Здравейте колеги... светна ми чека и на диагностика ми дава Р0051 (ламда сонда бака 2 сензор 1).. джипа е гранд чероки 4.7 WJ 2003г 258 к.с Виждам че това е сонда преди катализатора но не мога да разбера от коя страна на мотора е банка 2 и тъй като не мога да намеря за 258 к.с сонда има за 223 или там колкото се води и не знам дали ще стане , ще съм много благодарен някой ако може да помогне какво да правя
Грешка Р0051
От: Грешка Р0051
V engines by design have one cylinder bank that's closer to the front of the engine than the other. If you were to lay a ruler across the valve covers you'd find that one was placed further forward than the other, this is bank 1. Sensor 1 is the first sensor in the exhaust stream usually located in the exhaust manifold. So you're looking for the sensor in the side of the engine that sits a little back from the front and closest to the engine.
https://www.google.co.uk/search?q=P0...kee+4.7+petrol
Part of the problem is that you have four O2 sensors. Your code refers to the 2/1 sensor. Which of the four sensors did you actually change?????
Bank 1 Sensor 1 (Sensor 1/1) is on the pipe between the exhaust manifold and the small cat closest to the radiator. It's an upstream sensor.
Bank 1 Sensor 2 (Sensor 1/2) is on the pipe after the small cat closest to the radiator. It's a downstream sensor.
Bank 2 Sensor 1 (Sensor 2/1) is on the pipe between the exhaust manifold and the other small cat closest to the firewall. It's an upstream sensor.
Bank 2 Sensor 2 (Sensor 2/2) is on the pipe after the other small cat closest to the firewall. It's a downstream sensor.
Here's a link to a diagram. http://www.wjjeeps.com/oxygen_40.jpg
http://www.jeepforum.com/forum/f13/0...-p0051-553160/
http://wjjeeps.com/oxygen.htm
Бъдете живи и здрави!
От: Грешка Р0051
Превишил си лимита от съобщения, исках да ти пратя това по-долу:
Здрасти колега,
Аз съм любител механик и за съжаление не мога да ти дам бърз съвет, освен да прочетеш малко по линковете, които ти предоставих и да видиш как са нещата при теб, да набележиш проблемния/те датчици и да тестваш, хората казват ставало с бушони, ,махаш един да тестваш 1ви датчик, после другия бушон да тестваш втория датчик, или направо откачаш датчика и така разбираш дали е датчик и кой от двата.
Намери време и тествай последователно според съветите в линковете, ако не става лесно ще трябва да си намериш читав механик.
Успех и хубав ден!
ЖороБъдете живи и здрави!
От: Грешка Р0051
Първоначално публикуван от Boqn Mateev Преглед на мнение... за моя който се води H.O 258 коня няма нищо в цяла стара загора.....
.....опитай в "рокауто" (ако не се справиш сам, звънни ще помагам) Хо-хо мотора или ВИН код "Джей" си го дават за несъвместимите части, за сондите няма.......0877 17 07 27 Понеделник - ден за почивка
