Теч в купето на Land Rover Discovery 3
  • Теч в купето на Land Rover Discovery 3
    Както и при предишните генерации ,този проблем е налице в трета и четвърта серия ,при това е доста често срещан...В краката ми има приличен гьол.Вода се стича по А-колоната. Утре ще разгобявам и снимам. Досега четох англетата (през преводач от английски на немски ) .Нещата ми се поизясниха ,но моля някой с добър английски да преведе следния текст . Благодаря предварително .
    Water drainage system
    If a vehicle develops water leaks, then areas into which water is routed or drained should be checked first.
    Water leaks, diagnosis and corrective action: Front passenger compartment Windscreen
    ␣ Diagnosis: Ingress of water into A-pillar area or instrument cluster area and rocker panel area. ␣ Ingress of water into A-pillar area or instrument cluster area and rocker panel area.
    ␣ Cause: Breaks in adhesive beads ␣ Breaks in adhesive beads
    ␣ Corrective action: The breaks in adhesive beads can be located from inside by using compressed air. The leak can be identified from outside by the escaping air. The second test method is by means of a water test. The outer trims must be raised carefully using a plastic wedge. The leak should be located from inside by a second assistant.
    ␣ The breaks in adhesive beads can be located from inside by using compressed air. The leak can be identified from outside by the escaping air.
    ␣ The second test method is by means of a water test. The outer trims must be raised carefully using a plastic wedge. The leak should be located from inside by a second assistant.
    Side windows
    In the case of side windows, the same problems can arise as for a windscreen. The same corrective actions must therefore be used.
    Door seal
    ␣ Diagnosis: Water ingress in the lower part of the interior door trim or in the rocker panel area. ␣ Water ingress in the lower part of the interior door trim or in the rocker panel area.
    ␣ Cause: The water shield fitted behind the interior door trim exists to drain off water that has entered the door via the drainage holes, either downwards or outwards. If the water shield seal is damaged or has been fitted incorrectly, thenwater can get into the passenger compartment. In addition to this, the drainage holes can become clogged with leaves, dirt or excess cavity protection agents. Water gathers in the door and ingresses into the passenger compartment. Checkwater shield for damage or correct fitting. If the water shield needs to be re-bonded, then approved seam sealer should be used. Before the water shield is installed, the drainage holes must be checked for unhindered flow.
    ␣ The water shield fitted behind the interior door trim exists to drain off water that has entered the door via the drainage holes, either downwards or outwards. If the water shield seal is damaged or has been fitted incorrectly, then water can get into the passenger compartment.
    ␣ In addition to this, the drainage holes can become clogged with leaves, dirt or excess cavity protection agents. Watergathers in the door and ingresses into the passenger compartment.
    ␣ Check water shield for damage or correct fitting. ␣ If the water shield needs to be re-bonded, then approved seam sealer should be used. ␣ Before the water shield is installed, the drainage holes must be checked for unhindered flow.
    Door seals
    ␣ Diagnosis: Ingress of water into the rocker panel area ␣ Ingress of water into the rocker panel area
    ␣ Cause: Insufficient clamping load between seal and door. ␣ Insufficient clamping load between seal and door.
    ␣ Corrective action: Check clamping load: The easiest way to check the clamping load of a seal to the respective bearing surface is by means of a paper strip test. This consists of trapping strips of paper at various points between the door and the seal, and fully closing the door. If it is possible to pull out the paper with no great resistance, then the clamping load is too low. Adjust the clamping load: NOTE :
    When adjusting the clamping load, the profile alignment of the relevant components must always be taken into consideration.
    The clamping load is normally adjusted using the striker. When doing so, the edge alignment from the door to the side panel, or from the front door to the rear door must be taken into account. Another setting method is to realign the panel flange for the seal mounting. The clamping load is increased by moving the flange towards the door. NOTE :
    Do not realign the flange too far in the direction of the door, as this can reduce the bearing surface of the seal to the door.
    Check the bearing surface: Apply chalk evenly to the surface of the seal. Evenly coat the bearing surface of the door with vaseline. Close the door fully, the lock must engage. Open the door. The imprint of the chalk (bearing surface) can be identified in the film of grease. The bearing surface should be at least 5mm across at all points.
    ␣ Check clamping load: ␣ The easiest way to check the clamping load of a seal to the respective bearing surface is by means of
    ␣ Adjust the clamping load: ␣ NOTE :
    door to the side panel, or from the front door to the rear door must be taken into account. ␣ Another setting method is to realign the panel flange for the seal mounting. The clamping load is
    ␣ NOTE :
    Check the bearing surface: ␣ Apply chalk evenly to the surface of the seal. Evenly coat the bearing surface of the door with
    vaseline. ␣ Close the door fully, the lock must engage. Open the door. The imprint of the chalk (bearing surface)
    can be identified in the film of grease. ␣ The bearing surface should be at least 5mm across at all points.
    ␣ Other causes: The door seal must completely seal the door where it meets the bodywork. Water can ingress directly or indirectly into the interior of the vehicle if the seal is damaged at any point.
    ␣ The door seal must completely seal the door where it meets the bodywork. ␣ Water can ingress directly or indirectly into the interior of the vehicle if the seal is damaged at any
    point. ␣ Corrective action: A damaged or worn door seal must always be renewed in full. When renewing the seal, the
    following must be taken into account: Always fit the seal first in the area of the narrow radii (corner points). Next, secure the seal to the flange evenly by tapping lightly with a rubber hammer. The installed seal must not be kinked at any point.
    ␣ A damaged or worn door seal must always be renewed in full. ␣ When renewing the seal, the following must be taken into account: ␣ Always fit the seal first in the area of the narrow radii (corner points). ␣ Next, secure the seal to the flange evenly by tapping lightly with a rubber hammer. The installed seal
    must not be kinked at any point. The prescribed length of a seal must not be shortened.
    NOTE :
    ␣ Other cause: The door seal is attached to the welded flange all the way round. If this welded flange is uneven or damaged at any point (usually in areas with narrow radii) then this point could be subject to leaks. A stretched seal carrier can also cause a leak. In both cases, water gets into the vehicle interior under the seal carrier.
    ␣ The door seal is attached to the welded flange all the way round. If this welded flange is uneven or damaged at any point (usually in areas with narrow radii) then this point could be subject to leaks.
    ␣ A stretched seal carrier can also cause a leak.
    ␣ In both cases, water gets into the vehicle interior under the seal carrier. ␣ Corrective action: Align the deformed welded flange using a hammer and anvil block, prevent and if
    necessary repair any paint damage. ␣ Align the deformed welded flange using a hammer and anvil block, prevent and if necessary repair
    any paint damage.
    ␣ A stretched seal carrier can also cause a leak. ␣ In both cases, water gets into the vehicle interior under the seal carrier.
    Sliding roof/tilting roof
    ␣ Diagnosis: Ingress of water at sliding roof aperture ␣ Ingress of water at sliding roof aperture
    ␣ Cause: The sliding roof/tilting roof is installed in a water trap. The water drains off via the water trap, water drain holes and drain hoses. The drain hoses lead downwards on both sides via the A-pillar and C-pillar. The drain holes or drain hoses can become clogged with leaves, dirt, underbody protection and so on.
    ␣ The sliding roof/tilting roof is installed in a water trap. The water drains off via the water trap, water drain holes and drain hoses. The drain hoses lead downwards on both sides via the A-pillar and C- pillar.
    ␣ The drain holes or drain hoses can become clogged with leaves, dirt, underbody protection and so on. ␣ Corrective action: NOTE :
    In the case of a sliding or tilting roof, the external rubber seal and the lock actuator or latch mechanism must be checked first of all.
    Check the water trap for leaks. Check the drain hoses for leaks and for correct connection to the water trap. Check the drainage system for unhindered flow, and blow out with compressed air if necessary. Check the external seal and the correct adjustment of the sliding roof.
    ␣ NOTE :
    Check the water trap for leaks. ␣ Check the drain hoses for leaks and for correct connection to the water trap. ␣ Check the drainage system for unhindered flow, and blow out with compressed air if necessary. ␣ Check the external seal and the correct adjustment of the sliding roof.
    Tailgate and Liftgate
    ␣ Diagnosis: Ingress of water into rear headlining area and luggage area. ␣ Ingress of water into rear headlining area and luggage area.
    ␣ Cause: The leak problems of the tailgate and liftgate correspond to those of the doors. In addition to this, the area to be sealed is much bigger. The routing holes for cables and hoses must also be sealed. The rubber grommets for the routing holes must be checked for damage and correct seating (fully unhooked). The mounting points of the tailgate and liftgate hinges may leak.
    ␣ The leak problems of the tailgate and liftgate correspond to those of the doors. ␣ In addition to this, the area to be sealed is much bigger. The routing holes for cables and hoses must
    also be sealed. ␣ The rubber grommets for the routing holes must be checked for damage and correct seating (fully
    unhooked). ␣ The mounting points of the tailgate and liftgate hinges may leak.
    ␣ Corrective action: Check the rubber grommets and renew if necessary. Check the hinge mounting points, and re-seal with sealing compound if necessary.
    ␣ Check the rubber grommets and renew if necessary. ␣ Check the hinge mounting points, and re-seal with sealing compound if necessary.
    Forced air extraction
    ␣ Diagnosis: Ingress of water into side luggage compartment area ␣ Ingress of water into side luggage compartment area
    ␣ Cause: The forced air extraction for the vehicle interior is located in the D-pillar behind the rear lights. The rubber flap of the forced air extraction must be able to move freely.
    ␣ The forced air extraction for the vehicle interior is located in the D-pillar behind the rear lights.
    ␣ The rubber flap of the forced air extraction must be able to move freely. ␣ Corrective action: Remove the forced air extraction. Check the seal area between the bodywork and housing,
    as well as the rubber flap. Renew seal if necessary. ␣ Remove the forced air extraction. ␣ Check the seal area between the bodywork and housing, as well as the rubber flap. ␣ Renew seal if necessary.
    Rear window and moon roof
    ␣ Diagnosis: Ingress of water into the luggage compartment area ␣ Ingress of water into the luggage compartment area
    ␣ Cause: Rear window and moon roof leaking. Check for leak in the same way as for leaking windscreen. ␣ Rear window and moon roof leaking. ␣ Check for leak in the same way as for leaking windscreen.
    Panel connections with seal welds
    ␣ Cause: Several panel connections must be fitted in production in the wheelhouse and luggage compartment areas. These connections are sealed with sealing compound. Uneven application of sealing compound can lead to a break in a seal weld.
    ␣ Several panel connections must be fitted in production in the wheelhouse and luggage compartment areas. These connections are sealed with sealing compound.
    ␣ Uneven application of sealing compound can lead to a break in a seal weld. ␣ Corrective action: Expose the seal weld. Locate the leak in the seal weld. Re-seal using sealing compound.
    ␣ Expose the seal weld. ␣ Locate the leak in the seal weld. ␣ Re-seal using sealing compound.
    Виден столичен ихтиолог
    От: Теч в купето на Диско 3
    Марто, един въпрос - имаш ли люк?
    Една от възможните причини е запушване на отводнителните канали които вървят в колоната.
    Ако ли не -в текста посочената причина е нарушаване на слоя лепило (цепнатини ) под или около стъклото. Посочените начини на установяване чрез надуване с сгъстен въздух отвътре (нещо не ми е ясно как става точно) вероятно със спрей, и при внимателно повдигната лайсна отвън (съветват да се ползва пластмасова подложка) и се следи къде е теча. Може да се направи и воден тест - от вън на вътре - ... за целта трябва втори човек да следи отвътре къде тече. Ако имаш люк е вероятно теча да е от запушените канали и е добре да се тръгне от там.
    Последно редактирано от Slick; 19-04-14, 06:36.
      Първоначално публикуван от Slick Преглед на мнение
      Да, най вероятно е от люка,само да спре дъжда и го почвам...Дренажните тъбички най-вероятно са запушени.
        Такаа...
        Как се решава проблема стъпка по стъпка.
        1.Сваля се кората на А-колоната.Под капачката AIR BAG се намира имбус
        След неуспешни опити да развия имбуса пред блока , работата отиде на разпробиване...
        3.Сваля се тавана, за да се достигне дренажната тръбичка.
        Тръбичката се изважда. И ако сте късметлии,може да я отпушите с въздух под налягане.
        Аз обаче нали съм си карък....Маркучето беше здраво запушено...Пробвах с кабел,после пак надух с въздух...Изведнъж се ,,отпуши''. Налях с фуния вода за проба,която отново се изля в купето...Явно или маркучето е гръмнало, или е излязла накоя снадка...Разглобих подкалника-не се вижда нищо.Последва разглобяване на де що има пластмаси в краката на шофьора (маркучето не се вижда къде ходи, лежане на мокрия мокет и откриване на заветната дупка, в която е бил маркуча .А се оказа виновно ето това коленце ( предизвикало и самото запушване) ,гръмнало от налягането и излязло от дупката .
        Под ръка имах пневматичен маркуч със същия диаметър, с който смених оригиналния и работата заспа .
        Следва сушене...
          От: Теч в купето на Land Rover Discovery 3
          Супер си се справил
          Уффф .. бахти колко работа заради тая дрисня от 5 ст.
          Колко време ти отне веселбата?
            Супер си се справил
            Половин ден...Следващия път (a такъв ще има със сигурност ) ,може и по-бързо.От пасажерската страна е по-лесно, изхода е зад декоративната решетка в калника,от шофьорската пада голямо гъзурчене...А и не знаех откъде точно трябва да излезе дренажа...А дупки-бол....По едно време си мислех,че ще се наложи да свалям и таблото...
              Много полезно, като се има предвид, че рано или късно и ние ще минем на 3-ки...
              Land Lord Discovery II TD5 + Garmin Oregon 450 + Norica Marvik Gold + Sprint Apolon + Liverpool fan.
              LZ2РSD
                Първоначално публикуван от shaterhand Преглед на мнение
                По принцип никоя кола с шибедах не е застрахована и проблема се решава по подобен начин . Номера е да знаеш къде да търсиш дренажа.Входа е ясен, намирането на изхода обаче е гадна работа...Иначе пожелавам на всички двойкаджии скоро да станат тройкаджии, че защо не и четворкаджии
                  До бат'Марто: Извинявам се че разводнявам темата ама се опитвам да ти пратя лично съобщение, но ми дава че ти е пълна пощата.
                  Би ли изтрил малко съобщения ако може да ти пратя едно лично или тук да пиша, нищо че не е по темата?
                  Съобщение от модератор:
                  Моля, напишете си в профила от къде сте.
                  Прочетохте ли това
                  ...ЦЪК
                  Последно редактирано от PETER PETRAKIEV; 03-11-14, 16:53.
                    Първоначално публикуван от maxaffey Преглед на мнение
                    До бат'Марто: Извинявам се че разводнявам темата ама се опитвам да ти пратя лично съобщение, мо ми дава че ти е пълна пощата. Би ли изтрил малко съобщения ако може да ти пратя едно лично или тук да пиша, нищо че не е по темата?
                    Чистя.Но винаги може и тук да питаш .
                      Благодаря много за описанието, много ми помогна за отстраняване на теча в купето.
                      ...ЦЪК
                        Радвам се,че съм помогнал. Нали за това е Форума!При теб от коя страна беше запушването ?
                          Такааа...след 5 години дойде ред и на десния дренаж.Вече като врял и кипял решавам,че операцията е рутинна(затова няма и снимки).И сега внимание !!! От дясно е още по-голям К@Р ! Дренажа е изведен под решетката на въздухозаборника на калника със същото гадно и калпаво коленце(неговата мама),което ако излезе от гнездото си,няма намиране,ако не знаеш къде е.А и да знаеш,няма начин,без да разглобиш половината кола да го смениш.Лошото е,че по описаните по-горе процедури,няма от къде да бъде изведено бекъп маркуче в подкалника.Изведох го с триста зора през една от отводнителните тапи на пода.Ако на някой му се наложи процедурата, да се обажда,ще му спестя разглобяването на половината кола-вежда(арка),подкалник, радиаторна решетка, десен фар и половината кори в купето и др.
