Измерване на скорост с GPS
  • Измерване на скорост с GPS
    Чудя се какъв е начинът за измерване на скороста при GPS-те и доколко може да се разчита на тази информация. Как се влияе от малките особоености на релефа и т.н. и какви са възможностите за отклонения.
    Конкретно, с моя - Garmin Vista C, когато съм обръщал внимание в колата, всичко ми е изглеждало сравнително точно, но вчера правих разни други експерименти и се чудя....
    Идеи?
    Re: Измерване на скорост с GPS
    Първоначално публикуван от jimmy Преглед на мнение
    Идеи?
    съвсем точно е
    LZ1RED
      Ето ти малко инфо
      GPS Speed:
      How accurate is it? How fast can I go? How HIGH can I go?
      GPS receivers display speed and calculate the speed using algorithms in the Kalman filter. Most receivers compute speed by a combination of movement per unit time and computing the doppler shift in the pseudo range signals from the satellites. The speed is smoothed and not instantaneous speed.
      HOW ACCURATE IS THE SPEED READING?
      From the NAVSTAR GPS User Equipment Introduction document Section 3.7:
      GPS receivers typically calculate velocity by measuring the frequency shift (Doppler shift) of the GPS D-band carrier(s). Velocity accuracy can be scenario dependent, (multipath, obstructed sky view from the dash of a car, mountains, city canyons, bad DOP) but 0.2 m/sec per axis (95%) is achievable for PPS and SPS velocity accuracy is the same as PPS when SA is off.
      Velocity measured by a GPS is inherently 3 dimension, but consumer GPS receivers only report 2D (horizontal) speed on their readout. Garmin's specifications quote 0.1mph accuracy but due to signal degredation problems noted above, perhaps 0.5mph accuracy in typical automobile applications would be what you can count on.
      HOW FAST CAN I GO AND HAVE MY GPS READOUT MY SPEED?
      All Currently manufactured CONSUMER GPS receivers we know about will measure speed to 999 miles per hour.
      Garmin (uniquely as far as we know) manufactured the G-38, G-40, G-45, and the G-II (not PLUS) units which had a 90 mph speed readout limit. These units are manufacturing discontinued and we know of no other manufacturer who made a unit which would not go to 999mph.
      HOW HIGH CAN I GO AND HAVE MY GPS READOUT ALTITUDE?
      Defense department regulations prohibit standard consumer GPS receivers from functioning above 60,000 feet and 999mph (simultaneously). Most GPS receivers seem to set hard limits at EITHER 999mph or 60,000 feet.
      Например за 60csx
      Velocity: 0.05 meters / sec.
      Мисля че ни устроива
        Мда. И аз така предполагах, но да питам все пак.
        Потресен съм. От скороста, която развивам със ски.
          колко :-)
          моят рекорд е 93 км/ч
          LZ1RED
            115 km/h без много напъни.
              Виж това, има файл от мапсоурсе
                ГПС-а мери доста точно, НО има едно НО, понякога особено при лоша видимост на спътниците, допуска грешки с позицията и когато "навакса" до вярното място, понякога показва Интересни стойности особено за Максималната скорост, аз мисля имах в откраднатият ГПС макс. скорост от > 900км/ч а повярваите ми "Джипа" не вдига толкова.
                Но аз лично си "калибрирам" скоростомера на колата с ГПС-а, за това е повече от точен, за разлика от този на колата - Фабрично винаги има завишаване на скоростта показвана от скоростомера с цел избягване на бързото каране, това обаче лесно се "корегира" с по-голями гуми
                  Първоначално публикуван от alex_markov Преглед на мнение
                  Да този ефект с наваксването е готин. И моита джипка от време на време излита в орбита.
                    Имаш отсечка в която пише 140км/ч
                    LZ1PER
                      а като прибавиш и вертикалното отместване
                        после моторите били опасни! В интере на истината знам за повече случй със счупвания на ски от колкото с мотори! А не познавам много скиори!
                          Опасни са си, аз пък знам за най-много пострадали от ски, след това от мотори и най-накрая от джипки...
                          VPetrov.photography
                            Лошото е че все повече стават пострадалите при катастрофи докато някой е блеел в GPS-а . Така че внимателно с гледането! Верно че много помага ама и и разсейва!
                            ВѢРНОСТЬ И ПОСТОЯНСТВО
                              Показва с 6 км /над 20 опитни замервания/ в минус поне на моя Nuvi 660 спрямо километража пробвах и Nuvi 350 в друг авомобил и той отчита по малка скорост отколкото на километраж. едно приятелче има запаметена скорост в Нуви 350 ...277км/ч
                              S klase Mercedes V6, 3200cc, 204 к.с., 500 Нм.
                              или както е казал чипа: 240 к.с., 650 Нм.
                              пауър та пауър...пистолетен изстрел :lol:
