/Perf
P0957Auto Shift Manual Mode Circuit Low
P0958Auto Shift Manual Mode Circuit High
P0959Auto Shift Manual Mode CKT Intermittent
P0960Pressure Control Solenoid A Control Circuit Open
P0961Pressure Control Solenoid A Control CKT Range/Perf
P0962Pressure Control Solenoid A Control Circuit Low
P0963Pressure Control Solenoid A Control Circuit High
P0964Pressure Control Solenoid B Control Circuit Open
P0965Pressure Control Solenoid B Control CKT Range/Perf
P0966Pressure Control Solenoid B Control Circuit Low
P0967Pressure Control Solenoid B Control Circuit High
P0968Pressure Control Solenoid C Control Circuit Open
P0969Pressure Control Solenoid C Control CKT Range/Perf
P0970Pressure Control Solenoid C Control Circuit Low
P0971Pressure Control Solenoid C Control Circuit High
P0972Shift Solenoid A Control CKT Range/Perf
P0973Shift Solenoid A Control Circuit Low
P0974Shift Solenoid A Control Circuit High
P0975Shift Solenoid B Control CKT Range/Perf
P0976Shift Solenoid B Control Circuit Low
P0977Shift Solenoid B Control Circuit High
P0978Shift Solenoid C Control CKT Range/Perf
P0979Shift Solenoid C Control Circuit Low
P0980Shift Solenoid C Control Circuit High
P0981Shift Solenoid D Control CKT Range/Perf
P0982Shift Solenoid D Control Circuit Low
P0983Shift Solenoid D Control Circuit High
P0984Shift Solenoid E Control CKT Range/Perf
P0985Shift Solenoid E Control Circuit Low
P0986Shift Solenoid E Control Circuit High
P0987Trans Fluid Press Sensor/Switch E Circuit
P0988Trans Fluid Press Sensor/Switch E CKT Range/Perf
P0989Trans Fluid Press Sensor/Switch E Circuit Low
P0990Trans Fluid Press Sensor/Switch E Circuit High
P0991Trans Fluid Press Sensor/Switch E CKT Intermittent
P0992Trans Fluid Press Sensor/Switch F Circuit
P0993Trans Fluid Press Sensor/Switch F CKT Range/Perf
P0994Trans Fluid Press Sensor/Switch F Circuit Low
P0995Trans Fluid Press Sensor/Switch F Circuit High
P0996Trans Fluid Press Sensor/Switch F CKT Intermittent
P0997Shift Solenoid F Control CKT Range/Perf
P0998Shift Solenoid F Control Circuit Low
P0999Shift Solenoid F Control Circuit High
P2000NOx Trap Eff Below Threshold Bank1
P2001NOx Trap Eff Below Threshold Bank2
P2002Particulate Trap Eff Below Threshold Bank1
P2003Particulate Trap Eff Below Threshold Bank2
P2004Intake Manif Runner Ctrl Stuck Open Bank1
P2005Intake Manif Runner Ctrl Stuck Open Bank2
P2006Intake Manif Runner Ctrl Stuck Closed Bank1
P2007Intake Manif Runner Ctrl Stuck Closed Bank2
P2008Intake Manif Runner Ctrl Circ/Open Bank1
P2009Intake Manif Runner Ctrl Circ Low Bank1
P2010Intake Manif Runner Ctrl Circ Hi Bank1
P2011Intake Manif Runner Ctrl Circ/Open Bank2
P2012Intake Manif Runner Ctrl Circ Low Bank2
P2013Intake Manif Runner Ctrl Circ Hi Bank2
P2014Intake Manif Runner Pos Sens/Switch Circ Bank1
P2015Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank 1
P2016Intake Manif Runner Pos Sens/Switch Circ Low Bank1
P2017Intake Manif Runner Pos Sens/Switch Circ Hi Bank1
P2018Intake Manif Runner Pos Sens/Switch Circ Interm Bank1
P2019Intake Manif Runner Pos Sens/Switch Circ Bank2
P2020Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank 2
P2021Intake Manif Runner Pos Sens/Switch Circ Low Bank2
P2022Intake Manif Runner Pos Sens/Switch Circ Hi Bank2
P2023Intake Manif Runner Pos Sens/Switch Circ Interm Bank2
P2024EVAP Emissions (EVAP) Fuel Vapor Temp Sens Circ
P2025EVAP Fuel Vapor Temp Sens Perf
P2026EVAP Fuel Vapor Temp Sens Circ Low Voltage
P2027EVAP Fuel Vapor Temp Sens Circ Hi Voltage
P2028EVAP Fuel Vapor Temp Sens Circ Interm
P2029Fuel Fired Heater Disabled
P2030Fuel Fired Heater Perf
P2031Exhaust Gas Temp Sens Circ Bank1 Sens2
P2032Exhaust Gas Temp Sens Circ Low Bank1 Sens2
P2033Exhaust Gas Temp Sens Circ Hi Bank1 Sens2
P2034Exhaust Gas Temp Sens Circ Bank2 Sens2
P2035Exhaust Gas Temp Sens Circ Low Bank2 Sens2
P2036Exhaust Gas Temp Sens Circ Hi Bank2 Sens2
P2037Reductant Inj Air Press Sens Circ
P2038Reductant Inj Air Press Sens Circ Range/Perf
P2039Reductant Inj Air Press Sens Circ Low Input
P2040Reductant Inj Air Press Sens Circ Hi Input
P2041Reductant Inj Air Press Sens Circ Interm
P2042Reductant Temp Sens Circ
P2043Reductant Temp Sens Circ Range/Perf
P2044Reductant Temp Sens Circ Low Input
P2045Reductant Temp Sens Circ Hi Input
P2046Reductant Temp Sens Circ Interm
P2047Reductant Injector Circ/Open Bank1 Unit 1
P2048Reductant Injector Circ Low Bank1 Unit 1
P2049Reductant Injector Circ Hi Bank1 Unit 1
P2050Reductant Injector Circ/Open Bank2 Unit 1
P2051Reductant Injector Circ Low Bank2 Unit 1
P2052Reductant Injector Circ Hi Bank2 Unit 1
P2053Reductant Injector Circ/Open Bank1 Unit 2
P2054Reductant Injector Circ Low Bank1 Unit 2
P2055Reductant Injector Circ Hi Bank1 Unit 2
P2056Reductant Injector Circ/Open Bank2 Unit 2
P2057Reductant Injector Circ Low Bank2 Unit 2
P2058Reductant Injector Circ Hi Bank2 Unit 2
P2059Reductant Inj Air Pump Ctrl Circ/Open
P2060Reductant Inj Air Pump Ctrl Circ Low
P2061Reductant Inj Air Pump Ctrl Circ Hi
P2062Reductant Supply Ctrl Circ/Open
P2063Reductant Supply Ctrl Circ Low
P2064Reductant Supply Ctrl Circ Hi
P2065Fuel Level Sens B Circ
P2066Fuel Level Sens B Perf
P2067Fuel Level Sens B Circ Low
P2068Fuel Level Sens B Circ Hi
P2069Fuel Level Sens B Circ Interm
P2070Intake Manif Tuning (IMT) Valve Stuck Open
P2071IMT Valve Stuck Closed
P2075IMT Valve Pos Sens/Switch Circ
P2076IMT Valve Pos Sens/Switch Circ Range/Perf
P2077IMT Valve Pos Sens/Switch Circ Low
P2078IMT Valve Pos Sens/Switch Circ Hi
P2079IMT Valve Pos Sens/Switch Circ Interm
P2080Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens1
P2081Exhaust Gas Temp Sens Circ Interm Bank1 Sens1
P2082Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens1
P2083Exhaust Gas Temp Sens Circ Interm Bank2 Sens1
P2084Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens2
P2085Exhaust Gas Temp Sens Circ Interm Bank1 Sens2
P2086Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens2
P2087Exhaust Gas Temp Sens Circ Interm Bank2 Sens2
P2088A Camshaft Pos Actuator Ctrl Circ Low Bank1
P2089A Camshaft Pos Actuator Ctrl Circ Hi Bank1
P2090B Camshaft Pos Actuator Ctrl Circ Low Bank1 c)
P2091B Camshaft Pos Actuator Ctrl Circ Hi Bank1 c)
P2092A Camshaft Pos Actuator Ctrl Circ Low Bank2
P2093A Camshaft Pos Actuator Ctrl Circ Hi Bank2
P2094B Camshaft Pos Actuator Ctrl Circ Low Bank2 c)
P2095B Camshaft Pos Actuator Ctrl Circ Hi Bank2 c)
P2096Post Catalyst Fuel Trim Sys Too Lean Bank1
P2097Post Catalyst Fuel Trim Sys Too Rich Bank1
P2098Post Catalyst Fuel Trim Sys Too Lean Bank2
P2099Post Catalyst Fuel Trim Sys Too Rich Bank2
P2100Throttle Actuator Ctrl Motor Circ/Open
P2101Throttle Actuator Ctrl Motor Circ Range/Perf
P2102Throttle Actuator Ctrl Motor Circ Low
P2103Throttle Actuator Ctrl Motor Circ Hi
P2104Throttle Actuator Ctrl Sys-Forced Idle
P2105Throttle Actuator Ctrl Sys-Forced Engine Shutdown
P2106Throttle Actuator Ctrl Sys-Forced Limited Power
P2107Throttle Actuator Ctrl Mod Processor
P2108Throttle Actuator Ctrl Mod Perf
P2109Throttle/Pedal Pos Sens A Minimum Stop Perf
P2110Throttle Actuator Ctrl Sys-Forced Limited RPM
P2111 Throttle Actuator Ctrl Sys-Stuck Open
P2112Throttle Actuator Ctrl Sys-Stuck Closed
P2113Throttle/Pedal Pos Sens B Minimum Stop Perf
P2114Throttle/Pedal Pos Sens C Minimum Stop Perf
P2115Throttle/Pedal Pos Sens D Minimum Stop Perf
P2116Throttle/Pedal Pos Sens E Minimum Stop Perf
P2117Throttle/Pedal Pos Sens F Minimum Stop Perf
P2118Throttle Actuator Ctrl Motor Current Range/Perf
P2119Throttle Actuator Ctrl Throttle Body Range/Perf
P2120Throttle/Pedal Pos Sens/Switch D Circ
P2121Throttle/Pedal Pos Sens/Switch D Circ Range/Perf
P2122Throttle/Pedal Pos Sens/Switch D Circ Low Input
P2123Pedal Pos Sens1 Hi
P2124Throttle/Pedal Pos Sens/Switch D Circ Interm
P2125Throttle/Pedal Pos Sens/Switch E Circ
P2126Throttle/Pedal Pos Sens/Switch E Circ Range/Perf
P2127Pedal Pos Validation Switch 2 Low
P2128Pedal Pos Validation Switch 2 Hi
P2129Throttle/Pedal Pos Sens/Switch E Circ Interm
P2130Throttle/Pedal Pos Sens/Switch F Circ
P2131Throttle/Pedal Pos Sens/Switch F Circ Range Perf
P2132Throttle/Pedal Pos Sens/Switch F Circ Low Input
P2133Throttle/Pedal Pos Sens/Switch F Circ Hi Input
P2134Throttle/Pedal Pos Sens/Switch F Circ Interm
P2135Throttle/Pedal Pos Sens/Switch A/B Voltage Correlation
P2136Throttle/Pedal Pos Sens/Switch A/C Voltage Correlation
P2137Throttle/Pedal Pos Sens/Switch B/C Voltage Correlation
P2138Throttle/Pedal Pos Sens/Switch D/E Voltage Correlation
P2139Throttle/Pedal Pos Sens/Switch D/F Voltage Correlation
P2140Throttle/Pedal Pos Sens/Switch E/F Voltage Correlation
P2141Exhaust Gas Recirculation Throttle Ctrl Circ Low
P2142Exhaust Gas Recirculation Throttle Ctrl Circ Hi
P2143Exhaust Gas Recirculation Vent Ctrl Circ/Open
P2144Exhaust Gas Recirculation Vent Ctrl Circ Low
P2145Exhaust Gas Recirculation Vent Ctrl Circ Hi
P2146Fuel Injector Group 1 Supply Voltage Circ
P2147Fuel Injector Group 1 Supply Voltage Low
P2148Fuel Injector Group 1 Supply Voltage Hi
P2149Fuel Injector Group 2 Supply Voltage Circ
P2150Fuel Injector Group 2 Supply Voltage Low
P2151Fuel Injector Group 2 Supply Voltage Hi
P2152Fuel Injector Group C Supply Voltage Circ/Open
P2153Fuel Injector Group C Supply Voltage Circ Low
P2154Fuel Injector Group C Supply Voltage Circ Hi
P2155Fuel Injector Group D Supply Voltage Circ/Open
P2156Fuel Injector Group D Supply Voltage Circ Low
P2157Fuel Injector Group D Supply Voltage Circ Hi
P2158Vehicle Speed Sens B
P2159Vehicle Speed Sens B Range/Perf
P2160Vehicle Speed Sens B Circ Low
P2161Vehicle Speed Sens B Interm/Erratic
P2162Vehicle Speed Sens A / B Correlation
P2163Throttle/Pedal Pos Sens A Maximum Stop Perf
P2164Throttle/Pedal Pos Sens B Maximum Stop Perf
P2165Throttle/Pedal Pos Sens C Maximum Stop Perf
P2166Throttle/Pedal Pos Sens D Maximum Stop Perf
P2167Throttle/Pedal Pos Sens E Maximum Stop Perf
P2168Throttle/Pedal Pos Sens F Maximum Stop Perf
P2169Exhaust Press Regulator Vent Solenoid Ctrl Circ/Open
P2170Exhaust Press Regulator Vent Solenoid Ctrl Circ Low
P2171Exhaust Press Regulator Vent Solenoid Ctrl Circ Hi
P2172Throttle Actuator Ctrl Sys-Sudden Hi Airflow Detected
P2173Throttle Actuator Ctrl Sys-Hi Airflow Detected
P2174Throttle Actuator Ctrl Sys-Sudden Low Airflow Detected
P2175Throttle Actuator Ctrl Sys-Low Airflow Detected
P2176Throttle Actuator Ctrl Sys-Idle Pos Not Learned
P2177Sys Too Lean Off Idle Bank1
P2178Sys Too Rich Off Idle Bank1
P2179Sys Too Lean Off Idle Bank2
P2180Sys Too Rich Off Idle Bank2
P2181Cooling Sys Perf
P2182Engine Coolant Temp Sens2 Circ
P2183Engine Coolant Temp Sens2 Circ Range/Perf
P2184Engine Coolant Temp Sens2 Circ Low
P2185Engine Coolant Temp Sens2 Circ Hi
P2186Engine Coolant Temp Sens2 Circ Interm/Erratic
P2187Sys Too Lean at Idle Bank1
P2188Sys Too Rich at Idle Bank1
P2189Sys Too Lean at Idle Bank2
P2190Sys Too Rich at Idle Bank2
P2191Sys Too Lean at Hier Load Bank1
P2192Sys Too Rich at Hier Load Bank1
P2193Sys Too Lean at Hier Load Bank2
P2194Sys Too Rich at Hier Load Bank2
P2195O2 Sens Signal Stuck Lean Bank1 Sens1
P2196O2 Sens Signal Stuck Rich Bank1 Sens1
P2197O2 Sens Signal Stuck Lean Bank2 Sens1
P2198O2 Sens Signal Stuck Rich Bank2 Sens1
P2199Intake Air Temp Sens1 / 2 Correlation
P2200NOx Sens Circ Bank1
P2201NOx Sens Circ Range/Perf Bank1
P2202NOx Sens Circ Low Input Bank1
P2203NOx Sens Circ Hi Input Bank1
P2204NOx Sens Circ Interm Input Bank1
P2205NOx Sens Heater Ctrl Circ/Open Bank1
P2206NOx Sens Heater Ctrl Circ Low Bank1
P2207NOx Sens Heater Ctrl Circ Hi Bank1
P2208NOx Sens Heater Sense Circ Bank1
P2209NOx Sens Heater Sense Circ Range/Perf Bank1
P2210NOx Sens Heater Sense Circ Low Input Bank1
P2211NOx Sens Heater Sense Circ Hi Input Bank1
P2212NOx Sens Heater Sense Circ Interm Bank1
P2213NOx Sens Circ Bank2
P2214NOx Sens Circ Range/Perf Bank2
P2215NOx Sens Circ Low Input Bank2
P2216NOx Sens Circ Hi Input Bank2
P2217NOx Sens Circ Interm Input Bank2
P2218NOx Sens Heater Ctrl Circ/Open Bank2
P2219NOx Sens Heater Ctrl Circ Low Bank2
P2220NOx Sens Heater Ctrl Circ Hi Bank2
P2221NOx Sens Heater Sense Circ Bank2
P2222NOx Sens Heater Sense Circ Range/Perf Bank2
P2223NOx Sens Heater Sense Circ Low Bank2
P2224NOx Sens Heater Sense Circ Hi Bank2
P2225NOx Sens Heater Sense Circ Interm Bank2
P2226Barometric Press Circ
P2227Barometric Press Circ Range/Perf
P2228Barometric Press Circ Low
P2229Barometric Press Circ Hi
P2230Barometric Press Circ Interm
P2231O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens1
P2232O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens2
P2233O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens3
P2234O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens1
P2235O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens2
P2236O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens3
P2237O2 Sens Positive Current Ctrl Circ/Open Bank1 Sens1
P2238O2 Sens Positive Current Ctrl Circ Low Bank1 Sens1
P2239O2 Sens Positive Current Ctrl Circ Hi Bank1 Sens1
P2240O2 Sens Positive Current Ctrl Circ/Open Bank2 Sens1
P2241O2 Sens Positive Current Ctrl Circ Low Bank2 Sens1
P2242O2 Sens Positive Current Ctrl Circ Hi Bank2 Sens1
P2243O2 Sens Ref Voltage Circ/Open Bank1 Sens1
P2244O2 Sens Ref Voltage Perf Bank1 Sens1
P2245O2 Sens Ref Voltage Circ Low Bank1 Sens1
P2246O2 Sens Ref Voltage Circ Hi Bank1 Sens1
P2247O2 Sens Ref Voltage Circ/Open Bank2 Sens1
P2248O2 Sens Ref Voltage Perf Bank2 Sens1
P2249O2 Sens Ref Voltage Circ Low Bank2 Sens1
P2250O2 Sens Ref Voltage Circ Hi Bank2 Sens1
P2251O2 Sens Negative Current Ctrl Circ/Open Bank1 Sens1
P2252O2 Sens Negative Current Ctrl Circ Low Bank1 Sens1
P2253O2 Sens Negative Current Ctrl Circ Hi Bank1 Sens1
P2254O2 Sens Negative Current Ctrl Circ/Open Bank2 Sens1
P2255O2 Sens Negative Current Ctrl Circ Low Bank2 Sens1
P2256O2 Sens Negative Current Ctrl Circ Hi Bank2 Sens1
P2257Sec Air Inj Sys Ctrl A Circ Low
P2258Sec Air Inj Sys Ctrl A Circ Hi
P2259Sec Air Inj Sys Ctrl B Circ Low
P2260Sec Air Inj Sys Ctrl B Circ Hi
P2261T/Super Charger Bypass Valve-Mechanical
P2262Turbo Boost Press Not Detected-Mechanical
P2263T/Super Charger Boost Sys Perf
P2264Water in Fuel Sens Circ
P2265Water in Fuel Sens Circ Range/Perf
P2266Water in Fuel Sens Circ Low
P2267Water in Fuel Sens Circ Hi
P2268Water in Fuel Sens Circ Interm
P2269Water in Fuel Condition
P2270O2 Sens Signal Stuck Lean Bank1 Sens2
P2271O2 Sens Signal Stuck Rich Bank1 Sens2
P2272O2 Sens Signal Stuck Lean Bank2 Sens2
P2273O2 Sens Signal Stuck Rich Bank2 Sens2
P2274O2 Sens Signal Stuck Lean Bank1 Sens3
P2275O2 Sens Signal Stuck Rich Bank1 Sens3
P2276O2 Sens Signal Stuck Lean Bank2 Sens3
P2277O2 Sens Signal Stuck Rich Bank2 Sens3
P2278O2 Sens Signals Swapped Bank1 Sens3 / Bank2 Sens3
P2279Intake Air Sys Leak
P2280Air Flow Restriction / Air Leak Between Air Filter and MAF
P2281Air Leak Between MAF and Throttle Body
P2282Air Leak Between Throttle Body and Intake Valves
P2283Injector Ctrl Press Sens Circ
P2284Injector Ctrl Press Sens Circ Range/Perf
P2285Injector Ctrl Press Sens Circ Low
P2286Injector Ctrl Press Sens Circ Hi
P2287Injector Ctrl Press Sens Circ Interm
P2288Injector Ctrl Press Too Hi
P2289Injector Ctrl Press Too Hi-Engine Off
P2290Injector Ctrl Press Too Low
P2291Injector Ctrl Press Too Low-Engine Cranking
P2292Injector Ctrl Press Erratic
P2293Fuel Press Regulator 2 Perf
P2294Fuel Press Regulator 2 Ctrl Circ
P2295Fuel Press Regulator 2 Ctrl Circ Low
P2296Fuel Press Regulator 2 Ctrl Circ Hi
P2297O2 Sens Out of Range During Deceleration Bank1 Sens1
P2298O2 Sens Out of Range During Deceleration Bank2 Sens1
P2299Brake Pedal Pos / Accelerator Pedal Pos Incompatible
P2300Ignition Coil A Primary Ctrl Circ Low
P2301Ignition Coil A Primary Ctrl Circ Hi
P2302Ignition Coil A Sec Circ
P2303Ignition Coil B Primary Ctrl Circ Low
P2304Ignition Coil B Primary Ctrl Circ Hi
P2305Ignition Coil B Sec Circ
P2306Ignition Coil C Primary Ctrl Circ Low
P2307Ignition Coil C Primary Ctrl Circ Hi
P2308Ignition Coil C Sec Circ
P2309Ignition Coil D Primary Ctrl Circ Low
P2310Ignition Coil D Primary Ctrl Circ Hi
P2311Ignition Coil D Sec Circ
P2312Ignition Coil E Primary Ctrl Circ Low
P2313Ignition Coil E Primary Ctrl Circ Hi
P2314Ignition Coil E Sec Circ
P2315Ignition Coil F Primary Ctrl Circ Low
P2316Ignition Coil F Primary Ctrl Circ Hi
P2317Ignition Coil F Sec Circ
P2318Ignition Coil G Primary Ctrl Circ Low
P2319Ignition Coil G Primary Ctrl Circ Hi
P2320Ignition Coil G Sec Circ
P2321Ignition Coil H Primary Ctrl Circ Low
P2322Ignition Coil H Primary Ctrl Circ Hi
P2323Ignition Coil H Sec Circ
P2324Ignition Coil I Primary Ctrl Circ Low
P2325Ignition Coil I Primary Ctrl Circ Hi
P2326Ignition Coil I Sec Circ
P2327Ignition Coil J Primary Ctrl Circ Low
P2328Ignition Coil J Primary Ctrl Circ Hi
P2329Ignition Coil J Sec Circ
P2330Ignition Coil K Primary Ctrl Circ Low
P2331Ignition Coil K Primary Ctrl Circ Hi
P2332Ignition Coil K Sec Circ
P2333Ignition Coil L Primary Ctrl Circ Low
P2334Ignition Coil L Primary Ctrl Circ Hi
P2335Ignition Coil L Sec Circ
P2336Cylinder #1 Above Knock Threshold
P2337Cylinder #2 Above Knock Threshold
P2338Cylinder #3 Above Knock Threshold
P2339Cylinder #4 Above Knock Threshold
P2340Cylinder #5 Above Knock Threshold
P2341Cylinder #6 Above Knock Threshold
P2342Cylinder #7 Above Knock Threshold
P2343Cylinder #8 Above Knock Threshold
P2344Cylinder #9 Above Knock Threshold
P2345Cylinder #10 Above Knock Threshold
P2346Cylinder #11 Above Knock Threshold
P2347Cylinder #12 Above Knock Threshold
P2400EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
P2401EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
P2402EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
P2403EVAP Emission Sys Leak Detection Pump Sense Circ/Open
P2404EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
P2405EVAP Emission Sys Leak Detection Pump Sense Circ Low
P2406EVAP Emission Sys Leak Detection Pump Sense Circ Hi
P2407EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
P2408Fuel Cap Sens/Switch Circ
P2409Fuel Cap Sens/Switch Circ Range/Perf
P2410 Fuel Cap Sens/Switch Circ Low
P2411Fuel Cap Sens/Switch Circ Hi
P2412Fuel Cap Sens/Switch Circ Interm/Erratic
P2413Exhaust Gas Recirculation Sys Perf
P2414O2 Sens Exhaust Sample Error Bank1 Sens1
P2415O2 Sens Exhaust Sample Error Bank2 Sens1
P2416O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
P2417O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
P2418EVAP Emission Sys Switching Valve Ctrl Circ /Open
P2419EVAP Emission Sys Switching Valve Ctrl Circ Low
P2420EVAP Emission Sys Switching Valve Ctrl Circ Hi
P2421EVAP Emission Sys Vent Valve Stuck Open
P2422EVAP Emission Sys Vent Valve Stuck Closed
P2423HC Adsorption Catalyst Eff Below Threshold Bank1
P2424HC Adsorption Catalyst Eff Below Threshold Bank2
P2425Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
P2426Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
P2427Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
P2428Exhaust Gas Temp Too Hi Bank1
P2429Exhaust Gas Temp Too Hi Bank2
P2430Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
P2431Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
P2432Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
P2433Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
P2434Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
P2435Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
P2436Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
P2437Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
P2438Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
P2439Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
P2440Sec Air Inj Sys Switching Valve Stuck Open Bank1
P2441Sec Air Inj Sys Switching Valve Stuck Closed Bank1
P2442Sec Air Inj Sys Switching Valve Stuck Open Bank2
P2443Sec Air Inj Sys Switching Valve Stuck Closed Bank2
P2444Sec Air Inj Sys Pump Stuck On Bank1
P2445Sec Air Inj Sys Pump Stuck Off Bank1
P2446Sec Air Inj Sys Pump Stuck On Bank2
P2447Sec Air Inj Sys Pump Stuck Off Bank2
P2500Generator Lamp/L-Terminal Circ Low
P2501Generator Lamp/L-Terminal Circ Hi
P2502Charging Sys Output Voltage
P2503Charging Sys Output Voltage Low
P2504Charging Sys Output Voltage Hi
P2505ECM/PCM Power Input Signal
P2506ECM/PCM Power Input Signal Range/Perf
P2507ECM/PCM Power Input Signal Low
P2508ECM/PCM Power Input Signal Hi
P2509CM/PCM Power Input Signal Interm
P2510ECM/PCM Power Relay Sense Circ Range/Perf
P2511 ECM/PCM Power Relay Sense Circ Interm
P2512Event Data Recorder Request Circ/ Open
P2513Event Data Recorder Request Circ Low
P2514Event Data Recorder Request Circ Hi
P2515A/C Refrigerant Press Sens B Circ
P2516A/C Refrigerant Press Sens B Circ Range/Perf
P2517A/C Refrigerant Press Sens B Circ Low
P2518A/C Refrigerant Press Sens B Circ Hi
P2519A/C Request A Circ
P2520A/C Request A Circ Low
P2521A/C Request A Circ Hi
P2522A/C Request B Circ
P2523A/C Request B Circ Low
P2524A/C Request B Circ Hi
P2525Vacuum Reservoir Press Sens Circ
P2526Vacuum Reservoir Press Sens Circ Range/Perf
P2527Vacuum Reservoir Press Sens Circ Low
P2528Vacuum Reservoir Press Sens Circ Hi
P2529Vacuum Reservoir Press Sens Circ Interm
P2530Ignition Switch Run Pos Circ
P2531Ignition Switch Run Pos Circ Low
P2532Ignition Switch Run Pos Circ Hi
P2533Ignition Switch Run/Start Pos Circ
P2534Ignition Switch Run/Start Pos Circ Low
P2535Ignition Switch Run/Start Pos Circ Hi
P2536Ignition Switch Accessory Pos Circ
P2537Ignition Switch Accessory Pos Circ Low
P2538Ignition Switch Accessory Pos Circ Hi
P2539Low Press Fuel Sys Sens Circ
P2540Low Press Fuel Sys Sens Circ Range/Perf
P2541Low Press Fuel Sys Sens Circ Low
P2542Low Press Fuel Sys Sens Circ Hi
P2543Low Press Fuel Sys Sens Circ Interm
P2544Torque Management Request Input Signal A
P2545Torque Management Request Input Signal A Range/Perf
P2546Torque Management Request Input Signal A Low
P2547Torque Management Request Input Signal A Hi
P2548Torque Management Request Input Signal B
P2549Torque Management Request Input Signal B Range/Perf
P2550Torque Management Request Input Signal B Low
P2551Torque Management Request Input Signal B Hi
P2552Throttle/Fuel Inhibit Circ
P2553Throttle/Fuel Inhibit Circ Range/Perf
P2554Throttle/Fuel Inhibit Circ Low
P2555Throttle/Fuel Inhibit Circ Hi
P2556Engine Coolant Level Sens/Switch Circ
P2557Engine Coolant Level Sens/Switch Circ Range/Perf
P2558Engine Coolant Level Sens/Switch Circ Low
P2559Engine Coolant Level Sens/Switch Circ Hi
P2560Engine Coolant Level Low
P2561A/C Ctrl Mod Requested MIL Illumination
P2562Turbocharger Boost Ctrl Pos Sens Circ
P2563Turbocharger Boost Ctrl Pos Sens Circ Range/Perf
P2564Turbocharger Boost Ctrl Pos Sens Circ Low
P2565Turbocharger Boost Ctrl Pos Sens Circ Hi
P2566Turbocharger Boost Ctrl Pos Sens Circ Interm
P2567Direct Ozone Reduction Catalyst Temp Sens Circ
P2568Direct Ozone Reduction Catalyst Temp Sens Circ Range/Perf
P2569Direct Ozone Reduction Catalyst Temp Sens Circ Low
P2570Direct Ozone Reduction Catalyst Temp Sens Circ Hi
P2571Direct Ozone Reduction Catalyst Temp Sens Circ Interm/Erratic
P2572Direct Ozone Reduction Catalyst Deterioration Sens Circ
P2573Direct Ozone Reduction Catalyst Deterioration Sens Circ Range/Perf
P2574Direct Ozone Reduction Catalyst Deterioration Sens Circ Low
P2575Direct Ozone Reduction Catalyst Deterioration Sens Circ Hi
P2576Direct Ozone Reduction Catalyst Deterioration Sens Circ Interm/Erratic
P2577Direct Ozone Reduction Catalyst Eff Below Threshold
P2600Coolant Pump Ctrl Circ/Open
P2601Coolant Pump Ctrl Circ Range/Perf
P2602Coolant Pump Ctrl Circ Low
P2603Coolant Pump Ctrl Circ Hi
P2604Intake Air Heater A Circ Range/Perf
P2605Intake Air Heater A Circ/Open
P2606Intake Air Heater B Circ Range/Perf
P2607Intake Air Heater Relay 2 Low
P2608Intake Air Heater Relay 2 Hi
P2609Intake Air Heater Sys Perf
P2610ECM/PCM Internal Engine Off Timer Perf
P2611A/C Refrigerant Distribution Valve Ctrl Circ/Open
P2612A/C Refrigerant Distribution Valve Ctrl Circ Low
P2613A/C Refrigerant Distribution Valve Ctrl Circ Hi
P2614Camshaft Pos Signal Output Circ/Open
P2615Camshaft Pos Signal Output Circ Low
P2616Camshaft Pos Signal Output Circ Hi
P2617Crank Pos Signal Output Circ/Open
P2618Crank Pos Signal Output Circ Low
P2619Crank Pos Signal Output Circ Hi
P2620Throttle Pos Output Circ/Open
P2621Throttle Pos Output Circ Low
P2622Throttle Pos Output Circ Hi
P2623Injector Ctrl Press Regulator Circ/Open
P2624Injector Ctrl Press Regulator Circ Low
P2625Injector Ctrl Press Regulator Circ Hi
P2626O2 Sens Pumping Current Trim Circ/Open Bank1 Sens1
P2627O2 Sens Pumping Current Trim Circ Low Bank1 Sens1
P2628O2 Sens Pumping Current Trim Circ Hi Bank1 Sens1
P2629O2 Sens Pumping Current Trim Circ/Open Bank2 Sens1
P2630O2 Sens Pumping Current Trim Circ Low Bank2 Sens1
P2631O2 Sens Pumping Current Trim Circ Hi Bank2 Sens1
P2632Fuel Pump B Ctrl Circ /Open
P2633Fuel Pump B Ctrl Circ Low
P2634Fuel Pump B Ctrl Circ Hi
P2635Fuel Pump A Low Flow / Perf
P2636Fuel Pump B Low Flow / Perf
P2637Torque Management Feedback Signal A
P2638Torque Management Feedback Signal A Range/Perf
P2639Torque Management Feedback Signal A Low
P2640Torque Management Feedback Signal A Hi
P2641Torque Management Feedback Signal B
P2642Torque Management Feedback Signal B Range/Perf
P2643Torque Management Feedback Signal B Low
P2644Torque Management Feedback Signal B Hi
P2645A Rocker Arm Actuator Ctrl Circ/Open Bank1
P2646A Rocker Arm Actuator Sys Perf or Stuck Off Bank1
P2647A Rocker Arm Actuator Sys Stuck On Bank1
P2648A Rocker Arm Actuator Ctrl Circ Low Bank1
P2649A Rocker Arm Actuator Ctrl Circ Hi Bank1
P2650B Rocker Arm Actuator Ctrl Circ/Open Bank1
P2651B Rocker Arm Actuator Sys Perf or Stuck Off Bank1
P2652B Rocker Arm Actuator Sys Stuck On Bank1
P2653B Rocker Arm Actuator Ctrl Circ Low Bank1
P2654B Rocker Arm Actuator Ctrl Circ Hi Bank1
P2655A Rocker Arm Actuator Ctrl Circ/Open Bank2
P2656A Rocker Arm Actuator Sys Perf or Stuck Off Bank2
P2657A Rocker Arm Actuator Sys Stuck On Bank2
P2658A Rocker Arm Actuator Ctrl Circ Low Bank2
P2659A Rocker Arm Actuator Ctrl Circ Hi Bank2
P2660B Rocker Arm Actuator Ctrl Circ/Open Bank2
P2661B Rocker Arm Actuator Sys Perf or Stuck Off Bank2
P2662B Rocker Arm Actuator Sys Stuck On Bank2
P2663B Rocker Arm Actuator Ctrl Circ Low Bank2
P2664B Rocker Arm Actuator Ctrl Circ Hi Bank2
P2665Fuel Shutoff Valve B Ctrl Circ/Open
P2666Fuel Shutoff Valve B Ctrl Circ Low
P2667Fuel Shutoff Valve B Ctrl Circ Hi
P2668Fuel Mode Indicator Lamp Ctrl Circ
P2669Actuator Supply Voltage B Circ /Open
P2670Actuator Supply Voltage B Circ Low
P2671Actuator Supply Voltage B Circ Hi
P2700Trans Friction Element A Apply Time Range/Perf
P2701Trans Friction Element B Apply Time Range/Perf
P2702Trans Friction Element C Apply Time Range/Perf
P2703Trans Friction Element D Apply Time Range/Perf
P2704Trans Friction Element E Apply Time Range/Perf
P2705Trans Friction Element F Apply Time Range/Perf
P2706Shift Solenoid F
P2707Shift Solenoid F Perf or Stuck Off
P2708Shift Solenoid F Stuck On
P2709Shift Solenoid F Electrical
P2710Shift Solenoid F Interm
P2711Unexpected Mechanical Gear Disengagement
P2712Hydraulic Power Unit Leakage
P2713Press Ctrl Solenoid D
P2714Press Ctrl Solenoid D Perf or Stuck Off
P2715Press Ctrl Solenoid D Stuck On
P2716Press Ctrl Solenoid D Electrical
P2717Press Ctrl Solenoid D Interm
P2718Press Ctrl Solenoid D Ctrl Circ / Open
P2719Press Ctrl Solenoid D Ctrl Circ Range/Perf
P2720Press Ctrl Solenoid D Ctrl Circ Low
P2721Press Ctrl Solenoid D Ctrl Circ Hi
P2722Press Ctrl Solenoid E
P2723Press Ctrl Solenoid E Perf or Stuck Off
P2724Press Ctrl Solenoid E Stuck On
P2725 Press Ctrl Solenoid E Electrical
P2726Press Ctrl Solenoid E Interm
P2727Press Ctrl Solenoid E Ctrl Circ / Open
P2728Press Ctrl Solenoid E Ctrl Circ Range/Perf
P2729Press Ctrl Solenoid E Ctrl Circ Low
P2730Press Ctrl Solenoid E Ctrl Circ Hi
P2731Press Ctrl Solenoid F
P2732Press Ctrl Solenoid F Perf or Stuck Off
P2733Press Ctrl Solenoid F Stuck On
P2734Press Ctrl Solenoid F Electrical
P2735Press Ctrl Solenoid F Interm
P2736Press Ctrl Solenoid F Ctrl Circ/Open
P2737Press Ctrl Solenoid F Ctrl Circ Range/Perf
P2738Press Ctrl Solenoid F Ctrl Circ Low
P2739Press Ctrl Solenoid F Ctrl Circ Hi
P2740Trans Fluid Temp Sens B Circ
P2741Trans Fluid Temp Sens B Circ Range Perf
P2742Trans Fluid Temp Sens B Circ Low
P2743Trans Fluid Temp Sens B Circ Hi
P2744Trans Fluid Temp Sens B Circ Interm
P2745Intermediate Shaft Speed Sens B Circ
P2746Intermediate Shaft Speed Sens B Circ Range/Perf
P2747Intermediate Shaft Speed Sens B Circ No Signal
P2748Intermediate Shaft Speed Sens B Circ Interm
P2749Intermediate Shaft Speed Sens C Circ
P2750Intermediate Shaft Speed Sens C Circ Range/Perf
P2751Intermediate Shaft Speed Sens C Circ No Signal
P2752Intermediate Shaft Speed Sens C Circ Interm
P2753Trans Fluid Cooler Ctrl Circ/Open
P2754Trans Fluid Cooler Ctrl Circ Low
P2755Trans Fluid Cooler Ctrl Circ Hi
P2756Torque Conv Clutch Press Ctrl Solenoid
P2757Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
P2758Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
P2759Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
P2760Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ
P2761Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
P2762Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
P2763Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Hi
P2764Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
P2765Input/Turbine Speed Sens B Circ
P2766Input/Turbine Speed Sens B Circ Range/Perf
P2767Input/Turbine Speed Sens B Circ No Signal
P2768Input/Turbine Speed Sens B Circ Interm
P2769Torque Conv Clutch Circ Low
P2770Torque Conv Clutch Circ Hi
P2771Four Wheel Drive (4WD) Low Switch Circ
P2772Four Wheel Drive (4WD) Low Switch Circ Range/Perf
P2773Four Wheel Drive (4WD) Low Switch Circ Low
P2774Four Wheel Drive (4WD) Low Switch Circ Hi
P2775Upshift Switch Circ Range/Perf
P2776Upshift Switch Circ Low
P2777Upshift Switch Circ Hi
P2778Upshift Switch Circ Interm/Erratic
P2779Downshift Switch Circ Range/Perf
P2780Downshift Switch Circ Low
P2781Downshift Switch Circ Hi
P2782Downshift Switch Circ Interm/Erratic
P2783Torque Conv Temp Too Hi
P2784Input/Turbine Speed Sens A/B Correlation
P2785Clutch Actuator Temp Too Hi
P2786Gear Shift Actuator Temp Too Hi
P2787Clutch Temp Too Hi
P2788Auto Shift Manual Adaptive Learning at Limit
P2789Clutch Adaptive Learning at Limit
P2790Gate Select Direction Circ
P2791Gate Select Direction Circ Low
P2792Gate Select Direction Circ Hi
P2793Gear Shift Direction Circ
P2794Gear Shift Direction Circ Low
P2795Gear Shift Direction Circ Hi
P3400Cylinder Deactivation Sys Bank1
P3401Cylinder 1 Deactivation/Intake Valve Ctrl Circ/Open
P3402Cylinder 1 Deactivation/Intake Valve Ctrl Perf
P3403Cylinder 1 Deactivation/Intake Valve Ctrl Circ Low
P3404Cylinder 1 Deactivation/Intake Valve Ctrl Circ Hi
P3405Cylinder 1 Exhaust Valve Ctrl Circ/Open
P3406Cylinder 1 Exhaust Valve Ctrl Perf
P3407Cylinder 1 Exhaust Valve Ctrl Circ Low
P3408Cylinder 1 Exhaust Valve Ctrl Circ Hi
P3409Cylinder 2 Deactivation/Intake Valve Ctrl Circ/Open
P3410Cylinder 2 Deactivation/Intake Valve Ctrl Perf
P3411Cylinder 2 Deactivation/Intake Valve Ctrl Circ Low
P3412Cylinder 2 Deactivation/Intake Valve Ctrl Circ Hi
P3413Cylinder 2 Exhaust Valve Ctrl Circ/Open
P3414Cylinder 2 Exhaust Valve Ctrl Perf
P3415Cylinder 2 Exhaust Valve Ctrl Circ Low
P3416Cylinder 2 Exhaust Valve Ctrl Circ Hi
P3417Cylinder 3 Deactivation/Intake Valve Ctrl Circ/Open
P3418Cylinder 3 Deactivation/Intake Valve Ctrl Perf
P3419Cylinder 3 Deactivation/Intake Valve Ctrl Circ Low
P3420Cylinder 3 Deactivation/Intake Valve Ctrl Circ Hi
P3421Cylinder 3 Exhaust Valve Ctrl Circ/Open
P3422Cylinder 3 Exhaust Valve Ctrl Perf
P3423Cylinder 3 Exhaust Valve Ctrl Circ Low
P3424Cylinder 3 Exhaust Valve Ctrl Circ Hi
P3425Cylinder 4 Deactivation/Intake Valve Ctrl Circ/Open
P3426Cylinder 4 Deactivation/Intake Valve Ctrl Perf
P3427Cylinder 4 Deactivation/Intake Valve Ctrl Circ Low
P3428Cylinder 4 Deactivation/Intake Valve Ctrl Circ Hi
P3429Cylinder 4 Exhaust Valve Ctrl Circ/Open
P3430Cylinder 4 Exhaust Valve Ctrl Perf
P3431Cylinder 4 Exhaust Valve Ctrl Circ Low
P3432Cylinder 4 Exhaust Valve Ctrl Circ Hi
P3433Cylinder 5 Deactivation/Intake Valve Ctrl Circ/Open
P3434Cylinder 5 Deactivation/Intake Valve Ctrl Perf
P3435Cylinder 5 Deactivation/Intake Valve Ctrl Circ Low
P3436Cylinder 5 Deactivation/Intake Valve Ctrl Circ Hi
P3437Cylinder 5 Exhaust Valve Ctrl Circ/Open
P3438Cylinder 5 Exhaust Valve Ctrl Perf
P3439Cylinder 5 Exhaust Valve Ctrl Circ Low
P3440Cylinder 5 Exhaust Valve Ctrl Circ Hi
P3441Cylinder 6 Deactivation/Intake Valve Ctrl Circ/Open
P3442Cylinder 6 Deactivation/Intake Valve Ctrl Perf
P3443Cylinder 6 Deactivation/Intake Valve Ctrl Circ Low
P3444Cylinder 6 Deactivation/Intake Valve Ctrl Circ Hi
P3445Cylinder 6 Exhaust Valve Ctrl Circ/Open
P3446Cylinder 6 Exhaust Valve Ctrl Perf
P3447Cylinder 6 Exhaust Valve Ctrl Circ Low
P3448Cylinder 6 Exhaust Valve Ctrl Circ Hi
P3449Cylinder 7 Deactivation/Intake Valve Ctrl Circ/Open
P3450Cylinder 7 Deactivation/Intake Valve Ctrl Perf
P3451Cylinder 7 Deactivation/Intake Valve Ctrl Circ Low
P3452Cylinder 7 Deactivation/Intake Valve Ctrl Circ Hi
P3453Cylinder 7 Exhaust Valve Ctrl Circ/Open
P3454Cylinder 7 Exhaust Valve Ctrl Perf
P3455Cylinder 7 Exhaust Valve Ctrl Circ Low
P3456Cylinder 7 Exhaust Valve Ctrl Circ Hi
P3457Cylinder 8 Deactivation/Intake Valve Ctrl Circ/Open
P3458Cylinder 8 Deactivation/Intake Valve Ctrl Perf
P3459Cylinder 8 Deactivation/Intake Valve Ctrl Circ Low
P3460Cylinder 8 Deactivation/Intake Valve Ctrl Circ Hi
P3461Cylinder 8 Exhaust Valve Ctrl Circ/Open
P3462Cylinder 8 Exhaust Valve Ctrl Perf
P3463Cylinder 8 Exhaust Valve Ctrl Circ Low
P3464Cylinder 8 Exhaust Valve Ctrl Circ Hi
P3465Cylinder 9 Deactivation/Intake Valve Ctrl Circ/Open
P3466Cylinder 9 Deactivation/Intake Valve Ctrl Perf
P3467Cylinder 9 Deactivation/Intake Valve Ctrl Circ Low
P3468Cylinder 9 Deactivation/Intake Valve Ctrl Circ Hi
P3469Cylinder 9 Exhaust Valve Ctrl Circ/Open
P3470Cylinder 9 Exhaust Valve Ctrl Perf
P3471Cylinder 9 Exhaust Valve Ctrl Circ Low
P3472Cylinder 9 Exhaust Valve Ctrl Circ Hi
P3473Cylinder 10 Deactivation/Intake Valve Ctrl Circ/Open
P3474Cylinder 10 Deactivation/Intake Valve Ctrl Perf
P3475Cylinder 10 Deactivation/Intake Valve Ctrl Circ Low
P3476Cylinder 10 Deactivation/Intake Valve Ctrl Circ Hi
P3477Cylinder 10 Exhaust Valve Ctrl Circ/Open
P3478Cylinder 10 Exhaust Valve Ctrl Perf
P3479Cylinder 10 Exhaust Valve Ctrl Circ Low
P3480Cylinder 10 Exhaust Valve Ctrl Circ Hi
P3481Cylinder 11 Deactivation/Intake Valve Ctrl Circ/Open
P3482Cylinder 11 Deactivation/Intake Valve Ctrl Perf
P3483Cylinder 11 Deactivation/Intake Valve Ctrl Circ Low
P3484Cylinder 11 Deactivation/Intake Valve Ctrl Circ Hi
P3485Cylinder 11 Exhaust Valve Ctrl Circ/Open
P3486Cylinder 11 Exhaust Valve Ctrl Perf
P3487Cylinder 11 Exhaust Valve Ctrl Circ Low
P3488Cylinder 11 Exhaust Valve Ctrl Circ Hi
P3489Cylinder 12 Deactivation/Intake Valve Ctrl Circ/Open
P3490Cylinder 12 Deactivation/Intake Valve Ctrl Perf
P3491Cylinder 12 Deactivation/Intake Valve Ctrl Circ Low
P3492Cylinder 12 Deactivation/Intake Valve Ctrl Circ Hi
P3493Cylinder 12 Exhaust Valve Ctrl Circ/Open
U0001High Speed CAN Comm Bus
U0002High Speed CAN Comm Bus Perf
U0003High Speed CAN Comm Bus + Open
U0004High Speed CAN Comm Bus + Low
U0005High Speed CAN Comm Bus + High
U0006High Speed CAN Comm Bus - Open
U0007High Speed CAN Comm Bus - Low
U0008High Speed CAN Comm Bus - High
U0009High Speed CAN Comm Bus - shorted to Bus +
U0010Medium Speed CAN Comm Bus
U0011Medium Speed CAN Comm Bus Perf
U0012Medium Speed CAN Comm Bus + Open
U0013Medium Speed CAN Comm Bus + Low
U0014Medium Speed CAN Comm Bus + High
U0015Medium Speed CAN Comm Bus - Open
U0016Medium Speed CAN Comm Bus - Low
U0017Medium Speed CAN Comm Bus - High
U0018Medium Speed CAN Comm Bus - shorted to Bus +
U0019Low Speed CAN Comm Bus
U0020Low Speed CAN Comm Bus Perf
U0021Low Speed CAN Comm Bus + Open
U0022Low Speed CAN Comm Bus + Low
U0023Low Speed CAN Comm Bus + High
U0024Low Speed CAN Comm Bus - Open
U0025Low Speed CAN Comm Bus - Low
U0026Low Speed CAN Comm Bus - High
U0027Low Speed CAN Comm Bus - shorted to Bus +
U0028Vehicle Comm Bus A
U0029Vehicle Comm Bus A Perf
U0030Vehicle Comm Bus A + Open
U0031Vehicle Comm Bus A + Low
U0032Vehicle Comm Bus A + High
U0033Vehicle Comm Bus A - Open
U0034Vehicle Comm Bus A - Low
U0035Vehicle Comm Bus A - High
U0036Vehicle Comm Bus A - shorted to Bus A +
U0037Vehicle Comm Bus B
U0038Vehicle Comm Bus B Perf
U0039Vehicle Comm Bus B + Open
U0040Vehicle Comm Bus B + Low
U0041Vehicle Comm Bus B + High
U0042Vehicle Comm Bus B - Open
U0043Vehicle Comm Bus B - Low
U0044Vehicle Comm Bus B - High
U0045Vehicle Comm Bus B - shorted to Bus B +
U0046Vehicle Comm Bus C
U0047Vehicle Comm Bus C Perf
U0048Vehicle Comm Bus C + Open
U0049Vehicle Comm Bus C + Low
U0050Vehicle Comm Bus C + High
U0051Vehicle Comm Bus C - Open
U0052Vehicle Comm Bus C - Low
U0053Vehicle Comm Bus C - High
U0054Vehicle Comm Bus C - shorted to Bus C +
U0055Vehicle Comm Bus D
U0056Vehicle Comm Bus D Perf
U0057Vehicle Comm Bus D + Open
U0058Vehicle Comm Bus D + Low
U0059Vehicle Comm Bus D + High
U0060Vehicle Comm Bus D - Open
U0061Vehicle Comm Bus D - Low
U0062Vehicle Comm Bus D - High
U0063Vehicle Comm Bus D - shorted to Bus D +
U0064Vehicle Comm Bus E
U0065Vehicle Comm Bus E Perf
U0066Vehicle Comm Bus E + Open
U0067Vehicle Comm Bus E + Low
U0068Vehicle Comm Bus E + High
U0069Vehicle Comm Bus E - Open
U0070Vehicle Comm Bus E - Low
U0071Vehicle Comm Bus E - High
U0072Vehicle Comm Bus E - shorted to Bus E +
U0073Ctrl Mod Comm Bus Off
U0074Reserved by Document
U0075Reserved by Document
U0076Reserved by Document
U0077Reserved by Document
U0078Reserved by Document
U0079Reserved by Document
U0080Reserved by Document
U0081Reserved by Document
U0082Reserved by Document
U0083Reserved by Document
U0084Reserved by Document
U0085Reserved by Document
U0086Reserved by Document
U0087Reserved by Document
U0088Reserved by Document
U0089Reserved by Document
U0090Reserved by Document
U0091Reserved by Document
U0092Reserved by Document
U0093Reserved by Document
U0094Reserved by Document
U0095Reserved by Document
U0096Reserved by Document
U0097Reserved by Document
U0098Reserved by Document
U0099Reserved by Document
U0100Lost Comm With ECM/PCM A
U0101Lost Comm with TCM
U0102Lost Comm with Transfer Case Ctrl Mod
U0103Lost Comm With Gear Shift Mod
U0104Lost Comm With Cruise Ctrl Mod
U0105Lost Comm With Fuel Injector Ctrl Mod
U0106Lost Comm With Glow Plug Ctrl Mod
U0107Lost Comm With Throttle Actuator Ctrl Mod
U0108Lost Comm With Alternative Fuel Ctrl Mod
U0109Lost Comm With Fuel Pump Ctrl Mod
U0110Lost Comm With Drive Motor Ctrl Mod
U0111Lost Comm With Battery Energy Ctrl Mod A
U0112Lost Comm With Battery Energy Ctrl Mod B
U0113Lost Comm With Emissions Critical Ctrl Information
U0114Lost Comm With 4-Wheel Drive Clutch Ctrl Mod
U0115Lost Comm With ECM/PCM B
U0116Reserved by Document
U0117Reserved by Document
U0118Reserved by Document
U0119Reserved by Document
U0120Reserved by Document
U0121Lost Comm With Anti-Lock Brake System (ABS) Ctrl Mod
U0122Lost Comm With Vehicle Dynamics Ctrl Mod
U0123Lost Comm With Yaw Rate Sens Mod
U0124Lost Comm With Lateral Acceleration Sens Mod
U0125Lost Comm With Multi-axis Acceleration Sens Mod
U0126Lost Comm With Steering Angle Sens Mod
U0127Lost Comm With Tire Pressure Monitor Mod
U0128Lost Comm With Park Brake Ctrl Mod
U0129Lost Comm With Brake System Ctrl Mod
U0130Lost Comm With Steering Effort Ctrl Mod
U0131Lost Comm With Power Steering Ctrl Mod
U0132Lost Comm With Ride Level Ctrl Mod
U0133Reserved by Document
U0134Reserved by Document
U0135Reserved by Document
U0136Reserved by Document
U0137Reserved by Document
U0138Reserved by Document
U0139Reserved by Document
U0140Lost Comm With Body Ctrl Mod
U0141Lost Comm With Body Ctrl Mod A
U0142Lost Comm With Body Ctrl Mod B
U0143Lost Comm With Body Ctrl Mod C
U0144Lost Comm With Body Ctrl Mod D
U0145Lost Comm With Body Ctrl Mod E
U0146Lost Comm With Gateway A
U0147Lost Comm With Gateway B
U0148Lost Comm With Gateway C
U0149Lost Comm With Gateway D
U0150Lost Comm With Gateway E
U0151Lost Comm With Restraints Ctrl Mod
U0152Lost Comm With Side Restraints Ctrl Mod Left
U0153Lost Comm With Side Restraints Ctrl Mod Right
U0154Lost Comm With Restraints Occupant Sensing Ctrl Mod
U0155Lost Comm With Instrument Panel Cluster (IPC) Ctrl Mod
U0156Lost Comm With Information Center A
U0157Lost Comm With Information Center B
U0158Lost Comm With Head Up Display
U0159Lost Comm With Parking Assist Ctrl Mod
U0160Lost Comm With Audible Alert Ctrl Mod
U0161Lost Comm With Compass Mod
U0162Lost Comm With Navigation Display Mod
U0163Lost Comm With Navigation Ctrl Mod
U0164Lost Comm With HVAC Ctrl Mod
U0165Lost Comm With HVAC Ctrl Mod Rear
U0166Lost Comm With Auxiliary Heater Ctrl Mod
U0167Lost Comm With Vehicle Immobilizer Ctrl Mod
U0168Lost Comm With Vehicle Security Ctrl Mod
U0169Lost Comm With Sunroof Ctrl Mod
U0170Lost Comm With Restraints System Sens A
U0171Lost Comm With Restraints System Sens B
U0172Lost Comm With Restraints System Sens C
U0173Lost Comm With Restraints System Sens D
U0174Lost Comm With Restraints System Sens E
U0175Lost Comm With Restraints System Sens F
U0176Lost Comm With Restraints System Sens G
U0177Lost Comm With Restraints System Sens H
U0178Lost Comm With Restraints System Sens I
U0179Lost Comm With Restraints System Sens J
U0180Lost Comm With Automatic Lighting Ctrl Mod
U0181Lost Comm With Headlamp Leveling Ctrl Mod
U0182Lost Comm With Lighting Ctrl Mod Front
U0183Lost Comm With Lighting Ctrl Mod Rear
U0184Lost Comm With Radio
U0185Lost Comm With Antenna Ctrl Mod
U0186Lost Comm With Audio Amplifier
U0187Lost Comm With Digital Disc Player/Changer Mod A
U0188Lost Comm With Digital Disc Player/Changer Mod B
U0189Lost Comm With Digital Disc Player/Changer Mod C
U0190Lost Comm With Digital Disc Player/Changer Mod D
U0191Lost Comm With Television
U0192Lost Comm With Personal Computer
U0193Lost Comm With Digital Audio Ctrl Mod A
U0194Lost Comm With Digital Audio Ctrl Mod B
U0195Lost Comm With Subscription Entertainment Receiver Mod
U0196Lost Comm With Rear Seat Entertainment Ctrl Mod
U0197Lost Comm With Telephone Ctrl Mod
U0198Lost Comm With Telematic Ctrl Mod
U0199Lost Comm With Door Ctrl Mod A
U0200Lost Comm With Door Ctrl Mod B
U0201Lost Comm With Door Ctrl Mod C
U0202Lost Comm With Door Ctrl Mod D
U0203Lost Comm With Door Ctrl Mod E
U0204Lost Comm With Door Ctrl Mod F
U0205Lost Comm With Door Ctrl Mod G
U0206Lost Comm With Folding Top Ctrl Mod
U0207Lost Comm With Moveable Roof Ctrl Mod
U0208Lost Comm With Seat Ctrl Mod A
U0209Lost Comm With Seat Ctrl Mod B
U0210Lost Comm With Seat Ctrl Mod C
U0211Lost Comm With Seat Ctrl Mod D
U0212Lost Comm With Steering Column Ctrl Mod
U0213Lost Comm With Mirror Ctrl Mod
U0214Lost Comm With Remote Function Actuation
U0215Lost Comm With Door Switch A
U0216Lost Comm With Door Switch B
U0217Lost Comm With Door Switch C
U0218Lost Comm With Door Switch D
U0219Lost Comm With Door Switch E
U0220Lost Comm With Door Switch F
U0221Lost Comm With Door Switch G
U0222Lost Comm With Door Window Motor A
U0223Lost Comm With Door Window Motor B
U0224Lost Comm With Door Window Motor C
U0225Lost Comm With Door Window Motor D
U0226Lost Comm With Door Window Motor E
U0227Lost Comm With Door Window Motor F
U0228Lost Comm With Door Window Motor G
U0229Lost Comm With Heated Steering Wheel Mod
U0230Lost Comm With Rear Gate Mod
U0231Lost Comm With Rain Sensing Mod
U0232Lost Comm With Side Obstacle Detect Ctrl Mod Left
U0233Lost Comm With Side Obstacle Detect Ctrl Mod Right
U0234Lost Comm With Convenience Recall Mod
U0235Lost Comm With Cruise Ctrl Front Distance Range Sens
U0300Internal Ctrl Mod Software Incompatibility
U0301Software Incompatibility with ECM/PCM
U0302Software Incompatibility with Trans Ctrl Mod
U0303Software Incompatibility with Transfer Case Ctrl Mod
U0304Software Incompatibility with Gear Shift Ctrl Mod
U0305Software Incompatibility with Cruise Ctrl Mod
U0306Software Incompatibility with Fuel Injector Ctrl Mod
U0307Software Incompatibility with Glow Plug Ctrl Mod
U0308Software Incompatibility with Throttle Actuator Ctrl Mod
U0309Software Incompatibility with Alternative Fuel Ctrl Mod
U0310Software Incompatibility with Fuel Pump Ctrl Mod
U0311Software Incompatibility with Drive Motor Ctrl Mod
U0312Software Incompatibility with Battery Energy Ctrl Mod A
U0313Software Incompatibility with Battery Energy Ctrl Mod B
U0314Software Incompatibility with 4-Wheel Drive Clutch Ctrl Mod
U0315Software Incompatibility with Anti-Lock Brake System Ctrl Mod
U0316Software Incompatibility with Vehicle Dynamics Ctrl Mod
U0317Software Incompatibility with Park Brake Ctrl Mod
U0318Software Incompatibility with Brake System Ctrl Mod
U0319Software Incompatibility with Steering Effort Ctrl Mod
U0320Software Incompatibility with Power Steering Ctrl Mod
U0321Software Incompatibility with Ride Level Ctrl Mod
U0322Software Incompatibility with Body Ctrl Mod
U0323Software Incompatibility with Instrument Panel Ctrl Mod
U0324Software Incompatibility with HVAC Ctrl Mod
U0325Software Incompatibility with Auxiliary Heater Ctrl Mod
U0326Software Incompatibility with Vehicle Immobilizer Ctrl Mod
U0327Software Incompatibility with Vehicle Security Ctrl Mod
U0328Software Incompatibility with Steering Angle Sens Mod
U0329Software Incompatibility with Steering Column Ctrl Mod
U0330Software Incompatibility with Tire Pressure Monitor Mod
U0331Software Incompatibility with Body Ctrl Mod A
U0400Invalid Data Rcvd
U0401Invalid Data Rcvd From ECM/PCM
U0402Invalid Data Rcvd From Trans Ctrl Mod
U0403Invalid Data Rcvd From Transfer Case Ctrl Mod
U0404Invalid Data Rcvd From Gear Shift Ctrl Mod
U0405Invalid Data Rcvd From Cruise Ctrl Mod
U0406Invalid Data Rcvd From Fuel Injector Ctrl Mod
U0407Invalid Data Rcvd From Glow Plug Ctrl Mod
U0408Invalid Data Rcvd From Throttle Actuator Ctrl Mod
U0409Invalid Data Rcvd From Alternative Fuel Ctrl Mod
U0410Invalid Data Rcvd From Fuel Pump Ctrl Mod
U0411Invalid Data Rcvd From Drive Motor Ctrl Mod
U0412Invalid Data Rcvd From Battery Energy Ctrl Mod A
U0413Invalid Data Rcvd From Battery Energy Ctrl Mod B
U0414Invalid Data Rcvd From 4-Wheel Drive Clutch Ctrl Mod
U0415Invalid Data Rcvd From Anti-Lock Brake System Ctrl Mod
U0416Invalid Data Rcvd From Vehicle Dynamics Ctrl Mod
U0417Invalid Data Rcvd From Park Brake Ctrl Mod
U0418Invalid Data Rcvd From Brake System Ctrl Mod
U0419Invalid Data Rcvd From Steering Effort Ctrl Mod
U0420Invalid Data Rcvd From Power Steering Ctrl Mod
U0421Invalid Data Rcvd From Ride Level Ctrl Mod
U0422Invalid Data Rcvd From Body Ctrl Mod
U0423Invalid Data Rcvd From Instrument Panel Ctrl Mod
U0424Invalid Data Rcvd From HVAC Ctrl Mod
U0425Invalid Data Rcvd From Auxiliary Heater Ctrl Mod
U0426Invalid Data Rcvd From Vehicle Immobilizer Ctrl Mod
U0427Invalid Data Rcvd From Vehicle Security Ctrl Mod
U0428Invalid Data Rcvd From Steering Angle Sens Mod
U0429Invalid Data Rcvd From Steering Column Ctrl Mod
U0430Invalid Data Rcvd From Tire Pressure Monitor Mod
U0431Invalid Data Rcvd From Body Ctrl Mod A High
BMW
P1083Fuel control limit mixture too lean (bank 1 sensor1)
P1084Fuel control limit mixture too rich (bank 1 sensor1)
P1085Fuel control limit mixture too lean (bank 2 sensor1)
P1086Fuel control limit mixture too rich (bank 2 sensor1)
P108702 sensor circuit slow response in lean control range (bank 1 sensor1)
P108802 sensor circuit slow response in rich control range (bank 1 sensor1)
P108902 sensor circuit slow response in lean control range (bank 1 sensor2)
P1090Pre catalyst fuel trim system too lean bank 1
P1091Pre catalyst fuel trim system too rich bank 1
P1092Pre catalyst fuel trim system too lean bank 2
P1093Pre catalyst fuel trim system too rich bank 2
P109402 sensor circuit slow response in rich control range (bank 2sensor1)
P109502 sensor signal circuit slow switching from lean to rich (bank1 sensor1)
P109602 sensor signal circuit slow switching from lean to rich (bank2 sensor1)
P109702 sensor circuit slow response after coast down fuel cut-off (bank 1 sensor 2)
P109802 sensor circuit slow response after coast down fuel cut-off (bank 2 sensor 2)
P1111Engine coolant temperature radiator outlet sensor low input
P1112Engine coolant temperature radiator outlet sensor high input
P1115Coolant temperature sensor plausibility
P1116Mass or volume air flow circuit range/performance problem (bank 2)
P1117Mass or volume air flow circuit low input (bank 2)
P1118Mass or volume air flow circuit high input (bank 2)
P1120Pedal position sensor circuit
P1121Pedal position sensor 1 range/performance problem
P1122Pedal position sensor 1 low input
P1123Pedal position sensor 1 high input
P113202 sensor heater control circuit (bank1 sensor 1)
P113302 sensor heater control circuit (bank2 sensor 1)
P113402 sensor heater circiut signal intermittent (bank1 sensor1)
P113502 sensor heater circiut low voltage (bank1 sensor1)
P113602 sensor heater circiut high voltage (bank1 sensor1)
P113702 sensor heater circiut signal intermittent (bank1 sensor2)
P113802 Sensor heater circiut low voltage (bank1 sensor2)
P113902 sensor heater circiut high voltage (bank1 sensor2)
P1140Mass or volume air flow circuit range / performance problem
P1145Solenoid valve running losses conrtol circuit electrical
P115102 sensor heater circuit signal intermittent (bank 2 sensor 1)
P115202 sensor heater circuit low voltage (bank 2 sensor 1)
P115302 sensor heater circuit high voltage (bank 2 sensor 1)
P115502 sensor heater circuit signal intermittent (bank 2 sensor 2)
P115602 sensor heater circuit low voltage (bank 2 sensor 2)
P115702 sensor heater circuit high voltage (bank 2 sensor 2)
P1158Fuel trim adaptation additive bank 1 low
P1159Fuel trim adaptation additive bank 1 high
P1160Fuel trim adaptation additive bank 2 low
P1161Fuel trim adaptation additive bank 2 high M52: Engine oil temperature sensor circuit
P1162Fuel trim adaptation additive per ignition bank 1 low
P1163Fuel trim adaptation additive per ignition bank 1 high
P1164Fuel trim adaptation additive per ignition bank 2 low
P1165Fuel trim adaptation additive per ignition bank 2 high
P1174Fuel trim adaptation additive bank 1 malfunction
P1175Fuel trim adaptation additive bank 2 malfunction
P117602 sensor slow response bank 1
P117702 sensor slow response bank 2
P117802 sensor signal circuit slow switching from rich to lean (bank 1 sensor 1)
P117902 sensor signal circuit slow switching from rich to lean (bank 2 sensor 1)
P118002 sensor signal circuit slow switching from rich to lean (bank 1 sensor 2)
P118102 sensor signal circuit slow switching from rich to lean (bank 2sensor 2)
P118202 sensor (bank 1 sensor 2) open circuit during coast sown fuel cut-off
P118302 sensor (bank 2 sensor 2) open circuit during coast down fuel cut-off
P118602 sensor heater control circuit (bank 1 sensor 2)
P118702 sensor heater control circuit (bank 2 sensor 2)
P1188Fuel control (bank 1 sensor 1)
P1189Fuel control (bank 2 sensor 1)
P1190Pre catalyst fuel trim system bank 1
P1191Pre catalyst fuel trim system bank 2
P1192Post catalyst fuel trim system bank 1
P1193Post catalyst fuel trim system bank 2
P1221Pedal position sensor 2 range / performance problem
P1222Pedal position sensor 2 low input
P1223Pedal position sensor 2 high input
P1270control module self-test, torque monitoring M73: Mass air flow sensor bank comparison plausibility
P1271Ambient air pressure sensor electrical
P1283Switching solenoid for air assisted injection valves bank 1 control circuit electrical
P1284Switching solenoid for air assisted injection valves bank 1 control circuit signal low
P1285Switching solenoid for air assisted injection valves bank 1 control circuit signal high
P1287Switching solenoid for air assisted injection valves bank 2 control circuit electrical
P1288Switching solenoid for air assisted injection valves bank 2 control circuit signal low
P1289Switching solenoid for air assisted injection valves bank 2 control circuit signal high
P1313'A' Camshaft position actuator plausibility
P1317'B' Camshaft position actuator plausibility
P1327Knock sensor 2 (bank 1) low input
P1328Knock sensor 2 (bank 1) high input
P1332Knock sensor 4 low input
P1333Knock sensor 4 high input
P1340Multiple cylinder misfire during start
P1341Multiple cylinder misfire with fuel cut-off
P1342Misfire during start cylinder 1
P1343Misfire cylinder 1 with fuel cut-off
P1344Misfire during start cylinder 2
P1345Misfire cylinder 2 with fuel cut-off
P1346Misfire during start cylinder 3
P1347Misfire cylinder 3 with fuel cut-off
P1348Misfire during start cylinder 4
P1349Misfire cylinder 4 fuel cut-off
P1350Misfire during start cylinder 5
P1351Misfire cylinder 5 with fuel cut-off
P1352Misfire during start cylinder 6
P1353Misfire cylinder 6 with fuel cut-off
P1354Misfire during start cylinder 7
P1355Misfire cylinder 7 with fuel cut-off
P1356Misfire during start cylinder 8
P1357Misfire cylinder 8 with fuel cut-off
P1358Misfire during start cylinder 9
P1359Misfire cylinder 9 with fuel cut-off
P1360Misfire during start cylinder 10
P1361Misfire cylinder 10 with fuel cut-off
P1362Misfire during start cylinder 11
P1363Misfire cylinder 11 with fuel cut-off
P1364Misfire during start cylinder 12
P1365Misfire cylinder 12 with fuel cut-off
P1384Knock sensor 3 circuit
P1385Knock sensor 4 circuit
P1386Control module self-test, knock control circuit baseline test bank 1
P1396Crankshaft position sensor segment timing plausibility
P1397Camshaft position sensor 'B' circuit (bank 1)
P1400Heated catalyst battery voltage or current too low during heating (bank 1)
P1401Heated catalyst current too high during heating (bank 1)
P1402Heated catalyst power switch over temperature condition (bank 1)
P1403Carbon canister shut-off valve control circuit electrical - or- M73: heated catalyst battery voltage of current too low during heating (bank 2)
P1404Heated catalyst current too high during heating (bank 2)
P1405Heated catalyst power switch over temperature condition (bank 2)
P1406Heated catalyst internal control module checksum / ROM error
P1413Secondary air injection pump relay control circuit signal low
P1414Secondary air injection pump relay control circuit signal high
P1420Secondary air valve control circuit electrical
P1421Secondary air system bank 2
P1423Secondary air system bank 1
P1432Secondary air injection system incorrect flow detected
P1438Purge control valve control open circuit
P1439Purge control valve control circuit signal low
P1440Purge control valve control circuit signal high
P1441Leakage diagnostic pump control open circuit
P1442Leakage diagnostic pump control circuit signal low
P1443Leakage diagnostic pump control circuit signal high
P1444Diagnostic module tank leakage (DM-TL) pump control open circuit
P1445Diagnostic module tank leakage (DM-TL) pump control circuit signal low
P1446Diagnostic module tank leakage (DM-TL) pump control circuit signal high
P1447Diagnostic module tank leakage (DM-TL) pump current too high during switching solenoid test
P1448Diagnostic module tank leakage (DM-TL) pump current too low during switching solenoid test
P1449Diagnostic module tank leakage (DM-TL) pump current too high (during switching solenoid test)
P1450Diagnostic module tank leakage (DM-TL) switching solenoid control open circuit
P1451Diagnostic module tank leakage (DM-TL) switching solenoid control circuit signal low
P1452Diagnostic module tank leakage (DM-TL) switching solenoid control circuit signal high
P1453Secondary air injection pump relay control circuit electrical
P1454Secondary air injection pump with series resistor control circuit electrical
P1456Heated catalyst heater power supply open circuit (bank 1)
P1457Heated catalyst power switch temperature sensor electrical (bank 1)
P1459Heated catalyst heater power supply open circuit (bank 2)
P1460Heated catalyst power switch temperature sensor electrical (bank 2)
P1461Heated catalyst gate voltage signal low
P1462Heated catalyst internal control module checksum / EEPROM error
P1463Heated catalyst battery temperature sensor 1 electrical
P1464Heated catalyst battery temperature sensor 2 electrical
P1465Heated catalyst battery temperature sensor 1 or 2 plausibility
P1466Heated catalyst power switch temperature sensor plausibility
P1467Heated catalyst comparison battery voltages of power switches plausibility
P1468Heated catalyst battery disconnecting switch plausibility
P1470Leakage diagnostic pump control circuit electrical
P1472Diagnostic module tank leakage (DM-TL) switching solenoid control circuit electrical
P1473Diagnostic module tank leakage (DM-TL) pump current plausibility
P1475Leakage diagnostic pump reed switch did not close
P1476Leakage diagnostic pump clamped tube -or- M52 MY99/00: Leakage diagnostic pump reed switch circuit electrical
P1477Leakage diagnostic pump reed switch did not open
P1500Idle-speed control valve stuck open
P1501Idle-speed control valve stuck closed
P1502Idle-speed control valve closing solenoid control circuit signal high
P1503Idle-speed control valve closing solenoid control circuit signal low
P1504Idle-speed control valve closing solenoid control open circuit
P1505Idle-speed control valve closing solenoid control circuit electrical
P1506Idle-speed control valve opening solenoid control circuit signal high
P1507Idle-speed control valve opening solenoid control circuit signal low
P1508Idle-speed control valve opening solenoid control open circuit
P1509Idle-speed control valve opening solenoid control circuit electrical
P1510Idle-speed control valve stuck
P1511DISA (differentiated intake manifold) control circuit electrical
P1512DISA (differentiated intake manifold) control circuit signal low
P1513DISA (differentiated intake manifold) control circuit signal high
P1519'A' camshaft position actuator bank 1
P1520'B' camshaft position actuator bank 1
P1522'A' camshaft position actuator bank 2
P1523'A' camshaft position actuator signal low bang 1 -or- M52: Camshaft position actuator tight or jammed
P1524'A' camshaft position actuator control circuit signal high bank 1
P1525'A' camshaft position actuator control open circuit bank 1
P1526'A' camshaft position actuator control open circuit bank 2
P1527'A' camshaft position actuator control circuit signal low bank 2
P1528'A' camshaft position actuator control circuit signal high bank 2
P1529'B' camshaft position actuator control circuit signal low bank1
P1530'B' camshaft position actuator control circuit signal high bank1
P1531'B' camshaft position actuator control open circuit bank 1
P1532'B' camshaft position actuator control open circuit bank 2
P1533'B' camshaft position actuator control circuit signal low bank 2
P1534'B' camshaft position actuator control circuit signal high bank 2
P1540Pedal position sensor
P1541Pedal position sensor double error
P1542Pedal position sensor electrical
P1543Pedal position sensor
P1544Pedal position sensor
P1545Pedal position sensor
P1546Pedal position sensor
P1550Idle-speed control valve closing solenoid control circuit electrical
P1552"A" Camshaft position actuator control open circuit bank 1
P1556'A' Camshaft position actuator control open circuit bank 1
P1560'B' Camshaft position actuator control open circuit bank 1
P1564Control module selection
P1565'B' Camshaft position actuator control open circuit bank 1
P1569'A' Camshaft position actuator control open circuit bank 2
P1573Electronic control module sensor supply B low output -or- S54/S62: 'A' Camshaft position actuator control circuit signal low bank 2
P1580Throttle valve mechanically stuck
P1581'B' Camshaft position actuator control open circuit bank 2
P1589Control module self-test, knock control test pulse bank 1
P1593DISA (Differentiated intake manifold ) control circuit electrical
P1594'B' Camshaft position actuator control open circuit bank 2
P1602Control module self-test, control module defective
P1603Control module self-test, torque monitoring
P1604Control module self-test, sqeed monitoring
P1607CAN-Version
P1608Serial communication link control module
P1609Serial communication link EML (electronically engine-power regulation)
P1611Serial communication link transmission control module
P1619Map cooling thermostat control circuit signal low
P1620Map cooling thermostat control circuit signal high
P1622Map cooling thermostat control circuit electrical
P1623Pedal position sensor potentiometer supply
P1624Pedal position sensor potentiometer supply channel 1 electrical -or- M52: coolant thermostat (coolant temperature below thermostat regulating temperature)
P1625Pedal position sensor potentiometer supply channel 2 electrical
P1632Throttle valve adaptation; Adaptation conditions not met
P1633Throttle valve adaptation; Limp-home position unknown
P1634Throttle valve adaptation; Spring test failed
P1635Throttle valve adaptation; Lower mechanical stop not adapted
P1636Throttle valve control circuit
P1637Throttle valve position control; Control deviation
P1638Throttle valve position control; Throttle stuck temporarily
P1639Throttle valve position control; Throttle stuck permanently
P1640Internal control module (ROM/RAM) error
P1690Malfunction indicator lamp (MIL) electrical
P1734Pressure control solenoid 'B' electrical
P1738Pressure control solenoid 'C' electrical
P1743Pressure control solenoid 'E' electrical -or- M44/M52: Brake band electrical
P1744Pressure control solenoid 'A' electrical
P1746Transmission control module output stage
P1747CAN-Bus monitoring
P1748Transmission control module self-test
P1749Secondary pressure solenoid communication error -or- M52: Transmission control module internal memory
P1750Secondary pressure solenoid circuit range / performance -or- M44 / M52 / M62 / M73: System voltage input low
P1751Secondary pressure solenoid open circuit -or- M52: System voltage input high
P1761Shift lock solenoid malfunction
P1765CAN throttle valve
P1770CAN torque interface
P1780CAN torque reduction
CHR
P1000Ignition Circ Low
P1001Ignition Circ Hi
P1004ECU Battery Feed & Power Grounds
P1005Sys Ground Circ
P1006EGR/EVAP Solenoid Circ Low
P1007EGR/EVAP Solenoid Circ Hi
P1008Power Steering Circ Low
P1009Power Steering Circ Hi
P1012MPA Circ Low
P1013MPA Circ Hi
P1014Fuel Pump Circ Low
P1015Fuel Pump Circ Hi
P1016Charge Air Temp Circ Low
P1017Charge Air Temp Circ Hi
P1018Serial Data Circ
P1019Power Latch Not Set
P1021Engine Failed To Start Due To Mechanical, Fuel or Ignition Conditions
P1022Starter Relay Circ Low
P1024ECU Start Circ Low
P1025WOT Circ Low
P1026WOT Circ Hi
P1027ECU Sees Wide Open Throttle
P1028ECU Does Not See Wide Open Throttle
P1029ISA Closed Throttle Circ Low
P1030ISA Closed Throttle Circ Hi
P1031ECU Sees Closed Throttle
P1032ECU Does Not See Closed Throttle
P1033ISA Circs
P1037TP Sens Circ Reads Low
P1038Park/Neutral Line Hi
P1039Park/Neutral Line Low
P1040Latched B+ Line Low
P1041Latched B+ Line Hi
P1042No Latched B+ 1/2 Volt Drop
P1043Shift Lamp Circ Grounded
P1044D2ЁC1 Circ Low (A/T) or Upshift Lamp Circ (M/T) or Shift Lamp Circ Hi
P1045Shift Lamp Circ Open
P1047Wrong ECU
P1048M/T Vehicle Configuration
P1049A/T Vehicle Configuration
P1050Idle RPM Low
P1051Idle RPM Hi
P1052MAP Sens Out Of Limits
P1053Change In MAP Reading Out Of Limits
P1054Coolant Sens & 5V Supply for TP Sens/MAP Circs Low
P1055Coolant Sens Circ Hi
P1056Inactive Coolant Temp Sens
P1059A/C Request Circ Low
P1060A/C Request Circ Hi
P1061A/C Select Circ Low
P1062A/C Select Circ Hi
P1063A/C Clutch Circ Low
P1064A/C Clutch Circ Hi & Power Steering Input
P1068Latch Relay Circ Hi
P1069No Tach
P1074ECU Does Not See Speed Sens
P1105Open or shorted condition detected in the baro read solenoid control circuit
P1106MAP Sens Circ Interm Hi Voltage
P1107MAP Sens Circ Interm Low Voltage
P1110Decreased Engine Perf Due To Hi Intake Air Temp
P1111IAT Sens Circ Interm Hi Voltage
P1112IAT Sens Circ Interm Low Voltage
P1114ECT Sens Circ Interm Low Voltage
P1115ECT Sens Circ Interm Hi Voltage
P1121TPS Circ Interm Hi Voltage
P1122TPS Circ Interm Low Voltage
P1125Accelerator Pedal Pos Sys
P1133HO2S Insufficient Switching Bank1 Sens1
P1134HO2S Insufficient Transition Time Ratio Bank1 Sens1
P1153HO2S Insufficient Switching Bank2 Sens1
P1154HO2S Insufficient Transition Time Ratio Bank2 Sens 1
P1180Decreased Engine Perf Due To Hi Inj Pump Fuel Temp
P1191Intake Air Duct Leak
P1192Inlet Air Temp Sens Voltage Low
P1193Inlet Air Temp Voltage Hi
P119402 Heater Perf
P11951/1 02 Sens Slow During Catalyst Monitor
P11962/1 02 Sens Slow During Catalyst Monitor
P11971/2 02 Sens Slow During Catalyst Monitor
P1198Radiator Temp Sens Volts Too Hi
P1199Radiator Temp Sens Volts Too Low
P1214Inj Pump Timing Offset
P1216Fuel Solenoid Response Time Too Short
P1217Fuel Solenoid Response Time Too Long
P1218Inj Pump Calibration Circ
P1243Open or shorted condition detected in the turbocharger surge valve solenoid control
P1271Accelerator Pedal Pos Sens1-2 Correlation
P1272Accelerator Pedal Pos Sens2-3 Correlation
P1273Accelerator Pedal Pos Sens1-3 Correlation
P1275Accelerator Pedal Pos Sens1 Circ
P1277Accelerator Pedal Pos Sens1 Low Voltage
P1278Accelerator Pedal Pos Sens1 Hi Voltage
P1280Accelerator Pedal Pos Sens2 Circ
P1281Engine is Cold Too Long
P1282Accelerator Pedal Pos Sens2 Low Voltage or Fuel Pump Relay Ctrl Circ
P1283Accelerator Pedal Pos Sens2 Hi Voltage or Idle Select Signal Invalid
P1284Fuel Inj Pump Battery Voltage Out Of Range
P1285Accelerator Pedal Pos Sens3 Circ or Fuel Inj Pump Ctrller Always On
P1286Accelerator Pos Sens Supply Voltage Too Hi
P1287Accelerator Pedal Pos Sens3 Low Voltage or Fuel Inj Pump Ctrl Supply Voltage Low
P1288Accelerator Pedal Pos Sens3 Hi Voltage or Intake Manif Short Runner Solenoid Circ
P1289Manif Tune Valve Solenoid Circ
P1290CNG Fuel Sys Press Too Hi
P1291No Temp Rise Seen From Intake Heaters
P1292CNG Press Sens Voltage Too Hi
P1293CNG Press Sens Voltage Too Low
P1294Target Idle Not Reached
P1295No 5Vs to Throttle Pos Sens
P1296No 5Vs to MAP Sens
P1297No Change in MAP from Start To Run
P1298Lean Operation at Wide Open Throttle
P1299Vacuum Leak Found (IAC Fully Seated)
P1336Crank Pos Sys Variation Not Learned
P1345Crank Pos/Camshaft Pos Correlation
P1351Ignition Ctrl Circ Hi Voltage
P1361Ignition Ctrl Circ Low Voltage
P1380Electronic Brake Ctrl Rough Road Data Unusable
P1381Misfire Detected-No Electronic Brake Ctrl Data
P1388Auto Shutdown Relay Ctrl Circ
P1389No ASD Relay Output Voltage at PCM
P1390Timing Belt Skipped 1 Tooth or More
P1391Interm Loss of CMP or CKP
P1398Misfire Adaptive Numerator at Limit
P1399Wait to Start Lamp Circ
P1403No 5Vs to EGR Sens
P1404EGR Valve Closed Pintle Pos
P1406EGR Valve Pos
P1409EGR Valve Sys leak
P1415AIR Sys Bank1
P1416AIR Sys Bank1
P1441Evap Emissions Flow During Non-Purge
P1475Auxiliary 5V Supply Voltage Hi
P1476Too Little Sec Air
P1477Too Much Sec Air
P1478Battery Temp Sens Volts Out of Limit
P1479Trans Fan Relay Circ
P1480PCV Solenoid Circ
P1481EATX Misfire RPM Signal out of Range
P1482Catalyst Temp Sens Circ Shorted Low
P1483Catalyst Temp Sens Circ Shorted Hi
P1484Catalytic Conv Overheat Detected
P1485Air Inj Solenoid Circ
P1486Eva Leak Monitor Pinched Hose Found
P1487Hi Speed Radiator Fan CTRL Relay Circ
P1488Auxiliary 5V Supply Output Too Low
P1489Hi Speed Fan CTRL Relay Circ
P1490Low Speed Fan CTRL Relay Circ
P1491Radiator Fan Ctrl Relay Circ
P1492Ambient/Battery Temp Sens Volts Too Hi
P1493Ambient/Battery Temp Sens Volts Too Low
P1494Leak Detection Pump Switch or Mechanical Fault
P1495Leak Detection Pump Solenoid Circ
P14965V Supply, Output Too Low
P1498Hi Speed Radiator Fan Ground CTRL Relay Circ
P1499Open or shorted condition detected in the hydraulic cooling fan solenoid control
P1508IAC Sys Low RPM
P1509IAC Sys Hi RPM
P1594Charging Sys Voltage Too Hi
P1595Speed Ctrl Solenoid Circs
P1596Speed Ctrl Switch Always Hi
P1597Speed Ctrl Switch Always Low
P1598A/C Press Sens Volts Too Hi
P1599A/C Press Sens Volts Too Low
P1602PCM Not Programmed
P1621PCM Memory Perf or Write
P1626Vehicle Theft Sys Ctrl Loss of Data
P1627A/D Perf
P1630Vehicle Theft Sys PCM in Learn Mode
P1631Vehicle Theft Sys Improper Password
P16355V Ref ( Circ
P16395V Ref ( Circ
P1641MIL Ctrl Circ
P1643Wait To Start Lamp Ctrl Circ
P16465V Ref (C) Circ
P1652J1850 Comms Bus
P1653EGR Vent Solenoid Ctrl Circ
P1654Service Throttle Soon Lamp Ctrl Circ
P1655EGR Solenoid Ctrl Circ
P1656Wastegate Solenoid Ctrl Circ
P1680Clutch Released Switch Circ
P1681No I/P Cluster CCD/J1850 Messages Received
P1682Charging Sys Voltage Too Low
P1683Speed Ctrl Power Relay; or S/C 12v Driver CKT
P1684Battery Disconnected in the last 50 Starts
P1685Skim Invalid Key
P1686No SKIM BUS Messages Received
P1687No Cluster BUS Message
P1688Internal Fuel Inj Pump Ctrller Failure
P1689No Comm between ECM & Inj Pump Mod
P1690CKP Sens Does Not Agree with ECM CKP Sens
P1691Fuel Sys ESS RPM Error
P1692DTC Set In ECM
P1693DTC Detected in Companion JTEC Mod
P1694No BUS Message Received from ECM Mod
P1695No CCD/J1850 Messages from the Body Ctrl Mod.
P1696PCM Failure EEPROM Write Denied
P1697PCM Failure SRI Mile Not Stored
P1698No CCD/J1850 Message From TCM/PCM
P1699No CCD/J1850 Messages received from the Climate Control Module(CCM)
P1719Skip Shift Solenoid Circ
P1740TCC or O/D Solenoid Perf
P1756Gov Press Not Equal to Target @ not15-20 PSI
P1757Gov Press above 3 PSI in gear with 0 MPH
P1762Gov Press Sens Offset Volts Too Low or Hi
P1763Governor Press Sens Volts Too Hi
P1764Governor Press Sens Volts Too Low
P1765Trans 12 Volt Supply Relay CTRL Circ
P1830Open or shorted condition detected in the clutch pedal switch over-ride relay control
P1899P/N Switch Stuck in Park or in Gear
DTC-Generic
P0001 Fuel Volume Regulator Control Circuit/Open
P0002 Fuel Volume Regulator Control Circuit Range/Performance
P0003 Fuel Volume Regulator Control Circuit Low
P0004 Fuel Volume Regulator Control Circuit High
P0005 Fuel Shutoff Valve C ontrol Circuit/Open
P0006 Fuel Shutoff Valve C ontrol Circuit Low
P0007 Fuel Shutoff Valve C ontrol Circuit H igh
P0008 Engine Position System Performance (Bank1)
P0009 Engine Position System Performance (Bank2)
P0010 A Camshaft Position Actuator Circuit (Bank1)
P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 A Camshaft Position - Timing O ver-Retarded (Bank 1)
P0013 B Camshaft Position - Actuator Circuit (Bank1)
P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 B Camshaft Position - Timing O ver-Retarded (Bank 1)
P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)
P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)
P0020 A Camshaft Position Actuator Circuit (Bank 2)
P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 A Camshaft Position - Timing O ver-Retarded (Bank 2)
P0023 B Camshaft Position - Actuator Circuit (Bank 2)
P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 B Camshaft Position - Timing O ver-Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control C ircuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0049 Turbo/Super Charger Turbine Overspeed
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
P0062 HO2S Heater Control C ircuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0068 MAP/MAF Throttle Position Correlation
P0069 Manifold Absolute Pressure Barometric Pressure Correlation
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor C ircuit Low
P0073 Ambient Air Temperature Sensor Circuit High
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 1)
P0081 Intake Valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 2)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0090 Fuel Pressure Regulator 1 C ontrol Circuit
P0091 Fuel Pressure Regulator 1 C ontrol Circuit Low
P0092 Fuel Pressure Regulator 1 C ontrol Circuit High
P0093 Fuel System Leak Detected Large Leak
P0094 Fuel System Leak Detected Small Leak
P0095 Intake Air Temperature Sensor 2 C ircuit
P0096 Intake Air Temperature Sensor 2 C ircuit Range/Performance
P0097 Intake Air Temperature Sensor 2 C ircuit Low
P0098 Intake Air Temperature Sensor 2 Circuit High
P0099 Intake Air Temperature Sensor 2 C ircuit Intermittent/Erratic
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Position Sensor/Switch A Circuit Malfunction
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle Position Sensor/Switch A Circuit Low Input
P0123 Throttle Position Sensor/Switch A Circuit High Input
P0124 Throttle Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0128 Coolant Thermostat Malfunction
P0129 Barometric Pressure Too Low
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 Fuel Trim too Lean (Bank 1)
P0172 Fuel Trim too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 Fuel Trim too Lean (Bank 2)
P0175 Fuel Trim too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0562 A/C pressure sensor low voltage(Chrysler)
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Control Module Read Only Memory(ROM)
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off/1-2 Shift Solenoid Valve Performance
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical/1-2 Shift Solenoid Circuit Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off/2-3 Shift Solenoid Valve Performance
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical/2-3 Shift Solenoid Circuit Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B Malfunction
P0776 Pressure Control Solenoid B Performance
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction/ 3-2 Shift Solenoid Circuit Electrical
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
P1101 MAF Sensor Out Of Self Test Range./KOER Not Able To Complete KOER Aborted
P1102 MAF Sensor In Range But Lower Than Expected
P1103 MAF Sensor In Range But Higher Than Expected
P1104 MAF Ground Malfunction
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108 Dual Alternator Battery Lamp Circuit Malfunction
P1109 IAT - B Sensor Intermittent
P1110 IAT Sensor (D/C) Open/Short
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113 IAT Sensor Open/Short
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent
P1118 Manifold Absolute Temperature Circuit Low Input
P1119 Manifold Absolute Temperature Circuit High Input
P1120 Throttle position sensor out of range
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1123 Throttle Position Sensor In Range But Higher Than Expected
P1124 Throttle Position Sensor Out Of Self Test Range
P1125 Throttle position sensor intermittent
P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction
P1127 Exhaust Not Warm, Downstream O2 Sensor
P1128 Upstream Heated O2 Sensors Swapped
P1129 Downstream Heated O2 Sensors Swapped
P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
P1131 Lack Of HO2S Switch - Sensor Indicates Lean
P1132 Lack Of HO2S Switch - Sensor Indicates Rich
P1133 HO2S Insufficient Switching Sensor 1
P1134 HO2S Transition Time Ratio Sensor 1
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Fan Control Circuit Malfunction
P1137 Lack Of HO2S Switch - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139 Water In Fuel Indicator Circuit Malfunction
P1140 Water In Fuel Condition
P1141 Fuel Restriction Indicator Circuit Malfunction
P1142 Fuel Restriction Condition
P1143 Air Assist Control Valve Range/Performance
P1144 Air Assist Control Valve Circuit Malfunction
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean
P1154 Bank 2 Fuel Control Shifted Rich
P1155 Alternative Fuel Controller
P1156 Fuel Select Switch Malfunction
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159 Fuel Stepper Motor Malfunction
P1167 Invalid Test,throttle not depressed
P1168 Fuel Rail Sensor In-Range Low Failure
P1169 Fuel Rail Sensor In-Range High Failure
P1170 ESO - Engine Shut Off Solenoid Fault
P1171 Rotor Sensor Fault
P1172 Rotor Control Fault
P1173 Rotor Calibration Fault
P1174 Cam Sensor Fault
P1175 Cam Control Fault
P1176 Cam Calibration Fault
P1177 Synchronization Fault
P1178 ( open )
P1180 Fuel Delivery System Malfunction - Low
P1181 Fuel Delivery System Malfunction - High
P1182 Fuel Shut Off Solenoid Malfunction
P1183 Engine Oil Temperature Circuit Malfunction
P1184 Engine Oil Temperature Out Of Self Test Range
P1185 FTS High - Fuel Pump Temperature Sensor High
P1186 FTS Low - Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory Fault
P1189 Pump Speed Signal Fault
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 Voltage External
P1193 EGR Drive Overcurrent
P1194 ECU A/D Converter
P1195 SCP HBCC Failed To Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1200 Injector Control Circuit
P1201 Injector Circuit Open / Shorted - Cylinder #1
P1202 Injector Circuit Open / Shorted - Cylinder #2
P1203 Injector Circuit Open / Shorted - Cylinder #3
P1204 Injector Circuit Open / Shorted - Cylinder #4
P1205 Injector Circuit Open / Shorted - Cylinder #5
P1206 Injector Circuit Open / Shorted - Cylinder #6
P1209 Injector Control Pressure System Fault
P1210 Injector Control Pressure Above Expected Level
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
P1213 Start Injector Circuit Malfunction
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System Malfunction
P1221 Traction Control System Malfunction
P1222 Traction Control Output Circuit Malfunction
P1223 Pedal Demand Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor Malfunction
P1226 Control Sleeve Sensor Malfunction
P1227 Wastegate Failed Closed (Over Pressure)
P1228 Wastegate Failed Open (Under Pressure)
P1229 Intercooler Pump Driver Fault
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low, High Speed
P1232 Fuel Pump Speed Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off Line
P1234 Fuel Pump Driver Module Off Line
P1235 Fuel Pump Control Out Of Range
P1236 Fuel Pump Control Out Of Range
P1237 Fuel Pump Secondary Circuit Malfunction
P1238 Fuel Pump Secondary Circuit Malfunction
P1239 Speed Fuel Pump Positive Feed Fault
P1240 Sensor Power Supply Malfunction
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Faulty or Ground Fault
P1244 Alternator Load Input Failed High
P1245 Alternator Load Input Failed Low
P1246 Alternator Load Input Failed
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 PRC Solenoid Circuit Malfunction
P1251 Air Mixture Solenoid Circuit Malfunction
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255 Pedal Correlation PDS2 and LPDS Low
P1256 Pedal Correlation PDS1 and HPDS
P1257 Pedal Correlation PDS2 and HPDS
P1258 Pedal Correlation PDS1 and PDS2
P1259 Immobilizer to PCM Signal Error
P1260 THEFT Detected, Vehicle Immobilzed
P1261 Cylinder #1 High To Low Side Short
P1262 Cylinder #2 High To Low Side Short
P1263 Cylinder #3 High To Low Side Short
P1264 Cylinder #4 High To Low Side Short
P1265 Cylinder #5 High To Low Side Short
P1266 Cylinder #6 High To Low Side Short
P1267 Cylinder #7 High To Low Side Short
P1268 Cylinder #8 High To Low Side Short
P1269 Immobilizer Code Not Programmed
P1270 Engine RPM Or Speed Limiter Reached
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High To Low Side Open
P1273 Cylinder #3 High To Low Side Open
P1274 Cylinder #4 High To Low Side Open
P1275 Cylinder #5 High To Low Side Open
P1276 Cylinder #6 High To Low Side Open
P1277 Cylinder #7 High To Low Side Open
P1278 Cylinder #8 High To Low Side Open
P1280 Injection Control Pressure Out Of Range Low
P1281 Injection Control Pressure Out Of Range High
P1282 Excessive Injection Control Pressure
P1283 IPR Circuit Failure
P1284 Aborted KOER - ICP Failure
P1285 Cylinder head over temp sensed
P1286 Fuel Pulse In Range But Lower Than Expected
P1287 Fuel Pulse In Range But Higher Than Expected
P1288 Cylinder Head Temp Sensor Out Of Self Test Range
P1289 Cylinder Head Temp Sensor High Input
P1290 Cylinder Head Temp Sensor Low Input
P1291 Injector High Side Short To GND Or VBATT - Bank 1
P1292 Injector High Side Short To GND Or VBATT - Bank 2
P1293 Injector High Side Open - Bank 1
P1294 Injector High Side Open - Bank 2/Target idle not reached
P1295 Multi-faults - Bank 1 - With Low Side Shorts
P1296 Multi-faults - Bank 2 - With Low Side Shorts
P1297 Injector High Sides Shorted Together
P1298 IDM Failure
P1299 Cylinder Head Overtemperature Protection Active
P1300 Boost Calibration Fault
P1301 Boost Calibration High
P1302 Boost Calibration Low
P1303 EGR Calibration Fault
P1304 EGR Calibration High
P1305 EGR Calibration Low
P1306 Kickdown Relay Pull - In Circuit Fault
P1307 Kickdown Relay Hold Circuit Fault
P1308 A/C Clutch Circuit Fault
P1309 Misfire Monitor AICE Chip Fault
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Injector Circuit / IDM Codes Detected
P1317 Injector Circuit / IDM Codes Not Updated
P1336 Crank / Cam Sensor Range / Performance
P1340 Camshaft Position Sensor B Circuit Malfunction
P1341 Camshaft Position Sensor B Range / Performance
P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
P1346 Fuel Level Sensor B Circuit Malfunction
P1347 Fuel Level Sensor B Range / Performance
P1348 Fuel Level Sensor B Circuit Low
P1349 Fuel Level Sensor B Circuit High
P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor
P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
P1352 Ignition Coil A Primary Circuit Malfunction
P1353 Ignition Coil B Primary Circuit Malfunction
P1354 Ignition Coil C Primary Circuit Malfunction
P1355 Ignition Coil D Primary Circuit Malfunction
P1360 Ignition Coil A Secondary Circuit Malfunction
P1361 Ignition Control (IC) Circuit Low Voltage
P1362 Ignition Coil C Secondary Circuit Malfunction
P1363 Ignition Coil D Secondary Circuit Malfunction
P1364 Ignition Coil Primary Circuit Failure
P1365 Ignition Coil Secondary Circuit Failure
P1366 Ignition Spare
P1367 Ignition Spare
P1368 Ignition Spare
P1369 Engine Temperature Light Monitor Failure
P1370 Insufficient RMP Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1380 Misfire Detected - Rough Road Data Not Available
P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
P1383 Variable Cam Timing Overretarded (Bank #1)
P1384 VVT Solenoid A Malfunction
P1385 Variable Cam Timing Solenoid B Malfunction
P1386 Variable Cam Timing Overadvanced (Bank #2)
P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
P1388 Variable Cam Timing Overretarded (Bank #2)
P1389 Glow Plug Circuit High Side Low Input
P1390 Octane Adjust Pin Out Of Self Test Range
P1391 Glow Plug Circuit Low Input (Bank #1)
P1392 Glow Plug Circuit High Input (Bank #1)
P1393 Glow Plug Circuit Low Input (Bank #2)
P1394 Glow Plug Circuit High Input (Bank #2)
P1395 Glow Plug Monitor Fault (Bank #1)
P1396 Glow Plug Monitor Fault (Bank #2)
P1397 System Voltage Out Of Self Test Range
P1398 VVT Solenoid B Circuit High Input
P1399 Glow Plug Circuit High Side, High Input
P1400 DPFE Circuit Low Input
P1401 DPFE Circuit High Input
P1402 EGR Metering Orifice Restricted
P1403 DPFE Sensor Hoses Reversed
P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
P1405 DPFE Sensor Upstream Hose Off Or Plugged
P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
P1407 EGR No Flow Detected
P1408 EGR Flow Out Of Self Test Range
P1409 EVR Control Circuit Malfunction
P1411 SAI System Incorrect Downstream Flow Detected
P1413 SAI System Monitor Circuit Low Input
P1414 SAI System Monitor Circuit High Input
P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
P1417 Port Air Relief Circuit Malfunction
P1418 Split Air #1 Circuit Malfunction
P1419 Split Air #2 Circuit Malfunction
P1420 Catalyst Temperature Sensor Failure
P1421 Catalyst Damage
P1422 EGI Temperature Sensor Failure
P1423 EGI Functionality Test Failed
P1424 EGI Glow Plug Primary Failure
P1425 EGI Glow Plug Secondary Failure
P1426 EGI Mini - MAF Failed Out Of Range
P1427 EGI Mini - MAF Failed Short Circuit
P1428 EGI Mini - MAF Failed Open Circuit
P1429 Electric Air Pump Primary Failure
P1430 Electric Air Pump Secondary Failure
P1433 A/C Refrigerant Temperature Circuit Low
P1434 A/C Refrigerant Temperature Circuit High
P1435 A/C Refrigerant Temperature Circuit Range/Performance
P1436 A/C Evaporator Air Temperature Circuit Low
P1437 A/C Evaporator Air Temperature Circuit High
P1438 A/C Evaporator Air Temperature Circuit Range/Performance
P1439 Floor Temperature Switch Circuit Malfunction
P1440 Purge Valve Stuck Open
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
P1442 Evaporative Emission Control System Leak Detected
P1443 Evaporative Emission Control System Control Valve
P1444 Purge Flow Sensor Circuit Low Input
P1445 Purge Flow Sensor Circuit High Input
P1446 Evaporative Vac Solenoid Circuit Malfunction
P1447 ELC System Closure Valve Flow Fault
P1448 ELC System 2 Fault
P1449 Evaporative Check Solenoid Circuit Malfunction
P1450 Unable To Bleed Up Fuel Tank Vacuum
P1451 Evap Emission Control Sys Vent Control Valve Circuit
P1452 Unable To Bleed - Up Vacuum in Tank
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative System Vacuum Test Malfunction
P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
P1456 Fuel Tank Temperature Sensor Circuit Malfunction
P1457 Unable To Pull Vacuum In Tank
P1460 Wide open throttle A/C cutoff relay circuit
P1461 A/C pressure sensor circuit voltage low
P1462 A/C pressure sensor circuit voltage high
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out of Self Test Range
P1465 A/C Relay Circuit Malfunction
P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
P1467 A/C Compressor Temperature Sensor Malfunction
P1468 SSPOD Open Circuit or Closed Circuit Fault
P1469 Low A/C Cycling Period
P1470 A/C Cycling Period Too Short
P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
P1473 Fan Secondary High With Fan(s) Off
P1474 Low Fan Control Primary Circuit Malfunction
P1475 Fan Relay (Low) Circuit Malfunction
P1476 Fan Relay (High) Circuit Malfunction
P1477 Additional Fan Relay Circuit Malfunction
P1478 Cooling Fan Driver Fault
P1479 High Fan Control Primary Circuit Malfunction
P1480 Fan Secondary Low with Low Fan On
P1481 Fan Secondary Low With High Fan On
P1482 SCP
P1483 Power To Fan Circuit Overcurrent
P1484 Open Power To Ground VCRM
P1485 EGRV Circuit Malfunction
P1486 EGRA Circuit Malfunction
P1487 EGRCHK Solenoid Circuit Malfunction
P1490 Secondary Air Relief Solenoid Circuit Malfunction
P1491 Secondary Switch Solenoid Circuit Malfunction
P1492 APLSOL Solenoid Circuit Malfunction
P1493 RCNT Solenoid Circuit Malfunction
P1494 SPCUT Solenoid Circuit Malfunction
P1495 TCSPL Solenoid Circuit Malfunction
P1500 Vehicle Speed Sensor Intermittent
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent Malfunction
P1503 Auxillary Speed Sensor Fault
P1504 Idle Air Control Circuit Malfunction
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error
P1507 Idle Air Control Underspeed Error
P1508 Idle Control System Circuit Open
P1509 Idle Control System Circuit Shorted
P1510 Idle Signal Circuit Malfunction
P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit Malfunction
P1516 IMRC Input Error (Bank 1)
P1517 IMRC Input Error (Bank 2)
P1518 Intake Manifold Runner Control (Stuck Open)
P1519 Intake Manifold Runner Control (Stuck Closed)
P1520 Intake Manifold Runner Control Circuit Malfunction
P1521 Variable Intake Solenoid #1 Circuit Malfunction
P1522 Variable Intake Solenoid #2 Circuit Malfunction
P1523 IVC Solenoid Circuit Malfunction
P1524 Variable Intake Solenoid System
P1525 Air Bypass Valve System
P1526 Air Bypass System
P1527 Accelerate Warmup Solenoid Circuit Malfunction
P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529 SCAIR Solenoid Circuit Malfunction
P1530 A/C Clutch Circuit Malfunction
P1531 Invalid Test - Accelerator Pedal Movement
P1532 IMCC Circuit Malfunction, Bank B
P1533 AAI Circuit Malfunction
P1534 Inertia Switch Activated
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit Failure
P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
P1539 Power To A/C Clutch Circuit Overcurrent
P1540 Air Bypass Valve Circuit Malfunction
P1549 IMCC Circuit Malfunction, Bank B
P1550 PSPS Out Of Self Test Range
P1565 Speed Control Command Switch Out of Range High
P1566 Speed Control Command Switch Out of Range Low
P1567 Speed Control Output Circuit Continuity
P1568 Speed Control Unable to Hold Speed
P1571 Brake Switch Malfunction
P1572 Brake Pedal Switch Circuit Malfunction
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Disagreement btwn Sensors
P1575 Pedal Position Out of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Disagreement btwn Sensors
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disable
P1584 TCU Detected IPE Circuit Malfunction
P1585 Throttle Control Unit Malfunction
P1586 Throttle Control Unit Throttle Position Malfunction
P1587 Throttle Control Unit Modulated Command Malfunction
P1588 Throttle Control Unit Detected Loss of Return Spring
P1589 TCU Unable To Control Desired Throttle Angle
P1600 Loss of KAM Power; Open Circuit
P1601 ECM/TCM Serial Communication Error
P1602 Immobilizer/ECM Communication Error
P1603 EEPROM Malfunction
P1604 Code Word Unregestered
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay O/P Circuit Malfunction
P1607 MIL O/P Circuit Malfunction
P1608 Internal ECM Malfunction
P1609 Diagnostic Lamp Driver Fault
P1610 SBDS Interactive Codes
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
P1622 Immobilizer ID Does Not Match
P1623 Immobilizer Code Word/ID Number Write Failure
P1624 Anti Theft System
P1625 B+ Supply To VCRM Fan Circuit Malfunction
P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
P1627 Module Supply Voltage Out Of Range
P1628 Module Ignition Supply Input Malfunction
P1629 Internal Voltage Regulator Malfunction
P1630 Internal Vref Malfunction
P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P1633 KAM Voltage Too Low
P1634 Data Output Link Circuit Failure
P1635 Tire / Axle Ratio Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error
P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
P1638 Can Link ECM/INSTM Circuit / Network Malfunction
P1639 Vehicle ID Block Corrupted or Not Programmed
P1640 Powertrain DTCs Available in Another Module
P1641 Fuel Pump Primary Circuit Failure
P1642 Fuel Pump Monitor Circuit High Input
P1643 Fuel Pump Monitor Circuit Low Input
P1644 Fuel Pump Speed Control Circuit Malfunction
P1645 Fuel Pump Resistor Switch Circuit Malfunction
P1650 PSP Switch Out of Self Test Range
P1651 PSP Switch Input Malfunction
P1652 IAC Monitor Disabled by PSP Switch Failed On
P1653 Power Steering Output Circuit Malfunction
P1654 Recirculation Override Circuit Malfunction
P1655 Starter Disable Circuit Malfunction
P1660 Output Circuit Check Signal High
P1661 Output Circuit Check Signal Low
P1662 IDM_EN Circuit Failure
P1663 Fuel Demand Command Signal Circuit Malfunction
P1667 CI Circuit Malfunction
P1668 PCM - IDM Communications Error
P1670 Electronic Feedback Signal Not Detected
P1680 Metering Oil Pump Malfunction
P1681 Metering Oil Pump Malfunction
P1682 Metering Oil Pump Malfunction
P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
P1689 Oil Pressure Control Solenoid Circuit Malfunction
P1690 Wastegate Solenoid Circuit Malfunction
P1691 Turbo Pressure Control Solenoid Circuit Malfunction
P1692 Turbo Control Solenoid Circuit Malfunction
P1693 Turbo Charge Control Circuit Malfunction
P1694 Turbo Charge Relief Circuit Malfunction
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 TRS Circuit Intermittent Malfunction
P1703 Brake Switch Out Of Self Test Range
P1704 Digital TRS Failed to Transition States in KOEO / KOER
P1705 Not in P or N During KOEO / KOER
P1706 High Vehicle Speed Observed in Park
P1707 Transfer Case Neutral Indicator Hard Fault Present
P1708 Clutch Switch Circuit Malfunction
P1709 PNP Switch Out Of Self Test Range
P1711 TFT Sensor Out Of Self Test Range
P1712 Trans Torque Reduction Request Signal Malfunction
P1713 TFT Sensor In Range Failure Low Value
P1714 SSA Inductive Signature Malfunction
P1715 SSB Inductive Signature Malfunction
P1716 SSC Inductive Signature Malfunction
P1717 SSD Inductive Signature Malfunction
P1718 TFT Sensor In Range Failure High
P1720 Vehicle Speed (Meter) Circuit Malfunction
P1721 Gear 1 Incorrect Ratio
P1722 Gear 2 Incorrect Ratio
P1723 Gear 3 incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1725 Insufficient Engine Speed Increase During Self Test
P1726 Insufficient Engine Speed Decrease During Self Test
P1727 Coast Clutch Solenoid Inductive Signature Malfunction
P1728 Transmission Slip Error
P1729 4x4 Low Switch Error
P1730 Gear Control Malfunction 2,3,5
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1734 Gear Control Malfunction
P1735 First Gear Switch Circuit Malfunction
P1736 Second Gear Switch Circuit Malfunction
P1737 Lockup Solenoid System
P1738 Shift Time Error
P1739 Slip Solenoid System
P1740 Torque Converter Clutch Inductive Signature Malfunction
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Failed On
P1743 Torque Converter Clutch Solenoid Failied On
P1744 Torque Converter Clutch System Performance
P1745 Line Pressure Solenoid System
P1746 Pressure Control Solenoid "A" Open Circuit
P1747 Pressure Control Solenoid "A" Short Circuit
P1748 EPC Malfunction
P1749 Pressure Control Solenoid Failed Low
P1751 Shift Solenoid A Performance
P1754 Coast Clutch Solenoid Circuit Malfunction
P1755 Intermediate Speed Sensor (ISS) Malfunction
P1756 Shift Solenoid B Performance
P1760 Pressure Control Solenoid "A" Short Circuit
P1761 Shift Solenoid C Performance
P1762 Overdrive Band Failed Off
P1765 Timing Solenoid Circuit Malfunction
P1767 Torque Converter Clutch Circuit Malfunction
P1768 Performance / Normal / Winter Mode Input Malfunction
P1769 AG4 Transmission Torque Modulation Fault
P1770 Clutch Solenoid Circuit Malfunction
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration Fault
P1777 Ignition Retard Request Circuit Fault
P1778 Transmission Reverse I/P Circuit Malfunction
P1779 TCIL Circuit Malfunction
P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
P1781 4X4 Switch Out of Self Test Range
P1782 P/ES Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid "B" Open Circuit
P1789 Pressure Control Solenoid "B" Short Circuit
P1790 TP (Mechanical) Circuit Malfunction
P1791 TP (Electric) Circuit Malfunction
P1792 Barometer Pressure Circuit Malfunction
P1793 Intake Air Volume Circuit Malfunction
P1794 Battery Voltage Circuit Malfunction
P1795 Idle Switch Circuit Malfunction
P1796 Kick Down Switch Circuit Malfunction
P1797 Neutral Switch Circuit Malfunction
P1798 Coolant Temperature Circuit Malfunction
P1799 Hold Switch Circuit Malfunction
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P1801 Transmission Clutch Interlock Safety Switch Open Circuit
P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
P1816 Transmission Neutral Safety Switch Circuit Failure
P1817 Transmission Neutral Safety Switch Open Circuit
P1818 Transmission Neutral Safety Switch Short Circuit To Battery
P1819 Transmission Neutral Safety Switch Short Circuit To Ground
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
P1838 Transmission Transfer Case Shift Motor Circuit Failure
P1839 Transmission Transfer Case Shift Motor Open Circuit
P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery
P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground
P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
P1845 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
P1847 Transmission Transfer Case Contact Plate 'A' Open Circuit
P1848 Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery
P1849 Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground
P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
P1851 Transmission Transfer Case Contact Plate 'B' Open Circuit
P1852 Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery
P1853 Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground
P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
P1855 Transmission Transfer Case Contact Plate 'C' Open Circuit
P1856 Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery
P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
P1859 Transmission Transfer Case Contact Plate 'D' Open Circuit
P1860 TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery
P1861 Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground
P1862 Transmission Transfer Case Contact Plate Power Circuit Failure
P1863 Transmission Transfer Case Contact Plate Power Open Circuit
P1864 Transmission Transfer Case Contact Plate Power Short To Battery
P1865 Transmission Transfer Case Contact Plate Power Short To Ground
P1866 Transmission Transfer Case System Concern - Servicing Required
P1867 Transmission Transfer Case Contact Plate General Circuit Failure
P1868 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure
P1869 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
P1871 Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
P1872 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
P1873 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure
P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1878 Transmission Transfer Case Disengaged Solenoid Circuit Failure
P1879 Transmission Transfer Case Disengaged Solenoid Open Circuit
P1880 Transmission Transfer Case Disengaged Solenoid Short to Battery
P1881 Engine Coolant Level Switch Circuit Failure, GEM
P1882 Engine Coolant Level Switch Circuit Short to Ground
P1883 Engine Coolant Level Switch Circuit Failure, GEM
P1884 Engine Coolant Level Lamp Circuit Short to Ground
P1885 Transmission Transfer Case Disengaged Solenoid Short to Ground
P1886 4X4 Initialization Failure
P1890 Transmission 4WD Mode Select Return Input Circuit Failure
P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
P1900 OSS Circuit Intermittent Malfunction
P1901 TSS Circuit Intermittent Malfunction
P1902 Pressure Control Solenoid "B" Intermittent Short
P1903 Pressure Control Solenoid "C" Short Circuit
P1904 Pressure Control Solenoid "C" Open Circuit
P1905 Pressure Control Solenoid "C" Intermittent Short
P1906 Kickdown Pull Relay Open or Short Circuit to Ground
P1907 Kickdown Hold Relay Open or Short Circuit to Ground
P1908 Transmission Pressure Circuit Solenoid Open or Short to Ground
P1909 Trans Temp Sensor Circuit Open or Shorted to Pwr or Gnd
P1910 VFS A Pressure Output Failed Low
P1911 VFS B Pressure Output Failed Low
P1912 VFS C Pressure Output Failed Low
P1913 Pressure Switch A Circuit Malfunction
P1914 Manually Shifted Automatic (MSA) Sw Circuit Malf
P1915 Reverse Switch Circuit Malfunction
P1916 High Clutch Drum Speed Sensor Malfunction
P1917 High Clutch Drum Speed Sensor Intermittent
P1918 Transmission Range Display Circuit Malfunction
C1091 Speed Wheel Sensor All Coherency Failure
C1095 ABS Hydraulic Pump Motor Circuit Failure
C1096 ABS Hydraulic Pump Motor Circuit Open
C1097 ABS Hydraulic Pump Motor Circuit Short To Ground
C1098 ABS Hydraulic Pump Motor Circuit Short To Battery
C1100 ABS Pump Switch Circuit Failure
C1101 ABS Hydraulic Valve Circuit Failure
C1102 ABS Acceleration Switch Circuit Failure
C1103 ABS Hydraulic Brake Switch Circuit Failure
C1104 Traction Control Active Lamp - Circuit Short to Battery
C1105 Traction Control Disable Lamp - Circuit Short to Battery
C1106 Traction Control Disable Switch Circuit Short to Battery
C1107 ABS Function Enabled Input Circuit Failure
C1109 Speed Control Actuator Assembly Cable Release Failure
C1110 ABS Power Relay Coil Circuit Failure
C1111 ABS Power Relay Coil Open Circuit
C1112 ABS Power Relay Coil Short Circuit To Ground
C1113 ABS Power Relay Coil Short Circuit To Battery
C1114 ABS Power Relay Output Short Circuit To Ground
C1115 ABS Power Relay Output Short Circuit To Battery
C1116 Starter Motor Circuit Failure
C1117 RPM Input Circuit Failure
C1123 Vehicle Speed Sensor Input Short to Battery
C1124 Input shaft speed signal missing/faulted
C1125 Brake Fluid Level Sensor Input Circuit Failure
C1126 Cruise Control Command Switch Assembly Circuit Failure
C1127 Cruise Control Deactivator Brake Switch Circuit Failure
C1132 Clutch position ckt short to ground
C1133 Clutch position ckt short to battery
C1134 Gear Shift position short to ground
C1135 Gear Shift position short to battery
C1136 Gear Select position short to ground
C1137 ECU is Defective
C1138 Gear Select position short to Battery
C1139 Wheel Speed Sensor Center Tone Ring Missing Tooth Fault
C1140 Hydraulic Base Brake Failure
C1141 Wheel Speed Sensor LF Tone Ring Tooth Missing Fault
C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault
C1143 Wheel Speed Sensor LR Tone Ring Tooth Missing Fault
C1144 Wheel Speed Sensor RR Tone Ring Tooth Missing Fault
C1145 Speed Wheel Sensor RF Input Circuit Failure
C1146 Speed Wheel Sensor RF Circuit Open
C1148 Speed Wheel Sensor RF Coherency Fault
C1149 Hydraulic Fluid Pressure/ Flow Circuit Failure
C1150 Two Speed Rear Axle Input Switch Circuit Short to Vbatt
C1155 Speed Wheel Sensor LF Input Circuit Failure
C1156 Speed Wheel Sensor LF Circuit Open
C1157 Park Brake Actuator Assembly Switch Applied Circuit Failure
C1158 Speed Wheel Sensor LF Coherency Fault
C1159 Hydraulic Fluid Pressure/ Flow Circuit Short to Gnd
C1161 Air Pressure Low Circuit Short to Gnd
C1162 Park Brake Switch # 2 Released Circuit Failure
C1163 Park Brake Switch # 2 Applied Circuit Short to Gnd
C1164 Park Brake Actuator Assembly Switch Circuit Failure
C1165 Speed Wheel Sensor RR Input Circuit Failure
C1166 Speed Wheel Sensor RR Input Open Circuit
C1167 Park Brake Actuator Assembly Switch Released Circuit Short to Gnd
C1168 Speed Wheel Sensor RR Coherency Fault
C1169 ABS Fluid Dumping Exceeds Maximum Timing
C1170 PRNDL Switch Circuit Failure
C1172 Park Brake Switch # 1 Applied Circuit Failure
C1173 Park Brake Switch # 1 Released Circuit Short to Gnd
C1174 Park Brake Switch # 2 Applied Circuit Failure
C1175 Speed Wheel Sensor LR Input Circuit Failure
C1176 Speed Wheel Sensor LR Circuit Open
C1177 Park Brake Actuator Assembly Switch Released Circuit Failure
C1178 Speed Wheel Sensor LR Coherency Fault
C1179 Speed Control Actuator Assembly Cable Slack Failure
C1180 Park Brake Valve Solenoid #1 Sense Input Circuit Failure
C1181 Park Brake Valve Solenoid #1 Sense Input Circuit Short to Gound
C1182 Park Lamp Flash Relay Circuit Failure
C1183 Park Lamp Flash Relay Circuit Short to Battery
C1184 ABS System Is Not Operational
C1185 ABS Power Relay Output Circuit Failure
C1186 ABS Power Relay Output Open Circuit
C1187 Brake Fluid Level Sensor Input Open Circuit
C1188 Brake Fluid Level Sensor Input Short Circuit To Battery
C1189 Brake Fluid Level Sensor Input Short Circuit To Ground
C1190 Speed Wheel Sensor LF Input Short Circuit To Battery
C1191 Speed Wheel Sensor LF Input Short Circuit To Ground
C1192 Speed Wheel Sensor RF Input Short Circuit To Battery
C1193 Speed Wheel Sensor RF Input Short Circuit To Ground
C1194 ABS Outlet Valve Coil LF Circuit Failure
C1195 ABS Outlet Valve Coil LF Circuit Open
C1196 ABS Outlet Valve Coil LF Circuit Short To Battery
C1197 ABS Outlet Valve Coil LF Circuit Short To Ground
C1198 ABS Inlet Valve Coil LF Circuit Failure
C1199 ABS Inlet Valve Coil LF Circuit Open
C1200 ABS Inlet Valve Coil LF Circuit Short To Battery
C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
C1202 ABS Outlet Valve Coil Rear Circuit Failure
C1203 ABS Outlet Valve Coil Rear Circuit Open
C1204 ABS Outlet Valve Coil Rear Circuit Short To Battery
C1205 ABS Outlet Valve Coil Rear Circuit Short To Ground
C1206 ABS Inlet Valve Coil Rear Circuit Failure
C1207 ABS Inlet Valve Coil Rear Circuit Open
C1208 ABS Inlet Valve Coil Rear Circuit Short To Battery
C1209 ABS Inlet Valve Coil Rear Circuit Short To Ground
C1210 ABS Outlet Valve Coil RF Circuit Failure
C1211 ABS Outlet Valve Coil RF Circuit Open
C1212 ABS Outlet Valve Coil RF Circuit Short To Battery
C1213 ABS Outlet Valve Coil RF Circuit Short To Ground
C1214 ABS Inlet Valve Coil RF Circuit Failure
C1215 ABS Inlet Valve Coil RF Circuit Open
C1216 ABS Inlet Valve Coil RF Circuit Short To Battery
C1217 ABS Inlet Valve Coil RF Circuit Short To Ground
C1218 Lamp ABS Warning Output Circuit Failure
C1219 Lamp ABS Warning Output Circuit Open
C1220 Lamp ABS Warning Output Circuit Short To Battery
C1221 Lamp ABS Warning Output Circuit Short To Ground
C1222 Speed Wheel Mismatch
C1223 Lamp Brake Warning Output Circuit Failure
C1224 Lamp Brake Warning Output Circuit Open
C1225 Lamp Brake Warning Output Circuit Short To Battery
C1226 Lamp Brake Warning Output Circuit Short To Ground
C1227 Speed Wheel Sensor LR Input Short Circuit To Battery
C1228 Speed Wheel Sensor LR Input Short Circuit To Ground
C1229 Speed Wheel Sensor Rear Center Coherency Fault
C1230 Speed Wheel Sensor Rear Center Input Circuit Failure
C1231 Speed Wheel Sensor Rear Center Circuit Open
C1232 Speed Wheel Sensor Rear Center Input Short Circuit To Battery
C1233 Speed Wheel LF Input Signal Missing
C1234 Speed Wheel RF Input Signal Missing
C1235 Speed Wheel RR Input Signal Missing
C1236 Speed Wheel LR Input Signal Missing
C1237 Speed Wheel Rear Input Signal Missing
C1238 ABS Hydraulic Pressure Differential Switch Input Circuit Failure
C1239 ABS Hydraulic Pressure Differential Switch Input Open Circuit
C1240 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Battery
C1241 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Ground
C1242 ABS Outlet Valve Coil LR Circuit Failure
C1243 ABS Outlet Valve Coil LR Circuit Open
C1244 ABS Outlet Valve Coil LR Circuit Short To Battery
C1245 ABS Outlet Valve Coil LR Circuit Short To Ground
C1246 ABS Outlet Valve Coil RR Circuit Failure
C1247 ABS Outlet Valve Coil RR Circuit Open
C1248 ABS Outlet Valve Coil RR Circuit Short To Battery
C1249 ABS Outlet Valve Coil RR Circuit Short To Ground
C1250 ABS Inlet Valve Coil LR Circuit Failure
C1251 ABS Inlet Valve Coil LR Circuit Open
C1252 ABS Inlet Valve Coil LR Circuit Short To Battery
C1253 ABS Inlet Valve Coil LR Circuit Short To Ground
C1254 ABS Inlet Valve Coil RR Circuit Failure
C1255 ABS Inlet Valve Coil RR Circuit Open
C1256 ABS Inlet Valve Coil RR Circuit Short To Battery
C1257 ABS Inlet Valve Coil RR Circuit Short To Ground
C1258 Speed Wheel LF Comparison Failure
C1259 Speed Wheel RF Comparison Failure
C1260 Speed Wheel RR Comparison Failure
C1261 Speed Wheel LR Comparison Failure
C1262 Lamp Warning Relay Circuit Failure
C1263 Lamp Warning Relay Circuit Open
C1264 Lamp Warning Relay Circuit Short To Battery
C1265 Lamp Warning Relay Circuit Short To Ground
C1266 ABS Valve Power Relay Circuit Failure
C1267 ABS Functions Temporarily Disabled
C1268 Motor Relay # 1 Circuit Failure
C1269 Motor Relay # 1 Circuit Short to Battery
C1270 Motor # 1 Input Circuit Failure
C1271 Motor # 1 Input Circuit Short to Gnd
C1272 Motor # 2 Input Circuit Failure
C1273 Motor # 2 Input Circuit Short to Vbat
C1274 Solenoid Relay # 1 Circuit Failure
C1275 Solenoid Relay # 1 Circuit Short to Vbatt
C1276 Park Brake Actuator Assembly Switch Applied Circuit Short to Gnd
C1277 STEERING Wheel Angle 1and 2 Circuit Failure
C1278 STEERING Wheel Angle 1and 2 Signal Faulted
C1279 Yaw Rate Sensor circuit Failure
C1280 Yaw Rate Sensor Signal Fault
C1281 Lateral Accelerometer circuit Failure
C1282 Lateral Accelerometer Signal Fault
C1283 Switch Test Signal Failure
C1284 Oil Pressure Switch Failure
C1285 Booster Solenoid circuit Failure
C1286 Booster Mechanical Failure
C1287 Booster Pedal Force switch circuit Failure
C1288 Pressure Transducer Main / Primary Input Circuit Failure
C1289 Pressure Transducer Redundant / Secondary Input Circuit Failure
C1400 Traction Control Valve RF Circuit Failure
C1401 Traction Control Valve RF Circuit Open
C1402 Traction Control Valve RF Circuit Short To Ground
C1403 Traction Control Valve RF Circuit Short To Battery
C1404 Traction Control Valve Rear Circuit Failure
C1405 Traction Control Valve Rear Circuit Open
C1406 Traction Control Valve Rear Circuit Short To Ground
C1407 Traction Control Valve Rear Circuit Short To Battery
C1410 Traction Control Valve LF Circuit Failure
C1411 Traction Control Valve LF Circuit Open
C1412 Traction Control Valve LF Circuit Short To Ground
C1413 Traction Control Valve LF Circuit Short To Battery
C1414 Incorrect Module Design Level
C1415 Incorrect Module Configuration
C1416 Damper RF Circuit Short To Battery
C1417 Damper RF Circuit Short to Ground
C1418 Damper RF Circuit Failure
C1419 Damper RF Circuit Open
C1420 Hydraulic Fluid Pressure/ Flow Circuit Short to Vbatt
C1421 Damper LF Circuit Short To Battery
C1422 Damper LF Circuit Short to Ground
C1423 Damper LF Circuit Failure
C1424 Damper LF Circuit Open
C1425 Damper RR Circuit Short to Ground
C1426 Damper RR Circuit Short To Battery
C1427 Damper RR Circuit Open
C1428 Damper RR Circuit Failure
C1429 Input-shaft-speed input circuit failure
C1430 Damper LR Circuit Open
C1431 Damper LR Circuit Short To Battery
C1432 Damper LR Circuit Short to Ground
C1433 Damper LR Circuit Failure
C1435 Accelerometer Rear Circuit Failure
C1436 Accelerometer Rear Circuit Signal Is Not Sensed
C1437 Accelerometer Rear Circuit Short To Ground
C1438 Accelerometer Rear Circuit Short To Battery
C1439 Vehicle Acceleration EEC-IV Circuit Failure
C1440 Pressure Transducer Main / Primary signal Faulted
C1441 Steering Phase A Circuit Signal Is Not Sensed
C1442 Steering Phase B Circuit Signal Is Not Sensed
C1443 Steering Phase A Circuit Short To Ground
C1444 Steering Phase B Circuit Short To Ground
C1445 Speed Vehicle Signal Circuit Failure
C1446 Brake Switch Circuit Failure
C1447 Traction Control Module Request Circuit Failure
C1448 Lamp Adaptive Damping Warning Circuit Failure
C1449 Traction Control Motor Coherency Fault
C1450 Traction Control Motor Circuit Failure
C1451 Traction Control Motor Circuit Open
C1452 Traction Control Motor Circuit Short to Battery
C1453 Traction Control Motor Circuit Short to Ground
C1454 Front Lateral Accelerometer Circuit Failure
C1455 Accelerometer Front Circuit Failure
C1456 Accelerometer Front Circuit Is Not Sensed
C1457 Accelerometer Front Circuit Short To Ground
C1458 Accelerometer Front Circuit Short To Battery
C1459 Adaptive Mode Switch Circuit Failure
C1460 Vehicle Accelerometer Power Circuit Failure
C1461 Vehicle Accelerometer Power Circuit Short to Battery
C1462 Left Front Vertical Accelerometer Circuit Failure
C1463 Right Front Vertical Accelerometer Circuit Failure
C1464 Pressure Transducer Redundant / Secondary Signal Faulted
C1465 Damper High Side Front Circuit Short To Battery
C1466 Damper Circuit Failure
C1467 Damper High Side Rear Circuit Short To Battery
C1468 Damper Low Side Front Circuit Failure
C1469 Damper Low Side Rear Circuit Failure
C1495 Traction Control Motor Potentiometer Circuit Failure
C1496 Traction Control Motor Potentiometer Circuit Open
C1497 Traction Control Motor Potentiometer Circuit Short to Battery
C1498 Traction Control Motor Potentiometer Circuit Short to Ground
C1499 Transfer Case Contact Plate "A" Encoder Circuit Failure
C1500 Transfer Case Contact Plate "B" Encoder Circuit Failure
C1501 Transfer Case Contact Plate "C" Encoder Circuit Failure
C1502 Transfer Case Contact Plate "D" Encoder Circuit Failure
C1503 Dynamic Stability Control Left Front Valve Malfunction
C1504 Dynamic Stability Control Right Front Valve Malfunction
C1505 Dynamic Stability Control Left Rear Valve Malfunction
C1506 Dynamic Stability Control Right Rear Valve Malfunction
C1507 Traction Control of Brake Exceeds Time-Out
C1508 Traction Control of Engine Exceeds Time-Out
C1510 Right Front Wheel Pressure Reduction Performance Problem
C1511 Left Front Wheel Pressure Reduction Performance Problem
C1512 Right Rear Wheel Pressure Reduction Performance Problem
C1513 Left rear Wheel Pressure Reduction Performance Problem
C1699 Left Rear Sensor Circuit Short to Vbat
C1700 Left Rear Sensor Circuit Failure
C1701 Left Rear Sensor Circuit Fault
C1702 RightRear Sensor Circuit Short to Vbat
C1703 Right Rear Sensor Circuit Failure
C1704 Right Rear Sensor Circuit Fault
C1705 Left Rear Center Sensor Circuit Short to Vbat
C1706 Left Rear Center Sensor Circuit Failure
C1707 Left Rear Center Sensor Circuit Fault
C1708 Right Rear Center Sensor Circuit Short to Vbat
C1709 Right Rear Center Sensor Circuit Failure
C1710 Right Rear Center Sensor Circuit Fault
C1711 Left Front Sensor Circuit Short to Vbat
C1712 Left Front Sensor Circuit Failure
C1713 Left Front Sensor Circuit Fault
C1714 Right Front Sensor Circuit Short to Vbat
C1715 Right Front Sensor Circuit Failure
C1716 Right Front Sensor Circuit Fault
C1717 Left Front Center Sensor Circuit Short to Vbat
C1718 Left Front Center Sensor Circuit Failure
C1719 Left Front Center Sensor Circuit Fault
C1721 Air Suspension Height Sensor Power Circuit Open
C1722 Air Suspension Height Sensor Power Circuit Short To Battery
C1723 Air Suspension Height Sensor Power Circuit Short To Ground
C1724 Air Suspension Height Sensor Power Circuit Failure
C1725 Air Suspension Front Pneumatic Failure
C1726 Air Suspension Rear Pneumatic Failure
C1727 Air Suspension Reservoir Pneumatic Failure
C1728 Transfer Case unable to transition between 2H and 4H
C1729 Transfer Case unable to transition between 4H and 4L
C1730 Reference Voltage Out of Range (+5 v)
C1731 Air Suspension LF Corner Up Timeout
C1732 Air Suspension LF Corner Down Timeout
C1733 Air Suspension RF Corner Up Timeout
C1734 Air Suspension RF Corner Down Timeout
C1735 Air Suspension LR Corner Up Timeout
C1736 Air Suspension LR Corner Down Timeout
C1737 Air Suspension RR Corner Up Timeout
C1738 Air Suspension RR Corner Down Timeout
C1739 Right Front Center Sensor Circuit Short to Vbat
C1740 Right Front Center Sensor Circuit Failure
C1741 Right Front Center Sensor Circuit Fault
C1742 Rear Sounder Circuit Failure
C1743 Rear Sounder Circuit Short to Vbatt
C1744 Front Sounder Circuit Failure
C1745 Front Sounder Circuit Short to Vbatt
C1748 Switch input Circuit Short to Gnd
C1749 Trailer Input Circuit Failure
C1750 Accelerator Position Sensor Out of Range
C1751 Vehicle Speed Sensor # 1 Output Circuit Short to Vbatt
C1752 Vehicle Speed Sensor # 1 Output Circuit Short to Gnd
C1753 Hydraulic Clutch Actuator Valve Signal Fault
C1754 Hydraulic Clutch Actuator Valve Circuit Failure
C1755 Power Limit Shutdown Fault
C1756 Air Suspension Front Height Sensor High (SE) Signal Circuit Failure
C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open
C1758 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Battery
C1759 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Ground
C1760 Air Suspension Rear Height Sensor High (SE) Signal Circuit Failure
C1761 Air Suspension Rear Height Sensor High (SE) Signal Circuit Open
C1762 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Battery
C1763 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Ground
C1765 Air Suspension Rear Height Sensor Low Signal Circuit Failure
C1766 Air Suspension Rear Height Sensor Low Signal Circuit Open
C1767 Air Suspension Rear Height Sensor Low Signal Circuit Short To Battery
C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short To Ground
C1770 Air Suspension Vent Solenoid Output Circuit Failure
C1771 Air Suspension Vent Solenoid Output Circuit Open
C1772 Air Suspension Vent Solenoid Output Circuit Short To Battery
C1773 Air Suspension Vent Solenoid Output Circuit Short To Ground
C1774 Coolant Temp Out of Range
C1775 DC-DC Converter Failure
C1776 Heater System Failure
C1777 Vacuum Pressure Circuit Failure
C1778 Power Steering Failure
C1779 Blower Switch Failure
C1780 Temperature Select Failure
C1781 Engine Coolant Temperature Signal Missing/Fault
C1790 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Failure
C1791 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Open
C1792 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Battery
C1793 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Ground
C1795 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Failure
C1796 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Open
C1797 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Battery
C1798 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Ground
C1800 Air Suspension Reservoir Solenoid Circuit Failure
C1805 Mismatched PCM and/or ABS-TC Module
C1813 Air Suspension LR Vent Request Exceeded Max Timing
C1814 Air Suspension RR Vent Request Exceeded Max Timing
C1818 Air Suspension LR Air Compress Request Exceeded Max Timing
C1819 Air Suspension RR Air Compress Request Exceeded Max Timing
C1820 Air Suspension RF Air Compress Request Exceeded Max Timing
C1830 Air Suspension Compressor Relay Circuit Failure
C1831 Air Suspension Compressor Relay Circuit Open
C1832 Air Suspension Compressor Relay Circuit Short To Battery
C1833 Air Suspension Compressor Relay Circuit Short To Ground
C1834 Gauge Drive Current Fault
C1835 Current Sense Circuit Failure
C1836 Battery Temp out of Range
C1837 Battery Heater Circuit Failure
C1838 Charging System Fault
C1839 Leakage Fault
C1840 Air Suspension Disable Switch Circuit Failure
C1841 Air Suspension Disable Switch Circuit Open
C1842 Air Suspension Disable Switch Circuit Short To Battery
C1843 Air Suspension Disable Switch Circuit Short To Ground
C1844 Air Suspension Secondary Front Inflator Solenoid Output Circuit Failure
C1845 Air Suspension Front Inflator Solenoid Output Circuit Failure
C1846 Air Suspension Front Inflator Solenoid Output Circuit Open
C1847 Air Suspension Front Inflator Solenoid Output Circuit Short To Battery
C1848 Air Suspension Front Inflator Solenoid Output Circuit Short To Ground
C1849 Master Cylinder Pressure Out of Range
C1850 Air Suspension Warning Lamp Circuit Failure
C1851 Air Suspension Warning Lamp Circuit Open
C1852 Air Suspension Warning Lamp Circuit Short To Battery
C1853 Air Suspension Warning Lamp Circuit Short To Ground
C1854 Motor Temperature Out of Range
C1855 Acceleration Position Sensor Conflict
C1856 Traction Motor Encoder circuit Failure
C1859 PRNDL Input #2 Circuit Failure
C1860 PRNDL Input #3 Circuit Failure
C1861 PRNDL Input #4 Circuit Failure
C1862 Contactor Circuit Failure
C1863 External Charging Fault
C1864 Battery Module Fault
C1865 Air Suspension Rear Inflator Solenoid Output Circuit Failure
C1866 Air Suspension Rear Inflator Solenoid Output Circuit Open
C1867 Air Suspension Rear Inflator Solenoid Output Circuit Short To Battery
C1868 Air Suspension Rear Inflator Solenoid Output Circuit Short To Ground
C1869 Air Suspension Gate Solenoid Output Circuit Failure
C1870 Air Suspension Gate Solenoid Output Circuit Open
C1871 Air Suspension Gate Solenoid Output Circuit Short To Battery
C1872 Air Suspension Gate Solenoid Output Circuit Short To Ground
C1873 Air Suspension RF Air Spring Solenoid Output Circuit Failure
C1874 Air Suspension RF Air Spring Solenoid Output Circuit Open
C1875 Air Suspension RF Air Spring Solenoid Output Circuit Short To Battery
C1876 Air Suspension RF Air Spring Solenoid Output Circuit Short To Ground
C1877 Air Suspension LF Air Spring Solenoid Output Circuit Failure
C1878 Air Suspension LF Air Spring Solenoid Output Circuit Open
C1879 Air Suspension LF Air Spring Solenoid Output Circuit Short To Battery
C1880 Air Suspension LF Air Spring Solenoid Output Circuit Short To Ground
C1881 Air Suspension RF Height Sensor Circuit Failure
C1882 Air Suspension RF Height Sensor Circuit Open
C1883 Air Suspension RF Height Sensor Circuit Short To Battery
C1884 Air Suspension RF Height Sensor Circuit Short To Ground
C1885 Air Suspension RR Height Sensor Circuit Failure
C1886 Air Suspension RR Height Sensor Circuit Open
C1887 Air Suspension RR Height Sensor Circuit Short To Battery
C1888 Air Suspension RR Height Sensor Circuit Short To Ground
C1889 Air Suspension LF Height Sensor Circuit Failure
C1890 Air Suspension LF Height Sensor Circuit Open
C1891 Air Suspension LF Height Sensor Circuit Short To Battery
C1892 Air Suspension LF Height Sensor Circuit Short To Ground
C1893 Air Suspension LR Height Sensor Circuit Failure
C1894 Air Suspension LR Height Sensor Circuit Open
C1895 Air Suspension LR Height Sensor Circuit Short To Battery
C1896 Air Suspension LR Height Sensor Circuit Short To Ground
C1897 Steering VAPS II Circuit Loop Failure
C1898 Steering VAPS II Circuit Loop Open
C1899 Steering VAPS II Circuit Loop Short To Battery
C1900 Steering VAPS II Circuit Loop Short To Ground
C1901 Ride Control RR Shock Actuator Circuit Failure
C1902 Ride Control RR Shock Actuator Circuit Open
C1903 Ride Control RR Shock Actuator Circuit Short To Battery
C1904 Ride Control RR Shock Actuator Circuit Short To Ground
C1905 Ride Control LR Shock Actuator Circuit Failure
C1906 Ride Control LR Shock Actuator Circuit Open
C1907 Ride Control LR Shock Actuator Circuit Short To Battery
C1908 Ride Control LR Shock Actuator Circuit Short To Ground
C1909 Ride Control RF Shock Actuator Circuit Failure
C1910 Ride Control RF Shock Actuator Circuit Open
C1911 Ride Control RF Shock Actuator Circuit Short To Battery
C1912 Ride Control RF Shock Actuator Circuit Short To Ground
C1913 Ride Control LF Shock Actuator Circuit Failure
C1914 Ride Control LF Shock Actuator Circuit Open
C1915 Ride Control LF Shock Actuator Circuit Short To Battery
C1916 Ride Control LF Shock Actuator Circuit Short To Ground
C1917 Steering EVO Out-of-Range Fault
C1918 Air Suspension Ride Height Select Switch Circuit Failure
C1920 Led #1 Circuit Failure
C1921 VAPS Solenoid Actuator Output Circuit Failure
C1922 VAPS Solenoid Actuator Output Circuit Open
C1923 VAPS Solenoid Actuator Output Circuit Short To Battery
C1924 VAPS Solenoid Actuator Output Circuit Short To Ground
C1925 VAPS Solenoid Actuator Return Circuit Failure
C1926 VAPS Solenoid Actuator Return Circuit Open
C1927 VAPS Solenoid Actuator Return Circuit Short To Battery
C1928 VAPS Solenoid Actuator Return Circuit Short To Ground
C1929 Air Suspension Front Compressor Relay Circuit Failure
C1930 Air Suspension Front Compressor Relay Circuit Open
C1931 Air Suspension Front Compressor Relay Circuit Short To Battery
C1932 Air Suspension Front Compressor Relay Circuit Short To Ground
C1933 Solenoid Current Out Of Range
C1934 HPU (Hydraulic Pump Unit) Pressurisation Failure
C1935 Chime Circuit Failure
C1936 Hydraulic Pump Relay Circuit Failure
C1937 Steering Wheel Angle Sensor Offset Failure
C1938 Invalid Steering Wheel Angle Sensor ID
C1939 Brake Pressure Switch Input Circuit Failure
C1940 Brake Pressure Switch Mechanical Failure
C1942 Unrecognized Powertrain Configuration
C1943 Airbag Deployment Indication Input Fault
C1944 Gauge Driver Circuit Fault
C1945 Park Switch Indicates Park with Vehicle Moving
C1946 Seat Track Position Switch Circuit Open
C1947 Seat Track Position Switch Circuit Short to Ground
C1948 Seat Track Position Switch Circuit Resistance Out of Range
C1949 Accelerometer Sensor Circuit Open
C1950 Accelerometer Sensor Circuit Failure
C1951 Lateral Accelerometer Sensor Circuit Open
C1952 Yaw Rate Sensor Circuit Open
C1953 Master Cylinder Pressure Sensor Circuit Open
C1954 Master Cylinder Pressure Sensor Circuit Failure
C1955 Steering Angle Sensor Circuit Open
C1956 Steering Angle Sensor Circuit Failure
C1957 Dynamic Stability Control Valve RF Circuit Failure
C1958 Dynamic Stability Control Valve LF Circuit Failure
C1959 Lateral Accelerometer Sensor Circuit Failure
C1960 Driver Brake Apply Circuit Fault
C1961 Park Lamp Relay Coil Circuit Failure
C1962 Park Lamp Relay Coil Short to Battery
C1963 Stability Control Inhibit Warning
B1200 Climate Control Pushbutton Circuit Failure
B1201 Fuel Sender Circuit Failure
B1202 Fuel Sender Circuit Open
B1203 Fuel Sender Circuit Short To Battery
B1204 Fuel Sender Circuit Short To Ground
B1205 EIC Switch-1 Assembly Circuit Failure
B1206 EIC Switch-1 Assembly Circuit Open
B1207 EIC Switch-1 Assembly Circuit Short To Battery
B1208 EIC Switch-1 Assembly Circuit Short To Ground
B1209 EIC Switch-2 Assembly Circuit Failure
B1210 EIC Switch-2 Assembly Circuit Open
B1211 EIC Switch-2 Assembly Circuit Short To Battery
B1212 EIC Switch-2 Assembly Circuit Short To Ground
B1213 Anti-Theft Number of Programmed Keys Is Below Minimum
B1214 Running Board Lamp Circuit Failure
B1215 Running Board Lamp Circuit Short to Battery
B1216 Emergency & Road Side Assistance Switch Circuit Short to Ground
B1217 Horn Relay Coil Circuit Failure
B1218 Horn Relay Coil Circuit Short to Vbatt
B1219 Fuel Tank Pressure Sensor Circuit Failure
B1220 Fuel Tank Pressure Sensor Circuit Open
B1222 Fuel Temperature Sensor #1 Circuit Failure
B1223 Fuel Temperature Sensor #1 Circuit Open
B1224 Fuel Temperature Sensor #1 Circuit Short to Battery
B1225 Fuel Temperature Sensor #1 Circuit Short to Ground
B1226 Fuel Temperature Sensor #2 Circuit Failure
B1227 Fuel Temperature Sensor #2 Circuit Open
B1228 Fuel Temperature Sensor #2 Circuit Short to Battery
B1229 Fuel Temperature Sensor #2 Circuit Short to Ground
B1231 Longitudinal Acceleration Threshold Exceeded
B1232 See Manufacturer
B1233 Glass Break Sensor Failure
B1234 Mirror Switch Invalid Code
B1235 Window Feedback Failure
B1236 Window Feedback Loss of Signal
B1237 Window Feedback Out of Range
B1238 Over Temperature Fault
B1239 Air Flow Blend Door Driver Circuit Failure
B1240 Wiper Washer Rear Pump Relay Circuit Failure
B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery
B1242 Air Flow Recirculation Door Driver Circuit Failure
B1243 Express Window Down Switch Circuit Short to Battery
B1244 Wiper Rear Motor Run Relay Circuit Failure
B1245 Wiper Rear Motor Run Relay Circuit Short to Battery
B1246 Dim Panel Potentiometer Switch Circuit Failure
B1247 Panel Dim Switch Circuit Open
B1248 Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground
B1249 Blend Door Failure
B1250 Air Temperature Internal Sensor Circuit Failure
B1251 Air Temperature Internal Sensor Circuit Open
B1252 Air Temperature Internal Sensor Circuit Short To Battery
B1253 Air Temperature Internal Sensor Circuit Short To Ground
B1254 Air Temperature External Sensor Circuit Failure
B1255 Air Temperature External Sensor Circuit Open
B1256 Air Temperature External Sensor Circuit Short To Battery
B1257 Air Temperature External Sensor Circuit Short To Ground
B1258 Solar Radiation Sensor Circuit Failure
B1259 Solar Radiation Sensor Circuit Open
B1260 Solar Radiation Sensor Circuit Short To Battery
B1261 Solar Radiation Sensor Circuit Short To Ground
B1262 Servo Motor Defrost Circuit Failure
B1263 Servo Motor Vent Circuit Failure
B1264 Servo Motor Foot Circuit Failure
B1265 Servo Motor Coolair Bypass Circuit Failure
B1266 Servo Motor Airintake Left Circuit Failure
B1267 Servo Motor Airintake Right Circuit Failure
B1268 Servo Motor Potentiometer Defrost Circuit Failure
B1269 Servo Motor Potentiometer Defrost Circuit Open
B1270 Servo Motor Potentiometer Defrost Circuit Short To Battery
B1271 Servo Motor Potentiometer Defrost Circuit Short To Ground
B1272 Servo Motor Potentiometer Vent Circuit Failure
B1273 Servo Motor Potentiometer Vent Circuit Open
B1274 Servo Motor Potentiometer Vent Circuit Short To Battery
B1275 Servo Motor Potentiometer Vent Circuit Short To Ground
B1276 Servo Motor Potentiometer Foot Circuit Failure
B1277 Servo Motor Potentiometer Foot Circuit Open
B1278 Servo Motor Potentiometer Foot Circuit Short To Battery
B1279 Servo Motor Potentiometer Foot Circuit Short To Ground
B1280 Servo Motor Potentiometer Coolair Circuit Failure
B1281 Servo Motor Potentiometer Coolair Circuit Open
B1282 Servo Motor Potentiometer Coolair Circuit Short To Battery
B1283 Servo Motor Potentiometer Coolair Circuit Short To Ground
B1284 Servo Motor Potentiometer Airintake Left Circuit Failure
B1285 Servo Motor Potentiometer Airintake Left Circuit Open
B1286 Servo Motor Potentiometer Airintake Left Circuit Short To Battery
B1287 Servo Motor Potentiometer Airintake Left Circuit Short To Ground
B1288 Servo Motor Potentiometer Airintake Right Circuit Failure
B1289 Servo Motor Potentiometer Airintake Right Circuit Open
B1290 Servo Motor Potentiometer Airintake Right Circuit Short To Battery
B1291 Servo Motor Potentiometer Airintake Right Circuit Short To Ground
B1292 Battery Power Relay Circuit Failure
B1293 Battery Power Relay Circuit Open
B1294 Battery Power Relay Circuit Short To Battery
B1295 Battery Power Relay Circuit Short To Ground
B1296 Power Supply Sensor Circuit Failure
B1297 Power Supply Sensor Circuit Open
B1298 Power Supply Sensor Circuit Short To Battery
B1299 Power Supply Sensor Circuit Short To Ground
B1300 Power Door Lock Circuit Failure
B1301 Power Door Lock Circuit Open
B1302 Accessory Delay Relay Coil Circuit Failure
B1303 Accessory Delay Relay Coil Circuit Open
B1304 Accessory Delay Relay Coil Circuit Short To Battery
B1305 Accessory Delay Relay Coil Circuit Short To Ground
B1306 Oil Level Switch Circuit Open
B1307 Oil Level Switch Circuit Short To Battery
B1308 Oil Level Switch Circuit Short To Ground
B1309 Power Door Lock Circuit Short To Ground
B1310 Power Door Unlock Circuit Failure
B1311 Power Door Unlock Circuit Open
B1312 Lamp Headlamp Input Circuit Short To Battery
B1313 Battery Saver Relay Coil Circuit Failure
B1314 Battery Saver Relay Coil Circuit Open
B1315 Battery Saver Relay Coil Circuit Short To Battery
B1316 Battery Saver Relay Coil Circuit Short To Ground
B1317 Battery Voltage High
B1318 Battery Voltage Low
B1319 Driver Door Ajar Circuit Failure
B1320 Driver Door Ajar Circuit Open
B1321 Driver Door Ajar Circuit Short To Battery
B1322 Driver Door Ajar Circuit Short To Ground
B1323 Door Ajar Lamp Circuit Failure
B1324 Door Ajar Lamp Circuit Open
B1325 Door Ajar Lamp Circuit Short To Battery
B1326 Door Ajar Lamp Circuit Short To Ground
B1327 Passenger Door Ajar Circuit Failure
B1328 Passenger Door Ajar Circuit Open
B1329 Passenger Door Ajar Circuit Short To Battery
B1330 Passenger Door Ajar Circuit Short To Ground
B1331 Decklid Ajar Rear Door Circuit Failure
B1332 Decklid Ajar Rear Door Circuit Open
B1333 Decklid Ajar Rear Door Circuit Short To Battery
B1334 Decklid Ajar Rear Door Circuit Short To Ground
B1335 Door Ajar RR Circuit Failure
B1336 Door Ajar RR Circuit Open
B1337 Door Ajar RR Circuit Short To Battery
B1338 Door Ajar RR Circuit Short To Ground
B1339 Chime Input Request Circuit Short To Battery
B1340 Chime Input Request Circuit Short To Ground
B1341 Power Door Unlock Circuit Short To Ground
B1342 ECU Is Defective
B1343 Heated Backlite Input Circuit Failure
B1344 Heated Backlite Input Circuit Open
B1345 Heated Backlite Input Circuit Short To Ground
B1346 Heated Backlite Input Circuit Short To Battery
B1347 Heated Backlite Relay Circuit Failure
B1348 Heated Backlite Relay Circuit Open
B1349 Heated Backlite Relay Short To Battery
B1350 Heated Backlite Relay Short To Ground
B1351 Ignition Key-In Circuit Short To Battery
B1352 Ignition Key-In Circuit Failure
B1353 Ignition Key-In Circuit Open
B1354 Ignition Key-In Circuit Short To Ground
B1355 Ignition Run Circuit Failure
B1356 Ignition Run Circuit Open
B1357 Ignition Run Circuit Short To Battery
B1358 Ignition Run Circuit Short To Ground
B1359 Ignition Run/Acc Circuit Failure
B1360 Ignition Run/Acc Circuit Open
B1361 Ignition Run/Acc Circuit Short To Battery
B1362 Ignition Run/Acc Circuit Short To Ground
B1363 Ignition Start Circuit Failure
B1364 Ignition Start Circuit Open
B1365 Ignition Start Circuit Short To Battery
B1366 Ignition Start Circuit Short To Ground
B1367 Ignition Tach Circuit Failure
B1368 Ignition Tach Circuit Open
B1369 Ignition Tach Circuit Short To Battery
B1370 Ignition Tach Circuit Short To Ground
B1371 Illuminated Entry Relay Circuit Failure
B1372 Illuminated Entry Relay Circuit Open
B1373 Illuminated Entry Relay Short To Battery
B1374 Illuminated Entry Relay Short To Ground
B1375 Oil Change Lamp Circuit Open
B1376 Oil Change Lamp Circuit Short To Battery
B1377 Oil Change Lamp Circuit Failure
B1378 Oil Change Lamp Circuit Short To Ground
B1379 Oil Change Reset Button Circuit Short To Ground
B1380 Oil Change Reset Button Circuit Failure
B1381 Oil Change Reset Button Circuit Open
B1382 Oil Change Reset Button Circuit Short To Battery
B1383 Oil Level Lamp Circuit Short To Battery
B1384 Oil Level Lamp Circuit Failure
B1385 Oil Level Lamp Circuit Open
B1386 Oil Level Lamp Circuit Short To Ground
B1387 Oil Temperature Sensor Circuit Open
B1388 Oil Temperature Sensor Circuit Short To Battery
B1389 Oil Temperature Sensor Circuit Failure
B1390 Oil Temperature Sensor Circuit Short To Ground
B1391 Oil Level Switch Circuit Failure
B1392 Power Door Memory Lock Relay Circuit Failure
B1393 Power Door Memory Lock Relay Circuit Open
B1394 Power Door Memory Lock Relay Circuit Short To Battery
B1395 Power Door Memory Lock Relay Circuit Short To Ground
B1396 Power Door Lock Circuit Short To Battery
B1397 Power Door Unlock Circuit Short To Battery
B1398 Driver Power Window One Touch Window Relay Circuit Failure
B1399 Driver Power Window One Touch Window Relay Circuit Open
B1400 Driver Power Window One Touch Window Relay Circuit Short To Battery
B1401 Driver Power Window One Touch Window Relay Circuit Short To Ground
B1402 Driver Power Window Down Switch Circuit Failure
B1403 Driver Power Window Up Switch Circuit Failure
B1404 Driver Power Window Down Circuit Open
B1405 Driver Power Window Down Circuit Short To Battery
B1406 Driver Power Window Down Circuit Short To Ground
B1407 Driver Power Window Up Circuit Open
B1408 Driver Power Window Up Circuit Short To Battery
B1409 Driver Power Window Up Circuit Short To Ground
B1410 Driver Power Window Motor Circuit Failure
B1411 Driver Power Window Motor Circuit Open
B1412 Driver Power Window Motor Circuit Short To Battery
B1413 Driver Power Window Motor Circuit Short To Ground
B1414 Power Window LR Motor Circuit Failure
B1415 Power Window LR Motor Circuit Open
B1416 Power Window LR Motor Circuit Short To Battery
B1417 Power Window LR Motor Circuit Short To Ground
B1418 Passenger Power Window Motor Circuit Failure
B1419 Passenger Power Window Motor Circuit Open
B1420 Passenger Power Window Motor Circuit Short To Battery
B1421 Passenger Power Window Motor Circuit Short To Ground
B1422 Power Window RR Motor Circuit Failure
B1423 Power Window RR Motor Circuit Open
B1424 Power Window RR Motor Circuit Short To Battery
B1425 Power Window RR Motor Circuit Short To Ground
B1426 Lamp Seat Belt Circuit Short To Battery
B1427 Lamp Seat Belt Circuit Open
B1428 Lamp Seat Belt Circuit Failure
B1429 Lamp Seat Belt Circuit Short To Ground
B1430 Seat Belt Switch Circuit Short To Ground
B1431 Wiper Brake/Run Relay Circuit Failure
B1432 Wiper Brake/Run Relay Circuit Short To Battery
B1433 Wiper Brake/Run Relay Circuit Short To Ground
B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure
B1435 Wiper Hi/Low Speed Relay Coil Circuit Open
B1436 Wiper Hi/Low Speed Relay Coil Circuit Short To Battery
B1437 Wiper Hi/Low Speed Relay Coil Circuit Short To Ground
B1438 Wiper Mode Select Switch Circuit Failure
B1439 Wiper Mode Select Switch Circuit Open
B1440 Wiper Mode Select Switch Circuit Short To Battery
B1441 Wiper Mode Select Switch Circuit Short To Ground
B1442 Door Handle Switch Circuit Failure
B1443 Door Handle Switch Circuit Open
B1444 Door Handle Switch Circuit Short To Battery
B1445 Door Handle Switch Circuit Short To Ground
B1446 Wiper Park Sense Circuit Failure
B1447 Wiper Park Sense Circuit Open
B1448 Wiper Park Sense Circuit Short To Battery
B1449 Wiper Park Sense Circuit Short To Ground
B1450 Wiper Wash/Delay Switch Circuit Failure
B1451 Wiper Wash/Delay Switch Circuit Open
B1452 Wiper Wash/Delay Switch Circuit Short To Battery
B1453 Wiper Wash/Delay Switch Circuit Short To Ground
B1454 Wiper Washer Fluid Lamp Circuit Failure
B1455 Wiper Washer Fluid Lamp Circuit Open
B1456 Wiper Washer Fluid Lamp Circuit Short To Battery
B1457 Wiper Washer Fluid Lamp Circuit Short To Ground
B1458 Wiper Washer Pump Motor Relay Circuit Failure
B1459 Wiper Washer Pump Motor Relay Coil Circuit Open
B1460 Wiper Washer Pump Motor Relay Coil Circuit Short To Battery
B1461 Wiper Washer Pump Motor Relay Coil Circuit Short To Ground
B1462 Seat Belt Switch Circuit Failure
B1463 Seat Belt Switch Circuit Open
B1464 Seat Belt Switch Circuit Short To Battery
B1465 Wiper Brake/Run Relay Circuit Open
B1466 Wiper Hi/Low Speed Not Switching
B1467 Wiper Hi/Low Speed Circuit Motor Short To Battery
B1468 Chime Input Request Circuit Failure
B1469 Chime Input Request Circuit Open
B1470 Lamp Headlamp Input Circuit Failure
B1471 Lamp Headlamp Input Circuit Open
B1472 Lamp Headlamp Input Circuit Short To Ground
B1473 Wiper Low Speed Circuit Motor Failure
B1474 Battery Saver Power Relay Circuit Short To Battery
B1475 Accessory Delay Relay Contact Short To Battery
B1476 Wiper High Speed Circuit Motor Failure
B1477 Wiper Hi/Low Circuit Motor Short To Ground
B1478 Power Window One Touch Up/Down Activated Simultaneously
B1479 Wiper Washer Fluid Level Sensor Circuit Failure
B1480 Wiper Washer Fluid Level Sensor Circuit Open
B1481 Wiper Washer Fluid Level Sensor Circuit Short To Battery
B1482 Wiper Washer Fluid Level Sensor Circuit Short To Ground
B1483 Brake Pedal Input Circuit Failure
B1484 Brake Pedal Input Open Circuit
B1485 Brake Pedal Input Circuit Battery Short
B1486 Brake Pedal Input Circuit Ground Short
B1487 Door Handle Right Front Circuit Failure
B1488 Door Handle Right Front Circuit Open
B1489 Door Handle Right Front Short To Battery
B1490 Door Handle Right Front Short To Ground
B1491 Ignition Cylinder Sensor Circuit Failure
B1492 Ignition Cylinder Sensor Open Circuit
B1493 Ignition Cylinder Sensor Battery Short
B1494 Ignition Cylinder Sensor Ground Short
B1495 Decklid Punch-Out Sensor Circuit Failure
B1496 Decklid Punch-Out Sensor Open Circuit
B1497 Decklid Punch-Out Sensor Battery Short
B1498 Decklid Punch-Out Sensor Ground Short
B1499 Lamp Turn Signal Left Circuit Failure
B1500 Lamp Turn Signal Left Circuit Open
B1501 Lamp Turn Signal Left Circuit Short To Battery
B1502 Lamp Turn Signal Left Circuit Short To Ground
B1503 Lamp Turn Signal Right Circuit Failure
B1504 Lamp Turn Signal Right Circuit Open
B1505 Lamp Turn Signal Right Circuit Short To Battery
B1506 Lamp Turn Signal Right Circuit Short To Ground
B1507 Flash To Pass Switch Circuit Failure
B1508 Flash To Pass Switch Circuit Open
B1509 Flash To Pass Switch Circuit Short To Battery
B1510 Flash To Pass Switch Circuit Short To Ground
B1511 Driver Door Handle Circuit Failure
B1512 Driver Door Handle Circuit Open
B1513 Driver Door Handle Circuit Short To Battery
B1514 Driver Door Handle Circuit Short To Ground
B1515 Seat Driver Occupied Switch Circuit Failure
B1516 Seat Driver Occupied Switch Circuit Open
B1517 Seat Driver Occupied Switch Circuit Short To Battery
B1518 Seat Driver Occupied Switch Circuit Short To Ground
B1519 Hood Switch Circuit Failure
B1520 Hood Switch Circuit Open
B1521 Hood Switch Circuit Short To Battery
B1522 Hood Switch Circuit Short To Ground
B1523 Keyless Entry Circuit Failure
B1524 Keyless Entry Circuit Open
B1525 Keyless Entry Circuit Short To Battery
B1526 Keyless Entry Circuit Short To Ground
B1527 Memory Set Switch Circuit Failure
B1528 Memory Set Switch Circuit Open
B1529 Memory Set Switch Circuit Short To Battery
B1530 Memory Set Switch Circuit Short To Ground
B1531 Memory 1 Switch Circuit Failure
B1532 Memory 1 Switch Circuit Open
B1533 Memory 1 Switch Circuit Short To Battery
B1534 Memory 1 Switch Circuit Short To Ground
B1535 Memory 2 Switch Circuit Failure
B1536 Memory 2 Switch Circuit Open
B1537 Memory 2 Switch Circuit Short To Battery
B1538 Memory 2 Switch Circuit Short To Ground
B1539 Mirror Driver Switch Assembly Circuit Failure
B1540 Mirror Driver Switch Assembly Circuit Open
B1541 Mirror Driver Switch Assembly Circuit Short To Battery
B1542 Mirror Driver Switch Assembly Circuit Short To Ground
B1543 Seat Direction Switch Assembly Circuit Failure
B1544 Seat Direction Switch Assembly Circuit Open
B1545 Seat Direction Switch Assembly Circuit Short To Battery
B1546 Seat Direction Switch Assembly Circuit Short To Ground
B1547 Power Window Master Circuit Failure
B1548 Power Window Master Circuit Open
B1549 Power Window Master Circuit Short To Battery
B1550 Power Window Master Circuit Short To Ground
B1551 Decklid Release Circuit Failure
B1552 Decklid Release Circuit Open
B1553 Decklid Release Circuit Short To Battery
B1554 Decklid Release Circuit Short To Ground
B1555 Ignition Run/Start Circuit Failure
B1556 Ignition Run/Start Circuit Open
B1557 Ignition Run/Start Circuit Short To Battery
B1558 Ignition Run/Start Circuit Short To Ground
B1559 Door Lock Cylinder Circuit Failure
B1560 Door Lock Cylinder Circuit Open
B1561 Door Lock Cylinder Circuit Short To Battery
B1562 Door Lock Cylinder Circuit Short To Ground
B1563 Door Ajar Circuit Failure
B1564 Door Ajar Circuit Open
B1565 Door Ajar Circuit Short To Battery
B1566 Door Ajar Circuit Short To Ground
B1567 Lamp Headlamp High-Beam Circuit Failure
B1568 Lamp Headlamp High-Beam Circuit Open
B1569 Lamp Headlamp High-Beam Circuit Short To Battery
B1570 Lamp Headlamp High-Beam Circuit Short To Ground
B1571 Door Ajar LR Circuit Failure
B1572 Door Ajar LR Circuit Open
B1573 Door Ajar LR Circuit Short To Battery
B1574 Door Ajar LR Circuit Short To Ground
B1575 Lamp Park Input Circuit Failure
B1576 Lamp Park Input Circuit Open
B1577 Lamp Park Input Circuit Short To Battery
B1578 Lamp Park Input Circuit Short To Ground
B1579 Dim Panel Increase Input Circuit Failure
B1580 Dim Panel Increase Input Circuit Open
B1581 Dim Panel Increase Input Circuit Short To Battery
B1582 Dim Panel Increase Input Circuit Short To Ground
B1583 Dim Panel Decrease Input Circuit Failure
B1584 Dim Panel Decrease Input Circuit Open
B1585 Dim Panel Decrease Input Circuit Short To Battery
B1586 Dim Panel Decrease Input Circuit Short To Ground
B1587 Autolamp Delay Increase Circuit Failure
B1588 Autolamp Delay Increase Circuit Open
B1589 Autolamp Delay Increase Circuit Short To Battery
B1590 Autolamp Delay Increase Circuit Short To Ground
B1591 Autolamp Delay Decrease Circuit Failure
B1592 Autolamp Delay Decrease Circuit Open
B1593 Autolamp Delay Decrease Circuit Short To Battery
B1594 Autolamp Delay Decrease Circuit Short To Ground
B1595 Ignition Switch Illegal Input Code
B1596 Service Continuous Codes
B1597 Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground
B1598 Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground
B1599 Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground
B1600 PATS Ignition Key Transponder Signal Is Not Received
B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
B1603 Lamp Anti-Theft Indicator Circuit Failure
B1604 Lamp Anti-Theft Indicator Circuit Open
B1605 Lamp Anti-Theft Indicator Circuit Short To Battery
B1606 Lamp Anti-Theft Indicator Circuit Short To Ground
B1607 Illuminated Entry Input Circuit Failure
B1608 Illuminated Entry Input Open Circuit
B1609 Illuminated Entry Input Short Circuit To Battery
B1610 Illuminated Entry Input Short Circuit To Ground
B1611 Wiper Rear Mode Select Switch Circuit Failure
B1612 Wiper Rear Mode Select Switch Circuit Open
B1613 Wiper Rear Mode Select Switch Circuit Short To Battery
B1614 Wiper Rear Mode Select Switch Circuit Short To Ground
B1615 Wiper Rear Disable Switch Circuit Failure
B1616 Wiper Rear Disable Switch Circuit Open
B1617 Wiper Rear Disable Switch Circuit Short To Battery
B1618 Wiper Rear Disable Switch Circuit Short To Ground
B1619 Wiper Rear Low Limit Input Circuit Failure
B1620 Wiper Rear Low Limit Input Circuit Open
B1621 Wiper Rear Low Limit Input Circuit Short To Battery
B1622 Wiper Rear Low Limit Input Circuit Short To Ground
B1623 Lamp Keypad Output Circuit Failure
B1624 Lamp Keypad Output Open Circuit
B1625 Lamp Keypad Output Short Circuit To Battery
B1626 Lamp Keypad Output Short Circuit To Ground
B1627 PRNDL Reverse Input Circuit Failure
B1628 PRNDL Reverse Input Open Circuit
B1629 PRNDL Reverse Input Short To Battery
B1630 PRNDL Reverse Input Short Circuit To Ground
B1631 Mirror Driver Left Circuit Failure
B1632 Mirror Driver Left Circuit Open
B1633 Mirror Driver Left Circuit Short To Battery
B1634 Mirror Driver Left Circuit Short To Ground
B1635 Mirror Driver Right Circuit Failure
B1636 Mirror Driver Right Circuit Open
B1637 Mirror Driver Right Circuit Short To Battery
B1638 Mirror Driver Right Short To Ground
B1639 Mirror Passenger Left Circuit Failure
B1640 Mirror Passenger Left Circuit Open
B1641 Mirror Passenger Left Circuit Short To Battery
B1642 Mirror Passenger Left Circuit Short To Ground
B1643 Mirror Passenger Right Circuit Failure
B1644 Mirror Passenger Right Circuit Open
B1645 Mirror Passenger Right Circuit Short To Battery
B1646 Mirror Passenger Right Circuit Short To Ground
B1647 Seat Driver Recline Forward Circuit Failure
B1648 Seat Driver Recline Forward Circuit Open
B1649 Seat Driver Recline Forward Circuit Short To Battery
B1650 Seat Driver Recline Forward Circuit Short To Ground
B1651 Seat Driver Recline Backward Circuit Failure
B1652 Seat Driver Recline Backward Circuit Open
B1653 Seat Driver Recline Backward Circuit Short To Battery
B1654 Seat Driver Recline Backward Circuit Short To Ground
B1655 Seat Driver Rear Up Circuit Failure
B1656 Seat Driver Rear Up Circuit Open
B1657 Seat Driver Rear Up Circuit Short To Battery
B1658 Seat Driver Rear Up Circuit Short To Ground
B1659 Seat Driver Front Up Circuit Failure
B1660 Seat Driver Front Up Circuit Open
B1661 Seat Driver Front Up Circuit Short To Battery
B1662 Seat Driver Front Up Circuit Short To Ground
B1663 Seat Driver Front Up/Down Motor Stalled
B1664 Seat Driver Rear Up/Down Motor Stalled
B1665 Seat Driver Forward/Backward Motor Stalled
B1666 Seat Driver Recline Motor Stalled
B1667 Mirror Driver Up/Down Motor Stalled
B1668 Mirror Driver Right/Left Motor Stalled
B1669 Mirror Passenger Up/Down Motor Stalled
B1670 Mirror Passenger Right/Left Motor Stalled
B1671 Battery Module Voltage Out Of Range
B1672 Seat Driver Occupied Input Circuit Failure
B1673 Seat Driver Occupied Input Circuit Open
B1674 Seat Driver Occupied Input Circuit Short To Battery
B1675 Seat Driver Occupied Input Circuit Short To Ground
B1676 Battery Pack Voltage Out Of Range
B1677 Alarm Panic Input Circuit Failure
B1678 Alarm Panic Input Circuit Open
B1679 Alarm Panic Input Circuit Short To Battery
B1680 Alarm Panic Input Circuit Short To Ground
B1681 PATS Transceiver Module Signal Is Not Received
B1682 PATS Is Disabled (Check Link Between PATS And Transponder)
B1683 Mirror Driver/Passenger Switch Circuit Failure
B1684 Mirror Driver/Passenger Switch Circuit Open
B1685 Lamp Dome Input Circuit Failure
B1686 Lamp Dome Input Circuit Open
B1687 Lamp Dome Input Circuit Short To Battery
B1688 Lamp Dome Input Circuit Short To Ground
B1689 Autolamp Delay Circuit Failure
B1690 Autolamp Delay Circuit Open
B1691 Autolamp Delay Circuit Short To Battery
B1692 Autolamp Delay Circuit Short To Ground
B1693 Autolamp On Circuit Failure
B1694 Autolamp On Circuit Open
B1695 Autolamp On Circuit Short To Battery
B1696 Autolamp On Circuit Short To Ground
B1697 Mirror Driver/Passenger Switch Circuit Short To Battery
B1698 Mirror Driver/Passenger Switch Circuit Short To Ground
B1699 Passenger's Seat Occupied Switch Circuit Short to Ground
B1700 Passenger's Seatbelt Tension Reducer Circuit Short to Ground
B1701 Seat Driver Recline Forward Switch Circuit Failure
B1702 Seat Driver Recline Forward Switch Circuit Open
B1703 Seat Driver Recline Forward Switch Circuit Short To Battery
B1704 Seat Driver Recline Forward Switch Circuit Short To Ground
B1705 Seat Driver Recline Rearward Switch Circuit Failure
B1706 Seat Driver Recline Rearward Switch Circuit Open
B1707 Seat Driver Recline Rearward Switch Circuit Short To Battery
B1708 Seat Driver Recline Rearward Switch Circuit Short To Ground
B1709 Seat Driver Front Up Switch Circuit Failure
B1710 Seat Driver Front Up Switch Circuit Open
B1711 Seat Driver Front Up Switch Circuit Short To Battery
B1712 Seat Driver Front Up Switch Circuit Short To Ground
B1713 Seat Driver Front Down Switch Circuit Failure
B1714 Seat Driver Front Down Switch Circuit Open
B1715 Seat Driver Front Down Switch Circuit Short To Battery
B1716 Seat Driver Front Down Switch Circuit Short To Ground
B1717 Seat Driver Forward Switch Circuit Failure
B1718 Seat Driver Forward Switch Circuit Open
B1719 Seat Driver Forward Switch Circuit Short To Battery
B1720 Seat Driver Forward Switch Circuit Short To Ground
B1721 Seat Driver Rearward Switch Circuit Failure
B1722 Seat Driver Rearward Switch Circuit Open
B1723 Seat Driver Rearward Switch Circuit Short To Battery
B1724 Seat Driver Rearward Switch Circuit Short To Ground
B1725 Seat Driver Rear Up Switch Circuit Failure
B1726 Seat Driver Rear Up Switch Circuit Open
B1727 Seat Driver Rear Up Switch Circuit Short To Battery
B1728 Seat Driver Rear Up Switch Circuit Short To Ground
B1729 Seat Driver Rear Down Switch Circuit Failure
B1730 Seat Driver Rear Down Switch Circuit Open
B1731 Seat Driver Rear Down Switch Circuit Short To Battery
B1732 Seat Driver Rear Down Switch Circuit Short To Ground
B1733 Mirror Driver Vertical Switch Circuit Failure
B1734 Mirror Driver Vertical Switch Circuit Open
B1735 Mirror Driver Vertical Switch Circuit Short To Battery
B1736 Mirror Driver Vertical Switch Circuit Short To Ground
B1737 Mirror Driver Horizontal Switch Circuit Failure
B1738 Mirror Driver Horizontal Switch Circuit Open
B1739 Mirror Driver Horizontal Switch Circuit Short To Battery
B1740 Mirror Driver Horizontal Switch Circuit Short To Ground
B1741 Mirror Passenger Vertical Switch Circuit Failure
B1742 Mirror Passenger Vertical Switch Circuit Open
B1743 Mirror Passenger Vertical Switch Circuit Short To Battery
B1744 Mirror Passenger Vertical Switch Circuit Short To Ground
B1745 Mirror Passenger Horizontal Switch Circuit Failure
B1746 Mirror Passenger Horizontal Switch Circuit Open
B1747 Mirror Passenger Horizontal Switch Circuit Short To Battery
B1748 Mirror Passenger Horizontal Switch Circuit Short To Ground
B1749 Park/Neutral Switch Circuit Failure
B1750 Park/Neutral Switch Circuit Open
B1751 Park/Neutral Switch Circuit Short To Battery
B1752 Park/Neutral Switch Circuit Short To Ground
B1753 Hazard Flash Output Circuit Failure
B1754 Hazard Flash Output Circuit Open
B1755 Hazard Flash Output Circuit Short Battery
B1756 Hazard Flash Output Circuit Short To Ground
B1757 Seat Driver Rear Down Circuit Failure
B1758 Seat Driver Rear Down Circuit Open
B1759 Seat Driver Rear Down Circuit Short To Battery
B1760 Seat Driver Rear Down Circuit Short To Ground
B1761 Seat Driver Front Down Circuit Failure
B1762 Seat Driver Front Down Circuit Open
B1763 Seat Driver Front Down Circuit Short To Battery
B1764 Seat Driver Front Down Circuit Short To Ground
B1765 Seat Driver Forward Circuit Failure
B1766 Seat Driver Forward Circuit Open
B1767 Seat Driver Forward Circuit Short To Battery
B1768 Seat Driver Forward Circuit Short To Ground
B1769 Seat Driver Backward Circuit Failure
B1770 Seat Driver Backward Circuit Open
B1771 Seat Driver Backward Circuit Short To Battery
B1772 Seat Driver Backward Circuit Short To Ground
B1773 Mirror Driver Up Circuit Failure
B1774 Mirror Driver Up Circuit Open
B1775 Mirror Driver Up Circuit Short To Battery
B1776 Mirror Driver Up Circuit Short To Ground
B1777 Driver's Seatbelt Tension Reducer Circuit Short to Ground
B1778 Mirror Driver Down Circuit Failure
B1779 Mirror Driver Down Circuit Open
B1780 Mirror Driver Down Circuit Short To Battery
B1781 Mirror Driver Down Short To Ground
B1782 Mirror Passenger Up Circuit Failure
B1783 Mirror Passenger Up Circuit Open
B1784 Mirror Passenger Up Circuit Short To Battery
B1785 Mirror Passenger Up Circuit Short To Ground
B1786 Mirror Passenger Down Circuit Failure
B1787 Mirror Passenger Down Circuit Open
B1788 Mirror Passenger Down Circuit Short To Battery
B1789 Mirror Passenger Down Circuit Short To Ground
B1790 Autolamp Sensor Input Circuit Failure
B1791 Autolamp Sensor Input Circuit Open
B1792 Autolamp Sensor Input Circuit Short To Battery
B1793 Autolamp Sensor Input Circuit Short To Ground
B1794 Lamp Headlamp Low-Beam Circuit Failure
B1795 Lamp Headlamp Low-Beam Circuit Open
B1796 Lamp Headlamp Low-Beam Circuit Short To Battery
B1797 Lamp Headlamp Low-Beam Circuit Short To Ground
B1798 Lamp Turn Signal Front Output Circuit Failure
B1799 Lamp Turn Signal Front Output Circuit Open
B1800 Lamp Turn Signal Front Output Circuit Short To Battery
B1801 Lamp Turn Signal Front Output Circuit Short To Ground
B1802 Lamp Turn Signal Rear Output Circuit Failure
B1803 Lamp Turn Signal Rear Output Circuit Open
B1804 Lamp Turn Signal Rear Output Circuit Short To Battery
B1805 Lamp Turn Signal Rear Output Circuit Short To Ground
B1806 Lamp Tail Output Circuit Failure
B1807 Lamp Tail Output Circuit Open
B1808 Lamp Tail Output Circuit Short To Battery
B1809 Lamp Tail Output Circuit Short To Ground
B1810 Lamp Backup Switch Input Circuit Failure
B1811 Lamp Backup Switch Input Circuit Open
B1812 Lamp Backup Switch Input Circuit Short To Battery
B1813 Lamp Backup Switch Input Circuit Short To Ground
B1814 Wiper Rear Motor Down Relay Coil Circuit Failure
B1815 Wiper Rear Motor Down Relay Coil Circuit Open
B1816 Wiper Rear Motor Down Relay Coil Circuit Short To Battery
B1817 Wiper Rear Motor Down Relay Coil Circuit Short To Ground
B1818 Wiper Rear Motor Up Relay Coil Circuit Failure
B1819 Wiper Rear Motor Up Relay Coil Circuit Open
B1820 Wiper Rear Motor Up Relay Coil Circuit Short To Battery
B1821 Wiper Rear Motor Up Relay Coil Circuit Short To Ground
B1822 Wiper Rear Park Sense Input Circuit Failure
B1823 Wiper Rear Park Sense Input Circuit Open
B1824 Wiper Rear Park Sense Input Circuit Short To Battery
B1825 Wiper Rear Park Sense Input Circuit Short To Ground
B1826 Wiper Rear High Limit Input Circuit Failure
B1827 Wiper Rear High Limit Input Circuit Open
B1828 Wiper Rear High Limit Input Circuit Short To Battery
B1829 Wiper Rear High Limit Input Circuit Short To Ground
B1830 Door Unlock Disarm Switch Circuit Failure
B1831 Door Unlock Disarm Switch Circuit Open
B1832 Door Unlock Disarm Switch Circuit Short To Battery
B1833 Door Unlock Disarm Switch Circuit Short To Ground
B1834 Door Unlock Disarm Output Circuit Failure
B1835 Door Unlock Disarm Output Circuit Open
B1836 Door Unlock Disarm Output Circuit Short To Battery
B1837 Door Unlock Disarm Output Circuit Short To Ground
B1838 Battery Saver Power Relay Circuit Failure
B1839 Wiper Rear Motor Circuit Failure
B1840 Wiper Front Power Circuit Failure
B1841 Wiper Front Power Circuit Open
B1842 Wiper Front Power Circuit Short To Battery
B1843 Wiper Front Power Circuit Short To Ground
B1844 Phone Handset Circuit Failure
B1845 Ignition Tamper Circuit Failure
B1846 Ignition Tamper Circuit Open
B1847 Ignition Tamper Circuit Short To Battery
B1848 Ignition Tamper Circuit Short To Ground
B1849 Climate Control Temperature Differential Circuit Failure
B1850 Climate Control Temperature Differential Circuit Open
B1851 Climate Control Temperature Differential Circuit Short To Battery
B1852 Climate Control Temperature Differential Circuit Short To Ground
B1853 Climate Control Air Temperature Internal Sensor Motor Circuit Failure
B1854 Climate Control Air Temperature Internal Sensor Motor Circuit Open
B1855 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery
B1856 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground
B1857 Climate Control On/Off Switch Circuit Failure
B1858 Climate Control A/C Pressure Switch Circuit Failure
B1859 Climate Control A/C Pressure Switch Circuit Open
B1860 Climate Control A/C Pressure Switch Circuit Short To Battery
B1861 Climate Control A/C Pressure Switch Circuit Short To Ground
B1862 Climate Control A/C Lock Sensor Failure
B1863 Ground ECU Circuit Open
B1864 Battery Power Supply ECU Circuit Failure
B1865 Battery Power Supply ECU Circuit Open
B1866 Battery Power Supply ECU Circuit Short To Battery
B1867 Battery Power Supply ECU Circuit Short To Ground
B1868 Lamp Air Bag Warning Indicator Circuit Failure
B1869 Lamp Air Bag Warning Indicator Circuit Open
B1870 Lamp Air Bag Warning Indicator Circuit Short To Battery
B1871 Passenger Air Bag Disable Module Fault
B1872 Turn Signal / Hazard Power Feed Circuit Short To Battery
B1873 Turn Signal / Hazard Power Feed Circuit Short To Ground
B1874 Cellular Phone Handset Not Present
B1875 Turn Signal / Hazard Switch Signal Circuit Failure
B1876 Seatbelt Driver Pretensioner Circuit Failure
B1877 Seatbelt Driver Pretensioner Circuit Open
B1878 Seatbelt Driver Pretensioner Circuit Short to Battery
B1879 Seatbelt Driver Pretensioner Circuit Short to Ground
B1880 Seatbelt Passenger Pretensioner Circuit Failure
B1881 Seatbelt Passenger Pretensioner Circuit Open
B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery
B1883 Seatbelt Passenger Pretensioner Circuit Short to Ground
B1884 PAD Warning Lamp Inoperative
B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib
B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib
B1887 Air Bag Driver Circuit Resistance Low or Shorted Together
B1888 Air Bag Passenger Circuit Resistance Low or Shorted Together
B1889 Passenger Airbag Disable Module Sensor Obstructed
B1890 PAD Warning Lamp Circuit Short to Battery
B1891 Air Bag Tone Warning Indicator Circuit Short to Battery
B1892 Air Bag Tone Warning Indicator Circuit Failure
B1893 GPS Antenna Open Circuit
B1894 Wiper Rear Motor Speed Sense Circuit Failure
B1895 Driver's / Passenger's Door Ajar Output Circuit Failure
B1896 Driver's / Passenger's Door Ajar Output Circuit Short to Battery
B1897 Horn Switch Circuit Failure
B1898 Chime Input #2 Circuit Short to Ground
B1899 Microphone Input Signal Circuit Open
B1900 Driver Side Airbag Fault
B1901 Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground
B1902 Air Bag Crash Sensor #1 Ground Circuit Failure
B1903 Air Bag Crash Sensor #1 Ground Circuit Short To Battery
B1904 Air Bag Crash Sensor #2 Feed/Return Circuit Failure
B1905 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery
B1906 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground
B1907 Air Bag Crash Sensor #2 Ground Circuit Failure
B1908 Air Bag Crash Sensor #2 Ground Circuit Short To Battery
B1909 Air Bag Crash Sensor #2 Ground Circuit Short To Ground
B1910 Air Bag Diagnostic Monitor Ground Circuit Failure
B1911 Air Bag Diagnostic Monitor Ground Circuit Short To Battery
B1912 Air Bag Diagnostic Monitor Ground Circuit Short To Ground
B1913 Air Bag Driver/Passenger Circuit Short To Ground
B1914 Air Bag Crash Sensors #1 / #2 Circuit Short To Ground
B1915 Air Bag Driver Circuit Failure
B1916 Air Bag Driver Circuit Short To Battery
B1917 Air Bag Memory Clear Circuit Failure
B1918 Air Bag Memory Clear Circuit Open
B1919 Air Bag Memory Clear Circuit Short To Battery
B1920 Air Bag Passenger Circuit Failure
B1921 Air Bag Diagnostic Monitor Ground Circuit Open
B1922 Air Bag Safing Sensor Output Circuit Short To Battery
B1923 Air Bag Memory Clear Circuit Short To Ground
B1924 Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault
B1925 Air Bag Passenger Circuit Short To Battery
B1926 Air Bag Passenger Pressure Switch Circuit Failure
B1927 Passenger Side Airbag Fault
B1928 Air Bag Safing Sensor Output Circuit Failure
B1929 Air Bag Safing Sensor Output Circuit Open
B1930 Air Bag Safing Sensor Output Circuit Short To Ground
B1931 Air Bag Crash Sensor #1 Feed/Return Circuit Failure
B1932 Air Bag Driver Circuit Open
B1933 Air Bag Passenger Circuit Open
B1934 Air Bag Driver Inflator Circuit Resistance Low on Squib
B1935 Air Bag Passenger Inflator Circuit Resistance Low on Squib
B1936 Air Bag Driver Circuit Short To Ground
B1937 Air Bag Passenger Pressure Switch Circuit Open
B1938 Air Bag Passenger Circuit Short To Ground
B1939 Air Bag Passenger Pressure Switch Circuit Short To Ground
B1941 Air Bag Crash Sensor #1 Feed/Return Circuit Open
B1942 Air Bag Crash Sensor #2 Feed/Return Circuit Open
B1943 Air Bag Crash Sensor #1 Ground Circuit Short To Ground
B1944 Air Bag Crash Sensor #1 Ground Circuit Open
B1945 Air Bag Crash Sensor #2 Ground Circuit Open
B1946 Climate Control A/C Post Evaporator Sensor Circuit Failure
B1947 Climate Control A/C Post Evaporator Sensor Circuit Short To Ground
B1948 Climate Control Water Temperature Sensor Circuit Failure
B1949 Climate Control Water Temperature Sensor Circuit Short To Ground
B1950 Seat Rear Up/Down Potentiometer Feedback Circuit Failure
B1951 Seat Rear Up/Down Potentiometer Feedback Circuit Open
B1952 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Battery
B1953 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Ground
B1954 Seat Front Up/Down Potentiometer Feedback Circuit Failure
B1955 Seat Front Up/Down Potentiometer Feedback Circuit Open
B1956 Seat Front Up/Down Potentiometer Feedback Circuit Short To Battery
B1957 Seat Front Up/Down Potentiometer Feedback Circuit Short To Ground
B1958 Seat Recline Forward/Backward Potentiometer Feedback Circuit Failure
B1959 Seat Recline Forward/Backward Potentiometer Feedback Circuit Open
B1960 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Battery
B1961 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Ground
B1962 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure
B1963 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Open
B1964 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Battery
B1965 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Ground
B1966 A/C Post Heater Sensor Circuit Failure
B1967 A/C Post Heater Sensor Circuit Short To Ground
B1968 A/C Water Pump Detection Circuit Failure
B1969 A/C Clutch Magnetic Control Circuit Failure
B1970 Passenger Seatback Forward Switch Circuit Short to Ground
B1971 Passenger Seatback Rearward Switch Circuit Short to Ground
B1972 Passenger Rear Seat Up Switch Circuit Short to Battery
B1973 Passenger Rear Seat Down Switch Circuit Short to Battery
B1974 Passenger's Seat Recline Forward Switch Circuit Short to Battery
B1975 Passenger's Seat Recline Back Switch Circuit Short to Battery
B1976 Passenger's Seat Forward Switch Circuit Short to Battery
B1977 Passenger's Front Seat Up Switch Circuit Short to Battery
B1978 Passenger's Front Seat Down Switch Circuit Short to Battery
B1979 Passenger Seat Rearward Switch Circuit Short to Battery
B1980 Bulb - Outage Condition Detected
B1981 Memory Off Switch Circuit Short to Battery
B1982 Driver's Door Unlock Relay Circuit Failure
B1983 Driver's Door Unlock Relay Circuit Short to Battery
B1984 Seat Switch Lumbar Inflate Circuit Failure
B1985 Seat Switch Lumbar Deflate Circuit Failure
B1986 Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure
B1987 Pedal Forward / Rearward Motor Stalled
B1988 Pedal Position Forward Switch Circuit Short to Battery
B1989 Pedal Position Rearward Switch Circuit Short to Battery
B1990 Pedal Forward / Rearward Potentiometer Feedback Circuit Failure
B1991 Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery
B1992 Driver Side, Side mount Airbag Circuit Short to Vbatt
B1993 Driver Sid, Side mount Airbag Circuit Short to Ground
B1994 Driver Sid, Side mount Airbag Circuit Open
B1995 Driver Sid, Side mount Airbag Low resistance on Squib
B1996 Passenger Sid, Side mount Airbag Circuit Short to Vbatt
B1997 Passenger Sid, Side mount Airbag Circuit Short to Ground
B1998 Passenger Sid, Side mount Airbag Circuit Open
B1999 Passenger Sid, Side mount Airbag Low resistance on Squib
B2100 Door Driver Key Cylinder Switch Failure
B2101 Head Rest Switch Circuit Failure
B2102 Antenna Circuit Short to Ground
B2103 Antenna Not Connected
B2104 Door Passenger Key Cylinder Switch Failure
B2105 Throttle Position Input Out of Range Low
B2106 Throttle Position Input Out of Range High
B2107 Front Wiper Motor Relay Circuit Short to Vbatt
B2108 Trunk Key Cylinder Switch Failure
B2109 Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97)
B2110 Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97)
B2111 All Door Lock Input Short to Ground
B2112 Door Driver Set Switch Stuck Failure
B2113 Heated Windshield Input Short to Ground
B2114 Front Washer Input Short to Ground
B2115 Rear Washer Input Short to Ground
B2116 Door Driver Reset Switch Stuck Failure
B2117 Driver Side, Side mount Airbag Low capacitance on Squib
B2118 Passenger Sid, Side mount Airbag Low capacitance on Squib
B2119 Compressor Failure
B2120 Door Passenger Set Switch Stuck Failure
B2122 Driver Side Satellite Communication Circuit Short to Ground
B2123 Passenger Side Satellite Communication Circuit Short to Ground
B2124 Door Passenger Reset Switch Stuck Failure
B2128 Central Lock Motor Failure
B2129 Central Lock Feedback Failure
B2130 Double Lock Timeout Failure
B2131 Double Lock Feedback Failure
B2132 Dimmer switch Circuit Short to Gnd
B2133 Brake Motor Warning lamp Circuit Failure
B2134 Brake Motor Warning lamp Circuit Short to Vbatt
B2135 Park Brake Applied Warning Lamp Circuit Failure
B2136 Park Brake Applied Warning Lamp Circuit Short To Battery
B2139 Data Mismatch (receive data does not match what was expected)
B2141 NVM Configuration Failure
B2142 NVM TIC Failure
B2143 NVM Memory Failure
B2144 NVM Alarm Data Failure
B2145 NVM RF HR Failure
B2146 Seat Recline Motor Position Out of Range
B2148 PWM Input Circuit Failure
B2149 Seat Front Vertical Motor Position Out of Range
B2150 Power Supply #1 Circuit Short to Ground
B2151 Power Supply #2 Circuit Short to Ground
B2152 Seat Rear Vertical Motor Position Out of Range
B2153 Rear Echo Sensor Circuit Failure
B2154 Front Echo Sensor Circuit Failure
B2155 Seat Horizontal Motor Position Out of Range
B2156 Rear Doppler Sensor Circuit Failure
B2157 Front Doppler Sensor Circuit Failure
B2158 Seat Recline Motor Memory Position Out of Range
B2159 Memory #1 output Short to Ground
B2160 Memory #1 output Short to VBatt
B2161 Seat Front Vertical Motor Memory Position Out of Range
B2162 Data Mismatch #2 (receive data does not match what was expected)
B2163 Clutch Position Fault
B2164 Seat Rear Vertical Motor Memory Position Out of Range
B2165 Gear shift position Fault
B2166 Gear select position Fault
B2167 Seat Horizontal Motor Memory Position Out of Range
B2168 Unable to confirm Unlock Condition
B2169 Unable to confirm lock Condition
B2170 Steering Column Lock Switch Circuit Failure
B2172 Inertia Switch input Circuit Open
B2174 Window Driver Rear Remote Up Switch Short to Battery
B2175 A/C Request Signal Circuit Short to Ground
B2176 Overdrive switch circuit short to Vbatt
B2177 Interior Scanning Sensor Circuit Failure
B2178 Window Driver Rear Remote Down Switch Short to Battery
B2179 Front Wiper Select Switch "A" Short to Ground
B2180 Front Wiper Select Switch "B" Short to Ground
B2181 Front Wiper Select Switch "C" Short to Ground
B2182 Window Passenger Front Remote Up Switch Short to Battery
B2183 Front Wiper Select Switch "H" Short to Ground
B2184 Front Wiper Select Switch "W" Short to Ground
B2185 Rear Wiper Select Switch "D" Short to Ground
B2186 Window Passenger Front Remote Down Switch Short to Battery
B2187 Rear Wiper Select Switch "B" Short to Ground
B2188 Rear Wiper Select Switch "E" Short to Ground
B2190 Window Passenger Rear Remote Up Switch Short to Battery
B2194 Window Passenger Rear Remote Down Switch Short to Battery
B2195 Driver Window Up / Down Power Circuit Short to Ground
B2196 Passenger Window Up / Down Power Circuit Short to Ground
B2197 TV Module Error
B2198 TrafficMaster Module Error
B2199 VICS Module Error
B2200 No Communication to TV Module (No Fitting of TV)
B2201 No Communication With Traffic MasterModule
B2202 No Communication to VICS Module (No Fitting of VICS)
B2203 CD-ROM Error
B2204 GPS Antenna Connection Open or Short
B2205 GPS Receiver Error
B2206 Gyroscope Error
B2207 ECU ROM Checksum Error
B2208 Communication Link to Display and Switch Module Error
B2209 Interior Lamp Override Switch Open Circuit
B2210 Interior Lamp Override Switch Short to Ground
B2211 Low Coolant Lamp Output Circuit Short to Battery
B2214 Window Passenger Front Up Switch Short to Battery
B2215 Window Passenger Front Down Switch Short to Battery
B2219 Window Driver Front Current Feedback Exceeded
B2220 Window Driver Rear Current Feedback Exceeded
B2221 Window Passenger Front Current Feedback Exceeded
B2222 Window Passenger Rear Current Feedback Exceeded
B2223 Mirror Driver Drive Circuit Failure
B2224 Mirror Passenger Drive Circuit Failure
B2225 Front Crash Sensor Mount Fault
B2226 Front Crash Sensor Internal Fault
B2227 Front Crash Sensor Driver Communications Fault
B2228 Air Bag Driver Circuit Short to Ground - Loop #2
B2229 Air Bag Passenger Circuit Short to Ground - Loop #2
B2230 Air Bag Driver Circuit Short to Battery - Loop #2
B2231 Air Bag Passenger Circuit Short to Battery - Loop #2
B2232 Air Bag Driver Circuit Open - Loop #2
B2233 Air Bag passenger Circuit Open - Loop #2
B2234 Air Bag Driver Inflator Circuit Resistance Low on Squib - Loop #2
B2235 Air Bag Passenger Inflator Circuit
B2236 Weak or Defected Electric Vehicle Battery Module Fault
B2237 Vehicle Signal indicating Park While VSS Present
B2238 Power Cable For Power Sliding Door Broken
B2239 Rear Cargo Door Set Switch Stuck (Short to Ground)
B2240 Rear Cargo Door Reset Switch Stuck (Short to Ground)
B2241 Rear Cargo Door Lock Circuit Short to Ground
B2242 Rear Cargo Door Unlock Circuit Open
B2243 Driver Rear Door Ajar Circuit Open
B2244 Driver Sliding Door Ajar Circuit Short to GND
B2245 Passenger Rear Door Ajar Circuit Open
B2246 Passenger Sliding Door Ajar Circuit Short to GND
B2247 EV Battery Pack Temperature Fault
B2248 Heated Windshield Relay Coil Circuit Failure
B2249 Head Lamp Relay Coil Short to Battery
B2250 All Doors Unlock Relay Circuit Failure
B2251 Parklamp Output Relay Driver Circuit Failure
B2252 Parklamp Output Relay Dirver Short to Battery
B2300 Seat Driver Memory Position Error
B2301 Seat Passenger Memory Position Error
B2302 Seat Headrest Feedback Potentiometer Circuit Failure
B2303 Seat Headrest Feedback Potentiometer Circuit Open
B2304 Seat Headrest Feedback Potentiometer Circuit Short to Battery
B2305 Seat Headrest Feedback Potentiometer Circuit Short to Ground
B2306 Seat Headrest Motor Stalled
B2310 Mirror Driver Memory Position Error
B2311 Mirror Passenger Memory Position Error
B2312 Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure
B2313 Mirror Passenger Horizontal Feedback Potentiometer Circuit Open
B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery
B2315 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Ground
B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure
B2317 Mirror Passenger Vertical Feedback Potentiometer Circuit Open
B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery
B2319 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Ground
B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure
B2321 Mirror Driver Horizontal Feedback Potentiometer Circuit Open
B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery
B2323 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Ground
B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure
B2325 Mirror Driver Vertical Feedback Potentiometer Circuit Open
B2326 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Battery
B2327 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Ground
B2328 Column Reach Feedback Potentiometer Circuit Failure
B2329 Column Reach Feedback Potentiometer Circuit Open
B2330 Column Reach Feedback Potentiometer Circuit Short to Battery
B2331 Column Reach Feedback Potentiometer Circuit Short to Ground
B2332 Column Tilt Feedback Potentiometer Circuit Failure
B2333 Column Tilt Feedback Potentiometer Circuit Open
B2334 Column Tilt Feedback Potentiometer Circuit Short to Battery
B2335 Column Tilt Feedback Potentiometer Circuit Short to Ground
B2336 Mirror Switch Assembly Circuit Failure
B2337 Mirror Switch Assembly Circuit Open
B2338 Mirror Switch Assembly Circuit Short to Battery
B2339 Mirror Switch Assembly Circuit Short to Ground
B2340 Column Reach Motor Stalled
B2341 Column Tilt Motor Stalled
B2342 Seat Switch Reference Voltage Positive Common Open Circuit
B2343 Seat Switch Reference Voltage Positive Common Supply Low Voltage
B2344 Seat Switch Reference Voltage Positive Common Supply Voltage Fault
B2345 Seat Switch Reference Voltage Negative Common Open Circuit
B2346 Mirror Switch Reference Voltage Positive Common Open Circuit
B2347 Mirror Switch Reference Voltage Positive Common Supply Low Voltage
B2348 Mirror Switch Reference Voltage Positive Common Supply Voltage Fault
B2349 Mirror Switch Reference Voltage Negative Common Open Circuit
B2350 Steering Column Switch Circuit Short to Battery
B2351 Steering Column Switch Circuit Failure
B2352 Driver Memory Power Switch Indicator Circuit Short to Battery
B2353 Driver Mirror Power Driver Circuit Short Ground
B2354 Driver Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
B2355 Passenger Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
B2357 Driver Window Down Current Sense Low Circuit Failure
B2362 Remote Open/Close signal Circuit Short to Ground
B2363 Optical Sensor System Failure
B2364 Fuel Filler Door Circuit Open
B2365 B-pillar Power Sliding Door Open/Close Switch Input Ckt Short to Gnd
B2366 IP Power Sliding Door Open/Close switch Ckt Short to Gnd
B2367 Power Sliding Door Override Switch Input Ckt Short to Gnd
B2368 Steering Column Switch Circuit Out of Range
B2369 Chime OUTPUT Request Ckt Short to Ground
B2373 LED #1 Circuit Short to Battery
B2374 Power Sliding Detent (Latch) Circuit Failure
B2380 Heater Coolant Temp sensor circuit Short to GND
B2381 Heater Coolant Temp sensor circuit Open
B2384 Audio Reverse Aid Mute Input Ckt Failure
B2385 Audio Navigation Mute Input Ckt Failure
B2401 Audio Tape Deck Mechanism Fault
B2402 Audio CD/DJ Thermal Shutdown Fault
B2403 Audio CD/DJ Internal Fault
B2404 Audio Steering Wheel Switch Circuit Fault
B2405 Audio Single-Disc CD Player Thermal Shutdown Fault
B2406 Audio Single-Disc CD Player Internal Fault
B2416 Climate Control Recirculation Actuator Out of Limits
B2425 Remote Keyless Entry Out of Synchronization
B2426 Passenger Solar Radiation Sensor Circuit Open
B2427 Passenger Solar Radiation Sensor Circuit Short to Ground
B2428 A/C Post Heater Sensor #2 Circuit Failure
B2429 A/C Post Heater Sensor #2 Circuit Short to Ground
B2431 Transponder Programming Failed
B2432 Drivers Seat Belt Buckle Switch Circuit Open
B2433 Drivers Seat Belt Buckle Switch Circuit Short to Battery
B2434 Drivers Seat Belt Buckle Switch Circuit Short to Ground
B2435 Drivers Seat Belt Buckle Switch Resistance out of Range
B2436 Passengers Seat Belt Buckle Switch Circuit Open
B2437 Passengers Seat Belt Buckle Switch Circuit Short to Battery
B2438 Passengers Seat Belt Buckle Switch Circuit Short to Ground
B2439 Passengers Seat Belt Buckle Switch Resistance out of Range
B2440 Passenger Sid, Side crash sensor mount fault
B2441 Driver Sid, Side crash sensor mount fault
B2442 Intrusion Sensor Fault
B2443 Powertrain Performance Mode Switch Circuit failure
B2444 Driver Side Crash Sensor Internal Fault
B2445 Passenger Side Crash Sensor Internal Fault
B2446 RESCU/VEMS Input Circuit Open
B2447 RESCU/VEMS Input Circuit Short to Battery
B2448 RESCU/VEMS Input Circuit Short to Ground
B2449 Aux Heater Glow Plug Circuit Short to Ground
B2450 Aux Heater Glow Plug Circuit Open
B2451 Aux Heater Fuel Pump Circuit Short to Ground
B2452 Aux Heater Fuel Pump Circuit Open
B2453 Aux Heater Blower Fan Circuit Short to Ground
B2454 Aux Heater Blower Fan Circuit Open
B2455 Aux Heater Blower Faulted
B2456 Aux Heater Coolant Sensor Circuit Short to Ground
B2457 Aux Heater Coolant Sensor Circuit Open
B2458 Aux Heater Overheat Sensor Circuit Short to Ground
B2459 Aux Heater Overheat Sensor Circuit Open
B2460 Aux Heater Flame Sensor Circuit Short to Ground
B2461 Aux Heater Flame Sensor Circuit Open
B2462 Aux Heater Flame Out Fault
B2463 Aux Heater Overheat Fault
B2464 Aux Heater Start Time Exceeded
B2465 Aux Heater Start Counter Overrun/System Locked (same as below ?)
B2466 Aux Heater Overheat Counter Overrun/System Locked
B2467 Aux Heater Cool Down Time Exceeded (may be con to a453-5 )
B2468 Aux Heater Coolant Pump Circuit Short to Ground
B2469 Aux Heater Coolant Pump Circuit Open
B2470 Interior Fan Control Circuit Short to Ground
B2471 Interior Fan Control Circuit Open
B2472 Fog Lamp Switch Failure
B2473 Passenger Door Disarm Switch ckt Short to Ground
B2474 Passenger Door Lock Switch Circuit Shorted to Ground
B2475 Passenger Door Unlock Switch Circuit Shorted to Ground
B2476 RADIO PRESENT SWITCH Ckt Failure
B2477 Module Configuration Failure
B2478 ANTI THEFT INPUT SIGNAL SHORT TO GROUND
B2479 BRAKE PARK SWITCH CIRCUIT SHORT TO GROUND
B2480 LF CORNER LAMP OUTPUT Ckt Short to Battery
B2481 Convertible Top Up/Down switch Fault
B2482 RF CORNER LAMP OUTPUT Ckt Short to Battery
B2483 Enable Signal Open Circuit
B2484 Disable Signal Short to Ground
B2485 LF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
B2487 RF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
B2489 UNDERHOOD LAMP OUTPUT CIRCUIT Failure
B2490 UNDERHOOD LAMP OUTPUT CIRCUIT Short to Battery
B2491 RF PARK LAMP OUTPUT CIRCUIT Short to Battery
B2492 Already Programmed (Test Mode DTC Only !!!)
B2493 LF PARK LAMP OUTPUT CIRCUIT Short to Battery
B2494 ANTI THEFT HORN OUTPUT CIRCUIT Short to Batt
B2495 ANTI THEFT HORN OUTPUT CIRCUIT Failure
B2496 ANTI THEFT HORN OUTPUT CIRCUIT Short to Gnd
B2499 COURTESY LAMP OUTPUT Failure
B2500 COURTESY LAMP OUTPUT Ckt Short to Battery
B2501 LF LAMP LOW BEAM CIRCUIT Failure
B2502 LF LAMP LOW BEAM CIRCUIT Short to Battery
B2503 RF LAMP LOW BEAM CIRCUIT Failure
B2504 RF LAMP LOW BEAM CIRCUIT Short to Battery
B2505 LF LAMP HIGH BEAM CIRCUIT Failure
B2506 LF LAMP HIGH BEAM CIRCUIT Short to Battery
B2507 RF LAMP HIGH BEAM CIRCUIT Failure
B2508 RF LAMP HIGH BEAM CIRCUIT Short to Battery
B2509 Rear Fog Lamp Switch Circuit Failure
B2510 Main Blower Motor Relay Circuit Short to Battery
B2511 Horn Output Relay Circuit Short to Battery
B2512 Front Fog Lamp Relay Ckt Short to Battery
B2513 Blower (Fan) Circuit Failure
B2514 Blower (Fan) Circuit Short to Vbatt
B2515 Heater Blower Relay Circuit Failure
B2516 Blower Control Circuit Failure
B2517 Emergency Power Off System Faulted
B2518 Compressor Overtemp Fault
B2519 High Mount Stop Lamp Circuit Failure
B2520 High Mount Stop Lamp Circuit Short to Battery
B2523 License Lamp Circuit Failure
B2524 License Lamp Circuit Short to Battery
B2525 Left Rear Backup Lamp Circuit Failure
B2526 Left Rear Backup Lamp Circuit Short to Battery
B2527 Left Rear Stop lamp Circuit Failure
B2528 Left Rear Stop lamp Circuit Short to Battery
B2529 Left Rear Turn Lamp Circuit Failure
B2530 Left Rear Turn Lamp Circuit Short to Battery
B2531 Right Rear Backup Lamp Circuit Failure
B2532 Right Rear Backup Lamp Circuit Short to Battery
B2533 Right Rear Stop lamp Circuit Failure
B2534 Right Rear Stop lamp Circuit Short to Battery
B2535 Right Rear Turn Lamp Circuit Failure
B2536 Right Rear Turn Lamp Circuit Short to Battery
B2539 Aux A/C Mode Position Reference Circuit Short to Ground
B2540 Aux A/C Mode Position Reference Circuit Short to Battery
B2543 Aux A/C Control Switch Reference Circuit Short to Ground
B2544 Aux A/C Control Switch Reference Circuit Short to Battery
B2545 System Power Relay Circuit Short to Battery
B2546 System Power Relay Circuit Failure
B2550 LAMP DOME OUTPUT Circuit Short to Ground
B2553 Disable Signal Output Circuit Short to Battery
B2554 LAMP DOME OUTPUT Circuit Failure
B2555 LAMP DOME OUTPUT Circuit Short to Battery
B2556 Enable Signal Circuit Short to Battery
B2557 Left Power Sliding Door Open/Close Output Circuit Short to Battery
B2558 Right Power Sliding Door Open/Close Output Circuit Short to Battery
B2559 Aux A/C Blower Motor Relay Circuit Short to Battery
B2560 Aux A/C Blower Motor Relay Circuit Short to Ground
B2561 Aux A/C Blower Speed 1 Circuit Failure
B2562 Aux A/C Blower Speed 1 Circuit Short to Ground
B2563 Aux A/C Blower Speed 2 Circuit Failure
B2564 Aux A/C Blower Speed 2 Circuit Short to Ground
B2565 Right Tail Lamp Circuit Failure
B2566 Right Tail Lamp Circuit Short to Ground
B2567 Reverse Mirror Output Circuit Failure
B2568 Reverse Mirror Output Circuit Short to Ground
B2569 Liftgate Disarm Switch Circuit Short to Ground
B2570 Right Lamp Outage Signal Circuit Short to Ground
B2571 Left Lamp Outage Signal Circuit Short to Ground
B2580 Aux Blower Sense Switch Circuit Failure
B2581 Passenger Seat Occupant Detection Circuit Short To Ground
B2582 Passenger Seat Occupant Detection Circuit Open
B2583 Child Seat Detection Circuit Short to Ground
B2584 Child Seat Detection Circuit Open
B2585 Anti Theft Input Signal Circuit Short To Battery
B2586 Headlamp Mode Select Circuit Failure
B2587 Passenger Seat Occupant Detection Circuit Short To Battery
B2588 Child Seat Detection Circuit Short To Battery
B2589 Unexpected Door Reversal During Close
B2590 Vehicle Park/Speed Signal Circuit Failure
B2591 Detent Signal Missing During Unlatch
B2592 PSD Not Fully Closed (Module Commanded Successfully)
B2593 Power Sliding Door Opened During Module Close Command
B2594 No Movement Detected After an Unlatch During Power Open
B2595 Anti Theft Input Signal Circuit Failure
B2596 Headlamp Aim Output Relay Circuit Short To Battery
B2597 Headlamp Aim Output Relay Circuit Failure
B2598 Headlamp Relay Circuit Failure
B2599 Tailgate Release Open Circuit
B2600 Double Locking Door Motor Frozen
B2601 No Latch Signal Sensed on Closing and Door Reversed
B2602 Missing Latch Signal During Power Sliding Door Unlatch
B2603 PSD Not Fully Closed During Self-Test
B2604 Power Sliding Door On/Off Switch Open Circuit
B2605 Disable Signal Open Circuit
B2606 A/C Temperature Sensor Out of Range
U1000 SCP (J1850) Invalid or Missing Data for Primary Id
U1001 SCP (J1850) Invalid or Missing Data for Primary Id
U1002 SCP (J1850) Invalid or Missing Data for Primary Id
U1003 SCP (J1850) Invalid or Missing Data for Primary Id
U1004 SCP (J1850) Invalid or Missing Data for EEC Programming
U1005 SCP (J1850) Invalid or Missing Data for EEC Programming
U1006 SCP (J1850) Invalid or Missing Data for Primary Id
U1007 SCP (J1850) Invalid or Missing Data for Primary Id
U1008 SCP (J1850) Invalid or Missing Data for Engine Torque
U1009 SCP (J1850) Invalid or Missing Data for Engine Torque
U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1012 SCP (J1850) Invalid or Missing Data for Primary Id
U1013 SCP (J1850) Invalid or Missing Data for Primary Id
U1014 SCP (J1850) Invalid or Missing Data for Primary Id
U1015 SCP (J1850) Invalid or Missing Data for Primary Id
U1016 SCP (J1850) Invalid or Missing Data for Primary Id
U1017 SCP (J1850) Invalid or Missing Data for Primary Id
U1018 SCP (J1850) Invalid or Missing Data for Throttle
U1019 SCP (J1850) Invalid or Missing Data for Throttle
U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1022 SCP (J1850) Invalid or Missing Data for Primary Id
U1023 SCP (J1850) Invalid or Missing Data for Primary Id
U1024 SCP (J1850) Invalid or Missing Data for Primary Id
U1025 SCP (J1850) Invalid or Missing Data for Primary Id
U1026 SCP (J1850) Invalid or Missing Data for Engine RPM
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM
U1028 SCP (J1850) Invalid or Missing Data for Primary Id
U1029 SCP (J1850) Invalid or Missing Data for Primary Id
U1030 SCP (J1850) Invalid or Missing Data for Experimental #1
U1031 SCP (J1850) Invalid or Missing Data for Experimental #1
U1032 SCP (J1850) Invalid or Missing Data for Primary Id
U1033 SCP (J1850) Invalid or Missing Data for Primary Id
U1034 SCP (J1850) Invalid or Missing Data for Primary Id
U1035 SCP (J1850) Invalid or Missing Data for Primary Id
U1036 SCP (J1850) Invalid or Missing Data for Wheels
U1037 SCP (J1850) Invalid or Missing Data for Wheels
U1038 SCP (J1850) Invalid or Missing Data for Primary Id
U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed
U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1042 SCP (J1850) Invalid or Missing Data for Traction Control
U1043 SCP (J1850) Invalid or Missing Data for Traction Control
U1044 SCP (J1850) Invalid or Missing Data for Traction Motor
U1045 SCP (J1850) Invalid or Missing Data for Traction Motor
U1046 SCP (J1850) Invalid or Missing Data for Primary Id
U1047 SCP (J1850) Invalid or Missing Data for Primary Id
U1048 SCP (J1850) Invalid or Missing Data for Primary Id
U1049 SCP (J1850) Invalid or Missing Data for Primary Id
U1050 SCP (J1850) Invalid or Missing Data for Brakes
U1051 SCP (J1850) Invalid or Missing Data for Brakes
U1052 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1053 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1054 SCP (J1850) Invalid or Missing Data for Primary Id
U1055 SCP (J1850) Invalid or Missing Data for Primary Id
U1056 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1057 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1058 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1059 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1060 SCP (J1850) Invalid or Missing Data for Primary Id
U1061 SCP (J1850) Invalid or Missing Data for Primary Id
U1062 SCP (J1850) Invalid or Missing Data for Primary Id
U1063 SCP (J1850) Invalid or Missing Data for Primary Id
U1064 SCP (J1850) Invalid or Missing Data for Primary Id
U1065 SCP (J1850) Invalid or Missing Data for Primary Id
U1066 SCP (J1850) Invalid or Missing Data for Primary Id
U1067 SCP (J1850) Invalid or Missing Data for Primary Id
U1068 SCP (J1850) Invalid or Missing Data for Primary Id
U1069 SCP (J1850) Invalid or Missing Data for Primary Id
U1070 SCP (J1850) Invalid or Missing Data for Engine Sensors
U1071 SCP (J1850) Invalid or Missing Data for Engine Sensors
U1072 SCP (J1850) Invalid or Missing Data for Engine Coolant
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant
U1074 SCP (J1850) Invalid or Missing Data for Engine Oil
U1075 SCP (J1850) Invalid or Missing Data for Engine Oil Temp
U1076 SCP (J1850) Invalid or Missing Data for Primary Id
U1077 SCP (J1850) Invalid or Missing Data for Primary Id
U1078 SCP (J1850) Invalid or Missing Data for Primary Id
U1079 SCP (J1850) Invalid or Missing Data for Primary Id
U1080 SCP (J1850) Invalid or Missing Data for Primary Id
U1081 SCP (J1850) Invalid or Missing Data for Primary Id
U1082 SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1083 SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1084 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1085 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1086 SCP (J1850) Invalid or Missing Data for Primary Id
U1087 SCP (J1850) Invalid or Missing Data for Primary Id
U1088 SCP (J1850) Invalid or Missing Data for Suspension
U1089 SCP (J1850) Invalid or Missing Data for Suspension
U1090 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1091 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1092 SCP (J1850) Invalid or Missing Data for Primary Id
U1093 SCP (J1850) Invalid or Missing Data for Primary Id
U1094 SCP (J1850) Invalid or Missing Data for Experimental #2
U1095 SCP (J1850) Invalid or Missing Data for Experimental #2
U1096 SCP (J1850) Invalid or Missing Data for Primary Id
U1097 SCP (J1850) Invalid or Missing Data for Primary Id
U1098 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1099 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1100 SCP (J1850) Invalid or Missing Data for Primary Id
U1101 SCP (J1850) Invalid or Missing Data for Primary Id
U1102 SCP (J1850) Invalid or Missing Data for Primary Id
U1103 SCP (J1850) Invalid or Missing Data for Primary Id
U1104 SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1105 SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1106 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1107 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1108 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1109 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1110 SCP (J1850) Invalid or Missing Data for Primary Id
U1111 SCP (J1850) Invalid or Missing Data for Primary Id
U1112 SCP (J1850) Invalid or Missing Data for Primary Id
U1113 SCP (J1850) Invalid or Missing Data for Primary Id
U1114 SCP (J1850) Invalid or Missing Data for Charging System
U1115 SCP (J1850) Invalid or Missing Data for Charging System
U1116 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1117 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1118 SCP (J1850) Invalid or Missing Data for Primary Id
U1119 SCP (J1850) Invalid or Missing Data for Primary Id
U1120 SCP (J1850) Invalid or Missing Data for Primary Id
U1121 SCP (J1850) Invalid or Missing Data for Primary Id
U1122 SCP (J1850) Invalid or Missing Data for Odometer
U1123 SCP (J1850) Invalid or Missing Data for Odometer
U1124 SCP (J1850) Invalid or Missing Data for Primary Id
U1125 SCP (J1850) Invalid or Missing Data for Primary Id
U1126 SCP (J1850) Invalid or Missing Data for Primary Id
U1127 SCP (J1850) Invalid or Missing Data for Primary Id
U1128 SCP (J1850) Invalid or Missing Data for Primary Id
U1129 SCP (J1850) Invalid or Missing Data for Primary Id
U1130 SCP (J1850) Invalid or Missing Data for Fuel System
U1131 SCP (J1850) Invalid or Missing Data for Fuel System
U1132 SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1133 SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1134 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1136 SCP (J1850) Invalid or Missing Data for Telltales
U1137 SCP (J1850) Invalid or Missing Data for Telltales
U1138 SCP (J1850) Invalid or Missing Data for Primary Id
U1139 SCP (J1850) Invalid or Missing Data for Primary Id
U1140 SCP (J1850) Invalid or Missing Data for Gateway
U1141 SCP (J1850) Invalid or Missing Data for Gateway
U1142 SCP (J1850) Invalid or Missing Data for Primary Id
U1143 SCP (J1850) Invalid or Missing Data for Primary Id
U1144 SCP (J1850) Invalid or Missing Data for Primary Id
U1145 SCP (J1850) Invalid or Missing Data for Primary Id
U1146 SCP (J1850) Invalid or Missing Data for Vehicle Security
U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security
U1148 SCP (J1850) Invalid or Missing Data for Audio Control
U1149 SCP (J1850) Invalid or Missing Data for Audio Control
U1150 SCP (J1850) Invalid or Missing Data for Audible Warnings
U1151 SCP (J1850) Invalid or Missing Data for Audible Warnings
U1152 SCP (J1850) Invalid or Missing Data for Experimental #3
U1153 SCP (J1850) Invalid or Missing Data for Experimental #3
U1154 SCP (J1850) Invalid or Missing Data for Compact Disc
U1155 SCP (J1850) Invalid or Missing Data for Compact Disc
U1156 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1157 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1158 SCP (J1850) Invalid or Missing Data for Antenna
U1159 SCP (J1850) Invalid or Missing Data for Antenna
U1160 SCP (J1850) Invalid or Missing Data for Primary Id
U1161 SCP (J1850) Invalid or Missing Data for Primary Id
U1162 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1163 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1164 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1165 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1166 SCP (J1850) Invalid or Missing Data for Cassette Tape
U1167 SCP (J1850) Invalid or Missing Data for Cassette Tape
U1168 SCP (J1850) Invalid or Missing Data for Primary Id
U1169 SCP (J1850) Invalid or Missing Data for Primary Id
U1170 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1171 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1172 SCP (J1850) Invalid or Missing Data for Remote Button Control
U1173 SCP (J1850) Invalid or Missing Data for Remote Button Control
U1174 SCP (J1850) Invalid or Missing Data for Primary Id
U1175 SCP (J1850) Invalid or Missing Data for Primary Id
U1176 SCP (J1850) Invalid or Missing Data for Primary Id
U1177 SCP (J1850) Invalid or Missing Data for Primary Id
U1178 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1179 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1180 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1181 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1182 SCP (J1850) Invalid or Missing Data for Primary Id
U1183 SCP (J1850) Invalid or Missing Data for Primary Id
U1184 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1185 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1186 SCP (J1850) Invalid or Missing Data for Primary Id
U1187 SCP (J1850) Invalid or Missing Data for Primary Id
U1188 SCP (J1850) Invalid or Missing Data for Primary Id
U1189 SCP (J1850) Invalid or Missing Data for Primary Id
U1190 SCP (J1850) Invalid or Missing Data for Primary Id
U1191 SCP (J1850) Invalid or Missing Data for Primary Id
U1192 SCP (J1850) Invalid or Missing Data for Primary Id
U1193 SCP (J1850) Invalid or Missing Data for Primary Id
U1194 SCP (J1850) Invalid or Missing Data for Mirrors
U1195 SCP (J1850) Invalid or Missing Data for Mirrors
U1196 SCP (J1850) Invalid or Missing Data for Door Locks
U1197 SCP (J1850) Invalid or Missing Data for Door Locks
U1198 SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1199 SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1200 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1201 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1202 SCP (J1850) Invalid or Missing Data for Windows
U1203 SCP (J1850) Invalid or Missing Data for Windows
U1204 SCP (J1850) Invalid or Missing Data for Steering Column
U1205 SCP (J1850) Invalid or Missing Data for Steering Column
U1206 SCP (J1850) Invalid or Missing Data for Primary Id
U1207 SCP (J1850) Invalid or Missing Data for Primary Id
U1208 SCP (J1850) Invalid or Missing Data for Seat Switches
U1209 SCP (J1850) Invalid or Missing Data for Seat Switches
U1210 SCP (J1850) Invalid or Missing Data for Restraints
U1211 SCP (J1850) Invalid or Missing Data for Restraints
U1212 SCP (J1850) Invalid or Missing Data for Primary Id
U1213 SCP (J1850) Invalid or Missing Data for Primary Id
U1214 SCP (J1850) Invalid or Missing Data for Primary Id
U1215 SCP (J1850) Invalid or Missing Data for Primary Id
U1216 SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1217 SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1218 SCP (J1850) Invalid or Missing Data for External Lamps
U1219 SCP (J1850) Invalid or Missing Data for External Lamps
U1220 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1221 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1222 SCP (J1850) Invalid or Missing Data for Interior Lamps
U1223 SCP (J1850) Invalid or Missing Data for Interior Lamps
U1224 SCP (J1850) Invalid or Missing Data for Primary Id
U1225 SCP (J1850) Invalid or Missing Data for Primary Id
U1226 SCP (J1850) Invalid or Missing Data for Body Status Request
U1227 SCP (J1850) Invalid or Missing Data for Body Status Request
U1228 SCP (J1850) Invalid or Missing Data for Tires
U1229 SCP (J1850) Invalid or Missing Data for Tires
U1230 SCP (J1850) Invalid or Missing Data for Electric Defrost
U1231 SCP (J1850) Invalid or Missing Data for Electric Defrost
U1232 SCP (J1850) Invalid or Missing Data for Navigation
U1233 SCP (J1850) Invalid or Missing Data for Navigation
U1234 SCP (J1850) Invalid or Missing Data for Displays
U1235 SCP (J1850) Invalid or Missing Data for Displays
U1236 SCP (J1850) Invalid or Missing Data for Memory Storage
U1237 SCP (J1850) Invalid or Missing Data for Memory Storage
U1238 SCP (J1850) Invalid or Missing Data for Experimental #4
U1239 SCP (J1850) Invalid or Missing Data for Experimental #4
U1240 SCP (J1850) Invalid or Missing Data for Primary Id
U1241 SCP (J1850) Invalid or Missing Data for Primary Id
U1242 SCP (J1850) Invalid or Missing Data for Exterior Environment
U1243 SCP (J1850) Invalid or Missing Data for Exterior Environment
U1244 SCP (J1850) Invalid or Missing Data for Interior Environment
U1245 SCP (J1850) Invalid or Missing Data for Interior Environment
U1246 SCP (J1850) Invalid or Missing Data for Primary Id
U1247 SCP (J1850) Invalid or Missing Data for Primary Id
U1248 SCP (J1850) Invalid or Missing Data for Time / Date
U1249 SCP (J1850) Invalid or Missing Data for Time / Date
U1250 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1251 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1252 SCP (J1850) Invalid or Missing Data for Class A Functions
U1253 SCP (J1850) Invalid or Missing Data for Class A Functions
U1254 SCP (J1850) Invalid or Missing Data for Network Control
U1255 SCP (J1850) Invalid or Missing Data for Network Control
U1260 SCP (J1850) Single Ended (+) Circuit Failure
U1261 SCP (J1850) Single Ended (-) Circuit Failure
U1262 SCP (J1850) Communication Bus Fault
U1308 SCP (J1850) Invalid or Missing Data for Function Read Engine Torque
U1341 SCP (J1850) Invalid or Missing Data for Function Read Vehicle Speed
U1430 SCP (J1850) Invalid or Missing Data for Function Read Fuel System
U1451 SCP (J1850) Invalid or Missing Data for Function Read Audible Warnings / Anti-Theft Module, Vehicle Immobilized
U1612 SCP (J1850) Lack of Acknowledgment for Primary Id
U1736 SCP (J1850) Lack of Acknowledgment for Telltales
U1750 SCP (J1850) Lack of Acknowledgment for Audible Warnings
U1794 SCP (J1850) Lack of Acknowledgment for Mirrors
U1797 SCP (J1850) Lack of Acknowledgment for Door Locks
U1798 SCP (J1850) Lack of Acknowledgment for External Access (Doors)
U1806 SCP (J1850) Lack of Acknowledgment for Primary Id
U1900 CAN Communication Bus Fault
U1950 UPB Communication Bus Fault
U2000 Audio Rear Control Unit is Not Responding
U2001 Audio Tape Deck Unit is Not Responding
U2002 Audio Bezel is Not Responding
U2003 Audio Compact Disk / Disk Jockey Unit is Not Responding
U2004 Audio Steering Wheel Control Unit is Not Responding
U2005 Audio Rear Integrated Control Panel Unit is Not Responding
U2006 Audio Remote Climate Control Unit is Not Responding
U2007 Audio Navigation Unit is Not Responding
U2008 Audio Phone is Not Responding
U2009 Audio Front Control Module (ACM) is Not Responding
U2010 Module is Not Responding (Non SCP)
U2011 Module Transmitted Invalid Data (Non SCP)
U2012 Communication Bus Error (Non SCP)
U2013 Compass Module is not Responding
U2014 Audio Subwoofer Unit is Not Responding
U2015 Signal Link Fault (Non SCP)
U2016 Signal Link Short to Ground (Non SCP) / From NGV Module
U2017 Driver Side Crash Sensor Communication Fault (Non SCP)
U2018 Passenger Side Crash Sensor Communication Fault (Non SCP)
U2019 Audio Voice Module Not Responding
U2020 Audio Center Amp is not responding
U2021 Invalid /fault data received (Non SCP)
U2150 SCP (J1850) Invalid Data from REM
U2152 SCP (J1850) Invalid Data from GEM
U2160 SCP (J1850) Invalid Data from IC
U2195 SCP (J1850) Invalid Data from SCLM
U2500 (CAN) Lack of Acknowledgement From Engine Management
FORD
P1000Monitor Checks Not Complete-More Driving Required
P1001KOER Not Able to Complete, KOER Aborted
P1100Mass Air Flow Sens Circ Interm.
P1101Mass Air Flow Sens Out Of Self Test Range
P1102Mass Air Flow Sens in Range / Lower Than Expected
P1103Mass Air Flow Sens in Range / Higher Than Expected
P1104Mass Air Flow Sens Circ Ground
P1105Dual Alternator Upper Fault (Monitor)
P1106Dual Alternator Lower Fault (Ctrl)
P1107Dual Alternator Lower Circ Error (Ctrl)
P1108Dual Alternator BATT Lamp Circ Error
P1109Intake Air Temp B Circ Interm.
P1110Intake Air Temp Circ (D/C) Open/Short
P1111Sys Pass (No DTCs Available)
P1112Intake Air Temp Circ Interm.
P1113Intake Air Temp Circ (L/C) Open/Short
P1114Intake Air Temp B Circ Low Input (S/T Charged Eng)
P1115Intake Air Temp B Circ High Input (S/T Charged Eng)
P1116Eng Coolant Temp Sens Out Of Self Test Range
P1117Eng Coolant Temp Sens Circ Interm.
P1118Manf Air Temp Sens Low Input
P1119Manf Air Temp Sens High Input
P1120Throttle Pos Sens A Out Of Range Low (Ratch low)
P1121Throttle Pos Sens A Inconsistent With MAF Sens
P1122Pedal Pos Sens A Circ Low Input
P1123Pedal Pos Sens A Circ High Input
P1124Throttle Pos Sens A Out Of Self Test Range
P1125Throttle Pos Sens A Interm.
P1126Throttle Pos (Narrow Range) Sens Circ
P1127Exhaust Not Warm, Downstream O2 Sens Not Tested
P1128Upstream HO2S Sens Swapped
P1129Downstream HO2S Sens Swapped
P1130Lack Of HO2S11 Switch - Fuel Trim At Limit
P1131Lack Of HO2S11 Switch - Sens Indicates Lean
P1132Lack Of HO2S11 Switch - Sens Indicates Rich
P1133bank1 Fuel Ctrl Shifted Lean (FAOSC)
P1134bank1 Fuel Ctrl Shifted Rich (FAOSC)
P1135Pedal Position Sens A Circ Interm.
P1136Ctrl Box Fan Circ
P1137Lack Of HO2S12 Switch - Sens Indicates Lean
P1138Lack Of HO2S12 Switch - Sens Indicates Rich
P1139Water in Fuel Indicator Circ Error
P1140Water in Fuel Condition
P1141Fuel Restriction Indicator Circ
P1142Fuel Restriction Condition
P1143Air Assisted Injector Ctrl Valve Range/Perf
P1144Air Assisted Injector Ctrl Valve Circ
P1150Lack Of HO2S21 Switch - Fuel Trim At Limit
P1151Lack Of HO2S21 Switch - Sens Indicates Lean
P1152Lack Of HO2S21 Switch - Sens Indicates Rich
P1153bank2 Fuel Ctrl Shifted Lean (FAOSC)
P1154bank2 Fuel Ctrl Shifted Rich (FAOSC)
P1155Alternative Fuel Ctrl Mod Has Activated the MIL
P1156Fuel Select Switch Circ
P1157Lack Of HO2S22 Switch - Sens Indicates Lean
P1158Lack Of HO2S22 Switch - Sens Indicates Rich
P1159Fuel Stepper Motor
P1167Invalid Test - Operator Did Not Actuate Throttle
P1168Fuel Rail Pres Sens In Range But Low
P1169Fuel Rail Pres Sens In Range But High
P1170Eng Shut Off Solenoid
P1171Rotor Sens
P1172Rotor Ctrl
P1173Rotor Calibration
P1174Cam Sens
P1175Cam Ctrl
P1176Cam Calibration
P1177Synchronization
P1178Boltup Limits
P1179Long Term Fuel Trim Too Rich - Banks 1 & 2
P1180Fuel Delivery System - Low
P1181Fuel Delivery System - High
P1182Fuel Shutoff Solenoid Circ
P1183Eng Oil Temp Sens Circ
P1184Eng Oil Temp Sens Circ Perf
P1185Fuel Pump Temp Sens High
P1186Fuel Pump Temp Sens Low
P1187Variant Selection
P1188Calibration Mem
P1189Pump Speed Signal
P1190Calibration Resistor Out Of Range
P1191Key Line Voltage
P1192V External
P1193EGR Dvr Over Current
P1194ECM/PCM A/D Converter
P1195SCP HBCC Chip Failed to Initialize
P1196Key Off Voltage High
P1197Key Off Voltage Low
P1198Pump Rotor Ctrl Under-fueling
P1199Fuel Level Input Circ Low
P1201Cylinder #1 Injector Circ Open/Shorted
P1202Cylinder #2 Injector Circ Open/Shorted
P1203Cylinder #3 Injector Circ Open/Shorted
P1204Cylinder #4 Injector Circ Open/Shorted
P1205Cylinder #5 Injector Circ Open/Shorted
P1206Cylinder #6 Injector Circ Open/Shorted
P1207Cylinder #7 Injector Circ Open/Shorted
P1208Cylinder #8 Injector Circ Open/Shorted
P1209Injection Ctrl System Pres Peak Fault
P1210Injection Ctrl Pres Expected Level
P1211ICP Not Ctrllable - Pres Above/Desired
P1212ICP Voltage Not at Expected Level
P1214Pedal Position Sens B Circ Interm.
P1215Pedal Position Sens C Circ Low Input
P1216Pedal Position Sens C Circ High Input
P1217Pedal Position Sens C Circ Interm.
P1218CID Stuck High
P1219CID Stuck Low
P1220Series Throttle Ctrl System
P1221Traction Ctrl System
P1222Pedal Position Sens B Circ Low Input
P1223Pedal Position Sens B Circ High Input
P1224Throttle Position Sens B Out Of Self Test Range
P1225Injector Circ Cylinder 2 Interm.
P1226Ctrl Sleeve Sens Circ
P1227Wastegate Failed Closed (Over Pres)
P1228Wastegate Failed Open (Under Pres)
P1229Charge Air Cooler Pump Dvr
P1230Fuel Pump Low Speed Error (VLCM)
P1231Fuel Pump Sec Circ Low, High Speed (VLCM)
P1232Fuel Pump Speed Primary Circ(Two speed fuel pump)
P1233Fuel Pump Dvr Mod Disabled/Off Line
P1234Fuel Pump Dvr Mod Disabled/Off Line
P1235Fuel Pump Ctrl out Of Range
P1236Fuel Pump Ctrl Out Of Range
P1237Fuel Pump Sec Circ
P1238Fuel Pump Sec Circ
P1239Speed Fuel Pump Positive Feed
P1240Injector Circ Cylinder 7 Interm.
P1243Injector Circ Cylinder 8 Interm.
P1244Alternator Load High Input
P1245Alternator Load Low Input
P1246Alternator Load Input
P1247Turbo Boost Pres Low
P1248Turbo Boost Pres Not Detected
P1249Wastegate Fail Steady State Test
P1250Electronic Passive Anti-Theft System
P1252Pedal Correlation PDS1 and LPDS High
P1253Pedal Correlation PDS1 and LPDS Low
P1254Pedal Correlation PDS2 and LPDS High
P1255Pedal Correlation PDS2 and LPDS Low
P1256Pedal Correlation PDS1 and HPDS
P1257Pedal Correlation PDS2 and HPDS
P1258Pedal Correlation PDS1 and PDS2
P1260Theft Detected, Vehicle Immobilized
P1261High to Low Side Short - Cylinder 1
P1262High to Low Side Short - Cylinder 2
P1263High to Low Side Short - Cylinder 3
P1264High to Low Side Short - Cylinder 4
P1265High to Low Side Short - Cylinder 5
P1266High to Low Side Short - Cylinder 6
P1267High to Low Side Short - Cylinder 7
P1268High to Low Side Short - Cylinder 8
P1270Eng RPM/Vehicle Speed Limiter Reached
P1271High to Low Side Open - Cylinder 1
P1272High to Low Side Open - Cylinder 2
P1273High to Low Side Open - Cylinder 3
P1274High to Low Side Open - Cylinder 4
P1275High to Low Side Open - Cylinder 5
P1276High to Low Side Open - Cylinder 6
P1277High to Low Side Open - Cylinder 7
P1278High to Low Side Open - Cylinder 8
P1280ICP Circ Out of Range Low
P1281ICP Circ Out of Range High
P1282Excessive ICP
P1283Injector Pres Regulator Circ
P1284ICP Failure - Aborts KOER/CCT Test
P1285Cylinder Head Overtemp Condition
P1286Fuel Pulsewidth in Range But Lower Than Expected
P1287Fuel Pulsewidth in Range But Higher Than Expected
P1288Cylinder Head Temp Sens Out Of Self Test Range
P1289Cylinder Head Temp Sens Circ High Input
P1290Cylinder Head Temp Sens Circ Low Input
P1291High Side No. 1 (Right) Short to GND/B+
P1292High Side No. 2 (Left) Short to GND/B+
P1293High Side Open Bank No. 1 (Right)
P1294High Side Open Bank No. 2 (Left)
P1295Multiple Faults on Bank No. 1 (Right)
P1296Multiple Faults on Bank No. 2 (Left)
P1297High Sides Shorted Together
P1298Injector Dvr Mod Failure
P1299Cylinder Head Overtemp Protection Active
P1300Boost Calibration Fault
P1301Boost Calibration High
P1302Boost Calibration Low
P1303Exhaust Gas Recirculation Calibration Fault
P1304Exhaust Gas Recirculation Calibration High
P1305Exhaust Gas Recirculation Calibration Low
P1306Kickdown Relay Pull-in Circ
P1307Kickdown Relay Hold Circ
P1309 Misfire Mon Hdwr-CMP Misaligned, CKP/CMP Noise,PCM AICE Chip
P1310Ionization Misfire Detect Mod Fault
P1311Ionization Misfire Detect Mod Comm Fault
P1316Injector Circ/IDM Codes Detected
P1317Injector Circ/IDM Codes Not Retrieved
P1336Crankshaft Position System Variation Not Learned
P1340Camshaft Position Sens B Circ
P1350Ignition Ctrl System
P1351Ignition Diag Monitor Input Circ
P1352Ignition Coil A Primary Circ
P1353Ignition Coil B Primary Circ
P1354Ignition Coil C Primary Circ
P1355Ignition Coil D Primary Circ
P1356Ignition Diag Monitor Indicates Eng Not Turning
P1357Ignition Diag Monitor Pulsewidth Not Defined
P1358Ignition Diag Monitor Signal Out Of Self Test Range
P1359Spark Output Circ
P1360Ignition Coil A Sec Circ
P1361Ignition Coil B Sec Circ
P1362Ignition Coil C Sec Circ
P1363Ignition Coil D Sec Circ
P1364Ignition Coil Primary Circ
P1365Ignition Coil Sec Circ
P1366Ignition Spare
P1367Ignition Spare
P1368Ignition Spare
P1369Eng Temp Light Circ
P1380Camshaft Position Actuator Circ (bank1)
P1381Camshaft Position Timing Over Advanced (bank1)
P1383Camshaft Position Timing Over Retarded (bank1)
P1385Camshaft Position Actuator Circ (bank2)
P1386Camshaft Position Timing Over Advanced (bank2)
P1388Camshaft Position Timing Over Retarded (bank2)
P1389Glow Plug Circ High Side, Low Input
P1390Octane Adjust Service Pin In Use/Circ Open
P1391Glow Plug Circ Low Input Bank No. 1(Right)
P1392Glow Plug Circ High Input (bank1)
P1393Glow Plug Circ Low Input Bank No. 2 (Left)
P1394Glow Plug Circ High Input (bank2)
P1395Glow Plug Monitor Fault Bank No. 1
P1396Glow Plug Monitor Fault Bank No. 2
P1397System Voltage Out of Self Test Range
P1398Wheel Speed Sens2 - G - Sens Circ High Voltage
P1399Glow Plug Circ High Side, High Input
P1400Diff Pres Feedback EGR Circ Low Input
P1401Diff Pres Feedback EGR Circ High Input
P1402Exhaust Gas Recirculation Metering Orifice Restricted
P1403Diff Pres Feedback Sens Hoses Reversed
P1404EGR Temp Sens Circ
P1405Diff Pres Feedback Sens Upstream Hose Off/Plugged
P1406Diff Pres Feedback Sens Downstream Hose Off/Plugged
P1407Exhaust Gas Recirculation No Flow Detected
P1408Exhaust Gas Recirculation Flow Out Of Self Test Range
P1409EGR Vacuum Regulator Solenoid Circ
P1410Auxiliary Air Cleaner Inlet Ctrl Circ
P1411Sec Air Injection Incorrect Downstream Flow Detected
P1413Sec Air Injection Monitor Circ Low Input
P1414Sec Air Injection Monitor Circ High Input
P1431Misfire Monitor Disabled, unable to learn trig whl profile
P1442Evap Emission Ctrl System Ctrl Leak Detected
P1443Evap Emission Ctrl System Ctrl Valve
P1444Purge Flow Sens Circ Low Input
P1445Purge Flow Sens Circ High Input
P1450Unable to Bleed Up Fuel Tank Vacuum
P1451Evap Emission Ctrl System Vent Ctrl Circ
P1452Unable to Bleed Up Fuel Tank Vacuum
P1455Evap Emission Ctrl Sys Ctrl Leak (gross leak/no flow)
P1456Fuel Tank Temp Sens Circ
P1457Unable To Pull Fuel Tank Vacuum
P1460Wide Open Throttle A/C Cutout Circ
P1461A/C Pres Sens Circ High Input
P1462A/C Pres Sens Circ Low Input
P1463A/C Pres Sens Insuff Pres Change
P1464A/C On During KOER/CCT Test
P1465A/C Relay Circ
P1466A/C Refrigerant Temp Sens Circ
P1469Rapid A/C Cycling
P1473Fan Circ Open (VLCM
P1474Fan Ctrl Primary Circ
P1479High Fan Ctrl Primary Circ
P1480Fan Sec Low with Low Fan On
P1481Fan Sec Low with High Fan On
P1482SCP
P1483Fan Circ Shorted To Ground (VLCM)
P1484Fan Dvr Circ Open To Power Ground (VLCM)
P1485Brake Pedal Input Short To Battery
P1500Vehicle Speed Sens
P1501Vehicle Speed Sens Out Of Self Test Range
P1502VSS Interm./Invalid Self Test - APCM Functioning
P1504Idle Air Ctrl Circ
P1505Idle Air Ctrl System At Adaptive Clip
P1506Idle Air Ctrl Overspeed Error
P1507Idle Air Ctrl Underspeed Error
P1512Intake Manf Runner Ctrl Stuck Closed (bank1)
P1513Intake Manf Runner Ctrl Stuck Closed (bank2)
P1516Intake Manf Runner Ctrl Input Error (bank1)
P1517Intake Manf Runner Ctrl Input Error (bank2)
P1518Intake Manf Runner Ctrl Stuck Open (bank1)
P1519Intake Manf Runner Ctrl Stuck Closed (bank2)
P1520Intake Manf Runner Ctrl Circ
P1530A/C Clutch Circ Open (VLCM)
P1531Invalid Test -Accelerator Pedal Movement
P1532Intake Manf Comm Ctrl Circ (bank2)P1533
P1534Restraint Deployment Indicator Circ
P1536Parking Brake Applied Failure
P1537Intake Manf Runner Ctrl Stuck Open (bank1)
P1538Intake Manf Runner Ctrl Stuck Open (bank2)
P1539A/C Clutch Circ Overcurrent/Short (VLCM)
P1542Primary PCM ID Circ (dual PCM application)
P1543Eng Coolant heater A Ctrl Circ
P1544Eng Coolant heater B Ctrl Circ
P1549Intake Manf Comm Ctrl Circ (bank1)
P1550Power Steering Pres Sens Out Of Self Test Range
P1565Speed Ctrl Command Switch Out of Range High
P1566Speed Ctrl Command Switch Out of Range Low
P1567Speed Ctrl Output Circ
P1568Speed Ctrl Unable to Hold Speed
P1572Brake Pedal Switch Circ
P1573Throttle Position Not Available
P1574Throttle Position Sens Outputs Disagree
P1575Pedal Position Out Of Self Test Range
P1576Pedal Position Not Available
P1577Pedal Position Sens Outputs Disagree
P1578ETC Power Less Than Demand
P1579ETC In Power Limiting Mode
P1580Electronic Throttle Monitor PCM Override
P1581Electronic Throttle Monitor Error
P1582Electronic Throttle Monitor Data Available
P1583Electronic Throttle Monitor Cruise Disablement
P1584Throttle Ctrl Detected ETB Error
P1585Throttle Ctrl Error
P1586Electronic Throttle to PCM Comm Error
P1587Throttle Ctrl Modulated Command Error
P1588Throttle Ctrl Detected Loss Of Return Spring
P1589Throttle Ctrl Unable To Ctrl To Desired Throttle Angle
P1600Loss Of KAM Power, Circ Open
P1605Keep Alive Memory Test Failure
P1610SBDS Interactive Codes
P1611SBDS Interactive Codes
P1612SBDS Interactive Codes
P1613SBDS Interactive Codes
P1614SBDS Interactive Codes
P1615SBDS Interactive Codes
P1616SBDS Interactive Codes
P1617SBDS Interactive Codes
P1618SBDS Interactive Codes
P1619SBDS Interactive Codes
P1620SBDS Interactive Codes
P1625Fan Dvr Circ Open to Power B+ (VLCM)
P1626A/C Circ Open to Power B+ (VLCM)
P1633Keep Alive Power Voltage Too Low
P1634Data Output Link Circ
P1635Tire/Axle Out of Acceptable Range
P1636Inductive Signature Chip Comm Error
P1639Vehicle ID Block Corrupted, Not Programmed
P1640Powertrain DTCs Available In Another Ctrl Mod
P1641Fuel Pump Primary Circ
P1642CAN Link Circ
P1643CAN Link Eng Ctrl Mod/Tran Ctrl Mod Circ/Network
P1644Fuel Pump Speed Ctrl Circ
P1650Power Steering Pres Switch Out Of Self Test Range
P1651Power Steering Pres Switch Input
P1656CAN Link PCM/PCM Circ/Network
P1657CAN Link Chip Error
P1660Output Circ Check Circ High Input
P1661Output Circ Check Circ Low Input
P1662EDU_EN Output Circ
P1663Fuel Demand Command Signal Output Circ Failure
P1667Cylinder ID Circ Failure
P1668PCM/IDM Diagnostic Comm Error
P1670EF Feedback Signal Not Detected
P1690Wastegate Ctrl Valve Error
P1700Tran Indeterminate Failure (Failed to Neutral)
P1701Reverse Engagement Error
P1702Tran Range Sens Interm. Circ Error
P1703Brake Switch Out Of Self Test Range
P1704Tran Range Sens Failed to Transition State or Tran Range Sens out of Self Test Range
P1705Tran Range Circ Not Indicating P/N in Self test
P1706High Vehicle Speed Observed in Park
P1707Transfer Case Neutral Indicator Hard Fault Present
P1709Park Neutral Position Switch Out Of Self Test Range
P1711Tran Fluid Temp Sens Out Of Self Test Range
P1712Tran Torque Reduction Request Signal
P1713Tran Fluid Temp Sens In Range Failure(< 50 F)
P1714Shift Solenoid A Inductive Signature
P1715Shift Solenoid B Inductive Signature Error
P1716Shift Solenoid C Inductive Signature
P1717Shift Solenoid D Inductive Signature
P1718TFT Stuck in Range High-25OF
P1725Insuff Eng Speed Increase During Self Test
P1726Insuff Eng Speed Decrease During Self Test
P1727Coast Clutch Solenoid Inductive Signature
P1728Tran Slip Error
P17294x4L Switch Error
P17311-2 Shift Error
P17322-3 Shift Error
P17333-4 Shift Error
P1740Torque Converter Clutch Solenoid Inductive Signal
P1741Torque Converter Clutch Solenoid Ctrl Error
P1742Torque Converter Clutch Solenoid Circ Failed On
P1743Torque Converter Clutch Solenoid Circ Failed On*
P1744Torque Converter Clutch System Perf
P1746EPC Solenoid Open Circ
P1747EPC Solenoid Short Circ
P1748Pres Ctrl Solenoid A
P1749Pres Ctrl Solenoid A Failed Low
P1751Shift Solenoid A Perf
P1754Coast Clutch Solenoid Circ Error
P1756Shift Solenoid B Perf
P1760EPC Solenoid Short Interm.
P1761Shift Solenoid C Perf
P1762Overdrive Band Failed Off
P1766Shift Solenoid D Perf
P1767Torque Converter Clutch Circ
P1768Perf/Normal/Winter Mode Input
P1770Clutch Solenoid Circ
P1779TCIL Circ
P1780TCS Circ Out of self Test Range
P17814x4L Circ Out of Self Test Range
P1782Perf/Economy Switch Circ Out Of Self Test Range
P1783Tran Overtemp Condition
P1784Tran Mechanical Failure - 1st And Reverse
P1785Tran Mechanical Failure - 1st And 2nd
P17863-2 Downshift Error
P17872-1 Downshift Error
P1788Pres Ctrl Solenoid B Open Circ
P1789Pres Ctrl Solenoid B Short Circ
P1795Inconsistent CAN Level
P18044WD High Indicator Circ Open/Shorted To Ground
P18064WD High Indicator Short To Battery
P18084WD Low Indicator Circ Open/Short To Ground
P18104WD Low Indicator Short To Battery
P18124WD Mode Select Switch Circ Open
P18154WD Mode Select Switch Circ Short To Ground
P1819Neutral Safety Switch Input Short To Ground
P1820Transfer Case LO/HI Shift Relay Circ Open/Short To Gnd
P1822Transfer Case LO/HI Shift Relay Coil Short To Battery
P18244WD Electric Clutch Relay Open/Short To Ground
P18264WD Electric Clutch Relay Short To Battery
P1828Transfer Case HI/LO Shift Relay Coil Circ Open/Short to Gnd
P1830Transfer Case HI/LO Shift Relay Coil Circ Short To Battery
P1832Transfer Case 4WD Solenoid Circ Open/Short To Gnd
P1834Transfer Case 4WD Solenoid Circ Short To Battery
P1838No Shift Motor Movement Detected
P1846Transfer Case Contact Plate 'A' Circ Open
P1850Transfer Case Contact Plate 'B' Circ Open
P1854Transfer Case Contact Plate 'C' Circ Open
P1858Transfer Case Contact Plate 'D' Circ Open
P1865Transfer Case Contact Plate Power Short to Ground
P1866Transfer Case Cannot Be Shifted
P1867Transfer Case Contact Plate General Circ Failure
P1876Transfer Case 2WD Solenoid Circ Open/Short To Gnd
P1877Transfer Case 2WD Solenoid Circ Short To Battery
P1881Eng Coolant Level Switch Circ
P1882Eng Coolant Level Switch Circ Short To Ground
P1883Eng Coolant Level Switch Circ
P1884Eng Coolant Level Lamp Circ Short To Ground
P1891Transfer Case Contact Plate Gnd Return Open Circ
P1900Output Shaft Speed Sens Circ Interm.
P1901Turbine Shaft Speed Sens Circ Interm.
P1902Kickdown Solenoid Relay Ctrl Circ (Allison)
P1903Kickdown Solenoid Circ Low Voltage
P1904Kickdown Solenoid Circ High Voltage
U1058J1850 SCP Trans Fluid Temp Invalid ЁC Instr Clstr
U1059J1850 SCP Trans/Transaxle PRNDL invalid-Instr Clstr
U1073J1850 SCP Engine Coolent Invalid ЁC Instr Clstr
U1262J1850 SCP Comm Bus Fault ЁC Instr Clstr
U1950UBP Comm Bus Fault - DSM,or UBP Comm Bus Fault - VSM,or UBP Comm Bus Fault ЁC Instr Clstr
Geo
P1250Early fuel evaporation heater circuit fault
P1300Ignition Coil 1 Primary Feedback Circuit
P1305Ignition Coil 2 Primary Feedback Circuit
P1310Ignition Coil 3 Primary Feedback Circuit
P1315Ignition Coil 4 Primary Feedback Circuit
P1335Crankshaft position sensor circuit
P1346Intake Camshaft Position System Performance
P1349Intake Camshaft Position System
P1408MAP Sensor Circuit
P1410Fuel tank pressure system fault
P1450Barometric pressure sensor circuit fault
P1451Barometric pressure sensor performance
P1460Cooling fan control system fault
P1500Starter signal circuit fault
P1510Backup power supply fault
P1520Stop Lamp Switch Circuit
P1530Ignition timing adjustment switch circuit
P1600PCM battery circuit fault
P1656Intake CMP Actuator Solenoid Control Circuit
GM
P1031Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
P1032Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
P1101Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
P1105Secondary Vacuum Sensor Circuit
P1106Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108BARO to MAP Sensor Comparison Too High
P1109Secondary Port Throttle System
P1111Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113Intake Resonance Switchover Solenoid Control Circuit
P1114Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
P1115Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
P1116ECT Signal Unstable or Intermittent
P1117Engine Coolant Temp. Signal Out-Of-Range Low
P1118Engine Coolant Temp. Signal Out-Of-Range High
P1119ECT Signal Out-Of-Range With TFT Sensor
P1120Throttle Position (TP) Sensor 1 Circuit
P1121Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1125Accelerator Pedal Position (APP) System
P1130Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1
P1131Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
P1132Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
P1133Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
P1135Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1
P1136Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1
P1137Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
P1138Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
P1139Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2
P1140Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2
P1141Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P1143Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage
P1144Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage
P1145Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3
P1153Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1155Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
P1156Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
P1157Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage
P1158Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage
P1159Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2
P1161Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2
P1163Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage
P1164Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage
P1165Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3
P1170Bank to Bank Fuel Trim Offset
P1171Fuel System Lean During Acceleration
P1172Fuel Transfer Pump Flow Insufficient
P1185Engine Oil Temperature Circuit
P1186EOT Circuit Performance
P1187EOT Sensor Circuit Low Voltage
P1188EOT Sensor Circuit High Voltage
P1189Engine Oil Pressure (EOP) Switch Circuit
P1190Engine Vacuum Leak
P1191Intake Air Duct Air Leak
P1200Injector Control Circuit
P1201(Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
P1202(Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
P1203(Alt. Fuel) Gas Mass Sensor Circuit High Frequency
P1211Mass Air Flow Circuit Intermittent High
P1212Mass Air Flow Circuit Intermittent Low
P1214Injection Pump Timing Offset
P1215Ground Fault Detection Indicated
P1216Fuel Solenoid Response Time Too Short
P1217Fuel Solenoid Response Time Too Long
P1218Injection Pump Calibration Circuit
P1219Throttle Position Sensor Reference Voltage
P1220Throttle Position (TP) Sensor 2 Circuit
P1221Fuel Pump Secondary Circuit Low
P1222Injector Control Circuit Intermittent
P1225Injector Circuit Cylinder 2 Intermittent
P1228Injector Circuit Cylinder 3 Intermittent
P1231Injector Circuit Cylinder 4 Intermittent
P1234Injector Circuit Cylinder 5 Intermittent
P1237Injector Circuit Cylinder 6 Intermittent
P1240Injector Circuit Cylinder 7 Intermittent
P1243Injector Circuit Cylinder 8 Intermittent
P1245Intake Plenum Switchover Valve
P1250Early Fuel Evaporation Heater Circuit
P1257Supercharger System Overboost
P1258Engine Coolant Overtemperature - above 268ЎгF - Protection Mode Active
P1260Last Test Failed Failed SCC ENTER:More Info.
P1270Accelerator Pedal Position Sensor A/D Converter Error
P1271Accelerator Pedal Position (APP) Sensor 1-2 Correlation
P1272Accelerator Pedal Position Sensor 2
P1273"Accelerator Pedal Position Sensor 1
P1274Injectors Wired Incorrectly
P1275Accelerator Pedal Position (APP) Sensor 1 Circuit
P1276Accelerator Pedal Position Sensor 1 Circuit Performance
P1277Accelerator Pedal Position Sensor 1 Circuit Low Voltage
P1278Accelerator Pedal Position Sensor 1 Circuit High Voltage
P1280Accelerator Pedal Position (APP) Sensor 2 Circuit
P1281Accelerator Pedal Position Sensor 2 Circuit Performance
P1282Accelerator Pedal Position Sensor 2 Circuit Low Voltage
P1283Accelerator Pedal Position Sensor 2 Circuit High Voltage
P1285Accelerator Pedal Position Sensor 3 Circuit
P1286Accelerator Pedal Position Sensor 3 Circuit Performance
P1287Accelerator Pedal Position Sensor 3 Circuit Low Voltage
P1288Accelerator Pedal Position Sensor 3 Circuit High Voltage
P1300Ignitor Circuit
P1320IC 4X Reference Circuit Intermittent
P1321Electronic Ignition System Fault Line
P1322EI System or Ignition Control Extra or Missing
P1323IC 24X Reference Circuit Low Frequency
P1324Crank RPM Too Low
P1335CKP Circuit
P1336Crankshaft Position (CKP) System Variation Not Learned
P1345Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
P1346Intake Camshaft Position [CMP] Sensor System Performance
P1350Ignition Control System
P1351Ignition Coil Control Circuit High Voltage
P1352IC Output High/Pulse Detected when GND_Cyl. 2
P1353IC Output High/Pulse Detected when GND_Cyl. 3
P1354IC Output High/Pulse Detected when GND_Cyl. 4
P1355IC Output High/Pulse Detected when GND_Cyl. 5
P1356IC Output High/Pulse Detected when GND_Cyl. 6
P1357IC Output High/Pulse Detected when GND_Cyl. 7
P1358IC Output High/Pulse Detected when GND_Cyl. 8
P1359Ignition Coil Group 1 Control Circuit
P1360Ignition Coil Group 2 Control Circuit
P1361Ignition Coil Control Circuit Low Voltage
P1362IC Cylinder 2 Not Toggling After Enable
P1363IC Cylinder 3 Not Toggling After Enable
P1364IC Cylinder 4 Not Toggling After Enable
P1365IC Cylinder 5 Not Toggling After Enable
P1366IC Cylinder 6 Not Toggling After Enable
P1367IC Cylinder 7 Not Toggling After Enable
P1368IC Cylinder 8 Not Toggling After Enable
P1370IC 4X Reference Circuit Too Many Pulses
P1371IC 4X Reference Circuit Too Few Pulses
P1372Crankshaft Position (CKP) Sensor A-B Correlation
P13743X Reference Circuit
P1375IC 24X Reference Circuit High Voltage
P1376Ignition Ground Circuit
P1377IC Cam Pulse To 4X Reference Pulse
P1380Misfire Detected - Rough Road Data Not Available
P1381Misfire Detected - No Communication with Brake Control Module
P1390Wheel Speed Sensor 1 - G - Sensor Circuit
P1391Wheel Speed Sensor 1 - G - Sensor Circuit Performance
P1392Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
P1393Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
P1394Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
P1395Wheel Speed Sensor 2 - G - Sensor Circuit
P1396Wheel Speed Sensor 2 - G - Sensor Circuit Performance
P1397Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
P1398Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
P1399Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
P1401Exhaust Gas Recirculation (EGR) flow test fault
P1403Exhaust Gas Recirculation System Valve 1
P1404Exhaust Gas Recirculation (EGR) Closed Position Performance
P1405Exhaust Gas Recirculation System Valve 3
P1406EGR Valve Pintle Position Circuit
P1407EGR Air Intrusion in Exhaust Supply to EGR Valve
P1408Intake Manifold Pressure Sensor Circuit
P1409EGR Vacuum System Leak
P1410Fuel Tank Pressure System
P1415Secondary Air Injection (AIR) System Bank 1
P1416Secondary Air Injection (AIR) System Bank 2
P1418Secondary Air Injection System Relay A Control Circuit High
P1420Intake Air Low Pressure Switch Circuit Low Voltage
P1421Intake Air Low Pressure Switch Circuit High Voltage
P1423Intake Air High Pressure Switch Circuit High Voltage
P1431Fuel Level Sensor 2 Circuit Performance
P1432Fuel Level Sensor 2 Circuit Low Voltage
P1433Fuel Level Sensor 2 Circuit High Voltage
P1441Evaporative Emission (EVAP) System Flow During Non-Purge
P1442EVAP Vacuum Sw. High Voltage During Ign. On
P1450Barometric Pressure Sensor Circuit
P1451Barometric Press. Sensor Performance
P1460Cooling Fan Control System
P1480Cooling Fan 1 Control Circuit High
P1481Cooling Fan Speed Sensor Circuit
P1482Cooling Fan Speed Output Circuit
P1483Engine Cooling System Performance
P1484Cooling Fan System Performance
P1500Starter Signal Circuit
P1501Theft Deterrent System
P1501Vehicle Speed Sensor Circuit Intermittent
P1502Theft Deterrent Fuel Enable Signal Not Received
P1503Theft Deterrent Fuel Enable Signal Not Correct
P1504Vehicle Speed Output Circuit
P1508Idle Speed Low - Idle Air Control (IAC) System Not Responding
P1509Idle Speed High - Idle Air Control (IAC) System Not Responding
P1510Throttle Control System Performance - Throttle Limitation Active
P1511Throttle Control System - Backup System Performance
P1514Airflow to TP Sensor Correlation High
P1515Electronic Throttle System Throttle Position
P1516Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
P1517Electronic Throttle Module
P1518Electronic Throttle Module to PCM Communication
P1519Throttle Actuator Control (TAC) Module Internal Circuit
P1520Transmission Range Switch Circuit
P1521Transmission Engaged at High Throttle Angle
P1522Park/Neutral to Drive/Reverse at High RPM
P1523Throttle Closed Position Performance
P1524Throttle Closed Position Performance
P1525Throttle Body ServiceRequired
P1526Minimum Throttle Position Not Learned
P1527Transmission Range to Pressure Switch Correlation
P1528Governor
P1529Heated Windshield Request Problem
P1530Throttle Actuator Control (TAC) Module Internal Circuit
P1531A/C Low Side Temperature Sensor Fault
P1532A/C Evaporator Temp. Sens. Circuit Low Voltage
P1533A/C Evaporator Temp. Sens. Circuit High Voltage
P1534A/C High Side Temp. Sensor Low Voltage
P1535A/C High Side Temperature Sensor Circuit
P1536Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
P1537A/C Request Circuit Low Voltage
P1538A/C Request Circuit High Voltage
P1539A/C Clutch Status Circuit High Voltage
P1540Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
P1541A/C High Side Over Temperature
P1542A/C System High Pressure High Temperature
P1543A/C System Performance
P1544A/C Refrigerant Condition Very Low
P1545Air Conditioning (A/C) Clutch Relay Control Circuit
P1546A/C Clutch Status Circuit Low Voltage
P1547A/C System Performance Degraded
P1548A/C Recirculation Circuit
P1551Throttle Valve Rest Position Not Reached During Learn
P1554Cruise Control Feedback Circuit
P1555Electronic Variable Orifice Output
P1558Cruise Control Servo Indicates Low
P1559Cruise Control Power Management Mode
P1560Transaxle Not in Drive - Cruise Control Disabled
P1561Cruise Vent Solenoid
P1562Cruise Vacuum Solenoid
P1563Cruise Vehicle Speed/Set Speed Difference Too High
P1564Vehicle Acceleration Too High - Cruise Control Disabled
P1565Cruise Servo Position Sensor
P1566Engine RPM Too High - Cruise Control Disabled
P1567Active Banking Control Active - Cruise Control Disabled
P1568Cruise Servo Stroke Greater than Commanded in Cruise
P1569Cruise Servo Stroke High While not in Cruise
P1570Traction Control Active - Cruise Control Disabled
P1571Traction Control Torque Request Circuit
P1572ASR Active Circuit Low Too Long
P1573PCM/EBTCM Serial Data Circuit
P1574Stoplamp Switch Circuit
P1575Extended Travel Brake Switch Circuit
P1576BBV Sensor Circuit High Voltage
P1577BBV Sensor Circuit Low Voltage
P1578BBV Sensor Circuit Low Vacuum
P1579P/N to D/R at High Throttle Angle - Power Reduction Mode Active
P1580Cruise Move Circuit Low Voltage
P1581Cruise Move Circuit High Voltage
P1582Cruise Direction Circuit Low Voltage
P1583Cruise Direction CircuitHigh Voltage
P1584Cruise Control Disabled
P1585Cruise Control Inhibit Output Circuit
P1586Cruise Control Brake Switch 2 Circuit
P1587Cruise Control Clutch Control Circuit Low
P1588Cruise Control Clutch Control Circuit High
P1599Engine Stall or Near Stall Detected
P1600TCM Internal Watchdog Operation
P1601Serial Comm. Problem With Device 1
P1602Knock Sensor (KS) Module Performance
P1603Loss of SDM Serial Data
P1604Loss of IPC Serial Data
P1605Loss of HVAC Serial Data
P1606Serial Communication Problem With Device 6
P1607Serial Communication Problem With Device 7
P1608Serial Communication Problem With Device 8
P1609Loss Of TCS Serial Data
P1610Loss Of PZM Serial Data
P1611Loss Of CVRTD Serial Data
P1612Loss Of IPM Serial Data
P1613Loss Of DIM Serial Data
P1614Loss Of RIM Serial Data
P1615Loss Of VTD Serial Data
P1617Engine Oil Level Switch Circuit
P1619Engine Oil Life Monitor Reset Circuit
P1620Low Coolant Circuit
P1621Control Module Long Term Memory Performance
P1622Cylinder Select
P1623Transmission Temp Pull-Up Resistor
P1624Customer Snapshot Requested - Data Available
P1625TCM System Reset
P1626Theft Deterrent Fuel Enable Signal Not Received
P1627A/D Performance
P1628ECT Pull-Up Resistor
P1629Theft Deterrent System - Cranking Signal
P1630Theft Deterrent Learn Mode Active
P1631Theft Deterrent Start Enable Signal Not Correct
P1632Theft Deterrent Fuel Disable Signal Received
P1633Ignition 0 Switch Circuit
P1634Ignition 1 Switch Circuit
P16355 Volt Reference Circuit
P1636PCM Stack Overrun
P1637Generator L-Terminal Circuit
P1638Generator F-Terminal Circuit
P16395 Volt Reference 2 Circuit
P1640Driver-1-Input High Voltage
P1641Malfunction Indicator Lamp (MIL) Control Circuit
P1642Vehicle Speed Output Circuit
P1643Engine Speed Output Circuit
P1644Traction Control Delivered Torque Output Circuit
P1645Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
P1646Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P1647Driver 1 Line 7
P1650Control Module Output B Circuit
P1651Fan 1 Relay Control Circuit
P1652Powertrain Induced Chassis Pitch Output Circuit
P1653Oil Level Lamp Control Circuit
P1654Cruise Control Inhibit Output Circuit
P1655EVAP Purge Solenoid Control Circuit
P1656Driver 2 Line 6
P16571-4 Upshift Solenoid Control Circuit
P1658Starter Enable Relay Control Circuit
P1660Cooling Fan Control Circuits
P1661MIL Control Circuit
P1662Cruise Lamp Control Circuit
P1663Oil Life Lamp Control Circuit
P16641-4 Upshift Lamp Control Circuit
P1665Driver 3 Line 5
P1666Driver 3 Line 6
P1667Reverse Inhibit Solenoid Control Circuit
P1669ABS Unit Expected
P1670Driver 4
P1671Driver 4 Line 1
P1672Low Engine Oil Level Lamp Control Circuit
P1673Engine Hot Lamp Control Circuit
P1674Tachometer Control Circuit
P1675EVAP Vent Solenoid Control Circuit
P1676Driver 4 Line 6
P1677Driver 4 Line 7
P1680Driver 5 (ECU Malfunction)
P1681Driver 5 Line 1
P1682Driver 5 Line 2
P1683Driver 5 Line 3
P1684Driver 5 Line 4
P1685Driver 5 Line 5
P1686Driver 5 Line 6
P1687Driver 5 Line 7
P1689Delivered Torque Circuit Fault
P1690ECM Loop Overrun
P1691Coolant Gage Circuit Low Voltage
P1692Coolant Gage Circuit High Voltage
P1693Tachometer Circuit Low Voltage
P1694Tachometer Circuit High Voltage
P1695Remote Keyless Entry Circuit Low
P1696Remote Keyless Entry Voltage High
P1700Transmission Control Module (TCM) Requested MIL Illumination
P1701Trans. MIL Request Circuit
P1705P/N Signal Output Circuit
P1719Incorrect Shifting Detected (TCM)
P1740Torque Reduction Signal Circuit
P1743TP Signal from ECM
P1760TCM Supply Voltage Interrupted
P1779Engine Torque Delivered to TCM Signal
P1780Park/Neutral Position [PNP] Switch Circuit
P1781Engine Torque Signal Circuit
P1790Transmission Control Module Checksum
P1791Transmission Control Module Loop
P1791Throttle/Pedal Position Signal (2000+)
P1792Transmission Control Module Reprogrammable Memory
P1792ECM to TCM Engine Coolant Signal
P1793Transmission Control Module Stack Overrun
P1793Wheel Speed Signal (2000+)
P1795CAN Bus - Throttle Body Position
P1800TCM Power Relay Control Circuit
P1801Performance Selector Switch Failure
P1804Ground Control Relay
P1810TFP Valve Position Switch Circuit
P1811Maximum Adapt and Long Shift
P1812Transmission Over Temperature Condition
P1813Torque Control
P1814Torque Converter Overstressed
P1815Transmission Range Switch - Start In Wrong Range
P1816TFP Valve Position Sw. - Park/Neu. With Drive Ratio
P1817TFP Valve Position Sw. - Reverse With Drive Ratio
P1818TFP Valve Position Sw. - Drive Without Drive Ratio
P1819Internal Mode Switch - No Start\Wrong Range
P1820Internal Mode Switch Circuit A Low
P1822Internal Mode Switch Circuit B High
P1823Internal Mode Switch Circuit P Low
P1825Internal Mode Switch - Invalid Range
P1826Internal Mode Switch Circuit C - High
P1831Pressure Control (PC) Solenoid Power Circuit - Low Voltage
P1832Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
P1833A/T Solenoids Power Circuit - Low Voltage
P1834Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage
P1835Kick-Down Switch Circuit
P1836Kick-Down Switch Failed Open
P1837Kick-Down Switch Failed Short
P18421-2 Shift Solenoid Circuit Low Voltage
P18431-2 Shift Solenoid Circuit High Voltage
P1844Torque Reduction Signal Circuit Desired By TCM
P18452-3 Shift Solenoid Circuit Low Voltage
P18472-3 Shift Solenoid Circuit High Voltage
P1850Brake Band Apply Solenoid Circuit
P1851Brake Band Apply Solenoid Performance
P1852Brake Band Apply SolenoidLow Voltage
P1853Brake Band Apply Solenoid High Voltage
P1860TCC PWM Solenoid Circuit Electrical
P1864Torque Converter Clutch Circuit
P18654-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
P1866Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage
P1867Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage
P1868Transmission Fluid Life
P1870Transmission Component Slipping
P1871Undefined Gear Ratio
P1873TCC Stator Temp. Switch Circuit Low
P1874TCC Stator Temp. Switch Circuit High
P18754WD Low Switch Circuit Electrical
P1884TCC Enable/Shift Light Circuit
P1886Shift Timing Solenoid
P1887TCC Release Switch Circuit
P1890ECM Data Input Circuit, or - Throttle Position Signal Input
P1891Throttle Position Sensor PWM Signal Low
P1892Throttle Position Sensor PWM Signal High
P1893Engine Torque Signal Low Voltage
P1894Engine Torque Signal High Voltage
P1895TCM to ECM Torque Reduction Circuit
U1000Class 2 Communication Malfunction
U1001Loss of serial communications for class 2 devices
U1002Loss of serial communications for class 2 devices
U1003Loss of serial communications for class 2 devices
U1004Loss of serial communications for class 2 devices
U1005Loss of serial communications for class 2 devices
U1006Loss of serial communications for class 2 devices
U1007Loss of serial communications for class 2 devices
U1008Loss of serial communications for class 2 devices
U1009Loss of serial communications for class 2 devices
U1010Loss of serial communications for class 2 devices
U1011Loss of serial communications for class 2 devices
U1012Loss of serial communications for class 2 devices
U1013Loss of serial communications for class 2 devices
U1014Loss of serial communications for class 2 devices
U1015Loss of serial communications for class 2 devices
U1016Loss of Class 2 Communication with VCM
U1016Loss of Communications with PCM
U1017Loss of serial communications for class 2 devices
U1018Loss of serial communications for class 2 devices
U1019Loss of serial communications for class 2 devices
U1020Loss of serial communications for class 2 devices
U1021Loss of serial communications for class 2 devices
U1022Loss of serial communications for class 2 devices
U1023Loss of serial communications for class 2 devices
U1024Loss of serial communications for class 2 devices
U1025Loss of serial communications for class 2 devices
U1026Loss of ATC Class 2 Communication
U1027Loss of Serial Communications for Class 2 Devices
U1028Loss of Serial Communications for Class 2 Devices
U1029Loss of Serial Communications for Class 2 Devices
U1030Loss of Serial Communications for Class 2 Devices
U1031Loss of Serial Communications for Class 2 Devices
U1032Loss of Serial Communications for Class 2 Devices
U1033Loss of Serial Communications for Class 2 Devices
U1034Loss of Serial Communications for Class 2 Devices
U1035Loss of Serial Communications for Class 2 Devices
U1036Loss of Serial Communications for Class 2 Devices
U1037Loss of Serial Communications for Class 2 Devices
U1038Loss of Serial Communications for Class 2 Devices
U1039Loss of Serial Communications for Class 2 Devices
U1040Loss of Class 2 Communications with ABS
U1041Loss of EBCM Communication
U1042Lost Communications with Brake/Traction Control System
U1043Loss of Serial Communications for Class 2 Devices
U1044Loss of Serial Communications for Class 2 Devices
U1045Loss of Serial Communications for Class 2 Devices
U1046Loss of Serial Communications for Class 2 Devices
U1047Loss of Serial Communications for Class 2 Devices
U1048Loss of Serial Communications for Class 2 Devices
U1049Loss of Serial Communications for Class 2 Devices
U1050Loss of Serial Communications for Class 2 Devices
U1051Loss of Serial Communications for Class 2 Devices
U1052Loss of Serial Communications for Class 2 Devices
U1053Loss of Serial Communications for Class 2 Devices
U1054Loss of Serial Communications for Class 2 Devices
U1055Loss of Serial Communications for Class 2 Devices
U1056Loss of Communications with RSS
U1057Loss of Serial Communications for Class 2 Devices
U1058Loss of Serial Communications for Class 2 Devices
U1059Loss of Serial Communications for Class 2 Devices
U1060Loss of Serial Communications for Class 2 Devices
U1062Loss of Serial Communications for Class 2 Devices
U1064Loss Of Communications With DIM
U1065Loss of Communications with IPM
U1066Loss of Communications with RIM
U1067Loss of Serial Communications for Class 2 Devices
U1068Loss of Serial Communications for Class 2 Devices
U1069Loss of Serial Communications for Class 2 Devices
U1071Loss of Serial Communications for Class 2 Devices
U1072Loss of Serial Communications for Class 2 Devices
U1073Loss of Serial Communications for Class 2 Devices
U1074Loss of Serial Communications for Class 2 Devices
U1075Loss of Serial Communications for Class 2 Devices
U1076Loss of Serial Communications for Class 2 Devices
U1077Loss of Serial Communications for Class 2 Devices
U1078Loss of Serial Communications for Class 2 Devices
U1079Loss of Serial Communications for Class 2 Devices
U1080Loss of Serial Communications for Class 2 Devices
U1081Loss of Serial Communications for Class 2 Devices
U1082Loss of Serial Communications for Class 2 Devices
U1083Loss of Serial Communications for Class 2 Devices
U1084Loss of Serial Communications for Class 2 Devices
U1085Loss of Serial Communications for Class 2 Devices
U1086Loss of Serial Communications for Class 2 Devices
U1087Loss of Serial Communications for Class 2 Devices
U1088Loss of Communications with SDM
U1089Loss of Serial Communications for Class 2 Devices
U1090Loss of Serial Communications for Class 2 Devices
U1091Loss of Serial Communications for Class 2 Devices
U1092Loss of Serial Communications for Class 2 Devices
U1093Loss of Serial Communications for Class 2 Devices
U1094Loss of Serial Communications for Class 2 Devices
U1095Loss of Serial Communications for Class 2 Devices
U1096Loss of Communications with IPC
U1097Loss of serial communications for class 2 devices
U1098Loss of serial communications for class 2 devices
U1099Loss of serial communications for class 2 devices
U1100Loss of serial communications for class 2 devices
U1101Loss of serial communications for class 2 devices
U1102Loss of serial communications for class 2 devices
U1103Loss of serial communications for class 2 devices
U1104Loss of serial communications for class 2 devices
U1105Loss of serial communications for class 2 devices
U1106Loss of serial communications for class 2 devices
U1107Loss of serial communications for class 2 devices
U1108Loss of serial communications for class 2 devices
U1109Loss of serial communications for class 2 devices
U1110Loss of serial communications for class 2 devices
U1111Loss of serial communications for class 2 devices
U1112Loss of serial communications for class 2 devices
U1113Loss of serial communications for class 2 devices
U1114Loss of serial communications for class 2 devices
U1115Loss of serial communications for class 2 devices
U1116Loss of serial communications for class 2 devices
U1117Loss of serial communications for class 2 devices
U1118Loss of serial communications for class 2 devices
U1119Loss of serial communications for class 2 devices
U1120Loss of serial communications for class 2 devices
U1121Loss of serial communications for class 2 devices
U1122Loss of serial communications for class 2 devices
U1123Loss of serial communications for class 2 devices
U1124Loss of serial communications for class 2 devices
U1125Loss of serial communications for class 2 devices
U1126Loss of serial communications for class 2 devices
U1127Loss of serial communications for class 2 devices
U1128Loss of Communications with IRC
U1129Loss of Communications with AMP
U1130Loss of serial communications for class 2 devices
U1131Loss of serial communications for class 2 devices
U1132Loss of serial communications for class 2 devices
U1133Loss of serial communications for class 2 devices
U1134Loss of serial communications for class 2 devices
U1135Loss of serial communications for class 2 devices
U1136Loss of serial communications for class 2 devices
U1137Loss of serial communications for class 2 devices
U1138Loss of serial communications for class 2 devices
U1139Loss of serial communications for class 2 devices
U1140Loss of serial communications for class 2 devices
U1141Loss of serial communications for class 2 devices
U1142Loss of serial communications for class 2 devices
U1143Loss of serial communications for class 2 devices
U1144Loss of Communications with PHN
U1145Loss Of NAV Communications
U1146Loss Of Onstar Communiction
U1147Loss of serial communications for class 2 devices
U1148Loss of serial communications for class 2 devices
U1149Loss of serial communications for class 2 devices
U1150Loss of serial communications for class 2 devices
U1151Loss of serial communications for class 2 devices
U1152Loss Of ACM Serial Data Communication
U1152Loss of Data HCM
U1153Loss of Communications with CCP
U1154Loss of serial communications for class 2 devices
U1155Loss of serial communications for class 2 devices
U1156Loss of serial communications for class 2 devices
U1157Loss of serial communications for class 2 devices
U1158Loss of serial communications for class 2 devices
U1159Loss of serial communications for class 2 devices
U1160Loss of Communications with DDM
U1161Loss of PDM Serial Data
U1161Loss of PASS Door Module SBI
U1162Loss of Rear Driver Door Module SBI
U1163Loss of Rear PASS Door Module SBI
U1163Loss of RRDM Serial Data
U1164Loss Of DIM Serial Data Communication
U1165Loss of serial communications for class 2 devices
U1166Loss of Communications with SCM
U1167Loss of serial communications for class 2 devices
U1168Loss Of TTM Communications
U1169Loss of Communications with MMM
U1170Loss of Driver Door Switch Asm Serial Data
U1170Loss of Driver Door Switch SBI
U1171Loss of serial communications for class 2 devices
U1172Loss of serial communications for class 2 devices
U1173Loss of serial communications for class 2 devices
U1174Loss of serial communications for class 2 devices
U1175Loss of serial communications for class 2 devices
U1176Loss Of RFA Communications
U1177Loss of serial communications for class 2 devices
U1178Loss of serial communications for class 2 devices
U1179Loss of serial communications for class 2 devices
U1180Loss of serial communications for class 2 devices
U1181Loss of serial communications for class 2 devices
U1182Loss of serial communications for class 2 devices
U1183Loss of serial communications for class 2 devices
U1184Loss of serial communications for class 2 devices
U1185Loss of serial communications for class 2 devices
U1186Loss of serial communications for class 2 devices
U1187Loss of serial communications for class 2 devices
U1188Loss of serial communications for class 2 devices
U1189Loss of serial communications for class 2 devices
U1190Loss of serial communications for class 2 devices
U1191Loss of serial communications for class 2 devices
U1192Loss of VTD Class 2 Serial Data Com
U1193Loss of VIM Class 2 Communication
U1194Loss of serial communications for class 2 devices
U1195Loss of serial communications for class 2 devices
U1196Loss of serial communications for class 2 devices
U1197Loss of serial communications for class 2 devices
U1198Loss of serial communications for class 2 devices
U1199Loss of serial communications for class 2 devices
U1200Loss of serial communications for class 2 devices
U1201Loss of serial communications for class 2 devices
U1202Loss of serial communications for class 2 devices
U1203Loss of serial communications for class 2 devices
U1204Loss of serial communications for class 2 devices
U1205Loss of serial communications for class 2 devices
U1206Loss of serial communications for class 2 devices
U1207Loss of serial communications for class 2 devices
U1208Loss of serial communications for class 2 devices
U1209Loss of serial communications for class 2 devices
U1210Loss of serial communications for class 2 devices
U1211Loss of serial communications for class 2 devices
U1212Loss of serial communications for class 2 devices
U1213Loss of serial communications for class 2 devices
U1214Loss of serial communications for class 2 devices
U1215Loss of serial communications for class 2 devices
U1216Loss of serial communications for class 2 devices
U1217Loss of serial communications for class 2 devices
U1218Loss of serial communications for class 2 devices
U1219Loss of serial communications for class 2 devices
U1220Loss of serial communications for class 2 devices
U1221Loss of serial communications for class 2 devices
U1222Loss of serial communications for class 2 devices
U1223Loss of serial communications for class 2 devices
U1224Loss of serial communications for class 2 devices
U1225Loss of serial communications for class 2 devices
U1226Loss of serial communications for class 2 devices
U1227Loss of serial communications for class 2 devices
U1228Loss of serial communications for class 2 devices
U1229Loss of serial communications for class 2 devices
U1230Loss of serial communications for class 2 devices
U1231Loss of serial communications for class 2 devices
U1232Loss of serial communications for class 2 devices
U1233Loss of serial communications for class 2 devices
U1234Loss of serial communications for class 2 devices
U1235Loss of serial communications for class 2 devices
U1236Loss of serial communications for class 2 devices
U1237Loss of serial communications for class 2 devices
U1238Loss of serial communications for class 2 devices
U1239Loss of serial communications for class 2 devices
U1240Loss of serial communications for class 2 devices
U1241Loss of serial communications for class 2 devices
U1242Loss of serial communications for class 2 devices
U1243Loss of serial communications for class 2 devices
U1244Loss of serial communications for class 2 devices
U1245Loss of serial communications for class 2 devices
U1246Loss of serial communications for class 2 devices
U1247Loss of serial communications for class 2 devices
U1248Loss of serial communications for class 2 devices
U1249Loss of serial communications for class 2 devices
U1250Loss of serial communications for class 2 devices
U1251Loss of serial communications for class 2 devices
U1252Loss of serial communications for class 2 devices
U1253Loss of serial communications for class 2 devices
U1254Loss of serial communications for class 2 devices
U1255Class 2 Communication Malfunction (Serial Data Line Malfunction)
U1300Class 2 Short to Ground
U1301Class 2 Short to Battery
U1304Loss Of UART Communications
U1305Class 2 Data Link Low or High
U1500Inter-Device Dedicated Bus Malfunction
U1713Loss Of Front Door Module to Window Motor High Speed Comm.
U1714Loss Of Front Door Module to Window Motor Normal Speed Comm.
U1715Loss Of Front Door Module to Window Motor High Speed Comm.
U1716Loss Of Front Door Module to Window Motor Normal Speed Comm.
U1800Controller Area Network (CAN) Bus Communication
HONDА
P1020Valve Pause System Stuck Off
P1021Valve Pause System Stuck On
P1025Valve Pause System Sticking Off
P1026Valve Pause System Sticking On
P1077Intake Manifold Runner Control (IMRC) System Malfunction (Low rpm)
P1078Intake Mainfold Runner Control (IMRC) System Malfunction (High rpm)
P1106Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
P1107Barometric Pressure (BARO) Sensor Circuit Low Voltage
P1108Barometric Pressure (BARO) Sensor Circuit High Voltage
P1121Throttle Position (TP) Sensor Lower Than Expected
P1122Throttle Position (TP) Sensor Higher Than Expected
P1128Manifold Absolute Pressure (MAP) Sensor Circuit Lower Than Expected
P1129Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected
P1130Demand for Changing Both Secondary Heated Oxygen Sensor (Secondary HO2S)(Sensor 2) and Third Heated Oxygen Sensor (Third HO2S) (Sensor 3)
P1149 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor 03-020 6 of 10,or Air/Fuel Ratio Sensor (Sensor 1) Circuit Lean Range A/F sensor
P1157Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS Line High Voltage,or Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit High Voltage,or Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
P1158Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low Voltage
P1159Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Terminal Low Voltage
P1162Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response A/F sensor
P1163Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response A/F sensor,or Air/Fuel Ratio Sensor (Sensor 1) Slow Response A/F sensor
P1164Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor,or Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/Performance A/F sensor
P1165Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor,or Air/Fuel Ratio Sensor (Sensor 1) Circuit Range/Performance A/F sensor
P1166Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Electrical Problem A/F sensor heater,or Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit Malfunction (HO2S)
P1167Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Malfunction A/F sensor heater,or Heated Oxygen Sensor Sensor1 (Primary LAF HO2S) Heater System Malfunction A/F sensor heater
P1168Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL Low Voltage
P1169Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL High Voltage
P1182Fuel Temperature Sensor Circuit Low Voltage
P1183Fuel Temperature Sensor Circuit High Voltage
P1253VTEC System Circuit Fault
P1259VTEC System Circuit Fault(Bank 1)
P1297Electric Load Detector (ELD) Circuit Low Voltage
P1298Electric Load Detector (ELD) Circuit High Voltage
P1300Random Misfire Misfire
P1324Knock Sensor Power Source Circuit Low Voltage
P1336Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
P1337Engine Speed (RPM) Fluctuation Sensor No Signal
P1355Front Ignition Coil Power Circuit Malfunction
P1359Crankshaft Position (CKP)/Top Dead Center (TDC) Sensor Circuit Malfunction
P1361Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent Interruption,or Top Dead Center (TDC) Sensor Intermittent Interruption
P1362Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal,or Top Dead Center (TDC) Sensor No Signal
P1366Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent Interruption,or Top Dead Center (TDC) Sensor 2 Intermittent Interruption
P1367Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal,or Top Dear Center (TDC) Sensor 2 No Signal
P1381Cylinder Position (CYP) Sensor Intermittent Interruption
P1382Cylinder Position (CYP) Sensor No Signal
P1410Air Pump Malfunction(Air system)
P1415Air Pump Electric Current Sensor Circuit Low Voltage (Air system)
P1416Air Pump Electric Current Sensor Circuit High Voltage (Air system)
P1420Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter
P1438Motor Drive Module (MDM) Overheating Signal Circuit,or Motor Drive Module (MDM) Overheating
P1439Motor Drive Module (MDM) Short Circuit Sensor Problem,or Motor Drive Module (MDM) Short Circuit
P1440IMA System Problem
P1445Bypass Control Problem
P1448Battery Module Overheating
P1449Battery Module Overheating, or Battery Cell Overheating,or Battery Module Individual Voltage Input Deviation,or Battery Module Deterioration,or Battery Module Deviation
P1454Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
P1456Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System) EVAP
P1457Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System) EVAP
P1459Evaporative Emission (EVAP) Purge Flow Switch Malfunction
P1486Cooling System Malfunction (Thermostat)
P1491Exhaust Gas Recirculation (EGR) Valve Insufficient Lift EGR
P1491Exhaust Gas Recirculation (EGR) Valve Insufficient Lift (EGR)
P1498Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
P1505Positive Crankcase Ventilation (PCV) Air Leakage
P1508Idle Air Control Valve (IACV) Circuit Malfunction
P1509Idle Air Control Valve (IACV) Circuit Failure
P1519Idle Air Control Valve (IACV) Circuit Malfunction
P1522Brake Booster Pressure Sensor Circuit Low Voltage
P1523Brake Booster Pressure Sensor Circuit High Voltage
P1524Brake Booster Pressure Sensor Range/Performance Problem
P1541Climate Control Unit Signal Circuit Low Voltage
P1542Climate Control Unit Signal Circuit High Voltage
P1565Motor Commutation Signal Problem
P1568Battery Module Individual Voltage Input Problem,or Battery Module Temperature Signal Circuit Problem,or Battery Cell Temperature Signal Circuit Problem
P1572Motor Drive Module (MDM) Temperature Signal Circuit Low Input,or Motor Drive Module (MDM) Temperature Signal Circuit High Input
P1576Motor Drive Module (MDM) Voltge Signal Circuit Low Input
P1577High Voltage Detection Signal Circuit Problem
P1580Battery Current Circuit Problem
P1581Motor Power Inverter (MPI) Module Current Signal Circuit Low Input,or Motor Power Inverter (MPI) Module Current Signal Circuit High Input,or Motor Power Inverter (MPI) Module Current Signal Circuit Problem
P1582Motor Current U Phase Signal Circuit Low Input,or Motor Current U Phase Signal Circuit High Input
P1583Motor Current V Phase Signal Circuit Low Input,or Motor Current V Phase Signal Circuit High Input
P1584Motor Current W Phase Signal Circuit Low Input,or Motor Current W Phase Signal Circuit High Input
P1585Motor Current Signal Circuit Problem
P1586Motor Power Inverter (MPI) Module Current Signal/Battery Current Signal Circuit Problem
P1607Engine Control Module (ECM)/Powertrain Control Module (PCM) Internal Circuit Malfunction
P1630Transmission Control Module
P1635Battery Condition Monitor (BCM) Module Proble
P1639MOTB Signal Circuit Malfunction
P1640ACTTRQ Motor Torque Signal Circuit Low Input
P1641ACTTRQ Motor Torque Signal Circuit High Input
P1642QBATT Battery Signal Circuit Low Input
P1643QBATT Battery Signal Circuit High Input
P1644MOTFSA Signal Malfunction
P1645MOTFSB Signal Malfunction
P1646MOTSTB Signal Malfunction
P1647Power Command Signal Circuit Low Input,or Power Command Signal Circuit High Input,or Engine Torque Signal Circuit Low Input,or Engine Torque Signal Circuit High Input,or Mode Signal Circuit 1 Low Input
P1648Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem,or Motor Control Module (MCM) Communication Signal Circuit Problem
P1655CVT-FI TMA/TMB Signal Line Failure
P1656Problem in PCM-toVTM-4 Control Unit Communications Circuit
P1660A/T-FI Data Line Failure/TCM - ECM Halt
P1676FPTDR Signal Line Failure
P1678FPTDR Signal Line Failure
P1679RSCD Signal Circuit Malfunction
P1681A/T FI Signal A Cicuit Low Voltage
P1682A/T FI Signal A Circuit High Voltage
P1683Throttle Valve Default Position Spring Performance Problem
P1684Throttle Valve Return Spring Performance Problem
P1686A/T FI Signal B Circuit Low Voltage
P1687A/T FI Signal B Circuit High Voltage
P1705Short in Transmission Range Switch Circuit (More than one range position is on at the same time)
P1706Open in Transmission Range Switch Circuit
P1709Problem Transmission Gear Selection Switch Circuit DTC Detection Item Associated Monitor
P1730Problem in Shift Control System:Shift Solenoid Valve A and D Stuck OFF ,or Shift Solenoid Valve B Stuck ON,or Shift Valves A, B, and D Stuck
P1731Problem in Shift Control System:Shift Solenoid Valve E Stuck ON,or Shift Valve E Stuck,or A/T Clutch Pressure Control Solenoid Valve A Stuck OFF
P1732Problem in Shift Control System:Shift Solenoid Valve B and C Stuck ON,or Shift Valves B and C Stuck
P1733Problem in Shift Control System:Shift Solenoid Valve D Stuck ON,or Shift Valve D Stuck,or A/T Clutch Pressure Control Solenoid Valve C Stuck OFF
P1734Problem in Shift Control System:Shift Solenoid Valves B and C Stuck ON, or Shift Valves B and C Stuck
P1738Problem in 2nd Clutch Pressure Switch Circuit
P1739Problem in 3rd Clutch Pressure Switch Circuit
P1740Problem in 4th Clutch Pressure Switch Circuit
P1750Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve Assemblies A and B, or Problem in the Hydraulic Control System
P1751Problem in Torque Converter Clutch Solenoid Valve B Circuit
P1751Mechanical Problem in Hydraulic Control System of Shift Solenoid Valve B and A/T Clutch Pressure Control Solenoid Valves A and B, or Problem in the Hydraulic Control System
P1753Problem in Torque Converter Clutch Solenoid Valve Circuit
P1768Problem in Torque Converter Clutch Solenoid Valve B Circuit
P1773Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
P1790Throttle Position (TP) Sensor Circuit Malfunction
P1791Vehicle Speed Sensor (VSS) Range/Performance Problem
P1792Problem in Engine Coolant Temperature (ECT) Sensor Circuit
P1793Manifold Absolute Pressure Sensor Circuit
P1870Problem in CVT Speed Change Control Valve Assembly Circuit
P1873Problem in CVT Pulley Pressure Control Valve Assembly Circuit
P1879Problem in CVT Start Clutch Pressure Control Valve Assembly Circuit
P1882Problem in Inhibitor Solenoid Circuit
P1884Secondary Gear Speed Sensor 2 Circuit Malfunction
P1885CVT Drive Pulley Speed Sensor Circuit
P1886CVT Driven Pulley Speed Sensor Circuit
P1888CVT Speed Sensor
P1889Problem in CVT Speed Sensor 2 Circuit
P1890Shift Control System
P1891Problem in Start Clutch System
P1894CVT Speed Change Control Valve Circuit
P1895CVT Pulley Pressure Control Valve Circuit
JAGH
P1000OBD Systems Readiness Test Not Complete
P1104Mass Air Flow Sensor Circuit Ground
P1111System Pass
P1121Pedal Position Sensor A Circuit Range / Performance
P1122Pedal Position Sensor A Circuit Low input
P1123Pedal Position Sensor A Circuit High Input
P1136Control Box Fan Circuit
P1137Lack Of HO2S12 Switches -Sensor Indicates Lean
P1138Lack Of HO2S12 Switches -Sensor Indicates Rich
P1143Air Assisted Injector Control Valve Range/ Performance
P1144Air Assisted Injector Control Valve Circuit
P1157Lack Of HO2S22 Switches -Sensor Indicates Lean
P1158Lack Of HO2S22 Switches -Sensor Indicates Rich
P1171System Too Lean -Banks 1 and 2 (Lean Fuel Fault)
P1172System Too Rich -Banks 1 and 2 (Rich Fuel Fault)
P1174System Too Lean -Banks 1 and 2 (Suspect HO2S)
P1175System Too Rich -Banks 1 and 2 (Suspect HO2S)
P1176Long Term Fuel Trim Too Lean - Banks 1 and 2 (FMFR)
P1177Long Term Fuel Trim Too Rich - Banks 1 and 2 (FMFR)
P1178Long Term Fuel Trim Too Lean - Banks 1 and 2 (AMFR)
P1179Long Term Fuel Trim Too Rich - Banks 1 and 2 (AMFR)
P118502 Sensor Heater Circuit Open - Hardware Fault
P118602 Sensor Heater Circuit Shorted - Hardware Fault
P118702 Sensor Heater Circuit Open - Inferred Fault
P118802 Sensor Heater Circuit Resistance
P118902 Sensor Heater Circuit Low Resistance Fault 1
P119002 Sensor Heater Circuit Low Resistance Fault 2
P119102 Sensor Heater Circuit Open -Hardware Fault
P119202 Sensor Heater Circuit Shorted
P119302 Sensor Heater Circuit Open - Inferred Fault
P119402 Sensor Heater Circuit Resistance Fault
P119502 Sensor Heater Circuit Low Resistance Fault 1
P119602 Sensor Heater Circuit Low Resistance Fault 2
P1198Fuel Level Input Circuit High
P1199Fuel Level Input Circuit Low
P1201Cylinder # 1 Injector Circuit Open / Shorted
P1202Cylinder # 2 Injector Circuit Open / Shorted
P1203Cylinder # 3 Injector Circuit Open / Shorted
P1204Cylinder # 4 Injector Circuit Open / Shorted
P1205Cylinder # 5 Injector Circuit Open / Shorted
P1206Cylinder # 6 Injector Circuit Open / Shorted
P1207Cylinder # 7 Injector Circuit Open / Shorted
P1208Cylinder # 8 Injector Circuit Open / Shorted
P1221Pedal Demand Sensor B Circuit Range / Performance
P1224Electronic Throttle Control Position Error
P1226Mechanical Guard Circuit Range / Performance
P1227Mechanical Guard Circuit Low Input
P1228Mechanical Guard Circuit High Input
P1229Electronic Throttle Control Circuit
P1230Fuel Pump Relay
P1235VSV 1/2/3 Circuit Range / Performance
P1236VSV 1 Circuit
P1237VSV 2 Circuit
P1238VSV 3 Circuit
P1240Sensor Power Supply
P1241Sensor Power Supply Low Input
P1242Sensor Power Supply High Input
P1243Analog Ground
P1245Crank Signal Low Input
P1246Crank Signal High Input
P1250Throttle Valve Spring
P1251Throttle Position
P1252VSV stuck on VA/VV
P1253VSV Stuck on VR
P1313Misfire Rate Catalyst Damage Fault - Bank 1
P1314Misfire Rate Catalyst Damage Fault - Bank 2
P1315Persistent Misfire
P1316Misfire Rate Exceeds Emissions
P1336Crankshaft / Camshaft Sensor Range / Performance
P1340Camshaft Position Sensor B Circuit
P1341Camshaft Position Sensor B Circuit Range / Performance
P1361Ignition Coil, Cylinder #1, No Activation
P1362Ignition Coil, Cylinder #2, No Activation
P1363Ignition Coil, Cylinder #3, No Activation
P1364Ignition Coil, Cylinder #4, No Activation
P1365Ignition Coil, Cylinder #5, No Activation
P1366Ignition Coil, Cylinder #6, No Activation
P1367Ignition System Failure Group 1
P1368Ignition System Failure Group 2
P1370Insufficient RPM Increase During Spark Test
P1371Ignition Coil - Cylinder 1 - Early Activation Fault
P1372Ignition Coil - Cylinder 2 - Early Activation Fault
P1373Ignition Coil - Cylinder 3 - Early Activation Fault
P1374Ignition Coil - Cylinder 4 - Early Activation Fault
P1375Ignition Coil - Cylinder 5 - Early Activation Fault
P1376Ignition Coil - Cylinder 6 - Early Activation Fault
P1384Variable Valve Timing Solenoid A Circuit
P1392Variable Valve Timing Solenoid A Circuit Low Input
P1393Variable Valve Timing Solenoid A Circuit High Input
P1396Variable Valve Timing Solenoid B Circuit
P1397Variable Valve Timing Solenoid B Circuit Low Input
P1398Variable Valve Timing Solenoid B Circuit High Input
P1400Exhaust Gas Recirculation Valve Position Control
P1401Exhaust Gas Recirculation Valve Position Circuit
P1408Exhaust Gas Recirculation Thermister
P1409Exhaust Gas Recirculation Valve Circuit
P1440Purge Valve Stuck Open
P1441ELC System 1
P1447ELC System Closure Valve Flow
P1448ELC System System 2
P1453Fuel Tank Pressure Relief Valve Malfunction
P1454Evaporative Emission Control System Vacuum Test
P1475Fan Relay (Low) Circuit
P1476Fan Relay (High) Circuit
P1508Idle Air Control Circuit Open
P1509Idle Air Control Circuit Shorted
P1514High Load Neutral / Drive Fault
P1516Gear Change Neutral / Drive Fault
P1517Cranking Neutral / Drive Fault
P1534Restraint Deployment Indicator Circuit
P1565Speed Control Command Switch Out Of Range High
P1566Speed Control Command Switch Out Of Range Low
P1567Speed Control Output Circuit
P1568Speed Control Unable to Hold Speed
P1571Brake Switch
P1600Loss Of KAM Power, Cricuit Open
P1603EEPROM Malfunction
P1606ECM Control Relay Output Circuit
P1607MIL Output Circuit
P1608Watchdog Malfunction
P1609Internal Control Module CPU to CPU Communication Failure
P1611Throttle Target Malfunction 1
P1612Throttle Offset Malfunction
P1637CAN Link ECM/ABS Control Module Circuit / Network
P1638CAN Link ECM / INSTM Circuit / Network
P1641Fuel Pump Primary Circuit
P1642CAN Link Circuit
P1643CAN Link Engine Control Module / Transmission Control Module Circuit / Network
P1646Linear 02 Sensor Control Chip (Bank 1)
P1647Linear 02 Sensor Control Chip (Bank 2)
P1648Knock Sensor Input Chip
P1696CAN Link Engine Control Module /Cruise Control Module Circuit / Network
P1697Cruise Control Distance - Control Input Circuit
P1700Transmission Indeterminate Failure (Failed to Neutral)
P1720Vehicle Speed (Meter ) Circuit
P1722Stall Speed
P1726Engine Overspeed
P1730Gear Control Malfunction 2,3,5
P1731Inconsistent Gear Ratio
P1734Gear Control Malfuntion
P1745Pressure Regulator 1
P1746Pressure Regulator 2
P1747Pressure Regulator 3
P1748Pressure Regulator 5
P1758Pressure Solenoid Control System Incorrect Current
P1775Transmission System MIL Fault
P1776Ignition Retard Request Duration
P1777Ignition Retard Request Circuit
P1778Transmission Reverse I / P Circuit
P1779Load Control
P1789Ignition Supply Malfunction
P1790Ignition Supply Malfunction
P1791Ignition Supply Malfunction
P1792Ignition Supply Malfunction
P1793Ignition Supply Malfunction
P1794Battery Voltage Circuit
P1796CAN Controller Circuit (Bus off)
P1797CAN TCM / ECM Circuit Malfunction
P1798CAN TCM / INST Circuit Malfunction
P1799CAN TCM / ABS Circuit Malfunction
P1882Engine Coolant Level Switch Circuit Short To Ground
KIA
P1102HO2S - 11 heater circuit high voltage
P1105HO2S - 12 heater circuit high voltage
P1115HO2S - 11 heater circuit low voltage
P1117HO2S - 12 heater circuit low voltage
P1123Long term trim adaptive air system low
P1124Long term fuel trim adaptive air system high
P1127Long term fuel trim multiplicative air system low
P1128Long term fuel trim multiplicative air system high
P1140Load calculation cross check
P1170HO2S - 11 circuit voltage stuck at Mid - range
P1195EGR Boost or pressure sensor circuit fault
P1196Ignition switch start circuit fault
P1213Fuel injector 1 circuit high voltage
P1214Fuel injector 2 circuit high voltage
P1215Fuel injector 3 circuit high voltage
P1216Fuel injector 4 circuit high voltage
P1225Fuel injector 1 circuit low voltage
P1226Fuel injector 2 circuit low voltage
P1227Fuel injector 3 circuit low voltage
P1228Fuel injector 4 circuit low voltage
P1250Pressure regulator control solenoid circuit fault
P1345No SGC (CMP) signal to PCM
P1386Knock sensor control zero test
P1401EGR control solenoid circuit signal low
P1402EGR control solenoid circuit signal high
P1402EGR valve position sensor circuit fault
P1410EVAP purge control solenoid circuit high voltage
P1412EGR differential pressure sensor signal low
P1413EGR differential pressure sensor signal high
P1425EVAP purge control solenoid circuit low voltage
P1449Canister drain cut valve solenoid circuit fault
P1455Fuel tank sending unit circuit fault
P1458Air conditioning compressor clutch signal fault
P1485EGR Vent control solenoid circuit fault
P1486EGR vacuum control solenoid circuit fault
P1487EGR boost sensor solenoid circuit fault
P1510Idle air control valve closing coil high voltage
P1513Idle air control valve closing coil low voltage
P1515A / T to M / T codification
P1523VICS solenoid valve circuit fault
P1552Idle air control valve opening coil low voltage
P1553Idle air control valve opening coil high voltage
P1606Chassis accelerator sensor signal circuit fault
P1608PCM internal fault
P1611MIL request circuit low voltage
P1614MIL request circuit high voltage
P1616Chassis accelerator sensor signal low voltage
P1617Chassis accelerator sensor signal high voltage
P1624TCM to PCM MIL request signal circuit fault
P1655Unused power stage 'B'
P1660Power stage group 'B'
P1665Power stage group 'A'
P1743Torque converter clutch solenoid circuit fault
P1794Battery or circuit fault
P1797Clutch pedal switch (MT) -or- P/N switch circuit fault
MAZDA
P1001Activate self test SCP error
P1100Mass Air Flow Sensor Circuit Intermittent
P1101Mass Air Flow Sensor Out Of Self Test Range
P1102Mass Air Flow Sensor In Range But Lower Than Expected
P1103Mass Air Flow Sensor In Range But Higher Than Expected
P1110Intake Air Temperature Circuit (dynamic chamber) Open/Short
P1112Intake Air Temperature Circuit Intermittent
P1113Intake Air Temperature Circuit (dynamic chamber) Open/Short
P1116Engine Coolant Temperature Sensor Out Of Self Test Range
P1117Engine Coolant Temperature Sensor Circuit Intermittent
P1120TP sensor out of range low
P1121Tp sensor signal not consistent with MAF signal
P1122Throttle Position Sensor A In Range But Lower Than Expected
P1123Throttle Position Sensor A In Range But Higher Than Expected
P1124TP sensor signal out of self test range
P1125TP sensor signal intermittent
P1126Throttle Position(Narrow Range)Sensor Circuit
P1127H02S-12 heater not ON during KOER self test
P1128Upstream H02S Sensors Swapped
P1129Downstream H02S Sensors Swapped
P1130H02S-11 not switching (fuel control limit reached)
P1131H02S-11 signal above 0.45v(A/F ratio too lean)
P1132H02S-11 signal below 0.45v(A/F ratio too rich)
P1133Bank 1 Fuel Control Shifted Lean (FAOSC)
P1134Bank 1 Fuel Control Shifted Rich (FAOSC)
P1135H02S11 Heater Circuit Low
P1136H02S11 Hester Circuit High
P1137H02S-11 signal above 0.45v(A/F ratio too rich)
P1138Lack Of HO2S12 Switches - Sensor Indicates Rich
P1141H02S12 Heater Circuit Low
P1142H02S12 Hester Circuit High
P1143Lack Of HO2S Switches,H02S13 Indicates Lean
P1144Lack Of HO2S Switches,H02S13 Indicates Rich
P1150HO2S-21 not switching (fuel control limit reached)
P1151H02S-21 signal below 0.45v (A/F ratio too rich)
P1152H02S-21 signal above 0.45v (A/F ratio too rich)
P1153Bank 2 Fuel Control Shifted Lean (FAOSC)
P1154Bank 2 Fuel Control Shifted Rich (FAOSC)
P1169Feedback A/F Mixture Control (HO2S12)
P1170HO2S-11 circuit too high or low (bank 1 sensor 1)
P1173Feedback A/F Mixture Control (HO2S21)
P1182Fuel Shut Off Solenoid Circuit
P1189Pump Speed Signal
P1190Calibration Resistor Out Of Range
P1191TP (controlled) circuit
P1194ECM/PCM A/D Converter
P1195EGR boost sensor circuit fault
P1197Mileage Switch Circuit
P1213Start Injector Circuit
P1221Traction Control System
P1222Traction Control Output Circuit
P1226Control Sleeve Sensor Circuit
P1235Fuel pump control out range
P1236Fuel pump control out range
P1248Turbo Boost Pressure Not Detected
P1250Fuel Pressure Regulator Control Solenoid
P1251Air Mixture Solenoid Circuit
P1252Pressure regulator control solenoid '2'circuit fault
P1260Anti-theft system signal detected, engine disabled
P1270Engine RPM or vehicle speed limit reached
P1279Control Sleeve Sensor Circuit Range / Performance
P1298Injector Driver Module Failure
P1312Injection Pump Timing Actuator Circuit
P1318Injection Timing Piston Position Sensor Circuit
P1319Injection Timing Piston Position Sensor Circuit Range / Performance
P1345CMP or SGC sensor circuit fault
P1351IDM signal lost to PCM or out of range
P1352Ignition coil 'A' primary circuit fault
P1353Ignition coil 'B' primary circuit fault
P1354Ignition coil 'C' primary circuit fault
P1358IDM signal out of self test range
P1359SPOUT signal lost to PCM or out of range
P1360Ignition coil 'A' secondary circuit fault
P1361Ignition coil 'B' secondary circuit fault
P1362Ignition coil 'C' secondary circuit fault
P1364Ignition coil primary circuit fault
P1365Ignition coil secondary circuit fault
P1382Camshaft Position Timing Solenoid #1 Circuit
P1387Camshaft Position Timing Solenoid #2 Circuit
P1390Octane adjust shorting bar out or circuit open
P1400DPFE sensor signal below self test minimum
P1401DPFE sensor signal above self test maximum
P1405DPFE sensor upstream hose off or plugged
P1406DPFE sensor downstream hose off or plugged
P1407No EGR flow detected
P1408EGR system flow out of KOER self test range
P1409EGR vacuum regulator solenoid circuit fault
P1412Exhaust Gas Recirculation Valve Frozen
P1415Air Pump Circuit
P1416Port Air Circuit
P1417Port Air Relief Circuit
P1418Split Air #1 Circuit
P1419Split Air #2 Circuit
P1439Floor Temp Switch Circuit
P1443EVAP system purge flow fault
P1444EVAP purge flow sensor circuit low voltage
P1445EVAP purge flow sensor circuit high voltage
P1446Evaporative Vacuum Solenoid Circuit
P1449Evaporative Check Solenoid Circuit
P1450Unable to Bleed Up Fuel Tank Vacuum
P1451Evaporative Emission Control System Vent Control Circuit
P1455Fuel tank level sensor circuit fault
P1456Fuel Tank Temperature Sensor Circuit
P1457Purge Solenoid Control System
P1460Wide open throttle A/C cut-off relay circiut fault
P1464Air conditioning control signal circuit fault
P1465A/C Relay Circuit
P1473Fan Circuit Open (VLCM)
P1474Fan control system fault
P1477Additional Fan Relay Circuit
P1479High Fan Control Primary Circuit
P1480Fan Secondary Low With Low Fan On
P1481Fan Secondary Low With High Fan On
P1485EGR vacuum solenoid circuit fault
P1486EGR vent solenoid circuit fault
P1487Exhaust Gas Recirculation Check Solenoid Circuit
P1490Secondary Air Relief Solenoid Circuit
P1491Secondary Switch Solenoid Circuit
P1492APLSOL Solenoid Circuit
P1493RCNT Solenoid Circuit
P1494SPCUT Solenoid Circuit
P1495TCSPL Solenoid Circuit
P1496EGR Stepper Motor 1 Control Circuit Low/High
P1497EGR Stepper Motor 2 Control Circuit Low/High
P1498EGR Stepper Motor 3 Control Circuit Low/High
P1499EGR Stepper Motor 4 Control Circuit Low/High
P1500Vehicle speed sensor intermittent signals
P1501Vehicle speed sensor out of self test range
P1504Idle air control solenoid circuit intermittent fault
P1505Idle air control system at adaptive clip
P1506IAC system overspeed detected during self test
P1507IAC system underspeed detected during self test
P1508Bypass air solenoid '1' circuit fault
P1509Bypass air solenoid '2' circuit fault
P1510Idle Signal Circuit
P1511Idle Switch (Electric Control Throttle) Circuit
P1512Intake Manifold Runner Control Stuck Closed (Bank 1)
P1515Electric Current Circuit
P1521Variable Resonance Induction System Solenoid #1 Circuit
P1522Variable Resonance Induction System Solenoid #2 Circuit
P1523VICS solenoid circuit fault
P1524Variable Intake Solenoid Circuit
P1525ABV vacuum solenoid circuit fault
P1526ABV vent solenoid circuit fault
P1527Bypass Air Solenoid (Accelerate Warmup) Circuit
P1528Subsidiary Throttle Valve Solenoid Circuit
P1529L/C atmospheric balance air control valve fault
P1540Air Bypass Valve Circuit
P1562PCM B+ Voltage Low (KAM power)
P1566TCM B+ Voltage Low
P1569Intake Manifold Runner Control Control Circuit Low
P1570Intake Manifold Runner Control Control Circuit High
P1600Loss Of KAM Power, Circuit Open
P1601ECM / TCM Serial Communication Error
P1602Immobilizer / ECM Communication Error
P1603ID Number Unregistered
P1604Code Word Unregistered
P1605PCM keep active memory test error
P1608PCM Internal Circuit
P1609PCM (ECM CPU) knock sensor fault
P1621Immobilizer Code Words Do Not Match
P1622Immobilizer ID Does Not Match
P1623Immobilizer Code Word / ID Number Write Failure
P1624Anti-theft System
P1627PCM (ECM / TCS) line communication error
P1628PCM (ECM / TCS) ABV line communication error
P1630Alternator Regulator #1 Control Circuit
P1631Alternator Regulator #2 Control Circuit
P1633Generator Control System - over charge
P1634Generator Control System - no charge
P1645Fuel Pump Resistor Switch Circuit
P1649Fuel Injection Pump Module
P1650Power steering pressure switch out of range fault
P1651Power steering pressure switch circuit fault
P1652Idle Air Control Monitor Disabled By PSPS Failed On
P1680Metering Oil Pump Failure
P1681Metering Oil Pump Failure
P1682Metering Oil Pump Failure
P1683Metering Oil Pump Temperature Sensor Circuit
P1684Metering Oil Pump Position Sensor Circuit
P1685Metering Oil Pump Stepping Motor Cont.Circuit
P1686Metering Oil Pump Stepping Motor Cont.Circuit
P1687Metering Oil Pump Stepping Motor Cont.Circuit
P1688Metering Oil Pump Stepping Motor Cont.Circuit
P1689Oil Pressure Control Solenoid Circuit
P1690Wastegate Solenoid Circuit
P1691Turbo Pressure Control Solenoid Circuit
P1692Turbo Control Solenoid Circuit
P1693Turbo Charge Control Circuit
P1694Turbo Charge Relief Circuit
P1701A / T TR sensor reverse engagement error
P1703Brake on / off switch out of self test range
P1705Transmission Range Circuit Not Indicating Park / Neutral During Self Test
P1706HighVehicle Speed Observed in Park
P1708Clutch Switch Circuit
P1709Clutch Pedal (or Park / Neutral Position) Switch Out Of Self Test Range
P1710Transmission Control Module Solenoid / Internal Ground Circuit
P1711A/T TFT sensor out of self test range
P1713Transmission Fluid Temperature Sensor In Range Failure
P1719Engine Torque Signal
P1720Vehicle speed sensor '2' signal error
P1721Gear 1 Incorrect Ratio
P1722Gear 2 Incorrect Ratio
P1723Gear 3 Incorrect Ratio
P1724Gear 4 Incorrect Ratio
P1729Transmission 4ЎБ4 low switch error during self test
P1735First Gear Switch Circuit Failure
P1736Second Gear Switch Circuit Failure
P1737Lockup Solenoid
P1738Shift Time Error
P1739Slip Solenoid
P1741Torque converter clutch control error
P1742Torque converter clutch failed on, MIL is on
P1743Torque converter clutch failed on, TCIL is on
P1744Torque converter clutch Solenoid Circuit
P1745Line Pressure Solenoid
P1746Electronic pressure control solenoid circuit open
P1747Electronic pressure control solenoid circuit short
P1748Pressure Control Solenoid A
P1749Electronic pressure control solenoid circuit low
P1751Shift Solenoid A Circuit Open
P1752Shift Solenoid A Circuit Short
P1754Transmission coast clutch solenoid electrical fault
P1756Shift Solenoid B Circuit Open
P1757Shift Solenoid B Circuit Short
P17592-4 Brake Failsafe Valve Malfunction
P1761Transmission shift solenoid '3' performance
P1763Low and Reverse Brake Pressure Switch Circuit
P1764Low and Reverse Brake Failsafe Valve Malfunction
P1765Timing Solenoid Circuit
P1770Clutch Solenoid Circuit
P1771Throttle Position Sensor Circuit High Input
P1772Throttle Position Sensor Circuit Low Input
P1775Torque Down Signal #1 Circuit
P1776Torque Down Signal #2 Circuit
P1777Torque Down Response Signal Circuit
P1780Transmission control switch electrical fault
P1781Transmission 4ЎБ4 low switch out of range fault
P1783Transmission fluid temperature too high
P1788Pressure Control Solenoid B Open Circuit
P1789Pressure Control Solenoid B Short Circuit
P1790TP (Mechanical ) Circuit
P1791TP (Electric) Circuit
P1792Barometer Pressure Circuit
P1793Intake Air Volume Circuit
P1795Idle Switch Circuit
P1796Kick Down Switch Circuit
P1797Clutch Pedal (or Park / Neutral ) Position Switch Circuit
P1798Coolant Temperature Circuit
P1799Hold Switch Circuit
MERCEDES (diesel)
P1105Atmospheric pressure sensor in control module
P1220Fuel quantity actuator (Y23/1)
P1221CAN communication, ETC or ETS interrupted
P1222IFI accelerator pedal position sensor (R25/2)
P1223Fuel rack position sensor (Y23/1/1)
P1335CKP sensor (IFI)
P1350Injection sensor solenoid
P1351Injection sensor circuit
P1352Needle Lift Sensor
P1401EGR lifting sender (B28/3)
P1404EGR control
P1465EPW power
P1470Pressure control flap vacuum transducer (Y31/2)
P1475Resonance intake line switchover valve (Y22/7)
P1476Resonance intake manifold switchover valve (Y22/6)
P1480Preglow control
P1481Glow plug failure
P1482Preglow control module (N14/2)
P1520Cruise control switch (S40)
P1610Voltage supply missing -or- relay module (K40)
P1611IFI Control module (N3/7)
P1612IFI Control module (N3/7) voltage, circuit 15
P1613IFI Control module (N3/7)
P1614IFI Control module (N3/7) voltage -or-Fuel metering actuator(Y23/1k1) -or-Fuel rack position sensor(Y23/1/1)
P1615IFI Control module (N3/7) supply voltage
P1617Control module fault -or- Control module not coded
P1622Electrohydraulic shut-off actutor (Y1/1)
P1625Check Engine MIL
P1630Drive authorization signal
P1705Starter lock-out/backup lamp switch(S16/1)
P1780Modulating pressure switchover valve(AT/CC)(Y3/4) -or-Upshift delay switchover valve(AT/CC)(Y3/5)
P1781Upshift delay switchover valve (AT/CC)(Y3/5)
MERCEDES benzin
P1146Left hot film MGF sensor (B2/6)
P1147Left ECT sensor (B11/9)
P1148Left IAT sensor (B17/5)
P1149Left Manifold pressure sensor (B28/1)
P1162Left EA/CC/ISC actuator actual value potentiometer (M16/4r1,M16/4r2)
P1163Oil level switch (S43)
P1176Oil pressure sensor
P1177Oil sensor, level-temperature implausible
P1179Oil quality implausible
P1180High oil temperature
P1181Engine electric cooling fan, faulty
P1182Start relay output stage, faulty
P1183Output stage cylinder fadeout, valve1
P1184Output stage cylinder fadeout valve2
P1185Water in oil
P1186Satety fuel shutoff detected
P1225Variable intake manifold switchover valve (Y22/6)
P1233Throttle valve jamming
P1300Left CKP sensor (L5/4)
P1355Cylinder shut-off valve, right bank (Y80) does not close at cylinder cutoff
P1356Cylinder shut-off valve, left bank(Y81) does not close at cylinder cutoff
P1357Cylinder cutoff,inlet valve of a cylinder continuous to be operated at cylinder cutoff
P1358Cylinder 5 exhaust valve is not operating at cylinder cutoff
P1359Cylinder 2 exhaust valve is not operating at cylinder cutoff
P1360Cylinder 3 exhaust valve is not operating at cylinder cutoff
P1361Cylinder 8 exhaust valve is not operating at cylinder cutoff
P1366Exhaust flap switchover valve (Y93)
P1380Inlet valve of a cylinder is not operated at cylinder cutoff
P1384Left knock sensor 1 (A29g1)
P1385Left knock sensor 2 (A29g2)
P1386Knock sensor regulation from right ECM (N3/12) hardware failure
P1397Left camshaft Hall-effect sensor (B6/2)
P1400EGR switchover valve output stage (Y31-1)
P1420AIR pump switchover valve (Y32)
P1437Exhaust gas temperature sensor 1
P1443Purge valve
P1444Exhaust gas temperature sensor 2
P1453AIR relay module (K17)
P1463Left AIR system malfunction
P1490Left purge control valve (Y58/2)
P1491A/C refrigerant pressure too high
P1519Right adjustable camshaft timing solenoid (Y49/2)(logic chain)
P1522Left adjustable camshaft timing solenoid (Y49/1)(logic chain)
P1525Right adjustable camshaft timing solenoid (Y49/2)
P1533Left adjustable camshaft timing solenoid (Y49/1)
P1542Pedal value sensor (B37)
P1550AC compressor torque implausible
P1570Start enable of DAS not sent
P1580Throttle valve actuator (M16/6)
P1581Left EA/CC/ISC actuator M16/4)
P1584Stop lamp switch (S9/1)
P1587Left ECM (N3/11) voltage supply
P1588CAN signal from RCL control module (N54) to left ECM (N3/11) interrupted
P1589Knock sensor regulation from left ECM (N3/11) hardware failure
P1603No or incorrect CAN message from control unit EIS
P1605Rough road detected by signal from comparing wheel speeds
P1632Left engine control module (N3/11)
P1642ECU incorrectly coded
P1643ECU incorrectly coded -or- CAN from transmission
P1644Transmission version can't be checked due to low voltage at transmission ECU
P1681Crash Sensor, signal implausible or frontal crash or short to power
P1747CAN signal from ETC (N15/3) interrupted
MITSUBISHI
P1100Induction control motor position sensor fault
P1101Traction control vacuum solenoid circuit fault
P1102Traction control ventilation solenoid circuit fault
P1103Turbocharger waste gate actuator circuit fault
P1104Turbocharger waster Gate solenoid circuit fault
P1105Fuel pressure solenoid circuit fault
P1294Target Idle speed not reached
P1295No 5-volt supply to TP sensor
P1296No 5-volt supply to MAP sensor
P1297No charge in MAP from start to run
P1300Ignition timing adjustment circuit fault
P1390Timing belt skipped one tooth or more
P1391Intermittent loss of CMP or CKP sensor signals
P1400Manifold differential pressure sensor fault
P1443EVAP purge control solenoid '2' circuit fault
P1486EVAP leak monitor pinched hose detected
P1487High speed radiator fan control relay circuit fault
P1489High speed condenser fan control relay fault
P1490Low speed fan control relay fault
P1492Battery temperature sensor high voltage
P1494EVAP ventilation switch or mechanical fault
P1495EVAP ventilation solenoid circuit fault
P14965 Volt supply output too low
P1500Generator FR terminal circuit fault
P1600PCM / TCM serial communication link circuit fault
P1696PCM failure- EEPROM write denied
P1698NO CCD messages from TCM
P1715TCM pulse generator circuit fault
P1750Pressure control,shift control,TCC solenoid fault
P1791PCM ECT level signal to TCM circuit fault
P1899P / N position / transaxle range switch circuit fault
NISSAN
P1031Air/Fuel Ratio Sensor Meter
P1032Air/Fuel Ratio Sensor Meter
P1065ECM Power Supply Heater
P1102Mass Air Flow Sensor Function Heater
P1103MAP Sensor Heater
P1104MAP Sensor Heater
P1105MAP/BARO Switch SOL/V
P1108MAP Sensor Heater
P1110Intake Valve Timing Control, LH Bank
P1111Intake Valve Timing Control Solenoid Valve
P1119Radiator Temperature Sensor Circuit
P1120TP Sensor 2
P1121Electronic Throttle Control Actuator
P1122Electronic Throttle Control Actuator
P1124Throttle Control Motor Relay
P1125Tandem TP Sensor
P1126Throttle Control Motor Relay
P1128Throttle Control Motor
P1130Swirl Control Valve Control Solenoid Valve
P1131Swirl Control Solenoid Valve
P1132Swirl Control Valve
P1135Intake Valve Timing Control, RH Bank 2
P1136Intake Valve Timing Control Solenoid Valve
P1137Swirl Control Valve Position Sensor
P1138Swirl Control Valve
P1140Intake Valve Timing Control Position Sensor, LH Bank 1
P1143Heated O2 Sensor 1
P1144Heated O2 Sensor 1
P1145Intake Valve Timing Control Position Sensor, RH Bank 2
P1146Heated O2 Sensor 2
P1147Heated O2 Sensor 2
P1148Closed Loop, Bank 1
P1163Heated O2 Sensor 1
P1164Heated O2 Sensor 1
P1165Swirl Control Valve Control Vacuum Check Switch
P1166Heated O2 Sensor 2
P1167Heated O2 Sensor 2
P1168Closed Loop, Bank 2
P1169Heated O2 Sensor 3
P1170Heated O2 Sensor 3
P1210Traction Control Signal Circuit
P1211ABS/TCS Control Unit
P1212ABS/TCS Communication Line
P1217Engine Coolant Temperature
P1220FPCM
P1221Throttle Actuator Circuit
P1222Temperature Sensor Circuit
P1223Throttle Position Sensor 2
P1224Throttle Position Sensor 2
P1225Closed Throttle Position Learning
P1226Closed Throttle Position Learning
P1227Accelerator Pedal Position Sensor 2
P1228Accelerator Pedal Position Sensor 2
P1229Sensor Power Supply
P1271Air/Fuel Ratio Sensor 1
P1272Air/Fuel Ratio Sensor 1
P1273Air/Fuel Ratio Sensor 1
P1274Air/Fuel Ratio Sensor 1
P1276Air/Fuel Ratio Sensor 1
P1278Air/Fuel Ratio Sensor 1
P1279Air/Fuel Ratio Sensor 1
P1320Ignition Signal, Primary
P1335CKP Sensor (Ref)
P1336CKP Sensor (POS) Cog
P1400EGRC Solenoid/V
P1401EGR Temp Sensor
P1402EGR System
P1440EVAP Small Leak
P1441VC/V Bypass/V
P1443Canister Control Vacuum Check Switch
P1444Purge Volume Control/V
P1445Purge Volume Control/V
P1446Vent Control Valve
P1447EVAP Purge Flow
P1448Vent Control Valve
P1456EVAP Control System
P1464Fuel Level Sensor Circuit Ground Signal
P1480Fan Control Solenoid Valve Circuit
P1490VC/V Bypass/V
P1491VC Cut/V Bypass/V
P1492Purge Control/V S/V
P1493Purge Control/V & S/V
P1564ASCD Steering Switch
P1568ICC (Intelligent Cruise Control)
P1572ASCD (Automatic Sped Control Device) Brake Switch
P1574ASCD Vehicle Speed Sensor
P1605A/T Diag Comm Line
P1610NATS Malfunction
P1611NATS Malfunction
P1612NATS Malfunction
P1613NATS Malfunction
P1614NATS Malfunction
P1615NATS Malfunction
P1705TP Sensor A/T
P1706PNP Switch
P1720Vehicle Speed Sensor- A/T Output
P1760Overrun Clutch S/V
P1775Torque Converter Clutch Solenoid Valve
P1776Torque Converter Clutch Solenoid Valve
P1780Shift Change Signal
P1800VIAS Control Solenoid Valve
P1805Brake switch
P1900Cooling Fan
SUBARU
P1086Tumble generator valve #2 (LH) position sensor circuit low input
P1087Tumble generator valve #2 (LH) position sensor circuit high input
P1088Tumble generator valve #1 (RH) position sensor circuit low input
P1089Tumble generator valve #1 (RH) position sensor circuit high input
P1090Tumble generator valve #1 (RH) malfunction (stuck open)
P1091Tumble generator valve #1 (RH) malfunction (stuck close)
P1092Tumble generator valve #2 (LH) malfunction (stuck open)
P1093Tumble generator valve #2 (LH) malfunction (stuck close)
P1094Tumble generator valve circuit #1 (open circuit)
P1095Tumble generator valve circuit #1 (over current)
P1096Tumble generator valve circuit #2 (open circuit)
P1097Tumble generator valve circuit #2 (over current)
P1100Starter Switch Circuit Malfunction
P1101Neutral Position Switch Circuit High Input (A/T), or Neutral Position Switch Circuit Malfunction (M/T)
P1102Pressure Sources Solenoid Valve Circuit Malfunction
P1103Pressure Sources Switching Solenoid Valve Circuit
P1104Engine Torque Control Signal Circuit Malfunction
P1106Engine Torque Control Signal 2 Circuit Malfunction
P1110Atmospheric pressure sensor low input
P1111Atmospheric pressure sensor high input
P1112Atmospheric pressure sensor range/performance problem
P1115Engine Torque Control Cut Signal Circuit High Input
P1116Engine Torque Control Cut Signal Circuit Low Input
P1120Starter Switch High Input
P1121Neutral Position Switch Circuit High Input [MT Vehicles], or Neutral Position Switch Circuit Low Input [AT Vehicles]
P1122Pressure Sources Switching Valve Circuit High Input
P1124TCS Signal Circuit High Input
P1130Front oxygen sensor circuit malfunction (open circuit)
P1131Front oxygen sensor circuit malfunction (short circuit)
P1134Front oxygen (A/F) sensor microcomputer problem
P1137Front oxygen (A/F) sensor circuit range/performance problem
P1139Front oxygen (A/F) sensor #1 heater circuit performance/range problem
P1141Mass Air Flow Sensor Circuit High Input
P1142Mass Air Flow Sensor Circuit Low Input
P1143Pressure Sensor Circuit Low Input
P1144Pressure Sensor Circuit High Input
P1146Pressure sensor circuit range/performance problem (high input)
P1150Front Oxygen Sensor Heater Circuit High Input
P1151Rear Oxygen Sensor Heater Circuit High Input
P1230Fuel pump control unit malfunction
P1244Wastegate control solenoid valve malfunction (low input)
P1245Wastegate control solenoid valve malfunction (fail-safe)
P1301Fire due to increased exhaust temperature
P1312Exhaust temperature sensor malfunction
P1325Knock Sensor Circuit Low Input
P1400Fuel Tank Pressure Control Solenoid Low Input
P1420Fuel Tank Pressure Control Solenoid High Input
P1421Exhaust Gas Recirculation Circuit High Input
P1422EVAP Purge Control Valve Circuit High Input
P1423EVAP Vent Control High Input
P1440Fuel Tank Pressure Control System Low Input
P1441Fuel Tank Pressure Control System High Input
P1442Fuel Level Sensor Circuit Range/Perf
P1443EVAP Control System Vent Control Function Problem
P1480Cooling fan relay 1 circuit high input
P1500Radiator Fan Relay 1 Circuit Malfunction
P1501Idle Control System Malfunction (Fail Safe)
P1502Radiator Fan Function Problem
P1507Idle Control System Malfunction (Fail Safe)
P1510Idle Air Control Solenoid Signal 1 Circuit Low Input
P1511Idle Air Control Solenoid Signal 1 Circuit High Input
P1512Idle Air Control Solenoid Signal 2 Circuit Low Input
P1513Idle Air Control Solenoid Signal 2 Circuit High Input
P1514Idle Air Control Solenoid Signal 3 Circuit Low Input
P1515Idle Air Control Solenoid Signal 3 Circuit High Input
P1516Idle Air Control Solenoid Signal 4 Circuit Low Input
P1517Idle Air Control Solenoid Signal 4 Circuit High Input
P1518Starter switch circuit low input
P1520Radiator Fan Relay 1 Circuit High Input
P1540Vehicle Speed Sensor Malfunction 2
P1544High exhaust temperature detected
P1560Back-Up Voltage Circuit Malfunction
P1590Neutral position switch circuit high input
P1591Neutral position switch circuit low input
P1592Neutral position switch circuit (MT model)
P1594Automatic transmission diagnosis input signal circuit malfunction
P1595Automatic transmission diagnosis input signal circuit low input
P1596Automatic transmission diagnosis input signal circuit high input
P1698Engine torque control cut signal circuit low input
P1699Engine torque control cut signal circuit high input
P1700Throttle Position Sensor Circuit Malfunction (A/T)
P1701Cruise Control Set Signal Circuit Malfunction (A/T)
P1702Auto Trans Diagnosis Input Signal Circuit
P1703Low clutch timing control solenoid valve circuit malfunction
P17042-4 Brake Timing Solenoid Valve Circuit Malfunction
P17052-4 Brake Pressure Solenoid Valve (Solenoid D) Circuit
P1711Engine torque control signal 1 circuit malfunction
P1712Engine torque control signal 2 circuit malfunction
P1722Auto Trans Diagnosis Input Signal High Input
P1742Auto Trans Diagnosis Input Signal Malfunction
SUZUKI
P1250EFE heater circuit fault
P1408Manifold differential pressure sensor circuit fault
P1410Fuel tank pressure control solenoid circuit fault
P1450Barometric pressure sensor too low or too high
P1451Barometric pressure sensor performance
P1460Radiator fan control system fault
P1500Engine starter signal circuit fault
P1510PCM backup power supply circuit fault
P1530Ignition timing adjustment switch circuit fault
P1600PCM / TCM serial communication circuit fault
P1700TCM throttle position sensor circuit fault
P1705TCM ECT sensor circuit fault
P1710Back-Up Signal For Speed Sensor Circuit Malfunction
P1715PNP switch circuit fault
P1717AT Drive range signal circuit fault
P18754WD Low Switch Circuit Malfunction
P1895TCM To ECM Torque Reduction Circuit Malfunction
TOYOTA
P1100BARO Sensor Circuit malfunction
P1120Accelerator Pedal Position Sensor Circuit Malfunction
P1121Accelerator Pedal Position Sensor Range/Performance Problem
P1125Throttle Control Motor Circuit Malfunction
P1126Magnetic Clutch Circuit Malfunction
P1127ETCS Actuator Power Source Circuit Malfunction
P1128Throttle Control Motor Lock Malfunction
P1129Electric Throttle Control System Malfunction
P1130AirЁCFuel Sensor Circuit Range/Performance
P1133AirЁCFuel Sensor Circuit Response Malfunction
P1135AirЁCFuel Sensor Heater Circuit Response Malfunction
P1150A./F Sensor Circuit Range/Performance Malfunction
P1153A./F Sensor Circuit Response Malfunction
P1155A./F Sensor Heater Circuit Malfunction
P1200Fuel Pump Relay Circuit Malfunction
P1300Igniter Circuit Malfunction No. 1
P1305Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
P1310Igniter Circuit Malfunction No. 2 (Except 1998-2000 Land Cruiser, 2000 Celica & Tundra), or Igniter Circuit Malfunction No. 3 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
P1315Igniter Circuit Malfunction No. 4 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
P1320Igniter Circuit Malfunction No. 5 (1998-2000 Land Cruiser & 2000 Tundra)
P1325Igniter Circuit Malfunction No. 6 (1998-2000 Land Cruiser & 2000 Tundra)
P1330Igniter Circuit Malfunction No. 7 (1998-2000 Land Cruiser & 2000 Tundra)
P1335No CKP Sensor Signal Engine Running
P1340Igniter Circuit Malfunction No. 8 (1998-2000 Land Cruiser & 2000 Tundra)
P1345VVT Sensor/Camshaft Position Sensor Circuit Malfunction Bank 1
P1346VVT Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1)
P1349VVT System Malfunction Bank 1
P1350VVT Sensor/Camshaft Position Sensor Circuit Malfunction Bank 2
P1351VVT Sensor/Camshaft Position Sensor Circuit Range/Performance Problem Bank 2
P1354VVT System Malfunction Bank 2
P1400Sub-Throttle Position Sensor Malfunction
P1401Sub-Throttle Position Sensor Range/Performance Problem
P1405Turbo Pressure Sensor Circuit Malfunction
P1406Turbo Pressure Sensor Range/Performance Problem
P1410EGR Valve Position Sensor Circuit Malfunction
P1411EGR Valve Position Sensor Circuit Range/Performance
P1500Starter Signal Circuit Malfunction
P1510Boost Pressure Control Circuit Malfunction
P1511Boost Pressure Low Malfunction
P1512Boost Pressure High Malfunction
P1520Stop Lamp Switch Signal Malfunction
P1565Cruise Control Main Switch Circuit Malfunction
P1600ECM BATT Malfunction
P1605Knock Control CPU Malfunction
P1630Traction Control System Malfunction
P1633ECM Malfunction ECTS Circuit
P1645Body ECU Malfunction
P1652IACV Control Circuit Malfunction
P1656OCV Circuit Malfunction Bank 1
P1658Waste Gate Valve Control Circuit Malfunction
P1661EGR Circuit Malfunction
P1662EGR By-Pass Valve Control Circuit Malfunction
P1663OCV Circuit Malfunction Bank 2
P1690OCV Circuit Malfunction
P1692OCV Open Malfunction
P1693OCV Closed Malfunction
P1780PNP Switch Malfunction
VW_NEW
P1101O2 Sensor Circ., Bank1-Sensor1 Voltage too Low/Air Leak
P1102O2 Sensor Heating Circ., Bank1-Sensor1 Short to B+
P1103O2 Sensor Heating Circ., Bank1-Sensor1 Output too Low
P1104Bank1-Sensor2 Voltage too Low/Air Leak
P1105O2 Sensor Heating Circ., Bank1-Sensor2 Short to B+
P1106O2 Sensor Circ., Bank2-Sensor1 Voltage too Low/Air Leak
P1107O2 Sensor Heating Circ., Bank2-Sensor1 Short to B+
P1108O2 Sensor Heating Circ., Bank2-Sensor1 Output too Low
P1109O2 Sensor Circ., Bank2-Sensor2 Voltage too Low/Air Leak
P1110O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+
P1111O2 Control (Bank 1) System too lean
P1112O2 Control (Bank 1) System too rich
P1113Bank1-Sensor1 Internal Resistance too High
P1114Bank1-Sensor2 Internal Resistant too High
P1115O2 Sensor Heater Circ., Bank1-Sensor1 Short to Ground
P1116O2 Sensor Heater Circ., Bank1-Sensor1 Open
P1117O2 Sensor Heater Circ., Bank1-Sensor2 Short to Ground
P1118O2 Sensor Heater Circ., Bank1-Sensor2 Open
P1119O2 Sensor Heater Circ., Bank2-Sensor1 Short to Ground
P1120O2 Sensor Heater Circ., Bank2-Sensor1 Open
P1121O2 Sensor Heater Circ., Bank2-Sensor2 Short to Ground
P1122O2 Sensor Heater Circ., Bank2-Sensor2 Open
P1123Long Term Fuel Trim Add.Air., Bank1 System too Rich
P1124Long Term Fuel Trim Add.Air., Bank1 System too Lean
P1125Long Term Fuel Trim Add.Air., Bank2 System too Rich
P1126Long Term Fuel Trim Add.Air., Bank2 System too Lean
P1127Long Term Fuel Trim mult., Bank1 System too Rich
P1128Long Term Fuel Trim mult., Bank1 System too Lean
P1129Long Term Fuel Trim mult., Bank2 System too Rich
P1130Long Term Fuel Trim mult., Bank2 System too Lean
P1131Bank2-Sensor1 Internal Rsistance too High
P1132O2 Sensor Heating Circ., Bank1+2-Sensor1 Short to B+
P1133O2 Sensor Heating Circ., Bank1+2-Sensor1 Electrical Malfunction
P1134O2 Sensor Heating Circ., Bank1+2-Sensor2 Short to B+
P1135O2 Sensor Heating Circ., Bank1+2-Sensor2 Electrical Malfunction
P1136Long Term Fuel Trim Add.Fuel, Bank1 System too Lean
P1137Long Term Fuel Trim Add.Fuel, Bank1 System too Rich
P1138Long Term Fuel Trim Add.Fuel, Bank2 System too Lean
P1139Long Term Fuel Trim Add.Fuel, Bank2 System too Rich
P1140Bank2-Sensor2 Internal Resistance too High
P1141Load Calculation Cross Check Range/Performance
P1142Load Calculation Cross Check Lower Limit Exceeded
P1143Load Calculation Cross Check Upper Limit Exceeded
P1144Mass or Volume Air Flow Circ Open/Short to Ground
P1145Mass or Volume Air Flow Circ Short to B+
P1146Mass or Volume Air Flow Circ Supply Malfunction
P1147O2 Control (Bank 2) System too lean
P1148O2 Control (Bank 2) System too rich
P1149O2 Control (Bank 1) Out of range
P1150O2 Control (Bank 2) Out of range
P1151Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
P1152Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded
P1154Manifold Switch Over Malfunction
P1155Manifold Abs.Pressure Sensor Circ. Short to B+
P1156Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
P1157Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
P1158Manifold Abs.Pressure Sensor Circ. Range/Performance
P1160Manifold Temp.Sensor Circ. Short to Ground
P1161Manifold Temp.Sensor Circ. Open/Short to B+
P1162Fuel Temp.Sensor Circ. Short to Ground
P1163Fuel Temp.Sensor Circ. Open/Short to B+
P1164Fuel Temperature Sensor Range/ Performance/ Incorrect Signal
P1165Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
P1166Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
P1171Throttle Actuation Potentiometer Sign.2 Range/Performance
P1172Throttle Actuation Potentiometer Sign.2 Signal too Low
P1173Throttle Actuation Potentiometer Sign.2 Signal too High
P1174Fuel Trim, Bank 1 Different injection times
P1176O2 Correction Behind Catalyst,B1 Limit Attained
P1177O2 Correction Behind Catalyst,B2 Limit Attained
P1178Linear 02 Sensor/ Pump Current Open Circuit
P1179Linear 02 Sensor/ Pump Current Short to ground
P1180Linear 02 Sensor/ Pump Current Short to B+
P1181Linear 02 Sensor/ Reference Voltage Open Circuit
P1182Linear 02 Sensor/ Reference Voltage Short to ground
P1183Linear 02 Sensor/ Reference Voltage Short to B+
P1184Linear 02 Sensor/ Common Ground Wire Open Circuit
P1185Linear 02 Sensor/ Common Ground Wire Short to ground
P1186Linear 02 Sensor/ Common Ground Wire Short to B+
P1187Linear 02 Sensor/ Compens. Resistor Open Circuit
P1188Linear 02 Sensor/ Compens. Resistor Short to ground
P1189Linear 02 Sensor/ Compens. Resistor Short to B+
P1190Linear 02 Sensor/ Reference Voltage Incorrect Signal
P1196O2 Sensor Heater Circ., Bank1-Sensor1 Electrical Malfunction
P1197O2 Sensor Heater Circ., Bank2-Sensor1 Electrical Malfunction
P1198O2 Sensor Heater Circ., Bank1-Sensor2 Electrical Malfunction
P1199O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction
P1201Cyl.1-Fuel Inj.Circ. Electrical Malfunction
P1202Cyl.2-Fuel Inj.Circ. Electrical Malfunction
P1203Cyl.3-Fuel Inj.Circ. Electrical Malfunction
P1204Cyl.4-Fuel Inj.Circ. Electrical Malfunction
P1205Cyl.5-Fuel Inj.Circ. Electrical Malfunction
P1206Cyl.6-Fuel Inj.Circ. Electrical Malfunction
P1207Cyl.7-Fuel Inj.Circ. Electrical Malfunction
P1208Cyl.8-Fuel Inj.Circ. Electrical Malfunction
P1209Intake valves for cylinder shut-off Short circuit to ground
P1210Intake valves for cylinder shut-off Short to B+
P1211Intake valves for cylinder shut-off Open circuit
P1213Cyl.1-Fuel Inj.Circ. Short to B+
P1214Cyl.2-Fuel Inj.Circ. Short to B+
P1215Cyl.3-Fuel Inj.Circ. Short to B+
P1216Cyl.4-Fuel Inj.Circ. Short to B+
P1217Cyl.5-Fuel Inj.Circ. Short to B+
P1218Cyl.6-Fuel Inj.Circ. Short to B+
P1219Cyl.7-Fuel Inj.Circ. Short to B+
P1220Cyl.8-Fuel Inj.Circ. Short to B+
P1221Cylinder shut-off exhaust valves Short circuit to ground
P1222Cylinder shut-off exhaust valves Short to B+
P1223Cylinder shut-off exhaust valves Open circuit
P1225Cyl.1-Fuel Inj.Circ. Short to Ground
P1226Cyl.2-Fuel Inj.Circ. Short to Ground
P1227Cyl.3-Fuel Inj.Circ. Short to Ground
P1228Cyl.4-Fuel Inj.Circ. Short to Ground
P1229Cyl.5-Fuel Inj.Circ. Short to Ground
P1230Cyl.6-Fuel Inj.Circ. Short to Ground
P1231Cyl.7-Fuel Inj.Circ. Short to Ground
P1232Cyl.8-Fuel Inj.Circ. Short to Ground
P1237Cyl.1-Fuel Inj.Circ. Open Circ.
P1238Cyl.2-Fuel Inj.Circ. Open Circ.
P1239Cyl.3-Fuel Inj.Circ. Open Circ.
P1240Cyl.4-Fuel Inj.Circ. Open Circ.
P1241Cyl.5-Fuel Inj.Circ. Open Circ.
P1242Cyl.6-Fuel Inj.Circ. Open Circ.
P1243Cyl.7-Fuel Inj.Circ. Open Circ.
P1244Cyl.8-Fuel Inj.Circ. Open Circ.
P1245Needle Lift Sensor Circ. Short to Ground
P1246Needle Lift Sensor Circ. Range/Performance
P1247Needle Lift Sensor Circ. Open/Short to B+
P1248Injection Start Control Deviation
P1249Fuel consumption signal Electrical Fault in Circuit
P1250Fuel Level Too Low
P1251Start of Injection Solenoid Circ Short to B+
P1252Start of Injection Solenoid Circ Open/Short to Ground
P1253Fuel consumption signal Short to ground
P1254Fuel consumption signal Short to B+
P1255Engine Coolant Temp.Circ Short to Ground
P1256Engine Coolant Temp.Circ Open/Short to B+
P1257Engine Coolant System Valve Open
P1258Engine Coolant System Valve Short to B+
P1259Engine Coolant System Valve Short to Ground
P1280Fuel Inj.Air Contr.Valve Circ. Flow too Low
P1283Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
P1284Fuel Inj.Air Contr.Valve Circ. Open
P1285Fuel Inj.Air Contr.Valve Circ. Short to Ground
P1286Fuel Inj.Air Contr.Valve Circ. Short to B+
P1287Turbocharger bypass valve open
P1288Turbocharger bypass valve short to B+
P1289Turbocharger bypass valve short to ground
P1296Cooling system malfunction
P1297Connection turbocharger - throttle valve pressure hose
P1300Misfire detected Reason: Fuel level too low
P1319Knock Sensor 1 Circ. Short to Ground
P1320Knock Sensor 2 Circ. Short to Ground
P1321Knock Sensor 3 Circ. Low Input
P1322Knock Sensor 3 Circ. High Input
P1323Knock Sensor 4 Circ. Low Input
P1324Knock Sensor 4 Circ. High Input
P1325Cyl.1-Knock Contr. Limit Attained
P1326Cyl.2-Knock Contr. Limit Attained
P1327Cyl.3-Knock Contr. Limit Attained
P1328Cyl.4-Knock Contr. Limit Attained
P1329Cyl.5-Knock Contr. Limit Attained
P1330Cyl.6-Knock Contr. Limit Attained
P1331Cyl.7-Knock Contr. Limit Attained
P1332Cyl.8-Knock Contr. Limit Attained
P1335Engine Torque Monitoring 2 Control Limint Exceeded
P1336Engine Torque Monitoring Adaptation at limit
P1337Camshaft Pos.Sensor, Bank1 Short to Ground
P1338Camshaft Pos.Sensor, Bank1 Open Circ./Short to B+
P1339Crankshaft Pos./Engine Speed Sensor Cross Connected
P1340Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
P1341Ignition Coil Power Output Stage 1 Short to Ground
P1342Ignition Coil Power Output Stage 1 Short to B+
P1343Ignition Coil Power Output Stage 2 Short to Ground
P1344Ignition Coil Power Output Stage 2 Short to B+
P1345Ignition Coil Power Output Stage 3 Short to Ground
P1346Ignition Coil Power Output Stage 3 Short to B+
P1347Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
P1348Ignition Coil Power Output Stage 1 Open Circuit
P1349Ignition Coil Power Output Stage 2 Open Circuit
P1350Ignition Coil Power Output Stage 3 Open Circuit
P1354Modulation Piston Displ.Sensor Circ. Malfunction
P1355Cyl. 1, ignition circuit Open Circuit
P1356Cyl. 1, ignition circuit Short to B+
P1357Cyl. 1, ignition circuit Short to ground
P1358Cyl. 2, ignition circuit Open Circuit
P1359Cyl. 2, ignition circuit Short Circuit to B+
P1360Cyl. 2, ignition circuit Short Circuit to Ground
P1361Cyl. 3, ignition circuit Open Circuit
P1362Cyl. 3, ignition circuit Short Circuit to B+
P1363Cyl. 3, ignition circuit Short Circuit to ground
P1364Cyl. 4, ignition circuit Open Circuit
P1365Cyl. 4, ignition circuit Short circuit to B+
P1366Cyl. 4, ignition circuit Short circuit to ground
P1367Cyl. 5, ignition circuit Open Circuit
P1368Cyl. 5, ignition circuit Short Circuit to B+
P1369Cyl. 5, ignition circuit short to ground
P1370Cyl. 6, ignition circuit Open Circuit
P1371Cyl. 6, ignition circuit Short Circuit to B+
P1372Cyl. 6, ignition circuit short to ground
P1373Cyl. 7, ignition circuit Open Circuit
P1374Cyl. 7, ignition circuit Short Circuit to B+
P1375Cyl. 7, ignition circuit short to ground
P1376Cyl. 8, ignition circuit Open Circuit
P1377Cyl. 8, ignition circuit Short Circuit to B+
P1378Cyl. 8, ignition circuit short to ground
P1386Internal Control Module Knock Control Circ.Error
P1387Internal Contr. Module altitude sensor error
P1388Internal Contr. Module drive by wire error
P1391Camshaft Pos.Sensor,Bank2 Short to Ground
P1392Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
P1393Ignition Coil Power Output Stage 1 Electrical Malfunction
P1394Ignition Coil Power Output Stage 2 Electrical Malfunction
P1395Ignition Coil Power Output Stage 3 Electrical Malfunction
P1396Engine Speed Sensor Missing Tooth
P1397Engine speed wheel Adaptation limit reached
P1398Engine RPM signal, TD Short to ground
P1399Engine RPM signal, TD Short Circuit to B+
P1400EGR Valve Circ Electrical Malfunction
P1401EGR Valve Circ Short to Ground
P1402EGR Valve Circ Short to B+
P1403EGR Flow Deviation
P1404EGR Flow Basic Setting not carried out
P1406EGR Temp.Sensor Range/Performance
P1407EGR Temp.Sensor Signal too Low
P1408EGR Temp.Sensor Signal too High
P1409Tank Ventilation Valve Circ. Electrical Malfunction
P1410Tank Ventilation Valve Circ. Short to B+
P1411Sec.Air Inj.Sys.,Bank2 Flow too Flow
P1412EGR Different.Pressure Sensor Signal too Low
P1413EGR Different.Pressure Sensor Signal too High
P1414Sec.Air Inj.Sys.,Bank2 Leak Detected
P1417Fuel Level Sensor Circ Signal too Low
P1418Fuel Level Sensor Circ Signal too High
P1420Sec.Air Inj.Valve Circ Electrical Malfunction
P1421Sec.Air Inj.Valve Circ Short to Ground
P1422Sec.Air Inj.Sys.Contr.Valve Circ Short to B+
P1423Sec.Air Inj.Sys.,Bank1 Flow too Low
P1424Sec.Air Inj.Sys.,Bank1 Leak Detected
P1425Tank Vent.Valve Short to Ground
P1426Tank Vent.Valve Open
P1432Sec.Air Inj.Valve Open
P1433Sec.Air Inj.Sys.Pump Relay Circ. open
P1434Sec.Air Inj.Sys.Pump Relay Circ. Short to B+
P1435Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
P1436Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction
P1439EGR Potentiometer Error in Basic Seting
P1440EGR Valve Power Stage Open
P1441EGR Valve Circ Open/Short to Ground
P1442EGR Valve Position Sensor Signal too high
P1443EGR Valve Position Sensor Signal too low
P1444EGR Valve Position Sensor range/performance
P1445Catalyst Temp.Sensor 2 Circ. Range/Performance
P1446Catalyst Temp.Circ Short to Ground
P1447Catalyst Temp.Circ Open/Short to B+
P1448Catalyst Temp.Sensor 2 Circ. Short to Ground
P1449Catalyst Temp.Sensor 2 Circ. Open/Short to B+
P1450Sec.Air Inj.Sys.Circ Short to B+
P1451Sec.Air Inj.Sys.Circ Short to Ground
P1452Sec.Air Inj.Sys. Open Circ.
P1453Exhaust gas temperature sensor 1 open/short to B+
P1454Exhaust gas temperature sensor short 1 to ground
P1455Exhaust gas temperature sensor 1 range/performance
P1456Exhaust gas temperature control bank 1 limit attained
P1457Exhaust gas temperature sensor 2 open/short to B+
P1458Exhaust gas temperature sensor 2 short to ground
P1459Exhaust gas temperature sensor 2 range/performance
P1460Exhaust gas temperature control bank 2 limit attained
P1461Exhaust gas temperature control bank 1 Range/Performance
P1462Exhaust gas temperature control bank 2 Range/Performance
P1465Additive Pump Short Circuit to B+
P1466Additive Pump Open/Short to Ground
P1467EVAP Canister Purge Solenoid Valve Short Circuit to B+
P1468EVAP Canister Purge Solenoid Valve Short Circuit to Ground
P1469EVAP Canister Purge Solenoid Valve Open Circuit
P1470EVAP Emission Contr.LDP Circ Electrical Malfunction
P1471EVAP Emission Contr.LDP Circ Short to B+
P1472EVAP Emission Contr.LDP Circ Short to Ground
P1473EVAP Emission Contr.LDP Circ Open Circ.
P1474EVAP Canister Purge Solenoid Valve electrical malfunction
P1475EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open
P1476EVAP Emission Contr.LDP Circ Malfunction/ Insufficient Vacuum
P1477EVAP Emission Contr.LDP Circ Malfunction
P1478EVAP Emission Contr.LDP Circ Clamped Tube Detected
P1500Fuel Pump Relay Circ. Electrical Malfunction
P1501Fuel Pump Relay Circ. Short to Ground
P1502Fuel Pump Relay Circ. Short to B+
P1503Load signal from Alternator Term. DF Range/ performance/ Incorrect Signal
P1504Intake Air Sys.Bypass Leak Detected
P1505Closed Throttle Pos. Does Not Close/Open Circ
P1506Closed Throttle Pos.Switch Does Not Open/Short to Ground
P1507Idle Sys.Learned Value Lower Limit Attained
P1508Idle Sys.Learned Value Upper Limit Attained
P1509Idle Air Control Circ. Electrical Malfunction
P1510Idle Air Control Circ. Short to B+
P1511Intake Manifold Changeover Valve circuit electrical malfunction
P1512Intake Manifold Changeover Valve circuit Short to B+
P1513Intake Manifold Changeover Valve2 circuit Short to B+
P1514Intake Manifold Changeover Valve2 circuit Short to ground
P1515Intake Manifold Changeover Valve circuit Short to Ground
P1516Intake Manifold Changeover Valve circuit Open
P1517Main Relay Circ. Electrical Malfunction
P1518Main Relay Circ. Short to B+
P1519Intake Camshaft Contr.,Bank1 Malfunction
P1520Intake Manifold Changeover Valve2 circuit Open
P1521Intake Manifold Changeover Valve2 circuit electrical malfunction
P1522Intake Camshaft Contr.,Bank2 Malfunction
P1523Crash Signal from Airbag Control Unit range/performance
P1525Intake Camshaft Contr.Circ.,Bank1 Electrical Malfunction
P1526Intake Camshaft Contr.Circ.,Bank1 Short to B+
P1527Intake Camshaft Contr.Circ.,Bank1 Short to Ground
P1528Intake Camshaft Contr.Circ.,Bank1 Open
P1529Camshaft Control Circuit Short to B+
P1530Camshaft Control Circuit Short to ground
P1531Camshaft Control Circuit open
P1533Intake Camshaft Contr.Circ.,Bank2 Electrical Malfunction
P1534Intake Camshaft Contr.Circ.,Bank2 Short to B+
P1535Intake Camshaft Contr.Circ.,Bank2 Short to Ground
P1536Intake Camshaft Contr.Circ.,Bank2 Open
P1537Engine Shutoff Solenoid Malfunction
P1538Engine Shutoff Solenoid Open/Short to Ground
P1539Clutch Vacuum Vent Valve Switch Incorrect signal
P1540Vehicle Speed Sensor High Input
P1541Fuel Pump Relay Circ Open
P1542Throttle Actuation Potentiometer Range/Performance
P1543Throttle Actuation Potentiometer Signal too Low
P1544Throttle Actuation Potentiometer Signal too High
P1545Throttle Pos.Contr Malfunction
P1546Boost Pressure Contr.Valve Short to B+
P1547Boost Pressure Contr.Valve Short to Ground
P1548Boost Pressure Contr.Valve Open
P1549Boost Pressure Contr.Valve Short to Ground
P1550Charge Pressure Deviation
P1551Barometric Pressure Sensor Circ. Short to B+
P1552Barometric Pressure Sensor Circ. Open/Short to Ground
P1553Barometric/manifold pressure signal ratio out of range
P1554Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met
P1555Charge Pressure Upper Limit exceeded
P1556Charge Pressure Contr. Negative Deviation
P1557Charge Pressure Contr. Positive Deviation
P1558Throttle Actuator Electrical Malfunction
P1559Idle Speed Contr.Throttle Pos. Adaptation Malfunction
P1560Maximum Engine Speed Exceeded
P1561Quantity Adjuster Deviation
P1562Quantity Adjuster Upper Limit Attained
P1563Quantity Adjuster Lower Limit Attained
P1564Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation
P1565Idle Speed Control Throttle Position lower limit not attained
P1566Load signal from A/C compressor range/performance
P1567Load signal from A/C compressor no signal
P1568Idle Speed Contr.Throttle Pos. mechanical Malfunction
P1569Cruise control switch Incorrect signal
P1570Contr.Module Locked
P1571Left Eng. Mount Solenoid Valve Short to B+
P1572Left Eng. Mount Solenoid Valve Short to ground
P1573Left Eng. Mount Solenoid Valve Open circuit
P1574Left Eng. Mount Solenoid Valve Electrical fault in circuit
P1575Right Eng. Mount Solenoid Valve Short to B+
P1576Right Eng. Mount Solenoid Valve Short to ground
P1577Right Eng. Mount Solenoid Valve Open circuit
P1578Right Eng. Mount Solenoid Valve Electrical fault in circuit
P1579Idle Speed Contr.Throttle Pos. Adaptation not started
P1580Throttle Actuator B1 Malfunction
P1581Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out
P1582Idle Adaptation at Limit
P1583Transmission mount valves Short to B+
P1584Transmission mount valves Short to ground
P1585Transmission mount valves Open circuit
P1586Engine mount solenoid valves Short to B+
P1587Engine mount solenoid valves Short to ground
P1588Engine mount solenoid valves Open circuit
P1600Power Supply (B+) Terminal 15 Low Voltage
P1602Power Supply (B+) Terminal 30 Low Voltage
P1603Internal Control Module Malfunction
P1604Internal Control Module Driver Error
P1605Rough Road/Acceleration Sensor Electrical Malfunction
P1606Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
P1607Vehicle speed signal Error message from instrument cluster
P1608Steering angle signal Error message from steering angle sensor
P1609Crash shut-down activated
P1611MIL Call-up Circ./Transm.Contr.Module Short to Ground
P1612Electronic Control Module Incorrect Coding
P1613MIL Call-up Circ Open/Short to B+
P1614MIL Call-up Circ./Transm.Contr.Module Range/Performance
P1615Engine Oil Temperature Sensor Circuit range/performance
P1616Glow Plug/Heater Indicator Circ. Short to B+
P1617Glow Plug/Heater Indicator Circ. Open/Short to Ground
P1618Glow Plug/Heater Relay Circ. Short to B+
P1619Glow Plug/Heater Relay Circ. Open/Short to Ground
P1620Engine coolant temperature signal open/short to B+
P1621Engine coolant temperature signal short to ground
P1622Engine coolant temperature signal range/performance
P1623Data Bus Powertrain No Communication
P1624MIL Request Sign.active
P1625Data-Bus Powertrain Unplausible Message from Transm.Contr.
P1626Data-Bus Powertrain Missing Message from Transm.Contr.
P1627Data-Bus Powertrain missing message from fuel injection pump
P1628Data-Bus Powertrain missing message from steering sensor
P1629Data-Bus Powertrain missing message from distance control
P1630Accelera.Pedal Pos.Sensor 1 Signal too Low
P1631Accelera.Pedal Pos.Sensor 1 Signal too High
P1632Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction
P1633Accelera.Pedal Pos.Sensor 2 Signal too Low
P1634Accelera.Pedal Pos.Sensor 2 Signal too High
P1635Data Bus Powertrain missing message f.air condition control
P1636Data Bus Powertrain missing message from Airbag control
P1637Data Bus Powertrain missing message f.central electr.control
P1638Data Bus Powertrain missing message from clutch control
P1639Accelera.Pedal Pos.Sensor 1+2 Range/Performance
P1640Internal Contr.Module (EEPROM) Error
P1641Please check DTC Memory of Air Condition ECU
P1642Please check DTC Memory of Airbag ECU
P1643Please check DTC Memory of central electric ECU
P1644Please check DTC Memory of clutch ECU
P1645Data Bus Powertrain missing message f.all wheel drive contr.
P1646Please Check DTC Memory of all wheel drive ECU
P1647Please check coding of ECUs in Data Bus Powertrain
P1648Data Bus Powertrain Malfunction
P1649Data Bus Powertrain Missing message from ABS Control Module
P1650Data Bus Powertrain Missing message fr.instrument panel ECU
P1651Data Bus Powertrain missing messages
P1652Please check DTC Memory of transmission ECU
P1653Please check DTC Memory of ABS Control Module
P1654Please check DTC Memory of control panel ECU
P1655Please check DTC Memory of ADR Control Module
P1656A/C clutch relay circuit short to ground
P1657A/C clutch relay circuit short to B+
P1658Data Bus Powertrain Incorrect signal from ADR Control Module
P1676Drive by Wire-MIL Circ. Electrical Malfunction
P1677Drive by Wire-MIL Circ. Short to B+
P1678Drive by Wire-MIL Circ. Short to Ground
P1679Drive by Wire-MIL Circ. Open
P1681Contr.Unit Programming, Programming not Finished
P1684Contr.Unit Programming Communication Error
P1686Contr.Unit Error Programming Error
P1690Malfunction Indication Light Malfunction
P1691Malfunction Indication Light Open
P1692Malfunction Indication Light Short to Ground
P1693Malfunction Indication Light Short to B+
P1694Malfunction Indication Light Open/Short to Ground
P1704Kick Down Switch Malfunction
P1705Gear/Ratio Monitoring Adaptation limit reached
P1711Wheel Speed Signal 1 Range/Performance
P1716Wheel Speed Signal 2 Range/Performance
P1721Wheel Speed Signal 3 Range/Performance
P1723Starter Interlock Circ. Open
P1724Starter Interlock Circ. Short to Ground
P1726Wheel Speed Signal 4 Range/Performance
P1728Different Wheel Speed Signals Range/Performance
P1729Starter Interlock Circ. Short to B+
P1733Tiptronic Switch Down Circ. Short to Ground
P1739Tiptronic Switch up Circ. Short to Ground
P1740Clutch temperature control
P1741Clutch pressure adaptation at limit
P1742Clutch torque adaptation at limit
P1743Clutch slip control signal too high
P1744Tiptronic Switch Recognition Circ. Short to Ground
P1745Transm.Contr.Unit Relay Short to B+
P1746Transm.Contr.Unit Relay Malfunction
P1747Transm.Contr.Unit Relay Open/Short to Ground
P1748Transm.Contr.Unit Self-Check
P1749Transm.Contr.Unit Incorrect Coded
P1750Power Supply Voltage Low Voltage
P1751Power Supply Voltage High Voltage
P1752Power Supply Malfunction
P1760Shift Lock Malfunction
P1761Shift Lock Short to Ground
P1762Shift Lock Short to B+
P1763Shift Lock Open
P1764Transmission temperature control
P1765Hydraulic Pressure Sensor 2 adaptation at limit
P1766Throttle Angle Signal Stuck Off
P1767Throttle Angle Signal Stuck On
P1768Hydraulic Pressure Sensor 2 Too High
P1769Hydraulic Pressure Sensor 2 Too Low
P1770Load Signal Range/Performance
P1771Load Signal Stuck Off
P1772Load Signal Stuck On
P1773Hydraulic Pressure Sensor 1 Too High
P1774Hydraulic Pressure Sensor 1 Too Low
P1775Hydraulic Pressure Sensor 1 adaptation at limit
P1776Hydraulic Pressure Sensor 1 range/performance
P1777Hydraulic Pressure Sensor 2 range/performance
P1778Solenoid EV7 Electrical Malfunction
P1780Engine Intervention Unreadable. Also check for loose ECM power relay.
P1781Engine Torque Reduction Open/Short to Ground
P1782Engine Torque Reduction Short to B+
P1784Shift up/down Wire Open/Short to Ground
P1785Shift up/down Wire Short to B+
P1786Reversing Light Circ. Open
P1787Reversing Light Circ. Short to Ground
P1788Reversing Light Circ. Short to B+
P1789Idle Speed Intervention Circ. Error Message from Engine Contr.
P1790Transmission Range Display Circ. Open
P1791Transmission Range Display Circ. Short to Ground
P1792Transmission Range Display Circ. Short to B+
P1793Output Speed Sensor 2 Circ. No Signal
P1795Vehicle Speed Signal Circ. Open
P1796Vehicle Speed Signal Circ. Short to Ground
P1797Vehicle Speed Signal Circ. Short to B+
P1798Output Speed Sensor 2 Circ. Range/Performance
P1799Output Speed Sensor 2 Circ. Rpm too High
P1813Pressure Contr.Solenoid 1 Electrical
P1814Pressure Contr.Solenoid 1 Open/Short to Ground
P1815Pressure Contr.Solenoid 1 Short to B+
P1818Pressure Contr.Solenoid 2 Electrical
P1819Pressure Contr.Solenoid 2 Open/Short to Ground
P1820Pressure Contr.Solenoid 2 Short to B+
P1823Pressure Contr.Solenoid 3 Electrical
P1824Pressure Contr.Solenoid 3 Open/Short to Ground
P1825Pressure Contr.Solenoid 3 Short to B+
P1828Pressure Contr.Solenoid 4 Electrical
P1829Pressure Contr.Solenoid 4 Open/Short to Ground
P1830Pressure Contr.Solenoid 4 Short to B+
P1834Pressure Contr.Solenoid 5 Open/Short to Ground
P1835Pressure Contr.Solenoid 5 Short to B+
P1841Engine/Transmission Control Modules Versions do not match
P1842Please check DTC Memory of instrument panel ECU
P1843Please check DTC Memory of ADR Control Module
P1844Please check DTC Memory of central electric control ECU
P1847Please check DTC Memory of brake system ECU
P1848Please check DTC Memory of engine ECU
P1849Please check DTC Memory of transmission ECU
P1850Data-Bus Powertrain Missing Message from Engine Contr.
P1851Data-Bus Powertrain Missing Message from Brake Contr.
P1852Data-Bus Powertrain Unplausible Message from Engine Contr.
P1853Data-Bus Powertrain Unplausible Message from Brake Contr.
P1854Data-Bus Powertrain Hardware Defective
P1855Data-Bus Powertrain Software version Contr.
P1856Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr.
P1857Load Signal Error Message from Engine Contr.
P1858Engine Speed Input Circ. Error Message from Engine Contr.
P1859Brake Switch Circ. Error Message from Engine Contr.
P1860Kick Down Switch Error Message from Engine Contr.
P1861Throttle Position (TP) sensor Error Message from ECM
P1862Data Bus Powertrain Missing message from instr. panel ECU
P1863Data Bus Powertrain Missing Message from St. Angle Sensor
P1864Data Bus Powertrain Missing message from ADR control module
P1865Data Bus Powertrain Missing message from central electronics
P1866Data Bus Powertrain Missing messages
P0001Fuel Volume Regulator Control Circuit Open
P0002Fuel Volume Regulator Control CKT Range/Perf
P0003Fuel Volume Regulator Control Circuit Low
P0004Fuel Volume Regulator Control Circuit High
P0005Fuel Shutoff Vlv. A Control Circuit Open
P0006Fuel Shutoff Vlv. A Control Circuit Low
P0007Fuel Shutoff Vlv. A Control Circuit High
P0008Engine Position System Performance (Bank 1)
P0009Engine Position System Performance (Bank 2)
P0010Camshaft Position Actuator A - Bank 1 Circuit Malfunction
P0011Camshaft Position Actuator A -Bank 1 Timing Over-Advan.
P0012Camshaft Position Actuator A - Bank 1 Timing Over-Retard
P0013Camshaft Position Actuator B - Bank 1 Circuit Malfunction
P0014Camshaft Position Actuator B - Bank 1 Timing Over-Advan.
P0015Camshaft Position Actuator B - Bank 1 Timing Over-Retard
P0016Cam/Crankshaft Pos. Correlation Sensor A - Bank 1
P0017Cam/Crankshaft Pos. Correlation Sensor B - Bank 1
P0018Cam/Crankshaft Pos. Correlation Sensor A - Bank 2
P0019Cam/Crankshaft Pos. Correlation Sensor B - Bank 2
P0020Camshaft Position Actuator A - Bank 2 Circuit Malfunction
P0021Camshaft Position Actuator A - Bank 2 Timing Over-Advan.
P0022Camshaft Position Actuator A - Bank 2 Timing Over-Retard
P0023Camshaft Position Actuator B - Bank 2 Circuit Malfunction
P0024Camshaft Position Actuator B - Bank 2 Timing Over-Advan.
P0025Camshaft Position Actuator B - Bank 2 Timing Over-Retard
P0026Intake Valve-Bank 1 Control Solenoid CKT Range/Perf
P0027Exhaust Valve-Bank1 Control Solenoid CKT Range/Perf
P0028Intake Valve-Bank 2 Control Solenoid CKT Range/Perf
P0029Exhaust Valve-Bank2 Control Solenoid CKT Range/Perf
P0030HO2S Bank 1 Sen 1 Heater Circuit
P0031HO2S Bank 1 Sen 1 Heater Circuit Low
P0032HO2S Bank 1 Sen 1 Heater Circuit High
P0033Turbo/Sup Wastegate Control Circuit
P0034Turbo/Sup Wastegate Control Circuit Low
P0035Turbo/Sup Wastegate Control Circuit High
P0036HO2S Bank 1 Sen 2 Heater Circuit
P0037HO2S Bank 1 Sen 2 Heater Circuit Low
P0038HO2S Bank 1 Sen 2 Heater Circuit High
P0039Turbo/Super Charger Bypass Cntrl CKT Performance
P0040O2 Bank 1 Sensor 1 Signals Swapped w/ O2 Bank 2 Sensor 1
P0041O2 Bank 1 Sensor 2 Signals Swapped w/ O2 Bank 2 Sensor 2
P0042HO2S Bank 1 Sen 3 Heater Circuit
P0043HO2S Bank 1 Sen 3 Heater Circuit Low
P0044HO2S Bank 1 Sen 3 Heater Circuit High
P0045Turbo/Super Charger Boost Control Solenoid A Circuit Open
P0046Turbo/Super Charger Boost Control Solenoid A Circuit Range/ Perform ance
P0047Turbo/Super Charger Boost Control Solenoid A Circuit Low
P0048Turbo/Super Charger Boost Control Solenoid A Circuit High
P0049Turbo/Super Charger Boost Input/Turbine Speed Overspeed
P0050HO2S Bank 2 Sen 1 Heater Circuit
P0051HO2S Bank 2 Sen 1 Heater Circuit Low
P0052HO2S Bank 2 Sen 1 Heater Circuit High
P0053HO2S Bank 1 Sen 1 Heater Resistance
P0054HO2S Bank 1 Sen 2 Heater Resistance
P0055HO2S Bank 1 Sen 3 Heater Resistance
P0056HO2S Bank 2 Sen 2 Heater Circuit
P0057HO2S Bank 2 Sen 2 Heater Circuit Low
P0058HO2S Bank 2 Sen 2 Heater Circuit High
P0059HO2S Bank 2 Sen 1 Heater Resistance
P0060HO2S Bank 2 Sen 2 Heater Resistance
P0061HO2S Bank 2 Sen 3 Heater Resistance
P0062HO2S Bank 2 Sen 3 Heater Circuit
P0063HO2S Bank 2 Sen 3 Heater Circuit Low
P0064HO2S Bank 2 Sen 3 Heater Circuit High
P0065Air Assisted Injec. Control Range/Performance
P0066Air Assisted Injec. Control Circuit Low
P0067Air Assisted Injec. Control Circuit High
P0068MAF/MAP Sensor Throttle Position Correlation
P0069MAP/BARO Correlation
P0070Ambient Air Temp. Sensor Circuit
P0071Ambient Air Temp. Sensor Range/Performance
P0072Ambient Air Temp. Sensor Circuit Low
P0073Ambient Air Temp. Sensor Circuit High
P0074Ambient Air Temp. Sensor CKT Intermittent
P0075Intake Valve-Bank 1 Control Circuit
P0076Intake Valve-Bank 1 Control Circuit Low
P0077Intake Valve-Bank 1 Control Circuit High
P0078Exhaust Valve-Bank1 Control Circuit
P0079Exhaust Valve-Bank1 Control Circuit Low
P0080Exhaust Valve-Bank1 Control Circuit High
P0081Intake Valve-Bank 2 Control Circuit
P0082Intake Valve-Bank 2 Control Circuit Low
P0083Intake Valve-Bank 2 Control Circuit High
P0084Exhaust Valve-Bank2 Control Circuit
P0085Exhaust Valve-Bank2 Control Circuit Low
P0086Exhaust Valve-Bank2 Control Circuit High
P0087Fuel Rail Pressure Too Low
P0088Fuel Rail Pressure Too High
P0089Fuel Pressure Reg 1 Performance
P0090Fuel Pressure Reg 1 Control Circuit
P0091Fuel Pressure Reg 1 Control Circuit Low
P0092Fuel Pressure Reg 1 Control Circuit High
P0093Fuel System Leak (Large)
P0094Fuel System Leak (Small)
P0095IAT Sensor 2 Circuit
P0096IAT Sensor 2 CKT Range/Perf
P0097IAT Sensor 2 Circuit Low
P0098IAT Sensor 2 Circuit High
P0099IAT Sensor 2 CKT Intermittent
P0100MAF or VAF A Circuit Malfunction
P0101MAF or VAF A Circuit Range/Perf
P0102MAF or VAF A Circuit Low Input
P0103MAF or VAF A Circuit High Input
P0104MAF or VAF A Circuit Intermittent
P0105MAP/BARO Circuit Malfunction
P0106MAP/BARO CKT Range/Perf
P0107MAP/BARO Circuit Low Input
P0108MAP/BARO Circuit High Input
P0109MAP/BARO CKT Intermittent
P0110IAT Sensor Circuit Malfunction
P0111IAT Sensor 1 CKT Range/Perf
P0112IAT Sensor 1 Circuit Low Input
P0113IAT Sensor 1 Circuit High Input
P0114IAT Sensor 1 CKT Intermittent
P0115Engine Coolant Temp Circuit Malfunction
P0116Engine Coolant Temp CKT Range/Perf
P0117Engine Coolant Temp Circuit Low Input
P0118Engine Coolant Temp Circuit High Input
P0119Engine Coolant Temp CKT Intermittent
P0120TPS/Pedal Position Sensor A Circuit Malfunction
P0121TPS/Pedal Position Sensor A CKT Range/Perf
P0122TPS/Pedal Position Sensor A Circuit Low Input
P0123TPS/Pedal Position Sensor A Circuit High Input
P0124TPS/Pedal Position Sensor A CKT Intermittent
P0125Clsd Loop Fuel Ctrl Insufficient Coolant Temp
P0126Coolant Temp Insufficient Stable Operation
P0127IAT Sensor Too High
P0128Coolant Temp Below Thermostat Regulating Temp
P0129Barometric Pressure Too Low
P0130O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131O2 Sensor Circuit Low Volts (Bank 1 Sensor 1)
P0132O2 Sensor Circuit High Volts (Bank 1 Sensor 1)
P0133O2 Sensor CKT Slow Response (Bank 1 Sensor 1)
P0134O2 Sensor CKT No Activity (Bank 1 Sensor 1)
P0135O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137O2 Sensor Circuit Low Volts (Bank 1 Sensor 2)
P0138O2 Sensor Circuit High Volts (Bank 1 Sensor 2)
P0139O2 Sensor CKT Slow Response (Bank 1 Sensor 2)
P0140O2 Sensor CKT No Activity (Bank 1 Sensor 2)
P0141O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143O2 Sensor Circuit Low Volts (Bank 1 Sensor 3)
P0144O2 Sensor Circuit High Volts (Bank 1 Sensor 3)
P0145O2 Sensor CKT Slow Response (Bank 1 Sensor 3)
P0146O2 Sensor CKT No Activity (Bank 1 Sensor 3)
P0147O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0148Fuel Delivery Malfunction
P0149Fuel Timing Malfunction
P0150O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151O2 Sensor Circuit Low Volts (Bank 2 Sensor 1)
P0152O2 Sensor Circuit High Volts (Bank 2 Sensor 1)
P0153O2 Sensor CKT Slow Response (Bank 2 Sensor 1)
P0154O2 Sensor CKT No Activity (Bank 2 Sensor 1)
P0155O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157O2 Sensor Circuit Low Volts (Bank 2 Sensor 2)
P0158O2 Sensor Circuit High Volts (Bank 2 Sensor 2)
P0159O2 Sensor CKT Slow Response (Bank 2 Sensor 2)
P0160O2 Sensor CKT No Activity (Bank 2 Sensor 2)
P0161O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163O2 Sensor Circuit Low Volts (Bank 2 Sensor 3)
P0164O2 Sensor Circuit High Volts (Bank 2 Sensor 3)
P0165O2 Sensor CKT Slow Response (Bank 2 Sensor 3)
P0166O2 Sensor CKT No Activity (Bank 2 Sensor 3)
P0167O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0168Engine Fuel Temperature Too High
P0169Fuel Composition Incorrect
P0170Fuel Trim Malfunction (Bank 1)
P0171System Too Lean (Bank 1)
P0172System Too Rich (Bank 1)
P0173Fuel Trim Malfunction (Bank 2)
P0174System Too Lean (Bank 2)
P0175System Too Rich (Bank 2)
P0176Fuel Compensation Sensor Circuit Malfunction
P0177Fuel Compensation Sensor CKT Range/Perf
P0178Fuel Compensation Sensor Circuit Low Input
P0179Fuel Compensation Sensor Circuit High Input
P0180Fuel Temperature Sensor A Circuit Malfunction
P0181Fuel Temperature Sensor A CKT Range/Perf
P0182Fuel Temperature Sensor A Circuit Low Input
P0183Fuel Temperature Sensor A Circuit High Input
P0184Fuel Temperature Sensor A CKT Intermittent
P0185Fuel Temperature Sensor B Circuit Malfunction
P0186Fuel Temperature Sensor B CKT Range/Perf
P0187Fuel Temperature Sensor B Circuit Low Input
P0188Fuel Temperature Sensor B Circuit High Input
P0189Fuel Temperature Sensor B CKT Intermittent
P0190Fuel Rail Pressure Sensor Circuit Malfunction
P0191Fuel Rail Pressure Sensor CKT Range/Perf
P0192Fuel Rail Pressure Sensor Circuit Low Input
P0193Fuel Rail Pressure Sensor Circuit High Input
P0194Fuel Rail Pressure Sensor CKT Intermittent
P0195Engine Oil Temp Sensor Circuit Malfunction
P0196Engine Oil Temp Sensor CKT Range/Perf
P0197Engine Oil Temp Sensor Circuit Low Input
P0198Engine Oil Temp Sensor Circuit High Input
P0199Engine Oil Temp Sensor CKT Intermittent
P0200Injector Circuit Open
P0201Injector Circuit Open Cylinder 1
P0202Injector Circuit Open Cylinder 2
P0203Injector Circuit Open Cylinder 3
P0204Injector Circuit Open Cylinder 4
P0205Injector Circuit Open Cylinder 5
P0206Injector Circuit Open Cylinder 6
P0207Injector Circuit Open Cylinder 7
P0208Injector Circuit Open Cylinder 8
P0209Injector Circuit Open Cylinder 9
P0210Injector Circuit Open Cylinder 10
P0211Injector Circuit Open Cylinder 11
P0212Injector Circuit Open Cylinder 12
P0213Cold Start Injector 1 Malfunction
P0214Cold Start Injector 2 Malfunction
P0215Engine Shutoff Solenoid Malfunction
P0216Injection Timing Control Circuit Malfunction
P0217Engine Overtemp Condition
P0218Trans Overtemp Condition
P0219Engine Overspeed Condition
P0220TPS/Pedal Position Sensor/Switch B Circuit Malfunction
P0221TPS/Pedal Position Sensor/Switch B CKT Range/Perf
P0222TPS/Pedal Position Sensor/Switch B Circuit Low Input
P0223TPS/Pedal Position Sensor/Switch B Circuit High Input
P0224TPS/Pedal Position Sensor/Switch B CKT Intermittent
P0225TPS/Pedal Position Sensor/Switch C Circuit Malfunction
P0226TPS/Pedal Position Sensor/Switch C CKT Range/Perf
P0227TPS/Pedal Position Sensor/Switch C Circuit Low Input
P0228TPS/Pedal Position Sensor/Switch C Circuit High Input
P0229TPS/Pedal Position Sensor/Switch C CKT Intermittent
P0230Fuel Pump Primary Circuit Malfunction
P0231Fuel Pump Secondary Circuit Low
P0232Fuel Pump Secondary Circuit High
P0233Fuel Pump Secondary Circuit Intermittent Ckt
P0234Engine Overboost Condition
P0235Turbo/Super Boost Sensor A Circuit Malfunction
P0236Turbo/Super Boost Sensor A CKT Range/Perf
P0237Turbo/Super Boost Sensor A Circuit Low Input
P0238Turbo/Super Boost Sensor A Circuit High Input
P0239Turbo/Super Boost Sensor B Circuit Malfunction
P0240Turbo/Super Boost Sensor B CKT Range/Perf
P0241Turbo/Super Boost Sensor B Circuit Low Input
P0242Turbo/Super Boost Sensor B Circuit High Input
P0243Turbo/Sup Wastegate Solenoid A Malfunction
P0244Turbo/Sup Wastegate Solenoid A Range/Performance
P0245Turbo/Sup Wastegate Solenoid A Low
P0246Turbo/Sup Wastegate Solenoid A High
P0247Turbo/Sup Wastegate Solenoid B Malfunction
P0248Turbo /Sup Wastegate Solenoid B Range/Performance
P0249Turbo/Sup Wastegate Solenoid B Low
P0250Turbo/Sup Wastegate Solenoid B High
P0251Injection Pump Metering Control A
P0252Injection Pump Metering Control A Range/Performance
P0253Injection Pump Metering Control A Low
P0254Injection Pump Metering Control A High
P0255Injection Pump Metering Control A Intermittent Ckt
P0256Injection Pump Metering Control B Malfunction
P0257Injection Pump Metering Control B Range/Performance
P0258Injection Pump Metering Control B Low
P0259Injection Pump Metering Control B High
P0260Injection Pump Metering Control B Intermittent Ckt
P0261Cylinder 1 Injector Control Circuit Low
P0262Cylinder 1 Injector Control Circuit High
P0263Cylinder 1 Contribution Balance Fault
P0264Cylinder 2 Injector Control Circuit Low
P0265Cylinder 2 Injector Control Circuit High
P0266Cylinder 2 Contribution Balance Fault
P0267Cylinder 3 Injector Control Circuit Low
P0268Cylinder 3 Injector Control Circuit High
P0269Cylinder 3 Contribution Balance Fault
P0270Cylinder 4 Injector Control Circuit Low
P0271Cylinder 4 Injector Control Circuit High
P0272Cylinder 4 Contribution Balance Fault
P0273Cylinder 5 Injector Control Circuit Low
P0274Cylinder 5 Injector Control Circuit High
P0275Cylinder 5 Contribution Balance Fault
P0276Cylinder 6 Injector Control Circuit Low
P0277Cylinder 6 Injector Control Circuit High
P0278Cylinder 6 Contribution Balance Fault
P0279Cylinder 7 Injector Control Circuit Low
P0280Cylinder 7 Injector Control Circuit High
P0281Cylinder 7 Contribution Balance Fault
P0282Cylinder 8 Injector Control Circuit Low
P0283Cylinder 8 Injector Control Circuit High
P0284Cylinder 8 Contribution Balance Fault
P0285Cylinder 9 Injector Control Circuit Low
P0286Cylinder 9 Injector Control Circuit High
P0287Cylinder 9 Contribution Balance Fault
P0288Cylinder 10 Injector Control Circuit Low
P0289Cylinder 10 Injector Control Circuit High
P0290Cylinder 10 Contribution Balance Fault
P0291Cylinder 11 Injector Control Circuit Low
P0292Cylinder 11 Injector Control Circuit High
P0293Cylinder 11 Contribution Balance Fault
P0294Cylinder 12 Injector Control Circuit Low
P0295Cylinder 12 Injector Control Circuit High
P0296Cylinder 12 Contribution Balance Fault
P0297Vehicle Overspeed Error
P0298Engine Oil Temperature Too High
P0299Turbo/Super Charger UnderBoost
P0300Random/Multiple Cylinder Misfire Detected
P0301Cylinder 1 Misfire Detected
P0302Cylinder 2 Misfire Detected
P0303Cylinder 3 Misfire Detected
P0304Cylinder 4 Misfire Detected
P0305Cylinder 5 Misfire Detected
P0306Cylinder 6 Misfire Detected
P0307Cylinder 7 Misfire Detected
P0308Cylinder 8 Misfire Detected
P0309Cylinder 9 Misfire Detected
P0310Cylinder 10 Misfire Detected
P0311Cylinder 11 Misfire Detected
P0312Cylinder 12 Misfire Detected
P0313Misfire Detected Low Fuel Level
P0314Misfire Detected Cyl. not Specific
P0315Crankshaft Position System Variation Not Learned
P0316Misfire Detected 1st 1000 Revs.
P0317Rough Road Hardware Not Present
P0318Rough Road Sensor A Signal Circuit
P0319Rough Road Sensor B
P0320Ignition/Dist Engine Speed Input Circuit Malfunction
P0321Ignition/Dist Engine Speed Input CKT Range/Perf
P0322Ignition/Dist Engine Speed Input Circuit No Signal
P0323Ignition/Dist Engine Speed Input CKT Intermittent
P0324Knock Control System Malfunction
P0325Knock Sensor 1 Circuit Malfunction Bank 1 or 1 Sensor
P0326Knock Sensor 1 CKT Range/Perf Bank 1 or 1 Sensor
P0327Knock Sensor 1 Circuit Low Input Bank 1 or 1 Sensor
P0328Knock Sensor 1 Circuit High Input Bank 1 or 1 Sensor
P0329Knock Sensor 1 CKT Intermittent Bank 1 or 1 Sensor
P0330Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331Knock Sensor 2 CKT Range/Perf (Bank 2)
P0332Knock Sensor 2 Circuit Low Input (Bank 2)
P0333Knock Sensor 2 Circuit High Input (Bank 2)
P0334Knock Sensor 2 CKT Intermittent (Bank 2)
P0335Crankshaft Position Sensor A Circuit Malfunction
P0336Crankshaft Position Sensor A CKT Range/Perf
P0337Crankshaft Position Sensor A Circuit Low Input
P0338Crankshaft Position Sensor A Circuit High Input
P0339Crankshaft Position Sensor A CKT Intermittent
P0340Camshaft Position Sensor A - Bank 1 Circuit Malfunction
P0341Camshaft Position Sensor A - Bank 1 CKT Range/Perf
P0342Camshaft Position Sensor A - Bank 1 Circuit Low Input
P0343Camshaft Position Sensor A - Bank 1 Circuit High Input
P0344Camshaft Position Sensor A - Bank 1 CKT Intermittent
P0345Camshaft Position Sensor A - Bank 2 Circuit Malfunction
P0346Camshaft Position Sensor A - Bank 2 CKT Range/Perf
P0347Camshaft Position Sensor A - Bank 2 Circuit Low Input
P0348Camshaft Position Sensor A - Bank 2 Circuit High Input
P0349Camshaft Position Sensor A - Bank 2 CKT Intermittent
P0350Ignition Coil Primary/Secondary Circuit Malfunction
P0351Ignition Coil A Primary/Secondary Circuit Malfunction
P0352Ignition Coil B Primary/Secondary Circuit Malfunction
P0353Ignition Coil C Primary/Secondary Circuit Malfunction
P0354Ignition Coil D Primary/Secondary Circuit Malfunction
P0355Ignition Coil E Primary/Secondary Circuit Malfunction
P0356Ignition Coil F Primary/Secondary Circuit Malfunction
P0357Ignition Coil G Primary/Secondary Circuit Malfunction
P0358Ignition Coil H Primary/Secondary Circuit Malfunction
P0359Ignition Coil I Primary/Secondary Circuit Malfunction
P0360Ignition Coil J Primary/Secondary Circuit Malfunction
P0361Ignition Coil K Primary/Secondary Circuit Malfunction
P0362Ignition Coil L Primary/Secondary Circuit Malfunction
P0363Misfire Detected Fueling Disabled
P0365Camshaft Position Sensor B - Bank 1 Circuit Malfunction
P0366Camshaft Position Sensor B - Bank 1 CKT Range/Perf
P0367Camshaft Position Sensor B - Bank 1 Circuit Low Input
P0368Camshaft Position Sensor B - Bank 1 Circuit High Input
P0369Camshaft Position Sensor B - Bank 1 CKT Intermittent
P0370Timing Reference High Res Signal A Malfunction
P0371Timing Reference High Res Signal A Too Many Pulses
P0372Timing Reference High Res Signal A Too Few Pulses
P0373Timing Reference High Res Signal A Erratic Pulses
P0374Timing Reference High Res Signal A No Pulses
P0375Timing Reference High Res Signal B Malfunction
P0376Timing Reference High Res Signal B Too Many Pulses
P0377Timing Reference High Res Signal B Too Few Pulses
P0378Timing Reference High Res Signal B Erratic Pulses
P0379Timing Reference High Res Signal B No Pulses
P0380Glow Plug/Heater CKT A Malfunction
P0381Glow Plug/Heater Indicator Circuit Malfunction
P0382Glow Plug/Heater CKT B Malfunction
P0383Glow Plug Module Control Circuit Low
P0384Glow Plug Module Control Circuit High
P0385Crankshaft Position Sensor B Circuit Malfunction
P0386Crankshaft Position Sensor B CKT Range/Perf
P0387Crankshaft Position Sensor B Circuit Low Input
P0388Crankshaft Position Sensor B Circuit High Input
P0389Crankshaft Position Sensor B CKT Intermittent
P0390Camshaft Position Sensor B - Bank 2 Circuit Malfunction
P0391Camshaft Position Sensor B - Bank 2 CKT Range/Perf
P0392Camshaft Position Sensor B - Bank 2 Circuit Low Input
P0393Camshaft Position Sensor B - Bank 2 Circuit High Input
P0394Camshaft Position Sensor B - Bank 2 CKT Intermittent
P0400EGR Flow Malfunction
P0401EGR Flow Insufficient
P0402EGR Flow Excessive
P0403EGR Flow Circuit Malfunction
P0404EGR Flow CKT Range/Perf
P0405EGR Flow Sensor A Circuit Low Input
P0406EGR Flow Sensor A Circuit High Input
P0407EGR Flow Sensor B Circuit Low Input
P0408EGR Flow Sensor B Circuit High Input
P0409EGR Flow Sensor A Circuit
P0410Secondary Air Injection System Malfunction
P0411Secondary Air Injection System Incorrect Flow
P0412Secondary Air Injection System Valve A Malfunction
P0413Secondary Air Injection System Valve A CKT Open
P0414Secondary Air Injection System Valve A CKT Short
P0415Secondary Air Injection System Valve B Malfunction
P0416Secondary Air Injection System Valve B CKT Open
P0417Secondary Air Injection System Valve B CKT Short
P0418Secondary Air Injection System Relay A Malfunction
P0419Secondary Air Injection System Relay B Malfunction
P0420Catalyst Efficiency Below Threshold (Bank 1)
P0421Warm Up Catalyst Below Threshold (Bank 1)
P0422Main Catalyst Below Threshold (Bank 1)
P0423Heated Catalyst Below Threshold (Bank 1)
P0424Htd Catalyst Temp Below Threshold (Bank 1)
P0425Catalyst Temp. Sensor (Bank 1 Sensor 1)
P0426Catalyst Temp. Sensor Performance (Bank 1 Sensor 1)
P0427Catalyst Temp. Sensor Circuit Low (Bank 1 Sensor 1)
P0428Catalyst Temp. Sensor Circuit High (Bank 1 Sensor 1)
P0429Catalyst Heater Control (Bank 1)
P0430Catalyst Efficiency Below Threshold (Bank 2)
P0431Warm Up Catalyst Below Threshold (Bank 2)
P0432Main Catalyst Below Threshold (Bank 2)
P0433Heated Catalyst Below Threshold (Bank 2)
P0434Htd Catalyst Temp Below Threshold (Bank 2)
P0435Catalyst Temp. Sensor (Bank 2 Sensor 1)
P0436Catalyst Temp. Sensor Performance (Bank 2 Sensor 1)
P0437Catalyst Temp. Sensor Circuit Low (Bank 2 Sensor 1)
P0438Catalyst Temp. Sensor Circuit High (Bank 2 Sensor 1)
P0439Catalyst Heater Control (Bank 2)
P0440EVAP Emission Control System Malfunction
P0441EVAP Emission Control System Purge Flow Fault
P0442EVAP Emission Control System Leak (Small)
P0443EVAP Emission Control System Purge Valve C Fault
P0444EVAP Emission Control System Purge Valve C Open
P0445EVAP Emission Control System Purge Valve C Short
P0446EVAP Emission Control System Vent Circuit Malf
P0447EVAP Emission Control System Vent Circuit Open
P0448EVAP Emission Control System Vent Circuit Short
P0449EVAP Emission Control System Vent Vlv/Sol Malf
P0450EVAP Emission Control System Pres Sensor Fault
P0451EVAP Emission Control System Pres Sensor Range
P0452EVAP Emission Control System Pres Sensor Low
P0453EVAP Emission Control System Pres Sensor High
P0454EVAP Emission Control System Pres Sensor Erratic
P0455EVAP Emission Control System Leak (Large)
P0456EVAP Emission Control System Leak Very Small
P0457EVAP Emission Control System Leak Cap Loose/Off
P0458EVAP System Canister Purge Sol Circuit Low
P0459EVAP System Canister Purge Sol Circuit High
P0460Fuel Level Sensor A Circuit Malfunction
P0461Fuel Level Sensor A CKT Range/Perf
P0462Fuel Level Sensor A Circuit Low Input
P0463Fuel Level Sensor A Circuit High Input
P0464Fuel Level Sensor A CKT Intermittent
P0465EVAP Emission Purge Flow Sensor Circuit Malfunction
P0466EVAP Emission Purge Flow Sensor CKT Range/Perf
P0467EVAP Emission Purge Flow Sensor Circuit Low Input
P0468EVAP Emission Purge Flow Sensor Circuit High Input
P0469EVAP Emission Purge Flow Sensor CKT Intermittent
P0470Exhaust Pressure Sensor Circuit Malfunction
P0471Exhaust Pressure Sensor CKT Range/Perf
P0472Exhaust Pressure Sensor Circuit Low Input
P0473Exhaust Pressure Sensor Circuit High Input
P0474Exhaust Pressure Sensor CKT Intermittent
P0475Exhaust Pressure Control Valve Circuit Malfunction
P0476Exhaust Pressure Control Valve CKT Range/Perf
P0477Exhaust Pressure Control Valve Circuit Low Input
P0478Exhaust Pressure Control Valve Circuit High Input
P0479Exhaust Pressure Control Valve CKT Intermittent
P0480Cooling Fan 1 Control Circuit
P0481Cooling Fan 2 Control Circuit
P0482Cooling Fan 3 Control Circuit
P0483Control Fan Rationality Check Malfunction
P0484Control Fan CKT Over Current
P0485Control Fan Power/Ground Circuit Malfunction
P0486EGR System Sensor B Circuit
P0487EGR TPS Control Circuit
P0488EGR TPS Control CKT Range/Perf
P0489EGR Control Circuit Low
P0490EGR Control Circuit High
P0491Secondary Air System (Bank 1)
P0492Secondary Air System (Bank 2)
P0493Fan Speed Overspeed
P0494Fan Speed Low
P0495Fan Speed High
P0496EVAP Emission High Purge Flow Fault
P0497EVAP Emission Low Purge Flow Fault
P0498EVAP Emission Vent Vlv/Sol Malf Circuit Low
P0499EVAP Emission Vent Vlv/Sol Malf Circuit High
P0500Veh Speed Sensor A Malfunction
P0501Veh Speed Sensor A Range/Performance
P0502Veh Speed Sensor A Circuit Low Input
P0503Veh Speed Sensor A Erratic/High
P0504Brake Switch A Brake Switch B Correlation
P0505Idle Control System Malfunction
P0506Idle Control System RPM Low
P0507Idle Control System RPM High
P0508Idle Control System Circuit Low
P0509Idle Control System Circuit High
P0510Closed Throttle Position Switch
P0511Idle Air Control Circuit
P0512Starter Signal Circuit
P0513Immobilizer Incorrect
P0514Battery Temperature Sensor CKT Range/Perf
P0515Battery Temperature Sensor Circuit
P0516Battery Temperature Circuit Low
P0517Battery Temperature Circuit High
P0518Idle Air Control CKT Intermittent
P0519Idle Air Control System Performance
P0520Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521Engine Oil Pressure Sensor/Switch Range/Performance
P0522Engine Oil Pressure Sensor/Switch Low Voltage
P0523Engine Oil Pressure Sensor/Switch High Voltage
P0524Engine Oil Pressure Too Low
P0525Cruise Servo CKT Range/Perf
P0526Fan Speed Sensor Circuit
P0527Fan Speed Sensor CKT Range/Perf
P0528Fan Speed Sensor Circuit No Signal
P0529Fan Speed Sensor CKT Intermittent
P0530A/C Refrigerant Pressure Sensor A Circuit Malfunction
P0531A/C Refrigerant Pressure Sensor A CKT Range/Perf
P0532A/C Refrigerant Pressure Sensor A Circuit Low Input
P0533A/C Refrigerant Pressure Sensor A Circuit High Input
P0534A/C Refrigerant Charge Loss
P0535A/C Evaporator Temperature Sensor Circuit
P0536A/C Evaporator Temperature Sensor CKT Range/Perf
P0537A/C Evaporator Temperature Sensor Circuit Low
P0538A/C Evaporator Temperature Sensor Circuit High
P0539A/C Evaporator Temperature Sensor CKT Intermittent
P0540Intake Air Heater A Circuit
P0541Intake Air Heater A Circuit Low
P0542Intake Air Heater A Circuit High
P0543Intake Air Heater A Circuit Open
P0544Exhaust Gas Temp. Sensor Circuit (Bank 1 Sensor 1)
P0545Exhaust Gas Temp. Sensor Circuit Low (Bank 1 Sensor 1)
P0546Exhaust Gas Temp. Sensor Circuit High (Bank 1 Sensor 1)
P0547Exhaust Gas Temp. Sensor Circuit (Bank 2 Sensor 1)
P0548Exhaust Gas Temp. Sensor Circuit Low (Bank 2 Sensor 1)
P0549Exhaust Gas Temp. Sensor Circuit High (Bank 2 Sensor 1)
P0550Power Steering Pres Sensor Circuit Malfunction
P0551Power Steering Pres Sensor CKT Range/Perf
P0552Power Steering Pres Sensor Circuit Low Input
P0553Power Steering Pres Sensor Circuit High Input
P0554Power Steering Pres Sensor CKT Intermittent
P0555Brake Booster Pressure Sensor Circuit
P0556Brake Booster Pressure Sensor CKT Range/Perf
P0557Brake Booster Pressure Sensor Circuit Low Input
P0558Brake Booster Pressure Sensor Circuit High Input
P0559Brake Booster Pressure Sensor CKT Intermittent
P0560System Voltage Malfunction
P0561System Voltage Unstable
P0562System Voltage Low
P0563System Voltage High
P0564Cruise Control Multi Func. Input A Signal Error
P0565Cruise Control On Signal Malfunction
P0566Cruise Control Off Signal Malfunction
P0567Cruise Control Resume Signal Malfunction
P0568Cruise Control Set Signal Malfunction
P0569Cruise Control Coast Signal Malfunction
P0570Cruise Control Acceleration Signal Error
P0571Brake Switch A Circuit Malfunction
P0572Brake Switch A Circuit Low Input
P0573Brake Switch A Circuit High Input
P0574Cruise Control Vehicle Speed Too High
P0575Cruise Control Circuit Malfunction
P0576Cruise Control Circuit Low Input
P0577Cruise Control Circuit High Input
P0578Cruise Control Multi-Func. Input A Circuit Stuck
P0579Cruise Control Multi-Func. Input A CKT Range/Perf
P0580Cruise Control Multi-Func. Input A Circuit Low
P0581Cruise Control Multi-Func. Input A Circuit High
P0582Cruise Control Vacuum Control Circuit Open
P0583Cruise Control Vacuum Control Circuit Low
P0584Cruise Control Vacuum Control Circuit High
P0585Cruise Control Multi-Func. Input Correlation
P0586Cruise Control Vent Control Circuit Open
P0587Cruise Control Vent Control Circuit Low
P0588Cruise Control Vent Control Circuit High
P0589Cruise Control Multi-Func. Input B Circuit
P0590Cruise Control Multi-Func. Input B Circuit Stuck
P0591Cruise Control Multi-Func. Input B CKT Range/Perf
P0592Cruise Control Multi-Func. Input B Circuit Low
P0593Cruise Control Multi-Func. Input B Circuit High
P0594Cruise Control Servo Control Circuit Open
P0595Cruise Control Servo Control Circuit Low
P0596Cruise Control Servo Control Circuit High
P0597Cruise Control Control Circuit Open
P0598Cruise Control Control Circuit Low
P0599Cruise Control Control Circuit High
P0600Serial Comm Link Malfunction
P0601Int Control Module Memory Check Sum Error
P0602Control Module Programming Error
P0603PCM Keep Alive Memory (KAM) Error
P0604PCM Random Access Mem (RAM) Error
P0605PCM Read Only Memory (ROM) Error
P0606PCM Processor Fault
P0607Control Module Performance
P0608Control Module VSS Output A Malfunction
P0609Control Module VSS Output B Malfunction
P0610Control Module Vehicle Options Malfunction
P0611Injector Control Module Performance
P0612Injector Control Module Relay Control
P0613TCM Processor Fault
P0614ECM/TCM Incompatible
P0615Starter Relay Circuit
P0616Starter Relay Circuit Low
P0617Starter Relay Circuit High
P0618Alternative Fuel Module (KAM) Error
P0619Alternative Fuel Module Memory
P0620Generator Control Malfunction
P0621Generator L-Term. Lamp Control
P0622Generator F-Term. Field F Control
P0623Generator Lamp Control Circuit
P0624Fuel Cap Lamp Circuit
P0625Generator F-Term. Circuit Low
P0626Generator F-Term. Circuit High
P0627Fuel Pump A Control Circuit Open
P0628Fuel Pump A Control Circuit Low
P0629Fuel Pump A Control Circuit High
P0630PCM VIN Not Program. Or Missmatch
P0631TCM VIN Not Program. Or Missmatch
P0632Odometer Code Not Programmed ECM/PCM
P0633Immobilizer Code Not Programmed ECM/PCM
P0634PCM/ECM/TCM Internal Temp. Too High
P0635Power Steering Control Circuit
P0636Power Steering Control Circuit Low
P0637Power Steering Control Circuit High
P0638Throttle Actuator Range/Performance (Bank 1)
P0639Throttle Actuator Range/Performance (Bank 2)
P0640Intake Air Heater Control Circuit
P0641Sensor A Reference Voltage Circuit Open
P0642Sensor A Reference Voltage Circuit Low
P0643Sensor A Reference Voltage Circuit High
P0644Driver Display Serial Comm Link
P0645A/C Clutch Relay Control Circuit
P0646A/C Clutch Relay Control Circuit Low
P0647A/C Clutch Relay Control Circuit High
P0648Immobilizer Lamp Circuit
P0649Cruise Control Lamp Circuit
P0650MIL Control Circuit Malfunction
P0651Sensor B Reference Voltage Circuit Open
P0652Sensor B Reference Voltage Circuit Low
P0653Sensor B Reference Voltage Circuit High
P0654Engine RPM Circuit Malfunction
P0655Engine Hot Lamp Output Circuit Malfunction
P0656Fuel Level Output Circuit Malfunction
P0657Actuator Supply Voltage A Circuit Open
P0658Actuator Supply Voltage A Circuit Low
P0659Actuator Supply Voltage A Circuit High
P0660Intake Man Tuning Control CKT Open (Bank 1)
P0661Intake Man Tuning Control CKT Low (Bank 1)
P0662Intake Man Tuning Control CKT High (Bank 1)
P0663Intake Man Tuning Control CKT Open (Bank 2)
P0664Intake Man Tuning Control CKT Low (Bank 2)
P0665Intake Man Tuning Control CKT High (Bank 2)
P0666PCM/ECM/TCM Internal Temp. Sensor Circuit
P0667PCM/ECM/TCM Internal Temp. Sensor Range/Perf.
P0668PCM/ECM/TCM Internal Temp. Sensor Circuit Low
P0669PCM/ECM/TCM Internal Temp. Sensor Circuit High
P0670Glow Plug/Heater Module Control
P0671Glow Plug/Heater Cylinder 1
P0672Glow Plug/Heater Cylinder 2
P0673Glow Plug/Heater Cylinder 3
P0674Glow Plug/Heater Cylinder 4
P0675Glow Plug/Heater Cylinder 5
P0676Glow Plug/Heater Cylinder 6
P0677Glow Plug/Heater Cylinder 7
P0678Glow Plug/Heater Cylinder 8
P0679Glow Plug/Heater Cylinder 9
P0680Glow Plug/Heater Cylinder 10
P0681Glow Plug/Heater Cylinder 11
P0682Glow Plug/Heater Cylinder 12
P0683Glow Plug/Heater Module Comm Problem
P0684Glow Plug/Heater Comm Problem CKT Range/Perf
P0685ECM/PCM Power Relay Control Circuit Open
P0686ECM/PCM Power Relay Control Circuit Low
P0687ECM/PCM Power Relay Control Circuit High
P0688ECM/PCM Power Relay Sense Circuit Open
P0689ECM/PCM Power Relay Sense Circuit Low
P0690ECM/PCM Power Relay Sense Circuit High
P0691Fan 1 Control Circuit Low
P0692Fan 1 Control Circuit High
P0693Fan 2 Control Circuit Low
P0694Fan 2 Control Circuit High
P0695Fan 3 Control Circuit Low
P0696Fan 3 Control Circuit High
P0697Sensor C Reference Voltage Circuit Open
P0698Sensor C Reference Voltage Circuit Low
P0699Sensor C Reference Voltage Circuit High
P0700Trans Control Sys Malfunction
P0701Trans Control Sys Range/Performance
P0702Trans Control Sys Electrical
P0703Brake Switch B Circuit Malfunction
P0704Clutch Switch Input Circuit Malfunction
P0705Trans Range Sensor Circuit Malfunction (PRNDL Input)
P0706Trans Range Sensor CKT Range/Perf
P0707Trans Range Sensor Circuit Low Input
P0708Trans Range Sensor Circuit High Input
P0709Trans Range Sensor CKT Intermittent
P0710Transmission Fluid Temperature Sensor Circuit Malfunction
P0711Trans Fluid Temp Sensor A CKT Range/Perf
P0712Trans Fluid Temp Sensor A Circuit Low Input
P0713Trans Fluid Temp Sensor A Circuit High Input
P0714Trans Fluid Temp Sensor A CKT Intermittent
P0715Input/Turbine Speed Sensor A Circuit Malfunction
P0716Input/Turbine Speed Sensor A CKT Range/Perf
P0717Input/Turbine Speed Sensor A Circuit No Signal
P0718Input/Turbine Speed Sensor A CKT Intermittent
P0719Brake Switch B Circuit Low Input
P0720Output Speed Sensor Circuit Malfunction
P0721Output Speed Sensor Circuit Range/Perf
P0722Output Speed Sensor Circuit No Signal
P0723Output Speed Sensor CKT Intermittent
P0724Brake Switch B Circuit High Input
P0725Engine Speed Sensor Circuit Malfunction
P0726Engine Speed Sensor CKT Range/Perf
P0727Engine Speed Sensor Circuit No Signal
P0728Engine Speed Sensor CKT Intermittent
P0729Gear 6 Ratio Incorrect
P0730Gear Ratio Incorrect
P0731Gear 1 Ratio Incorrect
P0732Gear 2 Ratio Incorrect
P0733Gear 3 Ratio Incorrect
P0734Gear 4 Ratio Incorrect
P0735Gear 5 Ratio Incorrect
P0736Reverse Ratio Incorrect
P0737TCM Engine Speed Output Circuit
P0738TCM Engine Speed Output Circuit Low
P0739TCM Engine Speed Output Circuit High
P0740TCC Circuit Malfunction
P0741Torque Converter CKT Performance Or Stuck Off
P0742Torque Converter Circuit Stuck On
P0743Torque Converter Circuit Electrical
P0744Torque Converter CKT Intermittent
P0745Pres Cntrl Sol. A Circuit Malfunction
P0746Pres Cntrl Sol. A CKT Performance Or Stuck Off
P0747Pres Cntrl Sol. A Circuit Stuck On
P0748Pres Cntrl Sol. A Circuit Electrical
P0749Pres Cntrl Sol. A CKT Intermittent
P0750Shift Solenoid A Malfunction
P0751Shift Solenoid A CKT Performance Or Stuck Off
P0752Shift Solenoid A Circuit Stuck On
P0753Shift Solenoid A Circuit Electrical
P0754Shift Solenoid A CKT Intermittent
P0755Shift Solenoid B Malfunction
P0756Shift Solenoid B CKT Performance Or Stuck Off
P0757Shift Solenoid B Circuit Stuck On
P0758Shift Solenoid B Circuit Electrical
P0759Shift Solenoid B CKT Intermittent
P0760Shift Solenoid C Malfunction
P0761Shift Solenoid C CKT Performance Or Stuck Off
P0762Shift Solenoid C Circuit Stuck On
P0763Shift Solenoid C Circuit Electrical
P0764Shift Solenoid C CKT Intermittent
P0765Shift Solenoid D Malfunction
P0766Shift Solenoid D CKT Performance Or Stuck Off
P0767Shift Solenoid D Circuit Stuck On
P0768Shift Solenoid D Circuit Electrical
P0769Shift Solenoid D CKT Intermittent
P0770Shift Solenoid E Malfunction
P0771Shift Solenoid E CKT Performance Or Stuck Off
P0772Shift Solenoid E Circuit Stuck On
P0773Shift Solenoid E Circuit Electrical
P0774Shift Solenoid E CKT Intermittent
P0775Pres Ctrl Sol. B Circuit Malfunction
P0776Pres Ctrl Sol. B CKT Performance Or Stuck Off
P0777Pres Ctrl Sol. B Circuit Stuck On
P0778Pres Ctrl Sol. B Circuit Electrical
P0779Pres Ctrl Sol. B CKT Intermittent
P0780Shift Malfunction
P07811-2 Shift Malfunction
P07822-3 Shift Malfunction
P07833-4 Shift Malfunction
P07844-5 Shift Malfunction
P0785Shift/Timing Solenoid Malfunction
P0786Shift/Timing Solenoid Range/Performance
P0787Shift/Timing Solenoid Low
P0788Shift/Timing Solenoid High
P0789Shift/Timing Solenoid Intermittent Ckt
P0790Normal/Performance Switch Circuit Malfunction
P0791Intermediate Shaft Speed Sensor A Circuit
P0792Intermediate Shaft Speed Sensor A Circuit Range/Perf
P0793Intermediate Shaft Speed Sensor A Circuit No Signal
P0794Intermediate Shaft Speed Sensor A CKT Intermittent
P0795Pres Ctrl Sol. C Malfunction
P0796Pres Ctrl Sol. C CKT Performance Or Stuck Off
P0797Pres Ctrl Sol. C Circuit Stuck On
P0798Pres Ctrl Sol. C Circuit Electrical
P0799Pres Ctrl Sol. C CKT Intermittent
P0800Transfer Case Control System MIL Request
P0801Reverse Inhibit Control Circuit Malfunction
P0802Trans Control Sys MIL Request Circuit Open
P08031-4 Upshift Solenoid Circuit Malfunction
P08041-4 Upshift Lamp Circuit Malfunction
P0805Clutch Position Sensor Circuit Malfunction
P0806Clutch Position Sensor Circuit Range/Performance
P0807Clutch Position Sensor Circuit Low
P0808Clutch Position Sensor Circuit High
P0809Clutch Position Sensor Circuit Intermittent Ckt
P0810Clutch Position Control Malfunction
P0811Clutch Slippage Excessive
P0812Reverse Input Circuit Malfunction
P0813Reverse Output Circuit Malfunction
P0814Trans Range Display Circuit Malfunction
P0815Upshift Switch Circuit Malfunction
P0816Downshift Switch Circuit Malfunction
P0817Starter Disable Circuit
P0818Driveline Disconn. Switch Input
P0819Up/Down Shift SW Transmission Range Correlation
P0820Gear Lever X-Y Sensor Circuit
P0821Gear Lever X Sensor Circuit
P0822Gear Lever Y Sensor Circuit
P0823Gear Lever X Sensor Circuit Intermittent Ckt
P0824Gear Lever Y Sensor Circuit Intermittent Ckt
P0825Gear Lever Push/Pull Switch (Shift Anticipate)
P0826Upshift Switch Downshift Switch Circuit
P0827Upshift Switch Downshift Switch Circuit Low
P0828Upshift Switch Downshift Switch Circuit High
P08295-6 Shift
P0830Clutch Position Switch A Circuit Malfunction
P0831Clutch Position Switch A Circuit Low
P0832Clutch Position Switch A Circuit Highb
P0833Clutch Position Switch B Circuit Malfunction
P0834Clutch Position Switch B Circuit Low
P0835Clutch Position Switch B Circuit High
P08364 Wheel Drive Switch Circuit Malfunction
P08374 Wheel Drive Switch CKT Range/Perf
P08384 Wheel Drive Switch Circuit Low
P08394 Wheel Drive Switch Circuit High
P0840Trans Fluid Press Sensor/Switch A Circuit Malfunction
P0841Trans Fluid Press Sensor/Switch A CKT Range/Perf
P0842Trans Fluid Press Sensor/Switch A Circuit Low
P0843Trans Fluid Press Sensor/Switch A Circuit High
P0844Trans Fluid Press Sensor/Switch A CKT Intermittent
P0845Trans Fluid Press Sensor/Switch B Circuit Malfunction
P0846Trans Fluid Press Sensor/Switch B CKT Range/Perf
P0847Trans Fluid Press Sensor/Switch B Circuit Low
P0848Trans Fluid Press Sensor/Switch B Circuit High
P0849Trans Fluid Press Sensor/Switch B CKT Intermittent
P0850Park/Neutral Switch Input Circuit
P0851Park/Neutral Switch Circuit Low Input
P0852Park/Neutral Switch Circuit High Input
P0853Drive Switch Input Circuit
P0854Drive Switch Circuit Low Input
P0855Drive Switch Circuit High Input
P0856Traction Control Input Signal
P0857Traction Control Input Signal Range/Performance
P0858Traction Control Input Signal Low
P0859Traction Control Input Signal High
P0860Gear Shift Module Communications Circuit
P0861Gear Shift Module Communications Circuit Low
P0862Gear Shift Module Communications Circuit High
P0863TCM Communications Circuit
P0864TCM Communications CKT Range/Perf
P0865TCM Communications Circuit Low
P0866TCM Communications Circuit High
P0867Trans Fluid Press
P0868Trans Fluid Press Low
P0869Trans Fluid Press High
P0870Trans Fluid Press Sensor/Switch C Circuit
P0871Trans Fluid Press Sensor/Switch C CKT Range/Perf
P0872Trans Fluid Press Sensor/Switch C Circuit Low
P0873Trans Fluid Press Sensor/Switch C Circuit High
P0874Trans Fluid Press Sensor/Switch C CKT Intermittent
P0875Trans Fluid Press Sensor/Switch D Circuit
P0876Trans Fluid Press Sensor/Switch D CKT Range/Perf
P0877Trans Fluid Press Sensor/Switch D Circuit Low
P0878Trans Fluid Press Sensor/Switch D Circuit High
P0879Trans Fluid Press Sensor/Switch D CKT Intermittent
P0880TCM Power Input Signal
P0881TCM Power Input Signal Range/Performance
P0882TCM Power Input Signal Low
P0883TCM Power Input Signal High
P0884TCM Power Input Signal CKT Intermittent
P0885TCM Power Relay Control Circuit Open
P0886TCM Power Relay Control Circuit Low
P0887TCM Power Relay Control Circuit High
P0888TCM Power Relay Sense Circuit
P0889TCM Power Relay Sense CKT Range/Perf
P0890TCM Power Relay Sense Circuit Low
P0891TCM Power Relay Sense Circuit High
P0892TCM Power Relay Sense CKT Intermittent
P0893Multiple Gears Engaged
P0894Transmission Comp. Slipping
P0895Shift Time Too Short
P0896Shift Time Too Long
P0897Transmission Fluid Deteriorated
P0898Transmission Ctrl. MIL Request Circuit Low
P0899Transmission Ctrl. MIL Request Circuit High
P0900Clutch Actuator Circuit Open
P0901Clutch Actuator CKT Range/Perf
P0902Clutch Actuator Circuit Low
P0903Clutch Actuator Circuit High
P0904Gate Select Position Circuit
P0905Gate Select Position CKT Range/Perf
P0906Gate Select Position Circuit Low
P0907Gate Select Position Circuit High
P0908Gate Select Position CKT Intermittent
P0909Gate Select Control Error
P0910Gate Select Actuator Circuit Open
P0911Gate Select Actuator CKT Range/Perf
P0912Gate Select Actuator Circuit Low
P0913Gate Select Actuator Circuit High
P0914Gear Shift Position Circuit
P0915Gear Shift Position CKT Range/Perf
P0916Gear Shift Position Circuit Low
P0917Gear Shift Position Circuit High
P0918Gear Shift Position CKT Intermittent
P0919Gear Shift Position Control Error
P0920Gear Shift Forward Actuator Circuit Open
P0921Gear Shift Forward Actuator CKT Range/Perf
P0922Gear Shift Forward Actuator Circuit Low
P0923Gear Shift Forward Actuator Circuit High
P0924Gear Shift Reverse Actuator Circuit Open
P0925Gear Shift Reverse Actuator CKT Range/Perf
P0926Gear Shift Reverse Actuator Circuit Low
P0927Gear Shift Reverse Actuator Circuit High
P0928Gear Shift Lock Solenoid Ctrl Circuit Open
P0929Gear Shift Lock Solenoid Ctrl CKT Range/Perf
P0930Gear Shift Lock Solenoid Ctrl Circuit Low
P0931Gear Shift Lock Solenoid Ctrl Circuit High
P0932Hydraulic Pressure Sensor Circuit
P0933Hydraulic Pressure Sensor CKT Range/Perf
P0934Hydraulic Pressure Sensor Circuit Low
P0935Hydraulic Pressure Sensor Circuit High
P0936Hydraulic Pressure Sensor CKT Intermittent
P0937Hydraulic Oil Temp Sensor Circuit
P0938Hydraulic Oil Temp Sensor CKT Range/Perf
P0939Hydraulic Oil Temp Sensor Circuit Low
P0940Hydraulic Oil Temp Sensor Circuit High
P0941Hydraulic Oil Temp Sensor CKT Intermittent
P0942Hyd. Pressure Unit
P0943Hyd. Pressure Unit Unit Cycling Too Short
P0944Hyd. Pressure Unit Loss of Pressure
P0945Hyd. Pump Relay Circuit Open
P0946Hyd. Pump Relay CKT Range/Perf
P0947Hyd. Pump Relay Circuit Low
P0948Hyd. Pump Relay Circuit High
P0949Auto Shift Adaptive Learning Not Complete
P0950Auto Shift Manual Control Circuit
P0951Auto Shift Manual Control CKT Range/Perf
P0952Auto Shift Manual Control Circuit Low
P0953Auto Shift Manual Control Circuit High
P0954Auto Shift Manual Control CKT Intermittent
P0955Auto Shift Manual Mode Circuit
P0956Auto Shift Manual Mode CKT Range/Perf
P0957Auto Shift Manual Mode Circuit Low
P0958Auto Shift Manual Mode Circuit High
P0959Auto Shift Manual Mode CKT Intermittent
P0960Pressure Control Solenoid A Control Circuit Open
P0961Pressure Control Solenoid A Control CKT Range/Perf
P0962Pressure Control Solenoid A Control Circuit Low
P0963Pressure Control Solenoid A Control Circuit High
P0964Pressure Control Solenoid B Control Circuit Open
P0965Pressure Control Solenoid B Control CKT Range/Perf
P0966Pressure Control Solenoid B Control Circuit Low
P0967Pressure Control Solenoid B Control Circuit High
P0968Pressure Control Solenoid C Control Circuit Open
P0969Pressure Control Solenoid C Control CKT Range/Perf
P0970Pressure Control Solenoid C Control Circuit Low
P0971Pressure Control Solenoid C Control Circuit High
P0972Shift Solenoid A Control CKT Range/Perf
P0973Shift Solenoid A Control Circuit Low
P0974Shift Solenoid A Control Circuit High
P0975Shift Solenoid B Control CKT Range/Perf
P0976Shift Solenoid B Control Circuit Low
P0977Shift Solenoid B Control Circuit High
P0978Shift Solenoid C Control CKT Range/Perf
P0979Shift Solenoid C Control Circuit Low
P0980Shift Solenoid C Control Circuit High
P0981Shift Solenoid D Control CKT Range/Perf
P0982Shift Solenoid D Control Circuit Low
P0983Shift Solenoid D Control Circuit High
P0984Shift Solenoid E Control CKT Range/Perf
P0985Shift Solenoid E Control Circuit Low
P0986Shift Solenoid E Control Circuit High
P0987Trans Fluid Press Sensor/Switch E Circuit
P0988Trans Fluid Press Sensor/Switch E CKT Range/Perf
P0989Trans Fluid Press Sensor/Switch E Circuit Low
P0990Trans Fluid Press Sensor/Switch E Circuit High
P0991Trans Fluid Press Sensor/Switch E CKT Intermittent
P0992Trans Fluid Press Sensor/Switch F Circuit
P0993Trans Fluid Press Sensor/Switch F CKT Range/Perf
P0994Trans Fluid Press Sensor/Switch F Circuit Low
P0995Trans Fluid Press Sensor/Switch F Circuit High
P0996Trans Fluid Press Sensor/Switch F CKT Intermittent
P0997Shift Solenoid F Control CKT Range/Perf
P0998Shift Solenoid F Control Circuit Low
P0999Shift Solenoid F Control Circuit High
P2000NOx Trap Eff Below Threshold Bank1
P2001NOx Trap Eff Below Threshold Bank2
P2002Particulate Trap Eff Below Threshold Bank1
P2003Particulate Trap Eff Below Threshold Bank2
P2004Intake Manif Runner Ctrl Stuck Open Bank1
P2005Intake Manif Runner Ctrl Stuck Open Bank2
P2006Intake Manif Runner Ctrl Stuck Closed Bank1
P2007Intake Manif Runner Ctrl Stuck Closed Bank2
P2008Intake Manif Runner Ctrl Circ/Open Bank1
P2009Intake Manif Runner Ctrl Circ Low Bank1
P2010Intake Manif Runner Ctrl Circ Hi Bank1
P2011Intake Manif Runner Ctrl Circ/Open Bank2
P2012Intake Manif Runner Ctrl Circ Low Bank2
P2013Intake Manif Runner Ctrl Circ Hi Bank2
P2014Intake Manif Runner Pos Sens/Switch Circ Bank1
P2015Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank 1
P2016Intake Manif Runner Pos Sens/Switch Circ Low Bank1
P2017Intake Manif Runner Pos Sens/Switch Circ Hi Bank1
P2018Intake Manif Runner Pos Sens/Switch Circ Interm Bank1
P2019Intake Manif Runner Pos Sens/Switch Circ Bank2
P2020Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank 2
P2021Intake Manif Runner Pos Sens/Switch Circ Low Bank2
P2022Intake Manif Runner Pos Sens/Switch Circ Hi Bank2
P2023Intake Manif Runner Pos Sens/Switch Circ Interm Bank2
P2024EVAP Emissions (EVAP) Fuel Vapor Temp Sens Circ
P2025EVAP Fuel Vapor Temp Sens Perf
P2026EVAP Fuel Vapor Temp Sens Circ Low Voltage
P2027EVAP Fuel Vapor Temp Sens Circ Hi Voltage
P2028EVAP Fuel Vapor Temp Sens Circ Interm
P2029Fuel Fired Heater Disabled
P2030Fuel Fired Heater Perf
P2031Exhaust Gas Temp Sens Circ Bank1 Sens2
P2032Exhaust Gas Temp Sens Circ Low Bank1 Sens2
P2033Exhaust Gas Temp Sens Circ Hi Bank1 Sens2
P2034Exhaust Gas Temp Sens Circ Bank2 Sens2
P2035Exhaust Gas Temp Sens Circ Low Bank2 Sens2
P2036Exhaust Gas Temp Sens Circ Hi Bank2 Sens2
P2037Reductant Inj Air Press Sens Circ
P2038Reductant Inj Air Press Sens Circ Range/Perf
P2039Reductant Inj Air Press Sens Circ Low Input
P2040Reductant Inj Air Press Sens Circ Hi Input
P2041Reductant Inj Air Press Sens Circ Interm
P2042Reductant Temp Sens Circ
P2043Reductant Temp Sens Circ Range/Perf
P2044Reductant Temp Sens Circ Low Input
P2045Reductant Temp Sens Circ Hi Input
P2046Reductant Temp Sens Circ Interm
P2047Reductant Injector Circ/Open Bank1 Unit 1
P2048Reductant Injector Circ Low Bank1 Unit 1
P2049Reductant Injector Circ Hi Bank1 Unit 1
P2050Reductant Injector Circ/Open Bank2 Unit 1
P2051Reductant Injector Circ Low Bank2 Unit 1
P2052Reductant Injector Circ Hi Bank2 Unit 1
P2053Reductant Injector Circ/Open Bank1 Unit 2
P2054Reductant Injector Circ Low Bank1 Unit 2
P2055Reductant Injector Circ Hi Bank1 Unit 2
P2056Reductant Injector Circ/Open Bank2 Unit 2
P2057Reductant Injector Circ Low Bank2 Unit 2
P2058Reductant Injector Circ Hi Bank2 Unit 2
P2059Reductant Inj Air Pump Ctrl Circ/Open
P2060Reductant Inj Air Pump Ctrl Circ Low
P2061Reductant Inj Air Pump Ctrl Circ Hi
P2062Reductant Supply Ctrl Circ/Open
P2063Reductant Supply Ctrl Circ Low
P2064Reductant Supply Ctrl Circ Hi
P2065Fuel Level Sens B Circ
P2066Fuel Level Sens B Perf
P2067Fuel Level Sens B Circ Low
P2068Fuel Level Sens B Circ Hi
P2069Fuel Level Sens B Circ Interm
P2070Intake Manif Tuning (IMT) Valve Stuck Open
P2071IMT Valve Stuck Closed
P2075IMT Valve Pos Sens/Switch Circ
P2076IMT Valve Pos Sens/Switch Circ Range/Perf
P2077IMT Valve Pos Sens/Switch Circ Low
P2078IMT Valve Pos Sens/Switch Circ Hi
P2079IMT Valve Pos Sens/Switch Circ Interm
P2080Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens1
P2081Exhaust Gas Temp Sens Circ Interm Bank1 Sens1
P2082Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens1
P2083Exhaust Gas Temp Sens Circ Interm Bank2 Sens1
P2084Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens2
P2085Exhaust Gas Temp Sens Circ Interm Bank1 Sens2
P2086Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens2
P2087Exhaust Gas Temp Sens Circ Interm Bank2 Sens2
P2088A Camshaft Pos Actuator Ctrl Circ Low Bank1
P2089A Camshaft Pos Actuator Ctrl Circ Hi Bank1
P2090B Camshaft Pos Actuator Ctrl Circ Low Bank1 c)
P2091B Camshaft Pos Actuator Ctrl Circ Hi Bank1 c)
P2092A Camshaft Pos Actuator Ctrl Circ Low Bank2
P2093A Camshaft Pos Actuator Ctrl Circ Hi Bank2
P2094B Camshaft Pos Actuator Ctrl Circ Low Bank2 c)
P2095B Camshaft Pos Actuator Ctrl Circ Hi Bank2 c)
P2096Post Catalyst Fuel Trim Sys Too Lean Bank1
P2097Post Catalyst Fuel Trim Sys Too Rich Bank1
P2098Post Catalyst Fuel Trim Sys Too Lean Bank2
P2099Post Catalyst Fuel Trim Sys Too Rich Bank2
P2100Throttle Actuator Ctrl Motor Circ/Open
P2101Throttle Actuator Ctrl Motor Circ Range/Perf
P2102Throttle Actuator Ctrl Motor Circ Low
P2103Throttle Actuator Ctrl Motor Circ Hi
P2104Throttle Actuator Ctrl Sys-Forced Idle
P2105Throttle Actuator Ctrl Sys-Forced Engine Shutdown
P2106Throttle Actuator Ctrl Sys-Forced Limited Power
P2107Throttle Actuator Ctrl Mod Processor
P2108Throttle Actuator Ctrl Mod Perf
P2109Throttle/Pedal Pos Sens A Minimum Stop Perf
P2110Throttle Actuator Ctrl Sys-Forced Limited RPM
P2111 Throttle Actuator Ctrl Sys-Stuck Open
P2112Throttle Actuator Ctrl Sys-Stuck Closed
P2113Throttle/Pedal Pos Sens B Minimum Stop Perf
P2114Throttle/Pedal Pos Sens C Minimum Stop Perf
P2115Throttle/Pedal Pos Sens D Minimum Stop Perf
P2116Throttle/Pedal Pos Sens E Minimum Stop Perf
P2117Throttle/Pedal Pos Sens F Minimum Stop Perf
P2118Throttle Actuator Ctrl Motor Current Range/Perf
P2119Throttle Actuator Ctrl Throttle Body Range/Perf
P2120Throttle/Pedal Pos Sens/Switch D Circ
P2121Throttle/Pedal Pos Sens/Switch D Circ Range/Perf
P2122Throttle/Pedal Pos Sens/Switch D Circ Low Input
P2123Pedal Pos Sens1 Hi
P2124Throttle/Pedal Pos Sens/Switch D Circ Interm
P2125Throttle/Pedal Pos Sens/Switch E Circ
P2126Throttle/Pedal Pos Sens/Switch E Circ Range/Perf
P2127Pedal Pos Validation Switch 2 Low
P2128Pedal Pos Validation Switch 2 Hi
P2129Throttle/Pedal Pos Sens/Switch E Circ Interm
P2130Throttle/Pedal Pos Sens/Switch F Circ
P2131Throttle/Pedal Pos Sens/Switch F Circ Range Perf
P2132Throttle/Pedal Pos Sens/Switch F Circ Low Input
P2133Throttle/Pedal Pos Sens/Switch F Circ Hi Input
P2134Throttle/Pedal Pos Sens/Switch F Circ Interm
P2135Throttle/Pedal Pos Sens/Switch A/B Voltage Correlation
P2136Throttle/Pedal Pos Sens/Switch A/C Voltage Correlation
P2137Throttle/Pedal Pos Sens/Switch B/C Voltage Correlation
P2138Throttle/Pedal Pos Sens/Switch D/E Voltage Correlation
P2139Throttle/Pedal Pos Sens/Switch D/F Voltage Correlation
P2140Throttle/Pedal Pos Sens/Switch E/F Voltage Correlation
P2141Exhaust Gas Recirculation Throttle Ctrl Circ Low
P2142Exhaust Gas Recirculation Throttle Ctrl Circ Hi
P2143Exhaust Gas Recirculation Vent Ctrl Circ/Open
P2144Exhaust Gas Recirculation Vent Ctrl Circ Low
P2145Exhaust Gas Recirculation Vent Ctrl Circ Hi
P2146Fuel Injector Group 1 Supply Voltage Circ
P2147Fuel Injector Group 1 Supply Voltage Low
P2148Fuel Injector Group 1 Supply Voltage Hi
P2149Fuel Injector Group 2 Supply Voltage Circ
P2150Fuel Injector Group 2 Supply Voltage Low
P2151Fuel Injector Group 2 Supply Voltage Hi
P2152Fuel Injector Group C Supply Voltage Circ/Open
P2153Fuel Injector Group C Supply Voltage Circ Low
P2154Fuel Injector Group C Supply Voltage Circ Hi
P2155Fuel Injector Group D Supply Voltage Circ/Open
P2156Fuel Injector Group D Supply Voltage Circ Low
P2157Fuel Injector Group D Supply Voltage Circ Hi
P2158Vehicle Speed Sens B
P2159Vehicle Speed Sens B Range/Perf
P2160Vehicle Speed Sens B Circ Low
P2161Vehicle Speed Sens B Interm/Erratic
P2162Vehicle Speed Sens A / B Correlation
P2163Throttle/Pedal Pos Sens A Maximum Stop Perf
P2164Throttle/Pedal Pos Sens B Maximum Stop Perf
P2165Throttle/Pedal Pos Sens C Maximum Stop Perf
P2166Throttle/Pedal Pos Sens D Maximum Stop Perf
P2167Throttle/Pedal Pos Sens E Maximum Stop Perf
P2168Throttle/Pedal Pos Sens F Maximum Stop Perf
P2169Exhaust Press Regulator Vent Solenoid Ctrl Circ/Open
P2170Exhaust Press Regulator Vent Solenoid Ctrl Circ Low
P2171Exhaust Press Regulator Vent Solenoid Ctrl Circ Hi
P2172Throttle Actuator Ctrl Sys-Sudden Hi Airflow Detected
P2173Throttle Actuator Ctrl Sys-Hi Airflow Detected
P2174Throttle Actuator Ctrl Sys-Sudden Low Airflow Detected
P2175Throttle Actuator Ctrl Sys-Low Airflow Detected
P2176Throttle Actuator Ctrl Sys-Idle Pos Not Learned
P2177Sys Too Lean Off Idle Bank1
P2178Sys Too Rich Off Idle Bank1
P2179Sys Too Lean Off Idle Bank2
P2180Sys Too Rich Off Idle Bank2
P2181Cooling Sys Perf
P2182Engine Coolant Temp Sens2 Circ
P2183Engine Coolant Temp Sens2 Circ Range/Perf
P2184Engine Coolant Temp Sens2 Circ Low
P2185Engine Coolant Temp Sens2 Circ Hi
P2186Engine Coolant Temp Sens2 Circ Interm/Erratic
P2187Sys Too Lean at Idle Bank1
P2188Sys Too Rich at Idle Bank1
P2189Sys Too Lean at Idle Bank2
P2190Sys Too Rich at Idle Bank2
P2191Sys Too Lean at Hier Load Bank1
P2192Sys Too Rich at Hier Load Bank1
P2193Sys Too Lean at Hier Load Bank2
P2194Sys Too Rich at Hier Load Bank2
P2195O2 Sens Signal Stuck Lean Bank1 Sens1
P2196O2 Sens Signal Stuck Rich Bank1 Sens1
P2197O2 Sens Signal Stuck Lean Bank2 Sens1
P2198O2 Sens Signal Stuck Rich Bank2 Sens1
P2199Intake Air Temp Sens1 / 2 Correlation
P2200NOx Sens Circ Bank1
P2201NOx Sens Circ Range/Perf Bank1
P2202NOx Sens Circ Low Input Bank1
P2203NOx Sens Circ Hi Input Bank1
P2204NOx Sens Circ Interm Input Bank1
P2205NOx Sens Heater Ctrl Circ/Open Bank1
P2206NOx Sens Heater Ctrl Circ Low Bank1
P2207NOx Sens Heater Ctrl Circ Hi Bank1
P2208NOx Sens Heater Sense Circ Bank1
P2209NOx Sens Heater Sense Circ Range/Perf Bank1
P2210NOx Sens Heater Sense Circ Low Input Bank1
P2211NOx Sens Heater Sense Circ Hi Input Bank1
P2212NOx Sens Heater Sense Circ Interm Bank1
P2213NOx Sens Circ Bank2
P2214NOx Sens Circ Range/Perf Bank2
P2215NOx Sens Circ Low Input Bank2
P2216NOx Sens Circ Hi Input Bank2
P2217NOx Sens Circ Interm Input Bank2
P2218NOx Sens Heater Ctrl Circ/Open Bank2
P2219NOx Sens Heater Ctrl Circ Low Bank2
P2220NOx Sens Heater Ctrl Circ Hi Bank2
P2221NOx Sens Heater Sense Circ Bank2
P2222NOx Sens Heater Sense Circ Range/Perf Bank2
P2223NOx Sens Heater Sense Circ Low Bank2
P2224NOx Sens Heater Sense Circ Hi Bank2
P2225NOx Sens Heater Sense Circ Interm Bank2
P2226Barometric Press Circ
P2227Barometric Press Circ Range/Perf
P2228Barometric Press Circ Low
P2229Barometric Press Circ Hi
P2230Barometric Press Circ Interm
P2231O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens1
P2232O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens2
P2233O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens3
P2234O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens1
P2235O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens2
P2236O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens3
P2237O2 Sens Positive Current Ctrl Circ/Open Bank1 Sens1
P2238O2 Sens Positive Current Ctrl Circ Low Bank1 Sens1
P2239O2 Sens Positive Current Ctrl Circ Hi Bank1 Sens1
P2240O2 Sens Positive Current Ctrl Circ/Open Bank2 Sens1
P2241O2 Sens Positive Current Ctrl Circ Low Bank2 Sens1
P2242O2 Sens Positive Current Ctrl Circ Hi Bank2 Sens1
P2243O2 Sens Ref Voltage Circ/Open Bank1 Sens1
P2244O2 Sens Ref Voltage Perf Bank1 Sens1
P2245O2 Sens Ref Voltage Circ Low Bank1 Sens1
P2246O2 Sens Ref Voltage Circ Hi Bank1 Sens1
P2247O2 Sens Ref Voltage Circ/Open Bank2 Sens1
P2248O2 Sens Ref Voltage Perf Bank2 Sens1
P2249O2 Sens Ref Voltage Circ Low Bank2 Sens1
P2250O2 Sens Ref Voltage Circ Hi Bank2 Sens1
P2251O2 Sens Negative Current Ctrl Circ/Open Bank1 Sens1
P2252O2 Sens Negative Current Ctrl Circ Low Bank1 Sens1
P2253O2 Sens Negative Current Ctrl Circ Hi Bank1 Sens1
P2254O2 Sens Negative Current Ctrl Circ/Open Bank2 Sens1
P2255O2 Sens Negative Current Ctrl Circ Low Bank2 Sens1
P2256O2 Sens Negative Current Ctrl Circ Hi Bank2 Sens1
P2257Sec Air Inj Sys Ctrl A Circ Low
P2258Sec Air Inj Sys Ctrl A Circ Hi
P2259Sec Air Inj Sys Ctrl B Circ Low
P2260Sec Air Inj Sys Ctrl B Circ Hi
P2261T/Super Charger Bypass Valve-Mechanical
P2262Turbo Boost Press Not Detected-Mechanical
P2263T/Super Charger Boost Sys Perf
P2264Water in Fuel Sens Circ
P2265Water in Fuel Sens Circ Range/Perf
P2266Water in Fuel Sens Circ Low
P2267Water in Fuel Sens Circ Hi
P2268Water in Fuel Sens Circ Interm
P2269Water in Fuel Condition
P2270O2 Sens Signal Stuck Lean Bank1 Sens2
P2271O2 Sens Signal Stuck Rich Bank1 Sens2
P2272O2 Sens Signal Stuck Lean Bank2 Sens2
P2273O2 Sens Signal Stuck Rich Bank2 Sens2
P2274O2 Sens Signal Stuck Lean Bank1 Sens3
P2275O2 Sens Signal Stuck Rich Bank1 Sens3
P2276O2 Sens Signal Stuck Lean Bank2 Sens3
P2277O2 Sens Signal Stuck Rich Bank2 Sens3
P2278O2 Sens Signals Swapped Bank1 Sens3 / Bank2 Sens3
P2279Intake Air Sys Leak
P2280Air Flow Restriction / Air Leak Between Air Filter and MAF
P2281Air Leak Between MAF and Throttle Body
P2282Air Leak Between Throttle Body and Intake Valves
P2283Injector Ctrl Press Sens Circ
P2284Injector Ctrl Press Sens Circ Range/Perf
P2285Injector Ctrl Press Sens Circ Low
P2286Injector Ctrl Press Sens Circ Hi
P2287Injector Ctrl Press Sens Circ Interm
P2288Injector Ctrl Press Too Hi
P2289Injector Ctrl Press Too Hi-Engine Off
P2290Injector Ctrl Press Too Low
P2291Injector Ctrl Press Too Low-Engine Cranking
P2292Injector Ctrl Press Erratic
P2293Fuel Press Regulator 2 Perf
P2294Fuel Press Regulator 2 Ctrl Circ
P2295Fuel Press Regulator 2 Ctrl Circ Low
P2296Fuel Press Regulator 2 Ctrl Circ Hi
P2297O2 Sens Out of Range During Deceleration Bank1 Sens1
P2298O2 Sens Out of Range During Deceleration Bank2 Sens1
P2299Brake Pedal Pos / Accelerator Pedal Pos Incompatible
P2300Ignition Coil A Primary Ctrl Circ Low
P2301Ignition Coil A Primary Ctrl Circ Hi
P2302Ignition Coil A Sec Circ
P2303Ignition Coil B Primary Ctrl Circ Low
P2304Ignition Coil B Primary Ctrl Circ Hi
P2305Ignition Coil B Sec Circ
P2306Ignition Coil C Primary Ctrl Circ Low
P2307Ignition Coil C Primary Ctrl Circ Hi
P2308Ignition Coil C Sec Circ
P2309Ignition Coil D Primary Ctrl Circ Low
P2310Ignition Coil D Primary Ctrl Circ Hi
P2311Ignition Coil D Sec Circ
P2312Ignition Coil E Primary Ctrl Circ Low
P2313Ignition Coil E Primary Ctrl Circ Hi
P2314Ignition Coil E Sec Circ
P2315Ignition Coil F Primary Ctrl Circ Low
P2316Ignition Coil F Primary Ctrl Circ Hi
P2317Ignition Coil F Sec Circ
P2318Ignition Coil G Primary Ctrl Circ Low
P2319Ignition Coil G Primary Ctrl Circ Hi
P2320Ignition Coil G Sec Circ
P2321Ignition Coil H Primary Ctrl Circ Low
P2322Ignition Coil H Primary Ctrl Circ Hi
P2323Ignition Coil H Sec Circ
P2324Ignition Coil I Primary Ctrl Circ Low
P2325Ignition Coil I Primary Ctrl Circ Hi
P2326Ignition Coil I Sec Circ
P2327Ignition Coil J Primary Ctrl Circ Low
P2328Ignition Coil J Primary Ctrl Circ Hi
P2329Ignition Coil J Sec Circ
P2330Ignition Coil K Primary Ctrl Circ Low
P2331Ignition Coil K Primary Ctrl Circ Hi
P2332Ignition Coil K Sec Circ
P2333Ignition Coil L Primary Ctrl Circ Low
P2334Ignition Coil L Primary Ctrl Circ Hi
P2335Ignition Coil L Sec Circ
P2336Cylinder #1 Above Knock Threshold
P2337Cylinder #2 Above Knock Threshold
P2338Cylinder #3 Above Knock Threshold
P2339Cylinder #4 Above Knock Threshold
P2340Cylinder #5 Above Knock Threshold
P2341Cylinder #6 Above Knock Threshold
P2342Cylinder #7 Above Knock Threshold
P2343Cylinder #8 Above Knock Threshold
P2344Cylinder #9 Above Knock Threshold
P2345Cylinder #10 Above Knock Threshold
P2346Cylinder #11 Above Knock Threshold
P2347Cylinder #12 Above Knock Threshold
P2400EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
P2401EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
P2402EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
P2403EVAP Emission Sys Leak Detection Pump Sense Circ/Open
P2404EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
P2405EVAP Emission Sys Leak Detection Pump Sense Circ Low
P2406EVAP Emission Sys Leak Detection Pump Sense Circ Hi
P2407EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
P2408Fuel Cap Sens/Switch Circ
P2409Fuel Cap Sens/Switch Circ Range/Perf
P2410 Fuel Cap Sens/Switch Circ Low
P2411Fuel Cap Sens/Switch Circ Hi
P2412Fuel Cap Sens/Switch Circ Interm/Erratic
P2413Exhaust Gas Recirculation Sys Perf
P2414O2 Sens Exhaust Sample Error Bank1 Sens1
P2415O2 Sens Exhaust Sample Error Bank2 Sens1
P2416O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
P2417O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
P2418EVAP Emission Sys Switching Valve Ctrl Circ /Open
P2419EVAP Emission Sys Switching Valve Ctrl Circ Low
P2420EVAP Emission Sys Switching Valve Ctrl Circ Hi
P2421EVAP Emission Sys Vent Valve Stuck Open
P2422EVAP Emission Sys Vent Valve Stuck Closed
P2423HC Adsorption Catalyst Eff Below Threshold Bank1
P2424HC Adsorption Catalyst Eff Below Threshold Bank2
P2425Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
P2426Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
P2427Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
P2428Exhaust Gas Temp Too Hi Bank1
P2429Exhaust Gas Temp Too Hi Bank2
P2430Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
P2431Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
P2432Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
P2433Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
P2434Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
P2435Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
P2436Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
P2437Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
P2438Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
P2439Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
P2440Sec Air Inj Sys Switching Valve Stuck Open Bank1
P2441Sec Air Inj Sys Switching Valve Stuck Closed Bank1
P2442Sec Air Inj Sys Switching Valve Stuck Open Bank2
P2443Sec Air Inj Sys Switching Valve Stuck Closed Bank2
P2444Sec Air Inj Sys Pump Stuck On Bank1
P2445Sec Air Inj Sys Pump Stuck Off Bank1
P2446Sec Air Inj Sys Pump Stuck On Bank2
P2447Sec Air Inj Sys Pump Stuck Off Bank2
P2500Generator Lamp/L-Terminal Circ Low
P2501Generator Lamp/L-Terminal Circ Hi
P2502Charging Sys Output Voltage
P2503Charging Sys Output Voltage Low
P2504Charging Sys Output Voltage Hi
P2505ECM/PCM Power Input Signal
P2506ECM/PCM Power Input Signal Range/Perf
P2507ECM/PCM Power Input Signal Low
P2508ECM/PCM Power Input Signal Hi
P2509CM/PCM Power Input Signal Interm
P2510ECM/PCM Power Relay Sense Circ Range/Perf
P2511 ECM/PCM Power Relay Sense Circ Interm
P2512Event Data Recorder Request Circ/ Open
P2513Event Data Recorder Request Circ Low
P2514Event Data Recorder Request Circ Hi
P2515A/C Refrigerant Press Sens B Circ
P2516A/C Refrigerant Press Sens B Circ Range/Perf
P2517A/C Refrigerant Press Sens B Circ Low
P2518A/C Refrigerant Press Sens B Circ Hi
P2519A/C Request A Circ
P2520A/C Request A Circ Low
P2521A/C Request A Circ Hi
P2522A/C Request B Circ
P2523A/C Request B Circ Low
P2524A/C Request B Circ Hi
P2525Vacuum Reservoir Press Sens Circ
P2526Vacuum Reservoir Press Sens Circ Range/Perf
P2527Vacuum Reservoir Press Sens Circ Low
P2528Vacuum Reservoir Press Sens Circ Hi
P2529Vacuum Reservoir Press Sens Circ Interm
P2530Ignition Switch Run Pos Circ
P2531Ignition Switch Run Pos Circ Low
P2532Ignition Switch Run Pos Circ Hi
P2533Ignition Switch Run/Start Pos Circ
P2534Ignition Switch Run/Start Pos Circ Low
P2535Ignition Switch Run/Start Pos Circ Hi
P2536Ignition Switch Accessory Pos Circ
P2537Ignition Switch Accessory Pos Circ Low
P2538Ignition Switch Accessory Pos Circ Hi
P2539Low Press Fuel Sys Sens Circ
P2540Low Press Fuel Sys Sens Circ Range/Perf
P2541Low Press Fuel Sys Sens Circ Low
P2542Low Press Fuel Sys Sens Circ Hi
P2543Low Press Fuel Sys Sens Circ Interm
P2544Torque Management Request Input Signal A
P2545Torque Management Request Input Signal A Range/Perf
P2546Torque Management Request Input Signal A Low
P2547Torque Management Request Input Signal A Hi
P2548Torque Management Request Input Signal B
P2549Torque Management Request Input Signal B Range/Perf
P2550Torque Management Request Input Signal B Low
P2551Torque Management Request Input Signal B Hi
P2552Throttle/Fuel Inhibit Circ
P2553Throttle/Fuel Inhibit Circ Range/Perf
P2554Throttle/Fuel Inhibit Circ Low
P2555Throttle/Fuel Inhibit Circ Hi
P2556Engine Coolant Level Sens/Switch Circ
P2557Engine Coolant Level Sens/Switch Circ Range/Perf
P2558Engine Coolant Level Sens/Switch Circ Low
P2559Engine Coolant Level Sens/Switch Circ Hi
P2560Engine Coolant Level Low
P2561A/C Ctrl Mod Requested MIL Illumination
P2562Turbocharger Boost Ctrl Pos Sens Circ
P2563Turbocharger Boost Ctrl Pos Sens Circ Range/Perf
P2564Turbocharger Boost Ctrl Pos Sens Circ Low
P2565Turbocharger Boost Ctrl Pos Sens Circ Hi
P2566Turbocharger Boost Ctrl Pos Sens Circ Interm
P2567Direct Ozone Reduction Catalyst Temp Sens Circ
P2568Direct Ozone Reduction Catalyst Temp Sens Circ Range/Perf
P2569Direct Ozone Reduction Catalyst Temp Sens Circ Low
P2570Direct Ozone Reduction Catalyst Temp Sens Circ Hi
P2571Direct Ozone Reduction Catalyst Temp Sens Circ Interm/Erratic
P2572Direct Ozone Reduction Catalyst Deterioration Sens Circ
P2573Direct Ozone Reduction Catalyst Deterioration Sens Circ Range/Perf
P2574Direct Ozone Reduction Catalyst Deterioration Sens Circ Low
P2575Direct Ozone Reduction Catalyst Deterioration Sens Circ Hi
P2576Direct Ozone Reduction Catalyst Deterioration Sens Circ Interm/Erratic
P2577Direct Ozone Reduction Catalyst Eff Below Threshold
P2600Coolant Pump Ctrl Circ/Open
P2601Coolant Pump Ctrl Circ Range/Perf
P2602Coolant Pump Ctrl Circ Low
P2603Coolant Pump Ctrl Circ Hi
P2604Intake Air Heater A Circ Range/Perf
P2605Intake Air Heater A Circ/Open
P2606Intake Air Heater B Circ Range/Perf
P2607Intake Air Heater Relay 2 Low
P2608Intake Air Heater Relay 2 Hi
P2609Intake Air Heater Sys Perf
P2610ECM/PCM Internal Engine Off Timer Perf
P2611A/C Refrigerant Distribution Valve Ctrl Circ/Open
P2612A/C Refrigerant Distribution Valve Ctrl Circ Low
P2613A/C Refrigerant Distribution Valve Ctrl Circ Hi
P2614Camshaft Pos Signal Output Circ/Open
P2615Camshaft Pos Signal Output Circ Low
P2616Camshaft Pos Signal Output Circ Hi
P2617Crank Pos Signal Output Circ/Open
P2618Crank Pos Signal Output Circ Low
P2619Crank Pos Signal Output Circ Hi
P2620Throttle Pos Output Circ/Open
P2621Throttle Pos Output Circ Low
P2622Throttle Pos Output Circ Hi
P2623Injector Ctrl Press Regulator Circ/Open
P2624Injector Ctrl Press Regulator Circ Low
P2625Injector Ctrl Press Regulator Circ Hi
P2626O2 Sens Pumping Current Trim Circ/Open Bank1 Sens1
P2627O2 Sens Pumping Current Trim Circ Low Bank1 Sens1
P2628O2 Sens Pumping Current Trim Circ Hi Bank1 Sens1
P2629O2 Sens Pumping Current Trim Circ/Open Bank2 Sens1
P2630O2 Sens Pumping Current Trim Circ Low Bank2 Sens1
P2631O2 Sens Pumping Current Trim Circ Hi Bank2 Sens1
P2632Fuel Pump B Ctrl Circ /Open
P2633Fuel Pump B Ctrl Circ Low
P2634Fuel Pump B Ctrl Circ Hi
P2635Fuel Pump A Low Flow / Perf
P2636Fuel Pump B Low Flow / Perf
P2637Torque Management Feedback Signal A
P2638Torque Management Feedback Signal A Range/Perf
P2639Torque Management Feedback Signal A Low
P2640Torque Management Feedback Signal A Hi
P2641Torque Management Feedback Signal B
P2642Torque Management Feedback Signal B Range/Perf
P2643Torque Management Feedback Signal B Low
P2644Torque Management Feedback Signal B Hi
P2645A Rocker Arm Actuator Ctrl Circ/Open Bank1
P2646A Rocker Arm Actuator Sys Perf or Stuck Off Bank1
P2647A Rocker Arm Actuator Sys Stuck On Bank1
P2648A Rocker Arm Actuator Ctrl Circ Low Bank1
P2649A Rocker Arm Actuator Ctrl Circ Hi Bank1
P2650B Rocker Arm Actuator Ctrl Circ/Open Bank1
P2651B Rocker Arm Actuator Sys Perf or Stuck Off Bank1
P2652B Rocker Arm Actuator Sys Stuck On Bank1
P2653B Rocker Arm Actuator Ctrl Circ Low Bank1
P2654B Rocker Arm Actuator Ctrl Circ Hi Bank1
P2655A Rocker Arm Actuator Ctrl Circ/Open Bank2
P2656A Rocker Arm Actuator Sys Perf or Stuck Off Bank2
P2657A Rocker Arm Actuator Sys Stuck On Bank2
P2658A Rocker Arm Actuator Ctrl Circ Low Bank2
P2659A Rocker Arm Actuator Ctrl Circ Hi Bank2
P2660B Rocker Arm Actuator Ctrl Circ/Open Bank2
P2661B Rocker Arm Actuator Sys Perf or Stuck Off Bank2
P2662B Rocker Arm Actuator Sys Stuck On Bank2
P2663B Rocker Arm Actuator Ctrl Circ Low Bank2
P2664B Rocker Arm Actuator Ctrl Circ Hi Bank2
P2665Fuel Shutoff Valve B Ctrl Circ/Open
P2666Fuel Shutoff Valve B Ctrl Circ Low
P2667Fuel Shutoff Valve B Ctrl Circ Hi
P2668Fuel Mode Indicator Lamp Ctrl Circ
P2669Actuator Supply Voltage B Circ /Open
P2670Actuator Supply Voltage B Circ Low
P2671Actuator Supply Voltage B Circ Hi
P2700Trans Friction Element A Apply Time Range/Perf
P2701Trans Friction Element B Apply Time Range/Perf
P2702Trans Friction Element C Apply Time Range/Perf
P2703Trans Friction Element D Apply Time Range/Perf
P2704Trans Friction Element E Apply Time Range/Perf
P2705Trans Friction Element F Apply Time Range/Perf
P2706Shift Solenoid F
P2707Shift Solenoid F Perf or Stuck Off
P2708Shift Solenoid F Stuck On
P2709Shift Solenoid F Electrical
P2710Shift Solenoid F Interm
P2711Unexpected Mechanical Gear Disengagement
P2712Hydraulic Power Unit Leakage
P2713Press Ctrl Solenoid D
P2714Press Ctrl Solenoid D Perf or Stuck Off
P2715Press Ctrl Solenoid D Stuck On
P2716Press Ctrl Solenoid D Electrical
P2717Press Ctrl Solenoid D Interm
P2718Press Ctrl Solenoid D Ctrl Circ / Open
P2719Press Ctrl Solenoid D Ctrl Circ Range/Perf
P2720Press Ctrl Solenoid D Ctrl Circ Low
P2721Press Ctrl Solenoid D Ctrl Circ Hi
P2722Press Ctrl Solenoid E
P2723Press Ctrl Solenoid E Perf or Stuck Off
P2724Press Ctrl Solenoid E Stuck On
P2725 Press Ctrl Solenoid E Electrical
P2726Press Ctrl Solenoid E Interm
P2727Press Ctrl Solenoid E Ctrl Circ / Open
P2728Press Ctrl Solenoid E Ctrl Circ Range/Perf
P2729Press Ctrl Solenoid E Ctrl Circ Low
P2730Press Ctrl Solenoid E Ctrl Circ Hi
P2731Press Ctrl Solenoid F
P2732Press Ctrl Solenoid F Perf or Stuck Off
P2733Press Ctrl Solenoid F Stuck On
P2734Press Ctrl Solenoid F Electrical
P2735Press Ctrl Solenoid F Interm
P2736Press Ctrl Solenoid F Ctrl Circ/Open
P2737Press Ctrl Solenoid F Ctrl Circ Range/Perf
P2738Press Ctrl Solenoid F Ctrl Circ Low
P2739Press Ctrl Solenoid F Ctrl Circ Hi
P2740Trans Fluid Temp Sens B Circ
P2741Trans Fluid Temp Sens B Circ Range Perf
P2742Trans Fluid Temp Sens B Circ Low
P2743Trans Fluid Temp Sens B Circ Hi
P2744Trans Fluid Temp Sens B Circ Interm
P2745Intermediate Shaft Speed Sens B Circ
P2746Intermediate Shaft Speed Sens B Circ Range/Perf
P2747Intermediate Shaft Speed Sens B Circ No Signal
P2748Intermediate Shaft Speed Sens B Circ Interm
P2749Intermediate Shaft Speed Sens C Circ
P2750Intermediate Shaft Speed Sens C Circ Range/Perf
P2751Intermediate Shaft Speed Sens C Circ No Signal
P2752Intermediate Shaft Speed Sens C Circ Interm
P2753Trans Fluid Cooler Ctrl Circ/Open
P2754Trans Fluid Cooler Ctrl Circ Low
P2755Trans Fluid Cooler Ctrl Circ Hi
P2756Torque Conv Clutch Press Ctrl Solenoid
P2757Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
P2758Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
P2759Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
P2760Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ
P2761Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
P2762Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
P2763Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Hi
P2764Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
P2765Input/Turbine Speed Sens B Circ
P2766Input/Turbine Speed Sens B Circ Range/Perf
P2767Input/Turbine Speed Sens B Circ No Signal
P2768Input/Turbine Speed Sens B Circ Interm
P2769Torque Conv Clutch Circ Low
P2770Torque Conv Clutch Circ Hi
P2771Four Wheel Drive (4WD) Low Switch Circ
P2772Four Wheel Drive (4WD) Low Switch Circ Range/Perf
P2773Four Wheel Drive (4WD) Low Switch Circ Low
P2774Four Wheel Drive (4WD) Low Switch Circ Hi
P2775Upshift Switch Circ Range/Perf
P2776Upshift Switch Circ Low
P2777Upshift Switch Circ Hi
P2778Upshift Switch Circ Interm/Erratic
P2779Downshift Switch Circ Range/Perf
P2780Downshift Switch Circ Low
P2781Downshift Switch Circ Hi
P2782Downshift Switch Circ Interm/Erratic
P2783Torque Conv Temp Too Hi
P2784Input/Turbine Speed Sens A/B Correlation
P2785Clutch Actuator Temp Too Hi
P2786Gear Shift Actuator Temp Too Hi
P2787Clutch Temp Too Hi
P2788Auto Shift Manual Adaptive Learning at Limit
P2789Clutch Adaptive Learning at Limit
P2790Gate Select Direction Circ
P2791Gate Select Direction Circ Low
P2792Gate Select Direction Circ Hi
P2793Gear Shift Direction Circ
P2794Gear Shift Direction Circ Low
P2795Gear Shift Direction Circ Hi
P3400Cylinder Deactivation Sys Bank1
P3401Cylinder 1 Deactivation/Intake Valve Ctrl Circ/Open
P3402Cylinder 1 Deactivation/Intake Valve Ctrl Perf
P3403Cylinder 1 Deactivation/Intake Valve Ctrl Circ Low
P3404Cylinder 1 Deactivation/Intake Valve Ctrl Circ Hi
P3405Cylinder 1 Exhaust Valve Ctrl Circ/Open
P3406Cylinder 1 Exhaust Valve Ctrl Perf
P3407Cylinder 1 Exhaust Valve Ctrl Circ Low
P3408Cylinder 1 Exhaust Valve Ctrl Circ Hi
P3409Cylinder 2 Deactivation/Intake Valve Ctrl Circ/Open
P3410Cylinder 2 Deactivation/Intake Valve Ctrl Perf
P3411Cylinder 2 Deactivation/Intake Valve Ctrl Circ Low
P3412Cylinder 2 Deactivation/Intake Valve Ctrl Circ Hi
P3413Cylinder 2 Exhaust Valve Ctrl Circ/Open
P3414Cylinder 2 Exhaust Valve Ctrl Perf
P3415Cylinder 2 Exhaust Valve Ctrl Circ Low
P3416Cylinder 2 Exhaust Valve Ctrl Circ Hi
P3417Cylinder 3 Deactivation/Intake Valve Ctrl Circ/Open
P3418Cylinder 3 Deactivation/Intake Valve Ctrl Perf
P3419Cylinder 3 Deactivation/Intake Valve Ctrl Circ Low
P3420Cylinder 3 Deactivation/Intake Valve Ctrl Circ Hi
P3421Cylinder 3 Exhaust Valve Ctrl Circ/Open
P3422Cylinder 3 Exhaust Valve Ctrl Perf
P3423Cylinder 3 Exhaust Valve Ctrl Circ Low
P3424Cylinder 3 Exhaust Valve Ctrl Circ Hi
P3425Cylinder 4 Deactivation/Intake Valve Ctrl Circ/Open
P3426Cylinder 4 Deactivation/Intake Valve Ctrl Perf
P3427Cylinder 4 Deactivation/Intake Valve Ctrl Circ Low
P3428Cylinder 4 Deactivation/Intake Valve Ctrl Circ Hi
P3429Cylinder 4 Exhaust Valve Ctrl Circ/Open
P3430Cylinder 4 Exhaust Valve Ctrl Perf
P3431Cylinder 4 Exhaust Valve Ctrl Circ Low
P3432Cylinder 4 Exhaust Valve Ctrl Circ Hi
P3433Cylinder 5 Deactivation/Intake Valve Ctrl Circ/Open
P3434Cylinder 5 Deactivation/Intake Valve Ctrl Perf
P3435Cylinder 5 Deactivation/Intake Valve Ctrl Circ Low
P3436Cylinder 5 Deactivation/Intake Valve Ctrl Circ Hi
P3437Cylinder 5 Exhaust Valve Ctrl Circ/Open
P3438Cylinder 5 Exhaust Valve Ctrl Perf
P3439Cylinder 5 Exhaust Valve Ctrl Circ Low
P3440Cylinder 5 Exhaust Valve Ctrl Circ Hi
P3441Cylinder 6 Deactivation/Intake Valve Ctrl Circ/Open
P3442Cylinder 6 Deactivation/Intake Valve Ctrl Perf
P3443Cylinder 6 Deactivation/Intake Valve Ctrl Circ Low
P3444Cylinder 6 Deactivation/Intake Valve Ctrl Circ Hi
P3445Cylinder 6 Exhaust Valve Ctrl Circ/Open
P3446Cylinder 6 Exhaust Valve Ctrl Perf
P3447Cylinder 6 Exhaust Valve Ctrl Circ Low
P3448Cylinder 6 Exhaust Valve Ctrl Circ Hi
P3449Cylinder 7 Deactivation/Intake Valve Ctrl Circ/Open
P3450Cylinder 7 Deactivation/Intake Valve Ctrl Perf
P3451Cylinder 7 Deactivation/Intake Valve Ctrl Circ Low
P3452Cylinder 7 Deactivation/Intake Valve Ctrl Circ Hi
P3453Cylinder 7 Exhaust Valve Ctrl Circ/Open
P3454Cylinder 7 Exhaust Valve Ctrl Perf
P3455Cylinder 7 Exhaust Valve Ctrl Circ Low
P3456Cylinder 7 Exhaust Valve Ctrl Circ Hi
P3457Cylinder 8 Deactivation/Intake Valve Ctrl Circ/Open
P3458Cylinder 8 Deactivation/Intake Valve Ctrl Perf
P3459Cylinder 8 Deactivation/Intake Valve Ctrl Circ Low
P3460Cylinder 8 Deactivation/Intake Valve Ctrl Circ Hi
P3461Cylinder 8 Exhaust Valve Ctrl Circ/Open
P3462Cylinder 8 Exhaust Valve Ctrl Perf
P3463Cylinder 8 Exhaust Valve Ctrl Circ Low
P3464Cylinder 8 Exhaust Valve Ctrl Circ Hi
P3465Cylinder 9 Deactivation/Intake Valve Ctrl Circ/Open
P3466Cylinder 9 Deactivation/Intake Valve Ctrl Perf
P3467Cylinder 9 Deactivation/Intake Valve Ctrl Circ Low
P3468Cylinder 9 Deactivation/Intake Valve Ctrl Circ Hi
P3469Cylinder 9 Exhaust Valve Ctrl Circ/Open
P3470Cylinder 9 Exhaust Valve Ctrl Perf
P3471Cylinder 9 Exhaust Valve Ctrl Circ Low
P3472Cylinder 9 Exhaust Valve Ctrl Circ Hi
P3473Cylinder 10 Deactivation/Intake Valve Ctrl Circ/Open
P3474Cylinder 10 Deactivation/Intake Valve Ctrl Perf
P3475Cylinder 10 Deactivation/Intake Valve Ctrl Circ Low
P3476Cylinder 10 Deactivation/Intake Valve Ctrl Circ Hi
P3477Cylinder 10 Exhaust Valve Ctrl Circ/Open
P3478Cylinder 10 Exhaust Valve Ctrl Perf
P3479Cylinder 10 Exhaust Valve Ctrl Circ Low
P3480Cylinder 10 Exhaust Valve Ctrl Circ Hi
P3481Cylinder 11 Deactivation/Intake Valve Ctrl Circ/Open
P3482Cylinder 11 Deactivation/Intake Valve Ctrl Perf
P3483Cylinder 11 Deactivation/Intake Valve Ctrl Circ Low
P3484Cylinder 11 Deactivation/Intake Valve Ctrl Circ Hi
P3485Cylinder 11 Exhaust Valve Ctrl Circ/Open
P3486Cylinder 11 Exhaust Valve Ctrl Perf
P3487Cylinder 11 Exhaust Valve Ctrl Circ Low
P3488Cylinder 11 Exhaust Valve Ctrl Circ Hi
P3489Cylinder 12 Deactivation/Intake Valve Ctrl Circ/Open
P3490Cylinder 12 Deactivation/Intake Valve Ctrl Perf
P3491Cylinder 12 Deactivation/Intake Valve Ctrl Circ Low
P3492Cylinder 12 Deactivation/Intake Valve Ctrl Circ Hi
P3493Cylinder 12 Exhaust Valve Ctrl Circ/Open
U0001High Speed CAN Comm Bus
U0002High Speed CAN Comm Bus Perf
U0003High Speed CAN Comm Bus + Open
U0004High Speed CAN Comm Bus + Low
U0005High Speed CAN Comm Bus + High
U0006High Speed CAN Comm Bus - Open
U0007High Speed CAN Comm Bus - Low
U0008High Speed CAN Comm Bus - High
U0009High Speed CAN Comm Bus - shorted to Bus +
U0010Medium Speed CAN Comm Bus
U0011Medium Speed CAN Comm Bus Perf
U0012Medium Speed CAN Comm Bus + Open
U0013Medium Speed CAN Comm Bus + Low
U0014Medium Speed CAN Comm Bus + High
U0015Medium Speed CAN Comm Bus - Open
U0016Medium Speed CAN Comm Bus - Low
U0017Medium Speed CAN Comm Bus - High
U0018Medium Speed CAN Comm Bus - shorted to Bus +
U0019Low Speed CAN Comm Bus
U0020Low Speed CAN Comm Bus Perf
U0021Low Speed CAN Comm Bus + Open
U0022Low Speed CAN Comm Bus + Low
U0023Low Speed CAN Comm Bus + High
U0024Low Speed CAN Comm Bus - Open
U0025Low Speed CAN Comm Bus - Low
U0026Low Speed CAN Comm Bus - High
U0027Low Speed CAN Comm Bus - shorted to Bus +
U0028Vehicle Comm Bus A
U0029Vehicle Comm Bus A Perf
U0030Vehicle Comm Bus A + Open
U0031Vehicle Comm Bus A + Low
U0032Vehicle Comm Bus A + High
U0033Vehicle Comm Bus A - Open
U0034Vehicle Comm Bus A - Low
U0035Vehicle Comm Bus A - High
U0036Vehicle Comm Bus A - shorted to Bus A +
U0037Vehicle Comm Bus B
U0038Vehicle Comm Bus B Perf
U0039Vehicle Comm Bus B + Open
U0040Vehicle Comm Bus B + Low
U0041Vehicle Comm Bus B + High
U0042Vehicle Comm Bus B - Open
U0043Vehicle Comm Bus B - Low
U0044Vehicle Comm Bus B - High
U0045Vehicle Comm Bus B - shorted to Bus B +
U0046Vehicle Comm Bus C
U0047Vehicle Comm Bus C Perf
U0048Vehicle Comm Bus C + Open
U0049Vehicle Comm Bus C + Low
U0050Vehicle Comm Bus C + High
U0051Vehicle Comm Bus C - Open
U0052Vehicle Comm Bus C - Low
U0053Vehicle Comm Bus C - High
U0054Vehicle Comm Bus C - shorted to Bus C +
U0055Vehicle Comm Bus D
U0056Vehicle Comm Bus D Perf
U0057Vehicle Comm Bus D + Open
U0058Vehicle Comm Bus D + Low
U0059Vehicle Comm Bus D + High
U0060Vehicle Comm Bus D - Open
U0061Vehicle Comm Bus D - Low
U0062Vehicle Comm Bus D - High
U0063Vehicle Comm Bus D - shorted to Bus D +
U0064Vehicle Comm Bus E
U0065Vehicle Comm Bus E Perf
U0066Vehicle Comm Bus E + Open
U0067Vehicle Comm Bus E + Low
U0068Vehicle Comm Bus E + High
U0069Vehicle Comm Bus E - Open
U0070Vehicle Comm Bus E - Low
U0071Vehicle Comm Bus E - High
U0072Vehicle Comm Bus E - shorted to Bus E +
U0073Ctrl Mod Comm Bus Off
U0074Reserved by Document
U0075Reserved by Document
U0076Reserved by Document
U0077Reserved by Document
U0078Reserved by Document
U0079Reserved by Document
U0080Reserved by Document
U0081Reserved by Document
U0082Reserved by Document
U0083Reserved by Document
U0084Reserved by Document
U0085Reserved by Document
U0086Reserved by Document
U0087Reserved by Document
U0088Reserved by Document
U0089Reserved by Document
U0090Reserved by Document
U0091Reserved by Document
U0092Reserved by Document
U0093Reserved by Document
U0094Reserved by Document
U0095Reserved by Document
U0096Reserved by Document
U0097Reserved by Document
U0098Reserved by Document
U0099Reserved by Document
U0100Lost Comm With ECM/PCM A
U0101Lost Comm with TCM
U0102Lost Comm with Transfer Case Ctrl Mod
U0103Lost Comm With Gear Shift Mod
U0104Lost Comm With Cruise Ctrl Mod
U0105Lost Comm With Fuel Injector Ctrl Mod
U0106Lost Comm With Glow Plug Ctrl Mod
U0107Lost Comm With Throttle Actuator Ctrl Mod
U0108Lost Comm With Alternative Fuel Ctrl Mod
U0109Lost Comm With Fuel Pump Ctrl Mod
U0110Lost Comm With Drive Motor Ctrl Mod
U0111Lost Comm With Battery Energy Ctrl Mod A
U0112Lost Comm With Battery Energy Ctrl Mod B
U0113Lost Comm With Emissions Critical Ctrl Information
U0114Lost Comm With 4-Wheel Drive Clutch Ctrl Mod
U0115Lost Comm With ECM/PCM B
U0116Reserved by Document
U0117Reserved by Document
U0118Reserved by Document
U0119Reserved by Document
U0120Reserved by Document
U0121Lost Comm With Anti-Lock Brake System (ABS) Ctrl Mod
U0122Lost Comm With Vehicle Dynamics Ctrl Mod
U0123Lost Comm With Yaw Rate Sens Mod
U0124Lost Comm With Lateral Acceleration Sens Mod
U0125Lost Comm With Multi-axis Acceleration Sens Mod
U0126Lost Comm With Steering Angle Sens Mod
U0127Lost Comm With Tire Pressure Monitor Mod
U0128Lost Comm With Park Brake Ctrl Mod
U0129Lost Comm With Brake System Ctrl Mod
U0130Lost Comm With Steering Effort Ctrl Mod
U0131Lost Comm With Power Steering Ctrl Mod
U0132Lost Comm With Ride Level Ctrl Mod
U0133Reserved by Document
U0134Reserved by Document
U0135Reserved by Document
U0136Reserved by Document
U0137Reserved by Document
U0138Reserved by Document
U0139Reserved by Document
U0140Lost Comm With Body Ctrl Mod
U0141Lost Comm With Body Ctrl Mod A
U0142Lost Comm With Body Ctrl Mod B
U0143Lost Comm With Body Ctrl Mod C
U0144Lost Comm With Body Ctrl Mod D
U0145Lost Comm With Body Ctrl Mod E
U0146Lost Comm With Gateway A
U0147Lost Comm With Gateway B
U0148Lost Comm With Gateway C
U0149Lost Comm With Gateway D
U0150Lost Comm With Gateway E
U0151Lost Comm With Restraints Ctrl Mod
U0152Lost Comm With Side Restraints Ctrl Mod Left
U0153Lost Comm With Side Restraints Ctrl Mod Right
U0154Lost Comm With Restraints Occupant Sensing Ctrl Mod
U0155Lost Comm With Instrument Panel Cluster (IPC) Ctrl Mod
U0156Lost Comm With Information Center A
U0157Lost Comm With Information Center B
U0158Lost Comm With Head Up Display
U0159Lost Comm With Parking Assist Ctrl Mod
U0160Lost Comm With Audible Alert Ctrl Mod
U0161Lost Comm With Compass Mod
U0162Lost Comm With Navigation Display Mod
U0163Lost Comm With Navigation Ctrl Mod
U0164Lost Comm With HVAC Ctrl Mod
U0165Lost Comm With HVAC Ctrl Mod Rear
U0166Lost Comm With Auxiliary Heater Ctrl Mod
U0167Lost Comm With Vehicle Immobilizer Ctrl Mod
U0168Lost Comm With Vehicle Security Ctrl Mod
U0169Lost Comm With Sunroof Ctrl Mod
U0170Lost Comm With Restraints System Sens A
U0171Lost Comm With Restraints System Sens B
U0172Lost Comm With Restraints System Sens C
U0173Lost Comm With Restraints System Sens D
U0174Lost Comm With Restraints System Sens E
U0175Lost Comm With Restraints System Sens F
U0176Lost Comm With Restraints System Sens G
U0177Lost Comm With Restraints System Sens H
U0178Lost Comm With Restraints System Sens I
U0179Lost Comm With Restraints System Sens J
U0180Lost Comm With Automatic Lighting Ctrl Mod
U0181Lost Comm With Headlamp Leveling Ctrl Mod
U0182Lost Comm With Lighting Ctrl Mod Front
U0183Lost Comm With Lighting Ctrl Mod Rear
U0184Lost Comm With Radio
U0185Lost Comm With Antenna Ctrl Mod
U0186Lost Comm With Audio Amplifier
U0187Lost Comm With Digital Disc Player/Changer Mod A
U0188Lost Comm With Digital Disc Player/Changer Mod B
U0189Lost Comm With Digital Disc Player/Changer Mod C
U0190Lost Comm With Digital Disc Player/Changer Mod D
U0191Lost Comm With Television
U0192Lost Comm With Personal Computer
U0193Lost Comm With Digital Audio Ctrl Mod A
U0194Lost Comm With Digital Audio Ctrl Mod B
U0195Lost Comm With Subscription Entertainment Receiver Mod
U0196Lost Comm With Rear Seat Entertainment Ctrl Mod
U0197Lost Comm With Telephone Ctrl Mod
U0198Lost Comm With Telematic Ctrl Mod
U0199Lost Comm With Door Ctrl Mod A
U0200Lost Comm With Door Ctrl Mod B
U0201Lost Comm With Door Ctrl Mod C
U0202Lost Comm With Door Ctrl Mod D
U0203Lost Comm With Door Ctrl Mod E
U0204Lost Comm With Door Ctrl Mod F
U0205Lost Comm With Door Ctrl Mod G
U0206Lost Comm With Folding Top Ctrl Mod
U0207Lost Comm With Moveable Roof Ctrl Mod
U0208Lost Comm With Seat Ctrl Mod A
U0209Lost Comm With Seat Ctrl Mod B
U0210Lost Comm With Seat Ctrl Mod C
U0211Lost Comm With Seat Ctrl Mod D
U0212Lost Comm With Steering Column Ctrl Mod
U0213Lost Comm With Mirror Ctrl Mod
U0214Lost Comm With Remote Function Actuation
U0215Lost Comm With Door Switch A
U0216Lost Comm With Door Switch B
U0217Lost Comm With Door Switch C
U0218Lost Comm With Door Switch D
U0219Lost Comm With Door Switch E
U0220Lost Comm With Door Switch F
U0221Lost Comm With Door Switch G
U0222Lost Comm With Door Window Motor A
U0223Lost Comm With Door Window Motor B
U0224Lost Comm With Door Window Motor C
U0225Lost Comm With Door Window Motor D
U0226Lost Comm With Door Window Motor E
U0227Lost Comm With Door Window Motor F
U0228Lost Comm With Door Window Motor G
U0229Lost Comm With Heated Steering Wheel Mod
U0230Lost Comm With Rear Gate Mod
U0231Lost Comm With Rain Sensing Mod
U0232Lost Comm With Side Obstacle Detect Ctrl Mod Left
U0233Lost Comm With Side Obstacle Detect Ctrl Mod Right
U0234Lost Comm With Convenience Recall Mod
U0235Lost Comm With Cruise Ctrl Front Distance Range Sens
U0300Internal Ctrl Mod Software Incompatibility
U0301Software Incompatibility with ECM/PCM
U0302Software Incompatibility with Trans Ctrl Mod
U0303Software Incompatibility with Transfer Case Ctrl Mod
U0304Software Incompatibility with Gear Shift Ctrl Mod
U0305Software Incompatibility with Cruise Ctrl Mod
U0306Software Incompatibility with Fuel Injector Ctrl Mod
U0307Software Incompatibility with Glow Plug Ctrl Mod
U0308Software Incompatibility with Throttle Actuator Ctrl Mod
U0309Software Incompatibility with Alternative Fuel Ctrl Mod
U0310Software Incompatibility with Fuel Pump Ctrl Mod
U0311Software Incompatibility with Drive Motor Ctrl Mod
U0312Software Incompatibility with Battery Energy Ctrl Mod A
U0313Software Incompatibility with Battery Energy Ctrl Mod B
U0314Software Incompatibility with 4-Wheel Drive Clutch Ctrl Mod
U0315Software Incompatibility with Anti-Lock Brake System Ctrl Mod
U0316Software Incompatibility with Vehicle Dynamics Ctrl Mod
U0317Software Incompatibility with Park Brake Ctrl Mod
U0318Software Incompatibility with Brake System Ctrl Mod
U0319Software Incompatibility with Steering Effort Ctrl Mod
U0320Software Incompatibility with Power Steering Ctrl Mod
U0321Software Incompatibility with Ride Level Ctrl Mod
U0322Software Incompatibility with Body Ctrl Mod
U0323Software Incompatibility with Instrument Panel Ctrl Mod
U0324Software Incompatibility with HVAC Ctrl Mod
U0325Software Incompatibility with Auxiliary Heater Ctrl Mod
U0326Software Incompatibility with Vehicle Immobilizer Ctrl Mod
U0327Software Incompatibility with Vehicle Security Ctrl Mod
U0328Software Incompatibility with Steering Angle Sens Mod
U0329Software Incompatibility with Steering Column Ctrl Mod
U0330Software Incompatibility with Tire Pressure Monitor Mod
U0331Software Incompatibility with Body Ctrl Mod A
U0400Invalid Data Rcvd
U0401Invalid Data Rcvd From ECM/PCM
U0402Invalid Data Rcvd From Trans Ctrl Mod
U0403Invalid Data Rcvd From Transfer Case Ctrl Mod
U0404Invalid Data Rcvd From Gear Shift Ctrl Mod
U0405Invalid Data Rcvd From Cruise Ctrl Mod
U0406Invalid Data Rcvd From Fuel Injector Ctrl Mod
U0407Invalid Data Rcvd From Glow Plug Ctrl Mod
U0408Invalid Data Rcvd From Throttle Actuator Ctrl Mod
U0409Invalid Data Rcvd From Alternative Fuel Ctrl Mod
U0410Invalid Data Rcvd From Fuel Pump Ctrl Mod
U0411Invalid Data Rcvd From Drive Motor Ctrl Mod
U0412Invalid Data Rcvd From Battery Energy Ctrl Mod A
U0413Invalid Data Rcvd From Battery Energy Ctrl Mod B
U0414Invalid Data Rcvd From 4-Wheel Drive Clutch Ctrl Mod
U0415Invalid Data Rcvd From Anti-Lock Brake System Ctrl Mod
U0416Invalid Data Rcvd From Vehicle Dynamics Ctrl Mod
U0417Invalid Data Rcvd From Park Brake Ctrl Mod
U0418Invalid Data Rcvd From Brake System Ctrl Mod
U0419Invalid Data Rcvd From Steering Effort Ctrl Mod
U0420Invalid Data Rcvd From Power Steering Ctrl Mod
U0421Invalid Data Rcvd From Ride Level Ctrl Mod
U0422Invalid Data Rcvd From Body Ctrl Mod
U0423Invalid Data Rcvd From Instrument Panel Ctrl Mod
U0424Invalid Data Rcvd From HVAC Ctrl Mod
U0425Invalid Data Rcvd From Auxiliary Heater Ctrl Mod
U0426Invalid Data Rcvd From Vehicle Immobilizer Ctrl Mod
U0427Invalid Data Rcvd From Vehicle Security Ctrl Mod
U0428Invalid Data Rcvd From Steering Angle Sens Mod
U0429Invalid Data Rcvd From Steering Column Ctrl Mod
U0430Invalid Data Rcvd From Tire Pressure Monitor Mod
U0431Invalid Data Rcvd From Body Ctrl Mod A High
BMW
P1083Fuel control limit mixture too lean (bank 1 sensor1)
P1084Fuel control limit mixture too rich (bank 1 sensor1)
P1085Fuel control limit mixture too lean (bank 2 sensor1)
P1086Fuel control limit mixture too rich (bank 2 sensor1)
P108702 sensor circuit slow response in lean control range (bank 1 sensor1)
P108802 sensor circuit slow response in rich control range (bank 1 sensor1)
P108902 sensor circuit slow response in lean control range (bank 1 sensor2)
P1090Pre catalyst fuel trim system too lean bank 1
P1091Pre catalyst fuel trim system too rich bank 1
P1092Pre catalyst fuel trim system too lean bank 2
P1093Pre catalyst fuel trim system too rich bank 2
P109402 sensor circuit slow response in rich control range (bank 2sensor1)
P109502 sensor signal circuit slow switching from lean to rich (bank1 sensor1)
P109602 sensor signal circuit slow switching from lean to rich (bank2 sensor1)
P109702 sensor circuit slow response after coast down fuel cut-off (bank 1 sensor 2)
P109802 sensor circuit slow response after coast down fuel cut-off (bank 2 sensor 2)
P1111Engine coolant temperature radiator outlet sensor low input
P1112Engine coolant temperature radiator outlet sensor high input
P1115Coolant temperature sensor plausibility
P1116Mass or volume air flow circuit range/performance problem (bank 2)
P1117Mass or volume air flow circuit low input (bank 2)
P1118Mass or volume air flow circuit high input (bank 2)
P1120Pedal position sensor circuit
P1121Pedal position sensor 1 range/performance problem
P1122Pedal position sensor 1 low input
P1123Pedal position sensor 1 high input
P113202 sensor heater control circuit (bank1 sensor 1)
P113302 sensor heater control circuit (bank2 sensor 1)
P113402 sensor heater circiut signal intermittent (bank1 sensor1)
P113502 sensor heater circiut low voltage (bank1 sensor1)
P113602 sensor heater circiut high voltage (bank1 sensor1)
P113702 sensor heater circiut signal intermittent (bank1 sensor2)
P113802 Sensor heater circiut low voltage (bank1 sensor2)
P113902 sensor heater circiut high voltage (bank1 sensor2)
P1140Mass or volume air flow circuit range / performance problem
P1145Solenoid valve running losses conrtol circuit electrical
P115102 sensor heater circuit signal intermittent (bank 2 sensor 1)
P115202 sensor heater circuit low voltage (bank 2 sensor 1)
P115302 sensor heater circuit high voltage (bank 2 sensor 1)
P115502 sensor heater circuit signal intermittent (bank 2 sensor 2)
P115602 sensor heater circuit low voltage (bank 2 sensor 2)
P115702 sensor heater circuit high voltage (bank 2 sensor 2)
P1158Fuel trim adaptation additive bank 1 low
P1159Fuel trim adaptation additive bank 1 high
P1160Fuel trim adaptation additive bank 2 low
P1161Fuel trim adaptation additive bank 2 high M52: Engine oil temperature sensor circuit
P1162Fuel trim adaptation additive per ignition bank 1 low
P1163Fuel trim adaptation additive per ignition bank 1 high
P1164Fuel trim adaptation additive per ignition bank 2 low
P1165Fuel trim adaptation additive per ignition bank 2 high
P1174Fuel trim adaptation additive bank 1 malfunction
P1175Fuel trim adaptation additive bank 2 malfunction
P117602 sensor slow response bank 1
P117702 sensor slow response bank 2
P117802 sensor signal circuit slow switching from rich to lean (bank 1 sensor 1)
P117902 sensor signal circuit slow switching from rich to lean (bank 2 sensor 1)
P118002 sensor signal circuit slow switching from rich to lean (bank 1 sensor 2)
P118102 sensor signal circuit slow switching from rich to lean (bank 2sensor 2)
P118202 sensor (bank 1 sensor 2) open circuit during coast sown fuel cut-off
P118302 sensor (bank 2 sensor 2) open circuit during coast down fuel cut-off
P118602 sensor heater control circuit (bank 1 sensor 2)
P118702 sensor heater control circuit (bank 2 sensor 2)
P1188Fuel control (bank 1 sensor 1)
P1189Fuel control (bank 2 sensor 1)
P1190Pre catalyst fuel trim system bank 1
P1191Pre catalyst fuel trim system bank 2
P1192Post catalyst fuel trim system bank 1
P1193Post catalyst fuel trim system bank 2
P1221Pedal position sensor 2 range / performance problem
P1222Pedal position sensor 2 low input
P1223Pedal position sensor 2 high input
P1270control module self-test, torque monitoring M73: Mass air flow sensor bank comparison plausibility
P1271Ambient air pressure sensor electrical
P1283Switching solenoid for air assisted injection valves bank 1 control circuit electrical
P1284Switching solenoid for air assisted injection valves bank 1 control circuit signal low
P1285Switching solenoid for air assisted injection valves bank 1 control circuit signal high
P1287Switching solenoid for air assisted injection valves bank 2 control circuit electrical
P1288Switching solenoid for air assisted injection valves bank 2 control circuit signal low
P1289Switching solenoid for air assisted injection valves bank 2 control circuit signal high
P1313'A' Camshaft position actuator plausibility
P1317'B' Camshaft position actuator plausibility
P1327Knock sensor 2 (bank 1) low input
P1328Knock sensor 2 (bank 1) high input
P1332Knock sensor 4 low input
P1333Knock sensor 4 high input
P1340Multiple cylinder misfire during start
P1341Multiple cylinder misfire with fuel cut-off
P1342Misfire during start cylinder 1
P1343Misfire cylinder 1 with fuel cut-off
P1344Misfire during start cylinder 2
P1345Misfire cylinder 2 with fuel cut-off
P1346Misfire during start cylinder 3
P1347Misfire cylinder 3 with fuel cut-off
P1348Misfire during start cylinder 4
P1349Misfire cylinder 4 fuel cut-off
P1350Misfire during start cylinder 5
P1351Misfire cylinder 5 with fuel cut-off
P1352Misfire during start cylinder 6
P1353Misfire cylinder 6 with fuel cut-off
P1354Misfire during start cylinder 7
P1355Misfire cylinder 7 with fuel cut-off
P1356Misfire during start cylinder 8
P1357Misfire cylinder 8 with fuel cut-off
P1358Misfire during start cylinder 9
P1359Misfire cylinder 9 with fuel cut-off
P1360Misfire during start cylinder 10
P1361Misfire cylinder 10 with fuel cut-off
P1362Misfire during start cylinder 11
P1363Misfire cylinder 11 with fuel cut-off
P1364Misfire during start cylinder 12
P1365Misfire cylinder 12 with fuel cut-off
P1384Knock sensor 3 circuit
P1385Knock sensor 4 circuit
P1386Control module self-test, knock control circuit baseline test bank 1
P1396Crankshaft position sensor segment timing plausibility
P1397Camshaft position sensor 'B' circuit (bank 1)
P1400Heated catalyst battery voltage or current too low during heating (bank 1)
P1401Heated catalyst current too high during heating (bank 1)
P1402Heated catalyst power switch over temperature condition (bank 1)
P1403Carbon canister shut-off valve control circuit electrical - or- M73: heated catalyst battery voltage of current too low during heating (bank 2)
P1404Heated catalyst current too high during heating (bank 2)
P1405Heated catalyst power switch over temperature condition (bank 2)
P1406Heated catalyst internal control module checksum / ROM error
P1413Secondary air injection pump relay control circuit signal low
P1414Secondary air injection pump relay control circuit signal high
P1420Secondary air valve control circuit electrical
P1421Secondary air system bank 2
P1423Secondary air system bank 1
P1432Secondary air injection system incorrect flow detected
P1438Purge control valve control open circuit
P1439Purge control valve control circuit signal low
P1440Purge control valve control circuit signal high
P1441Leakage diagnostic pump control open circuit
P1442Leakage diagnostic pump control circuit signal low
P1443Leakage diagnostic pump control circuit signal high
P1444Diagnostic module tank leakage (DM-TL) pump control open circuit
P1445Diagnostic module tank leakage (DM-TL) pump control circuit signal low
P1446Diagnostic module tank leakage (DM-TL) pump control circuit signal high
P1447Diagnostic module tank leakage (DM-TL) pump current too high during switching solenoid test
P1448Diagnostic module tank leakage (DM-TL) pump current too low during switching solenoid test
P1449Diagnostic module tank leakage (DM-TL) pump current too high (during switching solenoid test)
P1450Diagnostic module tank leakage (DM-TL) switching solenoid control open circuit
P1451Diagnostic module tank leakage (DM-TL) switching solenoid control circuit signal low
P1452Diagnostic module tank leakage (DM-TL) switching solenoid control circuit signal high
P1453Secondary air injection pump relay control circuit electrical
P1454Secondary air injection pump with series resistor control circuit electrical
P1456Heated catalyst heater power supply open circuit (bank 1)
P1457Heated catalyst power switch temperature sensor electrical (bank 1)
P1459Heated catalyst heater power supply open circuit (bank 2)
P1460Heated catalyst power switch temperature sensor electrical (bank 2)
P1461Heated catalyst gate voltage signal low
P1462Heated catalyst internal control module checksum / EEPROM error
P1463Heated catalyst battery temperature sensor 1 electrical
P1464Heated catalyst battery temperature sensor 2 electrical
P1465Heated catalyst battery temperature sensor 1 or 2 plausibility
P1466Heated catalyst power switch temperature sensor plausibility
P1467Heated catalyst comparison battery voltages of power switches plausibility
P1468Heated catalyst battery disconnecting switch plausibility
P1470Leakage diagnostic pump control circuit electrical
P1472Diagnostic module tank leakage (DM-TL) switching solenoid control circuit electrical
P1473Diagnostic module tank leakage (DM-TL) pump current plausibility
P1475Leakage diagnostic pump reed switch did not close
P1476Leakage diagnostic pump clamped tube -or- M52 MY99/00: Leakage diagnostic pump reed switch circuit electrical
P1477Leakage diagnostic pump reed switch did not open
P1500Idle-speed control valve stuck open
P1501Idle-speed control valve stuck closed
P1502Idle-speed control valve closing solenoid control circuit signal high
P1503Idle-speed control valve closing solenoid control circuit signal low
P1504Idle-speed control valve closing solenoid control open circuit
P1505Idle-speed control valve closing solenoid control circuit electrical
P1506Idle-speed control valve opening solenoid control circuit signal high
P1507Idle-speed control valve opening solenoid control circuit signal low
P1508Idle-speed control valve opening solenoid control open circuit
P1509Idle-speed control valve opening solenoid control circuit electrical
P1510Idle-speed control valve stuck
P1511DISA (differentiated intake manifold) control circuit electrical
P1512DISA (differentiated intake manifold) control circuit signal low
P1513DISA (differentiated intake manifold) control circuit signal high
P1519'A' camshaft position actuator bank 1
P1520'B' camshaft position actuator bank 1
P1522'A' camshaft position actuator bank 2
P1523'A' camshaft position actuator signal low bang 1 -or- M52: Camshaft position actuator tight or jammed
P1524'A' camshaft position actuator control circuit signal high bank 1
P1525'A' camshaft position actuator control open circuit bank 1
P1526'A' camshaft position actuator control open circuit bank 2
P1527'A' camshaft position actuator control circuit signal low bank 2
P1528'A' camshaft position actuator control circuit signal high bank 2
P1529'B' camshaft position actuator control circuit signal low bank1
P1530'B' camshaft position actuator control circuit signal high bank1
P1531'B' camshaft position actuator control open circuit bank 1
P1532'B' camshaft position actuator control open circuit bank 2
P1533'B' camshaft position actuator control circuit signal low bank 2
P1534'B' camshaft position actuator control circuit signal high bank 2
P1540Pedal position sensor
P1541Pedal position sensor double error
P1542Pedal position sensor electrical
P1543Pedal position sensor
P1544Pedal position sensor
P1545Pedal position sensor
P1546Pedal position sensor
P1550Idle-speed control valve closing solenoid control circuit electrical
P1552"A" Camshaft position actuator control open circuit bank 1
P1556'A' Camshaft position actuator control open circuit bank 1
P1560'B' Camshaft position actuator control open circuit bank 1
P1564Control module selection
P1565'B' Camshaft position actuator control open circuit bank 1
P1569'A' Camshaft position actuator control open circuit bank 2
P1573Electronic control module sensor supply B low output -or- S54/S62: 'A' Camshaft position actuator control circuit signal low bank 2
P1580Throttle valve mechanically stuck
P1581'B' Camshaft position actuator control open circuit bank 2
P1589Control module self-test, knock control test pulse bank 1
P1593DISA (Differentiated intake manifold ) control circuit electrical
P1594'B' Camshaft position actuator control open circuit bank 2
P1602Control module self-test, control module defective
P1603Control module self-test, torque monitoring
P1604Control module self-test, sqeed monitoring
P1607CAN-Version
P1608Serial communication link control module
P1609Serial communication link EML (electronically engine-power regulation)
P1611Serial communication link transmission control module
P1619Map cooling thermostat control circuit signal low
P1620Map cooling thermostat control circuit signal high
P1622Map cooling thermostat control circuit electrical
P1623Pedal position sensor potentiometer supply
P1624Pedal position sensor potentiometer supply channel 1 electrical -or- M52: coolant thermostat (coolant temperature below thermostat regulating temperature)
P1625Pedal position sensor potentiometer supply channel 2 electrical
P1632Throttle valve adaptation; Adaptation conditions not met
P1633Throttle valve adaptation; Limp-home position unknown
P1634Throttle valve adaptation; Spring test failed
P1635Throttle valve adaptation; Lower mechanical stop not adapted
P1636Throttle valve control circuit
P1637Throttle valve position control; Control deviation
P1638Throttle valve position control; Throttle stuck temporarily
P1639Throttle valve position control; Throttle stuck permanently
P1640Internal control module (ROM/RAM) error
P1690Malfunction indicator lamp (MIL) electrical
P1734Pressure control solenoid 'B' electrical
P1738Pressure control solenoid 'C' electrical
P1743Pressure control solenoid 'E' electrical -or- M44/M52: Brake band electrical
P1744Pressure control solenoid 'A' electrical
P1746Transmission control module output stage
P1747CAN-Bus monitoring
P1748Transmission control module self-test
P1749Secondary pressure solenoid communication error -or- M52: Transmission control module internal memory
P1750Secondary pressure solenoid circuit range / performance -or- M44 / M52 / M62 / M73: System voltage input low
P1751Secondary pressure solenoid open circuit -or- M52: System voltage input high
P1761Shift lock solenoid malfunction
P1765CAN throttle valve
P1770CAN torque interface
P1780CAN torque reduction
CHR
P1000Ignition Circ Low
P1001Ignition Circ Hi
P1004ECU Battery Feed & Power Grounds
P1005Sys Ground Circ
P1006EGR/EVAP Solenoid Circ Low
P1007EGR/EVAP Solenoid Circ Hi
P1008Power Steering Circ Low
P1009Power Steering Circ Hi
P1012MPA Circ Low
P1013MPA Circ Hi
P1014Fuel Pump Circ Low
P1015Fuel Pump Circ Hi
P1016Charge Air Temp Circ Low
P1017Charge Air Temp Circ Hi
P1018Serial Data Circ
P1019Power Latch Not Set
P1021Engine Failed To Start Due To Mechanical, Fuel or Ignition Conditions
P1022Starter Relay Circ Low
P1024ECU Start Circ Low
P1025WOT Circ Low
P1026WOT Circ Hi
P1027ECU Sees Wide Open Throttle
P1028ECU Does Not See Wide Open Throttle
P1029ISA Closed Throttle Circ Low
P1030ISA Closed Throttle Circ Hi
P1031ECU Sees Closed Throttle
P1032ECU Does Not See Closed Throttle
P1033ISA Circs
P1037TP Sens Circ Reads Low
P1038Park/Neutral Line Hi
P1039Park/Neutral Line Low
P1040Latched B+ Line Low
P1041Latched B+ Line Hi
P1042No Latched B+ 1/2 Volt Drop
P1043Shift Lamp Circ Grounded
P1044D2ЁC1 Circ Low (A/T) or Upshift Lamp Circ (M/T) or Shift Lamp Circ Hi
P1045Shift Lamp Circ Open
P1047Wrong ECU
P1048M/T Vehicle Configuration
P1049A/T Vehicle Configuration
P1050Idle RPM Low
P1051Idle RPM Hi
P1052MAP Sens Out Of Limits
P1053Change In MAP Reading Out Of Limits
P1054Coolant Sens & 5V Supply for TP Sens/MAP Circs Low
P1055Coolant Sens Circ Hi
P1056Inactive Coolant Temp Sens
P1059A/C Request Circ Low
P1060A/C Request Circ Hi
P1061A/C Select Circ Low
P1062A/C Select Circ Hi
P1063A/C Clutch Circ Low
P1064A/C Clutch Circ Hi & Power Steering Input
P1068Latch Relay Circ Hi
P1069No Tach
P1074ECU Does Not See Speed Sens
P1105Open or shorted condition detected in the baro read solenoid control circuit
P1106MAP Sens Circ Interm Hi Voltage
P1107MAP Sens Circ Interm Low Voltage
P1110Decreased Engine Perf Due To Hi Intake Air Temp
P1111IAT Sens Circ Interm Hi Voltage
P1112IAT Sens Circ Interm Low Voltage
P1114ECT Sens Circ Interm Low Voltage
P1115ECT Sens Circ Interm Hi Voltage
P1121TPS Circ Interm Hi Voltage
P1122TPS Circ Interm Low Voltage
P1125Accelerator Pedal Pos Sys
P1133HO2S Insufficient Switching Bank1 Sens1
P1134HO2S Insufficient Transition Time Ratio Bank1 Sens1
P1153HO2S Insufficient Switching Bank2 Sens1
P1154HO2S Insufficient Transition Time Ratio Bank2 Sens 1
P1180Decreased Engine Perf Due To Hi Inj Pump Fuel Temp
P1191Intake Air Duct Leak
P1192Inlet Air Temp Sens Voltage Low
P1193Inlet Air Temp Voltage Hi
P119402 Heater Perf
P11951/1 02 Sens Slow During Catalyst Monitor
P11962/1 02 Sens Slow During Catalyst Monitor
P11971/2 02 Sens Slow During Catalyst Monitor
P1198Radiator Temp Sens Volts Too Hi
P1199Radiator Temp Sens Volts Too Low
P1214Inj Pump Timing Offset
P1216Fuel Solenoid Response Time Too Short
P1217Fuel Solenoid Response Time Too Long
P1218Inj Pump Calibration Circ
P1243Open or shorted condition detected in the turbocharger surge valve solenoid control
P1271Accelerator Pedal Pos Sens1-2 Correlation
P1272Accelerator Pedal Pos Sens2-3 Correlation
P1273Accelerator Pedal Pos Sens1-3 Correlation
P1275Accelerator Pedal Pos Sens1 Circ
P1277Accelerator Pedal Pos Sens1 Low Voltage
P1278Accelerator Pedal Pos Sens1 Hi Voltage
P1280Accelerator Pedal Pos Sens2 Circ
P1281Engine is Cold Too Long
P1282Accelerator Pedal Pos Sens2 Low Voltage or Fuel Pump Relay Ctrl Circ
P1283Accelerator Pedal Pos Sens2 Hi Voltage or Idle Select Signal Invalid
P1284Fuel Inj Pump Battery Voltage Out Of Range
P1285Accelerator Pedal Pos Sens3 Circ or Fuel Inj Pump Ctrller Always On
P1286Accelerator Pos Sens Supply Voltage Too Hi
P1287Accelerator Pedal Pos Sens3 Low Voltage or Fuel Inj Pump Ctrl Supply Voltage Low
P1288Accelerator Pedal Pos Sens3 Hi Voltage or Intake Manif Short Runner Solenoid Circ
P1289Manif Tune Valve Solenoid Circ
P1290CNG Fuel Sys Press Too Hi
P1291No Temp Rise Seen From Intake Heaters
P1292CNG Press Sens Voltage Too Hi
P1293CNG Press Sens Voltage Too Low
P1294Target Idle Not Reached
P1295No 5Vs to Throttle Pos Sens
P1296No 5Vs to MAP Sens
P1297No Change in MAP from Start To Run
P1298Lean Operation at Wide Open Throttle
P1299Vacuum Leak Found (IAC Fully Seated)
P1336Crank Pos Sys Variation Not Learned
P1345Crank Pos/Camshaft Pos Correlation
P1351Ignition Ctrl Circ Hi Voltage
P1361Ignition Ctrl Circ Low Voltage
P1380Electronic Brake Ctrl Rough Road Data Unusable
P1381Misfire Detected-No Electronic Brake Ctrl Data
P1388Auto Shutdown Relay Ctrl Circ
P1389No ASD Relay Output Voltage at PCM
P1390Timing Belt Skipped 1 Tooth or More
P1391Interm Loss of CMP or CKP
P1398Misfire Adaptive Numerator at Limit
P1399Wait to Start Lamp Circ
P1403No 5Vs to EGR Sens
P1404EGR Valve Closed Pintle Pos
P1406EGR Valve Pos
P1409EGR Valve Sys leak
P1415AIR Sys Bank1
P1416AIR Sys Bank1
P1441Evap Emissions Flow During Non-Purge
P1475Auxiliary 5V Supply Voltage Hi
P1476Too Little Sec Air
P1477Too Much Sec Air
P1478Battery Temp Sens Volts Out of Limit
P1479Trans Fan Relay Circ
P1480PCV Solenoid Circ
P1481EATX Misfire RPM Signal out of Range
P1482Catalyst Temp Sens Circ Shorted Low
P1483Catalyst Temp Sens Circ Shorted Hi
P1484Catalytic Conv Overheat Detected
P1485Air Inj Solenoid Circ
P1486Eva Leak Monitor Pinched Hose Found
P1487Hi Speed Radiator Fan CTRL Relay Circ
P1488Auxiliary 5V Supply Output Too Low
P1489Hi Speed Fan CTRL Relay Circ
P1490Low Speed Fan CTRL Relay Circ
P1491Radiator Fan Ctrl Relay Circ
P1492Ambient/Battery Temp Sens Volts Too Hi
P1493Ambient/Battery Temp Sens Volts Too Low
P1494Leak Detection Pump Switch or Mechanical Fault
P1495Leak Detection Pump Solenoid Circ
P14965V Supply, Output Too Low
P1498Hi Speed Radiator Fan Ground CTRL Relay Circ
P1499Open or shorted condition detected in the hydraulic cooling fan solenoid control
P1508IAC Sys Low RPM
P1509IAC Sys Hi RPM
P1594Charging Sys Voltage Too Hi
P1595Speed Ctrl Solenoid Circs
P1596Speed Ctrl Switch Always Hi
P1597Speed Ctrl Switch Always Low
P1598A/C Press Sens Volts Too Hi
P1599A/C Press Sens Volts Too Low
P1602PCM Not Programmed
P1621PCM Memory Perf or Write
P1626Vehicle Theft Sys Ctrl Loss of Data
P1627A/D Perf
P1630Vehicle Theft Sys PCM in Learn Mode
P1631Vehicle Theft Sys Improper Password
P16355V Ref ( Circ
P16395V Ref ( Circ
P1641MIL Ctrl Circ
P1643Wait To Start Lamp Ctrl Circ
P16465V Ref (C) Circ
P1652J1850 Comms Bus
P1653EGR Vent Solenoid Ctrl Circ
P1654Service Throttle Soon Lamp Ctrl Circ
P1655EGR Solenoid Ctrl Circ
P1656Wastegate Solenoid Ctrl Circ
P1680Clutch Released Switch Circ
P1681No I/P Cluster CCD/J1850 Messages Received
P1682Charging Sys Voltage Too Low
P1683Speed Ctrl Power Relay; or S/C 12v Driver CKT
P1684Battery Disconnected in the last 50 Starts
P1685Skim Invalid Key
P1686No SKIM BUS Messages Received
P1687No Cluster BUS Message
P1688Internal Fuel Inj Pump Ctrller Failure
P1689No Comm between ECM & Inj Pump Mod
P1690CKP Sens Does Not Agree with ECM CKP Sens
P1691Fuel Sys ESS RPM Error
P1692DTC Set In ECM
P1693DTC Detected in Companion JTEC Mod
P1694No BUS Message Received from ECM Mod
P1695No CCD/J1850 Messages from the Body Ctrl Mod.
P1696PCM Failure EEPROM Write Denied
P1697PCM Failure SRI Mile Not Stored
P1698No CCD/J1850 Message From TCM/PCM
P1699No CCD/J1850 Messages received from the Climate Control Module(CCM)
P1719Skip Shift Solenoid Circ
P1740TCC or O/D Solenoid Perf
P1756Gov Press Not Equal to Target @ not15-20 PSI
P1757Gov Press above 3 PSI in gear with 0 MPH
P1762Gov Press Sens Offset Volts Too Low or Hi
P1763Governor Press Sens Volts Too Hi
P1764Governor Press Sens Volts Too Low
P1765Trans 12 Volt Supply Relay CTRL Circ
P1830Open or shorted condition detected in the clutch pedal switch over-ride relay control
P1899P/N Switch Stuck in Park or in Gear
DTC-Generic
P0001 Fuel Volume Regulator Control Circuit/Open
P0002 Fuel Volume Regulator Control Circuit Range/Performance
P0003 Fuel Volume Regulator Control Circuit Low
P0004 Fuel Volume Regulator Control Circuit High
P0005 Fuel Shutoff Valve C ontrol Circuit/Open
P0006 Fuel Shutoff Valve C ontrol Circuit Low
P0007 Fuel Shutoff Valve C ontrol Circuit H igh
P0008 Engine Position System Performance (Bank1)
P0009 Engine Position System Performance (Bank2)
P0010 A Camshaft Position Actuator Circuit (Bank1)
P0011 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 A Camshaft Position - Timing O ver-Retarded (Bank 1)
P0013 B Camshaft Position - Actuator Circuit (Bank1)
P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 B Camshaft Position - Timing O ver-Retarded (Bank 1)
P0016 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor A)
P0017 Crankshaft Position Camshaft Position Correlation (Bank 1 Sensor B)
P0018 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor A)
P0019 Crankshaft Position Camshaft Position Correlation (Bank 2 Sensor B)
P0020 A Camshaft Position Actuator Circuit (Bank 2)
P0021 A Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 A Camshaft Position - Timing O ver-Retarded (Bank 2)
P0023 B Camshaft Position - Actuator Circuit (Bank 2)
P0024 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 B Camshaft Position - Timing O ver-Retarded (Bank 2)
P0026 Intake Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0027 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 1)
P0028 Intake Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0029 Exhaust Valve Control Solenoid Circuit Range/Performance (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control C ircuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
P0040 O2 Sensor Signals Swapped Bank 1 Sensor 1/ Bank 2 Sensor 1
P0041 O2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0049 Turbo/Super Charger Turbine Overspeed
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
P0055 HO2S Heater Resistance (Bank 1 Sensor 3)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0059 HO2S Heater Resistance (Bank 2 Sensor 1)
P0060 HO2S Heater Resistance (Bank 2 Sensor 2)
P0061 HO2S Heater Resistance (Bank 2 Sensor 3)
P0062 HO2S Heater Control C ircuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0068 MAP/MAF Throttle Position Correlation
P0069 Manifold Absolute Pressure Barometric Pressure Correlation
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor C ircuit Low
P0073 Ambient Air Temperature Sensor Circuit High
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 1)
P0081 Intake Valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve C ontrol Solenoid C ircuit High (Bank 2)
P0087 Fuel Rail/System Pressure - Too Low
P0088 Fuel Rail/System Pressure - Too High
P0089 Fuel Pressure Regulator 1 Performance
P0090 Fuel Pressure Regulator 1 C ontrol Circuit
P0091 Fuel Pressure Regulator 1 C ontrol Circuit Low
P0092 Fuel Pressure Regulator 1 C ontrol Circuit High
P0093 Fuel System Leak Detected Large Leak
P0094 Fuel System Leak Detected Small Leak
P0095 Intake Air Temperature Sensor 2 C ircuit
P0096 Intake Air Temperature Sensor 2 C ircuit Range/Performance
P0097 Intake Air Temperature Sensor 2 C ircuit Low
P0098 Intake Air Temperature Sensor 2 Circuit High
P0099 Intake Air Temperature Sensor 2 C ircuit Intermittent/Erratic
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit Malfunction
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Position Sensor/Switch A Circuit Malfunction
P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle Position Sensor/Switch A Circuit Low Input
P0123 Throttle Position Sensor/Switch A Circuit High Input
P0124 Throttle Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control; ECT Excessive Time to Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0128 Coolant Thermostat Malfunction
P0129 Barometric Pressure Too Low
P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170 Fuel Trim Malfunction (Bank 1)
P0171 Fuel Trim too Lean (Bank 1)
P0172 Fuel Trim too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 Fuel Trim too Lean (Bank 2)
P0175 Fuel Trim too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit Malfunction
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit Malfunction
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder 1
P0202 Injector Circuit Malfunction - Cylinder 2
P0203 Injector Circuit Malfunction - Cylinder 3
P0204 Injector Circuit Malfunction - Cylinder 4
P0205 Injector Circuit Malfunction - Cylinder 5
P0206 Injector Circuit Malfunction - Cylinder 6
P0207 Injector Circuit Malfunction - Cylinder 7
P0208 Injector Circuit Malfunction - Cylinder 8
P0209 Injector Circuit Malfunction - Cylinder 9
P0210 Injector Circuit Malfunction - Cylinder 10
P0211 Injector Circuit Malfunction - Cylinder 11
P0212 Injector Circuit Malfunction - Cylinder 12
P0213 Cold Start Injector 1 Malfunction
P0214 Cold Start Injector 2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Overtemp Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Overspeed Condition
P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Overboost Condition
P0235 Turbocharger Boost Sensor A Circuit Malfunction
P0236 Turbocharger Boost Sensor A Circuit Range/Performance
P0237 Turbocharger Boost Sensor A Circuit Low
P0238 Turbocharger Boost Sensor A Circuit High
P0239 Turbocharger Boost Sensor B Malfunction
P0240 Turbocharger Boost Sensor B Circuit Range/Performance
P0241 Turbocharger Boost Sensor B Circuit Low
P0242 Turbocharger Boost Sensor B Circuit High
P0243 Turbocharger Wastegate Solenoid A Malfunction
P0244 Turbocharger Wastegate Solenoid A Range/Performance
P0245 Turbocharger Wastegate Solenoid A Low
P0246 Turbocharger Wastegate Solenoid A High
P0247 Turbocharger Wastegate Solenoid B Malfunction
P0248 Turbocharger Wastegate Solenoid B Range/Performance
P0249 Turbocharger Wastegate Solenoid B Low
P0250 Turbocharger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance Fault
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance Fault
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance Fault
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance Fault
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance Fault
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Range Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal A Malfunction
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B Malfunction
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Exhaust Gas Recirculation Flow Malfunction
P0385 Crankshaft Position Sensor B Circuit Malfunction
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0426 Catalyst Temperature Sensor Range/Performance (Bank 1)
P0427 Catalyst Temperature Sensor Low Input (Bank 1)
P0428 Catalyst Temperature Sensor High Input (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0436 Catalyst Temperature Sensor Range/Performance (Bank 2)
P0437 Catalyst Temperature Sensor Low Input (Bank 2)
P0438 Catalyst Temperature Sensor High Input (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan 1 Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
P0500 Vehicle Speed Sensor Malfunction
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor Low Input
P0503 Vehicle Speed Sensor Intermittent/Erratic/High
P0505 Idle Control System Malfunction
P0506 Idle Control System RPM Lower Than Expected
P0507 Idle Control System RPM Higher Than Expected
P0510 Closed Throttle Position Switch Malfunction
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor Circuit High Input
P0534 Air Conditioner Refrigerant Charge Loss
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
P0560 System Voltage Malfunction
P0561 System Voltage Unstable
P0562 System Voltage Low
P0562 A/C pressure sensor low voltage(Chrysler)
P0563 System Voltage High
P0565 Cruise Control On Signal Malfunction
P0566 Cruise Control Off Signal Malfunction
P0567 Cruise Control Resume Signal Malfunction
P0568 Cruise Control Set Signal Malfunction
P0569 Cruise Control Coast Signal Malfunction
P0570 Cruise Control Accel Signal Malfunction
P0571 Cruise Control/Brake Switch A Circuit Malfunction
P0572 Cruise Control/Brake Switch A Circuit Low
P0573 Cruise Control/Brake Switch A Circuit High
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction
P0601 Control Module Read Only Memory(ROM)
P0602 Control Module Programming Error
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P0605 Internal Control Module Read Only Memory (ROM) Error
P0606 PCM Processor Fault
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F" Control Circuit Malfunction
P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656 Fuel Level Output Circuit Malfunction
P0700 Transmission Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706 Transmission Range Sensor Circuit Range/Performance
P0707 Transmission Range Sensor Circuit Low Input
P0708 Transmission Range Sensor Circuit High Input
P0709 Transmission Range Sensor Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor Circuit Low Input
P0713 Transmission Fluid Temperature Sensor Circuit High Input
P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
P0715 Input/Turbine Speed Sensor Circuit Malfunction
P0716 Input/Turbine Speed Sensor Circuit Range/Performance
P0717 Input/Turbine Speed Sensor Circuit No Signal
P0718 Input/Turbine Speed Sensor Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720 Output Speed Sensor Circuit Malfunction
P0721 Output Speed Sensor Range/Performance
P0722 Output Speed Sensor No Signal
P0723 Output Speed Sensor Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740 Torque Converter Clutch Circuit Malfuction
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
P0742 Torque Converter Clutch Circuit Stuck On
P0743 Torque Converter Clutch Circuit Electrical
P0744 Torque Converter Clutch Circuit Intermittent
P0745 Pressure Control Solenoid Malfunction
P0746 Pressure Control Solenoid Performance or Stuck Off
P0747 Pressure Control Solenoid Stuck On
P0748 Pressure Control Solenoid Electrical
P0749 Pressure Control Solenoid Intermittent
P0750 Shift Solenoid A Malfunction
P0751 Shift Solenoid A Performance or Stuck Off/1-2 Shift Solenoid Valve Performance
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical/1-2 Shift Solenoid Circuit Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B Malfunction
P0756 Shift Solenoid B Performance or Stuck Off/2-3 Shift Solenoid Valve Performance
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical/2-3 Shift Solenoid Circuit Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C Malfunction
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D Malfunction
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E Malfunction
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B Malfunction
P0776 Pressure Control Solenoid B Performance
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing Solenoid Malfunction/ 3-2 Shift Solenoid Circuit Electrical
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit Control Circuit Malfunction
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1100 MAF Sensor Intermittent/ Check of all OBDII Systems Not Complete
P1101 MAF Sensor Out Of Self Test Range./KOER Not Able To Complete KOER Aborted
P1102 MAF Sensor In Range But Lower Than Expected
P1103 MAF Sensor In Range But Higher Than Expected
P1104 MAF Ground Malfunction
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107 Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108 Dual Alternator Battery Lamp Circuit Malfunction
P1109 IAT - B Sensor Intermittent
P1110 IAT Sensor (D/C) Open/Short
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113 IAT Sensor Open/Short
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT - B Circuit Low Input
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT - B Circuit High Input
P1116 Engine Coolant sensor out of range/ECT Sensor Out Of Self Test Range
P1117 Engine Coolant Sensor intermittent/ECT Sensor Intermittent
P1118 Manifold Absolute Temperature Circuit Low Input
P1119 Manifold Absolute Temperature Circuit High Input
P1120 Throttle position sensor out of range
P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1123 Throttle Position Sensor In Range But Higher Than Expected
P1124 Throttle Position Sensor Out Of Self Test Range
P1125 Throttle position sensor intermittent
P1126 Throttle Position (Narrow Range) Sensor Circuit Malfunction
P1127 Exhaust Not Warm, Downstream O2 Sensor
P1128 Upstream Heated O2 Sensors Swapped
P1129 Downstream Heated O2 Sensors Swapped
P1130 Lack Of HO2S Switch - Adaptive Fuel At Limit
P1131 Lack Of HO2S Switch - Sensor Indicates Lean
P1132 Lack Of HO2S Switch - Sensor Indicates Rich
P1133 HO2S Insufficient Switching Sensor 1
P1134 HO2S Transition Time Ratio Sensor 1
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Fan Control Circuit Malfunction
P1137 Lack Of HO2S Switch - Sensor Indicates Lean
P1138 Lack Of HO2S12 Switch - Sensor Indicates Rich
P1139 Water In Fuel Indicator Circuit Malfunction
P1140 Water In Fuel Condition
P1141 Fuel Restriction Indicator Circuit Malfunction
P1142 Fuel Restriction Condition
P1143 Air Assist Control Valve Range/Performance
P1144 Air Assist Control Valve Circuit Malfunction
P1150 Lack Of HO2S21 Switch - Adaptive Fuel At Limit
P1151 Lack Of HO2S21 Switch - Sensor Indicates Lean
P1152 Lack Of HO2S21 Switch - Sensor Indicates Rich
P1153 Bank 2 Fuel Control Shifted Lean
P1154 Bank 2 Fuel Control Shifted Rich
P1155 Alternative Fuel Controller
P1156 Fuel Select Switch Malfunction
P1157 Lack Of HO2S22 Switch - Sensor Indicates Lean
P1158 Lack Of HO2S22 Switch - Sensor Indicates Rich
P1159 Fuel Stepper Motor Malfunction
P1167 Invalid Test,throttle not depressed
P1168 Fuel Rail Sensor In-Range Low Failure
P1169 Fuel Rail Sensor In-Range High Failure
P1170 ESO - Engine Shut Off Solenoid Fault
P1171 Rotor Sensor Fault
P1172 Rotor Control Fault
P1173 Rotor Calibration Fault
P1174 Cam Sensor Fault
P1175 Cam Control Fault
P1176 Cam Calibration Fault
P1177 Synchronization Fault
P1178 ( open )
P1180 Fuel Delivery System Malfunction - Low
P1181 Fuel Delivery System Malfunction - High
P1182 Fuel Shut Off Solenoid Malfunction
P1183 Engine Oil Temperature Circuit Malfunction
P1184 Engine Oil Temperature Out Of Self Test Range
P1185 FTS High - Fuel Pump Temperature Sensor High
P1186 FTS Low - Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory Fault
P1189 Pump Speed Signal Fault
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 Voltage External
P1193 EGR Drive Overcurrent
P1194 ECU A/D Converter
P1195 SCP HBCC Failed To Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1200 Injector Control Circuit
P1201 Injector Circuit Open / Shorted - Cylinder #1
P1202 Injector Circuit Open / Shorted - Cylinder #2
P1203 Injector Circuit Open / Shorted - Cylinder #3
P1204 Injector Circuit Open / Shorted - Cylinder #4
P1205 Injector Circuit Open / Shorted - Cylinder #5
P1206 Injector Circuit Open / Shorted - Cylinder #6
P1209 Injector Control Pressure System Fault
P1210 Injector Control Pressure Above Expected Level
P1211 Injector Control Pressure Sensor Above / Below Desired
P1212 Injector Control Pressure Not Detected During Crank
P1213 Start Injector Circuit Malfunction
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System Malfunction
P1221 Traction Control System Malfunction
P1222 Traction Control Output Circuit Malfunction
P1223 Pedal Demand Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor Malfunction
P1226 Control Sleeve Sensor Malfunction
P1227 Wastegate Failed Closed (Over Pressure)
P1228 Wastegate Failed Open (Under Pressure)
P1229 Intercooler Pump Driver Fault
P1230 Fuel Pump Low Speed Malfunction
P1231 Fuel Pump Secondary Circuit Low, High Speed
P1232 Fuel Pump Speed Primary Circuit Malfunction
P1233 Fuel Pump Driver Module Off Line
P1234 Fuel Pump Driver Module Off Line
P1235 Fuel Pump Control Out Of Range
P1236 Fuel Pump Control Out Of Range
P1237 Fuel Pump Secondary Circuit Malfunction
P1238 Fuel Pump Secondary Circuit Malfunction
P1239 Speed Fuel Pump Positive Feed Fault
P1240 Sensor Power Supply Malfunction
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Faulty or Ground Fault
P1244 Alternator Load Input Failed High
P1245 Alternator Load Input Failed Low
P1246 Alternator Load Input Failed
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 PRC Solenoid Circuit Malfunction
P1251 Air Mixture Solenoid Circuit Malfunction
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255 Pedal Correlation PDS2 and LPDS Low
P1256 Pedal Correlation PDS1 and HPDS
P1257 Pedal Correlation PDS2 and HPDS
P1258 Pedal Correlation PDS1 and PDS2
P1259 Immobilizer to PCM Signal Error
P1260 THEFT Detected, Vehicle Immobilzed
P1261 Cylinder #1 High To Low Side Short
P1262 Cylinder #2 High To Low Side Short
P1263 Cylinder #3 High To Low Side Short
P1264 Cylinder #4 High To Low Side Short
P1265 Cylinder #5 High To Low Side Short
P1266 Cylinder #6 High To Low Side Short
P1267 Cylinder #7 High To Low Side Short
P1268 Cylinder #8 High To Low Side Short
P1269 Immobilizer Code Not Programmed
P1270 Engine RPM Or Speed Limiter Reached
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High To Low Side Open
P1273 Cylinder #3 High To Low Side Open
P1274 Cylinder #4 High To Low Side Open
P1275 Cylinder #5 High To Low Side Open
P1276 Cylinder #6 High To Low Side Open
P1277 Cylinder #7 High To Low Side Open
P1278 Cylinder #8 High To Low Side Open
P1280 Injection Control Pressure Out Of Range Low
P1281 Injection Control Pressure Out Of Range High
P1282 Excessive Injection Control Pressure
P1283 IPR Circuit Failure
P1284 Aborted KOER - ICP Failure
P1285 Cylinder head over temp sensed
P1286 Fuel Pulse In Range But Lower Than Expected
P1287 Fuel Pulse In Range But Higher Than Expected
P1288 Cylinder Head Temp Sensor Out Of Self Test Range
P1289 Cylinder Head Temp Sensor High Input
P1290 Cylinder Head Temp Sensor Low Input
P1291 Injector High Side Short To GND Or VBATT - Bank 1
P1292 Injector High Side Short To GND Or VBATT - Bank 2
P1293 Injector High Side Open - Bank 1
P1294 Injector High Side Open - Bank 2/Target idle not reached
P1295 Multi-faults - Bank 1 - With Low Side Shorts
P1296 Multi-faults - Bank 2 - With Low Side Shorts
P1297 Injector High Sides Shorted Together
P1298 IDM Failure
P1299 Cylinder Head Overtemperature Protection Active
P1300 Boost Calibration Fault
P1301 Boost Calibration High
P1302 Boost Calibration Low
P1303 EGR Calibration Fault
P1304 EGR Calibration High
P1305 EGR Calibration Low
P1306 Kickdown Relay Pull - In Circuit Fault
P1307 Kickdown Relay Hold Circuit Fault
P1308 A/C Clutch Circuit Fault
P1309 Misfire Monitor AICE Chip Fault
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Injector Circuit / IDM Codes Detected
P1317 Injector Circuit / IDM Codes Not Updated
P1336 Crank / Cam Sensor Range / Performance
P1340 Camshaft Position Sensor B Circuit Malfunction
P1341 Camshaft Position Sensor B Range / Performance
P1345 SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
P1346 Fuel Level Sensor B Circuit Malfunction
P1347 Fuel Level Sensor B Range / Performance
P1348 Fuel Level Sensor B Circuit Low
P1349 Fuel Level Sensor B Circuit High
P1350 Fuel Level Sensor B Intermittent/Bypass Line Monitor
P1351 IDM Input Circuit Malfunction/ Ignition Coil Control Circuit High Voltage
P1352 Ignition Coil A Primary Circuit Malfunction
P1353 Ignition Coil B Primary Circuit Malfunction
P1354 Ignition Coil C Primary Circuit Malfunction
P1355 Ignition Coil D Primary Circuit Malfunction
P1360 Ignition Coil A Secondary Circuit Malfunction
P1361 Ignition Control (IC) Circuit Low Voltage
P1362 Ignition Coil C Secondary Circuit Malfunction
P1363 Ignition Coil D Secondary Circuit Malfunction
P1364 Ignition Coil Primary Circuit Failure
P1365 Ignition Coil Secondary Circuit Failure
P1366 Ignition Spare
P1367 Ignition Spare
P1368 Ignition Spare
P1369 Engine Temperature Light Monitor Failure
P1370 Insufficient RMP Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Crankshaft Position (CKP)/Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1380 Misfire Detected - Rough Road Data Not Available
P1381 Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM
P1382 Variable Cam Timing Solenoid #1 Circuit Malfunction
P1383 Variable Cam Timing Overretarded (Bank #1)
P1384 VVT Solenoid A Malfunction
P1385 Variable Cam Timing Solenoid B Malfunction
P1386 Variable Cam Timing Overadvanced (Bank #2)
P1387 Variable Cam Timing Solenoid #2 Circuit Malfunction
P1388 Variable Cam Timing Overretarded (Bank #2)
P1389 Glow Plug Circuit High Side Low Input
P1390 Octane Adjust Pin Out Of Self Test Range
P1391 Glow Plug Circuit Low Input (Bank #1)
P1392 Glow Plug Circuit High Input (Bank #1)
P1393 Glow Plug Circuit Low Input (Bank #2)
P1394 Glow Plug Circuit High Input (Bank #2)
P1395 Glow Plug Monitor Fault (Bank #1)
P1396 Glow Plug Monitor Fault (Bank #2)
P1397 System Voltage Out Of Self Test Range
P1398 VVT Solenoid B Circuit High Input
P1399 Glow Plug Circuit High Side, High Input
P1400 DPFE Circuit Low Input
P1401 DPFE Circuit High Input
P1402 EGR Metering Orifice Restricted
P1403 DPFE Sensor Hoses Reversed
P1404 IAT - B Circuit Malfunction/ Exhaust Gas Recirculation Closed Position Performance
P1405 DPFE Sensor Upstream Hose Off Or Plugged
P1406 Exhaust Gas Recirculation (EGR) Position Sensor Performance
P1407 EGR No Flow Detected
P1408 EGR Flow Out Of Self Test Range
P1409 EVR Control Circuit Malfunction
P1411 SAI System Incorrect Downstream Flow Detected
P1413 SAI System Monitor Circuit Low Input
P1414 SAI System Monitor Circuit High Input
P1415 Air Pump Circuit Malfunction/ (AIR) System Bank 1
P1416 Port Air Circuit Malfunction/ (AIR) System Bank 2
P1417 Port Air Relief Circuit Malfunction
P1418 Split Air #1 Circuit Malfunction
P1419 Split Air #2 Circuit Malfunction
P1420 Catalyst Temperature Sensor Failure
P1421 Catalyst Damage
P1422 EGI Temperature Sensor Failure
P1423 EGI Functionality Test Failed
P1424 EGI Glow Plug Primary Failure
P1425 EGI Glow Plug Secondary Failure
P1426 EGI Mini - MAF Failed Out Of Range
P1427 EGI Mini - MAF Failed Short Circuit
P1428 EGI Mini - MAF Failed Open Circuit
P1429 Electric Air Pump Primary Failure
P1430 Electric Air Pump Secondary Failure
P1433 A/C Refrigerant Temperature Circuit Low
P1434 A/C Refrigerant Temperature Circuit High
P1435 A/C Refrigerant Temperature Circuit Range/Performance
P1436 A/C Evaporator Air Temperature Circuit Low
P1437 A/C Evaporator Air Temperature Circuit High
P1438 A/C Evaporator Air Temperature Circuit Range/Performance
P1439 Floor Temperature Switch Circuit Malfunction
P1440 Purge Valve Stuck Open
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Chevrolet Only
P1441 Evaporative Emission (EVAP) System Flow During Non-Purge Oldsmobile Only
P1442 Evaporative Emission Control System Leak Detected
P1443 Evaporative Emission Control System Control Valve
P1444 Purge Flow Sensor Circuit Low Input
P1445 Purge Flow Sensor Circuit High Input
P1446 Evaporative Vac Solenoid Circuit Malfunction
P1447 ELC System Closure Valve Flow Fault
P1448 ELC System 2 Fault
P1449 Evaporative Check Solenoid Circuit Malfunction
P1450 Unable To Bleed Up Fuel Tank Vacuum
P1451 Evap Emission Control Sys Vent Control Valve Circuit
P1452 Unable To Bleed - Up Vacuum in Tank
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative System Vacuum Test Malfunction
P1455 Evap Emission Control Sys Leak Detected (Gross Leak/No Flow)
P1456 Fuel Tank Temperature Sensor Circuit Malfunction
P1457 Unable To Pull Vacuum In Tank
P1460 Wide open throttle A/C cutoff relay circuit
P1461 A/C pressure sensor circuit voltage low
P1462 A/C pressure sensor circuit voltage high
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out of Self Test Range
P1465 A/C Relay Circuit Malfunction
P1466 A/C Refrigerant Temperature Sensor/Circuit Malfunction
P1467 A/C Compressor Temperature Sensor Malfunction
P1468 SSPOD Open Circuit or Closed Circuit Fault
P1469 Low A/C Cycling Period
P1470 A/C Cycling Period Too Short
P1471 Electrodrive Fan 1 Operational Failure (Driver Side)
P1472 Electrodrive Fan 2 Operational Failure (Passenger Side)
P1473 Fan Secondary High With Fan(s) Off
P1474 Low Fan Control Primary Circuit Malfunction
P1475 Fan Relay (Low) Circuit Malfunction
P1476 Fan Relay (High) Circuit Malfunction
P1477 Additional Fan Relay Circuit Malfunction
P1478 Cooling Fan Driver Fault
P1479 High Fan Control Primary Circuit Malfunction
P1480 Fan Secondary Low with Low Fan On
P1481 Fan Secondary Low With High Fan On
P1482 SCP
P1483 Power To Fan Circuit Overcurrent
P1484 Open Power To Ground VCRM
P1485 EGRV Circuit Malfunction
P1486 EGRA Circuit Malfunction
P1487 EGRCHK Solenoid Circuit Malfunction
P1490 Secondary Air Relief Solenoid Circuit Malfunction
P1491 Secondary Switch Solenoid Circuit Malfunction
P1492 APLSOL Solenoid Circuit Malfunction
P1493 RCNT Solenoid Circuit Malfunction
P1494 SPCUT Solenoid Circuit Malfunction
P1495 TCSPL Solenoid Circuit Malfunction
P1500 Vehicle Speed Sensor Intermittent
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent Malfunction
P1503 Auxillary Speed Sensor Fault
P1504 Idle Air Control Circuit Malfunction
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error
P1507 Idle Air Control Underspeed Error
P1508 Idle Control System Circuit Open
P1509 Idle Control System Circuit Shorted
P1510 Idle Signal Circuit Malfunction
P1511 Idle Switch (Electric Control Throttle) Circuit Malfunction
P1512 Intake Manifold Runner Control (Bank 1) Stuck Closed
P1513 Intake Manifold Runner Control (Bank 2) Stuck Closed
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit Malfunction
P1516 IMRC Input Error (Bank 1)
P1517 IMRC Input Error (Bank 2)
P1518 Intake Manifold Runner Control (Stuck Open)
P1519 Intake Manifold Runner Control (Stuck Closed)
P1520 Intake Manifold Runner Control Circuit Malfunction
P1521 Variable Intake Solenoid #1 Circuit Malfunction
P1522 Variable Intake Solenoid #2 Circuit Malfunction
P1523 IVC Solenoid Circuit Malfunction
P1524 Variable Intake Solenoid System
P1525 Air Bypass Valve System
P1526 Air Bypass System
P1527 Accelerate Warmup Solenoid Circuit Malfunction
P1528 Subsidiary Throttle Valve Solenoid Circuit Malfunction
P1529 SCAIR Solenoid Circuit Malfunction
P1530 A/C Clutch Circuit Malfunction
P1531 Invalid Test - Accelerator Pedal Movement
P1532 IMCC Circuit Malfunction, Bank B
P1533 AAI Circuit Malfunction
P1534 Inertia Switch Activated
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit Failure
P1537 Intake Manifold Runner Control (Bank 1) Stuck Open
P1538 Intake Manifold Runner Control (Bank 2) Stuck Open
P1539 Power To A/C Clutch Circuit Overcurrent
P1540 Air Bypass Valve Circuit Malfunction
P1549 IMCC Circuit Malfunction, Bank B
P1550 PSPS Out Of Self Test Range
P1565 Speed Control Command Switch Out of Range High
P1566 Speed Control Command Switch Out of Range Low
P1567 Speed Control Output Circuit Continuity
P1568 Speed Control Unable to Hold Speed
P1571 Brake Switch Malfunction
P1572 Brake Pedal Switch Circuit Malfunction
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Disagreement btwn Sensors
P1575 Pedal Position Out of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Disagreement btwn Sensors
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disable
P1584 TCU Detected IPE Circuit Malfunction
P1585 Throttle Control Unit Malfunction
P1586 Throttle Control Unit Throttle Position Malfunction
P1587 Throttle Control Unit Modulated Command Malfunction
P1588 Throttle Control Unit Detected Loss of Return Spring
P1589 TCU Unable To Control Desired Throttle Angle
P1600 Loss of KAM Power; Open Circuit
P1601 ECM/TCM Serial Communication Error
P1602 Immobilizer/ECM Communication Error
P1603 EEPROM Malfunction
P1604 Code Word Unregestered
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay O/P Circuit Malfunction
P1607 MIL O/P Circuit Malfunction
P1608 Internal ECM Malfunction
P1609 Diagnostic Lamp Driver Fault
P1610 SBDS Interactive Codes
P1611 SBDS Interactive Codes
P1612 SBDS Interactive Codes
P1613 SBDS Interactive Codes
P1614 SBDS Interactive Codes
P1615 SBDS Interactive Codes
P1616 SBDS Interactive Codes
P1617 SBDS Interactive Codes
P1618 SBDS Interactive Codes
P1619 SBDS Interactive Codes
P1620 SBDS Interactive Codes
P1621 Control Module Long Term Memory Performance/ Immobilizer Code Words Do Not Match
P1622 Immobilizer ID Does Not Match
P1623 Immobilizer Code Word/ID Number Write Failure
P1624 Anti Theft System
P1625 B+ Supply To VCRM Fan Circuit Malfunction
P1626 Theft Deterrent Fuel Enable Signal Not Received/ B+ Supply To VCRM A/C Circuit Malfunction
P1627 Module Supply Voltage Out Of Range
P1628 Module Ignition Supply Input Malfunction
P1629 Internal Voltage Regulator Malfunction
P1630 Internal Vref Malfunction
P1631 Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P1633 KAM Voltage Too Low
P1634 Data Output Link Circuit Failure
P1635 Tire / Axle Ratio Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error
P1637 Can Link ECM/ABSCM Circuit / Network Malfunction
P1638 Can Link ECM/INSTM Circuit / Network Malfunction
P1639 Vehicle ID Block Corrupted or Not Programmed
P1640 Powertrain DTCs Available in Another Module
P1641 Fuel Pump Primary Circuit Failure
P1642 Fuel Pump Monitor Circuit High Input
P1643 Fuel Pump Monitor Circuit Low Input
P1644 Fuel Pump Speed Control Circuit Malfunction
P1645 Fuel Pump Resistor Switch Circuit Malfunction
P1650 PSP Switch Out of Self Test Range
P1651 PSP Switch Input Malfunction
P1652 IAC Monitor Disabled by PSP Switch Failed On
P1653 Power Steering Output Circuit Malfunction
P1654 Recirculation Override Circuit Malfunction
P1655 Starter Disable Circuit Malfunction
P1660 Output Circuit Check Signal High
P1661 Output Circuit Check Signal Low
P1662 IDM_EN Circuit Failure
P1663 Fuel Demand Command Signal Circuit Malfunction
P1667 CI Circuit Malfunction
P1668 PCM - IDM Communications Error
P1670 Electronic Feedback Signal Not Detected
P1680 Metering Oil Pump Malfunction
P1681 Metering Oil Pump Malfunction
P1682 Metering Oil Pump Malfunction
P1683 Metering Oil Pump Temperature Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
P1685 Metering Oil Pump Stepping Motor Circuit Malfunction
P1686 Metering Oil Pump Stepping Motor Circuit Malfunction
P1687 Metering Oil Pump Stepping Motor Circuit Malfunction
P1688 Metering Oil Pump Stepping Motor Circuit Malfunction
P1689 Oil Pressure Control Solenoid Circuit Malfunction
P1690 Wastegate Solenoid Circuit Malfunction
P1691 Turbo Pressure Control Solenoid Circuit Malfunction
P1692 Turbo Control Solenoid Circuit Malfunction
P1693 Turbo Charge Control Circuit Malfunction
P1694 Turbo Charge Relief Circuit Malfunction
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 TRS Circuit Intermittent Malfunction
P1703 Brake Switch Out Of Self Test Range
P1704 Digital TRS Failed to Transition States in KOEO / KOER
P1705 Not in P or N During KOEO / KOER
P1706 High Vehicle Speed Observed in Park
P1707 Transfer Case Neutral Indicator Hard Fault Present
P1708 Clutch Switch Circuit Malfunction
P1709 PNP Switch Out Of Self Test Range
P1711 TFT Sensor Out Of Self Test Range
P1712 Trans Torque Reduction Request Signal Malfunction
P1713 TFT Sensor In Range Failure Low Value
P1714 SSA Inductive Signature Malfunction
P1715 SSB Inductive Signature Malfunction
P1716 SSC Inductive Signature Malfunction
P1717 SSD Inductive Signature Malfunction
P1718 TFT Sensor In Range Failure High
P1720 Vehicle Speed (Meter) Circuit Malfunction
P1721 Gear 1 Incorrect Ratio
P1722 Gear 2 Incorrect Ratio
P1723 Gear 3 incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1725 Insufficient Engine Speed Increase During Self Test
P1726 Insufficient Engine Speed Decrease During Self Test
P1727 Coast Clutch Solenoid Inductive Signature Malfunction
P1728 Transmission Slip Error
P1729 4x4 Low Switch Error
P1730 Gear Control Malfunction 2,3,5
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1734 Gear Control Malfunction
P1735 First Gear Switch Circuit Malfunction
P1736 Second Gear Switch Circuit Malfunction
P1737 Lockup Solenoid System
P1738 Shift Time Error
P1739 Slip Solenoid System
P1740 Torque Converter Clutch Inductive Signature Malfunction
P1741 Torque Converter Clutch Control Error
P1742 Torque Converter Clutch Solenoid Failed On
P1743 Torque Converter Clutch Solenoid Failied On
P1744 Torque Converter Clutch System Performance
P1745 Line Pressure Solenoid System
P1746 Pressure Control Solenoid "A" Open Circuit
P1747 Pressure Control Solenoid "A" Short Circuit
P1748 EPC Malfunction
P1749 Pressure Control Solenoid Failed Low
P1751 Shift Solenoid A Performance
P1754 Coast Clutch Solenoid Circuit Malfunction
P1755 Intermediate Speed Sensor (ISS) Malfunction
P1756 Shift Solenoid B Performance
P1760 Pressure Control Solenoid "A" Short Circuit
P1761 Shift Solenoid C Performance
P1762 Overdrive Band Failed Off
P1765 Timing Solenoid Circuit Malfunction
P1767 Torque Converter Clutch Circuit Malfunction
P1768 Performance / Normal / Winter Mode Input Malfunction
P1769 AG4 Transmission Torque Modulation Fault
P1770 Clutch Solenoid Circuit Malfunction
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration Fault
P1777 Ignition Retard Request Circuit Fault
P1778 Transmission Reverse I/P Circuit Malfunction
P1779 TCIL Circuit Malfunction
P1780 Trans Control Switch (O/D Cancel) Out of Self Test Range
P1781 4X4 Switch Out of Self Test Range
P1782 P/ES Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid "B" Open Circuit
P1789 Pressure Control Solenoid "B" Short Circuit
P1790 TP (Mechanical) Circuit Malfunction
P1791 TP (Electric) Circuit Malfunction
P1792 Barometer Pressure Circuit Malfunction
P1793 Intake Air Volume Circuit Malfunction
P1794 Battery Voltage Circuit Malfunction
P1795 Idle Switch Circuit Malfunction
P1796 Kick Down Switch Circuit Malfunction
P1797 Neutral Switch Circuit Malfunction
P1798 Coolant Temperature Circuit Malfunction
P1799 Hold Switch Circuit Malfunction
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P1801 Transmission Clutch Interlock Safety Switch Open Circuit
P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804 Transmission 4-Wheel Drive High Indicator Circuit Failure
P1805 Transmission 4-Wheel Drive High Indicator Open Circuit
P1806 Transmission 4-Wheel Drive High Indicator Short Circuit To Battery
P1807 Transmission 4-Wheel Drive High Indicator Short Circuit To Ground
P1808 Transmission 4-Wheel Drive Low Indicator Circuit Failure
P1809 Transmission 4-Wheel Drive Low Indicator Open Circuit
P1810 TFP Valve Position Switch Circuit/ Transmission 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811 Transmission 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812 Transmission 4-Wheel Drive Mode Select Circuit Failure
P1813 Transmission 4-Wheel Drive Mode Select Open Circuit
P1814 Transmission 4-Wheel Drive Mode Select Short Circuit To Battery
P1815 Transmission 4-Wheel Drive Mode Select Short Circuit To Ground
P1816 Transmission Neutral Safety Switch Circuit Failure
P1817 Transmission Neutral Safety Switch Open Circuit
P1818 Transmission Neutral Safety Switch Short Circuit To Battery
P1819 Transmission Neutral Safety Switch Short Circuit To Ground
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821 Transmission Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823 Transmission Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824 Transmission 4-Wheel Drive Clutch Relay Circuit Failure
P1825 Transmission 4-Wheel Drive Clutch Relay Open Circuit
P1826 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827 Transmission 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828 Transmission Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829 Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831 Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832 Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833 Transmission Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835 Transmission Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
P1836 Transmission Transfer Case Front Shaft Speed Sensor Circuit Failure
P1837 Transmission Transfer Case Rear Shaft Speed Sensor Circuit Failure
P1838 Transmission Transfer Case Shift Motor Circuit Failure
P1839 Transmission Transfer Case Shift Motor Open Circuit
P1840 Transmission Transfer Case Shift Motor Short Circuit To Battery
P1841 Transmission Transfer Case Shift Motor Short Circuit To Ground
P1842 Transmission Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
P1843 Transmission Transfer Case Differential Lock-Up Feedback Switch Open Circuit
P1844 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
P1845 Transmission Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
P1846 Transmission Transfer Case Contact Plate 'A' Circuit Failure
P1847 Transmission Transfer Case Contact Plate 'A' Open Circuit
P1848 Transmission Transfer Case Contact Plate 'A' Short Circuit To Battery
P1849 Transmission Transfer Case Contact Plate 'A' Short Circuit To Ground
P1850 Transmission Transfer Case Contact Plate 'B' Circuit Failure
P1851 Transmission Transfer Case Contact Plate 'B' Open Circuit
P1852 Transmission Transfer Case Contact Plate 'B' Short Circuit To Battery
P1853 Transmission Transfer Case Contact Plate 'B' Short Circuit To Ground
P1854 Transmission Transfer Case Contact Plate 'C' Circuit Failure
P1855 Transmission Transfer Case Contact Plate 'C' Open Circuit
P1856 Transmission Transfer Case Contact Plate 'C' Short Circuit To Battery
P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
P1858 Transmission Transfer Case Contact Plate 'D' Circuit Failure
P1859 Transmission Transfer Case Contact Plate 'D' Open Circuit
P1860 TCC PWM Solenoid Circuit Electrical/ Transmission Transfer Case Contact Plate 'D' Short Circuit To Battery
P1861 Transmission Transfer Case Contact Plate 'D' Short Circuit To Ground
P1862 Transmission Transfer Case Contact Plate Power Circuit Failure
P1863 Transmission Transfer Case Contact Plate Power Open Circuit
P1864 Transmission Transfer Case Contact Plate Power Short To Battery
P1865 Transmission Transfer Case Contact Plate Power Short To Ground
P1866 Transmission Transfer Case System Concern - Servicing Required
P1867 Transmission Transfer Case Contact Plate General Circuit Failure
P1868 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Failure
P1869 Transmission Automatic 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
P1870 Transmission Component Slipping/ Transmission Mechanical Transfer Case 4x4 Switch Circuit Failure
P1871 Transmission Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
P1872 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
P1873 Transmission Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
P1874 Transmission Automatic Hall Effect Sensor Power Circuit Failure
P1875 Transmission Automatic Hall Effect Sensor Power Circuit Short To Battery / 4WD Low Switch Circuit Electrical
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1877 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1878 Transmission Transfer Case Disengaged Solenoid Circuit Failure
P1879 Transmission Transfer Case Disengaged Solenoid Open Circuit
P1880 Transmission Transfer Case Disengaged Solenoid Short to Battery
P1881 Engine Coolant Level Switch Circuit Failure, GEM
P1882 Engine Coolant Level Switch Circuit Short to Ground
P1883 Engine Coolant Level Switch Circuit Failure, GEM
P1884 Engine Coolant Level Lamp Circuit Short to Ground
P1885 Transmission Transfer Case Disengaged Solenoid Short to Ground
P1886 4X4 Initialization Failure
P1890 Transmission 4WD Mode Select Return Input Circuit Failure
P1891 Transmission Transfer Case Contact Plate Ground Return Open Circuit
P1900 OSS Circuit Intermittent Malfunction
P1901 TSS Circuit Intermittent Malfunction
P1902 Pressure Control Solenoid "B" Intermittent Short
P1903 Pressure Control Solenoid "C" Short Circuit
P1904 Pressure Control Solenoid "C" Open Circuit
P1905 Pressure Control Solenoid "C" Intermittent Short
P1906 Kickdown Pull Relay Open or Short Circuit to Ground
P1907 Kickdown Hold Relay Open or Short Circuit to Ground
P1908 Transmission Pressure Circuit Solenoid Open or Short to Ground
P1909 Trans Temp Sensor Circuit Open or Shorted to Pwr or Gnd
P1910 VFS A Pressure Output Failed Low
P1911 VFS B Pressure Output Failed Low
P1912 VFS C Pressure Output Failed Low
P1913 Pressure Switch A Circuit Malfunction
P1914 Manually Shifted Automatic (MSA) Sw Circuit Malf
P1915 Reverse Switch Circuit Malfunction
P1916 High Clutch Drum Speed Sensor Malfunction
P1917 High Clutch Drum Speed Sensor Intermittent
P1918 Transmission Range Display Circuit Malfunction
C1091 Speed Wheel Sensor All Coherency Failure
C1095 ABS Hydraulic Pump Motor Circuit Failure
C1096 ABS Hydraulic Pump Motor Circuit Open
C1097 ABS Hydraulic Pump Motor Circuit Short To Ground
C1098 ABS Hydraulic Pump Motor Circuit Short To Battery
C1100 ABS Pump Switch Circuit Failure
C1101 ABS Hydraulic Valve Circuit Failure
C1102 ABS Acceleration Switch Circuit Failure
C1103 ABS Hydraulic Brake Switch Circuit Failure
C1104 Traction Control Active Lamp - Circuit Short to Battery
C1105 Traction Control Disable Lamp - Circuit Short to Battery
C1106 Traction Control Disable Switch Circuit Short to Battery
C1107 ABS Function Enabled Input Circuit Failure
C1109 Speed Control Actuator Assembly Cable Release Failure
C1110 ABS Power Relay Coil Circuit Failure
C1111 ABS Power Relay Coil Open Circuit
C1112 ABS Power Relay Coil Short Circuit To Ground
C1113 ABS Power Relay Coil Short Circuit To Battery
C1114 ABS Power Relay Output Short Circuit To Ground
C1115 ABS Power Relay Output Short Circuit To Battery
C1116 Starter Motor Circuit Failure
C1117 RPM Input Circuit Failure
C1123 Vehicle Speed Sensor Input Short to Battery
C1124 Input shaft speed signal missing/faulted
C1125 Brake Fluid Level Sensor Input Circuit Failure
C1126 Cruise Control Command Switch Assembly Circuit Failure
C1127 Cruise Control Deactivator Brake Switch Circuit Failure
C1132 Clutch position ckt short to ground
C1133 Clutch position ckt short to battery
C1134 Gear Shift position short to ground
C1135 Gear Shift position short to battery
C1136 Gear Select position short to ground
C1137 ECU is Defective
C1138 Gear Select position short to Battery
C1139 Wheel Speed Sensor Center Tone Ring Missing Tooth Fault
C1140 Hydraulic Base Brake Failure
C1141 Wheel Speed Sensor LF Tone Ring Tooth Missing Fault
C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault
C1143 Wheel Speed Sensor LR Tone Ring Tooth Missing Fault
C1144 Wheel Speed Sensor RR Tone Ring Tooth Missing Fault
C1145 Speed Wheel Sensor RF Input Circuit Failure
C1146 Speed Wheel Sensor RF Circuit Open
C1148 Speed Wheel Sensor RF Coherency Fault
C1149 Hydraulic Fluid Pressure/ Flow Circuit Failure
C1150 Two Speed Rear Axle Input Switch Circuit Short to Vbatt
C1155 Speed Wheel Sensor LF Input Circuit Failure
C1156 Speed Wheel Sensor LF Circuit Open
C1157 Park Brake Actuator Assembly Switch Applied Circuit Failure
C1158 Speed Wheel Sensor LF Coherency Fault
C1159 Hydraulic Fluid Pressure/ Flow Circuit Short to Gnd
C1161 Air Pressure Low Circuit Short to Gnd
C1162 Park Brake Switch # 2 Released Circuit Failure
C1163 Park Brake Switch # 2 Applied Circuit Short to Gnd
C1164 Park Brake Actuator Assembly Switch Circuit Failure
C1165 Speed Wheel Sensor RR Input Circuit Failure
C1166 Speed Wheel Sensor RR Input Open Circuit
C1167 Park Brake Actuator Assembly Switch Released Circuit Short to Gnd
C1168 Speed Wheel Sensor RR Coherency Fault
C1169 ABS Fluid Dumping Exceeds Maximum Timing
C1170 PRNDL Switch Circuit Failure
C1172 Park Brake Switch # 1 Applied Circuit Failure
C1173 Park Brake Switch # 1 Released Circuit Short to Gnd
C1174 Park Brake Switch # 2 Applied Circuit Failure
C1175 Speed Wheel Sensor LR Input Circuit Failure
C1176 Speed Wheel Sensor LR Circuit Open
C1177 Park Brake Actuator Assembly Switch Released Circuit Failure
C1178 Speed Wheel Sensor LR Coherency Fault
C1179 Speed Control Actuator Assembly Cable Slack Failure
C1180 Park Brake Valve Solenoid #1 Sense Input Circuit Failure
C1181 Park Brake Valve Solenoid #1 Sense Input Circuit Short to Gound
C1182 Park Lamp Flash Relay Circuit Failure
C1183 Park Lamp Flash Relay Circuit Short to Battery
C1184 ABS System Is Not Operational
C1185 ABS Power Relay Output Circuit Failure
C1186 ABS Power Relay Output Open Circuit
C1187 Brake Fluid Level Sensor Input Open Circuit
C1188 Brake Fluid Level Sensor Input Short Circuit To Battery
C1189 Brake Fluid Level Sensor Input Short Circuit To Ground
C1190 Speed Wheel Sensor LF Input Short Circuit To Battery
C1191 Speed Wheel Sensor LF Input Short Circuit To Ground
C1192 Speed Wheel Sensor RF Input Short Circuit To Battery
C1193 Speed Wheel Sensor RF Input Short Circuit To Ground
C1194 ABS Outlet Valve Coil LF Circuit Failure
C1195 ABS Outlet Valve Coil LF Circuit Open
C1196 ABS Outlet Valve Coil LF Circuit Short To Battery
C1197 ABS Outlet Valve Coil LF Circuit Short To Ground
C1198 ABS Inlet Valve Coil LF Circuit Failure
C1199 ABS Inlet Valve Coil LF Circuit Open
C1200 ABS Inlet Valve Coil LF Circuit Short To Battery
C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
C1202 ABS Outlet Valve Coil Rear Circuit Failure
C1203 ABS Outlet Valve Coil Rear Circuit Open
C1204 ABS Outlet Valve Coil Rear Circuit Short To Battery
C1205 ABS Outlet Valve Coil Rear Circuit Short To Ground
C1206 ABS Inlet Valve Coil Rear Circuit Failure
C1207 ABS Inlet Valve Coil Rear Circuit Open
C1208 ABS Inlet Valve Coil Rear Circuit Short To Battery
C1209 ABS Inlet Valve Coil Rear Circuit Short To Ground
C1210 ABS Outlet Valve Coil RF Circuit Failure
C1211 ABS Outlet Valve Coil RF Circuit Open
C1212 ABS Outlet Valve Coil RF Circuit Short To Battery
C1213 ABS Outlet Valve Coil RF Circuit Short To Ground
C1214 ABS Inlet Valve Coil RF Circuit Failure
C1215 ABS Inlet Valve Coil RF Circuit Open
C1216 ABS Inlet Valve Coil RF Circuit Short To Battery
C1217 ABS Inlet Valve Coil RF Circuit Short To Ground
C1218 Lamp ABS Warning Output Circuit Failure
C1219 Lamp ABS Warning Output Circuit Open
C1220 Lamp ABS Warning Output Circuit Short To Battery
C1221 Lamp ABS Warning Output Circuit Short To Ground
C1222 Speed Wheel Mismatch
C1223 Lamp Brake Warning Output Circuit Failure
C1224 Lamp Brake Warning Output Circuit Open
C1225 Lamp Brake Warning Output Circuit Short To Battery
C1226 Lamp Brake Warning Output Circuit Short To Ground
C1227 Speed Wheel Sensor LR Input Short Circuit To Battery
C1228 Speed Wheel Sensor LR Input Short Circuit To Ground
C1229 Speed Wheel Sensor Rear Center Coherency Fault
C1230 Speed Wheel Sensor Rear Center Input Circuit Failure
C1231 Speed Wheel Sensor Rear Center Circuit Open
C1232 Speed Wheel Sensor Rear Center Input Short Circuit To Battery
C1233 Speed Wheel LF Input Signal Missing
C1234 Speed Wheel RF Input Signal Missing
C1235 Speed Wheel RR Input Signal Missing
C1236 Speed Wheel LR Input Signal Missing
C1237 Speed Wheel Rear Input Signal Missing
C1238 ABS Hydraulic Pressure Differential Switch Input Circuit Failure
C1239 ABS Hydraulic Pressure Differential Switch Input Open Circuit
C1240 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Battery
C1241 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Ground
C1242 ABS Outlet Valve Coil LR Circuit Failure
C1243 ABS Outlet Valve Coil LR Circuit Open
C1244 ABS Outlet Valve Coil LR Circuit Short To Battery
C1245 ABS Outlet Valve Coil LR Circuit Short To Ground
C1246 ABS Outlet Valve Coil RR Circuit Failure
C1247 ABS Outlet Valve Coil RR Circuit Open
C1248 ABS Outlet Valve Coil RR Circuit Short To Battery
C1249 ABS Outlet Valve Coil RR Circuit Short To Ground
C1250 ABS Inlet Valve Coil LR Circuit Failure
C1251 ABS Inlet Valve Coil LR Circuit Open
C1252 ABS Inlet Valve Coil LR Circuit Short To Battery
C1253 ABS Inlet Valve Coil LR Circuit Short To Ground
C1254 ABS Inlet Valve Coil RR Circuit Failure
C1255 ABS Inlet Valve Coil RR Circuit Open
C1256 ABS Inlet Valve Coil RR Circuit Short To Battery
C1257 ABS Inlet Valve Coil RR Circuit Short To Ground
C1258 Speed Wheel LF Comparison Failure
C1259 Speed Wheel RF Comparison Failure
C1260 Speed Wheel RR Comparison Failure
C1261 Speed Wheel LR Comparison Failure
C1262 Lamp Warning Relay Circuit Failure
C1263 Lamp Warning Relay Circuit Open
C1264 Lamp Warning Relay Circuit Short To Battery
C1265 Lamp Warning Relay Circuit Short To Ground
C1266 ABS Valve Power Relay Circuit Failure
C1267 ABS Functions Temporarily Disabled
C1268 Motor Relay # 1 Circuit Failure
C1269 Motor Relay # 1 Circuit Short to Battery
C1270 Motor # 1 Input Circuit Failure
C1271 Motor # 1 Input Circuit Short to Gnd
C1272 Motor # 2 Input Circuit Failure
C1273 Motor # 2 Input Circuit Short to Vbat
C1274 Solenoid Relay # 1 Circuit Failure
C1275 Solenoid Relay # 1 Circuit Short to Vbatt
C1276 Park Brake Actuator Assembly Switch Applied Circuit Short to Gnd
C1277 STEERING Wheel Angle 1and 2 Circuit Failure
C1278 STEERING Wheel Angle 1and 2 Signal Faulted
C1279 Yaw Rate Sensor circuit Failure
C1280 Yaw Rate Sensor Signal Fault
C1281 Lateral Accelerometer circuit Failure
C1282 Lateral Accelerometer Signal Fault
C1283 Switch Test Signal Failure
C1284 Oil Pressure Switch Failure
C1285 Booster Solenoid circuit Failure
C1286 Booster Mechanical Failure
C1287 Booster Pedal Force switch circuit Failure
C1288 Pressure Transducer Main / Primary Input Circuit Failure
C1289 Pressure Transducer Redundant / Secondary Input Circuit Failure
C1400 Traction Control Valve RF Circuit Failure
C1401 Traction Control Valve RF Circuit Open
C1402 Traction Control Valve RF Circuit Short To Ground
C1403 Traction Control Valve RF Circuit Short To Battery
C1404 Traction Control Valve Rear Circuit Failure
C1405 Traction Control Valve Rear Circuit Open
C1406 Traction Control Valve Rear Circuit Short To Ground
C1407 Traction Control Valve Rear Circuit Short To Battery
C1410 Traction Control Valve LF Circuit Failure
C1411 Traction Control Valve LF Circuit Open
C1412 Traction Control Valve LF Circuit Short To Ground
C1413 Traction Control Valve LF Circuit Short To Battery
C1414 Incorrect Module Design Level
C1415 Incorrect Module Configuration
C1416 Damper RF Circuit Short To Battery
C1417 Damper RF Circuit Short to Ground
C1418 Damper RF Circuit Failure
C1419 Damper RF Circuit Open
C1420 Hydraulic Fluid Pressure/ Flow Circuit Short to Vbatt
C1421 Damper LF Circuit Short To Battery
C1422 Damper LF Circuit Short to Ground
C1423 Damper LF Circuit Failure
C1424 Damper LF Circuit Open
C1425 Damper RR Circuit Short to Ground
C1426 Damper RR Circuit Short To Battery
C1427 Damper RR Circuit Open
C1428 Damper RR Circuit Failure
C1429 Input-shaft-speed input circuit failure
C1430 Damper LR Circuit Open
C1431 Damper LR Circuit Short To Battery
C1432 Damper LR Circuit Short to Ground
C1433 Damper LR Circuit Failure
C1435 Accelerometer Rear Circuit Failure
C1436 Accelerometer Rear Circuit Signal Is Not Sensed
C1437 Accelerometer Rear Circuit Short To Ground
C1438 Accelerometer Rear Circuit Short To Battery
C1439 Vehicle Acceleration EEC-IV Circuit Failure
C1440 Pressure Transducer Main / Primary signal Faulted
C1441 Steering Phase A Circuit Signal Is Not Sensed
C1442 Steering Phase B Circuit Signal Is Not Sensed
C1443 Steering Phase A Circuit Short To Ground
C1444 Steering Phase B Circuit Short To Ground
C1445 Speed Vehicle Signal Circuit Failure
C1446 Brake Switch Circuit Failure
C1447 Traction Control Module Request Circuit Failure
C1448 Lamp Adaptive Damping Warning Circuit Failure
C1449 Traction Control Motor Coherency Fault
C1450 Traction Control Motor Circuit Failure
C1451 Traction Control Motor Circuit Open
C1452 Traction Control Motor Circuit Short to Battery
C1453 Traction Control Motor Circuit Short to Ground
C1454 Front Lateral Accelerometer Circuit Failure
C1455 Accelerometer Front Circuit Failure
C1456 Accelerometer Front Circuit Is Not Sensed
C1457 Accelerometer Front Circuit Short To Ground
C1458 Accelerometer Front Circuit Short To Battery
C1459 Adaptive Mode Switch Circuit Failure
C1460 Vehicle Accelerometer Power Circuit Failure
C1461 Vehicle Accelerometer Power Circuit Short to Battery
C1462 Left Front Vertical Accelerometer Circuit Failure
C1463 Right Front Vertical Accelerometer Circuit Failure
C1464 Pressure Transducer Redundant / Secondary Signal Faulted
C1465 Damper High Side Front Circuit Short To Battery
C1466 Damper Circuit Failure
C1467 Damper High Side Rear Circuit Short To Battery
C1468 Damper Low Side Front Circuit Failure
C1469 Damper Low Side Rear Circuit Failure
C1495 Traction Control Motor Potentiometer Circuit Failure
C1496 Traction Control Motor Potentiometer Circuit Open
C1497 Traction Control Motor Potentiometer Circuit Short to Battery
C1498 Traction Control Motor Potentiometer Circuit Short to Ground
C1499 Transfer Case Contact Plate "A" Encoder Circuit Failure
C1500 Transfer Case Contact Plate "B" Encoder Circuit Failure
C1501 Transfer Case Contact Plate "C" Encoder Circuit Failure
C1502 Transfer Case Contact Plate "D" Encoder Circuit Failure
C1503 Dynamic Stability Control Left Front Valve Malfunction
C1504 Dynamic Stability Control Right Front Valve Malfunction
C1505 Dynamic Stability Control Left Rear Valve Malfunction
C1506 Dynamic Stability Control Right Rear Valve Malfunction
C1507 Traction Control of Brake Exceeds Time-Out
C1508 Traction Control of Engine Exceeds Time-Out
C1510 Right Front Wheel Pressure Reduction Performance Problem
C1511 Left Front Wheel Pressure Reduction Performance Problem
C1512 Right Rear Wheel Pressure Reduction Performance Problem
C1513 Left rear Wheel Pressure Reduction Performance Problem
C1699 Left Rear Sensor Circuit Short to Vbat
C1700 Left Rear Sensor Circuit Failure
C1701 Left Rear Sensor Circuit Fault
C1702 RightRear Sensor Circuit Short to Vbat
C1703 Right Rear Sensor Circuit Failure
C1704 Right Rear Sensor Circuit Fault
C1705 Left Rear Center Sensor Circuit Short to Vbat
C1706 Left Rear Center Sensor Circuit Failure
C1707 Left Rear Center Sensor Circuit Fault
C1708 Right Rear Center Sensor Circuit Short to Vbat
C1709 Right Rear Center Sensor Circuit Failure
C1710 Right Rear Center Sensor Circuit Fault
C1711 Left Front Sensor Circuit Short to Vbat
C1712 Left Front Sensor Circuit Failure
C1713 Left Front Sensor Circuit Fault
C1714 Right Front Sensor Circuit Short to Vbat
C1715 Right Front Sensor Circuit Failure
C1716 Right Front Sensor Circuit Fault
C1717 Left Front Center Sensor Circuit Short to Vbat
C1718 Left Front Center Sensor Circuit Failure
C1719 Left Front Center Sensor Circuit Fault
C1721 Air Suspension Height Sensor Power Circuit Open
C1722 Air Suspension Height Sensor Power Circuit Short To Battery
C1723 Air Suspension Height Sensor Power Circuit Short To Ground
C1724 Air Suspension Height Sensor Power Circuit Failure
C1725 Air Suspension Front Pneumatic Failure
C1726 Air Suspension Rear Pneumatic Failure
C1727 Air Suspension Reservoir Pneumatic Failure
C1728 Transfer Case unable to transition between 2H and 4H
C1729 Transfer Case unable to transition between 4H and 4L
C1730 Reference Voltage Out of Range (+5 v)
C1731 Air Suspension LF Corner Up Timeout
C1732 Air Suspension LF Corner Down Timeout
C1733 Air Suspension RF Corner Up Timeout
C1734 Air Suspension RF Corner Down Timeout
C1735 Air Suspension LR Corner Up Timeout
C1736 Air Suspension LR Corner Down Timeout
C1737 Air Suspension RR Corner Up Timeout
C1738 Air Suspension RR Corner Down Timeout
C1739 Right Front Center Sensor Circuit Short to Vbat
C1740 Right Front Center Sensor Circuit Failure
C1741 Right Front Center Sensor Circuit Fault
C1742 Rear Sounder Circuit Failure
C1743 Rear Sounder Circuit Short to Vbatt
C1744 Front Sounder Circuit Failure
C1745 Front Sounder Circuit Short to Vbatt
C1748 Switch input Circuit Short to Gnd
C1749 Trailer Input Circuit Failure
C1750 Accelerator Position Sensor Out of Range
C1751 Vehicle Speed Sensor # 1 Output Circuit Short to Vbatt
C1752 Vehicle Speed Sensor # 1 Output Circuit Short to Gnd
C1753 Hydraulic Clutch Actuator Valve Signal Fault
C1754 Hydraulic Clutch Actuator Valve Circuit Failure
C1755 Power Limit Shutdown Fault
C1756 Air Suspension Front Height Sensor High (SE) Signal Circuit Failure
C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open
C1758 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Battery
C1759 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Ground
C1760 Air Suspension Rear Height Sensor High (SE) Signal Circuit Failure
C1761 Air Suspension Rear Height Sensor High (SE) Signal Circuit Open
C1762 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Battery
C1763 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Ground
C1765 Air Suspension Rear Height Sensor Low Signal Circuit Failure
C1766 Air Suspension Rear Height Sensor Low Signal Circuit Open
C1767 Air Suspension Rear Height Sensor Low Signal Circuit Short To Battery
C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short To Ground
C1770 Air Suspension Vent Solenoid Output Circuit Failure
C1771 Air Suspension Vent Solenoid Output Circuit Open
C1772 Air Suspension Vent Solenoid Output Circuit Short To Battery
C1773 Air Suspension Vent Solenoid Output Circuit Short To Ground
C1774 Coolant Temp Out of Range
C1775 DC-DC Converter Failure
C1776 Heater System Failure
C1777 Vacuum Pressure Circuit Failure
C1778 Power Steering Failure
C1779 Blower Switch Failure
C1780 Temperature Select Failure
C1781 Engine Coolant Temperature Signal Missing/Fault
C1790 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Failure
C1791 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Open
C1792 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Battery
C1793 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Ground
C1795 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Failure
C1796 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Open
C1797 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Battery
C1798 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Ground
C1800 Air Suspension Reservoir Solenoid Circuit Failure
C1805 Mismatched PCM and/or ABS-TC Module
C1813 Air Suspension LR Vent Request Exceeded Max Timing
C1814 Air Suspension RR Vent Request Exceeded Max Timing
C1818 Air Suspension LR Air Compress Request Exceeded Max Timing
C1819 Air Suspension RR Air Compress Request Exceeded Max Timing
C1820 Air Suspension RF Air Compress Request Exceeded Max Timing
C1830 Air Suspension Compressor Relay Circuit Failure
C1831 Air Suspension Compressor Relay Circuit Open
C1832 Air Suspension Compressor Relay Circuit Short To Battery
C1833 Air Suspension Compressor Relay Circuit Short To Ground
C1834 Gauge Drive Current Fault
C1835 Current Sense Circuit Failure
C1836 Battery Temp out of Range
C1837 Battery Heater Circuit Failure
C1838 Charging System Fault
C1839 Leakage Fault
C1840 Air Suspension Disable Switch Circuit Failure
C1841 Air Suspension Disable Switch Circuit Open
C1842 Air Suspension Disable Switch Circuit Short To Battery
C1843 Air Suspension Disable Switch Circuit Short To Ground
C1844 Air Suspension Secondary Front Inflator Solenoid Output Circuit Failure
C1845 Air Suspension Front Inflator Solenoid Output Circuit Failure
C1846 Air Suspension Front Inflator Solenoid Output Circuit Open
C1847 Air Suspension Front Inflator Solenoid Output Circuit Short To Battery
C1848 Air Suspension Front Inflator Solenoid Output Circuit Short To Ground
C1849 Master Cylinder Pressure Out of Range
C1850 Air Suspension Warning Lamp Circuit Failure
C1851 Air Suspension Warning Lamp Circuit Open
C1852 Air Suspension Warning Lamp Circuit Short To Battery
C1853 Air Suspension Warning Lamp Circuit Short To Ground
C1854 Motor Temperature Out of Range
C1855 Acceleration Position Sensor Conflict
C1856 Traction Motor Encoder circuit Failure
C1859 PRNDL Input #2 Circuit Failure
C1860 PRNDL Input #3 Circuit Failure
C1861 PRNDL Input #4 Circuit Failure
C1862 Contactor Circuit Failure
C1863 External Charging Fault
C1864 Battery Module Fault
C1865 Air Suspension Rear Inflator Solenoid Output Circuit Failure
C1866 Air Suspension Rear Inflator Solenoid Output Circuit Open
C1867 Air Suspension Rear Inflator Solenoid Output Circuit Short To Battery
C1868 Air Suspension Rear Inflator Solenoid Output Circuit Short To Ground
C1869 Air Suspension Gate Solenoid Output Circuit Failure
C1870 Air Suspension Gate Solenoid Output Circuit Open
C1871 Air Suspension Gate Solenoid Output Circuit Short To Battery
C1872 Air Suspension Gate Solenoid Output Circuit Short To Ground
C1873 Air Suspension RF Air Spring Solenoid Output Circuit Failure
C1874 Air Suspension RF Air Spring Solenoid Output Circuit Open
C1875 Air Suspension RF Air Spring Solenoid Output Circuit Short To Battery
C1876 Air Suspension RF Air Spring Solenoid Output Circuit Short To Ground
C1877 Air Suspension LF Air Spring Solenoid Output Circuit Failure
C1878 Air Suspension LF Air Spring Solenoid Output Circuit Open
C1879 Air Suspension LF Air Spring Solenoid Output Circuit Short To Battery
C1880 Air Suspension LF Air Spring Solenoid Output Circuit Short To Ground
C1881 Air Suspension RF Height Sensor Circuit Failure
C1882 Air Suspension RF Height Sensor Circuit Open
C1883 Air Suspension RF Height Sensor Circuit Short To Battery
C1884 Air Suspension RF Height Sensor Circuit Short To Ground
C1885 Air Suspension RR Height Sensor Circuit Failure
C1886 Air Suspension RR Height Sensor Circuit Open
C1887 Air Suspension RR Height Sensor Circuit Short To Battery
C1888 Air Suspension RR Height Sensor Circuit Short To Ground
C1889 Air Suspension LF Height Sensor Circuit Failure
C1890 Air Suspension LF Height Sensor Circuit Open
C1891 Air Suspension LF Height Sensor Circuit Short To Battery
C1892 Air Suspension LF Height Sensor Circuit Short To Ground
C1893 Air Suspension LR Height Sensor Circuit Failure
C1894 Air Suspension LR Height Sensor Circuit Open
C1895 Air Suspension LR Height Sensor Circuit Short To Battery
C1896 Air Suspension LR Height Sensor Circuit Short To Ground
C1897 Steering VAPS II Circuit Loop Failure
C1898 Steering VAPS II Circuit Loop Open
C1899 Steering VAPS II Circuit Loop Short To Battery
C1900 Steering VAPS II Circuit Loop Short To Ground
C1901 Ride Control RR Shock Actuator Circuit Failure
C1902 Ride Control RR Shock Actuator Circuit Open
C1903 Ride Control RR Shock Actuator Circuit Short To Battery
C1904 Ride Control RR Shock Actuator Circuit Short To Ground
C1905 Ride Control LR Shock Actuator Circuit Failure
C1906 Ride Control LR Shock Actuator Circuit Open
C1907 Ride Control LR Shock Actuator Circuit Short To Battery
C1908 Ride Control LR Shock Actuator Circuit Short To Ground
C1909 Ride Control RF Shock Actuator Circuit Failure
C1910 Ride Control RF Shock Actuator Circuit Open
C1911 Ride Control RF Shock Actuator Circuit Short To Battery
C1912 Ride Control RF Shock Actuator Circuit Short To Ground
C1913 Ride Control LF Shock Actuator Circuit Failure
C1914 Ride Control LF Shock Actuator Circuit Open
C1915 Ride Control LF Shock Actuator Circuit Short To Battery
C1916 Ride Control LF Shock Actuator Circuit Short To Ground
C1917 Steering EVO Out-of-Range Fault
C1918 Air Suspension Ride Height Select Switch Circuit Failure
C1920 Led #1 Circuit Failure
C1921 VAPS Solenoid Actuator Output Circuit Failure
C1922 VAPS Solenoid Actuator Output Circuit Open
C1923 VAPS Solenoid Actuator Output Circuit Short To Battery
C1924 VAPS Solenoid Actuator Output Circuit Short To Ground
C1925 VAPS Solenoid Actuator Return Circuit Failure
C1926 VAPS Solenoid Actuator Return Circuit Open
C1927 VAPS Solenoid Actuator Return Circuit Short To Battery
C1928 VAPS Solenoid Actuator Return Circuit Short To Ground
C1929 Air Suspension Front Compressor Relay Circuit Failure
C1930 Air Suspension Front Compressor Relay Circuit Open
C1931 Air Suspension Front Compressor Relay Circuit Short To Battery
C1932 Air Suspension Front Compressor Relay Circuit Short To Ground
C1933 Solenoid Current Out Of Range
C1934 HPU (Hydraulic Pump Unit) Pressurisation Failure
C1935 Chime Circuit Failure
C1936 Hydraulic Pump Relay Circuit Failure
C1937 Steering Wheel Angle Sensor Offset Failure
C1938 Invalid Steering Wheel Angle Sensor ID
C1939 Brake Pressure Switch Input Circuit Failure
C1940 Brake Pressure Switch Mechanical Failure
C1942 Unrecognized Powertrain Configuration
C1943 Airbag Deployment Indication Input Fault
C1944 Gauge Driver Circuit Fault
C1945 Park Switch Indicates Park with Vehicle Moving
C1946 Seat Track Position Switch Circuit Open
C1947 Seat Track Position Switch Circuit Short to Ground
C1948 Seat Track Position Switch Circuit Resistance Out of Range
C1949 Accelerometer Sensor Circuit Open
C1950 Accelerometer Sensor Circuit Failure
C1951 Lateral Accelerometer Sensor Circuit Open
C1952 Yaw Rate Sensor Circuit Open
C1953 Master Cylinder Pressure Sensor Circuit Open
C1954 Master Cylinder Pressure Sensor Circuit Failure
C1955 Steering Angle Sensor Circuit Open
C1956 Steering Angle Sensor Circuit Failure
C1957 Dynamic Stability Control Valve RF Circuit Failure
C1958 Dynamic Stability Control Valve LF Circuit Failure
C1959 Lateral Accelerometer Sensor Circuit Failure
C1960 Driver Brake Apply Circuit Fault
C1961 Park Lamp Relay Coil Circuit Failure
C1962 Park Lamp Relay Coil Short to Battery
C1963 Stability Control Inhibit Warning
B1200 Climate Control Pushbutton Circuit Failure
B1201 Fuel Sender Circuit Failure
B1202 Fuel Sender Circuit Open
B1203 Fuel Sender Circuit Short To Battery
B1204 Fuel Sender Circuit Short To Ground
B1205 EIC Switch-1 Assembly Circuit Failure
B1206 EIC Switch-1 Assembly Circuit Open
B1207 EIC Switch-1 Assembly Circuit Short To Battery
B1208 EIC Switch-1 Assembly Circuit Short To Ground
B1209 EIC Switch-2 Assembly Circuit Failure
B1210 EIC Switch-2 Assembly Circuit Open
B1211 EIC Switch-2 Assembly Circuit Short To Battery
B1212 EIC Switch-2 Assembly Circuit Short To Ground
B1213 Anti-Theft Number of Programmed Keys Is Below Minimum
B1214 Running Board Lamp Circuit Failure
B1215 Running Board Lamp Circuit Short to Battery
B1216 Emergency & Road Side Assistance Switch Circuit Short to Ground
B1217 Horn Relay Coil Circuit Failure
B1218 Horn Relay Coil Circuit Short to Vbatt
B1219 Fuel Tank Pressure Sensor Circuit Failure
B1220 Fuel Tank Pressure Sensor Circuit Open
B1222 Fuel Temperature Sensor #1 Circuit Failure
B1223 Fuel Temperature Sensor #1 Circuit Open
B1224 Fuel Temperature Sensor #1 Circuit Short to Battery
B1225 Fuel Temperature Sensor #1 Circuit Short to Ground
B1226 Fuel Temperature Sensor #2 Circuit Failure
B1227 Fuel Temperature Sensor #2 Circuit Open
B1228 Fuel Temperature Sensor #2 Circuit Short to Battery
B1229 Fuel Temperature Sensor #2 Circuit Short to Ground
B1231 Longitudinal Acceleration Threshold Exceeded
B1232 See Manufacturer
B1233 Glass Break Sensor Failure
B1234 Mirror Switch Invalid Code
B1235 Window Feedback Failure
B1236 Window Feedback Loss of Signal
B1237 Window Feedback Out of Range
B1238 Over Temperature Fault
B1239 Air Flow Blend Door Driver Circuit Failure
B1240 Wiper Washer Rear Pump Relay Circuit Failure
B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery
B1242 Air Flow Recirculation Door Driver Circuit Failure
B1243 Express Window Down Switch Circuit Short to Battery
B1244 Wiper Rear Motor Run Relay Circuit Failure
B1245 Wiper Rear Motor Run Relay Circuit Short to Battery
B1246 Dim Panel Potentiometer Switch Circuit Failure
B1247 Panel Dim Switch Circuit Open
B1248 Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground
B1249 Blend Door Failure
B1250 Air Temperature Internal Sensor Circuit Failure
B1251 Air Temperature Internal Sensor Circuit Open
B1252 Air Temperature Internal Sensor Circuit Short To Battery
B1253 Air Temperature Internal Sensor Circuit Short To Ground
B1254 Air Temperature External Sensor Circuit Failure
B1255 Air Temperature External Sensor Circuit Open
B1256 Air Temperature External Sensor Circuit Short To Battery
B1257 Air Temperature External Sensor Circuit Short To Ground
B1258 Solar Radiation Sensor Circuit Failure
B1259 Solar Radiation Sensor Circuit Open
B1260 Solar Radiation Sensor Circuit Short To Battery
B1261 Solar Radiation Sensor Circuit Short To Ground
B1262 Servo Motor Defrost Circuit Failure
B1263 Servo Motor Vent Circuit Failure
B1264 Servo Motor Foot Circuit Failure
B1265 Servo Motor Coolair Bypass Circuit Failure
B1266 Servo Motor Airintake Left Circuit Failure
B1267 Servo Motor Airintake Right Circuit Failure
B1268 Servo Motor Potentiometer Defrost Circuit Failure
B1269 Servo Motor Potentiometer Defrost Circuit Open
B1270 Servo Motor Potentiometer Defrost Circuit Short To Battery
B1271 Servo Motor Potentiometer Defrost Circuit Short To Ground
B1272 Servo Motor Potentiometer Vent Circuit Failure
B1273 Servo Motor Potentiometer Vent Circuit Open
B1274 Servo Motor Potentiometer Vent Circuit Short To Battery
B1275 Servo Motor Potentiometer Vent Circuit Short To Ground
B1276 Servo Motor Potentiometer Foot Circuit Failure
B1277 Servo Motor Potentiometer Foot Circuit Open
B1278 Servo Motor Potentiometer Foot Circuit Short To Battery
B1279 Servo Motor Potentiometer Foot Circuit Short To Ground
B1280 Servo Motor Potentiometer Coolair Circuit Failure
B1281 Servo Motor Potentiometer Coolair Circuit Open
B1282 Servo Motor Potentiometer Coolair Circuit Short To Battery
B1283 Servo Motor Potentiometer Coolair Circuit Short To Ground
B1284 Servo Motor Potentiometer Airintake Left Circuit Failure
B1285 Servo Motor Potentiometer Airintake Left Circuit Open
B1286 Servo Motor Potentiometer Airintake Left Circuit Short To Battery
B1287 Servo Motor Potentiometer Airintake Left Circuit Short To Ground
B1288 Servo Motor Potentiometer Airintake Right Circuit Failure
B1289 Servo Motor Potentiometer Airintake Right Circuit Open
B1290 Servo Motor Potentiometer Airintake Right Circuit Short To Battery
B1291 Servo Motor Potentiometer Airintake Right Circuit Short To Ground
B1292 Battery Power Relay Circuit Failure
B1293 Battery Power Relay Circuit Open
B1294 Battery Power Relay Circuit Short To Battery
B1295 Battery Power Relay Circuit Short To Ground
B1296 Power Supply Sensor Circuit Failure
B1297 Power Supply Sensor Circuit Open
B1298 Power Supply Sensor Circuit Short To Battery
B1299 Power Supply Sensor Circuit Short To Ground
B1300 Power Door Lock Circuit Failure
B1301 Power Door Lock Circuit Open
B1302 Accessory Delay Relay Coil Circuit Failure
B1303 Accessory Delay Relay Coil Circuit Open
B1304 Accessory Delay Relay Coil Circuit Short To Battery
B1305 Accessory Delay Relay Coil Circuit Short To Ground
B1306 Oil Level Switch Circuit Open
B1307 Oil Level Switch Circuit Short To Battery
B1308 Oil Level Switch Circuit Short To Ground
B1309 Power Door Lock Circuit Short To Ground
B1310 Power Door Unlock Circuit Failure
B1311 Power Door Unlock Circuit Open
B1312 Lamp Headlamp Input Circuit Short To Battery
B1313 Battery Saver Relay Coil Circuit Failure
B1314 Battery Saver Relay Coil Circuit Open
B1315 Battery Saver Relay Coil Circuit Short To Battery
B1316 Battery Saver Relay Coil Circuit Short To Ground
B1317 Battery Voltage High
B1318 Battery Voltage Low
B1319 Driver Door Ajar Circuit Failure
B1320 Driver Door Ajar Circuit Open
B1321 Driver Door Ajar Circuit Short To Battery
B1322 Driver Door Ajar Circuit Short To Ground
B1323 Door Ajar Lamp Circuit Failure
B1324 Door Ajar Lamp Circuit Open
B1325 Door Ajar Lamp Circuit Short To Battery
B1326 Door Ajar Lamp Circuit Short To Ground
B1327 Passenger Door Ajar Circuit Failure
B1328 Passenger Door Ajar Circuit Open
B1329 Passenger Door Ajar Circuit Short To Battery
B1330 Passenger Door Ajar Circuit Short To Ground
B1331 Decklid Ajar Rear Door Circuit Failure
B1332 Decklid Ajar Rear Door Circuit Open
B1333 Decklid Ajar Rear Door Circuit Short To Battery
B1334 Decklid Ajar Rear Door Circuit Short To Ground
B1335 Door Ajar RR Circuit Failure
B1336 Door Ajar RR Circuit Open
B1337 Door Ajar RR Circuit Short To Battery
B1338 Door Ajar RR Circuit Short To Ground
B1339 Chime Input Request Circuit Short To Battery
B1340 Chime Input Request Circuit Short To Ground
B1341 Power Door Unlock Circuit Short To Ground
B1342 ECU Is Defective
B1343 Heated Backlite Input Circuit Failure
B1344 Heated Backlite Input Circuit Open
B1345 Heated Backlite Input Circuit Short To Ground
B1346 Heated Backlite Input Circuit Short To Battery
B1347 Heated Backlite Relay Circuit Failure
B1348 Heated Backlite Relay Circuit Open
B1349 Heated Backlite Relay Short To Battery
B1350 Heated Backlite Relay Short To Ground
B1351 Ignition Key-In Circuit Short To Battery
B1352 Ignition Key-In Circuit Failure
B1353 Ignition Key-In Circuit Open
B1354 Ignition Key-In Circuit Short To Ground
B1355 Ignition Run Circuit Failure
B1356 Ignition Run Circuit Open
B1357 Ignition Run Circuit Short To Battery
B1358 Ignition Run Circuit Short To Ground
B1359 Ignition Run/Acc Circuit Failure
B1360 Ignition Run/Acc Circuit Open
B1361 Ignition Run/Acc Circuit Short To Battery
B1362 Ignition Run/Acc Circuit Short To Ground
B1363 Ignition Start Circuit Failure
B1364 Ignition Start Circuit Open
B1365 Ignition Start Circuit Short To Battery
B1366 Ignition Start Circuit Short To Ground
B1367 Ignition Tach Circuit Failure
B1368 Ignition Tach Circuit Open
B1369 Ignition Tach Circuit Short To Battery
B1370 Ignition Tach Circuit Short To Ground
B1371 Illuminated Entry Relay Circuit Failure
B1372 Illuminated Entry Relay Circuit Open
B1373 Illuminated Entry Relay Short To Battery
B1374 Illuminated Entry Relay Short To Ground
B1375 Oil Change Lamp Circuit Open
B1376 Oil Change Lamp Circuit Short To Battery
B1377 Oil Change Lamp Circuit Failure
B1378 Oil Change Lamp Circuit Short To Ground
B1379 Oil Change Reset Button Circuit Short To Ground
B1380 Oil Change Reset Button Circuit Failure
B1381 Oil Change Reset Button Circuit Open
B1382 Oil Change Reset Button Circuit Short To Battery
B1383 Oil Level Lamp Circuit Short To Battery
B1384 Oil Level Lamp Circuit Failure
B1385 Oil Level Lamp Circuit Open
B1386 Oil Level Lamp Circuit Short To Ground
B1387 Oil Temperature Sensor Circuit Open
B1388 Oil Temperature Sensor Circuit Short To Battery
B1389 Oil Temperature Sensor Circuit Failure
B1390 Oil Temperature Sensor Circuit Short To Ground
B1391 Oil Level Switch Circuit Failure
B1392 Power Door Memory Lock Relay Circuit Failure
B1393 Power Door Memory Lock Relay Circuit Open
B1394 Power Door Memory Lock Relay Circuit Short To Battery
B1395 Power Door Memory Lock Relay Circuit Short To Ground
B1396 Power Door Lock Circuit Short To Battery
B1397 Power Door Unlock Circuit Short To Battery
B1398 Driver Power Window One Touch Window Relay Circuit Failure
B1399 Driver Power Window One Touch Window Relay Circuit Open
B1400 Driver Power Window One Touch Window Relay Circuit Short To Battery
B1401 Driver Power Window One Touch Window Relay Circuit Short To Ground
B1402 Driver Power Window Down Switch Circuit Failure
B1403 Driver Power Window Up Switch Circuit Failure
B1404 Driver Power Window Down Circuit Open
B1405 Driver Power Window Down Circuit Short To Battery
B1406 Driver Power Window Down Circuit Short To Ground
B1407 Driver Power Window Up Circuit Open
B1408 Driver Power Window Up Circuit Short To Battery
B1409 Driver Power Window Up Circuit Short To Ground
B1410 Driver Power Window Motor Circuit Failure
B1411 Driver Power Window Motor Circuit Open
B1412 Driver Power Window Motor Circuit Short To Battery
B1413 Driver Power Window Motor Circuit Short To Ground
B1414 Power Window LR Motor Circuit Failure
B1415 Power Window LR Motor Circuit Open
B1416 Power Window LR Motor Circuit Short To Battery
B1417 Power Window LR Motor Circuit Short To Ground
B1418 Passenger Power Window Motor Circuit Failure
B1419 Passenger Power Window Motor Circuit Open
B1420 Passenger Power Window Motor Circuit Short To Battery
B1421 Passenger Power Window Motor Circuit Short To Ground
B1422 Power Window RR Motor Circuit Failure
B1423 Power Window RR Motor Circuit Open
B1424 Power Window RR Motor Circuit Short To Battery
B1425 Power Window RR Motor Circuit Short To Ground
B1426 Lamp Seat Belt Circuit Short To Battery
B1427 Lamp Seat Belt Circuit Open
B1428 Lamp Seat Belt Circuit Failure
B1429 Lamp Seat Belt Circuit Short To Ground
B1430 Seat Belt Switch Circuit Short To Ground
B1431 Wiper Brake/Run Relay Circuit Failure
B1432 Wiper Brake/Run Relay Circuit Short To Battery
B1433 Wiper Brake/Run Relay Circuit Short To Ground
B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure
B1435 Wiper Hi/Low Speed Relay Coil Circuit Open
B1436 Wiper Hi/Low Speed Relay Coil Circuit Short To Battery
B1437 Wiper Hi/Low Speed Relay Coil Circuit Short To Ground
B1438 Wiper Mode Select Switch Circuit Failure
B1439 Wiper Mode Select Switch Circuit Open
B1440 Wiper Mode Select Switch Circuit Short To Battery
B1441 Wiper Mode Select Switch Circuit Short To Ground
B1442 Door Handle Switch Circuit Failure
B1443 Door Handle Switch Circuit Open
B1444 Door Handle Switch Circuit Short To Battery
B1445 Door Handle Switch Circuit Short To Ground
B1446 Wiper Park Sense Circuit Failure
B1447 Wiper Park Sense Circuit Open
B1448 Wiper Park Sense Circuit Short To Battery
B1449 Wiper Park Sense Circuit Short To Ground
B1450 Wiper Wash/Delay Switch Circuit Failure
B1451 Wiper Wash/Delay Switch Circuit Open
B1452 Wiper Wash/Delay Switch Circuit Short To Battery
B1453 Wiper Wash/Delay Switch Circuit Short To Ground
B1454 Wiper Washer Fluid Lamp Circuit Failure
B1455 Wiper Washer Fluid Lamp Circuit Open
B1456 Wiper Washer Fluid Lamp Circuit Short To Battery
B1457 Wiper Washer Fluid Lamp Circuit Short To Ground
B1458 Wiper Washer Pump Motor Relay Circuit Failure
B1459 Wiper Washer Pump Motor Relay Coil Circuit Open
B1460 Wiper Washer Pump Motor Relay Coil Circuit Short To Battery
B1461 Wiper Washer Pump Motor Relay Coil Circuit Short To Ground
B1462 Seat Belt Switch Circuit Failure
B1463 Seat Belt Switch Circuit Open
B1464 Seat Belt Switch Circuit Short To Battery
B1465 Wiper Brake/Run Relay Circuit Open
B1466 Wiper Hi/Low Speed Not Switching
B1467 Wiper Hi/Low Speed Circuit Motor Short To Battery
B1468 Chime Input Request Circuit Failure
B1469 Chime Input Request Circuit Open
B1470 Lamp Headlamp Input Circuit Failure
B1471 Lamp Headlamp Input Circuit Open
B1472 Lamp Headlamp Input Circuit Short To Ground
B1473 Wiper Low Speed Circuit Motor Failure
B1474 Battery Saver Power Relay Circuit Short To Battery
B1475 Accessory Delay Relay Contact Short To Battery
B1476 Wiper High Speed Circuit Motor Failure
B1477 Wiper Hi/Low Circuit Motor Short To Ground
B1478 Power Window One Touch Up/Down Activated Simultaneously
B1479 Wiper Washer Fluid Level Sensor Circuit Failure
B1480 Wiper Washer Fluid Level Sensor Circuit Open
B1481 Wiper Washer Fluid Level Sensor Circuit Short To Battery
B1482 Wiper Washer Fluid Level Sensor Circuit Short To Ground
B1483 Brake Pedal Input Circuit Failure
B1484 Brake Pedal Input Open Circuit
B1485 Brake Pedal Input Circuit Battery Short
B1486 Brake Pedal Input Circuit Ground Short
B1487 Door Handle Right Front Circuit Failure
B1488 Door Handle Right Front Circuit Open
B1489 Door Handle Right Front Short To Battery
B1490 Door Handle Right Front Short To Ground
B1491 Ignition Cylinder Sensor Circuit Failure
B1492 Ignition Cylinder Sensor Open Circuit
B1493 Ignition Cylinder Sensor Battery Short
B1494 Ignition Cylinder Sensor Ground Short
B1495 Decklid Punch-Out Sensor Circuit Failure
B1496 Decklid Punch-Out Sensor Open Circuit
B1497 Decklid Punch-Out Sensor Battery Short
B1498 Decklid Punch-Out Sensor Ground Short
B1499 Lamp Turn Signal Left Circuit Failure
B1500 Lamp Turn Signal Left Circuit Open
B1501 Lamp Turn Signal Left Circuit Short To Battery
B1502 Lamp Turn Signal Left Circuit Short To Ground
B1503 Lamp Turn Signal Right Circuit Failure
B1504 Lamp Turn Signal Right Circuit Open
B1505 Lamp Turn Signal Right Circuit Short To Battery
B1506 Lamp Turn Signal Right Circuit Short To Ground
B1507 Flash To Pass Switch Circuit Failure
B1508 Flash To Pass Switch Circuit Open
B1509 Flash To Pass Switch Circuit Short To Battery
B1510 Flash To Pass Switch Circuit Short To Ground
B1511 Driver Door Handle Circuit Failure
B1512 Driver Door Handle Circuit Open
B1513 Driver Door Handle Circuit Short To Battery
B1514 Driver Door Handle Circuit Short To Ground
B1515 Seat Driver Occupied Switch Circuit Failure
B1516 Seat Driver Occupied Switch Circuit Open
B1517 Seat Driver Occupied Switch Circuit Short To Battery
B1518 Seat Driver Occupied Switch Circuit Short To Ground
B1519 Hood Switch Circuit Failure
B1520 Hood Switch Circuit Open
B1521 Hood Switch Circuit Short To Battery
B1522 Hood Switch Circuit Short To Ground
B1523 Keyless Entry Circuit Failure
B1524 Keyless Entry Circuit Open
B1525 Keyless Entry Circuit Short To Battery
B1526 Keyless Entry Circuit Short To Ground
B1527 Memory Set Switch Circuit Failure
B1528 Memory Set Switch Circuit Open
B1529 Memory Set Switch Circuit Short To Battery
B1530 Memory Set Switch Circuit Short To Ground
B1531 Memory 1 Switch Circuit Failure
B1532 Memory 1 Switch Circuit Open
B1533 Memory 1 Switch Circuit Short To Battery
B1534 Memory 1 Switch Circuit Short To Ground
B1535 Memory 2 Switch Circuit Failure
B1536 Memory 2 Switch Circuit Open
B1537 Memory 2 Switch Circuit Short To Battery
B1538 Memory 2 Switch Circuit Short To Ground
B1539 Mirror Driver Switch Assembly Circuit Failure
B1540 Mirror Driver Switch Assembly Circuit Open
B1541 Mirror Driver Switch Assembly Circuit Short To Battery
B1542 Mirror Driver Switch Assembly Circuit Short To Ground
B1543 Seat Direction Switch Assembly Circuit Failure
B1544 Seat Direction Switch Assembly Circuit Open
B1545 Seat Direction Switch Assembly Circuit Short To Battery
B1546 Seat Direction Switch Assembly Circuit Short To Ground
B1547 Power Window Master Circuit Failure
B1548 Power Window Master Circuit Open
B1549 Power Window Master Circuit Short To Battery
B1550 Power Window Master Circuit Short To Ground
B1551 Decklid Release Circuit Failure
B1552 Decklid Release Circuit Open
B1553 Decklid Release Circuit Short To Battery
B1554 Decklid Release Circuit Short To Ground
B1555 Ignition Run/Start Circuit Failure
B1556 Ignition Run/Start Circuit Open
B1557 Ignition Run/Start Circuit Short To Battery
B1558 Ignition Run/Start Circuit Short To Ground
B1559 Door Lock Cylinder Circuit Failure
B1560 Door Lock Cylinder Circuit Open
B1561 Door Lock Cylinder Circuit Short To Battery
B1562 Door Lock Cylinder Circuit Short To Ground
B1563 Door Ajar Circuit Failure
B1564 Door Ajar Circuit Open
B1565 Door Ajar Circuit Short To Battery
B1566 Door Ajar Circuit Short To Ground
B1567 Lamp Headlamp High-Beam Circuit Failure
B1568 Lamp Headlamp High-Beam Circuit Open
B1569 Lamp Headlamp High-Beam Circuit Short To Battery
B1570 Lamp Headlamp High-Beam Circuit Short To Ground
B1571 Door Ajar LR Circuit Failure
B1572 Door Ajar LR Circuit Open
B1573 Door Ajar LR Circuit Short To Battery
B1574 Door Ajar LR Circuit Short To Ground
B1575 Lamp Park Input Circuit Failure
B1576 Lamp Park Input Circuit Open
B1577 Lamp Park Input Circuit Short To Battery
B1578 Lamp Park Input Circuit Short To Ground
B1579 Dim Panel Increase Input Circuit Failure
B1580 Dim Panel Increase Input Circuit Open
B1581 Dim Panel Increase Input Circuit Short To Battery
B1582 Dim Panel Increase Input Circuit Short To Ground
B1583 Dim Panel Decrease Input Circuit Failure
B1584 Dim Panel Decrease Input Circuit Open
B1585 Dim Panel Decrease Input Circuit Short To Battery
B1586 Dim Panel Decrease Input Circuit Short To Ground
B1587 Autolamp Delay Increase Circuit Failure
B1588 Autolamp Delay Increase Circuit Open
B1589 Autolamp Delay Increase Circuit Short To Battery
B1590 Autolamp Delay Increase Circuit Short To Ground
B1591 Autolamp Delay Decrease Circuit Failure
B1592 Autolamp Delay Decrease Circuit Open
B1593 Autolamp Delay Decrease Circuit Short To Battery
B1594 Autolamp Delay Decrease Circuit Short To Ground
B1595 Ignition Switch Illegal Input Code
B1596 Service Continuous Codes
B1597 Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground
B1598 Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground
B1599 Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground
B1600 PATS Ignition Key Transponder Signal Is Not Received
B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
B1603 Lamp Anti-Theft Indicator Circuit Failure
B1604 Lamp Anti-Theft Indicator Circuit Open
B1605 Lamp Anti-Theft Indicator Circuit Short To Battery
B1606 Lamp Anti-Theft Indicator Circuit Short To Ground
B1607 Illuminated Entry Input Circuit Failure
B1608 Illuminated Entry Input Open Circuit
B1609 Illuminated Entry Input Short Circuit To Battery
B1610 Illuminated Entry Input Short Circuit To Ground
B1611 Wiper Rear Mode Select Switch Circuit Failure
B1612 Wiper Rear Mode Select Switch Circuit Open
B1613 Wiper Rear Mode Select Switch Circuit Short To Battery
B1614 Wiper Rear Mode Select Switch Circuit Short To Ground
B1615 Wiper Rear Disable Switch Circuit Failure
B1616 Wiper Rear Disable Switch Circuit Open
B1617 Wiper Rear Disable Switch Circuit Short To Battery
B1618 Wiper Rear Disable Switch Circuit Short To Ground
B1619 Wiper Rear Low Limit Input Circuit Failure
B1620 Wiper Rear Low Limit Input Circuit Open
B1621 Wiper Rear Low Limit Input Circuit Short To Battery
B1622 Wiper Rear Low Limit Input Circuit Short To Ground
B1623 Lamp Keypad Output Circuit Failure
B1624 Lamp Keypad Output Open Circuit
B1625 Lamp Keypad Output Short Circuit To Battery
B1626 Lamp Keypad Output Short Circuit To Ground
B1627 PRNDL Reverse Input Circuit Failure
B1628 PRNDL Reverse Input Open Circuit
B1629 PRNDL Reverse Input Short To Battery
B1630 PRNDL Reverse Input Short Circuit To Ground
B1631 Mirror Driver Left Circuit Failure
B1632 Mirror Driver Left Circuit Open
B1633 Mirror Driver Left Circuit Short To Battery
B1634 Mirror Driver Left Circuit Short To Ground
B1635 Mirror Driver Right Circuit Failure
B1636 Mirror Driver Right Circuit Open
B1637 Mirror Driver Right Circuit Short To Battery
B1638 Mirror Driver Right Short To Ground
B1639 Mirror Passenger Left Circuit Failure
B1640 Mirror Passenger Left Circuit Open
B1641 Mirror Passenger Left Circuit Short To Battery
B1642 Mirror Passenger Left Circuit Short To Ground
B1643 Mirror Passenger Right Circuit Failure
B1644 Mirror Passenger Right Circuit Open
B1645 Mirror Passenger Right Circuit Short To Battery
B1646 Mirror Passenger Right Circuit Short To Ground
B1647 Seat Driver Recline Forward Circuit Failure
B1648 Seat Driver Recline Forward Circuit Open
B1649 Seat Driver Recline Forward Circuit Short To Battery
B1650 Seat Driver Recline Forward Circuit Short To Ground
B1651 Seat Driver Recline Backward Circuit Failure
B1652 Seat Driver Recline Backward Circuit Open
B1653 Seat Driver Recline Backward Circuit Short To Battery
B1654 Seat Driver Recline Backward Circuit Short To Ground
B1655 Seat Driver Rear Up Circuit Failure
B1656 Seat Driver Rear Up Circuit Open
B1657 Seat Driver Rear Up Circuit Short To Battery
B1658 Seat Driver Rear Up Circuit Short To Ground
B1659 Seat Driver Front Up Circuit Failure
B1660 Seat Driver Front Up Circuit Open
B1661 Seat Driver Front Up Circuit Short To Battery
B1662 Seat Driver Front Up Circuit Short To Ground
B1663 Seat Driver Front Up/Down Motor Stalled
B1664 Seat Driver Rear Up/Down Motor Stalled
B1665 Seat Driver Forward/Backward Motor Stalled
B1666 Seat Driver Recline Motor Stalled
B1667 Mirror Driver Up/Down Motor Stalled
B1668 Mirror Driver Right/Left Motor Stalled
B1669 Mirror Passenger Up/Down Motor Stalled
B1670 Mirror Passenger Right/Left Motor Stalled
B1671 Battery Module Voltage Out Of Range
B1672 Seat Driver Occupied Input Circuit Failure
B1673 Seat Driver Occupied Input Circuit Open
B1674 Seat Driver Occupied Input Circuit Short To Battery
B1675 Seat Driver Occupied Input Circuit Short To Ground
B1676 Battery Pack Voltage Out Of Range
B1677 Alarm Panic Input Circuit Failure
B1678 Alarm Panic Input Circuit Open
B1679 Alarm Panic Input Circuit Short To Battery
B1680 Alarm Panic Input Circuit Short To Ground
B1681 PATS Transceiver Module Signal Is Not Received
B1682 PATS Is Disabled (Check Link Between PATS And Transponder)
B1683 Mirror Driver/Passenger Switch Circuit Failure
B1684 Mirror Driver/Passenger Switch Circuit Open
B1685 Lamp Dome Input Circuit Failure
B1686 Lamp Dome Input Circuit Open
B1687 Lamp Dome Input Circuit Short To Battery
B1688 Lamp Dome Input Circuit Short To Ground
B1689 Autolamp Delay Circuit Failure
B1690 Autolamp Delay Circuit Open
B1691 Autolamp Delay Circuit Short To Battery
B1692 Autolamp Delay Circuit Short To Ground
B1693 Autolamp On Circuit Failure
B1694 Autolamp On Circuit Open
B1695 Autolamp On Circuit Short To Battery
B1696 Autolamp On Circuit Short To Ground
B1697 Mirror Driver/Passenger Switch Circuit Short To Battery
B1698 Mirror Driver/Passenger Switch Circuit Short To Ground
B1699 Passenger's Seat Occupied Switch Circuit Short to Ground
B1700 Passenger's Seatbelt Tension Reducer Circuit Short to Ground
B1701 Seat Driver Recline Forward Switch Circuit Failure
B1702 Seat Driver Recline Forward Switch Circuit Open
B1703 Seat Driver Recline Forward Switch Circuit Short To Battery
B1704 Seat Driver Recline Forward Switch Circuit Short To Ground
B1705 Seat Driver Recline Rearward Switch Circuit Failure
B1706 Seat Driver Recline Rearward Switch Circuit Open
B1707 Seat Driver Recline Rearward Switch Circuit Short To Battery
B1708 Seat Driver Recline Rearward Switch Circuit Short To Ground
B1709 Seat Driver Front Up Switch Circuit Failure
B1710 Seat Driver Front Up Switch Circuit Open
B1711 Seat Driver Front Up Switch Circuit Short To Battery
B1712 Seat Driver Front Up Switch Circuit Short To Ground
B1713 Seat Driver Front Down Switch Circuit Failure
B1714 Seat Driver Front Down Switch Circuit Open
B1715 Seat Driver Front Down Switch Circuit Short To Battery
B1716 Seat Driver Front Down Switch Circuit Short To Ground
B1717 Seat Driver Forward Switch Circuit Failure
B1718 Seat Driver Forward Switch Circuit Open
B1719 Seat Driver Forward Switch Circuit Short To Battery
B1720 Seat Driver Forward Switch Circuit Short To Ground
B1721 Seat Driver Rearward Switch Circuit Failure
B1722 Seat Driver Rearward Switch Circuit Open
B1723 Seat Driver Rearward Switch Circuit Short To Battery
B1724 Seat Driver Rearward Switch Circuit Short To Ground
B1725 Seat Driver Rear Up Switch Circuit Failure
B1726 Seat Driver Rear Up Switch Circuit Open
B1727 Seat Driver Rear Up Switch Circuit Short To Battery
B1728 Seat Driver Rear Up Switch Circuit Short To Ground
B1729 Seat Driver Rear Down Switch Circuit Failure
B1730 Seat Driver Rear Down Switch Circuit Open
B1731 Seat Driver Rear Down Switch Circuit Short To Battery
B1732 Seat Driver Rear Down Switch Circuit Short To Ground
B1733 Mirror Driver Vertical Switch Circuit Failure
B1734 Mirror Driver Vertical Switch Circuit Open
B1735 Mirror Driver Vertical Switch Circuit Short To Battery
B1736 Mirror Driver Vertical Switch Circuit Short To Ground
B1737 Mirror Driver Horizontal Switch Circuit Failure
B1738 Mirror Driver Horizontal Switch Circuit Open
B1739 Mirror Driver Horizontal Switch Circuit Short To Battery
B1740 Mirror Driver Horizontal Switch Circuit Short To Ground
B1741 Mirror Passenger Vertical Switch Circuit Failure
B1742 Mirror Passenger Vertical Switch Circuit Open
B1743 Mirror Passenger Vertical Switch Circuit Short To Battery
B1744 Mirror Passenger Vertical Switch Circuit Short To Ground
B1745 Mirror Passenger Horizontal Switch Circuit Failure
B1746 Mirror Passenger Horizontal Switch Circuit Open
B1747 Mirror Passenger Horizontal Switch Circuit Short To Battery
B1748 Mirror Passenger Horizontal Switch Circuit Short To Ground
B1749 Park/Neutral Switch Circuit Failure
B1750 Park/Neutral Switch Circuit Open
B1751 Park/Neutral Switch Circuit Short To Battery
B1752 Park/Neutral Switch Circuit Short To Ground
B1753 Hazard Flash Output Circuit Failure
B1754 Hazard Flash Output Circuit Open
B1755 Hazard Flash Output Circuit Short Battery
B1756 Hazard Flash Output Circuit Short To Ground
B1757 Seat Driver Rear Down Circuit Failure
B1758 Seat Driver Rear Down Circuit Open
B1759 Seat Driver Rear Down Circuit Short To Battery
B1760 Seat Driver Rear Down Circuit Short To Ground
B1761 Seat Driver Front Down Circuit Failure
B1762 Seat Driver Front Down Circuit Open
B1763 Seat Driver Front Down Circuit Short To Battery
B1764 Seat Driver Front Down Circuit Short To Ground
B1765 Seat Driver Forward Circuit Failure
B1766 Seat Driver Forward Circuit Open
B1767 Seat Driver Forward Circuit Short To Battery
B1768 Seat Driver Forward Circuit Short To Ground
B1769 Seat Driver Backward Circuit Failure
B1770 Seat Driver Backward Circuit Open
B1771 Seat Driver Backward Circuit Short To Battery
B1772 Seat Driver Backward Circuit Short To Ground
B1773 Mirror Driver Up Circuit Failure
B1774 Mirror Driver Up Circuit Open
B1775 Mirror Driver Up Circuit Short To Battery
B1776 Mirror Driver Up Circuit Short To Ground
B1777 Driver's Seatbelt Tension Reducer Circuit Short to Ground
B1778 Mirror Driver Down Circuit Failure
B1779 Mirror Driver Down Circuit Open
B1780 Mirror Driver Down Circuit Short To Battery
B1781 Mirror Driver Down Short To Ground
B1782 Mirror Passenger Up Circuit Failure
B1783 Mirror Passenger Up Circuit Open
B1784 Mirror Passenger Up Circuit Short To Battery
B1785 Mirror Passenger Up Circuit Short To Ground
B1786 Mirror Passenger Down Circuit Failure
B1787 Mirror Passenger Down Circuit Open
B1788 Mirror Passenger Down Circuit Short To Battery
B1789 Mirror Passenger Down Circuit Short To Ground
B1790 Autolamp Sensor Input Circuit Failure
B1791 Autolamp Sensor Input Circuit Open
B1792 Autolamp Sensor Input Circuit Short To Battery
B1793 Autolamp Sensor Input Circuit Short To Ground
B1794 Lamp Headlamp Low-Beam Circuit Failure
B1795 Lamp Headlamp Low-Beam Circuit Open
B1796 Lamp Headlamp Low-Beam Circuit Short To Battery
B1797 Lamp Headlamp Low-Beam Circuit Short To Ground
B1798 Lamp Turn Signal Front Output Circuit Failure
B1799 Lamp Turn Signal Front Output Circuit Open
B1800 Lamp Turn Signal Front Output Circuit Short To Battery
B1801 Lamp Turn Signal Front Output Circuit Short To Ground
B1802 Lamp Turn Signal Rear Output Circuit Failure
B1803 Lamp Turn Signal Rear Output Circuit Open
B1804 Lamp Turn Signal Rear Output Circuit Short To Battery
B1805 Lamp Turn Signal Rear Output Circuit Short To Ground
B1806 Lamp Tail Output Circuit Failure
B1807 Lamp Tail Output Circuit Open
B1808 Lamp Tail Output Circuit Short To Battery
B1809 Lamp Tail Output Circuit Short To Ground
B1810 Lamp Backup Switch Input Circuit Failure
B1811 Lamp Backup Switch Input Circuit Open
B1812 Lamp Backup Switch Input Circuit Short To Battery
B1813 Lamp Backup Switch Input Circuit Short To Ground
B1814 Wiper Rear Motor Down Relay Coil Circuit Failure
B1815 Wiper Rear Motor Down Relay Coil Circuit Open
B1816 Wiper Rear Motor Down Relay Coil Circuit Short To Battery
B1817 Wiper Rear Motor Down Relay Coil Circuit Short To Ground
B1818 Wiper Rear Motor Up Relay Coil Circuit Failure
B1819 Wiper Rear Motor Up Relay Coil Circuit Open
B1820 Wiper Rear Motor Up Relay Coil Circuit Short To Battery
B1821 Wiper Rear Motor Up Relay Coil Circuit Short To Ground
B1822 Wiper Rear Park Sense Input Circuit Failure
B1823 Wiper Rear Park Sense Input Circuit Open
B1824 Wiper Rear Park Sense Input Circuit Short To Battery
B1825 Wiper Rear Park Sense Input Circuit Short To Ground
B1826 Wiper Rear High Limit Input Circuit Failure
B1827 Wiper Rear High Limit Input Circuit Open
B1828 Wiper Rear High Limit Input Circuit Short To Battery
B1829 Wiper Rear High Limit Input Circuit Short To Ground
B1830 Door Unlock Disarm Switch Circuit Failure
B1831 Door Unlock Disarm Switch Circuit Open
B1832 Door Unlock Disarm Switch Circuit Short To Battery
B1833 Door Unlock Disarm Switch Circuit Short To Ground
B1834 Door Unlock Disarm Output Circuit Failure
B1835 Door Unlock Disarm Output Circuit Open
B1836 Door Unlock Disarm Output Circuit Short To Battery
B1837 Door Unlock Disarm Output Circuit Short To Ground
B1838 Battery Saver Power Relay Circuit Failure
B1839 Wiper Rear Motor Circuit Failure
B1840 Wiper Front Power Circuit Failure
B1841 Wiper Front Power Circuit Open
B1842 Wiper Front Power Circuit Short To Battery
B1843 Wiper Front Power Circuit Short To Ground
B1844 Phone Handset Circuit Failure
B1845 Ignition Tamper Circuit Failure
B1846 Ignition Tamper Circuit Open
B1847 Ignition Tamper Circuit Short To Battery
B1848 Ignition Tamper Circuit Short To Ground
B1849 Climate Control Temperature Differential Circuit Failure
B1850 Climate Control Temperature Differential Circuit Open
B1851 Climate Control Temperature Differential Circuit Short To Battery
B1852 Climate Control Temperature Differential Circuit Short To Ground
B1853 Climate Control Air Temperature Internal Sensor Motor Circuit Failure
B1854 Climate Control Air Temperature Internal Sensor Motor Circuit Open
B1855 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery
B1856 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground
B1857 Climate Control On/Off Switch Circuit Failure
B1858 Climate Control A/C Pressure Switch Circuit Failure
B1859 Climate Control A/C Pressure Switch Circuit Open
B1860 Climate Control A/C Pressure Switch Circuit Short To Battery
B1861 Climate Control A/C Pressure Switch Circuit Short To Ground
B1862 Climate Control A/C Lock Sensor Failure
B1863 Ground ECU Circuit Open
B1864 Battery Power Supply ECU Circuit Failure
B1865 Battery Power Supply ECU Circuit Open
B1866 Battery Power Supply ECU Circuit Short To Battery
B1867 Battery Power Supply ECU Circuit Short To Ground
B1868 Lamp Air Bag Warning Indicator Circuit Failure
B1869 Lamp Air Bag Warning Indicator Circuit Open
B1870 Lamp Air Bag Warning Indicator Circuit Short To Battery
B1871 Passenger Air Bag Disable Module Fault
B1872 Turn Signal / Hazard Power Feed Circuit Short To Battery
B1873 Turn Signal / Hazard Power Feed Circuit Short To Ground
B1874 Cellular Phone Handset Not Present
B1875 Turn Signal / Hazard Switch Signal Circuit Failure
B1876 Seatbelt Driver Pretensioner Circuit Failure
B1877 Seatbelt Driver Pretensioner Circuit Open
B1878 Seatbelt Driver Pretensioner Circuit Short to Battery
B1879 Seatbelt Driver Pretensioner Circuit Short to Ground
B1880 Seatbelt Passenger Pretensioner Circuit Failure
B1881 Seatbelt Passenger Pretensioner Circuit Open
B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery
B1883 Seatbelt Passenger Pretensioner Circuit Short to Ground
B1884 PAD Warning Lamp Inoperative
B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib
B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib
B1887 Air Bag Driver Circuit Resistance Low or Shorted Together
B1888 Air Bag Passenger Circuit Resistance Low or Shorted Together
B1889 Passenger Airbag Disable Module Sensor Obstructed
B1890 PAD Warning Lamp Circuit Short to Battery
B1891 Air Bag Tone Warning Indicator Circuit Short to Battery
B1892 Air Bag Tone Warning Indicator Circuit Failure
B1893 GPS Antenna Open Circuit
B1894 Wiper Rear Motor Speed Sense Circuit Failure
B1895 Driver's / Passenger's Door Ajar Output Circuit Failure
B1896 Driver's / Passenger's Door Ajar Output Circuit Short to Battery
B1897 Horn Switch Circuit Failure
B1898 Chime Input #2 Circuit Short to Ground
B1899 Microphone Input Signal Circuit Open
B1900 Driver Side Airbag Fault
B1901 Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground
B1902 Air Bag Crash Sensor #1 Ground Circuit Failure
B1903 Air Bag Crash Sensor #1 Ground Circuit Short To Battery
B1904 Air Bag Crash Sensor #2 Feed/Return Circuit Failure
B1905 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery
B1906 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground
B1907 Air Bag Crash Sensor #2 Ground Circuit Failure
B1908 Air Bag Crash Sensor #2 Ground Circuit Short To Battery
B1909 Air Bag Crash Sensor #2 Ground Circuit Short To Ground
B1910 Air Bag Diagnostic Monitor Ground Circuit Failure
B1911 Air Bag Diagnostic Monitor Ground Circuit Short To Battery
B1912 Air Bag Diagnostic Monitor Ground Circuit Short To Ground
B1913 Air Bag Driver/Passenger Circuit Short To Ground
B1914 Air Bag Crash Sensors #1 / #2 Circuit Short To Ground
B1915 Air Bag Driver Circuit Failure
B1916 Air Bag Driver Circuit Short To Battery
B1917 Air Bag Memory Clear Circuit Failure
B1918 Air Bag Memory Clear Circuit Open
B1919 Air Bag Memory Clear Circuit Short To Battery
B1920 Air Bag Passenger Circuit Failure
B1921 Air Bag Diagnostic Monitor Ground Circuit Open
B1922 Air Bag Safing Sensor Output Circuit Short To Battery
B1923 Air Bag Memory Clear Circuit Short To Ground
B1924 Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault
B1925 Air Bag Passenger Circuit Short To Battery
B1926 Air Bag Passenger Pressure Switch Circuit Failure
B1927 Passenger Side Airbag Fault
B1928 Air Bag Safing Sensor Output Circuit Failure
B1929 Air Bag Safing Sensor Output Circuit Open
B1930 Air Bag Safing Sensor Output Circuit Short To Ground
B1931 Air Bag Crash Sensor #1 Feed/Return Circuit Failure
B1932 Air Bag Driver Circuit Open
B1933 Air Bag Passenger Circuit Open
B1934 Air Bag Driver Inflator Circuit Resistance Low on Squib
B1935 Air Bag Passenger Inflator Circuit Resistance Low on Squib
B1936 Air Bag Driver Circuit Short To Ground
B1937 Air Bag Passenger Pressure Switch Circuit Open
B1938 Air Bag Passenger Circuit Short To Ground
B1939 Air Bag Passenger Pressure Switch Circuit Short To Ground
B1941 Air Bag Crash Sensor #1 Feed/Return Circuit Open
B1942 Air Bag Crash Sensor #2 Feed/Return Circuit Open
B1943 Air Bag Crash Sensor #1 Ground Circuit Short To Ground
B1944 Air Bag Crash Sensor #1 Ground Circuit Open
B1945 Air Bag Crash Sensor #2 Ground Circuit Open
B1946 Climate Control A/C Post Evaporator Sensor Circuit Failure
B1947 Climate Control A/C Post Evaporator Sensor Circuit Short To Ground
B1948 Climate Control Water Temperature Sensor Circuit Failure
B1949 Climate Control Water Temperature Sensor Circuit Short To Ground
B1950 Seat Rear Up/Down Potentiometer Feedback Circuit Failure
B1951 Seat Rear Up/Down Potentiometer Feedback Circuit Open
B1952 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Battery
B1953 Seat Rear Up/Down Potentiometer Feedback Circuit Short To Ground
B1954 Seat Front Up/Down Potentiometer Feedback Circuit Failure
B1955 Seat Front Up/Down Potentiometer Feedback Circuit Open
B1956 Seat Front Up/Down Potentiometer Feedback Circuit Short To Battery
B1957 Seat Front Up/Down Potentiometer Feedback Circuit Short To Ground
B1958 Seat Recline Forward/Backward Potentiometer Feedback Circuit Failure
B1959 Seat Recline Forward/Backward Potentiometer Feedback Circuit Open
B1960 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Battery
B1961 Seat Recline Forward/Backward Potentiometer Feedback Circuit Short To Ground
B1962 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Failure
B1963 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Open
B1964 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Battery
B1965 Seat Horizontal Forward/Rearward Potentiometer Feedback Circuit Short To Ground
B1966 A/C Post Heater Sensor Circuit Failure
B1967 A/C Post Heater Sensor Circuit Short To Ground
B1968 A/C Water Pump Detection Circuit Failure
B1969 A/C Clutch Magnetic Control Circuit Failure
B1970 Passenger Seatback Forward Switch Circuit Short to Ground
B1971 Passenger Seatback Rearward Switch Circuit Short to Ground
B1972 Passenger Rear Seat Up Switch Circuit Short to Battery
B1973 Passenger Rear Seat Down Switch Circuit Short to Battery
B1974 Passenger's Seat Recline Forward Switch Circuit Short to Battery
B1975 Passenger's Seat Recline Back Switch Circuit Short to Battery
B1976 Passenger's Seat Forward Switch Circuit Short to Battery
B1977 Passenger's Front Seat Up Switch Circuit Short to Battery
B1978 Passenger's Front Seat Down Switch Circuit Short to Battery
B1979 Passenger Seat Rearward Switch Circuit Short to Battery
B1980 Bulb - Outage Condition Detected
B1981 Memory Off Switch Circuit Short to Battery
B1982 Driver's Door Unlock Relay Circuit Failure
B1983 Driver's Door Unlock Relay Circuit Short to Battery
B1984 Seat Switch Lumbar Inflate Circuit Failure
B1985 Seat Switch Lumbar Deflate Circuit Failure
B1986 Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure
B1987 Pedal Forward / Rearward Motor Stalled
B1988 Pedal Position Forward Switch Circuit Short to Battery
B1989 Pedal Position Rearward Switch Circuit Short to Battery
B1990 Pedal Forward / Rearward Potentiometer Feedback Circuit Failure
B1991 Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery
B1992 Driver Side, Side mount Airbag Circuit Short to Vbatt
B1993 Driver Sid, Side mount Airbag Circuit Short to Ground
B1994 Driver Sid, Side mount Airbag Circuit Open
B1995 Driver Sid, Side mount Airbag Low resistance on Squib
B1996 Passenger Sid, Side mount Airbag Circuit Short to Vbatt
B1997 Passenger Sid, Side mount Airbag Circuit Short to Ground
B1998 Passenger Sid, Side mount Airbag Circuit Open
B1999 Passenger Sid, Side mount Airbag Low resistance on Squib
B2100 Door Driver Key Cylinder Switch Failure
B2101 Head Rest Switch Circuit Failure
B2102 Antenna Circuit Short to Ground
B2103 Antenna Not Connected
B2104 Door Passenger Key Cylinder Switch Failure
B2105 Throttle Position Input Out of Range Low
B2106 Throttle Position Input Out of Range High
B2107 Front Wiper Motor Relay Circuit Short to Vbatt
B2108 Trunk Key Cylinder Switch Failure
B2109 Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97)
B2110 Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97)
B2111 All Door Lock Input Short to Ground
B2112 Door Driver Set Switch Stuck Failure
B2113 Heated Windshield Input Short to Ground
B2114 Front Washer Input Short to Ground
B2115 Rear Washer Input Short to Ground
B2116 Door Driver Reset Switch Stuck Failure
B2117 Driver Side, Side mount Airbag Low capacitance on Squib
B2118 Passenger Sid, Side mount Airbag Low capacitance on Squib
B2119 Compressor Failure
B2120 Door Passenger Set Switch Stuck Failure
B2122 Driver Side Satellite Communication Circuit Short to Ground
B2123 Passenger Side Satellite Communication Circuit Short to Ground
B2124 Door Passenger Reset Switch Stuck Failure
B2128 Central Lock Motor Failure
B2129 Central Lock Feedback Failure
B2130 Double Lock Timeout Failure
B2131 Double Lock Feedback Failure
B2132 Dimmer switch Circuit Short to Gnd
B2133 Brake Motor Warning lamp Circuit Failure
B2134 Brake Motor Warning lamp Circuit Short to Vbatt
B2135 Park Brake Applied Warning Lamp Circuit Failure
B2136 Park Brake Applied Warning Lamp Circuit Short To Battery
B2139 Data Mismatch (receive data does not match what was expected)
B2141 NVM Configuration Failure
B2142 NVM TIC Failure
B2143 NVM Memory Failure
B2144 NVM Alarm Data Failure
B2145 NVM RF HR Failure
B2146 Seat Recline Motor Position Out of Range
B2148 PWM Input Circuit Failure
B2149 Seat Front Vertical Motor Position Out of Range
B2150 Power Supply #1 Circuit Short to Ground
B2151 Power Supply #2 Circuit Short to Ground
B2152 Seat Rear Vertical Motor Position Out of Range
B2153 Rear Echo Sensor Circuit Failure
B2154 Front Echo Sensor Circuit Failure
B2155 Seat Horizontal Motor Position Out of Range
B2156 Rear Doppler Sensor Circuit Failure
B2157 Front Doppler Sensor Circuit Failure
B2158 Seat Recline Motor Memory Position Out of Range
B2159 Memory #1 output Short to Ground
B2160 Memory #1 output Short to VBatt
B2161 Seat Front Vertical Motor Memory Position Out of Range
B2162 Data Mismatch #2 (receive data does not match what was expected)
B2163 Clutch Position Fault
B2164 Seat Rear Vertical Motor Memory Position Out of Range
B2165 Gear shift position Fault
B2166 Gear select position Fault
B2167 Seat Horizontal Motor Memory Position Out of Range
B2168 Unable to confirm Unlock Condition
B2169 Unable to confirm lock Condition
B2170 Steering Column Lock Switch Circuit Failure
B2172 Inertia Switch input Circuit Open
B2174 Window Driver Rear Remote Up Switch Short to Battery
B2175 A/C Request Signal Circuit Short to Ground
B2176 Overdrive switch circuit short to Vbatt
B2177 Interior Scanning Sensor Circuit Failure
B2178 Window Driver Rear Remote Down Switch Short to Battery
B2179 Front Wiper Select Switch "A" Short to Ground
B2180 Front Wiper Select Switch "B" Short to Ground
B2181 Front Wiper Select Switch "C" Short to Ground
B2182 Window Passenger Front Remote Up Switch Short to Battery
B2183 Front Wiper Select Switch "H" Short to Ground
B2184 Front Wiper Select Switch "W" Short to Ground
B2185 Rear Wiper Select Switch "D" Short to Ground
B2186 Window Passenger Front Remote Down Switch Short to Battery
B2187 Rear Wiper Select Switch "B" Short to Ground
B2188 Rear Wiper Select Switch "E" Short to Ground
B2190 Window Passenger Rear Remote Up Switch Short to Battery
B2194 Window Passenger Rear Remote Down Switch Short to Battery
B2195 Driver Window Up / Down Power Circuit Short to Ground
B2196 Passenger Window Up / Down Power Circuit Short to Ground
B2197 TV Module Error
B2198 TrafficMaster Module Error
B2199 VICS Module Error
B2200 No Communication to TV Module (No Fitting of TV)
B2201 No Communication With Traffic MasterModule
B2202 No Communication to VICS Module (No Fitting of VICS)
B2203 CD-ROM Error
B2204 GPS Antenna Connection Open or Short
B2205 GPS Receiver Error
B2206 Gyroscope Error
B2207 ECU ROM Checksum Error
B2208 Communication Link to Display and Switch Module Error
B2209 Interior Lamp Override Switch Open Circuit
B2210 Interior Lamp Override Switch Short to Ground
B2211 Low Coolant Lamp Output Circuit Short to Battery
B2214 Window Passenger Front Up Switch Short to Battery
B2215 Window Passenger Front Down Switch Short to Battery
B2219 Window Driver Front Current Feedback Exceeded
B2220 Window Driver Rear Current Feedback Exceeded
B2221 Window Passenger Front Current Feedback Exceeded
B2222 Window Passenger Rear Current Feedback Exceeded
B2223 Mirror Driver Drive Circuit Failure
B2224 Mirror Passenger Drive Circuit Failure
B2225 Front Crash Sensor Mount Fault
B2226 Front Crash Sensor Internal Fault
B2227 Front Crash Sensor Driver Communications Fault
B2228 Air Bag Driver Circuit Short to Ground - Loop #2
B2229 Air Bag Passenger Circuit Short to Ground - Loop #2
B2230 Air Bag Driver Circuit Short to Battery - Loop #2
B2231 Air Bag Passenger Circuit Short to Battery - Loop #2
B2232 Air Bag Driver Circuit Open - Loop #2
B2233 Air Bag passenger Circuit Open - Loop #2
B2234 Air Bag Driver Inflator Circuit Resistance Low on Squib - Loop #2
B2235 Air Bag Passenger Inflator Circuit
B2236 Weak or Defected Electric Vehicle Battery Module Fault
B2237 Vehicle Signal indicating Park While VSS Present
B2238 Power Cable For Power Sliding Door Broken
B2239 Rear Cargo Door Set Switch Stuck (Short to Ground)
B2240 Rear Cargo Door Reset Switch Stuck (Short to Ground)
B2241 Rear Cargo Door Lock Circuit Short to Ground
B2242 Rear Cargo Door Unlock Circuit Open
B2243 Driver Rear Door Ajar Circuit Open
B2244 Driver Sliding Door Ajar Circuit Short to GND
B2245 Passenger Rear Door Ajar Circuit Open
B2246 Passenger Sliding Door Ajar Circuit Short to GND
B2247 EV Battery Pack Temperature Fault
B2248 Heated Windshield Relay Coil Circuit Failure
B2249 Head Lamp Relay Coil Short to Battery
B2250 All Doors Unlock Relay Circuit Failure
B2251 Parklamp Output Relay Driver Circuit Failure
B2252 Parklamp Output Relay Dirver Short to Battery
B2300 Seat Driver Memory Position Error
B2301 Seat Passenger Memory Position Error
B2302 Seat Headrest Feedback Potentiometer Circuit Failure
B2303 Seat Headrest Feedback Potentiometer Circuit Open
B2304 Seat Headrest Feedback Potentiometer Circuit Short to Battery
B2305 Seat Headrest Feedback Potentiometer Circuit Short to Ground
B2306 Seat Headrest Motor Stalled
B2310 Mirror Driver Memory Position Error
B2311 Mirror Passenger Memory Position Error
B2312 Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure
B2313 Mirror Passenger Horizontal Feedback Potentiometer Circuit Open
B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery
B2315 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Ground
B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure
B2317 Mirror Passenger Vertical Feedback Potentiometer Circuit Open
B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery
B2319 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Ground
B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure
B2321 Mirror Driver Horizontal Feedback Potentiometer Circuit Open
B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery
B2323 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Ground
B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure
B2325 Mirror Driver Vertical Feedback Potentiometer Circuit Open
B2326 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Battery
B2327 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Ground
B2328 Column Reach Feedback Potentiometer Circuit Failure
B2329 Column Reach Feedback Potentiometer Circuit Open
B2330 Column Reach Feedback Potentiometer Circuit Short to Battery
B2331 Column Reach Feedback Potentiometer Circuit Short to Ground
B2332 Column Tilt Feedback Potentiometer Circuit Failure
B2333 Column Tilt Feedback Potentiometer Circuit Open
B2334 Column Tilt Feedback Potentiometer Circuit Short to Battery
B2335 Column Tilt Feedback Potentiometer Circuit Short to Ground
B2336 Mirror Switch Assembly Circuit Failure
B2337 Mirror Switch Assembly Circuit Open
B2338 Mirror Switch Assembly Circuit Short to Battery
B2339 Mirror Switch Assembly Circuit Short to Ground
B2340 Column Reach Motor Stalled
B2341 Column Tilt Motor Stalled
B2342 Seat Switch Reference Voltage Positive Common Open Circuit
B2343 Seat Switch Reference Voltage Positive Common Supply Low Voltage
B2344 Seat Switch Reference Voltage Positive Common Supply Voltage Fault
B2345 Seat Switch Reference Voltage Negative Common Open Circuit
B2346 Mirror Switch Reference Voltage Positive Common Open Circuit
B2347 Mirror Switch Reference Voltage Positive Common Supply Low Voltage
B2348 Mirror Switch Reference Voltage Positive Common Supply Voltage Fault
B2349 Mirror Switch Reference Voltage Negative Common Open Circuit
B2350 Steering Column Switch Circuit Short to Battery
B2351 Steering Column Switch Circuit Failure
B2352 Driver Memory Power Switch Indicator Circuit Short to Battery
B2353 Driver Mirror Power Driver Circuit Short Ground
B2354 Driver Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
B2355 Passenger Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
B2357 Driver Window Down Current Sense Low Circuit Failure
B2362 Remote Open/Close signal Circuit Short to Ground
B2363 Optical Sensor System Failure
B2364 Fuel Filler Door Circuit Open
B2365 B-pillar Power Sliding Door Open/Close Switch Input Ckt Short to Gnd
B2366 IP Power Sliding Door Open/Close switch Ckt Short to Gnd
B2367 Power Sliding Door Override Switch Input Ckt Short to Gnd
B2368 Steering Column Switch Circuit Out of Range
B2369 Chime OUTPUT Request Ckt Short to Ground
B2373 LED #1 Circuit Short to Battery
B2374 Power Sliding Detent (Latch) Circuit Failure
B2380 Heater Coolant Temp sensor circuit Short to GND
B2381 Heater Coolant Temp sensor circuit Open
B2384 Audio Reverse Aid Mute Input Ckt Failure
B2385 Audio Navigation Mute Input Ckt Failure
B2401 Audio Tape Deck Mechanism Fault
B2402 Audio CD/DJ Thermal Shutdown Fault
B2403 Audio CD/DJ Internal Fault
B2404 Audio Steering Wheel Switch Circuit Fault
B2405 Audio Single-Disc CD Player Thermal Shutdown Fault
B2406 Audio Single-Disc CD Player Internal Fault
B2416 Climate Control Recirculation Actuator Out of Limits
B2425 Remote Keyless Entry Out of Synchronization
B2426 Passenger Solar Radiation Sensor Circuit Open
B2427 Passenger Solar Radiation Sensor Circuit Short to Ground
B2428 A/C Post Heater Sensor #2 Circuit Failure
B2429 A/C Post Heater Sensor #2 Circuit Short to Ground
B2431 Transponder Programming Failed
B2432 Drivers Seat Belt Buckle Switch Circuit Open
B2433 Drivers Seat Belt Buckle Switch Circuit Short to Battery
B2434 Drivers Seat Belt Buckle Switch Circuit Short to Ground
B2435 Drivers Seat Belt Buckle Switch Resistance out of Range
B2436 Passengers Seat Belt Buckle Switch Circuit Open
B2437 Passengers Seat Belt Buckle Switch Circuit Short to Battery
B2438 Passengers Seat Belt Buckle Switch Circuit Short to Ground
B2439 Passengers Seat Belt Buckle Switch Resistance out of Range
B2440 Passenger Sid, Side crash sensor mount fault
B2441 Driver Sid, Side crash sensor mount fault
B2442 Intrusion Sensor Fault
B2443 Powertrain Performance Mode Switch Circuit failure
B2444 Driver Side Crash Sensor Internal Fault
B2445 Passenger Side Crash Sensor Internal Fault
B2446 RESCU/VEMS Input Circuit Open
B2447 RESCU/VEMS Input Circuit Short to Battery
B2448 RESCU/VEMS Input Circuit Short to Ground
B2449 Aux Heater Glow Plug Circuit Short to Ground
B2450 Aux Heater Glow Plug Circuit Open
B2451 Aux Heater Fuel Pump Circuit Short to Ground
B2452 Aux Heater Fuel Pump Circuit Open
B2453 Aux Heater Blower Fan Circuit Short to Ground
B2454 Aux Heater Blower Fan Circuit Open
B2455 Aux Heater Blower Faulted
B2456 Aux Heater Coolant Sensor Circuit Short to Ground
B2457 Aux Heater Coolant Sensor Circuit Open
B2458 Aux Heater Overheat Sensor Circuit Short to Ground
B2459 Aux Heater Overheat Sensor Circuit Open
B2460 Aux Heater Flame Sensor Circuit Short to Ground
B2461 Aux Heater Flame Sensor Circuit Open
B2462 Aux Heater Flame Out Fault
B2463 Aux Heater Overheat Fault
B2464 Aux Heater Start Time Exceeded
B2465 Aux Heater Start Counter Overrun/System Locked (same as below ?)
B2466 Aux Heater Overheat Counter Overrun/System Locked
B2467 Aux Heater Cool Down Time Exceeded (may be con to a453-5 )
B2468 Aux Heater Coolant Pump Circuit Short to Ground
B2469 Aux Heater Coolant Pump Circuit Open
B2470 Interior Fan Control Circuit Short to Ground
B2471 Interior Fan Control Circuit Open
B2472 Fog Lamp Switch Failure
B2473 Passenger Door Disarm Switch ckt Short to Ground
B2474 Passenger Door Lock Switch Circuit Shorted to Ground
B2475 Passenger Door Unlock Switch Circuit Shorted to Ground
B2476 RADIO PRESENT SWITCH Ckt Failure
B2477 Module Configuration Failure
B2478 ANTI THEFT INPUT SIGNAL SHORT TO GROUND
B2479 BRAKE PARK SWITCH CIRCUIT SHORT TO GROUND
B2480 LF CORNER LAMP OUTPUT Ckt Short to Battery
B2481 Convertible Top Up/Down switch Fault
B2482 RF CORNER LAMP OUTPUT Ckt Short to Battery
B2483 Enable Signal Open Circuit
B2484 Disable Signal Short to Ground
B2485 LF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
B2487 RF SIDE REPEATER LAMP OUTPUT Ckt Short to Battery
B2489 UNDERHOOD LAMP OUTPUT CIRCUIT Failure
B2490 UNDERHOOD LAMP OUTPUT CIRCUIT Short to Battery
B2491 RF PARK LAMP OUTPUT CIRCUIT Short to Battery
B2492 Already Programmed (Test Mode DTC Only !!!)
B2493 LF PARK LAMP OUTPUT CIRCUIT Short to Battery
B2494 ANTI THEFT HORN OUTPUT CIRCUIT Short to Batt
B2495 ANTI THEFT HORN OUTPUT CIRCUIT Failure
B2496 ANTI THEFT HORN OUTPUT CIRCUIT Short to Gnd
B2499 COURTESY LAMP OUTPUT Failure
B2500 COURTESY LAMP OUTPUT Ckt Short to Battery
B2501 LF LAMP LOW BEAM CIRCUIT Failure
B2502 LF LAMP LOW BEAM CIRCUIT Short to Battery
B2503 RF LAMP LOW BEAM CIRCUIT Failure
B2504 RF LAMP LOW BEAM CIRCUIT Short to Battery
B2505 LF LAMP HIGH BEAM CIRCUIT Failure
B2506 LF LAMP HIGH BEAM CIRCUIT Short to Battery
B2507 RF LAMP HIGH BEAM CIRCUIT Failure
B2508 RF LAMP HIGH BEAM CIRCUIT Short to Battery
B2509 Rear Fog Lamp Switch Circuit Failure
B2510 Main Blower Motor Relay Circuit Short to Battery
B2511 Horn Output Relay Circuit Short to Battery
B2512 Front Fog Lamp Relay Ckt Short to Battery
B2513 Blower (Fan) Circuit Failure
B2514 Blower (Fan) Circuit Short to Vbatt
B2515 Heater Blower Relay Circuit Failure
B2516 Blower Control Circuit Failure
B2517 Emergency Power Off System Faulted
B2518 Compressor Overtemp Fault
B2519 High Mount Stop Lamp Circuit Failure
B2520 High Mount Stop Lamp Circuit Short to Battery
B2523 License Lamp Circuit Failure
B2524 License Lamp Circuit Short to Battery
B2525 Left Rear Backup Lamp Circuit Failure
B2526 Left Rear Backup Lamp Circuit Short to Battery
B2527 Left Rear Stop lamp Circuit Failure
B2528 Left Rear Stop lamp Circuit Short to Battery
B2529 Left Rear Turn Lamp Circuit Failure
B2530 Left Rear Turn Lamp Circuit Short to Battery
B2531 Right Rear Backup Lamp Circuit Failure
B2532 Right Rear Backup Lamp Circuit Short to Battery
B2533 Right Rear Stop lamp Circuit Failure
B2534 Right Rear Stop lamp Circuit Short to Battery
B2535 Right Rear Turn Lamp Circuit Failure
B2536 Right Rear Turn Lamp Circuit Short to Battery
B2539 Aux A/C Mode Position Reference Circuit Short to Ground
B2540 Aux A/C Mode Position Reference Circuit Short to Battery
B2543 Aux A/C Control Switch Reference Circuit Short to Ground
B2544 Aux A/C Control Switch Reference Circuit Short to Battery
B2545 System Power Relay Circuit Short to Battery
B2546 System Power Relay Circuit Failure
B2550 LAMP DOME OUTPUT Circuit Short to Ground
B2553 Disable Signal Output Circuit Short to Battery
B2554 LAMP DOME OUTPUT Circuit Failure
B2555 LAMP DOME OUTPUT Circuit Short to Battery
B2556 Enable Signal Circuit Short to Battery
B2557 Left Power Sliding Door Open/Close Output Circuit Short to Battery
B2558 Right Power Sliding Door Open/Close Output Circuit Short to Battery
B2559 Aux A/C Blower Motor Relay Circuit Short to Battery
B2560 Aux A/C Blower Motor Relay Circuit Short to Ground
B2561 Aux A/C Blower Speed 1 Circuit Failure
B2562 Aux A/C Blower Speed 1 Circuit Short to Ground
B2563 Aux A/C Blower Speed 2 Circuit Failure
B2564 Aux A/C Blower Speed 2 Circuit Short to Ground
B2565 Right Tail Lamp Circuit Failure
B2566 Right Tail Lamp Circuit Short to Ground
B2567 Reverse Mirror Output Circuit Failure
B2568 Reverse Mirror Output Circuit Short to Ground
B2569 Liftgate Disarm Switch Circuit Short to Ground
B2570 Right Lamp Outage Signal Circuit Short to Ground
B2571 Left Lamp Outage Signal Circuit Short to Ground
B2580 Aux Blower Sense Switch Circuit Failure
B2581 Passenger Seat Occupant Detection Circuit Short To Ground
B2582 Passenger Seat Occupant Detection Circuit Open
B2583 Child Seat Detection Circuit Short to Ground
B2584 Child Seat Detection Circuit Open
B2585 Anti Theft Input Signal Circuit Short To Battery
B2586 Headlamp Mode Select Circuit Failure
B2587 Passenger Seat Occupant Detection Circuit Short To Battery
B2588 Child Seat Detection Circuit Short To Battery
B2589 Unexpected Door Reversal During Close
B2590 Vehicle Park/Speed Signal Circuit Failure
B2591 Detent Signal Missing During Unlatch
B2592 PSD Not Fully Closed (Module Commanded Successfully)
B2593 Power Sliding Door Opened During Module Close Command
B2594 No Movement Detected After an Unlatch During Power Open
B2595 Anti Theft Input Signal Circuit Failure
B2596 Headlamp Aim Output Relay Circuit Short To Battery
B2597 Headlamp Aim Output Relay Circuit Failure
B2598 Headlamp Relay Circuit Failure
B2599 Tailgate Release Open Circuit
B2600 Double Locking Door Motor Frozen
B2601 No Latch Signal Sensed on Closing and Door Reversed
B2602 Missing Latch Signal During Power Sliding Door Unlatch
B2603 PSD Not Fully Closed During Self-Test
B2604 Power Sliding Door On/Off Switch Open Circuit
B2605 Disable Signal Open Circuit
B2606 A/C Temperature Sensor Out of Range
U1000 SCP (J1850) Invalid or Missing Data for Primary Id
U1001 SCP (J1850) Invalid or Missing Data for Primary Id
U1002 SCP (J1850) Invalid or Missing Data for Primary Id
U1003 SCP (J1850) Invalid or Missing Data for Primary Id
U1004 SCP (J1850) Invalid or Missing Data for EEC Programming
U1005 SCP (J1850) Invalid or Missing Data for EEC Programming
U1006 SCP (J1850) Invalid or Missing Data for Primary Id
U1007 SCP (J1850) Invalid or Missing Data for Primary Id
U1008 SCP (J1850) Invalid or Missing Data for Engine Torque
U1009 SCP (J1850) Invalid or Missing Data for Engine Torque
U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1012 SCP (J1850) Invalid or Missing Data for Primary Id
U1013 SCP (J1850) Invalid or Missing Data for Primary Id
U1014 SCP (J1850) Invalid or Missing Data for Primary Id
U1015 SCP (J1850) Invalid or Missing Data for Primary Id
U1016 SCP (J1850) Invalid or Missing Data for Primary Id
U1017 SCP (J1850) Invalid or Missing Data for Primary Id
U1018 SCP (J1850) Invalid or Missing Data for Throttle
U1019 SCP (J1850) Invalid or Missing Data for Throttle
U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1022 SCP (J1850) Invalid or Missing Data for Primary Id
U1023 SCP (J1850) Invalid or Missing Data for Primary Id
U1024 SCP (J1850) Invalid or Missing Data for Primary Id
U1025 SCP (J1850) Invalid or Missing Data for Primary Id
U1026 SCP (J1850) Invalid or Missing Data for Engine RPM
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM
U1028 SCP (J1850) Invalid or Missing Data for Primary Id
U1029 SCP (J1850) Invalid or Missing Data for Primary Id
U1030 SCP (J1850) Invalid or Missing Data for Experimental #1
U1031 SCP (J1850) Invalid or Missing Data for Experimental #1
U1032 SCP (J1850) Invalid or Missing Data for Primary Id
U1033 SCP (J1850) Invalid or Missing Data for Primary Id
U1034 SCP (J1850) Invalid or Missing Data for Primary Id
U1035 SCP (J1850) Invalid or Missing Data for Primary Id
U1036 SCP (J1850) Invalid or Missing Data for Wheels
U1037 SCP (J1850) Invalid or Missing Data for Wheels
U1038 SCP (J1850) Invalid or Missing Data for Primary Id
U1039 SCP (J1850) Invalid or Missing Data for Primary Id / Vehicle Speed
U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1042 SCP (J1850) Invalid or Missing Data for Traction Control
U1043 SCP (J1850) Invalid or Missing Data for Traction Control
U1044 SCP (J1850) Invalid or Missing Data for Traction Motor
U1045 SCP (J1850) Invalid or Missing Data for Traction Motor
U1046 SCP (J1850) Invalid or Missing Data for Primary Id
U1047 SCP (J1850) Invalid or Missing Data for Primary Id
U1048 SCP (J1850) Invalid or Missing Data for Primary Id
U1049 SCP (J1850) Invalid or Missing Data for Primary Id
U1050 SCP (J1850) Invalid or Missing Data for Brakes
U1051 SCP (J1850) Invalid or Missing Data for Brakes
U1052 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1053 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1054 SCP (J1850) Invalid or Missing Data for Primary Id
U1055 SCP (J1850) Invalid or Missing Data for Primary Id
U1056 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1057 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1058 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1059 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1060 SCP (J1850) Invalid or Missing Data for Primary Id
U1061 SCP (J1850) Invalid or Missing Data for Primary Id
U1062 SCP (J1850) Invalid or Missing Data for Primary Id
U1063 SCP (J1850) Invalid or Missing Data for Primary Id
U1064 SCP (J1850) Invalid or Missing Data for Primary Id
U1065 SCP (J1850) Invalid or Missing Data for Primary Id
U1066 SCP (J1850) Invalid or Missing Data for Primary Id
U1067 SCP (J1850) Invalid or Missing Data for Primary Id
U1068 SCP (J1850) Invalid or Missing Data for Primary Id
U1069 SCP (J1850) Invalid or Missing Data for Primary Id
U1070 SCP (J1850) Invalid or Missing Data for Engine Sensors
U1071 SCP (J1850) Invalid or Missing Data for Engine Sensors
U1072 SCP (J1850) Invalid or Missing Data for Engine Coolant
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant
U1074 SCP (J1850) Invalid or Missing Data for Engine Oil
U1075 SCP (J1850) Invalid or Missing Data for Engine Oil Temp
U1076 SCP (J1850) Invalid or Missing Data for Primary Id
U1077 SCP (J1850) Invalid or Missing Data for Primary Id
U1078 SCP (J1850) Invalid or Missing Data for Primary Id
U1079 SCP (J1850) Invalid or Missing Data for Primary Id
U1080 SCP (J1850) Invalid or Missing Data for Primary Id
U1081 SCP (J1850) Invalid or Missing Data for Primary Id
U1082 SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1083 SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1084 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1085 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1086 SCP (J1850) Invalid or Missing Data for Primary Id
U1087 SCP (J1850) Invalid or Missing Data for Primary Id
U1088 SCP (J1850) Invalid or Missing Data for Suspension
U1089 SCP (J1850) Invalid or Missing Data for Suspension
U1090 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1091 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1092 SCP (J1850) Invalid or Missing Data for Primary Id
U1093 SCP (J1850) Invalid or Missing Data for Primary Id
U1094 SCP (J1850) Invalid or Missing Data for Experimental #2
U1095 SCP (J1850) Invalid or Missing Data for Experimental #2
U1096 SCP (J1850) Invalid or Missing Data for Primary Id
U1097 SCP (J1850) Invalid or Missing Data for Primary Id
U1098 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1099 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1100 SCP (J1850) Invalid or Missing Data for Primary Id
U1101 SCP (J1850) Invalid or Missing Data for Primary Id
U1102 SCP (J1850) Invalid or Missing Data for Primary Id
U1103 SCP (J1850) Invalid or Missing Data for Primary Id
U1104 SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1105 SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1106 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1107 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1108 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1109 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1110 SCP (J1850) Invalid or Missing Data for Primary Id
U1111 SCP (J1850) Invalid or Missing Data for Primary Id
U1112 SCP (J1850) Invalid or Missing Data for Primary Id
U1113 SCP (J1850) Invalid or Missing Data for Primary Id
U1114 SCP (J1850) Invalid or Missing Data for Charging System
U1115 SCP (J1850) Invalid or Missing Data for Charging System
U1116 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1117 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1118 SCP (J1850) Invalid or Missing Data for Primary Id
U1119 SCP (J1850) Invalid or Missing Data for Primary Id
U1120 SCP (J1850) Invalid or Missing Data for Primary Id
U1121 SCP (J1850) Invalid or Missing Data for Primary Id
U1122 SCP (J1850) Invalid or Missing Data for Odometer
U1123 SCP (J1850) Invalid or Missing Data for Odometer
U1124 SCP (J1850) Invalid or Missing Data for Primary Id
U1125 SCP (J1850) Invalid or Missing Data for Primary Id
U1126 SCP (J1850) Invalid or Missing Data for Primary Id
U1127 SCP (J1850) Invalid or Missing Data for Primary Id
U1128 SCP (J1850) Invalid or Missing Data for Primary Id
U1129 SCP (J1850) Invalid or Missing Data for Primary Id
U1130 SCP (J1850) Invalid or Missing Data for Fuel System
U1131 SCP (J1850) Invalid or Missing Data for Fuel System
U1132 SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1133 SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1134 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1136 SCP (J1850) Invalid or Missing Data for Telltales
U1137 SCP (J1850) Invalid or Missing Data for Telltales
U1138 SCP (J1850) Invalid or Missing Data for Primary Id
U1139 SCP (J1850) Invalid or Missing Data for Primary Id
U1140 SCP (J1850) Invalid or Missing Data for Gateway
U1141 SCP (J1850) Invalid or Missing Data for Gateway
U1142 SCP (J1850) Invalid or Missing Data for Primary Id
U1143 SCP (J1850) Invalid or Missing Data for Primary Id
U1144 SCP (J1850) Invalid or Missing Data for Primary Id
U1145 SCP (J1850) Invalid or Missing Data for Primary Id
U1146 SCP (J1850) Invalid or Missing Data for Vehicle Security
U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security
U1148 SCP (J1850) Invalid or Missing Data for Audio Control
U1149 SCP (J1850) Invalid or Missing Data for Audio Control
U1150 SCP (J1850) Invalid or Missing Data for Audible Warnings
U1151 SCP (J1850) Invalid or Missing Data for Audible Warnings
U1152 SCP (J1850) Invalid or Missing Data for Experimental #3
U1153 SCP (J1850) Invalid or Missing Data for Experimental #3
U1154 SCP (J1850) Invalid or Missing Data for Compact Disc
U1155 SCP (J1850) Invalid or Missing Data for Compact Disc
U1156 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1157 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1158 SCP (J1850) Invalid or Missing Data for Antenna
U1159 SCP (J1850) Invalid or Missing Data for Antenna
U1160 SCP (J1850) Invalid or Missing Data for Primary Id
U1161 SCP (J1850) Invalid or Missing Data for Primary Id
U1162 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1163 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1164 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1165 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1166 SCP (J1850) Invalid or Missing Data for Cassette Tape
U1167 SCP (J1850) Invalid or Missing Data for Cassette Tape
U1168 SCP (J1850) Invalid or Missing Data for Primary Id
U1169 SCP (J1850) Invalid or Missing Data for Primary Id
U1170 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1171 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1172 SCP (J1850) Invalid or Missing Data for Remote Button Control
U1173 SCP (J1850) Invalid or Missing Data for Remote Button Control
U1174 SCP (J1850) Invalid or Missing Data for Primary Id
U1175 SCP (J1850) Invalid or Missing Data for Primary Id
U1176 SCP (J1850) Invalid or Missing Data for Primary Id
U1177 SCP (J1850) Invalid or Missing Data for Primary Id
U1178 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1179 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1180 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1181 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1182 SCP (J1850) Invalid or Missing Data for Primary Id
U1183 SCP (J1850) Invalid or Missing Data for Primary Id
U1184 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1185 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1186 SCP (J1850) Invalid or Missing Data for Primary Id
U1187 SCP (J1850) Invalid or Missing Data for Primary Id
U1188 SCP (J1850) Invalid or Missing Data for Primary Id
U1189 SCP (J1850) Invalid or Missing Data for Primary Id
U1190 SCP (J1850) Invalid or Missing Data for Primary Id
U1191 SCP (J1850) Invalid or Missing Data for Primary Id
U1192 SCP (J1850) Invalid or Missing Data for Primary Id
U1193 SCP (J1850) Invalid or Missing Data for Primary Id
U1194 SCP (J1850) Invalid or Missing Data for Mirrors
U1195 SCP (J1850) Invalid or Missing Data for Mirrors
U1196 SCP (J1850) Invalid or Missing Data for Door Locks
U1197 SCP (J1850) Invalid or Missing Data for Door Locks
U1198 SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1199 SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1200 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1201 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1202 SCP (J1850) Invalid or Missing Data for Windows
U1203 SCP (J1850) Invalid or Missing Data for Windows
U1204 SCP (J1850) Invalid or Missing Data for Steering Column
U1205 SCP (J1850) Invalid or Missing Data for Steering Column
U1206 SCP (J1850) Invalid or Missing Data for Primary Id
U1207 SCP (J1850) Invalid or Missing Data for Primary Id
U1208 SCP (J1850) Invalid or Missing Data for Seat Switches
U1209 SCP (J1850) Invalid or Missing Data for Seat Switches
U1210 SCP (J1850) Invalid or Missing Data for Restraints
U1211 SCP (J1850) Invalid or Missing Data for Restraints
U1212 SCP (J1850) Invalid or Missing Data for Primary Id
U1213 SCP (J1850) Invalid or Missing Data for Primary Id
U1214 SCP (J1850) Invalid or Missing Data for Primary Id
U1215 SCP (J1850) Invalid or Missing Data for Primary Id
U1216 SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1217 SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1218 SCP (J1850) Invalid or Missing Data for External Lamps
U1219 SCP (J1850) Invalid or Missing Data for External Lamps
U1220 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1221 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1222 SCP (J1850) Invalid or Missing Data for Interior Lamps
U1223 SCP (J1850) Invalid or Missing Data for Interior Lamps
U1224 SCP (J1850) Invalid or Missing Data for Primary Id
U1225 SCP (J1850) Invalid or Missing Data for Primary Id
U1226 SCP (J1850) Invalid or Missing Data for Body Status Request
U1227 SCP (J1850) Invalid or Missing Data for Body Status Request
U1228 SCP (J1850) Invalid or Missing Data for Tires
U1229 SCP (J1850) Invalid or Missing Data for Tires
U1230 SCP (J1850) Invalid or Missing Data for Electric Defrost
U1231 SCP (J1850) Invalid or Missing Data for Electric Defrost
U1232 SCP (J1850) Invalid or Missing Data for Navigation
U1233 SCP (J1850) Invalid or Missing Data for Navigation
U1234 SCP (J1850) Invalid or Missing Data for Displays
U1235 SCP (J1850) Invalid or Missing Data for Displays
U1236 SCP (J1850) Invalid or Missing Data for Memory Storage
U1237 SCP (J1850) Invalid or Missing Data for Memory Storage
U1238 SCP (J1850) Invalid or Missing Data for Experimental #4
U1239 SCP (J1850) Invalid or Missing Data for Experimental #4
U1240 SCP (J1850) Invalid or Missing Data for Primary Id
U1241 SCP (J1850) Invalid or Missing Data for Primary Id
U1242 SCP (J1850) Invalid or Missing Data for Exterior Environment
U1243 SCP (J1850) Invalid or Missing Data for Exterior Environment
U1244 SCP (J1850) Invalid or Missing Data for Interior Environment
U1245 SCP (J1850) Invalid or Missing Data for Interior Environment
U1246 SCP (J1850) Invalid or Missing Data for Primary Id
U1247 SCP (J1850) Invalid or Missing Data for Primary Id
U1248 SCP (J1850) Invalid or Missing Data for Time / Date
U1249 SCP (J1850) Invalid or Missing Data for Time / Date
U1250 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1251 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1252 SCP (J1850) Invalid or Missing Data for Class A Functions
U1253 SCP (J1850) Invalid or Missing Data for Class A Functions
U1254 SCP (J1850) Invalid or Missing Data for Network Control
U1255 SCP (J1850) Invalid or Missing Data for Network Control
U1260 SCP (J1850) Single Ended (+) Circuit Failure
U1261 SCP (J1850) Single Ended (-) Circuit Failure
U1262 SCP (J1850) Communication Bus Fault
U1308 SCP (J1850) Invalid or Missing Data for Function Read Engine Torque
U1341 SCP (J1850) Invalid or Missing Data for Function Read Vehicle Speed
U1430 SCP (J1850) Invalid or Missing Data for Function Read Fuel System
U1451 SCP (J1850) Invalid or Missing Data for Function Read Audible Warnings / Anti-Theft Module, Vehicle Immobilized
U1612 SCP (J1850) Lack of Acknowledgment for Primary Id
U1736 SCP (J1850) Lack of Acknowledgment for Telltales
U1750 SCP (J1850) Lack of Acknowledgment for Audible Warnings
U1794 SCP (J1850) Lack of Acknowledgment for Mirrors
U1797 SCP (J1850) Lack of Acknowledgment for Door Locks
U1798 SCP (J1850) Lack of Acknowledgment for External Access (Doors)
U1806 SCP (J1850) Lack of Acknowledgment for Primary Id
U1900 CAN Communication Bus Fault
U1950 UPB Communication Bus Fault
U2000 Audio Rear Control Unit is Not Responding
U2001 Audio Tape Deck Unit is Not Responding
U2002 Audio Bezel is Not Responding
U2003 Audio Compact Disk / Disk Jockey Unit is Not Responding
U2004 Audio Steering Wheel Control Unit is Not Responding
U2005 Audio Rear Integrated Control Panel Unit is Not Responding
U2006 Audio Remote Climate Control Unit is Not Responding
U2007 Audio Navigation Unit is Not Responding
U2008 Audio Phone is Not Responding
U2009 Audio Front Control Module (ACM) is Not Responding
U2010 Module is Not Responding (Non SCP)
U2011 Module Transmitted Invalid Data (Non SCP)
U2012 Communication Bus Error (Non SCP)
U2013 Compass Module is not Responding
U2014 Audio Subwoofer Unit is Not Responding
U2015 Signal Link Fault (Non SCP)
U2016 Signal Link Short to Ground (Non SCP) / From NGV Module
U2017 Driver Side Crash Sensor Communication Fault (Non SCP)
U2018 Passenger Side Crash Sensor Communication Fault (Non SCP)
U2019 Audio Voice Module Not Responding
U2020 Audio Center Amp is not responding
U2021 Invalid /fault data received (Non SCP)
U2150 SCP (J1850) Invalid Data from REM
U2152 SCP (J1850) Invalid Data from GEM
U2160 SCP (J1850) Invalid Data from IC
U2195 SCP (J1850) Invalid Data from SCLM
U2500 (CAN) Lack of Acknowledgement From Engine Management
FORD
P1000Monitor Checks Not Complete-More Driving Required
P1001KOER Not Able to Complete, KOER Aborted
P1100Mass Air Flow Sens Circ Interm.
P1101Mass Air Flow Sens Out Of Self Test Range
P1102Mass Air Flow Sens in Range / Lower Than Expected
P1103Mass Air Flow Sens in Range / Higher Than Expected
P1104Mass Air Flow Sens Circ Ground
P1105Dual Alternator Upper Fault (Monitor)
P1106Dual Alternator Lower Fault (Ctrl)
P1107Dual Alternator Lower Circ Error (Ctrl)
P1108Dual Alternator BATT Lamp Circ Error
P1109Intake Air Temp B Circ Interm.
P1110Intake Air Temp Circ (D/C) Open/Short
P1111Sys Pass (No DTCs Available)
P1112Intake Air Temp Circ Interm.
P1113Intake Air Temp Circ (L/C) Open/Short
P1114Intake Air Temp B Circ Low Input (S/T Charged Eng)
P1115Intake Air Temp B Circ High Input (S/T Charged Eng)
P1116Eng Coolant Temp Sens Out Of Self Test Range
P1117Eng Coolant Temp Sens Circ Interm.
P1118Manf Air Temp Sens Low Input
P1119Manf Air Temp Sens High Input
P1120Throttle Pos Sens A Out Of Range Low (Ratch low)
P1121Throttle Pos Sens A Inconsistent With MAF Sens
P1122Pedal Pos Sens A Circ Low Input
P1123Pedal Pos Sens A Circ High Input
P1124Throttle Pos Sens A Out Of Self Test Range
P1125Throttle Pos Sens A Interm.
P1126Throttle Pos (Narrow Range) Sens Circ
P1127Exhaust Not Warm, Downstream O2 Sens Not Tested
P1128Upstream HO2S Sens Swapped
P1129Downstream HO2S Sens Swapped
P1130Lack Of HO2S11 Switch - Fuel Trim At Limit
P1131Lack Of HO2S11 Switch - Sens Indicates Lean
P1132Lack Of HO2S11 Switch - Sens Indicates Rich
P1133bank1 Fuel Ctrl Shifted Lean (FAOSC)
P1134bank1 Fuel Ctrl Shifted Rich (FAOSC)
P1135Pedal Position Sens A Circ Interm.
P1136Ctrl Box Fan Circ
P1137Lack Of HO2S12 Switch - Sens Indicates Lean
P1138Lack Of HO2S12 Switch - Sens Indicates Rich
P1139Water in Fuel Indicator Circ Error
P1140Water in Fuel Condition
P1141Fuel Restriction Indicator Circ
P1142Fuel Restriction Condition
P1143Air Assisted Injector Ctrl Valve Range/Perf
P1144Air Assisted Injector Ctrl Valve Circ
P1150Lack Of HO2S21 Switch - Fuel Trim At Limit
P1151Lack Of HO2S21 Switch - Sens Indicates Lean
P1152Lack Of HO2S21 Switch - Sens Indicates Rich
P1153bank2 Fuel Ctrl Shifted Lean (FAOSC)
P1154bank2 Fuel Ctrl Shifted Rich (FAOSC)
P1155Alternative Fuel Ctrl Mod Has Activated the MIL
P1156Fuel Select Switch Circ
P1157Lack Of HO2S22 Switch - Sens Indicates Lean
P1158Lack Of HO2S22 Switch - Sens Indicates Rich
P1159Fuel Stepper Motor
P1167Invalid Test - Operator Did Not Actuate Throttle
P1168Fuel Rail Pres Sens In Range But Low
P1169Fuel Rail Pres Sens In Range But High
P1170Eng Shut Off Solenoid
P1171Rotor Sens
P1172Rotor Ctrl
P1173Rotor Calibration
P1174Cam Sens
P1175Cam Ctrl
P1176Cam Calibration
P1177Synchronization
P1178Boltup Limits
P1179Long Term Fuel Trim Too Rich - Banks 1 & 2
P1180Fuel Delivery System - Low
P1181Fuel Delivery System - High
P1182Fuel Shutoff Solenoid Circ
P1183Eng Oil Temp Sens Circ
P1184Eng Oil Temp Sens Circ Perf
P1185Fuel Pump Temp Sens High
P1186Fuel Pump Temp Sens Low
P1187Variant Selection
P1188Calibration Mem
P1189Pump Speed Signal
P1190Calibration Resistor Out Of Range
P1191Key Line Voltage
P1192V External
P1193EGR Dvr Over Current
P1194ECM/PCM A/D Converter
P1195SCP HBCC Chip Failed to Initialize
P1196Key Off Voltage High
P1197Key Off Voltage Low
P1198Pump Rotor Ctrl Under-fueling
P1199Fuel Level Input Circ Low
P1201Cylinder #1 Injector Circ Open/Shorted
P1202Cylinder #2 Injector Circ Open/Shorted
P1203Cylinder #3 Injector Circ Open/Shorted
P1204Cylinder #4 Injector Circ Open/Shorted
P1205Cylinder #5 Injector Circ Open/Shorted
P1206Cylinder #6 Injector Circ Open/Shorted
P1207Cylinder #7 Injector Circ Open/Shorted
P1208Cylinder #8 Injector Circ Open/Shorted
P1209Injection Ctrl System Pres Peak Fault
P1210Injection Ctrl Pres Expected Level
P1211ICP Not Ctrllable - Pres Above/Desired
P1212ICP Voltage Not at Expected Level
P1214Pedal Position Sens B Circ Interm.
P1215Pedal Position Sens C Circ Low Input
P1216Pedal Position Sens C Circ High Input
P1217Pedal Position Sens C Circ Interm.
P1218CID Stuck High
P1219CID Stuck Low
P1220Series Throttle Ctrl System
P1221Traction Ctrl System
P1222Pedal Position Sens B Circ Low Input
P1223Pedal Position Sens B Circ High Input
P1224Throttle Position Sens B Out Of Self Test Range
P1225Injector Circ Cylinder 2 Interm.
P1226Ctrl Sleeve Sens Circ
P1227Wastegate Failed Closed (Over Pres)
P1228Wastegate Failed Open (Under Pres)
P1229Charge Air Cooler Pump Dvr
P1230Fuel Pump Low Speed Error (VLCM)
P1231Fuel Pump Sec Circ Low, High Speed (VLCM)
P1232Fuel Pump Speed Primary Circ(Two speed fuel pump)
P1233Fuel Pump Dvr Mod Disabled/Off Line
P1234Fuel Pump Dvr Mod Disabled/Off Line
P1235Fuel Pump Ctrl out Of Range
P1236Fuel Pump Ctrl Out Of Range
P1237Fuel Pump Sec Circ
P1238Fuel Pump Sec Circ
P1239Speed Fuel Pump Positive Feed
P1240Injector Circ Cylinder 7 Interm.
P1243Injector Circ Cylinder 8 Interm.
P1244Alternator Load High Input
P1245Alternator Load Low Input
P1246Alternator Load Input
P1247Turbo Boost Pres Low
P1248Turbo Boost Pres Not Detected
P1249Wastegate Fail Steady State Test
P1250Electronic Passive Anti-Theft System
P1252Pedal Correlation PDS1 and LPDS High
P1253Pedal Correlation PDS1 and LPDS Low
P1254Pedal Correlation PDS2 and LPDS High
P1255Pedal Correlation PDS2 and LPDS Low
P1256Pedal Correlation PDS1 and HPDS
P1257Pedal Correlation PDS2 and HPDS
P1258Pedal Correlation PDS1 and PDS2
P1260Theft Detected, Vehicle Immobilized
P1261High to Low Side Short - Cylinder 1
P1262High to Low Side Short - Cylinder 2
P1263High to Low Side Short - Cylinder 3
P1264High to Low Side Short - Cylinder 4
P1265High to Low Side Short - Cylinder 5
P1266High to Low Side Short - Cylinder 6
P1267High to Low Side Short - Cylinder 7
P1268High to Low Side Short - Cylinder 8
P1270Eng RPM/Vehicle Speed Limiter Reached
P1271High to Low Side Open - Cylinder 1
P1272High to Low Side Open - Cylinder 2
P1273High to Low Side Open - Cylinder 3
P1274High to Low Side Open - Cylinder 4
P1275High to Low Side Open - Cylinder 5
P1276High to Low Side Open - Cylinder 6
P1277High to Low Side Open - Cylinder 7
P1278High to Low Side Open - Cylinder 8
P1280ICP Circ Out of Range Low
P1281ICP Circ Out of Range High
P1282Excessive ICP
P1283Injector Pres Regulator Circ
P1284ICP Failure - Aborts KOER/CCT Test
P1285Cylinder Head Overtemp Condition
P1286Fuel Pulsewidth in Range But Lower Than Expected
P1287Fuel Pulsewidth in Range But Higher Than Expected
P1288Cylinder Head Temp Sens Out Of Self Test Range
P1289Cylinder Head Temp Sens Circ High Input
P1290Cylinder Head Temp Sens Circ Low Input
P1291High Side No. 1 (Right) Short to GND/B+
P1292High Side No. 2 (Left) Short to GND/B+
P1293High Side Open Bank No. 1 (Right)
P1294High Side Open Bank No. 2 (Left)
P1295Multiple Faults on Bank No. 1 (Right)
P1296Multiple Faults on Bank No. 2 (Left)
P1297High Sides Shorted Together
P1298Injector Dvr Mod Failure
P1299Cylinder Head Overtemp Protection Active
P1300Boost Calibration Fault
P1301Boost Calibration High
P1302Boost Calibration Low
P1303Exhaust Gas Recirculation Calibration Fault
P1304Exhaust Gas Recirculation Calibration High
P1305Exhaust Gas Recirculation Calibration Low
P1306Kickdown Relay Pull-in Circ
P1307Kickdown Relay Hold Circ
P1309 Misfire Mon Hdwr-CMP Misaligned, CKP/CMP Noise,PCM AICE Chip
P1310Ionization Misfire Detect Mod Fault
P1311Ionization Misfire Detect Mod Comm Fault
P1316Injector Circ/IDM Codes Detected
P1317Injector Circ/IDM Codes Not Retrieved
P1336Crankshaft Position System Variation Not Learned
P1340Camshaft Position Sens B Circ
P1350Ignition Ctrl System
P1351Ignition Diag Monitor Input Circ
P1352Ignition Coil A Primary Circ
P1353Ignition Coil B Primary Circ
P1354Ignition Coil C Primary Circ
P1355Ignition Coil D Primary Circ
P1356Ignition Diag Monitor Indicates Eng Not Turning
P1357Ignition Diag Monitor Pulsewidth Not Defined
P1358Ignition Diag Monitor Signal Out Of Self Test Range
P1359Spark Output Circ
P1360Ignition Coil A Sec Circ
P1361Ignition Coil B Sec Circ
P1362Ignition Coil C Sec Circ
P1363Ignition Coil D Sec Circ
P1364Ignition Coil Primary Circ
P1365Ignition Coil Sec Circ
P1366Ignition Spare
P1367Ignition Spare
P1368Ignition Spare
P1369Eng Temp Light Circ
P1380Camshaft Position Actuator Circ (bank1)
P1381Camshaft Position Timing Over Advanced (bank1)
P1383Camshaft Position Timing Over Retarded (bank1)
P1385Camshaft Position Actuator Circ (bank2)
P1386Camshaft Position Timing Over Advanced (bank2)
P1388Camshaft Position Timing Over Retarded (bank2)
P1389Glow Plug Circ High Side, Low Input
P1390Octane Adjust Service Pin In Use/Circ Open
P1391Glow Plug Circ Low Input Bank No. 1(Right)
P1392Glow Plug Circ High Input (bank1)
P1393Glow Plug Circ Low Input Bank No. 2 (Left)
P1394Glow Plug Circ High Input (bank2)
P1395Glow Plug Monitor Fault Bank No. 1
P1396Glow Plug Monitor Fault Bank No. 2
P1397System Voltage Out of Self Test Range
P1398Wheel Speed Sens2 - G - Sens Circ High Voltage
P1399Glow Plug Circ High Side, High Input
P1400Diff Pres Feedback EGR Circ Low Input
P1401Diff Pres Feedback EGR Circ High Input
P1402Exhaust Gas Recirculation Metering Orifice Restricted
P1403Diff Pres Feedback Sens Hoses Reversed
P1404EGR Temp Sens Circ
P1405Diff Pres Feedback Sens Upstream Hose Off/Plugged
P1406Diff Pres Feedback Sens Downstream Hose Off/Plugged
P1407Exhaust Gas Recirculation No Flow Detected
P1408Exhaust Gas Recirculation Flow Out Of Self Test Range
P1409EGR Vacuum Regulator Solenoid Circ
P1410Auxiliary Air Cleaner Inlet Ctrl Circ
P1411Sec Air Injection Incorrect Downstream Flow Detected
P1413Sec Air Injection Monitor Circ Low Input
P1414Sec Air Injection Monitor Circ High Input
P1431Misfire Monitor Disabled, unable to learn trig whl profile
P1442Evap Emission Ctrl System Ctrl Leak Detected
P1443Evap Emission Ctrl System Ctrl Valve
P1444Purge Flow Sens Circ Low Input
P1445Purge Flow Sens Circ High Input
P1450Unable to Bleed Up Fuel Tank Vacuum
P1451Evap Emission Ctrl System Vent Ctrl Circ
P1452Unable to Bleed Up Fuel Tank Vacuum
P1455Evap Emission Ctrl Sys Ctrl Leak (gross leak/no flow)
P1456Fuel Tank Temp Sens Circ
P1457Unable To Pull Fuel Tank Vacuum
P1460Wide Open Throttle A/C Cutout Circ
P1461A/C Pres Sens Circ High Input
P1462A/C Pres Sens Circ Low Input
P1463A/C Pres Sens Insuff Pres Change
P1464A/C On During KOER/CCT Test
P1465A/C Relay Circ
P1466A/C Refrigerant Temp Sens Circ
P1469Rapid A/C Cycling
P1473Fan Circ Open (VLCM
P1474Fan Ctrl Primary Circ
P1479High Fan Ctrl Primary Circ
P1480Fan Sec Low with Low Fan On
P1481Fan Sec Low with High Fan On
P1482SCP
P1483Fan Circ Shorted To Ground (VLCM)
P1484Fan Dvr Circ Open To Power Ground (VLCM)
P1485Brake Pedal Input Short To Battery
P1500Vehicle Speed Sens
P1501Vehicle Speed Sens Out Of Self Test Range
P1502VSS Interm./Invalid Self Test - APCM Functioning
P1504Idle Air Ctrl Circ
P1505Idle Air Ctrl System At Adaptive Clip
P1506Idle Air Ctrl Overspeed Error
P1507Idle Air Ctrl Underspeed Error
P1512Intake Manf Runner Ctrl Stuck Closed (bank1)
P1513Intake Manf Runner Ctrl Stuck Closed (bank2)
P1516Intake Manf Runner Ctrl Input Error (bank1)
P1517Intake Manf Runner Ctrl Input Error (bank2)
P1518Intake Manf Runner Ctrl Stuck Open (bank1)
P1519Intake Manf Runner Ctrl Stuck Closed (bank2)
P1520Intake Manf Runner Ctrl Circ
P1530A/C Clutch Circ Open (VLCM)
P1531Invalid Test -Accelerator Pedal Movement
P1532Intake Manf Comm Ctrl Circ (bank2)P1533
P1534Restraint Deployment Indicator Circ
P1536Parking Brake Applied Failure
P1537Intake Manf Runner Ctrl Stuck Open (bank1)
P1538Intake Manf Runner Ctrl Stuck Open (bank2)
P1539A/C Clutch Circ Overcurrent/Short (VLCM)
P1542Primary PCM ID Circ (dual PCM application)
P1543Eng Coolant heater A Ctrl Circ
P1544Eng Coolant heater B Ctrl Circ
P1549Intake Manf Comm Ctrl Circ (bank1)
P1550Power Steering Pres Sens Out Of Self Test Range
P1565Speed Ctrl Command Switch Out of Range High
P1566Speed Ctrl Command Switch Out of Range Low
P1567Speed Ctrl Output Circ
P1568Speed Ctrl Unable to Hold Speed
P1572Brake Pedal Switch Circ
P1573Throttle Position Not Available
P1574Throttle Position Sens Outputs Disagree
P1575Pedal Position Out Of Self Test Range
P1576Pedal Position Not Available
P1577Pedal Position Sens Outputs Disagree
P1578ETC Power Less Than Demand
P1579ETC In Power Limiting Mode
P1580Electronic Throttle Monitor PCM Override
P1581Electronic Throttle Monitor Error
P1582Electronic Throttle Monitor Data Available
P1583Electronic Throttle Monitor Cruise Disablement
P1584Throttle Ctrl Detected ETB Error
P1585Throttle Ctrl Error
P1586Electronic Throttle to PCM Comm Error
P1587Throttle Ctrl Modulated Command Error
P1588Throttle Ctrl Detected Loss Of Return Spring
P1589Throttle Ctrl Unable To Ctrl To Desired Throttle Angle
P1600Loss Of KAM Power, Circ Open
P1605Keep Alive Memory Test Failure
P1610SBDS Interactive Codes
P1611SBDS Interactive Codes
P1612SBDS Interactive Codes
P1613SBDS Interactive Codes
P1614SBDS Interactive Codes
P1615SBDS Interactive Codes
P1616SBDS Interactive Codes
P1617SBDS Interactive Codes
P1618SBDS Interactive Codes
P1619SBDS Interactive Codes
P1620SBDS Interactive Codes
P1625Fan Dvr Circ Open to Power B+ (VLCM)
P1626A/C Circ Open to Power B+ (VLCM)
P1633Keep Alive Power Voltage Too Low
P1634Data Output Link Circ
P1635Tire/Axle Out of Acceptable Range
P1636Inductive Signature Chip Comm Error
P1639Vehicle ID Block Corrupted, Not Programmed
P1640Powertrain DTCs Available In Another Ctrl Mod
P1641Fuel Pump Primary Circ
P1642CAN Link Circ
P1643CAN Link Eng Ctrl Mod/Tran Ctrl Mod Circ/Network
P1644Fuel Pump Speed Ctrl Circ
P1650Power Steering Pres Switch Out Of Self Test Range
P1651Power Steering Pres Switch Input
P1656CAN Link PCM/PCM Circ/Network
P1657CAN Link Chip Error
P1660Output Circ Check Circ High Input
P1661Output Circ Check Circ Low Input
P1662EDU_EN Output Circ
P1663Fuel Demand Command Signal Output Circ Failure
P1667Cylinder ID Circ Failure
P1668PCM/IDM Diagnostic Comm Error
P1670EF Feedback Signal Not Detected
P1690Wastegate Ctrl Valve Error
P1700Tran Indeterminate Failure (Failed to Neutral)
P1701Reverse Engagement Error
P1702Tran Range Sens Interm. Circ Error
P1703Brake Switch Out Of Self Test Range
P1704Tran Range Sens Failed to Transition State or Tran Range Sens out of Self Test Range
P1705Tran Range Circ Not Indicating P/N in Self test
P1706High Vehicle Speed Observed in Park
P1707Transfer Case Neutral Indicator Hard Fault Present
P1709Park Neutral Position Switch Out Of Self Test Range
P1711Tran Fluid Temp Sens Out Of Self Test Range
P1712Tran Torque Reduction Request Signal
P1713Tran Fluid Temp Sens In Range Failure(< 50 F)
P1714Shift Solenoid A Inductive Signature
P1715Shift Solenoid B Inductive Signature Error
P1716Shift Solenoid C Inductive Signature
P1717Shift Solenoid D Inductive Signature
P1718TFT Stuck in Range High-25OF
P1725Insuff Eng Speed Increase During Self Test
P1726Insuff Eng Speed Decrease During Self Test
P1727Coast Clutch Solenoid Inductive Signature
P1728Tran Slip Error
P17294x4L Switch Error
P17311-2 Shift Error
P17322-3 Shift Error
P17333-4 Shift Error
P1740Torque Converter Clutch Solenoid Inductive Signal
P1741Torque Converter Clutch Solenoid Ctrl Error
P1742Torque Converter Clutch Solenoid Circ Failed On
P1743Torque Converter Clutch Solenoid Circ Failed On*
P1744Torque Converter Clutch System Perf
P1746EPC Solenoid Open Circ
P1747EPC Solenoid Short Circ
P1748Pres Ctrl Solenoid A
P1749Pres Ctrl Solenoid A Failed Low
P1751Shift Solenoid A Perf
P1754Coast Clutch Solenoid Circ Error
P1756Shift Solenoid B Perf
P1760EPC Solenoid Short Interm.
P1761Shift Solenoid C Perf
P1762Overdrive Band Failed Off
P1766Shift Solenoid D Perf
P1767Torque Converter Clutch Circ
P1768Perf/Normal/Winter Mode Input
P1770Clutch Solenoid Circ
P1779TCIL Circ
P1780TCS Circ Out of self Test Range
P17814x4L Circ Out of Self Test Range
P1782Perf/Economy Switch Circ Out Of Self Test Range
P1783Tran Overtemp Condition
P1784Tran Mechanical Failure - 1st And Reverse
P1785Tran Mechanical Failure - 1st And 2nd
P17863-2 Downshift Error
P17872-1 Downshift Error
P1788Pres Ctrl Solenoid B Open Circ
P1789Pres Ctrl Solenoid B Short Circ
P1795Inconsistent CAN Level
P18044WD High Indicator Circ Open/Shorted To Ground
P18064WD High Indicator Short To Battery
P18084WD Low Indicator Circ Open/Short To Ground
P18104WD Low Indicator Short To Battery
P18124WD Mode Select Switch Circ Open
P18154WD Mode Select Switch Circ Short To Ground
P1819Neutral Safety Switch Input Short To Ground
P1820Transfer Case LO/HI Shift Relay Circ Open/Short To Gnd
P1822Transfer Case LO/HI Shift Relay Coil Short To Battery
P18244WD Electric Clutch Relay Open/Short To Ground
P18264WD Electric Clutch Relay Short To Battery
P1828Transfer Case HI/LO Shift Relay Coil Circ Open/Short to Gnd
P1830Transfer Case HI/LO Shift Relay Coil Circ Short To Battery
P1832Transfer Case 4WD Solenoid Circ Open/Short To Gnd
P1834Transfer Case 4WD Solenoid Circ Short To Battery
P1838No Shift Motor Movement Detected
P1846Transfer Case Contact Plate 'A' Circ Open
P1850Transfer Case Contact Plate 'B' Circ Open
P1854Transfer Case Contact Plate 'C' Circ Open
P1858Transfer Case Contact Plate 'D' Circ Open
P1865Transfer Case Contact Plate Power Short to Ground
P1866Transfer Case Cannot Be Shifted
P1867Transfer Case Contact Plate General Circ Failure
P1876Transfer Case 2WD Solenoid Circ Open/Short To Gnd
P1877Transfer Case 2WD Solenoid Circ Short To Battery
P1881Eng Coolant Level Switch Circ
P1882Eng Coolant Level Switch Circ Short To Ground
P1883Eng Coolant Level Switch Circ
P1884Eng Coolant Level Lamp Circ Short To Ground
P1891Transfer Case Contact Plate Gnd Return Open Circ
P1900Output Shaft Speed Sens Circ Interm.
P1901Turbine Shaft Speed Sens Circ Interm.
P1902Kickdown Solenoid Relay Ctrl Circ (Allison)
P1903Kickdown Solenoid Circ Low Voltage
P1904Kickdown Solenoid Circ High Voltage
U1058J1850 SCP Trans Fluid Temp Invalid ЁC Instr Clstr
U1059J1850 SCP Trans/Transaxle PRNDL invalid-Instr Clstr
U1073J1850 SCP Engine Coolent Invalid ЁC Instr Clstr
U1262J1850 SCP Comm Bus Fault ЁC Instr Clstr
U1950UBP Comm Bus Fault - DSM,or UBP Comm Bus Fault - VSM,or UBP Comm Bus Fault ЁC Instr Clstr
Geo
P1250Early fuel evaporation heater circuit fault
P1300Ignition Coil 1 Primary Feedback Circuit
P1305Ignition Coil 2 Primary Feedback Circuit
P1310Ignition Coil 3 Primary Feedback Circuit
P1315Ignition Coil 4 Primary Feedback Circuit
P1335Crankshaft position sensor circuit
P1346Intake Camshaft Position System Performance
P1349Intake Camshaft Position System
P1408MAP Sensor Circuit
P1410Fuel tank pressure system fault
P1450Barometric pressure sensor circuit fault
P1451Barometric pressure sensor performance
P1460Cooling fan control system fault
P1500Starter signal circuit fault
P1510Backup power supply fault
P1520Stop Lamp Switch Circuit
P1530Ignition timing adjustment switch circuit
P1600PCM battery circuit fault
P1656Intake CMP Actuator Solenoid Control Circuit
GM
P1031Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
P1032Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
P1101Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
P1105Secondary Vacuum Sensor Circuit
P1106Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1107Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
P1108BARO to MAP Sensor Comparison Too High
P1109Secondary Port Throttle System
P1111Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
P1112Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
P1113Intake Resonance Switchover Solenoid Control Circuit
P1114Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
P1115Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
P1116ECT Signal Unstable or Intermittent
P1117Engine Coolant Temp. Signal Out-Of-Range Low
P1118Engine Coolant Temp. Signal Out-Of-Range High
P1119ECT Signal Out-Of-Range With TFT Sensor
P1120Throttle Position (TP) Sensor 1 Circuit
P1121Throttle Position (TP) Sensor Circuit Intermittent High Voltage
P1122Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
P1125Accelerator Pedal Position (APP) System
P1130Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1
P1131Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
P1132Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
P1133Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1134Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
P1135Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1
P1136Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1
P1137Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
P1138Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
P1139Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2
P1140Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2
P1141Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P1143Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage
P1144Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage
P1145Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3
P1153Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
P1154Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
P1155Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
P1156Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
P1157Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage
P1158Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage
P1159Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2
P1161Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2
P1163Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage
P1164Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage
P1165Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3
P1170Bank to Bank Fuel Trim Offset
P1171Fuel System Lean During Acceleration
P1172Fuel Transfer Pump Flow Insufficient
P1185Engine Oil Temperature Circuit
P1186EOT Circuit Performance
P1187EOT Sensor Circuit Low Voltage
P1188EOT Sensor Circuit High Voltage
P1189Engine Oil Pressure (EOP) Switch Circuit
P1190Engine Vacuum Leak
P1191Intake Air Duct Air Leak
P1200Injector Control Circuit
P1201(Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
P1202(Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
P1203(Alt. Fuel) Gas Mass Sensor Circuit High Frequency
P1211Mass Air Flow Circuit Intermittent High
P1212Mass Air Flow Circuit Intermittent Low
P1214Injection Pump Timing Offset
P1215Ground Fault Detection Indicated
P1216Fuel Solenoid Response Time Too Short
P1217Fuel Solenoid Response Time Too Long
P1218Injection Pump Calibration Circuit
P1219Throttle Position Sensor Reference Voltage
P1220Throttle Position (TP) Sensor 2 Circuit
P1221Fuel Pump Secondary Circuit Low
P1222Injector Control Circuit Intermittent
P1225Injector Circuit Cylinder 2 Intermittent
P1228Injector Circuit Cylinder 3 Intermittent
P1231Injector Circuit Cylinder 4 Intermittent
P1234Injector Circuit Cylinder 5 Intermittent
P1237Injector Circuit Cylinder 6 Intermittent
P1240Injector Circuit Cylinder 7 Intermittent
P1243Injector Circuit Cylinder 8 Intermittent
P1245Intake Plenum Switchover Valve
P1250Early Fuel Evaporation Heater Circuit
P1257Supercharger System Overboost
P1258Engine Coolant Overtemperature - above 268ЎгF - Protection Mode Active
P1260Last Test Failed Failed SCC ENTER:More Info.
P1270Accelerator Pedal Position Sensor A/D Converter Error
P1271Accelerator Pedal Position (APP) Sensor 1-2 Correlation
P1272Accelerator Pedal Position Sensor 2
P1273"Accelerator Pedal Position Sensor 1
P1274Injectors Wired Incorrectly
P1275Accelerator Pedal Position (APP) Sensor 1 Circuit
P1276Accelerator Pedal Position Sensor 1 Circuit Performance
P1277Accelerator Pedal Position Sensor 1 Circuit Low Voltage
P1278Accelerator Pedal Position Sensor 1 Circuit High Voltage
P1280Accelerator Pedal Position (APP) Sensor 2 Circuit
P1281Accelerator Pedal Position Sensor 2 Circuit Performance
P1282Accelerator Pedal Position Sensor 2 Circuit Low Voltage
P1283Accelerator Pedal Position Sensor 2 Circuit High Voltage
P1285Accelerator Pedal Position Sensor 3 Circuit
P1286Accelerator Pedal Position Sensor 3 Circuit Performance
P1287Accelerator Pedal Position Sensor 3 Circuit Low Voltage
P1288Accelerator Pedal Position Sensor 3 Circuit High Voltage
P1300Ignitor Circuit
P1320IC 4X Reference Circuit Intermittent
P1321Electronic Ignition System Fault Line
P1322EI System or Ignition Control Extra or Missing
P1323IC 24X Reference Circuit Low Frequency
P1324Crank RPM Too Low
P1335CKP Circuit
P1336Crankshaft Position (CKP) System Variation Not Learned
P1345Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
P1346Intake Camshaft Position [CMP] Sensor System Performance
P1350Ignition Control System
P1351Ignition Coil Control Circuit High Voltage
P1352IC Output High/Pulse Detected when GND_Cyl. 2
P1353IC Output High/Pulse Detected when GND_Cyl. 3
P1354IC Output High/Pulse Detected when GND_Cyl. 4
P1355IC Output High/Pulse Detected when GND_Cyl. 5
P1356IC Output High/Pulse Detected when GND_Cyl. 6
P1357IC Output High/Pulse Detected when GND_Cyl. 7
P1358IC Output High/Pulse Detected when GND_Cyl. 8
P1359Ignition Coil Group 1 Control Circuit
P1360Ignition Coil Group 2 Control Circuit
P1361Ignition Coil Control Circuit Low Voltage
P1362IC Cylinder 2 Not Toggling After Enable
P1363IC Cylinder 3 Not Toggling After Enable
P1364IC Cylinder 4 Not Toggling After Enable
P1365IC Cylinder 5 Not Toggling After Enable
P1366IC Cylinder 6 Not Toggling After Enable
P1367IC Cylinder 7 Not Toggling After Enable
P1368IC Cylinder 8 Not Toggling After Enable
P1370IC 4X Reference Circuit Too Many Pulses
P1371IC 4X Reference Circuit Too Few Pulses
P1372Crankshaft Position (CKP) Sensor A-B Correlation
P13743X Reference Circuit
P1375IC 24X Reference Circuit High Voltage
P1376Ignition Ground Circuit
P1377IC Cam Pulse To 4X Reference Pulse
P1380Misfire Detected - Rough Road Data Not Available
P1381Misfire Detected - No Communication with Brake Control Module
P1390Wheel Speed Sensor 1 - G - Sensor Circuit
P1391Wheel Speed Sensor 1 - G - Sensor Circuit Performance
P1392Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
P1393Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
P1394Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
P1395Wheel Speed Sensor 2 - G - Sensor Circuit
P1396Wheel Speed Sensor 2 - G - Sensor Circuit Performance
P1397Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
P1398Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
P1399Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
P1401Exhaust Gas Recirculation (EGR) flow test fault
P1403Exhaust Gas Recirculation System Valve 1
P1404Exhaust Gas Recirculation (EGR) Closed Position Performance
P1405Exhaust Gas Recirculation System Valve 3
P1406EGR Valve Pintle Position Circuit
P1407EGR Air Intrusion in Exhaust Supply to EGR Valve
P1408Intake Manifold Pressure Sensor Circuit
P1409EGR Vacuum System Leak
P1410Fuel Tank Pressure System
P1415Secondary Air Injection (AIR) System Bank 1
P1416Secondary Air Injection (AIR) System Bank 2
P1418Secondary Air Injection System Relay A Control Circuit High
P1420Intake Air Low Pressure Switch Circuit Low Voltage
P1421Intake Air Low Pressure Switch Circuit High Voltage
P1423Intake Air High Pressure Switch Circuit High Voltage
P1431Fuel Level Sensor 2 Circuit Performance
P1432Fuel Level Sensor 2 Circuit Low Voltage
P1433Fuel Level Sensor 2 Circuit High Voltage
P1441Evaporative Emission (EVAP) System Flow During Non-Purge
P1442EVAP Vacuum Sw. High Voltage During Ign. On
P1450Barometric Pressure Sensor Circuit
P1451Barometric Press. Sensor Performance
P1460Cooling Fan Control System
P1480Cooling Fan 1 Control Circuit High
P1481Cooling Fan Speed Sensor Circuit
P1482Cooling Fan Speed Output Circuit
P1483Engine Cooling System Performance
P1484Cooling Fan System Performance
P1500Starter Signal Circuit
P1501Theft Deterrent System
P1501Vehicle Speed Sensor Circuit Intermittent
P1502Theft Deterrent Fuel Enable Signal Not Received
P1503Theft Deterrent Fuel Enable Signal Not Correct
P1504Vehicle Speed Output Circuit
P1508Idle Speed Low - Idle Air Control (IAC) System Not Responding
P1509Idle Speed High - Idle Air Control (IAC) System Not Responding
P1510Throttle Control System Performance - Throttle Limitation Active
P1511Throttle Control System - Backup System Performance
P1514Airflow to TP Sensor Correlation High
P1515Electronic Throttle System Throttle Position
P1516Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
P1517Electronic Throttle Module
P1518Electronic Throttle Module to PCM Communication
P1519Throttle Actuator Control (TAC) Module Internal Circuit
P1520Transmission Range Switch Circuit
P1521Transmission Engaged at High Throttle Angle
P1522Park/Neutral to Drive/Reverse at High RPM
P1523Throttle Closed Position Performance
P1524Throttle Closed Position Performance
P1525Throttle Body ServiceRequired
P1526Minimum Throttle Position Not Learned
P1527Transmission Range to Pressure Switch Correlation
P1528Governor
P1529Heated Windshield Request Problem
P1530Throttle Actuator Control (TAC) Module Internal Circuit
P1531A/C Low Side Temperature Sensor Fault
P1532A/C Evaporator Temp. Sens. Circuit Low Voltage
P1533A/C Evaporator Temp. Sens. Circuit High Voltage
P1534A/C High Side Temp. Sensor Low Voltage
P1535A/C High Side Temperature Sensor Circuit
P1536Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
P1537A/C Request Circuit Low Voltage
P1538A/C Request Circuit High Voltage
P1539A/C Clutch Status Circuit High Voltage
P1540Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
P1541A/C High Side Over Temperature
P1542A/C System High Pressure High Temperature
P1543A/C System Performance
P1544A/C Refrigerant Condition Very Low
P1545Air Conditioning (A/C) Clutch Relay Control Circuit
P1546A/C Clutch Status Circuit Low Voltage
P1547A/C System Performance Degraded
P1548A/C Recirculation Circuit
P1551Throttle Valve Rest Position Not Reached During Learn
P1554Cruise Control Feedback Circuit
P1555Electronic Variable Orifice Output
P1558Cruise Control Servo Indicates Low
P1559Cruise Control Power Management Mode
P1560Transaxle Not in Drive - Cruise Control Disabled
P1561Cruise Vent Solenoid
P1562Cruise Vacuum Solenoid
P1563Cruise Vehicle Speed/Set Speed Difference Too High
P1564Vehicle Acceleration Too High - Cruise Control Disabled
P1565Cruise Servo Position Sensor
P1566Engine RPM Too High - Cruise Control Disabled
P1567Active Banking Control Active - Cruise Control Disabled
P1568Cruise Servo Stroke Greater than Commanded in Cruise
P1569Cruise Servo Stroke High While not in Cruise
P1570Traction Control Active - Cruise Control Disabled
P1571Traction Control Torque Request Circuit
P1572ASR Active Circuit Low Too Long
P1573PCM/EBTCM Serial Data Circuit
P1574Stoplamp Switch Circuit
P1575Extended Travel Brake Switch Circuit
P1576BBV Sensor Circuit High Voltage
P1577BBV Sensor Circuit Low Voltage
P1578BBV Sensor Circuit Low Vacuum
P1579P/N to D/R at High Throttle Angle - Power Reduction Mode Active
P1580Cruise Move Circuit Low Voltage
P1581Cruise Move Circuit High Voltage
P1582Cruise Direction Circuit Low Voltage
P1583Cruise Direction CircuitHigh Voltage
P1584Cruise Control Disabled
P1585Cruise Control Inhibit Output Circuit
P1586Cruise Control Brake Switch 2 Circuit
P1587Cruise Control Clutch Control Circuit Low
P1588Cruise Control Clutch Control Circuit High
P1599Engine Stall or Near Stall Detected
P1600TCM Internal Watchdog Operation
P1601Serial Comm. Problem With Device 1
P1602Knock Sensor (KS) Module Performance
P1603Loss of SDM Serial Data
P1604Loss of IPC Serial Data
P1605Loss of HVAC Serial Data
P1606Serial Communication Problem With Device 6
P1607Serial Communication Problem With Device 7
P1608Serial Communication Problem With Device 8
P1609Loss Of TCS Serial Data
P1610Loss Of PZM Serial Data
P1611Loss Of CVRTD Serial Data
P1612Loss Of IPM Serial Data
P1613Loss Of DIM Serial Data
P1614Loss Of RIM Serial Data
P1615Loss Of VTD Serial Data
P1617Engine Oil Level Switch Circuit
P1619Engine Oil Life Monitor Reset Circuit
P1620Low Coolant Circuit
P1621Control Module Long Term Memory Performance
P1622Cylinder Select
P1623Transmission Temp Pull-Up Resistor
P1624Customer Snapshot Requested - Data Available
P1625TCM System Reset
P1626Theft Deterrent Fuel Enable Signal Not Received
P1627A/D Performance
P1628ECT Pull-Up Resistor
P1629Theft Deterrent System - Cranking Signal
P1630Theft Deterrent Learn Mode Active
P1631Theft Deterrent Start Enable Signal Not Correct
P1632Theft Deterrent Fuel Disable Signal Received
P1633Ignition 0 Switch Circuit
P1634Ignition 1 Switch Circuit
P16355 Volt Reference Circuit
P1636PCM Stack Overrun
P1637Generator L-Terminal Circuit
P1638Generator F-Terminal Circuit
P16395 Volt Reference 2 Circuit
P1640Driver-1-Input High Voltage
P1641Malfunction Indicator Lamp (MIL) Control Circuit
P1642Vehicle Speed Output Circuit
P1643Engine Speed Output Circuit
P1644Traction Control Delivered Torque Output Circuit
P1645Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
P1646Evaporative Emission (EVAP) Vent Solenoid Control Circuit
P1647Driver 1 Line 7
P1650Control Module Output B Circuit
P1651Fan 1 Relay Control Circuit
P1652Powertrain Induced Chassis Pitch Output Circuit
P1653Oil Level Lamp Control Circuit
P1654Cruise Control Inhibit Output Circuit
P1655EVAP Purge Solenoid Control Circuit
P1656Driver 2 Line 6
P16571-4 Upshift Solenoid Control Circuit
P1658Starter Enable Relay Control Circuit
P1660Cooling Fan Control Circuits
P1661MIL Control Circuit
P1662Cruise Lamp Control Circuit
P1663Oil Life Lamp Control Circuit
P16641-4 Upshift Lamp Control Circuit
P1665Driver 3 Line 5
P1666Driver 3 Line 6
P1667Reverse Inhibit Solenoid Control Circuit
P1669ABS Unit Expected
P1670Driver 4
P1671Driver 4 Line 1
P1672Low Engine Oil Level Lamp Control Circuit
P1673Engine Hot Lamp Control Circuit
P1674Tachometer Control Circuit
P1675EVAP Vent Solenoid Control Circuit
P1676Driver 4 Line 6
P1677Driver 4 Line 7
P1680Driver 5 (ECU Malfunction)
P1681Driver 5 Line 1
P1682Driver 5 Line 2
P1683Driver 5 Line 3
P1684Driver 5 Line 4
P1685Driver 5 Line 5
P1686Driver 5 Line 6
P1687Driver 5 Line 7
P1689Delivered Torque Circuit Fault
P1690ECM Loop Overrun
P1691Coolant Gage Circuit Low Voltage
P1692Coolant Gage Circuit High Voltage
P1693Tachometer Circuit Low Voltage
P1694Tachometer Circuit High Voltage
P1695Remote Keyless Entry Circuit Low
P1696Remote Keyless Entry Voltage High
P1700Transmission Control Module (TCM) Requested MIL Illumination
P1701Trans. MIL Request Circuit
P1705P/N Signal Output Circuit
P1719Incorrect Shifting Detected (TCM)
P1740Torque Reduction Signal Circuit
P1743TP Signal from ECM
P1760TCM Supply Voltage Interrupted
P1779Engine Torque Delivered to TCM Signal
P1780Park/Neutral Position [PNP] Switch Circuit
P1781Engine Torque Signal Circuit
P1790Transmission Control Module Checksum
P1791Transmission Control Module Loop
P1791Throttle/Pedal Position Signal (2000+)
P1792Transmission Control Module Reprogrammable Memory
P1792ECM to TCM Engine Coolant Signal
P1793Transmission Control Module Stack Overrun
P1793Wheel Speed Signal (2000+)
P1795CAN Bus - Throttle Body Position
P1800TCM Power Relay Control Circuit
P1801Performance Selector Switch Failure
P1804Ground Control Relay
P1810TFP Valve Position Switch Circuit
P1811Maximum Adapt and Long Shift
P1812Transmission Over Temperature Condition
P1813Torque Control
P1814Torque Converter Overstressed
P1815Transmission Range Switch - Start In Wrong Range
P1816TFP Valve Position Sw. - Park/Neu. With Drive Ratio
P1817TFP Valve Position Sw. - Reverse With Drive Ratio
P1818TFP Valve Position Sw. - Drive Without Drive Ratio
P1819Internal Mode Switch - No Start\Wrong Range
P1820Internal Mode Switch Circuit A Low
P1822Internal Mode Switch Circuit B High
P1823Internal Mode Switch Circuit P Low
P1825Internal Mode Switch - Invalid Range
P1826Internal Mode Switch Circuit C - High
P1831Pressure Control (PC) Solenoid Power Circuit - Low Voltage
P1832Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
P1833A/T Solenoids Power Circuit - Low Voltage
P1834Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage
P1835Kick-Down Switch Circuit
P1836Kick-Down Switch Failed Open
P1837Kick-Down Switch Failed Short
P18421-2 Shift Solenoid Circuit Low Voltage
P18431-2 Shift Solenoid Circuit High Voltage
P1844Torque Reduction Signal Circuit Desired By TCM
P18452-3 Shift Solenoid Circuit Low Voltage
P18472-3 Shift Solenoid Circuit High Voltage
P1850Brake Band Apply Solenoid Circuit
P1851Brake Band Apply Solenoid Performance
P1852Brake Band Apply SolenoidLow Voltage
P1853Brake Band Apply Solenoid High Voltage
P1860TCC PWM Solenoid Circuit Electrical
P1864Torque Converter Clutch Circuit
P18654-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
P1866Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage
P1867Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage
P1868Transmission Fluid Life
P1870Transmission Component Slipping
P1871Undefined Gear Ratio
P1873TCC Stator Temp. Switch Circuit Low
P1874TCC Stator Temp. Switch Circuit High
P18754WD Low Switch Circuit Electrical
P1884TCC Enable/Shift Light Circuit
P1886Shift Timing Solenoid
P1887TCC Release Switch Circuit
P1890ECM Data Input Circuit, or - Throttle Position Signal Input
P1891Throttle Position Sensor PWM Signal Low
P1892Throttle Position Sensor PWM Signal High
P1893Engine Torque Signal Low Voltage
P1894Engine Torque Signal High Voltage
P1895TCM to ECM Torque Reduction Circuit
U1000Class 2 Communication Malfunction
U1001Loss of serial communications for class 2 devices
U1002Loss of serial communications for class 2 devices
U1003Loss of serial communications for class 2 devices
U1004Loss of serial communications for class 2 devices
U1005Loss of serial communications for class 2 devices
U1006Loss of serial communications for class 2 devices
U1007Loss of serial communications for class 2 devices
U1008Loss of serial communications for class 2 devices
U1009Loss of serial communications for class 2 devices
U1010Loss of serial communications for class 2 devices
U1011Loss of serial communications for class 2 devices
U1012Loss of serial communications for class 2 devices
U1013Loss of serial communications for class 2 devices
U1014Loss of serial communications for class 2 devices
U1015Loss of serial communications for class 2 devices
U1016Loss of Class 2 Communication with VCM
U1016Loss of Communications with PCM
U1017Loss of serial communications for class 2 devices
U1018Loss of serial communications for class 2 devices
U1019Loss of serial communications for class 2 devices
U1020Loss of serial communications for class 2 devices
U1021Loss of serial communications for class 2 devices
U1022Loss of serial communications for class 2 devices
U1023Loss of serial communications for class 2 devices
U1024Loss of serial communications for class 2 devices
U1025Loss of serial communications for class 2 devices
U1026Loss of ATC Class 2 Communication
U1027Loss of Serial Communications for Class 2 Devices
U1028Loss of Serial Communications for Class 2 Devices
U1029Loss of Serial Communications for Class 2 Devices
U1030Loss of Serial Communications for Class 2 Devices
U1031Loss of Serial Communications for Class 2 Devices
U1032Loss of Serial Communications for Class 2 Devices
U1033Loss of Serial Communications for Class 2 Devices
U1034Loss of Serial Communications for Class 2 Devices
U1035Loss of Serial Communications for Class 2 Devices
U1036Loss of Serial Communications for Class 2 Devices
U1037Loss of Serial Communications for Class 2 Devices
U1038Loss of Serial Communications for Class 2 Devices
U1039Loss of Serial Communications for Class 2 Devices
U1040Loss of Class 2 Communications with ABS
U1041Loss of EBCM Communication
U1042Lost Communications with Brake/Traction Control System
U1043Loss of Serial Communications for Class 2 Devices
U1044Loss of Serial Communications for Class 2 Devices
U1045Loss of Serial Communications for Class 2 Devices
U1046Loss of Serial Communications for Class 2 Devices
U1047Loss of Serial Communications for Class 2 Devices
U1048Loss of Serial Communications for Class 2 Devices
U1049Loss of Serial Communications for Class 2 Devices
U1050Loss of Serial Communications for Class 2 Devices
U1051Loss of Serial Communications for Class 2 Devices
U1052Loss of Serial Communications for Class 2 Devices
U1053Loss of Serial Communications for Class 2 Devices
U1054Loss of Serial Communications for Class 2 Devices
U1055Loss of Serial Communications for Class 2 Devices
U1056Loss of Communications with RSS
U1057Loss of Serial Communications for Class 2 Devices
U1058Loss of Serial Communications for Class 2 Devices
U1059Loss of Serial Communications for Class 2 Devices
U1060Loss of Serial Communications for Class 2 Devices
U1062Loss of Serial Communications for Class 2 Devices
U1064Loss Of Communications With DIM
U1065Loss of Communications with IPM
U1066Loss of Communications with RIM
U1067Loss of Serial Communications for Class 2 Devices
U1068Loss of Serial Communications for Class 2 Devices
U1069Loss of Serial Communications for Class 2 Devices
U1071Loss of Serial Communications for Class 2 Devices
U1072Loss of Serial Communications for Class 2 Devices
U1073Loss of Serial Communications for Class 2 Devices
U1074Loss of Serial Communications for Class 2 Devices
U1075Loss of Serial Communications for Class 2 Devices
U1076Loss of Serial Communications for Class 2 Devices
U1077Loss of Serial Communications for Class 2 Devices
U1078Loss of Serial Communications for Class 2 Devices
U1079Loss of Serial Communications for Class 2 Devices
U1080Loss of Serial Communications for Class 2 Devices
U1081Loss of Serial Communications for Class 2 Devices
U1082Loss of Serial Communications for Class 2 Devices
U1083Loss of Serial Communications for Class 2 Devices
U1084Loss of Serial Communications for Class 2 Devices
U1085Loss of Serial Communications for Class 2 Devices
U1086Loss of Serial Communications for Class 2 Devices
U1087Loss of Serial Communications for Class 2 Devices
U1088Loss of Communications with SDM
U1089Loss of Serial Communications for Class 2 Devices
U1090Loss of Serial Communications for Class 2 Devices
U1091Loss of Serial Communications for Class 2 Devices
U1092Loss of Serial Communications for Class 2 Devices
U1093Loss of Serial Communications for Class 2 Devices
U1094Loss of Serial Communications for Class 2 Devices
U1095Loss of Serial Communications for Class 2 Devices
U1096Loss of Communications with IPC
U1097Loss of serial communications for class 2 devices
U1098Loss of serial communications for class 2 devices
U1099Loss of serial communications for class 2 devices
U1100Loss of serial communications for class 2 devices
U1101Loss of serial communications for class 2 devices
U1102Loss of serial communications for class 2 devices
U1103Loss of serial communications for class 2 devices
U1104Loss of serial communications for class 2 devices
U1105Loss of serial communications for class 2 devices
U1106Loss of serial communications for class 2 devices
U1107Loss of serial communications for class 2 devices
U1108Loss of serial communications for class 2 devices
U1109Loss of serial communications for class 2 devices
U1110Loss of serial communications for class 2 devices
U1111Loss of serial communications for class 2 devices
U1112Loss of serial communications for class 2 devices
U1113Loss of serial communications for class 2 devices
U1114Loss of serial communications for class 2 devices
U1115Loss of serial communications for class 2 devices
U1116Loss of serial communications for class 2 devices
U1117Loss of serial communications for class 2 devices
U1118Loss of serial communications for class 2 devices
U1119Loss of serial communications for class 2 devices
U1120Loss of serial communications for class 2 devices
U1121Loss of serial communications for class 2 devices
U1122Loss of serial communications for class 2 devices
U1123Loss of serial communications for class 2 devices
U1124Loss of serial communications for class 2 devices
U1125Loss of serial communications for class 2 devices
U1126Loss of serial communications for class 2 devices
U1127Loss of serial communications for class 2 devices
U1128Loss of Communications with IRC
U1129Loss of Communications with AMP
U1130Loss of serial communications for class 2 devices
U1131Loss of serial communications for class 2 devices
U1132Loss of serial communications for class 2 devices
U1133Loss of serial communications for class 2 devices
U1134Loss of serial communications for class 2 devices
U1135Loss of serial communications for class 2 devices
U1136Loss of serial communications for class 2 devices
U1137Loss of serial communications for class 2 devices
U1138Loss of serial communications for class 2 devices
U1139Loss of serial communications for class 2 devices
U1140Loss of serial communications for class 2 devices
U1141Loss of serial communications for class 2 devices
U1142Loss of serial communications for class 2 devices
U1143Loss of serial communications for class 2 devices
U1144Loss of Communications with PHN
U1145Loss Of NAV Communications
U1146Loss Of Onstar Communiction
U1147Loss of serial communications for class 2 devices
U1148Loss of serial communications for class 2 devices
U1149Loss of serial communications for class 2 devices
U1150Loss of serial communications for class 2 devices
U1151Loss of serial communications for class 2 devices
U1152Loss Of ACM Serial Data Communication
U1152Loss of Data HCM
U1153Loss of Communications with CCP
U1154Loss of serial communications for class 2 devices
U1155Loss of serial communications for class 2 devices
U1156Loss of serial communications for class 2 devices
U1157Loss of serial communications for class 2 devices
U1158Loss of serial communications for class 2 devices
U1159Loss of serial communications for class 2 devices
U1160Loss of Communications with DDM
U1161Loss of PDM Serial Data
U1161Loss of PASS Door Module SBI
U1162Loss of Rear Driver Door Module SBI
U1163Loss of Rear PASS Door Module SBI
U1163Loss of RRDM Serial Data
U1164Loss Of DIM Serial Data Communication
U1165Loss of serial communications for class 2 devices
U1166Loss of Communications with SCM
U1167Loss of serial communications for class 2 devices
U1168Loss Of TTM Communications
U1169Loss of Communications with MMM
U1170Loss of Driver Door Switch Asm Serial Data
U1170Loss of Driver Door Switch SBI
U1171Loss of serial communications for class 2 devices
U1172Loss of serial communications for class 2 devices
U1173Loss of serial communications for class 2 devices
U1174Loss of serial communications for class 2 devices
U1175Loss of serial communications for class 2 devices
U1176Loss Of RFA Communications
U1177Loss of serial communications for class 2 devices
U1178Loss of serial communications for class 2 devices
U1179Loss of serial communications for class 2 devices
U1180Loss of serial communications for class 2 devices
U1181Loss of serial communications for class 2 devices
U1182Loss of serial communications for class 2 devices
U1183Loss of serial communications for class 2 devices
U1184Loss of serial communications for class 2 devices
U1185Loss of serial communications for class 2 devices
U1186Loss of serial communications for class 2 devices
U1187Loss of serial communications for class 2 devices
U1188Loss of serial communications for class 2 devices
U1189Loss of serial communications for class 2 devices
U1190Loss of serial communications for class 2 devices
U1191Loss of serial communications for class 2 devices
U1192Loss of VTD Class 2 Serial Data Com
U1193Loss of VIM Class 2 Communication
U1194Loss of serial communications for class 2 devices
U1195Loss of serial communications for class 2 devices
U1196Loss of serial communications for class 2 devices
U1197Loss of serial communications for class 2 devices
U1198Loss of serial communications for class 2 devices
U1199Loss of serial communications for class 2 devices
U1200Loss of serial communications for class 2 devices
U1201Loss of serial communications for class 2 devices
U1202Loss of serial communications for class 2 devices
U1203Loss of serial communications for class 2 devices
U1204Loss of serial communications for class 2 devices
U1205Loss of serial communications for class 2 devices
U1206Loss of serial communications for class 2 devices
U1207Loss of serial communications for class 2 devices
U1208Loss of serial communications for class 2 devices
U1209Loss of serial communications for class 2 devices
U1210Loss of serial communications for class 2 devices
U1211Loss of serial communications for class 2 devices
U1212Loss of serial communications for class 2 devices
U1213Loss of serial communications for class 2 devices
U1214Loss of serial communications for class 2 devices
U1215Loss of serial communications for class 2 devices
U1216Loss of serial communications for class 2 devices
U1217Loss of serial communications for class 2 devices
U1218Loss of serial communications for class 2 devices
U1219Loss of serial communications for class 2 devices
U1220Loss of serial communications for class 2 devices
U1221Loss of serial communications for class 2 devices
U1222Loss of serial communications for class 2 devices
U1223Loss of serial communications for class 2 devices
U1224Loss of serial communications for class 2 devices
U1225Loss of serial communications for class 2 devices
U1226Loss of serial communications for class 2 devices
U1227Loss of serial communications for class 2 devices
U1228Loss of serial communications for class 2 devices
U1229Loss of serial communications for class 2 devices
U1230Loss of serial communications for class 2 devices
U1231Loss of serial communications for class 2 devices
U1232Loss of serial communications for class 2 devices
U1233Loss of serial communications for class 2 devices
U1234Loss of serial communications for class 2 devices
U1235Loss of serial communications for class 2 devices
U1236Loss of serial communications for class 2 devices
U1237Loss of serial communications for class 2 devices
U1238Loss of serial communications for class 2 devices
U1239Loss of serial communications for class 2 devices
U1240Loss of serial communications for class 2 devices
U1241Loss of serial communications for class 2 devices
U1242Loss of serial communications for class 2 devices
U1243Loss of serial communications for class 2 devices
U1244Loss of serial communications for class 2 devices
U1245Loss of serial communications for class 2 devices
U1246Loss of serial communications for class 2 devices
U1247Loss of serial communications for class 2 devices
U1248Loss of serial communications for class 2 devices
U1249Loss of serial communications for class 2 devices
U1250Loss of serial communications for class 2 devices
U1251Loss of serial communications for class 2 devices
U1252Loss of serial communications for class 2 devices
U1253Loss of serial communications for class 2 devices
U1254Loss of serial communications for class 2 devices
U1255Class 2 Communication Malfunction (Serial Data Line Malfunction)
U1300Class 2 Short to Ground
U1301Class 2 Short to Battery
U1304Loss Of UART Communications
U1305Class 2 Data Link Low or High
U1500Inter-Device Dedicated Bus Malfunction
U1713Loss Of Front Door Module to Window Motor High Speed Comm.
U1714Loss Of Front Door Module to Window Motor Normal Speed Comm.
U1715Loss Of Front Door Module to Window Motor High Speed Comm.
U1716Loss Of Front Door Module to Window Motor Normal Speed Comm.
U1800Controller Area Network (CAN) Bus Communication
HONDА
P1020Valve Pause System Stuck Off
P1021Valve Pause System Stuck On
P1025Valve Pause System Sticking Off
P1026Valve Pause System Sticking On
P1077Intake Manifold Runner Control (IMRC) System Malfunction (Low rpm)
P1078Intake Mainfold Runner Control (IMRC) System Malfunction (High rpm)
P1106Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
P1107Barometric Pressure (BARO) Sensor Circuit Low Voltage
P1108Barometric Pressure (BARO) Sensor Circuit High Voltage
P1121Throttle Position (TP) Sensor Lower Than Expected
P1122Throttle Position (TP) Sensor Higher Than Expected
P1128Manifold Absolute Pressure (MAP) Sensor Circuit Lower Than Expected
P1129Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected
P1130Demand for Changing Both Secondary Heated Oxygen Sensor (Secondary HO2S)(Sensor 2) and Third Heated Oxygen Sensor (Third HO2S) (Sensor 3)
P1149 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor 03-020 6 of 10,or Air/Fuel Ratio Sensor (Sensor 1) Circuit Lean Range A/F sensor
P1157Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS Line High Voltage,or Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit High Voltage,or Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
P1158Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low Voltage
P1159Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Terminal Low Voltage
P1162Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response A/F sensor
P1163Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response A/F sensor,or Air/Fuel Ratio Sensor (Sensor 1) Slow Response A/F sensor
P1164Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor,or Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/Performance A/F sensor
P1165Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem A/F sensor,or Air/Fuel Ratio Sensor (Sensor 1) Circuit Range/Performance A/F sensor
P1166Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Electrical Problem A/F sensor heater,or Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit Malfunction (HO2S)
P1167Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Malfunction A/F sensor heater,or Heated Oxygen Sensor Sensor1 (Primary LAF HO2S) Heater System Malfunction A/F sensor heater
P1168Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL Low Voltage
P1169Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL High Voltage
P1182Fuel Temperature Sensor Circuit Low Voltage
P1183Fuel Temperature Sensor Circuit High Voltage
P1253VTEC System Circuit Fault
P1259VTEC System Circuit Fault(Bank 1)
P1297Electric Load Detector (ELD) Circuit Low Voltage
P1298Electric Load Detector (ELD) Circuit High Voltage
P1300Random Misfire Misfire
P1324Knock Sensor Power Source Circuit Low Voltage
P1336Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
P1337Engine Speed (RPM) Fluctuation Sensor No Signal
P1355Front Ignition Coil Power Circuit Malfunction
P1359Crankshaft Position (CKP)/Top Dead Center (TDC) Sensor Circuit Malfunction
P1361Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent Interruption,or Top Dead Center (TDC) Sensor Intermittent Interruption
P1362Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal,or Top Dead Center (TDC) Sensor No Signal
P1366Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent Interruption,or Top Dead Center (TDC) Sensor 2 Intermittent Interruption
P1367Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal,or Top Dear Center (TDC) Sensor 2 No Signal
P1381Cylinder Position (CYP) Sensor Intermittent Interruption
P1382Cylinder Position (CYP) Sensor No Signal
P1410Air Pump Malfunction(Air system)
P1415Air Pump Electric Current Sensor Circuit Low Voltage (Air system)
P1416Air Pump Electric Current Sensor Circuit High Voltage (Air system)
P1420Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter
P1438Motor Drive Module (MDM) Overheating Signal Circuit,or Motor Drive Module (MDM) Overheating
P1439Motor Drive Module (MDM) Short Circuit Sensor Problem,or Motor Drive Module (MDM) Short Circuit
P1440IMA System Problem
P1445Bypass Control Problem
P1448Battery Module Overheating
P1449Battery Module Overheating, or Battery Cell Overheating,or Battery Module Individual Voltage Input Deviation,or Battery Module Deterioration,or Battery Module Deviation
P1454Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
P1456Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System) EVAP
P1457Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System) EVAP
P1459Evaporative Emission (EVAP) Purge Flow Switch Malfunction
P1486Cooling System Malfunction (Thermostat)
P1491Exhaust Gas Recirculation (EGR) Valve Insufficient Lift EGR
P1491Exhaust Gas Recirculation (EGR) Valve Insufficient Lift (EGR)
P1498Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
P1505Positive Crankcase Ventilation (PCV) Air Leakage
P1508Idle Air Control Valve (IACV) Circuit Malfunction
P1509Idle Air Control Valve (IACV) Circuit Failure
P1519Idle Air Control Valve (IACV) Circuit Malfunction
P1522Brake Booster Pressure Sensor Circuit Low Voltage
P1523Brake Booster Pressure Sensor Circuit High Voltage
P1524Brake Booster Pressure Sensor Range/Performance Problem
P1541Climate Control Unit Signal Circuit Low Voltage
P1542Climate Control Unit Signal Circuit High Voltage
P1565Motor Commutation Signal Problem
P1568Battery Module Individual Voltage Input Problem,or Battery Module Temperature Signal Circuit Problem,or Battery Cell Temperature Signal Circuit Problem
P1572Motor Drive Module (MDM) Temperature Signal Circuit Low Input,or Motor Drive Module (MDM) Temperature Signal Circuit High Input
P1576Motor Drive Module (MDM) Voltge Signal Circuit Low Input
P1577High Voltage Detection Signal Circuit Problem
P1580Battery Current Circuit Problem
P1581Motor Power Inverter (MPI) Module Current Signal Circuit Low Input,or Motor Power Inverter (MPI) Module Current Signal Circuit High Input,or Motor Power Inverter (MPI) Module Current Signal Circuit Problem
P1582Motor Current U Phase Signal Circuit Low Input,or Motor Current U Phase Signal Circuit High Input
P1583Motor Current V Phase Signal Circuit Low Input,or Motor Current V Phase Signal Circuit High Input
P1584Motor Current W Phase Signal Circuit Low Input,or Motor Current W Phase Signal Circuit High Input
P1585Motor Current Signal Circuit Problem
P1586Motor Power Inverter (MPI) Module Current Signal/Battery Current Signal Circuit Problem
P1607Engine Control Module (ECM)/Powertrain Control Module (PCM) Internal Circuit Malfunction
P1630Transmission Control Module
P1635Battery Condition Monitor (BCM) Module Proble
P1639MOTB Signal Circuit Malfunction
P1640ACTTRQ Motor Torque Signal Circuit Low Input
P1641ACTTRQ Motor Torque Signal Circuit High Input
P1642QBATT Battery Signal Circuit Low Input
P1643QBATT Battery Signal Circuit High Input
P1644MOTFSA Signal Malfunction
P1645MOTFSB Signal Malfunction
P1646MOTSTB Signal Malfunction
P1647Power Command Signal Circuit Low Input,or Power Command Signal Circuit High Input,or Engine Torque Signal Circuit Low Input,or Engine Torque Signal Circuit High Input,or Mode Signal Circuit 1 Low Input
P1648Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem,or Motor Control Module (MCM) Communication Signal Circuit Problem
P1655CVT-FI TMA/TMB Signal Line Failure
P1656Problem in PCM-toVTM-4 Control Unit Communications Circuit
P1660A/T-FI Data Line Failure/TCM - ECM Halt
P1676FPTDR Signal Line Failure
P1678FPTDR Signal Line Failure
P1679RSCD Signal Circuit Malfunction
P1681A/T FI Signal A Cicuit Low Voltage
P1682A/T FI Signal A Circuit High Voltage
P1683Throttle Valve Default Position Spring Performance Problem
P1684Throttle Valve Return Spring Performance Problem
P1686A/T FI Signal B Circuit Low Voltage
P1687A/T FI Signal B Circuit High Voltage
P1705Short in Transmission Range Switch Circuit (More than one range position is on at the same time)
P1706Open in Transmission Range Switch Circuit
P1709Problem Transmission Gear Selection Switch Circuit DTC Detection Item Associated Monitor
P1730Problem in Shift Control System:Shift Solenoid Valve A and D Stuck OFF ,or Shift Solenoid Valve B Stuck ON,or Shift Valves A, B, and D Stuck
P1731Problem in Shift Control System:Shift Solenoid Valve E Stuck ON,or Shift Valve E Stuck,or A/T Clutch Pressure Control Solenoid Valve A Stuck OFF
P1732Problem in Shift Control System:Shift Solenoid Valve B and C Stuck ON,or Shift Valves B and C Stuck
P1733Problem in Shift Control System:Shift Solenoid Valve D Stuck ON,or Shift Valve D Stuck,or A/T Clutch Pressure Control Solenoid Valve C Stuck OFF
P1734Problem in Shift Control System:Shift Solenoid Valves B and C Stuck ON, or Shift Valves B and C Stuck
P1738Problem in 2nd Clutch Pressure Switch Circuit
P1739Problem in 3rd Clutch Pressure Switch Circuit
P1740Problem in 4th Clutch Pressure Switch Circuit
P1750Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve Assemblies A and B, or Problem in the Hydraulic Control System
P1751Problem in Torque Converter Clutch Solenoid Valve B Circuit
P1751Mechanical Problem in Hydraulic Control System of Shift Solenoid Valve B and A/T Clutch Pressure Control Solenoid Valves A and B, or Problem in the Hydraulic Control System
P1753Problem in Torque Converter Clutch Solenoid Valve Circuit
P1768Problem in Torque Converter Clutch Solenoid Valve B Circuit
P1773Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
P1790Throttle Position (TP) Sensor Circuit Malfunction
P1791Vehicle Speed Sensor (VSS) Range/Performance Problem
P1792Problem in Engine Coolant Temperature (ECT) Sensor Circuit
P1793Manifold Absolute Pressure Sensor Circuit
P1870Problem in CVT Speed Change Control Valve Assembly Circuit
P1873Problem in CVT Pulley Pressure Control Valve Assembly Circuit
P1879Problem in CVT Start Clutch Pressure Control Valve Assembly Circuit
P1882Problem in Inhibitor Solenoid Circuit
P1884Secondary Gear Speed Sensor 2 Circuit Malfunction
P1885CVT Drive Pulley Speed Sensor Circuit
P1886CVT Driven Pulley Speed Sensor Circuit
P1888CVT Speed Sensor
P1889Problem in CVT Speed Sensor 2 Circuit
P1890Shift Control System
P1891Problem in Start Clutch System
P1894CVT Speed Change Control Valve Circuit
P1895CVT Pulley Pressure Control Valve Circuit
JAGH
P1000OBD Systems Readiness Test Not Complete
P1104Mass Air Flow Sensor Circuit Ground
P1111System Pass
P1121Pedal Position Sensor A Circuit Range / Performance
P1122Pedal Position Sensor A Circuit Low input
P1123Pedal Position Sensor A Circuit High Input
P1136Control Box Fan Circuit
P1137Lack Of HO2S12 Switches -Sensor Indicates Lean
P1138Lack Of HO2S12 Switches -Sensor Indicates Rich
P1143Air Assisted Injector Control Valve Range/ Performance
P1144Air Assisted Injector Control Valve Circuit
P1157Lack Of HO2S22 Switches -Sensor Indicates Lean
P1158Lack Of HO2S22 Switches -Sensor Indicates Rich
P1171System Too Lean -Banks 1 and 2 (Lean Fuel Fault)
P1172System Too Rich -Banks 1 and 2 (Rich Fuel Fault)
P1174System Too Lean -Banks 1 and 2 (Suspect HO2S)
P1175System Too Rich -Banks 1 and 2 (Suspect HO2S)
P1176Long Term Fuel Trim Too Lean - Banks 1 and 2 (FMFR)
P1177Long Term Fuel Trim Too Rich - Banks 1 and 2 (FMFR)
P1178Long Term Fuel Trim Too Lean - Banks 1 and 2 (AMFR)
P1179Long Term Fuel Trim Too Rich - Banks 1 and 2 (AMFR)
P118502 Sensor Heater Circuit Open - Hardware Fault
P118602 Sensor Heater Circuit Shorted - Hardware Fault
P118702 Sensor Heater Circuit Open - Inferred Fault
P118802 Sensor Heater Circuit Resistance
P118902 Sensor Heater Circuit Low Resistance Fault 1
P119002 Sensor Heater Circuit Low Resistance Fault 2
P119102 Sensor Heater Circuit Open -Hardware Fault
P119202 Sensor Heater Circuit Shorted
P119302 Sensor Heater Circuit Open - Inferred Fault
P119402 Sensor Heater Circuit Resistance Fault
P119502 Sensor Heater Circuit Low Resistance Fault 1
P119602 Sensor Heater Circuit Low Resistance Fault 2
P1198Fuel Level Input Circuit High
P1199Fuel Level Input Circuit Low
P1201Cylinder # 1 Injector Circuit Open / Shorted
P1202Cylinder # 2 Injector Circuit Open / Shorted
P1203Cylinder # 3 Injector Circuit Open / Shorted
P1204Cylinder # 4 Injector Circuit Open / Shorted
P1205Cylinder # 5 Injector Circuit Open / Shorted
P1206Cylinder # 6 Injector Circuit Open / Shorted
P1207Cylinder # 7 Injector Circuit Open / Shorted
P1208Cylinder # 8 Injector Circuit Open / Shorted
P1221Pedal Demand Sensor B Circuit Range / Performance
P1224Electronic Throttle Control Position Error
P1226Mechanical Guard Circuit Range / Performance
P1227Mechanical Guard Circuit Low Input
P1228Mechanical Guard Circuit High Input
P1229Electronic Throttle Control Circuit
P1230Fuel Pump Relay
P1235VSV 1/2/3 Circuit Range / Performance
P1236VSV 1 Circuit
P1237VSV 2 Circuit
P1238VSV 3 Circuit
P1240Sensor Power Supply
P1241Sensor Power Supply Low Input
P1242Sensor Power Supply High Input
P1243Analog Ground
P1245Crank Signal Low Input
P1246Crank Signal High Input
P1250Throttle Valve Spring
P1251Throttle Position
P1252VSV stuck on VA/VV
P1253VSV Stuck on VR
P1313Misfire Rate Catalyst Damage Fault - Bank 1
P1314Misfire Rate Catalyst Damage Fault - Bank 2
P1315Persistent Misfire
P1316Misfire Rate Exceeds Emissions
P1336Crankshaft / Camshaft Sensor Range / Performance
P1340Camshaft Position Sensor B Circuit
P1341Camshaft Position Sensor B Circuit Range / Performance
P1361Ignition Coil, Cylinder #1, No Activation
P1362Ignition Coil, Cylinder #2, No Activation
P1363Ignition Coil, Cylinder #3, No Activation
P1364Ignition Coil, Cylinder #4, No Activation
P1365Ignition Coil, Cylinder #5, No Activation
P1366Ignition Coil, Cylinder #6, No Activation
P1367Ignition System Failure Group 1
P1368Ignition System Failure Group 2
P1370Insufficient RPM Increase During Spark Test
P1371Ignition Coil - Cylinder 1 - Early Activation Fault
P1372Ignition Coil - Cylinder 2 - Early Activation Fault
P1373Ignition Coil - Cylinder 3 - Early Activation Fault
P1374Ignition Coil - Cylinder 4 - Early Activation Fault
P1375Ignition Coil - Cylinder 5 - Early Activation Fault
P1376Ignition Coil - Cylinder 6 - Early Activation Fault
P1384Variable Valve Timing Solenoid A Circuit
P1392Variable Valve Timing Solenoid A Circuit Low Input
P1393Variable Valve Timing Solenoid A Circuit High Input
P1396Variable Valve Timing Solenoid B Circuit
P1397Variable Valve Timing Solenoid B Circuit Low Input
P1398Variable Valve Timing Solenoid B Circuit High Input
P1400Exhaust Gas Recirculation Valve Position Control
P1401Exhaust Gas Recirculation Valve Position Circuit
P1408Exhaust Gas Recirculation Thermister
P1409Exhaust Gas Recirculation Valve Circuit
P1440Purge Valve Stuck Open
P1441ELC System 1
P1447ELC System Closure Valve Flow
P1448ELC System System 2
P1453Fuel Tank Pressure Relief Valve Malfunction
P1454Evaporative Emission Control System Vacuum Test
P1475Fan Relay (Low) Circuit
P1476Fan Relay (High) Circuit
P1508Idle Air Control Circuit Open
P1509Idle Air Control Circuit Shorted
P1514High Load Neutral / Drive Fault
P1516Gear Change Neutral / Drive Fault
P1517Cranking Neutral / Drive Fault
P1534Restraint Deployment Indicator Circuit
P1565Speed Control Command Switch Out Of Range High
P1566Speed Control Command Switch Out Of Range Low
P1567Speed Control Output Circuit
P1568Speed Control Unable to Hold Speed
P1571Brake Switch
P1600Loss Of KAM Power, Cricuit Open
P1603EEPROM Malfunction
P1606ECM Control Relay Output Circuit
P1607MIL Output Circuit
P1608Watchdog Malfunction
P1609Internal Control Module CPU to CPU Communication Failure
P1611Throttle Target Malfunction 1
P1612Throttle Offset Malfunction
P1637CAN Link ECM/ABS Control Module Circuit / Network
P1638CAN Link ECM / INSTM Circuit / Network
P1641Fuel Pump Primary Circuit
P1642CAN Link Circuit
P1643CAN Link Engine Control Module / Transmission Control Module Circuit / Network
P1646Linear 02 Sensor Control Chip (Bank 1)
P1647Linear 02 Sensor Control Chip (Bank 2)
P1648Knock Sensor Input Chip
P1696CAN Link Engine Control Module /Cruise Control Module Circuit / Network
P1697Cruise Control Distance - Control Input Circuit
P1700Transmission Indeterminate Failure (Failed to Neutral)
P1720Vehicle Speed (Meter ) Circuit
P1722Stall Speed
P1726Engine Overspeed
P1730Gear Control Malfunction 2,3,5
P1731Inconsistent Gear Ratio
P1734Gear Control Malfuntion
P1745Pressure Regulator 1
P1746Pressure Regulator 2
P1747Pressure Regulator 3
P1748Pressure Regulator 5
P1758Pressure Solenoid Control System Incorrect Current
P1775Transmission System MIL Fault
P1776Ignition Retard Request Duration
P1777Ignition Retard Request Circuit
P1778Transmission Reverse I / P Circuit
P1779Load Control
P1789Ignition Supply Malfunction
P1790Ignition Supply Malfunction
P1791Ignition Supply Malfunction
P1792Ignition Supply Malfunction
P1793Ignition Supply Malfunction
P1794Battery Voltage Circuit
P1796CAN Controller Circuit (Bus off)
P1797CAN TCM / ECM Circuit Malfunction
P1798CAN TCM / INST Circuit Malfunction
P1799CAN TCM / ABS Circuit Malfunction
P1882Engine Coolant Level Switch Circuit Short To Ground
KIA
P1102HO2S - 11 heater circuit high voltage
P1105HO2S - 12 heater circuit high voltage
P1115HO2S - 11 heater circuit low voltage
P1117HO2S - 12 heater circuit low voltage
P1123Long term trim adaptive air system low
P1124Long term fuel trim adaptive air system high
P1127Long term fuel trim multiplicative air system low
P1128Long term fuel trim multiplicative air system high
P1140Load calculation cross check
P1170HO2S - 11 circuit voltage stuck at Mid - range
P1195EGR Boost or pressure sensor circuit fault
P1196Ignition switch start circuit fault
P1213Fuel injector 1 circuit high voltage
P1214Fuel injector 2 circuit high voltage
P1215Fuel injector 3 circuit high voltage
P1216Fuel injector 4 circuit high voltage
P1225Fuel injector 1 circuit low voltage
P1226Fuel injector 2 circuit low voltage
P1227Fuel injector 3 circuit low voltage
P1228Fuel injector 4 circuit low voltage
P1250Pressure regulator control solenoid circuit fault
P1345No SGC (CMP) signal to PCM
P1386Knock sensor control zero test
P1401EGR control solenoid circuit signal low
P1402EGR control solenoid circuit signal high
P1402EGR valve position sensor circuit fault
P1410EVAP purge control solenoid circuit high voltage
P1412EGR differential pressure sensor signal low
P1413EGR differential pressure sensor signal high
P1425EVAP purge control solenoid circuit low voltage
P1449Canister drain cut valve solenoid circuit fault
P1455Fuel tank sending unit circuit fault
P1458Air conditioning compressor clutch signal fault
P1485EGR Vent control solenoid circuit fault
P1486EGR vacuum control solenoid circuit fault
P1487EGR boost sensor solenoid circuit fault
P1510Idle air control valve closing coil high voltage
P1513Idle air control valve closing coil low voltage
P1515A / T to M / T codification
P1523VICS solenoid valve circuit fault
P1552Idle air control valve opening coil low voltage
P1553Idle air control valve opening coil high voltage
P1606Chassis accelerator sensor signal circuit fault
P1608PCM internal fault
P1611MIL request circuit low voltage
P1614MIL request circuit high voltage
P1616Chassis accelerator sensor signal low voltage
P1617Chassis accelerator sensor signal high voltage
P1624TCM to PCM MIL request signal circuit fault
P1655Unused power stage 'B'
P1660Power stage group 'B'
P1665Power stage group 'A'
P1743Torque converter clutch solenoid circuit fault
P1794Battery or circuit fault
P1797Clutch pedal switch (MT) -or- P/N switch circuit fault
MAZDA
P1001Activate self test SCP error
P1100Mass Air Flow Sensor Circuit Intermittent
P1101Mass Air Flow Sensor Out Of Self Test Range
P1102Mass Air Flow Sensor In Range But Lower Than Expected
P1103Mass Air Flow Sensor In Range But Higher Than Expected
P1110Intake Air Temperature Circuit (dynamic chamber) Open/Short
P1112Intake Air Temperature Circuit Intermittent
P1113Intake Air Temperature Circuit (dynamic chamber) Open/Short
P1116Engine Coolant Temperature Sensor Out Of Self Test Range
P1117Engine Coolant Temperature Sensor Circuit Intermittent
P1120TP sensor out of range low
P1121Tp sensor signal not consistent with MAF signal
P1122Throttle Position Sensor A In Range But Lower Than Expected
P1123Throttle Position Sensor A In Range But Higher Than Expected
P1124TP sensor signal out of self test range
P1125TP sensor signal intermittent
P1126Throttle Position(Narrow Range)Sensor Circuit
P1127H02S-12 heater not ON during KOER self test
P1128Upstream H02S Sensors Swapped
P1129Downstream H02S Sensors Swapped
P1130H02S-11 not switching (fuel control limit reached)
P1131H02S-11 signal above 0.45v(A/F ratio too lean)
P1132H02S-11 signal below 0.45v(A/F ratio too rich)
P1133Bank 1 Fuel Control Shifted Lean (FAOSC)
P1134Bank 1 Fuel Control Shifted Rich (FAOSC)
P1135H02S11 Heater Circuit Low
P1136H02S11 Hester Circuit High
P1137H02S-11 signal above 0.45v(A/F ratio too rich)
P1138Lack Of HO2S12 Switches - Sensor Indicates Rich
P1141H02S12 Heater Circuit Low
P1142H02S12 Hester Circuit High
P1143Lack Of HO2S Switches,H02S13 Indicates Lean
P1144Lack Of HO2S Switches,H02S13 Indicates Rich
P1150HO2S-21 not switching (fuel control limit reached)
P1151H02S-21 signal below 0.45v (A/F ratio too rich)
P1152H02S-21 signal above 0.45v (A/F ratio too rich)
P1153Bank 2 Fuel Control Shifted Lean (FAOSC)
P1154Bank 2 Fuel Control Shifted Rich (FAOSC)
P1169Feedback A/F Mixture Control (HO2S12)
P1170HO2S-11 circuit too high or low (bank 1 sensor 1)
P1173Feedback A/F Mixture Control (HO2S21)
P1182Fuel Shut Off Solenoid Circuit
P1189Pump Speed Signal
P1190Calibration Resistor Out Of Range
P1191TP (controlled) circuit
P1194ECM/PCM A/D Converter
P1195EGR boost sensor circuit fault
P1197Mileage Switch Circuit
P1213Start Injector Circuit
P1221Traction Control System
P1222Traction Control Output Circuit
P1226Control Sleeve Sensor Circuit
P1235Fuel pump control out range
P1236Fuel pump control out range
P1248Turbo Boost Pressure Not Detected
P1250Fuel Pressure Regulator Control Solenoid
P1251Air Mixture Solenoid Circuit
P1252Pressure regulator control solenoid '2'circuit fault
P1260Anti-theft system signal detected, engine disabled
P1270Engine RPM or vehicle speed limit reached
P1279Control Sleeve Sensor Circuit Range / Performance
P1298Injector Driver Module Failure
P1312Injection Pump Timing Actuator Circuit
P1318Injection Timing Piston Position Sensor Circuit
P1319Injection Timing Piston Position Sensor Circuit Range / Performance
P1345CMP or SGC sensor circuit fault
P1351IDM signal lost to PCM or out of range
P1352Ignition coil 'A' primary circuit fault
P1353Ignition coil 'B' primary circuit fault
P1354Ignition coil 'C' primary circuit fault
P1358IDM signal out of self test range
P1359SPOUT signal lost to PCM or out of range
P1360Ignition coil 'A' secondary circuit fault
P1361Ignition coil 'B' secondary circuit fault
P1362Ignition coil 'C' secondary circuit fault
P1364Ignition coil primary circuit fault
P1365Ignition coil secondary circuit fault
P1382Camshaft Position Timing Solenoid #1 Circuit
P1387Camshaft Position Timing Solenoid #2 Circuit
P1390Octane adjust shorting bar out or circuit open
P1400DPFE sensor signal below self test minimum
P1401DPFE sensor signal above self test maximum
P1405DPFE sensor upstream hose off or plugged
P1406DPFE sensor downstream hose off or plugged
P1407No EGR flow detected
P1408EGR system flow out of KOER self test range
P1409EGR vacuum regulator solenoid circuit fault
P1412Exhaust Gas Recirculation Valve Frozen
P1415Air Pump Circuit
P1416Port Air Circuit
P1417Port Air Relief Circuit
P1418Split Air #1 Circuit
P1419Split Air #2 Circuit
P1439Floor Temp Switch Circuit
P1443EVAP system purge flow fault
P1444EVAP purge flow sensor circuit low voltage
P1445EVAP purge flow sensor circuit high voltage
P1446Evaporative Vacuum Solenoid Circuit
P1449Evaporative Check Solenoid Circuit
P1450Unable to Bleed Up Fuel Tank Vacuum
P1451Evaporative Emission Control System Vent Control Circuit
P1455Fuel tank level sensor circuit fault
P1456Fuel Tank Temperature Sensor Circuit
P1457Purge Solenoid Control System
P1460Wide open throttle A/C cut-off relay circiut fault
P1464Air conditioning control signal circuit fault
P1465A/C Relay Circuit
P1473Fan Circuit Open (VLCM)
P1474Fan control system fault
P1477Additional Fan Relay Circuit
P1479High Fan Control Primary Circuit
P1480Fan Secondary Low With Low Fan On
P1481Fan Secondary Low With High Fan On
P1485EGR vacuum solenoid circuit fault
P1486EGR vent solenoid circuit fault
P1487Exhaust Gas Recirculation Check Solenoid Circuit
P1490Secondary Air Relief Solenoid Circuit
P1491Secondary Switch Solenoid Circuit
P1492APLSOL Solenoid Circuit
P1493RCNT Solenoid Circuit
P1494SPCUT Solenoid Circuit
P1495TCSPL Solenoid Circuit
P1496EGR Stepper Motor 1 Control Circuit Low/High
P1497EGR Stepper Motor 2 Control Circuit Low/High
P1498EGR Stepper Motor 3 Control Circuit Low/High
P1499EGR Stepper Motor 4 Control Circuit Low/High
P1500Vehicle speed sensor intermittent signals
P1501Vehicle speed sensor out of self test range
P1504Idle air control solenoid circuit intermittent fault
P1505Idle air control system at adaptive clip
P1506IAC system overspeed detected during self test
P1507IAC system underspeed detected during self test
P1508Bypass air solenoid '1' circuit fault
P1509Bypass air solenoid '2' circuit fault
P1510Idle Signal Circuit
P1511Idle Switch (Electric Control Throttle) Circuit
P1512Intake Manifold Runner Control Stuck Closed (Bank 1)
P1515Electric Current Circuit
P1521Variable Resonance Induction System Solenoid #1 Circuit
P1522Variable Resonance Induction System Solenoid #2 Circuit
P1523VICS solenoid circuit fault
P1524Variable Intake Solenoid Circuit
P1525ABV vacuum solenoid circuit fault
P1526ABV vent solenoid circuit fault
P1527Bypass Air Solenoid (Accelerate Warmup) Circuit
P1528Subsidiary Throttle Valve Solenoid Circuit
P1529L/C atmospheric balance air control valve fault
P1540Air Bypass Valve Circuit
P1562PCM B+ Voltage Low (KAM power)
P1566TCM B+ Voltage Low
P1569Intake Manifold Runner Control Control Circuit Low
P1570Intake Manifold Runner Control Control Circuit High
P1600Loss Of KAM Power, Circuit Open
P1601ECM / TCM Serial Communication Error
P1602Immobilizer / ECM Communication Error
P1603ID Number Unregistered
P1604Code Word Unregistered
P1605PCM keep active memory test error
P1608PCM Internal Circuit
P1609PCM (ECM CPU) knock sensor fault
P1621Immobilizer Code Words Do Not Match
P1622Immobilizer ID Does Not Match
P1623Immobilizer Code Word / ID Number Write Failure
P1624Anti-theft System
P1627PCM (ECM / TCS) line communication error
P1628PCM (ECM / TCS) ABV line communication error
P1630Alternator Regulator #1 Control Circuit
P1631Alternator Regulator #2 Control Circuit
P1633Generator Control System - over charge
P1634Generator Control System - no charge
P1645Fuel Pump Resistor Switch Circuit
P1649Fuel Injection Pump Module
P1650Power steering pressure switch out of range fault
P1651Power steering pressure switch circuit fault
P1652Idle Air Control Monitor Disabled By PSPS Failed On
P1680Metering Oil Pump Failure
P1681Metering Oil Pump Failure
P1682Metering Oil Pump Failure
P1683Metering Oil Pump Temperature Sensor Circuit
P1684Metering Oil Pump Position Sensor Circuit
P1685Metering Oil Pump Stepping Motor Cont.Circuit
P1686Metering Oil Pump Stepping Motor Cont.Circuit
P1687Metering Oil Pump Stepping Motor Cont.Circuit
P1688Metering Oil Pump Stepping Motor Cont.Circuit
P1689Oil Pressure Control Solenoid Circuit
P1690Wastegate Solenoid Circuit
P1691Turbo Pressure Control Solenoid Circuit
P1692Turbo Control Solenoid Circuit
P1693Turbo Charge Control Circuit
P1694Turbo Charge Relief Circuit
P1701A / T TR sensor reverse engagement error
P1703Brake on / off switch out of self test range
P1705Transmission Range Circuit Not Indicating Park / Neutral During Self Test
P1706HighVehicle Speed Observed in Park
P1708Clutch Switch Circuit
P1709Clutch Pedal (or Park / Neutral Position) Switch Out Of Self Test Range
P1710Transmission Control Module Solenoid / Internal Ground Circuit
P1711A/T TFT sensor out of self test range
P1713Transmission Fluid Temperature Sensor In Range Failure
P1719Engine Torque Signal
P1720Vehicle speed sensor '2' signal error
P1721Gear 1 Incorrect Ratio
P1722Gear 2 Incorrect Ratio
P1723Gear 3 Incorrect Ratio
P1724Gear 4 Incorrect Ratio
P1729Transmission 4ЎБ4 low switch error during self test
P1735First Gear Switch Circuit Failure
P1736Second Gear Switch Circuit Failure
P1737Lockup Solenoid
P1738Shift Time Error
P1739Slip Solenoid
P1741Torque converter clutch control error
P1742Torque converter clutch failed on, MIL is on
P1743Torque converter clutch failed on, TCIL is on
P1744Torque converter clutch Solenoid Circuit
P1745Line Pressure Solenoid
P1746Electronic pressure control solenoid circuit open
P1747Electronic pressure control solenoid circuit short
P1748Pressure Control Solenoid A
P1749Electronic pressure control solenoid circuit low
P1751Shift Solenoid A Circuit Open
P1752Shift Solenoid A Circuit Short
P1754Transmission coast clutch solenoid electrical fault
P1756Shift Solenoid B Circuit Open
P1757Shift Solenoid B Circuit Short
P17592-4 Brake Failsafe Valve Malfunction
P1761Transmission shift solenoid '3' performance
P1763Low and Reverse Brake Pressure Switch Circuit
P1764Low and Reverse Brake Failsafe Valve Malfunction
P1765Timing Solenoid Circuit
P1770Clutch Solenoid Circuit
P1771Throttle Position Sensor Circuit High Input
P1772Throttle Position Sensor Circuit Low Input
P1775Torque Down Signal #1 Circuit
P1776Torque Down Signal #2 Circuit
P1777Torque Down Response Signal Circuit
P1780Transmission control switch electrical fault
P1781Transmission 4ЎБ4 low switch out of range fault
P1783Transmission fluid temperature too high
P1788Pressure Control Solenoid B Open Circuit
P1789Pressure Control Solenoid B Short Circuit
P1790TP (Mechanical ) Circuit
P1791TP (Electric) Circuit
P1792Barometer Pressure Circuit
P1793Intake Air Volume Circuit
P1795Idle Switch Circuit
P1796Kick Down Switch Circuit
P1797Clutch Pedal (or Park / Neutral ) Position Switch Circuit
P1798Coolant Temperature Circuit
P1799Hold Switch Circuit
MERCEDES (diesel)
P1105Atmospheric pressure sensor in control module
P1220Fuel quantity actuator (Y23/1)
P1221CAN communication, ETC or ETS interrupted
P1222IFI accelerator pedal position sensor (R25/2)
P1223Fuel rack position sensor (Y23/1/1)
P1335CKP sensor (IFI)
P1350Injection sensor solenoid
P1351Injection sensor circuit
P1352Needle Lift Sensor
P1401EGR lifting sender (B28/3)
P1404EGR control
P1465EPW power
P1470Pressure control flap vacuum transducer (Y31/2)
P1475Resonance intake line switchover valve (Y22/7)
P1476Resonance intake manifold switchover valve (Y22/6)
P1480Preglow control
P1481Glow plug failure
P1482Preglow control module (N14/2)
P1520Cruise control switch (S40)
P1610Voltage supply missing -or- relay module (K40)
P1611IFI Control module (N3/7)
P1612IFI Control module (N3/7) voltage, circuit 15
P1613IFI Control module (N3/7)
P1614IFI Control module (N3/7) voltage -or-Fuel metering actuator(Y23/1k1) -or-Fuel rack position sensor(Y23/1/1)
P1615IFI Control module (N3/7) supply voltage
P1617Control module fault -or- Control module not coded
P1622Electrohydraulic shut-off actutor (Y1/1)
P1625Check Engine MIL
P1630Drive authorization signal
P1705Starter lock-out/backup lamp switch(S16/1)
P1780Modulating pressure switchover valve(AT/CC)(Y3/4) -or-Upshift delay switchover valve(AT/CC)(Y3/5)
P1781Upshift delay switchover valve (AT/CC)(Y3/5)
MERCEDES benzin
P1146Left hot film MGF sensor (B2/6)
P1147Left ECT sensor (B11/9)
P1148Left IAT sensor (B17/5)
P1149Left Manifold pressure sensor (B28/1)
P1162Left EA/CC/ISC actuator actual value potentiometer (M16/4r1,M16/4r2)
P1163Oil level switch (S43)
P1176Oil pressure sensor
P1177Oil sensor, level-temperature implausible
P1179Oil quality implausible
P1180High oil temperature
P1181Engine electric cooling fan, faulty
P1182Start relay output stage, faulty
P1183Output stage cylinder fadeout, valve1
P1184Output stage cylinder fadeout valve2
P1185Water in oil
P1186Satety fuel shutoff detected
P1225Variable intake manifold switchover valve (Y22/6)
P1233Throttle valve jamming
P1300Left CKP sensor (L5/4)
P1355Cylinder shut-off valve, right bank (Y80) does not close at cylinder cutoff
P1356Cylinder shut-off valve, left bank(Y81) does not close at cylinder cutoff
P1357Cylinder cutoff,inlet valve of a cylinder continuous to be operated at cylinder cutoff
P1358Cylinder 5 exhaust valve is not operating at cylinder cutoff
P1359Cylinder 2 exhaust valve is not operating at cylinder cutoff
P1360Cylinder 3 exhaust valve is not operating at cylinder cutoff
P1361Cylinder 8 exhaust valve is not operating at cylinder cutoff
P1366Exhaust flap switchover valve (Y93)
P1380Inlet valve of a cylinder is not operated at cylinder cutoff
P1384Left knock sensor 1 (A29g1)
P1385Left knock sensor 2 (A29g2)
P1386Knock sensor regulation from right ECM (N3/12) hardware failure
P1397Left camshaft Hall-effect sensor (B6/2)
P1400EGR switchover valve output stage (Y31-1)
P1420AIR pump switchover valve (Y32)
P1437Exhaust gas temperature sensor 1
P1443Purge valve
P1444Exhaust gas temperature sensor 2
P1453AIR relay module (K17)
P1463Left AIR system malfunction
P1490Left purge control valve (Y58/2)
P1491A/C refrigerant pressure too high
P1519Right adjustable camshaft timing solenoid (Y49/2)(logic chain)
P1522Left adjustable camshaft timing solenoid (Y49/1)(logic chain)
P1525Right adjustable camshaft timing solenoid (Y49/2)
P1533Left adjustable camshaft timing solenoid (Y49/1)
P1542Pedal value sensor (B37)
P1550AC compressor torque implausible
P1570Start enable of DAS not sent
P1580Throttle valve actuator (M16/6)
P1581Left EA/CC/ISC actuator M16/4)
P1584Stop lamp switch (S9/1)
P1587Left ECM (N3/11) voltage supply
P1588CAN signal from RCL control module (N54) to left ECM (N3/11) interrupted
P1589Knock sensor regulation from left ECM (N3/11) hardware failure
P1603No or incorrect CAN message from control unit EIS
P1605Rough road detected by signal from comparing wheel speeds
P1632Left engine control module (N3/11)
P1642ECU incorrectly coded
P1643ECU incorrectly coded -or- CAN from transmission
P1644Transmission version can't be checked due to low voltage at transmission ECU
P1681Crash Sensor, signal implausible or frontal crash or short to power
P1747CAN signal from ETC (N15/3) interrupted
MITSUBISHI
P1100Induction control motor position sensor fault
P1101Traction control vacuum solenoid circuit fault
P1102Traction control ventilation solenoid circuit fault
P1103Turbocharger waste gate actuator circuit fault
P1104Turbocharger waster Gate solenoid circuit fault
P1105Fuel pressure solenoid circuit fault
P1294Target Idle speed not reached
P1295No 5-volt supply to TP sensor
P1296No 5-volt supply to MAP sensor
P1297No charge in MAP from start to run
P1300Ignition timing adjustment circuit fault
P1390Timing belt skipped one tooth or more
P1391Intermittent loss of CMP or CKP sensor signals
P1400Manifold differential pressure sensor fault
P1443EVAP purge control solenoid '2' circuit fault
P1486EVAP leak monitor pinched hose detected
P1487High speed radiator fan control relay circuit fault
P1489High speed condenser fan control relay fault
P1490Low speed fan control relay fault
P1492Battery temperature sensor high voltage
P1494EVAP ventilation switch or mechanical fault
P1495EVAP ventilation solenoid circuit fault
P14965 Volt supply output too low
P1500Generator FR terminal circuit fault
P1600PCM / TCM serial communication link circuit fault
P1696PCM failure- EEPROM write denied
P1698NO CCD messages from TCM
P1715TCM pulse generator circuit fault
P1750Pressure control,shift control,TCC solenoid fault
P1791PCM ECT level signal to TCM circuit fault
P1899P / N position / transaxle range switch circuit fault
NISSAN
P1031Air/Fuel Ratio Sensor Meter
P1032Air/Fuel Ratio Sensor Meter
P1065ECM Power Supply Heater
P1102Mass Air Flow Sensor Function Heater
P1103MAP Sensor Heater
P1104MAP Sensor Heater
P1105MAP/BARO Switch SOL/V
P1108MAP Sensor Heater
P1110Intake Valve Timing Control, LH Bank
P1111Intake Valve Timing Control Solenoid Valve
P1119Radiator Temperature Sensor Circuit
P1120TP Sensor 2
P1121Electronic Throttle Control Actuator
P1122Electronic Throttle Control Actuator
P1124Throttle Control Motor Relay
P1125Tandem TP Sensor
P1126Throttle Control Motor Relay
P1128Throttle Control Motor
P1130Swirl Control Valve Control Solenoid Valve
P1131Swirl Control Solenoid Valve
P1132Swirl Control Valve
P1135Intake Valve Timing Control, RH Bank 2
P1136Intake Valve Timing Control Solenoid Valve
P1137Swirl Control Valve Position Sensor
P1138Swirl Control Valve
P1140Intake Valve Timing Control Position Sensor, LH Bank 1
P1143Heated O2 Sensor 1
P1144Heated O2 Sensor 1
P1145Intake Valve Timing Control Position Sensor, RH Bank 2
P1146Heated O2 Sensor 2
P1147Heated O2 Sensor 2
P1148Closed Loop, Bank 1
P1163Heated O2 Sensor 1
P1164Heated O2 Sensor 1
P1165Swirl Control Valve Control Vacuum Check Switch
P1166Heated O2 Sensor 2
P1167Heated O2 Sensor 2
P1168Closed Loop, Bank 2
P1169Heated O2 Sensor 3
P1170Heated O2 Sensor 3
P1210Traction Control Signal Circuit
P1211ABS/TCS Control Unit
P1212ABS/TCS Communication Line
P1217Engine Coolant Temperature
P1220FPCM
P1221Throttle Actuator Circuit
P1222Temperature Sensor Circuit
P1223Throttle Position Sensor 2
P1224Throttle Position Sensor 2
P1225Closed Throttle Position Learning
P1226Closed Throttle Position Learning
P1227Accelerator Pedal Position Sensor 2
P1228Accelerator Pedal Position Sensor 2
P1229Sensor Power Supply
P1271Air/Fuel Ratio Sensor 1
P1272Air/Fuel Ratio Sensor 1
P1273Air/Fuel Ratio Sensor 1
P1274Air/Fuel Ratio Sensor 1
P1276Air/Fuel Ratio Sensor 1
P1278Air/Fuel Ratio Sensor 1
P1279Air/Fuel Ratio Sensor 1
P1320Ignition Signal, Primary
P1335CKP Sensor (Ref)
P1336CKP Sensor (POS) Cog
P1400EGRC Solenoid/V
P1401EGR Temp Sensor
P1402EGR System
P1440EVAP Small Leak
P1441VC/V Bypass/V
P1443Canister Control Vacuum Check Switch
P1444Purge Volume Control/V
P1445Purge Volume Control/V
P1446Vent Control Valve
P1447EVAP Purge Flow
P1448Vent Control Valve
P1456EVAP Control System
P1464Fuel Level Sensor Circuit Ground Signal
P1480Fan Control Solenoid Valve Circuit
P1490VC/V Bypass/V
P1491VC Cut/V Bypass/V
P1492Purge Control/V S/V
P1493Purge Control/V & S/V
P1564ASCD Steering Switch
P1568ICC (Intelligent Cruise Control)
P1572ASCD (Automatic Sped Control Device) Brake Switch
P1574ASCD Vehicle Speed Sensor
P1605A/T Diag Comm Line
P1610NATS Malfunction
P1611NATS Malfunction
P1612NATS Malfunction
P1613NATS Malfunction
P1614NATS Malfunction
P1615NATS Malfunction
P1705TP Sensor A/T
P1706PNP Switch
P1720Vehicle Speed Sensor- A/T Output
P1760Overrun Clutch S/V
P1775Torque Converter Clutch Solenoid Valve
P1776Torque Converter Clutch Solenoid Valve
P1780Shift Change Signal
P1800VIAS Control Solenoid Valve
P1805Brake switch
P1900Cooling Fan
SUBARU
P1086Tumble generator valve #2 (LH) position sensor circuit low input
P1087Tumble generator valve #2 (LH) position sensor circuit high input
P1088Tumble generator valve #1 (RH) position sensor circuit low input
P1089Tumble generator valve #1 (RH) position sensor circuit high input
P1090Tumble generator valve #1 (RH) malfunction (stuck open)
P1091Tumble generator valve #1 (RH) malfunction (stuck close)
P1092Tumble generator valve #2 (LH) malfunction (stuck open)
P1093Tumble generator valve #2 (LH) malfunction (stuck close)
P1094Tumble generator valve circuit #1 (open circuit)
P1095Tumble generator valve circuit #1 (over current)
P1096Tumble generator valve circuit #2 (open circuit)
P1097Tumble generator valve circuit #2 (over current)
P1100Starter Switch Circuit Malfunction
P1101Neutral Position Switch Circuit High Input (A/T), or Neutral Position Switch Circuit Malfunction (M/T)
P1102Pressure Sources Solenoid Valve Circuit Malfunction
P1103Pressure Sources Switching Solenoid Valve Circuit
P1104Engine Torque Control Signal Circuit Malfunction
P1106Engine Torque Control Signal 2 Circuit Malfunction
P1110Atmospheric pressure sensor low input
P1111Atmospheric pressure sensor high input
P1112Atmospheric pressure sensor range/performance problem
P1115Engine Torque Control Cut Signal Circuit High Input
P1116Engine Torque Control Cut Signal Circuit Low Input
P1120Starter Switch High Input
P1121Neutral Position Switch Circuit High Input [MT Vehicles], or Neutral Position Switch Circuit Low Input [AT Vehicles]
P1122Pressure Sources Switching Valve Circuit High Input
P1124TCS Signal Circuit High Input
P1130Front oxygen sensor circuit malfunction (open circuit)
P1131Front oxygen sensor circuit malfunction (short circuit)
P1134Front oxygen (A/F) sensor microcomputer problem
P1137Front oxygen (A/F) sensor circuit range/performance problem
P1139Front oxygen (A/F) sensor #1 heater circuit performance/range problem
P1141Mass Air Flow Sensor Circuit High Input
P1142Mass Air Flow Sensor Circuit Low Input
P1143Pressure Sensor Circuit Low Input
P1144Pressure Sensor Circuit High Input
P1146Pressure sensor circuit range/performance problem (high input)
P1150Front Oxygen Sensor Heater Circuit High Input
P1151Rear Oxygen Sensor Heater Circuit High Input
P1230Fuel pump control unit malfunction
P1244Wastegate control solenoid valve malfunction (low input)
P1245Wastegate control solenoid valve malfunction (fail-safe)
P1301Fire due to increased exhaust temperature
P1312Exhaust temperature sensor malfunction
P1325Knock Sensor Circuit Low Input
P1400Fuel Tank Pressure Control Solenoid Low Input
P1420Fuel Tank Pressure Control Solenoid High Input
P1421Exhaust Gas Recirculation Circuit High Input
P1422EVAP Purge Control Valve Circuit High Input
P1423EVAP Vent Control High Input
P1440Fuel Tank Pressure Control System Low Input
P1441Fuel Tank Pressure Control System High Input
P1442Fuel Level Sensor Circuit Range/Perf
P1443EVAP Control System Vent Control Function Problem
P1480Cooling fan relay 1 circuit high input
P1500Radiator Fan Relay 1 Circuit Malfunction
P1501Idle Control System Malfunction (Fail Safe)
P1502Radiator Fan Function Problem
P1507Idle Control System Malfunction (Fail Safe)
P1510Idle Air Control Solenoid Signal 1 Circuit Low Input
P1511Idle Air Control Solenoid Signal 1 Circuit High Input
P1512Idle Air Control Solenoid Signal 2 Circuit Low Input
P1513Idle Air Control Solenoid Signal 2 Circuit High Input
P1514Idle Air Control Solenoid Signal 3 Circuit Low Input
P1515Idle Air Control Solenoid Signal 3 Circuit High Input
P1516Idle Air Control Solenoid Signal 4 Circuit Low Input
P1517Idle Air Control Solenoid Signal 4 Circuit High Input
P1518Starter switch circuit low input
P1520Radiator Fan Relay 1 Circuit High Input
P1540Vehicle Speed Sensor Malfunction 2
P1544High exhaust temperature detected
P1560Back-Up Voltage Circuit Malfunction
P1590Neutral position switch circuit high input
P1591Neutral position switch circuit low input
P1592Neutral position switch circuit (MT model)
P1594Automatic transmission diagnosis input signal circuit malfunction
P1595Automatic transmission diagnosis input signal circuit low input
P1596Automatic transmission diagnosis input signal circuit high input
P1698Engine torque control cut signal circuit low input
P1699Engine torque control cut signal circuit high input
P1700Throttle Position Sensor Circuit Malfunction (A/T)
P1701Cruise Control Set Signal Circuit Malfunction (A/T)
P1702Auto Trans Diagnosis Input Signal Circuit
P1703Low clutch timing control solenoid valve circuit malfunction
P17042-4 Brake Timing Solenoid Valve Circuit Malfunction
P17052-4 Brake Pressure Solenoid Valve (Solenoid D) Circuit
P1711Engine torque control signal 1 circuit malfunction
P1712Engine torque control signal 2 circuit malfunction
P1722Auto Trans Diagnosis Input Signal High Input
P1742Auto Trans Diagnosis Input Signal Malfunction
SUZUKI
P1250EFE heater circuit fault
P1408Manifold differential pressure sensor circuit fault
P1410Fuel tank pressure control solenoid circuit fault
P1450Barometric pressure sensor too low or too high
P1451Barometric pressure sensor performance
P1460Radiator fan control system fault
P1500Engine starter signal circuit fault
P1510PCM backup power supply circuit fault
P1530Ignition timing adjustment switch circuit fault
P1600PCM / TCM serial communication circuit fault
P1700TCM throttle position sensor circuit fault
P1705TCM ECT sensor circuit fault
P1710Back-Up Signal For Speed Sensor Circuit Malfunction
P1715PNP switch circuit fault
P1717AT Drive range signal circuit fault
P18754WD Low Switch Circuit Malfunction
P1895TCM To ECM Torque Reduction Circuit Malfunction
TOYOTA
P1100BARO Sensor Circuit malfunction
P1120Accelerator Pedal Position Sensor Circuit Malfunction
P1121Accelerator Pedal Position Sensor Range/Performance Problem
P1125Throttle Control Motor Circuit Malfunction
P1126Magnetic Clutch Circuit Malfunction
P1127ETCS Actuator Power Source Circuit Malfunction
P1128Throttle Control Motor Lock Malfunction
P1129Electric Throttle Control System Malfunction
P1130AirЁCFuel Sensor Circuit Range/Performance
P1133AirЁCFuel Sensor Circuit Response Malfunction
P1135AirЁCFuel Sensor Heater Circuit Response Malfunction
P1150A./F Sensor Circuit Range/Performance Malfunction
P1153A./F Sensor Circuit Response Malfunction
P1155A./F Sensor Heater Circuit Malfunction
P1200Fuel Pump Relay Circuit Malfunction
P1300Igniter Circuit Malfunction No. 1
P1305Igniter Circuit Malfunction No. 2 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
P1310Igniter Circuit Malfunction No. 2 (Except 1998-2000 Land Cruiser, 2000 Celica & Tundra), or Igniter Circuit Malfunction No. 3 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
P1315Igniter Circuit Malfunction No. 4 (1998-2000 Land Cruiser, 2000 Celica & Tundra)
P1320Igniter Circuit Malfunction No. 5 (1998-2000 Land Cruiser & 2000 Tundra)
P1325Igniter Circuit Malfunction No. 6 (1998-2000 Land Cruiser & 2000 Tundra)
P1330Igniter Circuit Malfunction No. 7 (1998-2000 Land Cruiser & 2000 Tundra)
P1335No CKP Sensor Signal Engine Running
P1340Igniter Circuit Malfunction No. 8 (1998-2000 Land Cruiser & 2000 Tundra)
P1345VVT Sensor/Camshaft Position Sensor Circuit Malfunction Bank 1
P1346VVT Sensor/Camshaft Position Sensor Circuit Range/Performance Problem (Bank 1)
P1349VVT System Malfunction Bank 1
P1350VVT Sensor/Camshaft Position Sensor Circuit Malfunction Bank 2
P1351VVT Sensor/Camshaft Position Sensor Circuit Range/Performance Problem Bank 2
P1354VVT System Malfunction Bank 2
P1400Sub-Throttle Position Sensor Malfunction
P1401Sub-Throttle Position Sensor Range/Performance Problem
P1405Turbo Pressure Sensor Circuit Malfunction
P1406Turbo Pressure Sensor Range/Performance Problem
P1410EGR Valve Position Sensor Circuit Malfunction
P1411EGR Valve Position Sensor Circuit Range/Performance
P1500Starter Signal Circuit Malfunction
P1510Boost Pressure Control Circuit Malfunction
P1511Boost Pressure Low Malfunction
P1512Boost Pressure High Malfunction
P1520Stop Lamp Switch Signal Malfunction
P1565Cruise Control Main Switch Circuit Malfunction
P1600ECM BATT Malfunction
P1605Knock Control CPU Malfunction
P1630Traction Control System Malfunction
P1633ECM Malfunction ECTS Circuit
P1645Body ECU Malfunction
P1652IACV Control Circuit Malfunction
P1656OCV Circuit Malfunction Bank 1
P1658Waste Gate Valve Control Circuit Malfunction
P1661EGR Circuit Malfunction
P1662EGR By-Pass Valve Control Circuit Malfunction
P1663OCV Circuit Malfunction Bank 2
P1690OCV Circuit Malfunction
P1692OCV Open Malfunction
P1693OCV Closed Malfunction
P1780PNP Switch Malfunction
VW_NEW
P1101O2 Sensor Circ., Bank1-Sensor1 Voltage too Low/Air Leak
P1102O2 Sensor Heating Circ., Bank1-Sensor1 Short to B+
P1103O2 Sensor Heating Circ., Bank1-Sensor1 Output too Low
P1104Bank1-Sensor2 Voltage too Low/Air Leak
P1105O2 Sensor Heating Circ., Bank1-Sensor2 Short to B+
P1106O2 Sensor Circ., Bank2-Sensor1 Voltage too Low/Air Leak
P1107O2 Sensor Heating Circ., Bank2-Sensor1 Short to B+
P1108O2 Sensor Heating Circ., Bank2-Sensor1 Output too Low
P1109O2 Sensor Circ., Bank2-Sensor2 Voltage too Low/Air Leak
P1110O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+
P1111O2 Control (Bank 1) System too lean
P1112O2 Control (Bank 1) System too rich
P1113Bank1-Sensor1 Internal Resistance too High
P1114Bank1-Sensor2 Internal Resistant too High
P1115O2 Sensor Heater Circ., Bank1-Sensor1 Short to Ground
P1116O2 Sensor Heater Circ., Bank1-Sensor1 Open
P1117O2 Sensor Heater Circ., Bank1-Sensor2 Short to Ground
P1118O2 Sensor Heater Circ., Bank1-Sensor2 Open
P1119O2 Sensor Heater Circ., Bank2-Sensor1 Short to Ground
P1120O2 Sensor Heater Circ., Bank2-Sensor1 Open
P1121O2 Sensor Heater Circ., Bank2-Sensor2 Short to Ground
P1122O2 Sensor Heater Circ., Bank2-Sensor2 Open
P1123Long Term Fuel Trim Add.Air., Bank1 System too Rich
P1124Long Term Fuel Trim Add.Air., Bank1 System too Lean
P1125Long Term Fuel Trim Add.Air., Bank2 System too Rich
P1126Long Term Fuel Trim Add.Air., Bank2 System too Lean
P1127Long Term Fuel Trim mult., Bank1 System too Rich
P1128Long Term Fuel Trim mult., Bank1 System too Lean
P1129Long Term Fuel Trim mult., Bank2 System too Rich
P1130Long Term Fuel Trim mult., Bank2 System too Lean
P1131Bank2-Sensor1 Internal Rsistance too High
P1132O2 Sensor Heating Circ., Bank1+2-Sensor1 Short to B+
P1133O2 Sensor Heating Circ., Bank1+2-Sensor1 Electrical Malfunction
P1134O2 Sensor Heating Circ., Bank1+2-Sensor2 Short to B+
P1135O2 Sensor Heating Circ., Bank1+2-Sensor2 Electrical Malfunction
P1136Long Term Fuel Trim Add.Fuel, Bank1 System too Lean
P1137Long Term Fuel Trim Add.Fuel, Bank1 System too Rich
P1138Long Term Fuel Trim Add.Fuel, Bank2 System too Lean
P1139Long Term Fuel Trim Add.Fuel, Bank2 System too Rich
P1140Bank2-Sensor2 Internal Resistance too High
P1141Load Calculation Cross Check Range/Performance
P1142Load Calculation Cross Check Lower Limit Exceeded
P1143Load Calculation Cross Check Upper Limit Exceeded
P1144Mass or Volume Air Flow Circ Open/Short to Ground
P1145Mass or Volume Air Flow Circ Short to B+
P1146Mass or Volume Air Flow Circ Supply Malfunction
P1147O2 Control (Bank 2) System too lean
P1148O2 Control (Bank 2) System too rich
P1149O2 Control (Bank 1) Out of range
P1150O2 Control (Bank 2) Out of range
P1151Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
P1152Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded
P1154Manifold Switch Over Malfunction
P1155Manifold Abs.Pressure Sensor Circ. Short to B+
P1156Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
P1157Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
P1158Manifold Abs.Pressure Sensor Circ. Range/Performance
P1160Manifold Temp.Sensor Circ. Short to Ground
P1161Manifold Temp.Sensor Circ. Open/Short to B+
P1162Fuel Temp.Sensor Circ. Short to Ground
P1163Fuel Temp.Sensor Circ. Open/Short to B+
P1164Fuel Temperature Sensor Range/ Performance/ Incorrect Signal
P1165Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
P1166Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
P1171Throttle Actuation Potentiometer Sign.2 Range/Performance
P1172Throttle Actuation Potentiometer Sign.2 Signal too Low
P1173Throttle Actuation Potentiometer Sign.2 Signal too High
P1174Fuel Trim, Bank 1 Different injection times
P1176O2 Correction Behind Catalyst,B1 Limit Attained
P1177O2 Correction Behind Catalyst,B2 Limit Attained
P1178Linear 02 Sensor/ Pump Current Open Circuit
P1179Linear 02 Sensor/ Pump Current Short to ground
P1180Linear 02 Sensor/ Pump Current Short to B+
P1181Linear 02 Sensor/ Reference Voltage Open Circuit
P1182Linear 02 Sensor/ Reference Voltage Short to ground
P1183Linear 02 Sensor/ Reference Voltage Short to B+
P1184Linear 02 Sensor/ Common Ground Wire Open Circuit
P1185Linear 02 Sensor/ Common Ground Wire Short to ground
P1186Linear 02 Sensor/ Common Ground Wire Short to B+
P1187Linear 02 Sensor/ Compens. Resistor Open Circuit
P1188Linear 02 Sensor/ Compens. Resistor Short to ground
P1189Linear 02 Sensor/ Compens. Resistor Short to B+
P1190Linear 02 Sensor/ Reference Voltage Incorrect Signal
P1196O2 Sensor Heater Circ., Bank1-Sensor1 Electrical Malfunction
P1197O2 Sensor Heater Circ., Bank2-Sensor1 Electrical Malfunction
P1198O2 Sensor Heater Circ., Bank1-Sensor2 Electrical Malfunction
P1199O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction
P1201Cyl.1-Fuel Inj.Circ. Electrical Malfunction
P1202Cyl.2-Fuel Inj.Circ. Electrical Malfunction
P1203Cyl.3-Fuel Inj.Circ. Electrical Malfunction
P1204Cyl.4-Fuel Inj.Circ. Electrical Malfunction
P1205Cyl.5-Fuel Inj.Circ. Electrical Malfunction
P1206Cyl.6-Fuel Inj.Circ. Electrical Malfunction
P1207Cyl.7-Fuel Inj.Circ. Electrical Malfunction
P1208Cyl.8-Fuel Inj.Circ. Electrical Malfunction
P1209Intake valves for cylinder shut-off Short circuit to ground
P1210Intake valves for cylinder shut-off Short to B+
P1211Intake valves for cylinder shut-off Open circuit
P1213Cyl.1-Fuel Inj.Circ. Short to B+
P1214Cyl.2-Fuel Inj.Circ. Short to B+
P1215Cyl.3-Fuel Inj.Circ. Short to B+
P1216Cyl.4-Fuel Inj.Circ. Short to B+
P1217Cyl.5-Fuel Inj.Circ. Short to B+
P1218Cyl.6-Fuel Inj.Circ. Short to B+
P1219Cyl.7-Fuel Inj.Circ. Short to B+
P1220Cyl.8-Fuel Inj.Circ. Short to B+
P1221Cylinder shut-off exhaust valves Short circuit to ground
P1222Cylinder shut-off exhaust valves Short to B+
P1223Cylinder shut-off exhaust valves Open circuit
P1225Cyl.1-Fuel Inj.Circ. Short to Ground
P1226Cyl.2-Fuel Inj.Circ. Short to Ground
P1227Cyl.3-Fuel Inj.Circ. Short to Ground
P1228Cyl.4-Fuel Inj.Circ. Short to Ground
P1229Cyl.5-Fuel Inj.Circ. Short to Ground
P1230Cyl.6-Fuel Inj.Circ. Short to Ground
P1231Cyl.7-Fuel Inj.Circ. Short to Ground
P1232Cyl.8-Fuel Inj.Circ. Short to Ground
P1237Cyl.1-Fuel Inj.Circ. Open Circ.
P1238Cyl.2-Fuel Inj.Circ. Open Circ.
P1239Cyl.3-Fuel Inj.Circ. Open Circ.
P1240Cyl.4-Fuel Inj.Circ. Open Circ.
P1241Cyl.5-Fuel Inj.Circ. Open Circ.
P1242Cyl.6-Fuel Inj.Circ. Open Circ.
P1243Cyl.7-Fuel Inj.Circ. Open Circ.
P1244Cyl.8-Fuel Inj.Circ. Open Circ.
P1245Needle Lift Sensor Circ. Short to Ground
P1246Needle Lift Sensor Circ. Range/Performance
P1247Needle Lift Sensor Circ. Open/Short to B+
P1248Injection Start Control Deviation
P1249Fuel consumption signal Electrical Fault in Circuit
P1250Fuel Level Too Low
P1251Start of Injection Solenoid Circ Short to B+
P1252Start of Injection Solenoid Circ Open/Short to Ground
P1253Fuel consumption signal Short to ground
P1254Fuel consumption signal Short to B+
P1255Engine Coolant Temp.Circ Short to Ground
P1256Engine Coolant Temp.Circ Open/Short to B+
P1257Engine Coolant System Valve Open
P1258Engine Coolant System Valve Short to B+
P1259Engine Coolant System Valve Short to Ground
P1280Fuel Inj.Air Contr.Valve Circ. Flow too Low
P1283Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
P1284Fuel Inj.Air Contr.Valve Circ. Open
P1285Fuel Inj.Air Contr.Valve Circ. Short to Ground
P1286Fuel Inj.Air Contr.Valve Circ. Short to B+
P1287Turbocharger bypass valve open
P1288Turbocharger bypass valve short to B+
P1289Turbocharger bypass valve short to ground
P1296Cooling system malfunction
P1297Connection turbocharger - throttle valve pressure hose
P1300Misfire detected Reason: Fuel level too low
P1319Knock Sensor 1 Circ. Short to Ground
P1320Knock Sensor 2 Circ. Short to Ground
P1321Knock Sensor 3 Circ. Low Input
P1322Knock Sensor 3 Circ. High Input
P1323Knock Sensor 4 Circ. Low Input
P1324Knock Sensor 4 Circ. High Input
P1325Cyl.1-Knock Contr. Limit Attained
P1326Cyl.2-Knock Contr. Limit Attained
P1327Cyl.3-Knock Contr. Limit Attained
P1328Cyl.4-Knock Contr. Limit Attained
P1329Cyl.5-Knock Contr. Limit Attained
P1330Cyl.6-Knock Contr. Limit Attained
P1331Cyl.7-Knock Contr. Limit Attained
P1332Cyl.8-Knock Contr. Limit Attained
P1335Engine Torque Monitoring 2 Control Limint Exceeded
P1336Engine Torque Monitoring Adaptation at limit
P1337Camshaft Pos.Sensor, Bank1 Short to Ground
P1338Camshaft Pos.Sensor, Bank1 Open Circ./Short to B+
P1339Crankshaft Pos./Engine Speed Sensor Cross Connected
P1340Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
P1341Ignition Coil Power Output Stage 1 Short to Ground
P1342Ignition Coil Power Output Stage 1 Short to B+
P1343Ignition Coil Power Output Stage 2 Short to Ground
P1344Ignition Coil Power Output Stage 2 Short to B+
P1345Ignition Coil Power Output Stage 3 Short to Ground
P1346Ignition Coil Power Output Stage 3 Short to B+
P1347Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
P1348Ignition Coil Power Output Stage 1 Open Circuit
P1349Ignition Coil Power Output Stage 2 Open Circuit
P1350Ignition Coil Power Output Stage 3 Open Circuit
P1354Modulation Piston Displ.Sensor Circ. Malfunction
P1355Cyl. 1, ignition circuit Open Circuit
P1356Cyl. 1, ignition circuit Short to B+
P1357Cyl. 1, ignition circuit Short to ground
P1358Cyl. 2, ignition circuit Open Circuit
P1359Cyl. 2, ignition circuit Short Circuit to B+
P1360Cyl. 2, ignition circuit Short Circuit to Ground
P1361Cyl. 3, ignition circuit Open Circuit
P1362Cyl. 3, ignition circuit Short Circuit to B+
P1363Cyl. 3, ignition circuit Short Circuit to ground
P1364Cyl. 4, ignition circuit Open Circuit
P1365Cyl. 4, ignition circuit Short circuit to B+
P1366Cyl. 4, ignition circuit Short circuit to ground
P1367Cyl. 5, ignition circuit Open Circuit
P1368Cyl. 5, ignition circuit Short Circuit to B+
P1369Cyl. 5, ignition circuit short to ground
P1370Cyl. 6, ignition circuit Open Circuit
P1371Cyl. 6, ignition circuit Short Circuit to B+
P1372Cyl. 6, ignition circuit short to ground
P1373Cyl. 7, ignition circuit Open Circuit
P1374Cyl. 7, ignition circuit Short Circuit to B+
P1375Cyl. 7, ignition circuit short to ground
P1376Cyl. 8, ignition circuit Open Circuit
P1377Cyl. 8, ignition circuit Short Circuit to B+
P1378Cyl. 8, ignition circuit short to ground
P1386Internal Control Module Knock Control Circ.Error
P1387Internal Contr. Module altitude sensor error
P1388Internal Contr. Module drive by wire error
P1391Camshaft Pos.Sensor,Bank2 Short to Ground
P1392Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
P1393Ignition Coil Power Output Stage 1 Electrical Malfunction
P1394Ignition Coil Power Output Stage 2 Electrical Malfunction
P1395Ignition Coil Power Output Stage 3 Electrical Malfunction
P1396Engine Speed Sensor Missing Tooth
P1397Engine speed wheel Adaptation limit reached
P1398Engine RPM signal, TD Short to ground
P1399Engine RPM signal, TD Short Circuit to B+
P1400EGR Valve Circ Electrical Malfunction
P1401EGR Valve Circ Short to Ground
P1402EGR Valve Circ Short to B+
P1403EGR Flow Deviation
P1404EGR Flow Basic Setting not carried out
P1406EGR Temp.Sensor Range/Performance
P1407EGR Temp.Sensor Signal too Low
P1408EGR Temp.Sensor Signal too High
P1409Tank Ventilation Valve Circ. Electrical Malfunction
P1410Tank Ventilation Valve Circ. Short to B+
P1411Sec.Air Inj.Sys.,Bank2 Flow too Flow
P1412EGR Different.Pressure Sensor Signal too Low
P1413EGR Different.Pressure Sensor Signal too High
P1414Sec.Air Inj.Sys.,Bank2 Leak Detected
P1417Fuel Level Sensor Circ Signal too Low
P1418Fuel Level Sensor Circ Signal too High
P1420Sec.Air Inj.Valve Circ Electrical Malfunction
P1421Sec.Air Inj.Valve Circ Short to Ground
P1422Sec.Air Inj.Sys.Contr.Valve Circ Short to B+
P1423Sec.Air Inj.Sys.,Bank1 Flow too Low
P1424Sec.Air Inj.Sys.,Bank1 Leak Detected
P1425Tank Vent.Valve Short to Ground
P1426Tank Vent.Valve Open
P1432Sec.Air Inj.Valve Open
P1433Sec.Air Inj.Sys.Pump Relay Circ. open
P1434Sec.Air Inj.Sys.Pump Relay Circ. Short to B+
P1435Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
P1436Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction
P1439EGR Potentiometer Error in Basic Seting
P1440EGR Valve Power Stage Open
P1441EGR Valve Circ Open/Short to Ground
P1442EGR Valve Position Sensor Signal too high
P1443EGR Valve Position Sensor Signal too low
P1444EGR Valve Position Sensor range/performance
P1445Catalyst Temp.Sensor 2 Circ. Range/Performance
P1446Catalyst Temp.Circ Short to Ground
P1447Catalyst Temp.Circ Open/Short to B+
P1448Catalyst Temp.Sensor 2 Circ. Short to Ground
P1449Catalyst Temp.Sensor 2 Circ. Open/Short to B+
P1450Sec.Air Inj.Sys.Circ Short to B+
P1451Sec.Air Inj.Sys.Circ Short to Ground
P1452Sec.Air Inj.Sys. Open Circ.
P1453Exhaust gas temperature sensor 1 open/short to B+
P1454Exhaust gas temperature sensor short 1 to ground
P1455Exhaust gas temperature sensor 1 range/performance
P1456Exhaust gas temperature control bank 1 limit attained
P1457Exhaust gas temperature sensor 2 open/short to B+
P1458Exhaust gas temperature sensor 2 short to ground
P1459Exhaust gas temperature sensor 2 range/performance
P1460Exhaust gas temperature control bank 2 limit attained
P1461Exhaust gas temperature control bank 1 Range/Performance
P1462Exhaust gas temperature control bank 2 Range/Performance
P1465Additive Pump Short Circuit to B+
P1466Additive Pump Open/Short to Ground
P1467EVAP Canister Purge Solenoid Valve Short Circuit to B+
P1468EVAP Canister Purge Solenoid Valve Short Circuit to Ground
P1469EVAP Canister Purge Solenoid Valve Open Circuit
P1470EVAP Emission Contr.LDP Circ Electrical Malfunction
P1471EVAP Emission Contr.LDP Circ Short to B+
P1472EVAP Emission Contr.LDP Circ Short to Ground
P1473EVAP Emission Contr.LDP Circ Open Circ.
P1474EVAP Canister Purge Solenoid Valve electrical malfunction
P1475EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open
P1476EVAP Emission Contr.LDP Circ Malfunction/ Insufficient Vacuum
P1477EVAP Emission Contr.LDP Circ Malfunction
P1478EVAP Emission Contr.LDP Circ Clamped Tube Detected
P1500Fuel Pump Relay Circ. Electrical Malfunction
P1501Fuel Pump Relay Circ. Short to Ground
P1502Fuel Pump Relay Circ. Short to B+
P1503Load signal from Alternator Term. DF Range/ performance/ Incorrect Signal
P1504Intake Air Sys.Bypass Leak Detected
P1505Closed Throttle Pos. Does Not Close/Open Circ
P1506Closed Throttle Pos.Switch Does Not Open/Short to Ground
P1507Idle Sys.Learned Value Lower Limit Attained
P1508Idle Sys.Learned Value Upper Limit Attained
P1509Idle Air Control Circ. Electrical Malfunction
P1510Idle Air Control Circ. Short to B+
P1511Intake Manifold Changeover Valve circuit electrical malfunction
P1512Intake Manifold Changeover Valve circuit Short to B+
P1513Intake Manifold Changeover Valve2 circuit Short to B+
P1514Intake Manifold Changeover Valve2 circuit Short to ground
P1515Intake Manifold Changeover Valve circuit Short to Ground
P1516Intake Manifold Changeover Valve circuit Open
P1517Main Relay Circ. Electrical Malfunction
P1518Main Relay Circ. Short to B+
P1519Intake Camshaft Contr.,Bank1 Malfunction
P1520Intake Manifold Changeover Valve2 circuit Open
P1521Intake Manifold Changeover Valve2 circuit electrical malfunction
P1522Intake Camshaft Contr.,Bank2 Malfunction
P1523Crash Signal from Airbag Control Unit range/performance
P1525Intake Camshaft Contr.Circ.,Bank1 Electrical Malfunction
P1526Intake Camshaft Contr.Circ.,Bank1 Short to B+
P1527Intake Camshaft Contr.Circ.,Bank1 Short to Ground
P1528Intake Camshaft Contr.Circ.,Bank1 Open
P1529Camshaft Control Circuit Short to B+
P1530Camshaft Control Circuit Short to ground
P1531Camshaft Control Circuit open
P1533Intake Camshaft Contr.Circ.,Bank2 Electrical Malfunction
P1534Intake Camshaft Contr.Circ.,Bank2 Short to B+
P1535Intake Camshaft Contr.Circ.,Bank2 Short to Ground
P1536Intake Camshaft Contr.Circ.,Bank2 Open
P1537Engine Shutoff Solenoid Malfunction
P1538Engine Shutoff Solenoid Open/Short to Ground
P1539Clutch Vacuum Vent Valve Switch Incorrect signal
P1540Vehicle Speed Sensor High Input
P1541Fuel Pump Relay Circ Open
P1542Throttle Actuation Potentiometer Range/Performance
P1543Throttle Actuation Potentiometer Signal too Low
P1544Throttle Actuation Potentiometer Signal too High
P1545Throttle Pos.Contr Malfunction
P1546Boost Pressure Contr.Valve Short to B+
P1547Boost Pressure Contr.Valve Short to Ground
P1548Boost Pressure Contr.Valve Open
P1549Boost Pressure Contr.Valve Short to Ground
P1550Charge Pressure Deviation
P1551Barometric Pressure Sensor Circ. Short to B+
P1552Barometric Pressure Sensor Circ. Open/Short to Ground
P1553Barometric/manifold pressure signal ratio out of range
P1554Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met
P1555Charge Pressure Upper Limit exceeded
P1556Charge Pressure Contr. Negative Deviation
P1557Charge Pressure Contr. Positive Deviation
P1558Throttle Actuator Electrical Malfunction
P1559Idle Speed Contr.Throttle Pos. Adaptation Malfunction
P1560Maximum Engine Speed Exceeded
P1561Quantity Adjuster Deviation
P1562Quantity Adjuster Upper Limit Attained
P1563Quantity Adjuster Lower Limit Attained
P1564Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation
P1565Idle Speed Control Throttle Position lower limit not attained
P1566Load signal from A/C compressor range/performance
P1567Load signal from A/C compressor no signal
P1568Idle Speed Contr.Throttle Pos. mechanical Malfunction
P1569Cruise control switch Incorrect signal
P1570Contr.Module Locked
P1571Left Eng. Mount Solenoid Valve Short to B+
P1572Left Eng. Mount Solenoid Valve Short to ground
P1573Left Eng. Mount Solenoid Valve Open circuit
P1574Left Eng. Mount Solenoid Valve Electrical fault in circuit
P1575Right Eng. Mount Solenoid Valve Short to B+
P1576Right Eng. Mount Solenoid Valve Short to ground
P1577Right Eng. Mount Solenoid Valve Open circuit
P1578Right Eng. Mount Solenoid Valve Electrical fault in circuit
P1579Idle Speed Contr.Throttle Pos. Adaptation not started
P1580Throttle Actuator B1 Malfunction
P1581Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out
P1582Idle Adaptation at Limit
P1583Transmission mount valves Short to B+
P1584Transmission mount valves Short to ground
P1585Transmission mount valves Open circuit
P1586Engine mount solenoid valves Short to B+
P1587Engine mount solenoid valves Short to ground
P1588Engine mount solenoid valves Open circuit
P1600Power Supply (B+) Terminal 15 Low Voltage
P1602Power Supply (B+) Terminal 30 Low Voltage
P1603Internal Control Module Malfunction
P1604Internal Control Module Driver Error
P1605Rough Road/Acceleration Sensor Electrical Malfunction
P1606Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
P1607Vehicle speed signal Error message from instrument cluster
P1608Steering angle signal Error message from steering angle sensor
P1609Crash shut-down activated
P1611MIL Call-up Circ./Transm.Contr.Module Short to Ground
P1612Electronic Control Module Incorrect Coding
P1613MIL Call-up Circ Open/Short to B+
P1614MIL Call-up Circ./Transm.Contr.Module Range/Performance
P1615Engine Oil Temperature Sensor Circuit range/performance
P1616Glow Plug/Heater Indicator Circ. Short to B+
P1617Glow Plug/Heater Indicator Circ. Open/Short to Ground
P1618Glow Plug/Heater Relay Circ. Short to B+
P1619Glow Plug/Heater Relay Circ. Open/Short to Ground
P1620Engine coolant temperature signal open/short to B+
P1621Engine coolant temperature signal short to ground
P1622Engine coolant temperature signal range/performance
P1623Data Bus Powertrain No Communication
P1624MIL Request Sign.active
P1625Data-Bus Powertrain Unplausible Message from Transm.Contr.
P1626Data-Bus Powertrain Missing Message from Transm.Contr.
P1627Data-Bus Powertrain missing message from fuel injection pump
P1628Data-Bus Powertrain missing message from steering sensor
P1629Data-Bus Powertrain missing message from distance control
P1630Accelera.Pedal Pos.Sensor 1 Signal too Low
P1631Accelera.Pedal Pos.Sensor 1 Signal too High
P1632Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction
P1633Accelera.Pedal Pos.Sensor 2 Signal too Low
P1634Accelera.Pedal Pos.Sensor 2 Signal too High
P1635Data Bus Powertrain missing message f.air condition control
P1636Data Bus Powertrain missing message from Airbag control
P1637Data Bus Powertrain missing message f.central electr.control
P1638Data Bus Powertrain missing message from clutch control
P1639Accelera.Pedal Pos.Sensor 1+2 Range/Performance
P1640Internal Contr.Module (EEPROM) Error
P1641Please check DTC Memory of Air Condition ECU
P1642Please check DTC Memory of Airbag ECU
P1643Please check DTC Memory of central electric ECU
P1644Please check DTC Memory of clutch ECU
P1645Data Bus Powertrain missing message f.all wheel drive contr.
P1646Please Check DTC Memory of all wheel drive ECU
P1647Please check coding of ECUs in Data Bus Powertrain
P1648Data Bus Powertrain Malfunction
P1649Data Bus Powertrain Missing message from ABS Control Module
P1650Data Bus Powertrain Missing message fr.instrument panel ECU
P1651Data Bus Powertrain missing messages
P1652Please check DTC Memory of transmission ECU
P1653Please check DTC Memory of ABS Control Module
P1654Please check DTC Memory of control panel ECU
P1655Please check DTC Memory of ADR Control Module
P1656A/C clutch relay circuit short to ground
P1657A/C clutch relay circuit short to B+
P1658Data Bus Powertrain Incorrect signal from ADR Control Module
P1676Drive by Wire-MIL Circ. Electrical Malfunction
P1677Drive by Wire-MIL Circ. Short to B+
P1678Drive by Wire-MIL Circ. Short to Ground
P1679Drive by Wire-MIL Circ. Open
P1681Contr.Unit Programming, Programming not Finished
P1684Contr.Unit Programming Communication Error
P1686Contr.Unit Error Programming Error
P1690Malfunction Indication Light Malfunction
P1691Malfunction Indication Light Open
P1692Malfunction Indication Light Short to Ground
P1693Malfunction Indication Light Short to B+
P1694Malfunction Indication Light Open/Short to Ground
P1704Kick Down Switch Malfunction
P1705Gear/Ratio Monitoring Adaptation limit reached
P1711Wheel Speed Signal 1 Range/Performance
P1716Wheel Speed Signal 2 Range/Performance
P1721Wheel Speed Signal 3 Range/Performance
P1723Starter Interlock Circ. Open
P1724Starter Interlock Circ. Short to Ground
P1726Wheel Speed Signal 4 Range/Performance
P1728Different Wheel Speed Signals Range/Performance
P1729Starter Interlock Circ. Short to B+
P1733Tiptronic Switch Down Circ. Short to Ground
P1739Tiptronic Switch up Circ. Short to Ground
P1740Clutch temperature control
P1741Clutch pressure adaptation at limit
P1742Clutch torque adaptation at limit
P1743Clutch slip control signal too high
P1744Tiptronic Switch Recognition Circ. Short to Ground
P1745Transm.Contr.Unit Relay Short to B+
P1746Transm.Contr.Unit Relay Malfunction
P1747Transm.Contr.Unit Relay Open/Short to Ground
P1748Transm.Contr.Unit Self-Check
P1749Transm.Contr.Unit Incorrect Coded
P1750Power Supply Voltage Low Voltage
P1751Power Supply Voltage High Voltage
P1752Power Supply Malfunction
P1760Shift Lock Malfunction
P1761Shift Lock Short to Ground
P1762Shift Lock Short to B+
P1763Shift Lock Open
P1764Transmission temperature control
P1765Hydraulic Pressure Sensor 2 adaptation at limit
P1766Throttle Angle Signal Stuck Off
P1767Throttle Angle Signal Stuck On
P1768Hydraulic Pressure Sensor 2 Too High
P1769Hydraulic Pressure Sensor 2 Too Low
P1770Load Signal Range/Performance
P1771Load Signal Stuck Off
P1772Load Signal Stuck On
P1773Hydraulic Pressure Sensor 1 Too High
P1774Hydraulic Pressure Sensor 1 Too Low
P1775Hydraulic Pressure Sensor 1 adaptation at limit
P1776Hydraulic Pressure Sensor 1 range/performance
P1777Hydraulic Pressure Sensor 2 range/performance
P1778Solenoid EV7 Electrical Malfunction
P1780Engine Intervention Unreadable. Also check for loose ECM power relay.
P1781Engine Torque Reduction Open/Short to Ground
P1782Engine Torque Reduction Short to B+
P1784Shift up/down Wire Open/Short to Ground
P1785Shift up/down Wire Short to B+
P1786Reversing Light Circ. Open
P1787Reversing Light Circ. Short to Ground
P1788Reversing Light Circ. Short to B+
P1789Idle Speed Intervention Circ. Error Message from Engine Contr.
P1790Transmission Range Display Circ. Open
P1791Transmission Range Display Circ. Short to Ground
P1792Transmission Range Display Circ. Short to B+
P1793Output Speed Sensor 2 Circ. No Signal
P1795Vehicle Speed Signal Circ. Open
P1796Vehicle Speed Signal Circ. Short to Ground
P1797Vehicle Speed Signal Circ. Short to B+
P1798Output Speed Sensor 2 Circ. Range/Performance
P1799Output Speed Sensor 2 Circ. Rpm too High
P1813Pressure Contr.Solenoid 1 Electrical
P1814Pressure Contr.Solenoid 1 Open/Short to Ground
P1815Pressure Contr.Solenoid 1 Short to B+
P1818Pressure Contr.Solenoid 2 Electrical
P1819Pressure Contr.Solenoid 2 Open/Short to Ground
P1820Pressure Contr.Solenoid 2 Short to B+
P1823Pressure Contr.Solenoid 3 Electrical
P1824Pressure Contr.Solenoid 3 Open/Short to Ground
P1825Pressure Contr.Solenoid 3 Short to B+
P1828Pressure Contr.Solenoid 4 Electrical
P1829Pressure Contr.Solenoid 4 Open/Short to Ground
P1830Pressure Contr.Solenoid 4 Short to B+
P1834Pressure Contr.Solenoid 5 Open/Short to Ground
P1835Pressure Contr.Solenoid 5 Short to B+
P1841Engine/Transmission Control Modules Versions do not match
P1842Please check DTC Memory of instrument panel ECU
P1843Please check DTC Memory of ADR Control Module
P1844Please check DTC Memory of central electric control ECU
P1847Please check DTC Memory of brake system ECU
P1848Please check DTC Memory of engine ECU
P1849Please check DTC Memory of transmission ECU
P1850Data-Bus Powertrain Missing Message from Engine Contr.
P1851Data-Bus Powertrain Missing Message from Brake Contr.
P1852Data-Bus Powertrain Unplausible Message from Engine Contr.
P1853Data-Bus Powertrain Unplausible Message from Brake Contr.
P1854Data-Bus Powertrain Hardware Defective
P1855Data-Bus Powertrain Software version Contr.
P1856Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr.
P1857Load Signal Error Message from Engine Contr.
P1858Engine Speed Input Circ. Error Message from Engine Contr.
P1859Brake Switch Circ. Error Message from Engine Contr.
P1860Kick Down Switch Error Message from Engine Contr.
P1861Throttle Position (TP) sensor Error Message from ECM
P1862Data Bus Powertrain Missing message from instr. panel ECU
P1863Data Bus Powertrain Missing Message from St. Angle Sensor
P1864Data Bus Powertrain Missing message from ADR control module
P1865Data Bus Powertrain Missing message from central electronics
P1866Data Bus Powertrain Missing messages
