Главният е, може ли модификацията Е да се докара до възможностите на Т? Разликите програмни ли са, или в желязото?
Юзерски въпроси за Алинко DJ-G5
До: Юзерски въпроси за Алинко DJ-5G
Модела е DJ-G5.
Разликата е програмна и хардуерна - има я описана в сервизното ръководство.
Ето някои съвети от колеги:
Extended RX/TX for DJ-G5E
Extending the recieve range.
To extend the recieve range to AM/FM 108-173.995mhz, 400-511.995mhz and 800-999.990mhz there is a simple keypad sequence as follows.
Press and hold the function button on the side and press the FL button twice
This puts the frequency lock on.Then whilst pressing the function button press #212, The display should then read "OPEN".
Then remove the frequency lock by pressing function and FL together.
Extending The Transmit range.
The radio can be made able to tramsmit between 130-174mhz and 400-512mhz (if it cant already after the above mod) by removing the back and cutting the blue loop of wire near the speaker socket and resetting the radio.
Open and reset the Alinco DJ-G5E radio
As in dg-g5T you can open your radio as described:
Remove the 4 screws that hold the back cover of the unit on.
CAREFULLY pry the case apart (It's helps to remove the VFO/Mem/etc knob first)
On the FRONT portion (DTMF Pad) of the case, in the upper right-hand corner you will see a BLUE wire. Cut that carefully.
Reassemble the unit.
While holding the FUNC key, press POWER to reset the unit.
Extended TX/RX for the Alinco DJ-G5E (European Model)
In the DJ-G5E you can extend TX/RX just by doing this (you don't have to open the radio):
Keylock your radio (Func 0)
Press Func #212
It will appear on the screen:
Open
Now you have:
VHF
RX: 108Mhz - 174Mhz
TX: 130Mhz - 174Mhz
UHF
RX: 400Mhz - 512Mhz
TX: 400Mhz - 512Mhz
On the right VFO
RX: 800Mhz - 1000Mhz
In VHF or UHF you can receive in AM just by pressing Func 6
To close te radio use the same procedure:
Press Func #212
it will appear on the screen:
ClosedShow must go on!
LZ1VES
До: Юзерски въпроси за Алинко DJ-G5
Ако не стане, има и други хардуерни начини - със смяна резисторите в матрица, която се чете при стартиране от процесора. Слагам и схемите, там има таблица отдолу...
Описаниетo по-долу е за обратната процедура - Т във Е, но принципа е същия.
After studying the service manual, I found how to make the G5T into the
G5E. The only diference is FL51 the UHF Sinad and 3 chip resistors.
Now for the mod:
Remove the back of the radio. On the front half of the unit, remove
two screws from the PCB near the bottom(not the very bottom screws) and
remove the board carefully to expose the CPU board. Above the CPU
shield are 4 SMT resistors to the right of a large SMT Cap (+ 33 10V).
Remove the top Resistor (R536) remove the the second and third
resistors (R541 and R571) and swap them.
Reasemble the radio, and reset the CPU. And now it will respond the
same as the DJG5E
I have tried this on my own radio and it works, I Dont take
responsibility if you damage your radio. You have to enter 800 MHz in
the VFO and then it will scan it. I STRONGLY recoment getting the
sevice manual from the alinco websight. Its 5MB download but its
free.
За да се отворят схемите, трябва файла DJ-G5_r00.rar да се преименува на DG-G5.r00 и да е в една папка с другия DG-G5.rarПрикачени файловеShow must go on!
LZ1VES
И сервизното ръководство.Прикачени файловеShow must go on!
LZ1VES
Ами като тръгне в Т режим, ще позволява кросбанда, нали за това е упражнението...
Слагам тука и оперативното ръководство, да са заедно.Прикачени файловеShow must go on!
LZ1VES
Първоначално публикуван от Стефан Преглед на мнениеНе знам, в ръководството пише че сато Т било кросбанд.
Ммм ... А какъв е смисълът Т да се прави на Е? Доколкото схванах, Е е същото, с орязани параметри.
Един приятел - Борето има един точен лаф - "Големите разлики са в малките разлики"Show must go on!
LZ1VES
Е, от една страна е така, да внимаваш. Ама я си представи, връткаш нещо, и не гледаш къде си, или сканираш и ти спира някъде из забраненото А ти не помниш честотите кои-къде, натискаш PTT да говориш.... После има два варианта - да ти е гадно (ако има на какво) или да ти е още по-гадно, като дойдат с кочаните.Show must go on!
LZ1VES
От това радио верно ми омекна мозъка. Има повече копчета от пишеща машина, и част от функциите още не вдявам за какво са. Утре пак ще чета от края до другия край на трамвая 12. Два пъти.
От: До: Юзерски въпроси за Алинко DJ-G5
Първоначално публикуван от LZ1MOB Преглед на мнениеАз имам въпрос за отключването за "T" версията на DJ-G5, ако имате някакво инфо ще съм благодарен!
ФУНКЦИИ НА ALINCO G5
1. POW + MW -> 80+20 или 100 канала
2. POW + DIAL -> демонстрация - ниво индикатори
3. POW + W+V -> Функция CLONE - зареждане паметта на друг чрез излъчване на DUALTONE гама
4. POW + GPDSQ -> 480/750 време DIAL
5. POW + TSQV -> 88.5 T.SCUELCH - +
6. POW + SHIFT -> 10.00 - SHIFT - +
7. POW + KL/FL -> горен/долен банд - репитер
8. POW + STEP I -> PL-Lo - ниско ниво предаване на малък бутон
I -> PL-5b -
I -> PL-Lb - норм??
9. KL/FUNC + #986 -> заключва на канал
10. KL/FUNC + *284 -> отключване
11. V + ENT -> записва и отключва ???
12. KL/FUNC #212 -> отключва и заключва комерсиално/радиолюбителко използване
13. KLF + KON -> BS 06/08/1.2 - време на батерия сейф
14. AM - от VFO FUNC + SCIP
